[U-Boot] Bootdelay -1 for none autoboot does not work
i am using u-boot 213.07 and hav set CONFIG_BOOTDELAY to -1 to prevent autoboot. But u-boot seems to ignore the parameter and do autoboot after 1 second. Could someon please help why I cannot disable autoboot?
Regards Mario
Hi Mario,
Do you by chance have 'bootdelay' saved in a persistent environment?
If memory serves, the 'bootdelay' environment variable over-rides the default from the CONFIG variable.
On Mon, 7 Oct 2013, Eric Nelson wrote:
Hi Mario,
what board is this on?
rday
the board uses an Freescale i.MX35 Controller.
When I use the u-boot revision 2013.01.01 with same configuration all works fine (-1 disables autoboot) Only when I use u-boot 2013.07 it does not work. I have looked in main.c and found the following differences:
2013.01.01: Line 68: #if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) 2013.07: Line 88: #if defined(CONFIG_BOOTDELAY)
2013.01.01: Line 298: #if defined(CONFIG_BOOTDELAY) && (CONFIG_BOOTDELAY >= 0) && defined(CONFIG_OF_CONTROL) 2013.07: Line 286: #if defined(CONFIG_BOOTDELAY) && defined(CONFIG_OF_CONTROL)
Could it be, that -1 Value for disable autoboot is not longer supported in u-boot 2013.07?
Regards Mario
-----Ursprüngliche Nachricht----- Von: Robert P. J. Day [mailto:rpjday@crashcourse.ca] Gesendet: Montag, 7. Oktober 2013 21:10 An: Eric Nelson Cc: Mario Albrecht; u-boot@lists.denx.de Betreff: Re: [U-Boot] Bootdelay -1 for none autoboot does not work
Hi Mario,
rday
i have found a working configuration. When I comment out the CONFIG_BOOTDELAY in the board header file, autoboot is disabled.
Regards Mario
Hi Mario,
rday
Eric Nelson
Mario Albrecht
Robert P. J. Day
