[PATCH 0/3] arm: Add Analog Devices SC5xx Machine Type
This series adds support for the ADI SC5xx machine type and includes two core drivers that are required for being able to boot any board--a UART driver and the clock tree driver. Our corresponding Linux support relies on u-boot configuring the clocks correctly before booting, so it is not possible to boot any board without the CGU/CDU configuration happening here. The clock tree itself is only used by the UART in this minimal patch set, but is of course broadly useful for all other peripheral drivers to be submitted in future patch sets. There are also no board files or defconfigs included here, but some common definitions that will be used to build board files currently are.
Some of the configuration code in dmcinit and clkinit is quite scary and causes a lot of checkpatch violations. It is modified from code initially provided by ADI, but it has not been fully rewritten. There's a question of how important it is to clean up this code--it has some quality violations, but it has been in use (including in production) for over two years and is known to work for performing the low level SoC initialization, while a rewrite might introduce bugs that could take a significant amount of time to detect in the future.
Please provide any feedback or comments that will be helpful in creating a v2 of this patch that will be ready to submit for inclusion into the main tree, as well as general observations that we should consider in other driver patches before submitting them.
Thank you!
Nathan Barrett-Morrison (3): arch: arm: Add Analog Devices SC5xx machine type drivers: clk: adi: Add in SC5XX-family clock driver drivers: serial: Add in UART for ADI SC5XX-family processors
MAINTAINERS | 15 + arch/arm/Kconfig | 6 + arch/arm/Makefile | 1 + arch/arm/include/asm/arch-adi/sc5xx/sc5xx.h | 115 +++ arch/arm/include/asm/arch-adi/sc5xx/soc.h | 18 + arch/arm/include/asm/arch-adi/sc5xx/spl.h | 41 + arch/arm/include/asm/mach-types.h | 4 + arch/arm/mach-sc5xx/Kconfig | 464 +++++++++ arch/arm/mach-sc5xx/Makefile | 19 + arch/arm/mach-sc5xx/config.mk | 21 + arch/arm/mach-sc5xx/init/Makefile | 11 + arch/arm/mach-sc5xx/init/clkinit.c | 543 +++++++++++ arch/arm/mach-sc5xx/init/clkinit.h | 18 + arch/arm/mach-sc5xx/init/dmcinit.c | 973 +++++++++++++++++++ arch/arm/mach-sc5xx/init/dmcinit.h | 29 + arch/arm/mach-sc5xx/init/init.c | 68 ++ arch/arm/mach-sc5xx/init/init.h | 37 + arch/arm/mach-sc5xx/init/mem/is43tr16512bl.h | 63 ++ arch/arm/mach-sc5xx/init/mem/mt41k128m16jt.h | 51 + arch/arm/mach-sc5xx/init/mem/mt41k512m16ha.h | 51 + arch/arm/mach-sc5xx/init/mem/mt47h128m16rt.h | 50 + arch/arm/mach-sc5xx/rcu.c | 22 + arch/arm/mach-sc5xx/sc57x.c | 21 + arch/arm/mach-sc5xx/sc58x.c | 21 + arch/arm/mach-sc5xx/sc59x.c | 32 + arch/arm/mach-sc5xx/sc59x_64.c | 36 + arch/arm/mach-sc5xx/soc.c | 142 +++ arch/arm/mach-sc5xx/spl.c | 140 +++ drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/adi/Kconfig | 83 ++ drivers/clk/adi/Makefile | 16 + drivers/clk/adi/clk-adi-pll.c | 94 ++ drivers/clk/adi/clk-adi-sc57x.c | 205 ++++ drivers/clk/adi/clk-adi-sc58x.c | 221 +++++ drivers/clk/adi/clk-adi-sc594.c | 230 +++++ drivers/clk/adi/clk-adi-sc598.c | 307 ++++++ drivers/clk/adi/clk-shared.c | 48 + drivers/clk/adi/clk.h | 122 +++ drivers/serial/Makefile | 1 + drivers/serial/serial_adi_uart4.c | 228 +++++ include/configs/sc_adi_common.h | 226 +++++ include/dt-bindings/clock/adi-sc5xx-clock.h | 271 ++++++ 43 files changed, 5066 insertions(+) create mode 100644 arch/arm/include/asm/arch-adi/sc5xx/sc5xx.h create mode 100644 arch/arm/include/asm/arch-adi/sc5xx/soc.h create mode 100644 arch/arm/include/asm/arch-adi/sc5xx/spl.h create mode 100644 arch/arm/mach-sc5xx/Kconfig create mode 100644 arch/arm/mach-sc5xx/Makefile create mode 100644 arch/arm/mach-sc5xx/config.mk create mode 100644 arch/arm/mach-sc5xx/init/Makefile create mode 100644 arch/arm/mach-sc5xx/init/clkinit.c create mode 100644 arch/arm/mach-sc5xx/init/clkinit.h create mode 100644 arch/arm/mach-sc5xx/init/dmcinit.c create mode 100644 arch/arm/mach-sc5xx/init/dmcinit.h create mode 100644 arch/arm/mach-sc5xx/init/init.c create mode 100644 arch/arm/mach-sc5xx/init/init.h create mode 100644 arch/arm/mach-sc5xx/init/mem/is43tr16512bl.h create mode 100644 arch/arm/mach-sc5xx/init/mem/mt41k128m16jt.h create mode 100644 arch/arm/mach-sc5xx/init/mem/mt41k512m16ha.h create mode 100644 arch/arm/mach-sc5xx/init/mem/mt47h128m16rt.h create mode 100644 arch/arm/mach-sc5xx/rcu.c create mode 100644 arch/arm/mach-sc5xx/sc57x.c create mode 100644 arch/arm/mach-sc5xx/sc58x.c create mode 100644 arch/arm/mach-sc5xx/sc59x.c create mode 100644 arch/arm/mach-sc5xx/sc59x_64.c create mode 100644 arch/arm/mach-sc5xx/soc.c create mode 100644 arch/arm/mach-sc5xx/spl.c create mode 100644 drivers/clk/adi/Kconfig create mode 100644 drivers/clk/adi/Makefile create mode 100644 drivers/clk/adi/clk-adi-pll.c create mode 100644 drivers/clk/adi/clk-adi-sc57x.c create mode 100644 drivers/clk/adi/clk-adi-sc58x.c create mode 100644 drivers/clk/adi/clk-adi-sc594.c create mode 100644 drivers/clk/adi/clk-adi-sc598.c create mode 100644 drivers/clk/adi/clk-shared.c create mode 100644 drivers/clk/adi/clk.h create mode 100644 drivers/serial/serial_adi_uart4.c create mode 100644 include/configs/sc_adi_common.h create mode 100644 include/dt-bindings/clock/adi-sc5xx-clock.h
From: Nathan Barrett-Morrison nathan.morrison@timesys.com
Add support for the SC5xx machine type from Analog Devices. This includes support for the SC57x, SC58x, SC59x, and SC59x-64 SoCs, which have many common features such as common ADI IP blocks, and SHARC DSP cores. This commit introduces core functionality required for all boards using an SC5xx SoC, such as:
- SPL configuration - Required CPU hooks such as reset - Boot ROM interaction to load the stage 2 bootloader in the reference configuration. Other options are possible but not officially supported at this time - SoC-common configuration expected to be reused by all boards - Early initialization for system clocks and DDR controller
Co-developed-by: Greg Malysa greg.malysa@timesys.com Signed-off-by: Greg Malysa greg.malysa@timesys.com Co-developed-by: Ian Roberts ian.roberts@timesys.com Signed-off-by: Ian Roberts ian.roberts@timesys.com Signed-off-by: Vasileios Bimpikas vasileios.bimpikas@analog.com Signed-off-by: Utsav Agarwal utsav.agarwal@analog.com Signed-off-by: Arturs Artamonovs arturs.artamonovs@analog.com Signed-off-by: Nathan Barrett-Morrison nathan.morrison@timesys.com
--- MAINTAINERS | 13 + arch/arm/Kconfig | 6 + arch/arm/Makefile | 1 + arch/arm/include/asm/arch-adi/sc5xx/sc5xx.h | 115 +++ arch/arm/include/asm/arch-adi/sc5xx/soc.h | 18 + arch/arm/include/asm/arch-adi/sc5xx/spl.h | 41 + arch/arm/include/asm/mach-types.h | 4 + arch/arm/mach-sc5xx/Kconfig | 464 +++++++++ arch/arm/mach-sc5xx/Makefile | 19 + arch/arm/mach-sc5xx/config.mk | 21 + arch/arm/mach-sc5xx/init/Makefile | 11 + arch/arm/mach-sc5xx/init/clkinit.c | 543 +++++++++++ arch/arm/mach-sc5xx/init/clkinit.h | 18 + arch/arm/mach-sc5xx/init/dmcinit.c | 973 +++++++++++++++++++ arch/arm/mach-sc5xx/init/dmcinit.h | 29 + arch/arm/mach-sc5xx/init/init.c | 68 ++ arch/arm/mach-sc5xx/init/init.h | 37 + arch/arm/mach-sc5xx/init/mem/is43tr16512bl.h | 63 ++ arch/arm/mach-sc5xx/init/mem/mt41k128m16jt.h | 51 + arch/arm/mach-sc5xx/init/mem/mt41k512m16ha.h | 51 + arch/arm/mach-sc5xx/init/mem/mt47h128m16rt.h | 50 + arch/arm/mach-sc5xx/rcu.c | 22 + arch/arm/mach-sc5xx/sc57x.c | 21 + arch/arm/mach-sc5xx/sc58x.c | 21 + arch/arm/mach-sc5xx/sc59x.c | 32 + arch/arm/mach-sc5xx/sc59x_64.c | 36 + arch/arm/mach-sc5xx/soc.c | 142 +++ arch/arm/mach-sc5xx/spl.c | 140 +++ include/configs/sc_adi_common.h | 226 +++++ 29 files changed, 3236 insertions(+) create mode 100644 arch/arm/include/asm/arch-adi/sc5xx/sc5xx.h create mode 100644 arch/arm/include/asm/arch-adi/sc5xx/soc.h create mode 100644 arch/arm/include/asm/arch-adi/sc5xx/spl.h create mode 100644 arch/arm/mach-sc5xx/Kconfig create mode 100644 arch/arm/mach-sc5xx/Makefile create mode 100644 arch/arm/mach-sc5xx/config.mk create mode 100644 arch/arm/mach-sc5xx/init/Makefile create mode 100644 arch/arm/mach-sc5xx/init/clkinit.c create mode 100644 arch/arm/mach-sc5xx/init/clkinit.h create mode 100644 arch/arm/mach-sc5xx/init/dmcinit.c create mode 100644 arch/arm/mach-sc5xx/init/dmcinit.h create mode 100644 arch/arm/mach-sc5xx/init/init.c create mode 100644 arch/arm/mach-sc5xx/init/init.h create mode 100644 arch/arm/mach-sc5xx/init/mem/is43tr16512bl.h create mode 100644 arch/arm/mach-sc5xx/init/mem/mt41k128m16jt.h create mode 100644 arch/arm/mach-sc5xx/init/mem/mt41k512m16ha.h create mode 100644 arch/arm/mach-sc5xx/init/mem/mt47h128m16rt.h create mode 100644 arch/arm/mach-sc5xx/rcu.c create mode 100644 arch/arm/mach-sc5xx/sc57x.c create mode 100644 arch/arm/mach-sc5xx/sc58x.c create mode 100644 arch/arm/mach-sc5xx/sc59x.c create mode 100644 arch/arm/mach-sc5xx/sc59x_64.c create mode 100644 arch/arm/mach-sc5xx/soc.c create mode 100644 arch/arm/mach-sc5xx/spl.c create mode 100644 include/configs/sc_adi_common.h
diff --git a/MAINTAINERS b/MAINTAINERS index 83fd68e3f3..9693b86ddd 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -598,6 +598,19 @@ R: Marc Murphy marc.murphy@sancloud.com S: Supported F: arch/arm/dts/am335x-sancloud*
+ARM SC5XX +M: Nathan Barrett-Morrison nathan.morrison@timesys.com +M: Greg Malysa greg.malysa@timesys.com +M: Ian Roberts ian.roberts@timesys.com +M: Vasileios Bimpikas vasileios.bimpikas@analog.com +M: Utsav Agarwal utsav.agarwal@analog.com +M: Arturs Artamonovs arturs.artamonovs@analog.com +S: Supported +T: git https://github.com/analogdevicesinc/lnxdsp-u-boot +F: arch/arm/include/asm/arch-adi/ +F: arch/arm/mach-sc5xx/ +F: include/configs/sc_adi_common.h + ARM SNAPDRAGON M: Caleb Connolly caleb.connolly@linaro.org M: Neil Armstrong neil.armstrong@linaro.org diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index a0842e1933..fdaf4e23d0 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1843,6 +1843,10 @@ config TARGET_LS1046AFRWY development platform that supports the QorIQ LS1046A Layerscape Architecture processor.
+config ARCH_SC5XX + bool "Analog Devices SC5XX-processor family" + select STATIC_MACH_TYPE + config TARGET_SL28 bool "Support sl28" select ARCH_LS1028A @@ -2276,6 +2280,8 @@ source "arch/arm/mach-rockchip/Kconfig"
source "arch/arm/mach-s5pc1xx/Kconfig"
+source "arch/arm/mach-sc5xx/Kconfig" + source "arch/arm/mach-snapdragon/Kconfig"
source "arch/arm/mach-socfpga/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index a4266a3e36..734c6d6992 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -78,6 +78,7 @@ machine-$(CONFIG_ARCH_OWL) += owl machine-$(CONFIG_ARCH_RENESAS) += renesas machine-$(CONFIG_ARCH_ROCKCHIP) += rockchip machine-$(CONFIG_ARCH_S5PC1XX) += s5pc1xx +machine-$(CONFIG_ARCH_SC5XX) += sc5xx machine-$(CONFIG_ARCH_SNAPDRAGON) += snapdragon machine-$(CONFIG_ARCH_SOCFPGA) += socfpga machine-$(CONFIG_ARCH_STM32) += stm32 diff --git a/arch/arm/include/asm/arch-adi/sc5xx/sc5xx.h b/arch/arm/include/asm/arch-adi/sc5xx/sc5xx.h new file mode 100644 index 0000000000..bcac3ad8e3 --- /dev/null +++ b/arch/arm/include/asm/arch-adi/sc5xx/sc5xx.h @@ -0,0 +1,115 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ +#ifndef ARCH_ADI_SC5XX_SC5XX_H +#define ARCH_ADI_SC5XX_SC5XX_H + +#include <inttypes.h> + +#ifdef CONFIG_SC57X +#define L2_SRAM_BASE 0x20000000 +#else +#define L2_SRAM_BASE 0x20080000 +#endif + +#define TWI0_CLKDIV 0x31001400 // TWI0 SCL Clock Divider Register +#define TWI1_CLKDIV 0x31001500 // TWI1 SCL Clock Divider Register +#define TWI2_CLKDIV 0x31001600 // TWI2 SCL Clock Divider Register + +#ifdef CONFIG_SC58X +#define RCU0_CTL 0x3108B000 // RCU0 Control Register +#define RCU0_STAT 0x3108B004 // RCU0 Status Register +#define RCU0_CRCTL 0x3108B008 // RCU0 Core Reset Control Register +#define RCU0_CRSTAT 0x3108B00C // RCU0 Core Reset Status Register +#define RCU0_SIDIS 0x3108B010 // RCU0 System Interface Disable Register +#define RCU0_MSG_SET 0x3108B064 // RCU0 Message Set Bits Register +#else +#define RCU0_CTL 0x3108C000 // RCU0 Control Register +#define RCU0_STAT 0x3108C004 // RCU0 Status Register +#define RCU0_CRCTL 0x3108C008 // RCU0 Core Reset Control Register +#define RCU0_CRSTAT 0x3108C00C // RCU0 Core Reset Status Register +#define RCU0_SIDIS 0x3108C01C // RCU0 System Interface Disable Register +#define RCU0_MSG_SET 0x3108C070 // RCU0 Message Set Bits Register +#endif + +#define BITP_RCU_STAT_BMODE 8 // Boot Mode +#define BITM_RCU_STAT_BMODE 0x00000F00 // Boot Mode + +#ifdef CONFIG_SC58X +#define REG_SPU0_CTL 0x3108C000 // SPU0 Control Register +#else +#define REG_SPU0_CTL 0x3108B000 // SPU0 Control Register +#define REG_SPU0_SECUREC0 0x3108B980 // SPU0 Secure Core Registers +#define REG_SPU0_SECUREC1 0x3108B984 // SPU0 Secure Core Registers +#define REG_SPU0_SECUREC2 0x3108B988 // SPU0 Secure Core Registers +#define REG_SPU0_SECURECn(i) (REG_SPU0_SECUREC0 + ((i) * 4)) +#define REG_SPU0_SECURECn_COUNT 3 +#endif + +#define CGU0_CTL 0x3108D000 // CGU0 Control Register +#define CGU0_PLLCTL 0x3108D004 // CGU0 PLL Control Register +#define CGU0_STAT 0x3108D008 // CGU0 Status Register +#define CGU0_DIV 0x3108D00C // CGU0 Clocks Divisor Register +#define CGU0_CLKOUTSEL 0x3108D010 // CGU0 CLKOUT Select Register +#define CGU0_DIVEX 0x3108D040 // CGU0 DIV Register Extension + +#define CGU1_CTL 0x3108E000 // CGU1 Control Register +#define CGU1_PLLCTL 0x3108E004 // CGU1 PLL Control Register +#define CGU1_STAT 0x3108E008 // CGU1 Status Register + +#define BITP_CGU_DIV_OSEL 22 // OUTCLK Divisor +#define BITP_CGU_DIV_DSEL 16 // DCLK Divisor +#define BITP_CGU_DIV_S1SEL 13 // SCLK 1 Divisor +#define BITP_CGU_DIV_SYSSEL 8 // SYSCLK Divisor +#define BITP_CGU_DIV_S0SEL 5 // SCLK 0 Divisor +#define BITP_CGU_DIV_CSEL 0 // CCLK Divisor + +#define BITP_CGU_CTL_MSEL 8 // Multiplier Select +#define BITP_CGU_CTL_DF 0 // Divide Frequency + +#define BITM_CGU_STAT_CLKSALGN 0x00000008 +#define BITM_CGU_STAT_PLOCK 0x00000004 +#define BITM_CGU_STAT_PLLBP 0x00000002 +#define BITM_CGU_STAT_PLLEN 0x00000001 + +#define REG_MISC_REG10_tst_addr 0x310A902C + +#define REG_USB0_FADDR 0x310C1000 // USB0 Function Address Register +#define REG_USB0_DMA_IRQ 0x310C1200 // USB0 DMA Interrupt Register +#define REG_USB0_VBUS_CTL 0x310C1380 // USB0 VBUS Control Register +#define REG_USB0_PHY_CTL 0x310C1394 // USB0 PHY Control Register +#define REG_USB0_PLL_OSC 0x310C1398 // USB0 PLL and Oscillator Control Register +#define REG_USB0_UTMI_CTL 0x310C139C + +#define BITP_USB_DMA_CTL_IE 3 // DMA Interrupt Enable +#define BITP_USB_DMA_CTL_DIR 1 // DMA Transfer Direction +#define BITP_USB_DMA_CTL_EN 0 // DMA Enable + +#if defined(CONFIG_SC59X) + #define pRCU_MSG ((void __iomem *)0x3108C06C) +#elif defined(CONFIG_SC59X_64) + #define pRCU_MSG ((void __iomem *)0x3108C06C) + #define pREG_EMSI0_SWRST ((void __iomem *)0x310C702F) +#elif defined(CONFIG_SC57X) + #define pRCU_MSG ((void __iomem *)0x3108C06C) +#elif defined(CONFIG_SC58X) + #define pRCU_MSG ((void __iomem *)0x3108B06C) +#endif + +const char *sc5xx_get_boot_mode(u32 *bmode); +void sc5xx_enable_rgmii(void); + +/* + * Reconfigure SPI memory map region for OSPI use. The adi-spi3 driver + * does not use the memory map, while the OSPI driver requires it. Only + * available on sc59x and sc59x-64 + */ +void sc59x_remap_ospi(void); + +#endif diff --git a/arch/arm/include/asm/arch-adi/sc5xx/soc.h b/arch/arm/include/asm/arch-adi/sc5xx/soc.h new file mode 100644 index 0000000000..430dbe2dae --- /dev/null +++ b/arch/arm/include/asm/arch-adi/sc5xx/soc.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#ifndef BOARD_ADI_COMMON_SOC_H +#define BOARD_ADI_COMMON_SOC_H + +#include <phy.h> + +void fixup_dp83867_phy(struct phy_device *phydev); + +#endif diff --git a/arch/arm/include/asm/arch-adi/sc5xx/spl.h b/arch/arm/include/asm/arch-adi/sc5xx/spl.h new file mode 100644 index 0000000000..946d599b56 --- /dev/null +++ b/arch/arm/include/asm/arch-adi/sc5xx/spl.h @@ -0,0 +1,41 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ +#ifndef ARCH_ADI_SC5XX_SPL_H +#define ARCH_ADI_SC5XX_SPL_H + +#include <netdev.h> +#include <phy.h> +#include <asm/io.h> +#include <asm/mach-types.h> +#include <asm/arch-adi/sc5xx/sc5xx.h> +#include <linux/delay.h> +#include <linux/stringify.h> +#include <watchdog.h> +#include <asm/spl.h> + +struct adi_boot_args { + phys_addr_t addr; + u32 flags; + u32 cmd; +}; + +extern u32 bmode; + +extern const struct adi_boot_args adi_rom_boot_args[8]; + +// Struct layout is processor specific +struct ADI_ROM_BOOT_CONFIG; + +int32_t adi_rom_boot_hook(struct ADI_ROM_BOOT_CONFIG *cfg, int32_t cause); + +extern void (*adi_rom_boot)(void *address, uint32_t flags, int32_t count, + void *hook, uint32_t command); + +#endif diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index 2713b1d2c5..3e577fc0f1 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -5050,4 +5050,8 @@ #define MACH_TYPE_NASM25 5112 #define MACH_TYPE_TOMATO 5113 #define MACH_TYPE_OMAP3_MRC3D 5114 +#define MACH_TYPE_SC57X 5115 +#define MACH_TYPE_SC58X 5116 +#define MACH_TYPE_SC59X 5117 +#define MACH_TYPE_SC59X_64 5118 #endif diff --git a/arch/arm/mach-sc5xx/Kconfig b/arch/arm/mach-sc5xx/Kconfig new file mode 100644 index 0000000000..b1253290f2 --- /dev/null +++ b/arch/arm/mach-sc5xx/Kconfig @@ -0,0 +1,464 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# (C) Copyright 2022 - Analog Devices, Inc. +# +# Written and/or maintained by Timesys Corporation +# +# Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com +# Contact: Greg Malysa greg.malysa@timesys.com +# + +# All 32-bit platforms require SYS_ARM_CACHE_WRITETHROUGH +# But it is ignored if selected here, so it must be in the defconfig + +if ARCH_SC5XX + +config TARGET_SC573_EZKIT + bool "Analog Devices SC573 EZ Kit" + select SC57X + +config SC57X + bool + select SUPPORT_SPL + select CPU_V7A + select PANIC_HANG + select COMMON_CLK_ADI_SC57X + select TIMER + select ADI_SC5XX_TIMER + +config SC58X + bool + select SUPPORT_SPL + select CPU_V7A + select PANIC_HANG + select COMMON_CLK_ADI_SC58X + select TIMER + select ADI_SC5XX_TIMER + +config SC59X + bool + select SUPPORT_SPL + select CPU_V7A + select PANIC_HANG + select COMMON_CLK_ADI_SC594 + select TIMER + select ADI_SC5XX_TIMER + select NOP_PHY + +config SC59X_64 + bool + select SUPPORT_SPL + select PANIC_HANG + select MMC_SDHCI_ADMA_FORCE_32BIT + select ARM64 + select DM + select DM_SERIAL + select COMMON_CLK_ADI_SC598 + select GICV3 + select GIC_600_CLEAR_RDPD + select NOP_PHY + +# These need to match the constants in arch/arm/include/asm/mach-types.h +config MACH_TYPE + default 5115 if SC57X + default 5116 if SC58X + default 5117 if SC59X + default 5118 if SC59X_64 + +config SC_BOOT_MODE + int "SC5XX boot mode select" + default 1 + range 0 7 + help + Mode 0: do nothing, just idle + Mode 1: boot ldr out of serial flash + Mode 7: boot ldr over uart + +config SC_BOOT_SPI_BUS + int "sc5xx spi boot bus" + default 2 + range 0 4 + help + This is the SPI peripheral number to use for booting, X in the + expression `sf probe X:Y` + +config SC_BOOT_SPI_SSEL + int "sc5xx spi boot chipselect" + default 1 + range 0 6 + help + This is the SPI chip select number to use for booting, Y in the + expression `sf probe X:Y` + +config SC_BOOT_OSPI_BUS + int "sc5xx ospi boot bus" + default 0 + help + This is the OSPI peripheral number to use for booting, X in the + expression `sf probe X:Y` + +config SC_BOOT_OSPI_SSEL + int "sc5xx ospi boot chipselect" + default 0 + help + This is the OSPI chip select number to use for booting, Y in the + expression `sf probe X:Y` + +config SYS_FLASH_BASE + hex + default 0x60000000 + +config UART_CONSOLE + int + default 0 + +config UART4_SERIAL + bool + depends on DM_SERIAL + default y + +config WDT_ADI + bool + default y + +config WATCHDOG_TIMEOUT_MSECS + int + default 30000 + +config DW_PORTS + int + default 1 + +config ADI_BUG_EZKHW21 + bool "SC584 EZKIT phy bug workaround" + depends on SC58X + default n + help + This workaround affects the SC584 EZKIT and addresses bug EZKHW21. + It disables gigabit ethernet mode and limits the board to 100 Mbps + +config ADI_CARRIER_SOMCRR_EZKIT + bool "Support the EV-SOMCRR-EZKIT" + depends on (SC59X || SC59X_64) + default n + help + Say y to include support for the EV-SOMCRR-EZKIT carrier board, + which is compatible with the SC594 and SC598 SOMs. The EZKIT is + mutually incompatible with the EZLITE. + +config ADI_CARRIER_SOMCRR_EZLITE + bool "Support the EV-SOMCRR-EZLITE" + depends on (SC59X || SC59X_64) + default n + help + Say y to include support for the EV-SOMCRR-EZLITE carrier board, + which is compatible with the SC594 and SC598 SOMs. The EZLITE is + mutually incompatible with the EZKIT. + +config ADI_SPL_FORCE_BMODE + int "Force the SPL to use this BMODE device during next boot stage" + default 0 + range 0 9 + depends on SPL + help + Force the SPL to use this BMODE device during next boot stage. + For example, if booting via QSPI, we can force the second stage + Of the boot process to use other peripherals via: + 1 = QSPI -> QSPI + 5 = QSPI -> OSPI + 6 = QSPI -> eMMC + +menu "Clock configuration" + +config CGU0_DF_DIV + int "CGU0_DF_DIV" + range 0 1 + help + Select 0 to pass CLKIN to PLL + Select 1 to pass CLKIN/2 to PLL + +config CGU0_VCO_MULT + int "CGU0_VCO_MULT" + range 0 127 + help + VCO_MULT controls the MSEL (multiplier) bits in PLL_CTL + A value of 0 means 128 + +config CGU0_CCLK_DIV + int "CGU0_CCLK_DIV" + range 0 31 + help + CCLK_DIV controls the core clock divider + A value of 0 means 32 + CCLK = ((CLKIN / (1 + DF)) * VCO_MULT) / CCLK_DIV + +config CGU0_SCLK_DIV + int "CGU0_SCLK_DIV" + range 0 31 + help + SCLK_DIV controls the system clock divider + A value of 0 means 32 + SCLK = ((CLKIN / (1 + DF)) * VCO_MULT) / SYSCLK_DIV + +config CGU0_SCLK0_DIV + int "CGU0_SCLK0_DIV" + range 0 7 + help + A value of 0 means 8 + SCLK0 = SCLK / SCLK0_DIV + +config CGU0_SCLK1_DIV + int "CGU0_SCLK1_DIV" + depends on (SC57X || SC58X) + range 0 7 + help + A value of 0 means 8 + SCLK1 = SCLK / SCLK1_DIV + +config CGU0_DCLK_DIV + int "CGU0_DCLK_DIV" + range 0 31 + help + DCLK_DIV controls the DDR clock divider + A value of 0 means 32 + DCLK = ((CLKIN / (1 + DF)) * VCO_MULT) / DCLK_DIV + +config CGU0_OCLK_DIV + int "CGU0_OCLK_DIV" + range 0 127 + help + OCLK_DIV controls the output clock divider + A value of 0 means 128 + OCLK = ((CLKIN / (1 + DF)) * VCO_MULT) / OCLK_DIV + +config CGU0_DIV_S1SELEX + int "CGU0_DIV_S1SELEX" + depends on !SC57X && !SC58X + range 0 255 + help + CGU0 SCLK1 Extended divisor register. + A value of 0 means 256. + SCLK1 = ((CLKIN / (1 + DF)) * VCO_MULT) / DIV_S1SELEX + +config CGU0_CLKOUTSEL + int "CGU0_CLKOUTSEL" + default 0 + range 0 31 + help + Select signal driven through CLKOUT pin multiplexer. + This value varies on each SOC. Refer to + CGU_CLKOUTSEL.CLKOUTSEL in the Hardware Reference Manual + for values applicable to each SOC. + Commonly, values 0 and 1 select CLKIN0 or CLKIN1 respectively. + +config CGU1_PLL3_DDRCLK + bool "DDRCLK From 3rd PLL" + depends on SC59X_64 + help + 3rd PLL output is connected to DMC block when set. + When cleared, DDR clock is CLKO3 output of CDU. + +config CGU1_PLL3_VCO_MSEL + int "CGU0_PLL3_VCO_MSEL" + depends on CGU1_PLL3_DDRCLK + range 1 128 + help + PLL multiplier value for the 3rd PLL. + DCLK = (CLKIN * PLL3_VCO_MSEL) / PLL3_DCLK_DIV + +config CGU1_PLL3_DCLK_DIV + int "CGU0_PLL3_DCLK_DIV" + depends on CGU1_PLL3_DDRCLK + range 1 32 + help + PLL divider value for the 3rd PLL. + DCLK = (CLKIN * PLL3_VCO_MSEL) / PLL3_DCLK_DIV + +config CGU1_DF_DIV + int "CGU1_DF_DIV" + range 0 1 + help + Select 0 to pass CLKIN to PLL + Select 1 to pass CLKIN/2 to PLL + +config CGU1_VCO_MULT + int "CGU1_VCO_MULT" + range 0 127 + help + VCO_MULT controls the MSEL (multiplier) bits in PLL_CTL + A value of 0 means 128 + +config CGU1_CCLK_DIV + int "CGU1_CCLK_DIV" + range 0 31 + help + CCLK_DIV controls the core clock divider + A value of 0 means 32 + CCLK = ((CLKIN / (1 + DF)) * VCO_MULT) / CCLK_DIV + +config CGU1_SCLK_DIV + int "CGU1_SCLK_DIV" + range 0 31 + help + SCLK_DIV controls the system clock divider + A value of 0 means 32 + SCLK = ((CLKIN / (1 + DF)) * VCO_MULT) / SYSCLK_DIV + +config CGU1_SCLK0_DIV + int "CGU1_SCLK0_DIV" + depends on (SC57X || SC58X || SC59X) + range 0 7 + help + A value of 0 means 8 + SCLK0 = SCLK / SCLK0_DIV + +config CGU1_SCLK1_DIV + int "CGU1_SCLK1_DIV" + depends on (SC57X || SC58X) + range 0 7 + help + A value of 0 means 8 + SCLK1 = SCLK / SCLK1_DIV + +config CGU1_DCLK_DIV + int "CGU1_DCLK_DIV" + range 0 31 + help + DCLK_DIV controls the DDR clock divider + A value of 0 means 32 + DCLK = ((CLKIN / (1 + DF)) * VCO_MULT) / DCLK_DIV + +config CGU1_OCLK_DIV + int "CGU1_OCLK_DIV" + range 0 127 + help + OCLK_DIV controls the output clock divider + A value of 0 means 128 + OCLK = ((CLKIN / (1 + DF)) * VCO_MULT) / OCLK_DIV + +config CGU1_DIV_S0SELEX + int "CGU1_DIV_S0SELEX" + depends on !SC57X && !SC58X && !SC59X + range 0 255 + help + CGU1 SCLK0 Extended divisor register. + A value of 0 means 256. + SCLK0 = ((CLKIN / (1 + DF)) * VCO_MULT) / DIV_S0SELEX + +config CGU1_DIV_S1SELEX + int "CGU1_DIV_S1SELEX" + depends on !SC57X && !SC58X + range 0 255 + help + CGU1 SCLK1 Extended divisor register. + A value of 0 means 256. + SCLK1 = ((CLKIN / (1 + DF)) * VCO_MULT) / DIV_S1SELEX + +config CDU0_CGU1_CLKIN + int "CDU0 CGU1 CLKINn Select" + default 0 + range 0 1 + help + Selects source clock for CGU1. + 0 for CLKIN0 + 1 for CLKIN1 + +config CDU0_CLKO0 + int "CDU0_CLKO0" + range 1 7 + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO1 + int "CDU0_CLKO1" + range 1 7 + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO2 + int "CDU0_CLKO2" + range 1 7 + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO3 + int "CDU0_CLKO3" + range 1 7 + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO4 + int "CDU0_CLKO4" + range 1 7 + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO5 + int "CDU0_CLKO5" + range 1 7 + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO6 + int "CDU0_CLKO6" + range 1 7 + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO7 + int "CDU0_CLKO7" + range 1 7 + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO8 + int "CDU0_CLKO8" + range 1 7 + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO9 + int "CDU0_CLKO9" + range 1 7 + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO10 + int "CDU0_CLKO10" + range 1 7 + depends on (SC59X || SC59X_64) + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO12 + int "CDU0_CLKO12" + range 1 7 + depends on (SC59X || SC59X_64) + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO13 + int "CDU0_CLKO13" + range 1 7 + depends on SC59X_64 + help + Clock source select. Refer to SOC Hardware Reference Manual + +config CDU0_CLKO14 + int "CDU0_CLKO14" + range 1 7 + depends on SC59X_64 + help + Clock source select. Refer to SOC Hardware Reference Manual + +endmenu + +config ADI_GPIO + default y + +config PINCTRL_ADI + default y + +source "board/adi/sc573-ezkit/Kconfig" + +endif diff --git a/arch/arm/mach-sc5xx/Makefile b/arch/arm/mach-sc5xx/Makefile new file mode 100644 index 0000000000..eeb56c078b --- /dev/null +++ b/arch/arm/mach-sc5xx/Makefile @@ -0,0 +1,19 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# (C) Copyright 2022 - Analog Devices, Inc. +# +# Written and/or maintained by Timesys Corporation +# +# Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com +# Contact: Greg Malysa greg.malysa@timesys.com +# + +obj-y += soc.o init/ + +obj-$(CONFIG_SC57X) += sc57x.o +obj-$(CONFIG_SC58X) += sc58x.o +obj-$(CONFIG_SC59X) += sc59x.o +obj-$(CONFIG_SC59X_64) += sc59x_64.o + +obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_SYSCON) += rcu.o diff --git a/arch/arm/mach-sc5xx/config.mk b/arch/arm/mach-sc5xx/config.mk new file mode 100644 index 0000000000..b80644d6dc --- /dev/null +++ b/arch/arm/mach-sc5xx/config.mk @@ -0,0 +1,21 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# (C) Copyright 2022 - Analog Devices, Inc. +# +# Written and/or maintained by Timesys Corporation +# +# Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com +# Contact: Greg Malysa greg.malysa@timesys.com +# + +ifdef CONFIG_SPL_BUILD +INPUTS-y += $(obj)/u-boot-spl.ldr +endif + +LDR_FLAGS += --bcode=$(CONFIG_SC_BOOT_MODE) +LDR_FLAGS += --use-vmas + +ifndef CONFIG_SC59X_64 + # Select the Analog Devices processor. + PLATFORM_RELFLAGS += -fno-stack-protector -std=gnu89 +endif diff --git a/arch/arm/mach-sc5xx/init/Makefile b/arch/arm/mach-sc5xx/init/Makefile new file mode 100644 index 0000000000..c2835318a6 --- /dev/null +++ b/arch/arm/mach-sc5xx/init/Makefile @@ -0,0 +1,11 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# (C) Copyright 2022 - Analog Devices, Inc. +# +# Written and/or maintained by Timesys Corporation +# +# Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com +# Contact: Greg Malysa greg.malysa@timesys.com +# + +obj-y += init.o dmcinit.o clkinit.o diff --git a/arch/arm/mach-sc5xx/init/clkinit.c b/arch/arm/mach-sc5xx/init/clkinit.c new file mode 100644 index 0000000000..44d3d16d74 --- /dev/null +++ b/arch/arm/mach-sc5xx/init/clkinit.c @@ -0,0 +1,543 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#include <asm/arch-adi/sc5xx/sc5xx.h> +#include <asm/io.h> +#include <config.h> +#include <linux/types.h> +#include <asm/io.h> +#include "clkinit.h" +#include "dmcinit.h" + +#ifdef CONFIG_CGU0_SCLK0_DIV + #define VAL_CGU0_SCLK0_DIV CONFIG_CGU0_SCLK0_DIV +#else + #define VAL_CGU0_SCLK0_DIV 1 +#endif +#ifdef CONFIG_CGU0_SCLK1_DIV + #define VAL_CGU0_SCLK1_DIV CONFIG_CGU0_SCLK1_DIV +#else + #define VAL_CGU0_SCLK1_DIV 1 +#endif +#ifdef CONFIG_CGU0_DIV_S0SELEX + #define VAL_CGU0_DIV_S0SELEX CONFIG_CGU0_DIV_S0SELEX +#else + #define VAL_CGU0_DIV_S0SELEX -1 +#endif +#ifdef CONFIG_CGU0_DIV_S1SELEX + #define VAL_CGU0_DIV_S1SELEX CONFIG_CGU0_DIV_S1SELEX +#else + #define VAL_CGU0_DIV_S1SELEX -1 +#endif +#ifdef CONFIG_CGU0_CLKOUTSEL + #define VAL_CGU0_CLKOUTSEL CONFIG_CGU0_CLKOUTSEL +#else + #define VAL_CGU0_CLKOUTSEL -1 +#endif +#ifdef CONFIG_CGU1_SCLK0_DIV + #define VAL_CGU1_SCLK0_DIV CONFIG_CGU1_SCLK0_DIV +#else + #define VAL_CGU1_SCLK0_DIV 1 +#endif +#ifdef CONFIG_CGU1_SCLK1_DIV + #define VAL_CGU1_SCLK1_DIV CONFIG_CGU1_SCLK1_DIV +#else + #define VAL_CGU1_SCLK1_DIV 1 +#endif +#ifdef CONFIG_CGU1_DIV_S0SELEX + #define VAL_CGU1_DIV_S0SELEX CONFIG_CGU1_DIV_S0SELEX +#else + #define VAL_CGU1_DIV_S0SELEX -1 +#endif +#ifdef CONFIG_CGU1_DIV_S1SELEX + #define VAL_CGU1_DIV_S1SELEX CONFIG_CGU1_DIV_S1SELEX +#else + #define VAL_CGU1_DIV_S1SELEX -1 +#endif +#ifdef CONFIG_CGU1_CLKOUTSEL + #define VAL_CGU1_CLKOUTSEL CONFIG_CGU1_CLKOUTSEL +#else + #define VAL_CGU1_CLKOUTSEL -1 +#endif + +#define CGU0_REGBASE 0x3108D000 +#define CGU1_REGBASE 0x3108E000 + +#define CGU_CTL 0x00 // CGU0 Control Register +#define CGU_PLLCTL 0x04 // CGU0 PLL Control Register +#define CGU_STAT 0x08 // CGU0 Status Register +#define CGU_DIV 0x0C // CGU0 Clocks Divisor Register +#define CGU_CLKOUTSEL 0x10 // CGU0 CLKOUT Select Register +#define CGU_DIVEX 0x40 // CGU0 DIV Register Extension + +/* PLL Multiplier and Divisor Selections (Required Value, Bit Position) */ +/* PLL Multiplier Select */ +#define MSEL(X) (((X) << BITP_CGU_CTL_MSEL) & \ + BITM_CGU_CTL_MSEL) +/* Divide frequency[true or false] */ +#define DF(X) (((X) << BITP_CGU_CTL_DF) & \ + BITM_CGU_CTL_DF) +/* Core Clock Divisor Select */ +#define CSEL(X) (((X) << BITP_CGU_DIV_CSEL) & \ + BITM_CGU_DIV_CSEL) +/* System Clock Divisor Select */ +#define SYSSEL(X) (((X) << BITP_CGU_DIV_SYSSEL) & \ + BITM_CGU_DIV_SYSSEL) +/* SCLK0 Divisor Select */ +#define S0SEL(X) (((X) << BITP_CGU_DIV_S0SEL) & \ + BITM_CGU_DIV_S0SEL) +/* SCLK1 Divisor Select */ +#define S1SEL(X) (((X) << BITP_CGU_DIV_S1SEL) & \ + BITM_CGU_DIV_S1SEL) +/* DDR Clock Divisor Select */ +#define DSEL(X) (((X) << BITP_CGU_DIV_DSEL) & \ + BITM_CGU_DIV_DSEL) +/* OUTCLK Divisor Select */ +#define OSEL(X) (((X) << BITP_CGU_DIV_OSEL) & \ + BITM_CGU_DIV_OSEL) +/* CLKOUT select */ +#define CLKOUTSEL(X) (((X) << BITP_CGU_CLKOUTSEL_CLKOUTSEL) & \ + BITM_CGU_CLKOUTSEL_CLKOUTSEL) +#define S0SELEX(X) (((X) << BITP_CGU_DIVEX_S0SELEX) & \ + BITM_CGU_DIVEX_S0SELEX) +#define S1SELEX(X) (((X) << BITP_CGU_DIVEX_S1SELEX) & \ + BITM_CGU_DIVEX_S1SELEX) + +struct CGU_Settings { + phys_addr_t rbase; + u32 ctl_MSEL:7; + u32 ctl_DF:1; + u32 div_CSEL:5; + u32 div_SYSSEL:5; + u32 div_S0SEL:3; + u32 div_S1SEL:3; + u32 div_DSEL:5; + u32 div_OSEL:7; + s16 divex_S0SELEX; + s16 divex_S1SELEX; + s8 clkoutsel; +}; + +/* CGU Registers */ +#define BITM_CGU_CTL_LOCK 0x80000000 /* Lock */ + +#define BITM_CGU_CTL_MSEL 0x00007F00 /* Multiplier Select */ +#define BITM_CGU_CTL_DF 0x00000001 /* Divide Frequency */ +#define BITM_CGU_CTL_S1SELEXEN 0x00020000 /* SCLK1 Extension Divider Enable */ +#define BITM_CGU_CTL_S0SELEXEN 0x00010000 /* SCLK0 Extension Divider Enable */ + +#define BITM_CGU_DIV_LOCK 0x80000000 /* Lock */ +#define BITM_CGU_DIV_UPDT 0x40000000 /* Update Clock Divisors */ +#define BITM_CGU_DIV_ALGN 0x20000000 /* Align */ +#define BITM_CGU_DIV_OSEL 0x1FC00000 /* OUTCLK Divisor */ +#define BITM_CGU_DIV_DSEL 0x001F0000 /* DCLK Divisor */ +#define BITM_CGU_DIV_S1SEL 0x0000E000 /* SCLK 1 Divisor */ +#define BITM_CGU_DIV_SYSSEL 0x00001F00 /* SYSCLK Divisor */ +#define BITM_CGU_DIV_S0SEL 0x000000E0 /* SCLK 0 Divisor */ +#define BITM_CGU_DIV_CSEL 0x0000001F /* CCLK Divisor */ + +#define BITP_CGU_DIVEX_S0SELEX 0 +#define BITM_CGU_DIVEX_S0SELEX 0x000000FF /* SCLK 0 Extension Divisor */ + +#define BITP_CGU_DIVEX_S1SELEX 16 +#define BITM_CGU_DIVEX_S1SELEX 0x00FF0000 /* SCLK 1 Extension Divisor */ + +#define BITM_CGU_PLLCTL_PLLEN 0x00000008 /* PLL Enable */ +#define BITM_CGU_PLLCTL_PLLBPCL 0x00000002 /* PLL Bypass Clear */ +#define BITM_CGU_PLLCTL_PLLBPST 0x00000001 /* PLL Bypass Set */ + +#define BITP_CGU_CLKOUTSEL_CLKOUTSEL 0 /* CLKOUT Select */ +#define BITM_CGU_CLKOUTSEL_CLKOUTSEL 0x0000001F /* CLKOUT Select */ + +#define CGU_STAT_MASK (BITM_CGU_STAT_PLLEN | BITM_CGU_STAT_PLOCK | \ + BITM_CGU_STAT_CLKSALGN) +#define CGU_STAT_ALGN_LOCK (BITM_CGU_STAT_PLLEN | BITM_CGU_STAT_PLOCK) + +/* Clock Distribution Unit Registers */ +#define REG_CDU0_CFG0 0x3108F000 +#define REG_CDU0_CFG1 0x3108F004 +#define REG_CDU0_CFG2 0x3108F008 +#define REG_CDU0_CFG3 0x3108F00C +#define REG_CDU0_CFG4 0x3108F010 +#define REG_CDU0_CFG5 0x3108F014 +#define REG_CDU0_CFG6 0x3108F018 +#define REG_CDU0_CFG7 0x3108F01C +#define REG_CDU0_CFG8 0x3108F020 +#define REG_CDU0_CFG9 0x3108F024 +#define REG_CDU0_CFG10 0x3108F028 +#define REG_CDU0_CFG11 0x3108F02C +#define REG_CDU0_CFG12 0x3108F030 +#define REG_CDU0_CFG13 0x3108F034 +#define REG_CDU0_CFG14 0x3108F038 +#define REG_CDU0_STAT 0x3108F040 +#define REG_CDU0_CLKINSEL 0x3108F044 +#define REG_CDU0_REVID 0x3108F048 + +#define BITM_REG10_MSEL3 0x000007F0 +#define BITP_REG10_MSEL3 4 + +#define BITM_REG10_DSEL3 0x0001F000 +#define BITP_REG10_DSEL3 12 + +/* Selected clock macros */ +#define CGUn_MULT(cgu) ((CONFIG_CGU##cgu##_VCO_MULT == 0) ? \ + 128 : CONFIG_CGU##cgu##_VCO_MULT) +#define CGUn_DIV(clkname, cgu) ((CONFIG_CGU##cgu##_##clkname##_DIV == 0) ? \ + 32 : CONFIG_CGU##cgu##_##clkname##_DIV) +#define CCLK1_n_RATIO(cgu) (((CGUn_MULT(cgu)) / \ + (1 + CONFIG_CGU##cgu##_DF_DIV)) / \ + CGUn_DIV(CCLK, cgu)) +#define CCLK2_n_RATIO(cgu) (((CGUn_MULT(cgu) * 2) / 3) / \ + (1 + CONFIG_CGU##cgu##_DF_DIV)) +#define DCLK_n_RATIO(cgu) (((CGUn_MULT(cgu)) / \ + (1 + CONFIG_CGU##cgu##_DF_DIV)) / \ + CGUn_DIV(DCLK, cgu)) +#define SYSCLK_n_RATIO(cgu) (((CGUn_MULT(cgu)) / \ + (1 + CONFIG_CGU##cgu##_DF_DIV)) / \ + CGUn_DIV(SCLK, cgu)) +#define PLL3_RATIO ((CONFIG_CGU1_PLL3_VCO_MSEL) / \ + (CONFIG_CGU1_PLL3_DCLK_DIV)) + +#if (1 == CONFIG_CDU0_CLKO2) + #define ARMCLK_IN 0 + #define ARMCLK_RATIO CCLK1_n_RATIO(0) +#elif (3 == CONFIG_CDU0_CLKO2) && \ + (defined(CONFIG_SC57X) || defined(CONFIG_SC58X)) + #define ARMCLK_IN 0 + #define ARMCLK_RATIO SYSCLK_n_RATIO(0) +#elif (5 == CONFIG_CDU0_CLKO2) && defined(CONFIG_SC59X_64) + #define ARMCLK_IN 0 + #define ARMCLK_RATIO CCLK2_n_RATIO(0) +#elif (7 == CONFIG_CDU0_CLKO2) && defined(CONFIG_SC59X_64) + #define ARMCLK_IN CDU0_CGU1_CLKIN + #define ARMCLK_RATIO CCLK2_n_RATIO(1) +#endif + +#ifdef CONFIG_CGU1_PLL3_DDRCLK + #define DDRCLK_IN CDU0_CGU1_CLKIN + #define DDRCLK_RATIO PLL3_RATIO +#elif (1 == CONFIG_CDU0_CLKO3) + #define DDRCLK_IN 0 + #define DDRCLK_RATIO DCLK_n_RATIO(0) +#elif (3 == CONFIG_CDU0_CLKO3) + #define DDRCLK_IN CDU0_CGU1_CLKIN + #define DDRCLK_RATIO DCLK_n_RATIO(1) +#endif + +#ifndef ARMCLK_RATIO + #error Invalid/unknown ARMCLK selection! +#endif +#ifndef DDRCLK_RATIO + #error Invalid/unknown DDRCLK selection! +#endif + +#define ARMDDR_CLK_RATIO_FPERCISION 1000 + +#if ARMCLK_IN != DDRCLK_IN + #ifndef CUSTOM_ARMDDR_CLK_RATIO + /** + * SYS_CLKINx are defined within the device tree, not configs. + * Thus, we can only determine cross-CGU clock ratios if they + * use the same SYS_CLKINx. + */ + #error Define CUSTOM_ARMDDR_CLK_RATIO for different SYS_CLKINs + #else + #define ARMDDR_CLK_RATIO CUSTOM_ARMDDR_CLK_RATIO + #endif +#else + #define ARMDDR_CLK_RATIO (ARMDDR_CLK_RATIO_FPERCISION *\ + ARMCLK_RATIO / DDRCLK_RATIO) +#endif + +void dmcdelay(uint32_t delay) +{ + /* There is no zero-overhead loop on ARM, so assume each iteration + * takes 4 processor cycles (based on examination of -O3 and -Ofast + * output). + */ + u32 i, remainder; + + /* Convert DDR cycles to core clock cycles */ + u32 f = delay * ARMDDR_CLK_RATIO; + + delay = f + 500; + delay /= ARMDDR_CLK_RATIO_FPERCISION; + + /* Round up to multiple of 4 */ + remainder = delay % 4; + if (remainder != 0u) + delay += (4u - remainder); + + for (i = 0; i < delay; i += 4) + asm("nop"); +} + +static void program_cgu(const struct CGU_Settings *cgu) +{ + const uintptr_t b = cgu->rbase; + const bool use_extension0 = cgu->divex_S0SELEX >= 0; + const bool use_extension1 = cgu->divex_S1SELEX >= 0; + u32 temp; + + temp = OSEL(cgu->div_OSEL); + temp |= SYSSEL(cgu->div_SYSSEL); + temp |= CSEL(cgu->div_CSEL); + temp |= DSEL(cgu->div_DSEL); + temp |= (S0SEL(cgu->div_S0SEL)); + temp |= (S1SEL(cgu->div_S1SEL)); + temp &= ~BITM_CGU_DIV_LOCK; + + //Put PLL in to Bypass Mode + writel(BITM_CGU_PLLCTL_PLLEN | BITM_CGU_PLLCTL_PLLBPST, + b + CGU_PLLCTL); + while (!(readl(b + CGU_STAT) & BITM_CGU_STAT_PLLBP)) + ; + + while (!((readl(b + CGU_STAT) & CGU_STAT_MASK) == CGU_STAT_ALGN_LOCK)) + ; + + dmcdelay(1000); + + writel(temp & (~BITM_CGU_DIV_ALGN) & (~BITM_CGU_DIV_UPDT), + b + CGU_DIV); + + dmcdelay(1000); + + temp = MSEL(cgu->ctl_MSEL) | DF(cgu->ctl_DF); + if (use_extension0) + temp |= BITM_CGU_CTL_S0SELEXEN; + if (use_extension1) + temp |= BITM_CGU_CTL_S1SELEXEN; + + writel(temp & (~BITM_CGU_CTL_LOCK), b + CGU_CTL); + + if (use_extension0 || use_extension1) { + u32 mask = BITM_CGU_CTL_S1SELEXEN | BITM_CGU_CTL_S0SELEXEN; + + while (!(readl(b + CGU_CTL) & mask)) + ; + + temp = readl(b + CGU_DIVEX); + + if (use_extension0) { + temp &= ~BITM_CGU_DIVEX_S0SELEX; + temp |= S0SELEX(cgu->divex_S0SELEX); + } + + if (use_extension1) { + temp &= ~BITM_CGU_DIVEX_S1SELEX; + temp |= S1SELEX(cgu->divex_S1SELEX); + } + + writel(temp, b + CGU_DIVEX); + } + + dmcdelay(1000); + + //Take PLL out of Bypass Mode + writel(BITM_CGU_PLLCTL_PLLEN | BITM_CGU_PLLCTL_PLLBPCL, + b + CGU_PLLCTL); + while ((readl(b + CGU_STAT) & + (BITM_CGU_STAT_PLLBP | BITM_CGU_STAT_CLKSALGN))) + ; + + dmcdelay(1000); + + if (cgu->clkoutsel >= 0) { + temp = readl(b + CGU_CLKOUTSEL); + temp &= ~BITM_CGU_CLKOUTSEL_CLKOUTSEL; + temp |= CLKOUTSEL(cgu->clkoutsel); + writel(temp, b + CGU_CLKOUTSEL); + } +} + +void adi_config_third_pll(void) +{ +#if defined(CONFIG_CGU1_PLL3_VCO_MSEL) && defined(CONFIG_CGU1_PLL3_DCLK_DIV) + u32 temp; + + u32 msel = CONFIG_CGU1_PLL3_VCO_MSEL - 1; + u32 dsel = CONFIG_CGU1_PLL3_DCLK_DIV - 1; + + temp = readl(REG_MISC_REG10_tst_addr); + temp &= 0xFFFE0000; + writel(temp, REG_MISC_REG10_tst_addr); + + dmcdelay(4000u); + + //update MSEL [10:4] + temp = readl(REG_MISC_REG10_tst_addr); + temp |= ((msel << BITP_REG10_MSEL3) & BITM_REG10_MSEL3); + writel(temp, REG_MISC_REG10_tst_addr); + + temp = readl(REG_MISC_REG10_tst_addr); + temp |= 0x2; + writel(temp, REG_MISC_REG10_tst_addr); + + dmcdelay(100000u); + + temp = readl(REG_MISC_REG10_tst_addr); + temp |= 0x1; + writel(temp, REG_MISC_REG10_tst_addr); + + temp = readl(REG_MISC_REG10_tst_addr); + temp |= 0x800; + writel(temp, REG_MISC_REG10_tst_addr); + + temp = readl(REG_MISC_REG10_tst_addr); + temp &= 0xFFFFF7F8; + writel(temp, REG_MISC_REG10_tst_addr); + + dmcdelay(4000u); + + temp = readl(REG_MISC_REG10_tst_addr); + temp |= ((dsel << BITP_REG10_DSEL3) & BITM_REG10_DSEL3); + writel(temp, REG_MISC_REG10_tst_addr); + + temp = readl(REG_MISC_REG10_tst_addr); + temp |= 0x4; + writel(temp, REG_MISC_REG10_tst_addr); + + dmcdelay(100000u); + + temp = readl(REG_MISC_REG10_tst_addr); + temp |= 0x1; + writel(temp, REG_MISC_REG10_tst_addr); + + temp = readl(REG_MISC_REG10_tst_addr); + temp |= 0x800; + writel(temp, REG_MISC_REG10_tst_addr); +#endif +} + +static void Active_To_Fullon(const struct CGU_Settings *pCGU) +{ + u32 tmp; + + while (1) { + tmp = readl(pCGU->rbase + CGU_STAT); + if ((tmp & BITM_CGU_STAT_PLLEN) && + (tmp & BITM_CGU_STAT_PLLBP)) + break; + } + + writel(BITM_CGU_PLLCTL_PLLBPCL, pCGU->rbase + CGU_PLLCTL); + + while (1) { + tmp = readl(pCGU->rbase + CGU_STAT); + if ((tmp & BITM_CGU_STAT_PLLEN) && + ~(tmp & BITM_CGU_STAT_PLLBP) && + ~(tmp & BITM_CGU_STAT_CLKSALGN)) + break; + } +} + +static void CGU_Init(const struct CGU_Settings *pCGU) +{ + const uintptr_t b = pCGU->rbase; + +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + if (readl(b + CGU_STAT) & BITM_CGU_STAT_PLLEN) + writel(BITM_CGU_PLLCTL_PLLEN, b + CGU_PLLCTL); + + dmcdelay(1000); +#endif + + /* Check if processor is in Active mode */ + if (readl(b + CGU_STAT) & BITM_CGU_STAT_PLLBP) + Active_To_Fullon(pCGU); + +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + dmcdelay(1000); +#endif + + program_cgu(pCGU); +} + +void cgu_init(void) +{ + const struct CGU_Settings dividers0 = { + .rbase = CGU0_REGBASE, + .ctl_MSEL = CONFIG_CGU0_VCO_MULT, + .ctl_DF = CONFIG_CGU0_DF_DIV, + .div_CSEL = CONFIG_CGU0_CCLK_DIV, + .div_SYSSEL = CONFIG_CGU0_SCLK_DIV, + .div_S0SEL = VAL_CGU0_SCLK0_DIV, + .div_S1SEL = VAL_CGU0_SCLK1_DIV, + .div_DSEL = CONFIG_CGU0_DCLK_DIV, + .div_OSEL = CONFIG_CGU0_OCLK_DIV, + .divex_S0SELEX = VAL_CGU0_DIV_S0SELEX, + .divex_S1SELEX = VAL_CGU0_DIV_S1SELEX, + .clkoutsel = VAL_CGU0_CLKOUTSEL, + }; + const struct CGU_Settings dividers1 = { + .rbase = CGU1_REGBASE, + .ctl_MSEL = CONFIG_CGU1_VCO_MULT, + .ctl_DF = CONFIG_CGU1_DF_DIV, + .div_CSEL = CONFIG_CGU1_CCLK_DIV, + .div_SYSSEL = CONFIG_CGU1_SCLK_DIV, + .div_S0SEL = VAL_CGU1_SCLK0_DIV, + .div_S1SEL = VAL_CGU1_SCLK1_DIV, + .div_DSEL = CONFIG_CGU1_DCLK_DIV, + .div_OSEL = CONFIG_CGU1_OCLK_DIV, + .divex_S0SELEX = VAL_CGU1_DIV_S0SELEX, + .divex_S1SELEX = VAL_CGU1_DIV_S1SELEX, + .clkoutsel = VAL_CGU1_CLKOUTSEL, + }; + + CGU_Init(÷rs0); + CGU_Init(÷rs1); +} + +#define CONFIGURE_CDU0(a, b, c) \ + writel(a, b); \ + while (readl(REG_CDU0_STAT) & (1 << (c))) + +void cdu_init(void) +{ + while (readl(REG_CDU0_STAT) & 0xffff) + ; + writel((CONFIG_CDU0_CGU1_CLKIN & 0x1), REG_CDU0_CLKINSEL); + + CONFIGURE_CDU0(CONFIG_CDU0_CLKO0, REG_CDU0_CFG0, 0); + CONFIGURE_CDU0(CONFIG_CDU0_CLKO1, REG_CDU0_CFG1, 1); + CONFIGURE_CDU0(CONFIG_CDU0_CLKO2, REG_CDU0_CFG2, 2); + CONFIGURE_CDU0(CONFIG_CDU0_CLKO3, REG_CDU0_CFG3, 3); + CONFIGURE_CDU0(CONFIG_CDU0_CLKO4, REG_CDU0_CFG4, 4); + CONFIGURE_CDU0(CONFIG_CDU0_CLKO5, REG_CDU0_CFG5, 5); + CONFIGURE_CDU0(CONFIG_CDU0_CLKO6, REG_CDU0_CFG6, 6); + CONFIGURE_CDU0(CONFIG_CDU0_CLKO7, REG_CDU0_CFG7, 7); + CONFIGURE_CDU0(CONFIG_CDU0_CLKO8, REG_CDU0_CFG8, 8); + CONFIGURE_CDU0(CONFIG_CDU0_CLKO9, REG_CDU0_CFG9, 9); +#ifdef CONFIG_CDU0_CLKO10 + CONFIGURE_CDU0(CONFIG_CDU0_CLKO10, REG_CDU0_CFG10, 10); +#endif +#ifdef CONFIG_CDU0_CLKO12 + CONFIGURE_CDU0(CONFIG_CDU0_CLKO12, REG_CDU0_CFG12, 12); +#endif +#ifdef CONFIG_CDU0_CLKO13 + CONFIGURE_CDU0(CONFIG_CDU0_CLKO13, REG_CDU0_CFG13, 13); +#endif +#ifdef CONFIG_CDU0_CLKO14 + CONFIGURE_CDU0(CONFIG_CDU0_CLKO14, REG_CDU0_CFG14, 14); +#endif +} + +void clks_init(void) +{ + adi_dmc_reset_lanes(true); + + cdu_init(); + cgu_init(); + + adi_config_third_pll(); + + adi_dmc_reset_lanes(false); +} diff --git a/arch/arm/mach-sc5xx/init/clkinit.h b/arch/arm/mach-sc5xx/init/clkinit.h new file mode 100644 index 0000000000..b05f4325bf --- /dev/null +++ b/arch/arm/mach-sc5xx/init/clkinit.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#ifndef CLKINIT_H_ +#define CLKINIT_H_ + +void clks_init(void); + +void dmcdelay(uint32_t delay); + +#endif diff --git a/arch/arm/mach-sc5xx/init/dmcinit.c b/arch/arm/mach-sc5xx/init/dmcinit.c new file mode 100644 index 0000000000..3b9d2f7039 --- /dev/null +++ b/arch/arm/mach-sc5xx/init/dmcinit.c @@ -0,0 +1,973 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#include <config.h> +#include <asm/arch-adi/sc5xx/sc5xx.h> +#include <linux/types.h> +#include <asm/io.h> +#include "clkinit.h" +#include "dmcinit.h" +#include <stdbool.h> + +#define REG_DMC0_BASE 0x31070000 +#define REG_DMC1_BASE 0x31073000 + +#define REG_DMC_CTL 0x0004 // Control Register +#define REG_DMC_STAT 0x0008 // Status Register +#define REG_DMC_CFG 0x0040 // Configuration Register +#define REG_DMC_TR0 0x0044 // Timing 0 Register +#define REG_DMC_TR1 0x0048 // Timing 1 Register +#define REG_DMC_TR2 0x004C // Timing 2 Register +#define REG_DMC_MR 0x0060 // Shadow MR Register (DDR3) +#define REG_DMC_EMR1 0x0064 // Shadow EMR1 Register +#define REG_DMC_EMR2 0x0068 // Shadow EMR2 Register +#define REG_DMC_EMR3 0x006C +#define REG_DMC_DLLCTL 0x0080 // DLL Control Register +#define REG_DMC_DT_CALIB_ADDR 0x0090 // Data Calibration Address Register +#define REG_DMC_CPHY_CTL 0x01C0 // Controller to PHY Interface Register + +/* SC57x && SC58x DMC REGs */ +#define REG_DMC_PHY_CTL0 0x1000 // PHY Control 0 Register +#define REG_DMC_PHY_CTL1 0x1004 // PHY Control 1 Register +#define REG_DMC_PHY_CTL2 0x1008 // PHY Control 2 Register +#define REG_DMC_PHY_CTL3 0x100c // PHY Control 3 Register +#define REG_DMC_PHY_CTL4 0x1010 // PHY Control 4 Register +#define REG_DMC_CAL_PADCTL0 0x1034 // CALIBRATION PAD CTL 0 Register +#define REG_DMC_CAL_PADCTL2 0x103C // CALIBRATION PAD CTL2 Register +/* END */ + +/* SC59x DMC REGs */ +#define REG_DMC_DDR_LANE0_CTL0 0x1000 // Data Lane 0 Control Register 0 +#define REG_DMC_DDR_LANE0_CTL1 0x1004 // Data Lane 0 Control Register 1 +#define REG_DMC_DDR_LANE1_CTL0 0x100C // Data Lane 1 Control Register 0 +#define REG_DMC_DDR_LANE1_CTL1 0x1010 // Data Lane 1 Control Register 1 +#define REG_DMC_DDR_ROOT_CTL 0x1018 // DDR ROOT Module Control Register +#define REG_DMC_DDR_ZQ_CTL0 0x1034 // DDR Calibration Control Register 0 +#define REG_DMC_DDR_ZQ_CTL1 0x1038 // DDR Calibration Control Register 1 +#define REG_DMC_DDR_ZQ_CTL2 0x103C // DDR Calibration Control Register 2 +#define REG_DMC_DDR_CA_CTL 0x1068 // DDR CA Lane Control Register +/* END */ + +#define REG_DMC_DDR_SCRATCH_2 0x1074 +#define REG_DMC_DDR_SCRATCH_3 0x1078 +#define REG_DMC_DDR_SCRATCH_6 0x1084 +#define REG_DMC_DDR_SCRATCH_7 0x1088 + +#define REG_DMC_DDR_SCRATCH_STAT0 0x107C +#define REG_DMC_DDR_SCRATCH_STAT1 0x1080 + +#define DMC0_DATA_CALIB_ADD 0x80000000 +#define DMC1_DATA_CALIB_ADD 0xC0000000 + +#define BITM_DMC_CFG_EXTBANK 0x0000F000 /* External Banks */ +#define ENUM_DMC_CFG_EXTBANK1 0x00000000 /* EXTBANK: 1 External Bank */ +#define BITM_DMC_CFG_SDRSIZE 0x00000F00 /* SDRAM Size */ +#define ENUM_DMC_CFG_SDRSIZE64 0x00000000 /* SDRSIZE: 64M Bit SDRAM (LPDDR Only) */ +#define ENUM_DMC_CFG_SDRSIZE128 0x00000100 /* SDRSIZE: 128M Bit SDRAM (LPDDR Only) */ +#define ENUM_DMC_CFG_SDRSIZE256 0x00000200 /* SDRSIZE: 256M Bit SDRAM */ +#define ENUM_DMC_CFG_SDRSIZE512 0x00000300 /* SDRSIZE: 512M Bit SDRAM */ +#define ENUM_DMC_CFG_SDRSIZE1G 0x00000400 /* SDRSIZE: 1G Bit SDRAM */ +#define ENUM_DMC_CFG_SDRSIZE2G 0x00000500 /* SDRSIZE: 2G Bit SDRAM */ +#define ENUM_DMC_CFG_SDRSIZE4G 0x00000600 /* SDRSIZE: 4G Bit SDRAM */ +#define ENUM_DMC_CFG_SDRSIZE8G 0x00000700 /* SDRSIZE: 8G Bit SDRAM */ +#define BITM_DMC_CFG_SDRWID 0x000000F0 /* SDRAM Width */ +#define ENUM_DMC_CFG_SDRWID16 0x00000020 /* SDRWID: 16-Bit Wide SDRAM */ +#define BITM_DMC_CFG_IFWID 0x0000000F /* Interface Width */ +#define ENUM_DMC_CFG_IFWID16 0x00000002 /* IFWID: 16-Bit Wide Interface */ + +#define BITM_DMC_CTL_DDR3EN 0x00000001 +#define BITM_DMC_CTL_INIT 0x00000004 +#define BITP_DMC_STAT_INITDONE 2 /* Initialization Done */ +#define BITM_DMC_STAT_INITDONE 0x00000004 + +#define BITP_DMC_CTL_AL_EN 27 +#define BITP_DMC_CTL_ZQCL 25 /* ZQ Calibration Long */ +#define BITP_DMC_CTL_ZQCS 24 /* ZQ Calibration Short */ +#define BITP_DMC_CTL_DLLCAL 13 /* DLL Calibration Start */ +#define BITP_DMC_CTL_PPREF 12 /* Postpone Refresh */ +#define BITP_DMC_CTL_RDTOWR 9 /* Read-to-Write Cycle */ +#define BITP_DMC_CTL_ADDRMODE 8 /* Addressing (Page/Bank) Mode */ +#define BITP_DMC_CTL_RESET 7 /* Reset SDRAM */ +#define BITP_DMC_CTL_PREC 6 /* Precharge */ +#define BITP_DMC_CTL_DPDREQ 5 /* Deep Power Down Request */ +#define BITP_DMC_CTL_PDREQ 4 /* Power Down Request */ +#define BITP_DMC_CTL_SRREQ 3 /* Self Refresh Request */ +#define BITP_DMC_CTL_INIT 2 /* Initialize DRAM Start */ +#define BITP_DMC_CTL_LPDDR 1 /* Low Power DDR Mode */ +#define BITP_DMC_CTL_DDR3EN 0 /* DDR3 Mode */ + +#ifdef CONFIG_TARGET_SC584_EZKIT + #define DMC_PADCTL2_VALUE 0x0078283C +#elif CONFIG_TARGET_SC573_EZKIT + #define DMC_PADCTL2_VALUE 0x00782828 +#elif CONFIG_TARGET_SC589_MINI || CONFIG_TARGET_SC589_EZKIT + #define DMC_PADCTL2_VALUE 0x00783C3C +#elif defined(CONFIG_SC57X) || defined(CONFIG_SC58X) + #error "PADCTL2 not specified for custom board!" +#else + //Newer DMC. Legacy calibration obsolete + #define DMC_PADCTL2_VALUE 0x0 +#endif + +#define DMC_CPHYCTL_VALUE 0x0000001A + +#define BITP_DMC_MR1_QOFF 12 /* Output Buffer Enable */ +#define BITP_DMC_MR1_TDQS 11 /* Termination Data Strobe */ +#define BITP_DMC_MR1_RTT2 9 /* Rtt_nom */ +#define BITP_DMC_MR1_WL 7 /* Write Leveling Enable. */ +#define BITP_DMC_MR1_RTT1 6 /* Rtt_nom */ +#define BITP_DMC_MR1_DIC1 5 /* Output Driver Impedance Control */ +#define BITP_DMC_MR1_AL 3 /* Additive Latency */ +#define BITP_DMC_MR1_RTT0 2 /* Rtt_nom */ +#define BITP_DMC_MR1_DIC0 1 /* Output Driver Impedance control */ +#define BITP_DMC_MR1_DLLEN 0 /* DLL Enable */ + +#define BITP_DMC_MR2_CWL 3 /* CAS write Latency */ + +#define BITP_DMC_TR0_TMRD 28 /* Timing Mode Register Delay */ +#define BITP_DMC_TR0_TRC 20 /* Timing Row Cycle */ +#define BITP_DMC_TR0_TRAS 12 /* Timing Row Active Time */ +#define BITP_DMC_TR0_TRP 8 /* Timing RAS Precharge. */ +#define BITP_DMC_TR0_TWTR 4 /* Timing Write to Read */ +#define BITP_DMC_TR0_TRCD 0 /* Timing RAS to CAS Delay */ + +#define BITP_DMC_TR1_TRRD 28 /* Timing Read-Read Delay */ +#define BITP_DMC_TR1_TRFC 16 /* Timing Refresh-to-Command */ +#define BITP_DMC_TR1_TREF 0 /* Timing Refresh Interval */ + +#define BITP_DMC_TR2_TCKE 20 /* Timing Clock Enable */ +#define BITP_DMC_TR2_TXP 16 /* Timing Exit Powerdown */ +#define BITP_DMC_TR2_TWR 12 /* Timing Write Recovery */ +#define BITP_DMC_TR2_TRTP 8 /* Timing Read-to-Precharge */ +#define BITP_DMC_TR2_TFAW 0 /* Timing Four-Activated-Window */ + +#define BITP_DMC_MR_PD 12 /* Active Powerdown Mode */ +#define BITP_DMC_MR_WRRECOV 9 /* Write Recovery */ +#define BITP_DMC_MR_DLLRST 8 /* DLL Reset */ +#define BITP_DMC_MR_CL 4 /* CAS Latency */ +#define BITP_DMC_MR_CL0 2 /* CAS Latency */ +#define BITP_DMC_MR_BLEN 0 /* Burst Length */ + +#define BITP_DMC_DLLCTL_DATACYC 8 /* Data Cycles */ +#define BITP_DMC_DLLCTL_DLLCALRDCNT 0 /* DLL Calibration RD Count */ + +#define BITM_DMC_DLLCTL_DATACYC 0x00000F00 /* Data Cycles */ +#define BITM_DMC_DLLCTL_DLLCALRDCNT 0x000000FF /* DLL Calib RD Count */ + +#define BITP_DMC_STAT_PHYRDPHASE 20 /* PHY Read Phase */ + +#define BITM_DMC_DDR_LANE0_CTL0_CB_RSTDAT 0x08000000 /* Rst Data Pads */ +#define BITM_DMC_DDR_LANE1_CTL0_CB_RSTDAT 0x08000000 /* Rst Data Pads */ +#define BITM_DMC_DDR_LANE0_CTL1_COMP_DCYCLE 0x00000002 /* Compute Dcycle */ +#define BITM_DMC_DDR_LANE1_CTL1_COMP_DCYCLE 0x00000002 /* Compute Dcycle */ +#define BITM_DMC_DDR_LANE1_CTL0_CB_RSTDLL 0x00000100 /* Rst Lane DLL */ +#define BITM_DMC_DDR_LANE0_CTL0_CB_RSTDLL 0x00000100 /* Rst Lane DLL */ +#define BITP_DMC_DDR_ROOT_CTL_PIPE_OFSTDCYCLE 10 /* Pipeline offset for PHYC_DATACYCLE */ +#define BITM_DMC_DDR_ROOT_CTL_SW_REFRESH 0x00002000 /* Refresh Lane DLL Code */ +#define BITM_DMC_DDR_CA_CTL_SW_REFRESH 0x00004000 /* Refresh Lane DLL Code */ + +#define BITP_DMC_CTL_RL_DQS 26 /* RL_DQS */ +#define BITM_DMC_CTL_RL_DQS 0x04000000 /* RL_DQS */ +#define BITP_DMC_EMR3_MPR 2 /* Multi Purpose Read Enable (Read Leveling)*/ +#define BITM_DMC_EMR3_MPR 0x00000004 /* Multi Purpose Read Enable (Read Leveling)*/ +#define BITM_DMC_MR1_WL 0x00000080 /* Write Leveling Enable.*/ +#define BITM_DMC_STAT_PHYRDPHASE 0x00F00000 /* PHY Read Phase */ + +#define BITP_DMC_DDR_LANE0_CTL1_BYPCODE 10 +#define BITM_DMC_DDR_LANE0_CTL1_BYPCODE 0x00007C00 +#define BITP_DMC_DDR_LANE0_CTL1_BYPDELCHAINEN 15 +#define BITM_DMC_DDR_LANE0_CTL1_BYPDELCHAINEN 0x00008000 + +#define DMC_ZQCTL0_VALUE 0x00785A64 +#define DMC_ZQCTL1_VALUE 0 +#define DMC_ZQCTL2_VALUE 0x70000000 + +#define DMC_TRIG_CALIB 0 +#define DMC_OFSTDCYCLE 2 + +#define BITP_DMC_CAL_PADCTL0_RTTCALEN 31 /* RTT Calibration Enable */ +#define BITP_DMC_CAL_PADCTL0_PDCALEN 30 /* PULLDOWN Calib Enable */ +#define BITP_DMC_CAL_PADCTL0_PUCALEN 29 /* PULLUP Calib Enable */ +#define BITP_DMC_CAL_PADCTL0_CALSTRT 28 /* Start New Calib ( Hardware Cleared) */ +#define BITM_DMC_CAL_PADCTL0_RTTCALEN 0x80000000 /* RTT Calibration Enable */ +#define BITM_DMC_CAL_PADCTL0_PDCALEN 0x40000000 /* PULLDOWN Calib Enable */ +#define BITM_DMC_CAL_PADCTL0_PUCALEN 0x20000000 /* PULLUP Calib Enable */ +#define BITM_DMC_CAL_PADCTL0_CALSTRT 0x10000000 /* Start New Calib ( Hardware Cleared) */ +#define ENUM_DMC_PHY_CTL4_DDR3 0x00000000 /* DDRMODE: DDR3 Mode */ +#define ENUM_DMC_PHY_CTL4_DDR2 0x00000001 /* DDRMODE: DDR2 Mode */ +#define ENUM_DMC_PHY_CTL4_LPDDR 0x00000003 /* DDRMODE: LPDDR Mode */ + +#define BITP_DMC_DDR_ZQ_CTL0_IMPRTT 16 /* Data/DQS ODT */ +#define BITP_DMC_DDR_ZQ_CTL0_IMPWRDQ 8 /* Data/DQS/DM/CLK Drive Strength */ +#define BITP_DMC_DDR_ZQ_CTL0_IMPWRADD 0 /* Address/Command Drive Strength */ +#define BITM_DMC_DDR_ZQ_CTL0_IMPRTT 0x00FF0000 /* Data/DQS ODT */ +#define BITM_DMC_DDR_ZQ_CTL0_IMPWRDQ 0x0000FF00 /* Data/DQS/DM/CLK Drive Strength */ +#define BITM_DMC_DDR_ZQ_CTL0_IMPWRADD 0x000000FF /* Address/Command Drive Strength */ + +#define BITM_DMC_DDR_ROOT_CTL_TRIG_RD_XFER_ALL 0x00200000 /* All Lane Read Status */ + +#ifdef MEM_DDR2 + #define DMC_MR0_VALUE \ + ((DMC_BL / 4 + 1) << BITP_DMC_MR_BLEN) | \ + (DMC_CL << BITP_DMC_MR_CL) | \ + (DMC_WRRECOV << BITP_DMC_MR_WRRECOV) + + #define DMC_MR1_VALUE \ + (DMC_MR1_AL << BITP_DMC_MR1_AL | 0x04) \ + + #define DMC_MR2_VALUE 0 + #define DMC_MR3_VALUE 0 + + #define DMC_CTL_VALUE \ + (DMC_RDTOWR << BITP_DMC_CTL_RDTOWR) | \ + (1 << BITP_DMC_CTL_DLLCAL) | \ + (BITM_DMC_CTL_INIT) +#endif + +#ifdef MEM_DDR3 + #define DMC_MR0_VALUE \ + (0 << BITP_DMC_MR_BLEN) | \ + (DMC_CL0 << BITP_DMC_MR_CL0) | \ + (DMC_CL123 << BITP_DMC_MR_CL) | \ + (DMC_WRRECOV << BITP_DMC_MR_WRRECOV) | \ + (1 << BITP_DMC_MR_DLLRST) + + #define DMC_MR1_VALUE \ + (DMC_MR1_DLLEN << BITP_DMC_MR1_DLLEN) | \ + (DMC_MR1_DIC0 << BITP_DMC_MR1_DIC0) | \ + (DMC_MR1_RTT0 << BITP_DMC_MR1_RTT0) | \ + (DMC_MR1_AL << BITP_DMC_MR1_AL) | \ + (DMC_MR1_DIC1 << BITP_DMC_MR1_DIC1) | \ + (DMC_MR1_RTT1 << BITP_DMC_MR1_RTT1) | \ + (DMC_MR1_RTT2 << BITP_DMC_MR1_RTT2) | \ + (DMC_MR1_WL << BITP_DMC_MR1_WL) | \ + (DMC_MR1_TDQS << BITP_DMC_MR1_TDQS) | \ + (DMC_MR1_QOFF << BITP_DMC_MR1_QOFF) + + #define DMC_MR2_VALUE \ + ((DMC_WL) << BITP_DMC_MR2_CWL) + + #define DMC_MR3_VALUE \ + ((DMC_WL) << BITP_DMC_MR2_CWL) + + #define DMC_CTL_VALUE \ + (DMC_RDTOWR << BITP_DMC_CTL_RDTOWR) | \ + (BITM_DMC_CTL_INIT) | \ + (BITM_DMC_CTL_DDR3EN) | \ + (DMC_CTL_AL_EN << BITP_DMC_CTL_AL_EN) +#endif + +#define DMC_DLLCTL_VALUE \ + (DMC_DATACYC << BITP_DMC_DLLCTL_DATACYC) | \ + (DMC_DLLCALRDCNT << BITP_DMC_DLLCTL_DLLCALRDCNT) + +#define DMC_CFG_VALUE \ + ENUM_DMC_CFG_IFWID16 | \ + ENUM_DMC_CFG_SDRWID16 | \ + SDR_CHIP_SIZE | \ + ENUM_DMC_CFG_EXTBANK1 + +#define DMC_TR0_VALUE \ + (DMC_TRCD << BITP_DMC_TR0_TRCD) | \ + (DMC_TWTR << BITP_DMC_TR0_TWTR) | \ + (DMC_TRP << BITP_DMC_TR0_TRP) | \ + (DMC_TRAS << BITP_DMC_TR0_TRAS) | \ + (DMC_TRC << BITP_DMC_TR0_TRC) | \ + (DMC_TMRD << BITP_DMC_TR0_TMRD) + +#define DMC_TR1_VALUE \ + (DMC_TREF << BITP_DMC_TR1_TREF) | \ + (DMC_TRFC << BITP_DMC_TR1_TRFC) | \ + (DMC_TRRD << BITP_DMC_TR1_TRRD) + +#define DMC_TR2_VALUE \ + (DMC_TFAW << BITP_DMC_TR2_TFAW) | \ + (DMC_TRTP << BITP_DMC_TR2_TRTP) | \ + (DMC_TWR << BITP_DMC_TR2_TWR) | \ + (DMC_TXP << BITP_DMC_TR2_TXP) | \ + (DMC_TCKE << BITP_DMC_TR2_TCKE) + +enum DDR_MODE { + DDR3_MODE, + DDR2_MODE, + LPDDR_MODE, +}; + +enum CALIBRATION_MODE { + CALIBRATION_LEGACY, + CALIBRATION_METHOD1, + CALIBRATION_METHOD2, +}; + +static struct dmc_param { + phys_addr_t reg; + u32 ddr_mode; + u32 padctl2_value; + u32 dmc_cphyctl_value; + u32 dmc_cfg_value; + u32 dmc_dllctl_value; + u32 dmc_ctl_value; + u32 dmc_tr0_value; + u32 dmc_tr1_value; + u32 dmc_tr2_value; + u32 dmc_mr0_value; + u32 dmc_mr1_value; + u32 dmc_mr2_value; + u32 dmc_mr3_value; + u32 dmc_zqctl0_value; + u32 dmc_zqctl1_value; + u32 dmc_zqctl2_value; + u32 dmc_data_calib_add_value; + bool phy_init_required; + bool anomaly_20000037_applicable; + enum CALIBRATION_MODE calib_mode; +} dmc; + +#ifdef CONFIG_SC59X_64 +#define DQS_DEFAULT_DELAY 3ul + +#define DELAYTRIM 1 +#define LANE0_DQS_DELAY 1 +#define LANE1_DQS_DELAY 1 + +#define CLKDIR 0ul + +#define DQSTRIM 0 +#define DQSCODE 0ul + +#define CLKTRIM 0 +#define CLKCODE 0ul +#endif + +static inline void calibration_legacy(void) +{ + u32 temp; + + /* 1. Set DDR mode to DDR3/DDR2/LPDDR in DMCx_PHY_CTL4 register */ + if (dmc.ddr_mode == DDR3_MODE) + writel(ENUM_DMC_PHY_CTL4_DDR3, dmc.reg + REG_DMC_PHY_CTL4); + else if (dmc.ddr_mode == DDR2_MODE) + writel(ENUM_DMC_PHY_CTL4_DDR2, dmc.reg + REG_DMC_PHY_CTL4); + else if (dmc.ddr_mode == LPDDR_MODE) + writel(ENUM_DMC_PHY_CTL4_LPDDR, dmc.reg + REG_DMC_PHY_CTL4); + + /* + * 2. Make sure that the bits 6, 7, 25, and 27 of the DMC_PHY_ + * CTL3 register are set + */ + writel(0x0A0000C0, dmc.reg + REG_DMC_PHY_CTL3); + + /* + * 3. For DDR2/DDR3 mode, make sure that the bits 0, 1, 2, 3 of + * the DMC_PHY_CTL0 register and the bits 26, 27, 28, 29, 30, 31 + * of the DMC_PHY_CTL2 are set. + */ + if (dmc.ddr_mode == DDR3_MODE || + dmc.ddr_mode == DDR2_MODE) { + writel(0XFC000000, dmc.reg + REG_DMC_PHY_CTL2); + writel(0x0000000f, dmc.reg + REG_DMC_PHY_CTL0); + } + + writel(0x00000000, dmc.reg + REG_DMC_PHY_CTL1); + + /* 4. For DDR3 mode, set bit 1 and configure bits [5:2] of the + * DMC_CPHY_CTL register with WL=CWL+AL in DCLK cycles. + */ + if (dmc.ddr_mode == DDR3_MODE) + writel(dmc.dmc_cphyctl_value, dmc.reg + REG_DMC_CPHY_CTL); + /* 5. Perform On Die Termination(ODT) & Driver Impedance Calibration */ + if (dmc.ddr_mode == LPDDR_MODE) { + /* Bypass processor ODT */ + writel(0x80000, dmc.reg + REG_DMC_PHY_CTL1); + } else { + /* Set bits RTTCALEN, PDCALEN, PUCALEN of register */ + temp = BITM_DMC_CAL_PADCTL0_RTTCALEN | + BITM_DMC_CAL_PADCTL0_PDCALEN | + BITM_DMC_CAL_PADCTL0_PUCALEN; + writel(temp, dmc.reg + REG_DMC_CAL_PADCTL0); + /* Configure ODT and drive impedance values in the + * DMCx_CAL_PADCTL2 register + */ + writel(dmc.padctl2_value, dmc.reg + REG_DMC_CAL_PADCTL2); + /* start calibration */ + temp |= BITM_DMC_CAL_PADCTL0_CALSTRT; + writel(temp, dmc.reg + REG_DMC_CAL_PADCTL0); + /* Wait for PAD calibration to complete - 300 DCLK cycle. + * Worst case: CCLK=450 MHz, DCLK=125 MHz + */ + dmcdelay(300); + } +} + +static inline void calibration_method1(void) +{ +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + writel(dmc.dmc_zqctl0_value, dmc.reg + REG_DMC_DDR_ZQ_CTL0); + writel(dmc.dmc_zqctl1_value, dmc.reg + REG_DMC_DDR_ZQ_CTL1); + writel(dmc.dmc_zqctl2_value, dmc.reg + REG_DMC_DDR_ZQ_CTL2); + + /* Generate the trigger */ + writel(0x0ul, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0x0ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + writel(0x00010000ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(8000u); + + /* The [31:26] bits may change if pad ring changes */ + writel(0x0C000001ul | DMC_TRIG_CALIB, dmc.reg + REG_DMC_DDR_CA_CTL); + dmcdelay(8000u); + writel(0x0ul, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0x0ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); +#endif +} + +static inline void calibration_method2(void) +{ +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + u32 stat_value = 0x0u; + u32 drv_pu, drv_pd, odt_pu, odt_pd; + u32 ro_dt, clk_dqs_drv_impedance; + u32 temp; + + /* Reset trigger */ + writel(0x0ul, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0x0ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + writel(0x0ul, dmc.reg + REG_DMC_DDR_SCRATCH_3); + writel(0x0ul, dmc.reg + REG_DMC_DDR_SCRATCH_2); + + /* Writing internal registers in calib pad to zero. Calib mode set + * to 1 [26], trig M1 S1 write [16], this enables usage of scratch + * registers instead of ZQCTL registers + */ + writel(0x04010000ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(2500u); + + /* TRIGGER FOR M2-S2 WRITE -> slave id 31:26 trig m2,s2 write + * bit 1->1 slave1 address is 4 + */ + writel(0x10000002ul, dmc.reg + REG_DMC_DDR_CA_CTL); + dmcdelay(2500u); + + /* reset Trigger */ + writel(0x0u, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0x0u, dmc.reg + REG_DMC_DDR_ROOT_CTL); + + /* write to slave 1, make the power down bit high */ + writel(0x1ul << 12, dmc.reg + REG_DMC_DDR_SCRATCH_3); + writel(0x0ul, dmc.reg + REG_DMC_DDR_SCRATCH_2); + dmcdelay(2500u); + + /* Calib mode set to 1 [26], trig M1 S1 write [16] */ + writel(0x04010000ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(2500u); + + writel(0x10000002ul, dmc.reg + REG_DMC_DDR_CA_CTL); + dmcdelay(2500u); + + writel(0x0ul, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0x0ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + writel(0x0, dmc.reg + REG_DMC_DDR_SCRATCH_3); + + /* for slave 0 */ + writel(dmc.dmc_zqctl0_value, dmc.reg + REG_DMC_DDR_SCRATCH_2); + + /* Calib mode set to 1 [26], trig M1 S1 write [16] */ + writel(0x04010000ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(2500u); + + writel(0x0C000002ul, dmc.reg + REG_DMC_DDR_CA_CTL); + dmcdelay(2500u); + + writel(0x0ul, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0x0ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + + /* writing to slave 1 + * calstrt is 0, but other programming is done + * + * make power down LOW again, to kickstart BIAS circuit + */ + writel(0x0ul, dmc.reg + REG_DMC_DDR_SCRATCH_3); + writel(0x30000000ul, dmc.reg + REG_DMC_DDR_SCRATCH_2); + + /* write to ca_ctl lane, calib mode set to 1 [26], + * trig M1 S1 write [16] + */ + writel(0x04010000ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(2500u); + + /* copies data to lane controller slave + * TRIGGER FOR M2-S2 WRITE -> slave id 31:26 + * trig m2,s2 write bit 1->1 + * slave1 address is 4 + */ + writel(0x10000002ul, dmc.reg + REG_DMC_DDR_CA_CTL); + dmcdelay(2500u); + + /* reset Trigger */ + writel(0x0ul, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0x0ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + writel(0x0ul, dmc.reg + REG_DMC_DDR_SCRATCH_3); + writel(0x0ul, dmc.reg + REG_DMC_DDR_SCRATCH_2); + writel(0x0ul, dmc.reg + REG_DMC_DDR_SCRATCH_3); + writel(0x0ul, dmc.reg + REG_DMC_DDR_SCRATCH_2); + writel(0x04010000ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(2500u); + writel(0x10000002ul, dmc.reg + REG_DMC_DDR_CA_CTL); + dmcdelay(2500u); + writel(0x0ul, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0x0ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + writel(0x0ul, dmc.reg + REG_DMC_DDR_SCRATCH_3); + writel(0x0ul, dmc.reg + REG_DMC_DDR_SCRATCH_2); + writel(0x0ul, dmc.reg + REG_DMC_DDR_SCRATCH_3); + writel(0x50000000ul, dmc.reg + REG_DMC_DDR_SCRATCH_2); + writel(0x04010000ul, dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(2500u); + writel(0x10000002ul, dmc.reg + REG_DMC_DDR_CA_CTL); + dmcdelay(2500u); + writel(0u, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0u, dmc.reg + REG_DMC_DDR_ROOT_CTL); + writel(0x0C000004u, dmc.reg + REG_DMC_DDR_CA_CTL); + dmcdelay(2500u); + writel(BITM_DMC_DDR_ROOT_CTL_TRIG_RD_XFER_ALL, + dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(2500u); + writel(0u, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0u, dmc.reg + REG_DMC_DDR_ROOT_CTL); + // calculate ODT PU and PD values + stat_value = ((readl(dmc.reg + REG_DMC_DDR_SCRATCH_7) & 0x0000FFFFu) << + 16); + stat_value |= ((readl(dmc.reg + REG_DMC_DDR_SCRATCH_6) & 0xFFFF0000u) >> + 16); + clk_dqs_drv_impedance = ((dmc.dmc_zqctl0_value) & + BITM_DMC_DDR_ZQ_CTL0_IMPWRDQ) >> BITP_DMC_DDR_ZQ_CTL0_IMPWRDQ; + ro_dt = ((dmc.dmc_zqctl0_value) & BITM_DMC_DDR_ZQ_CTL0_IMPRTT) >> + BITP_DMC_DDR_ZQ_CTL0_IMPRTT; + drv_pu = stat_value & 0x0000003Fu; + drv_pd = (stat_value >> 12) & 0x0000003Fu; + odt_pu = (drv_pu * clk_dqs_drv_impedance) / ro_dt; + odt_pd = (drv_pd * clk_dqs_drv_impedance) / ro_dt; + temp = ((1uL << 24) | + ((drv_pd & 0x0000003Fu)) | + ((odt_pd & 0x0000003Fu) << 6) | + ((drv_pu & 0x0000003Fu) << 12) | + ((odt_pu & 0x0000003Fu) << 18)); + temp |= readl(dmc.reg + REG_DMC_DDR_SCRATCH_2); + writel(temp, dmc.reg + REG_DMC_DDR_SCRATCH_2); + writel(0x0C010000u, dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(2500u); + writel(0x08000002u, dmc.reg + REG_DMC_DDR_CA_CTL); + dmcdelay(2500u); + writel(0u, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0u, dmc.reg + REG_DMC_DDR_ROOT_CTL); + writel(0x04010000u, dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(2500u); + writel(0x80000002u, dmc.reg + REG_DMC_DDR_CA_CTL); + dmcdelay(2500u); + writel(0u, dmc.reg + REG_DMC_DDR_CA_CTL); + writel(0u, dmc.reg + REG_DMC_DDR_ROOT_CTL); +#endif +} + +static inline void adi_dmc_lane_reset(bool reset, uint32_t dmc_no) +{ +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + u32 temp; + phys_addr_t base = (dmc_no == 0) ? REG_DMC0_BASE : REG_DMC1_BASE; + phys_addr_t ln0 = base + REG_DMC_DDR_LANE0_CTL0; + phys_addr_t ln1 = base + REG_DMC_DDR_LANE1_CTL0; + + if (reset) { + temp = readl(ln0); + temp |= BITM_DMC_DDR_LANE0_CTL0_CB_RSTDLL; + writel(temp, ln0); + + temp = readl(ln1); + temp |= BITM_DMC_DDR_LANE1_CTL0_CB_RSTDLL; + writel(temp, ln1); + } else { + temp = readl(ln0); + temp &= ~BITM_DMC_DDR_LANE0_CTL0_CB_RSTDLL; + writel(temp, ln0); + + temp = readl(ln1); + temp &= ~BITM_DMC_DDR_LANE1_CTL0_CB_RSTDLL; + writel(temp, ln1); + } + dmcdelay(9000u); +#endif +} + +void adi_dmc_reset_lanes(bool reset) +{ +#ifdef MEM_DDR3 + #if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + #ifdef MEM_DMC0 + adi_dmc_lane_reset(reset, 0); + #endif + #ifdef MEM_DMC1 + adi_dmc_lane_reset(reset, 1); + #endif + #else + u32 temp = reset ? 0x800 : 0x0; + #ifdef MEM_DMC0 + writel(temp, REG_DMC0_BASE + REG_DMC_PHY_CTL0); + #endif + #ifdef MEM_DMC1 + writel(temp, REG_DMC1_BASE + REG_DMC_PHY_CTL0); + #endif + #endif +#endif //MEM_DDR3 +} + +#pragma GCC push_options +#pragma GCC optimize("O0") +static inline void dummy_read(void) +{ + /* Do not let this be optimized out by compiler */ + readl(0x80000000); +} + +#pragma GCC pop_options + +static inline void dmc_controller_init(void) +{ +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + u32 phyphase, rd_cnt, t_EMR1, t_EMR3, t_CTL, data_cyc, temp; +#endif + + /* 1. Program the DMC controller registers: DMCx_CFG, DMCx_TR0, + * DMCx_TR1, DMCx_TR2, DMCx_MR(DDR2/LPDDR)/DMCx_MR0(DDR3), + * DMCx_EMR1(DDR2)/DMCx_MR1(DDR3), + * DMCx_EMR2(DDR2)/DMCx_EMR(LPDDR)/DMCx_MR2(DDR3) + */ + writel(dmc.dmc_cfg_value, dmc.reg + REG_DMC_CFG); + writel(dmc.dmc_tr0_value, dmc.reg + REG_DMC_TR0); + writel(dmc.dmc_tr1_value, dmc.reg + REG_DMC_TR1); + writel(dmc.dmc_tr2_value, dmc.reg + REG_DMC_TR2); + writel(dmc.dmc_mr0_value, dmc.reg + REG_DMC_MR); + writel(dmc.dmc_mr1_value, dmc.reg + REG_DMC_EMR1); + writel(dmc.dmc_mr2_value, dmc.reg + REG_DMC_EMR2); + +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + writel(dmc.dmc_mr3_value, dmc.reg + REG_DMC_EMR3); + writel(dmc.dmc_dllctl_value, dmc.reg + REG_DMC_DLLCTL); + dmcdelay(2000u); + + temp = readl(dmc.reg + REG_DMC_DDR_CA_CTL); + temp |= BITM_DMC_DDR_CA_CTL_SW_REFRESH; + writel(temp, dmc.reg + REG_DMC_DDR_CA_CTL); + dmcdelay(5u); + + temp = readl(dmc.reg + REG_DMC_DDR_ROOT_CTL); + temp |= BITM_DMC_DDR_ROOT_CTL_SW_REFRESH | + (DMC_OFSTDCYCLE << BITP_DMC_DDR_ROOT_CTL_PIPE_OFSTDCYCLE); + writel(temp, dmc.reg + REG_DMC_DDR_ROOT_CTL); +#endif + + /* 2. Make sure that the REG_DMC_DT_CALIB_ADDR register is programmed + * to an unused DMC location corresponding to a burst of 16 bytes + * (by default it is the starting address of the DMC address range). + */ +#ifndef CONFIG_SC59X + writel(dmc.dmc_data_calib_add_value, dmc.reg + REG_DMC_DT_CALIB_ADDR); +#endif + /* 3. Program the DMCx_CTL register with INIT bit set to start + * the DMC initialization sequence + */ + writel(dmc.dmc_ctl_value, dmc.reg + REG_DMC_CTL); + /* 4. Wait for the DMC initialization to complete by polling + * DMCx_STAT.INITDONE bit. + */ + +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + dmcdelay(722000u); + + /* Add necessary delay depending on the configuration */ + t_EMR1 = (dmc.dmc_mr1_value & BITM_DMC_MR1_WL) >> BITP_DMC_MR1_WL; + + dmcdelay(600u); + if (t_EMR1 != 0u) + while ((readl(dmc.reg + REG_DMC_EMR1) & BITM_DMC_MR1_WL) != 0) + ; + + t_EMR3 = (dmc.dmc_mr3_value & BITM_DMC_EMR3_MPR) >> + BITP_DMC_EMR3_MPR; + dmcdelay(2000u); + if (t_EMR3 != 0u) + while ((readl(dmc.reg + REG_DMC_EMR3) & BITM_DMC_EMR3_MPR) != 0) + ; + + t_CTL = (dmc.dmc_ctl_value & BITM_DMC_CTL_RL_DQS) >> BITP_DMC_CTL_RL_DQS; + dmcdelay(600u); + if (t_CTL != 0u) + while ((readl(dmc.reg + REG_DMC_CTL) & BITM_DMC_CTL_RL_DQS) != 0) + ; +#endif + + /* check if DMC initialization finished*/ + while ((readl(dmc.reg + REG_DMC_STAT) & BITM_DMC_STAT_INITDONE) == 0) + ; + +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + /* toggle DCYCLE */ + temp = readl(dmc.reg + REG_DMC_DDR_LANE0_CTL1); + temp |= BITM_DMC_DDR_LANE0_CTL1_COMP_DCYCLE; + writel(temp, dmc.reg + REG_DMC_DDR_LANE0_CTL1); + + temp = readl(dmc.reg + REG_DMC_DDR_LANE1_CTL1); + temp |= BITM_DMC_DDR_LANE1_CTL1_COMP_DCYCLE; + writel(temp, dmc.reg + REG_DMC_DDR_LANE1_CTL1); + + dmcdelay(10u); + + temp = readl(dmc.reg + REG_DMC_DDR_LANE0_CTL1); + temp &= (~BITM_DMC_DDR_LANE0_CTL1_COMP_DCYCLE); + writel(temp, dmc.reg + REG_DMC_DDR_LANE0_CTL1); + + temp = readl(dmc.reg + REG_DMC_DDR_LANE1_CTL1); + temp &= (~BITM_DMC_DDR_LANE1_CTL1_COMP_DCYCLE); + writel(temp, dmc.reg + REG_DMC_DDR_LANE1_CTL1); + + /* toggle RSTDAT */ + temp = readl(dmc.reg + REG_DMC_DDR_LANE0_CTL0); + temp |= BITM_DMC_DDR_LANE0_CTL0_CB_RSTDAT; + writel(temp, dmc.reg + REG_DMC_DDR_LANE0_CTL0); + + temp = readl(dmc.reg + REG_DMC_DDR_LANE0_CTL0); + temp &= (~BITM_DMC_DDR_LANE0_CTL0_CB_RSTDAT); + writel(temp, dmc.reg + REG_DMC_DDR_LANE0_CTL0); + + temp = readl(dmc.reg + REG_DMC_DDR_LANE1_CTL0); + temp |= BITM_DMC_DDR_LANE1_CTL0_CB_RSTDAT; + writel(temp, dmc.reg + REG_DMC_DDR_LANE1_CTL0); + + temp = readl(dmc.reg + REG_DMC_DDR_LANE1_CTL0); + temp &= (~BITM_DMC_DDR_LANE1_CTL0_CB_RSTDAT); + writel(temp, dmc.reg + REG_DMC_DDR_LANE1_CTL0); + + dmcdelay(2500u); + + /* Program phyphase*/ + phyphase = (readl(dmc.reg + REG_DMC_STAT) & + BITM_DMC_STAT_PHYRDPHASE) >> BITP_DMC_STAT_PHYRDPHASE; + data_cyc = (phyphase << BITP_DMC_DLLCTL_DATACYC) & + BITM_DMC_DLLCTL_DATACYC; + rd_cnt = dmc.dmc_dllctl_value; + rd_cnt <<= BITP_DMC_DLLCTL_DLLCALRDCNT; + rd_cnt &= BITM_DMC_DLLCTL_DLLCALRDCNT; + writel(rd_cnt | data_cyc, dmc.reg + REG_DMC_DLLCTL); + writel((dmc.dmc_ctl_value & (~BITM_DMC_CTL_INIT) & + (~BITM_DMC_CTL_RL_DQS)), dmc.reg + REG_DMC_CTL); + +#if DELAYTRIM + /* DQS delay trim*/ + u32 stat_value, WL_code_LDQS, WL_code_UDQS; + + /* For LDQS */ + temp = readl(dmc.reg + REG_DMC_DDR_LANE0_CTL1) | (0x000000D0); + writel(temp, dmc.reg + REG_DMC_DDR_LANE0_CTL1); + dmcdelay(2500u); + writel(0x00400000, dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(2500u); + writel(0x0, dmc.reg + REG_DMC_DDR_ROOT_CTL); + stat_value = (readl(dmc.reg + REG_DMC_DDR_SCRATCH_STAT0) & + (0xFFFF0000)) >> 16; + WL_code_LDQS = (stat_value) & (0x0000001F); + + temp = readl(dmc.reg + REG_DMC_DDR_LANE0_CTL1); + temp &= ~(BITM_DMC_DDR_LANE0_CTL1_BYPCODE | + BITM_DMC_DDR_LANE0_CTL1_BYPDELCHAINEN); + writel(temp, dmc.reg + REG_DMC_DDR_LANE0_CTL1); + + /* If write leveling is enabled */ + if ((dmc.dmc_mr1_value & BITM_DMC_MR1_WL) >> BITP_DMC_MR1_WL) { + temp = readl(dmc.reg + REG_DMC_DDR_LANE0_CTL1); + temp |= (((WL_code_LDQS + LANE0_DQS_DELAY) << + BITP_DMC_DDR_LANE0_CTL1_BYPCODE) & + BITM_DMC_DDR_LANE0_CTL1_BYPCODE) | + BITM_DMC_DDR_LANE0_CTL1_BYPDELCHAINEN; + writel(temp, dmc.reg + REG_DMC_DDR_LANE0_CTL1); + } else { + temp = readl(dmc.reg + REG_DMC_DDR_LANE0_CTL1); + temp |= (((DQS_DEFAULT_DELAY + LANE0_DQS_DELAY) << + BITP_DMC_DDR_LANE0_CTL1_BYPCODE) & + BITM_DMC_DDR_LANE0_CTL1_BYPCODE) | + BITM_DMC_DDR_LANE0_CTL1_BYPDELCHAINEN; + writel(temp, dmc.reg + REG_DMC_DDR_LANE0_CTL1); + } + dmcdelay(2500u); + + /* For UDQS */ + temp = readl(dmc.reg + REG_DMC_DDR_LANE1_CTL1) | (0x000000D0); + writel(temp, dmc.reg + REG_DMC_DDR_LANE1_CTL1); + dmcdelay(2500u); + writel(0x00800000, dmc.reg + REG_DMC_DDR_ROOT_CTL); + dmcdelay(2500u); + writel(0x0, dmc.reg + REG_DMC_DDR_ROOT_CTL); + stat_value = (readl(dmc.reg + REG_DMC_DDR_SCRATCH_STAT1) & + (0xFFFF0000)) >> 16; + WL_code_UDQS = (stat_value) & (0x0000001F); + + temp = readl(dmc.reg + REG_DMC_DDR_LANE1_CTL1); + temp &= ~(BITM_DMC_DDR_LANE0_CTL1_BYPCODE | + BITM_DMC_DDR_LANE0_CTL1_BYPDELCHAINEN); + writel(temp, dmc.reg + REG_DMC_DDR_LANE1_CTL1); + + /* If write leveling is enabled */ + if ((dmc.dmc_mr1_value & BITM_DMC_MR1_WL) >> BITP_DMC_MR1_WL) { + temp = readl(dmc.reg + REG_DMC_DDR_LANE1_CTL1); + temp |= (((WL_code_UDQS + LANE1_DQS_DELAY) << + BITP_DMC_DDR_LANE0_CTL1_BYPCODE) & + BITM_DMC_DDR_LANE0_CTL1_BYPCODE) | + BITM_DMC_DDR_LANE0_CTL1_BYPDELCHAINEN; + writel(temp, dmc.reg + REG_DMC_DDR_LANE1_CTL1); + } else { + temp = readl(dmc.reg + REG_DMC_DDR_LANE1_CTL1); + temp |= (((DQS_DEFAULT_DELAY + LANE1_DQS_DELAY) << + BITP_DMC_DDR_LANE0_CTL1_BYPCODE) & + BITM_DMC_DDR_LANE0_CTL1_BYPCODE) | + BITM_DMC_DDR_LANE0_CTL1_BYPDELCHAINEN; + writel(temp, dmc.reg + REG_DMC_DDR_LANE1_CTL1); + } + dmcdelay(2500u); +#endif + +#else + /* 5. Program the DMCx_CTL.DLLCTL register with 0x948 value + * (DATACYC=9, DLLCALRDCNT=72). + */ + writel(0x00000948, dmc.reg + REG_DMC_DLLCTL); +#endif + + /* 6. Workaround for anomaly#20000037 */ + if (dmc.anomaly_20000037_applicable) { + /* Perform dummy read to any DMC location */ + dummy_read(); + + writel(readl(dmc.reg + REG_DMC_PHY_CTL0) | 0x1000, + dmc.reg + REG_DMC_PHY_CTL0); + /* Clear DMCx_PHY_CTL0.RESETDAT bit */ + writel(readl(dmc.reg + REG_DMC_PHY_CTL0) & (~0x1000), + dmc.reg + REG_DMC_PHY_CTL0); + } +} + +static inline void dmc_init(void) +{ + /* PHY Calibration+Initialization */ + if (!dmc.phy_init_required) + goto out; + + switch (dmc.calib_mode) { + case CALIBRATION_LEGACY: + calibration_legacy(); + break; + case CALIBRATION_METHOD1: + calibration_method1(); + break; + case CALIBRATION_METHOD2: + calibration_method2(); + break; + } + +#if DQSTRIM + /* DQS duty trim */ + temp = readl(dmc.reg + REG_DMC_DDR_LANE0_CTL0); + temp |= ((DQSCODE) << BITP_DMC_DDR_LANE0_CTL0_BYPENB) & + (BITM_DMC_DDR_LANE1_CTL0_BYPENB | + BITM_DMC_DDR_LANE0_CTL0_BYPSELP | + BITM_DMC_DDR_LANE0_CTL0_BYPCODE); + writel(temp, dmc.reg + REG_DMC_DDR_LANE0_CTL0); + + temp = readl(dmc.reg + REG_DMC_DDR_LANE1_CTL0); + temp |= ((DQSCODE) << BITP_DMC_DDR_LANE1_CTL0_BYPENB) & + (BITM_DMC_DDR_LANE1_CTL1_BYPCODE | + BITM_DMC_DDR_LANE1_CTL0_BYPSELP | + BITM_DMC_DDR_LANE1_CTL0_BYPCODE); + writel(temp, dmc.reg + REG_DMC_DDR_LANE1_CTL0); +#endif + +#if CLKTRIM + /* Clock duty trim */ + temp = readl(dmc.reg + REG_DMC_DDR_CA_CTL); + temp |= (((CLKCODE << BITP_DMC_DDR_CA_CTL_BYPCODE1) & + BITM_DMC_DDR_CA_CTL_BYPCODE1) | + BITM_DMC_DDR_CA_CTL_BYPENB | + ((CLKDIR << BITP_DMC_DDR_CA_CTL_BYPSELP) & + BITM_DMC_DDR_CA_CTL_BYPSELP)); + writel(temp, dmc.reg + REG_DMC_DDR_CA_CTL); +#endif + +out: + /* Controller Initialization */ + dmc_controller_init(); +} + +static inline void __dmc_config(uint32_t dmc_no) +{ + if (dmc_no == 0) { + dmc.reg = REG_DMC0_BASE; + dmc.dmc_data_calib_add_value = DMC0_DATA_CALIB_ADD; + } else if (dmc_no == 1) { + dmc.reg = REG_DMC1_BASE; + dmc.dmc_data_calib_add_value = DMC1_DATA_CALIB_ADD; + } else { + return; + } + +#ifdef CONFIG_TARGET_SC584_EZKIT + dmc.ddr_mode = DDR2_MODE; +#else + dmc.ddr_mode = DDR3_MODE; +#endif + + dmc.phy_init_required = true; + +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + dmc.anomaly_20000037_applicable = false; + dmc.dmc_dllctl_value = DMC_DLLCTL_VALUE; + dmc.calib_mode = CALIBRATION_METHOD2; +#else + dmc.anomaly_20000037_applicable = true; + dmc.calib_mode = CALIBRATION_LEGACY; +#endif + + dmc.dmc_ctl_value = DMC_CTL_VALUE; + dmc.dmc_cfg_value = DMC_CFG_VALUE; + dmc.dmc_tr0_value = DMC_TR0_VALUE; + dmc.dmc_tr1_value = DMC_TR1_VALUE; + dmc.dmc_tr2_value = DMC_TR2_VALUE; + dmc.dmc_mr0_value = DMC_MR0_VALUE; + dmc.dmc_mr1_value = DMC_MR1_VALUE; + dmc.dmc_mr2_value = DMC_MR2_VALUE; + +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + dmc.dmc_mr3_value = DMC_MR3_VALUE; + dmc.dmc_zqctl0_value = DMC_ZQCTL0_VALUE; + dmc.dmc_zqctl1_value = DMC_ZQCTL1_VALUE; + dmc.dmc_zqctl2_value = DMC_ZQCTL2_VALUE; +#endif + + dmc.padctl2_value = DMC_PADCTL2_VALUE; + dmc.dmc_cphyctl_value = DMC_CPHYCTL_VALUE; + + /* Initialize DMC now */ + dmc_init(); +} + +void DMC_Config(void) +{ +#ifdef MEM_DMC0 + __dmc_config(0); +#endif + +#ifdef MEM_DMC1 + __dmc_config(1); +#endif +} diff --git a/arch/arm/mach-sc5xx/init/dmcinit.h b/arch/arm/mach-sc5xx/init/dmcinit.h new file mode 100644 index 0000000000..4fc36dd148 --- /dev/null +++ b/arch/arm/mach-sc5xx/init/dmcinit.h @@ -0,0 +1,29 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#ifndef DMCINIT_H_ +#define DMCINIT_H_ + +#ifdef MEM_MT41K512M16HA + #include "mem/mt41k512m16ha.h" +#elif defined(MEM_MT41K128M16JT) + #include "mem/mt41k128m16jt.h" +#elif defined(MEM_MT47H128M16RT) + #include "mem/mt47h128m16rt.h" +#elif defined(MEM_IS43TR16512BL) + #include "mem/is43tr16512bl.h" +#else + #error "No DDR part name is defined for this board." +#endif + +void DMC_Config(void); +void adi_dmc_reset_lanes(bool reset); + +#endif diff --git a/arch/arm/mach-sc5xx/init/init.c b/arch/arm/mach-sc5xx/init/init.c new file mode 100644 index 0000000000..8b033bf03a --- /dev/null +++ b/arch/arm/mach-sc5xx/init/init.c @@ -0,0 +1,68 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#include <asm/arch-adi/sc5xx/sc5xx.h> +#include <asm/io.h> +#include <config.h> +#include <linux/types.h> +#include <asm/io.h> +#include "clkinit.h" +#include "dmcinit.h" +#include "init.h" + +static void spu_disable_peripheral_security(void) +{ +#if !(defined(CONFIG_SC57X) || defined(CONFIG_SC59X_64)) + u32 i; + + for (i = REG_SPU0_SECUREP_START; i <= REG_SPU0_SECUREP_END; i += 4) + writel(0, i); +#endif +} + +void adi_initcode_shared(void) +{ + clks_init(); + + //DDR init + DMC_Config(); + +#ifdef CONFIG_SC59X_64 + // Enable coresight timer + writel(1, REG_TSGENWR0_CNTCR); +#endif + + // Enable non-secure access to SHARC to support remoteproc in Linux + writel(0, REG_SPU0_SECUREC0); + writel(0, REG_SPU0_SECUREC1); + writel(0, REG_SPU0_SECUREC2); + +#ifdef CONFIG_SC59X_64 + //Do not rerun preboot routine -- + // Without this, hardware resets triggered by RCU0_CTL:SYSRST + // lead to a deadlock somewhere in the boot ROM + writel(0x200, REG_RCU0_BCODE); +#endif + +#ifndef CONFIG_SC59X_64 + // Configure PMU for non-secure operation + writel(readl(REG_ARMPMU0_PMUSERENR) | 0x01, REG_ARMPMU0_PMUSERENR); + writel(0xc5acce55, REG_ARMPMU0_PMLAR); + writel(readl(REG_ARMPMU0_PMCR) | (1 << 1), REG_ARMPMU0_PMCR); +#endif + +#if defined(CONFIG_SC59X) || defined(CONFIG_SC59X_64) + //Enable board LEDs 7, 9, and 10 + writel(0xE, 0x3100411C); + writel(0xE, 0x3100410C); +#endif + + spu_disable_peripheral_security(); +} diff --git a/arch/arm/mach-sc5xx/init/init.h b/arch/arm/mach-sc5xx/init/init.h new file mode 100644 index 0000000000..4fef49cd13 --- /dev/null +++ b/arch/arm/mach-sc5xx/init/init.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#if defined(CONFIG_SC57X) || defined(CONFIG_SC59X) +#define REG_SPU0_SECUREC0 0x3108B980 +#define REG_SPU0_SECUREC1 0x3108B984 +#define REG_SPU0_SECUREC2 0x3108B988 +#define REG_SPU0_SECUREP_START 0x3108BA00 +#define REG_SPU0_SECUREP_END 0x3108BD24 +#endif + +#ifdef CONFIG_SC59X_64 +#define REG_RCU0_BCODE 0x3108C028 +#define REG_TSGENWR0_CNTCR 0x310AE000 /* TSGENWR0 Counter Control Register */ +#endif + +#ifdef CONFIG_SC58X +#define REG_SPU0_SECUREC0 0x3108C980 +#define REG_SPU0_SECUREC1 0x3108C984 +#define REG_SPU0_SECUREC2 0x3108C988 +#define REG_SPU0_SECUREP_START 0x3108CA00 +#define REG_SPU0_SECUREP_END 0x3108CCF0 +#endif + +#define REG_ARMPMU0_PMCR 0x31121E04 +#define REG_ARMPMU0_PMUSERENR 0x31121E08 +#define REG_ARMPMU0_PMLAR 0x31121FB0 + +void adi_initcode(void); +void adi_initcode_shared(void); diff --git a/arch/arm/mach-sc5xx/init/mem/is43tr16512bl.h b/arch/arm/mach-sc5xx/init/mem/is43tr16512bl.h new file mode 100644 index 0000000000..bdf6c349d4 --- /dev/null +++ b/arch/arm/mach-sc5xx/init/mem/is43tr16512bl.h @@ -0,0 +1,63 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#ifndef IS43TR16512BL_H +#define IS43TR16512BL_H + +/* DMC0 setup for the EV-21593-SOM and EV-SC594-SOM : + * - uses a single 8GB IS43TR16512BL-125KBL DDR3 chip configured for + * 800 MHz DCLK. + * DMC0 setup for the EV-SC594-SOMS : + * - uses a single 4GB IS43TR16256BL-093NBL DDR3 chip configured for + * 800 MHz DCLK. + */ +#define MEM_DDR3 +#define DMC_DLLCALRDCNT 240 +#define DMC_DATACYC 12 +#define DMC_TRCD 11 +#define DMC_TWTR 6 +#define DMC_TRP 11 +#define DMC_TRAS 28 +#define DMC_TRC 39 +#define DMC_TMRD 4 +#define DMC_TREF 6240 +#define DMC_TRRD 6 +#define DMC_TFAW 32 +#define DMC_TRTP 6 +#define DMC_TWR 12 +#define DMC_TXP 5 +#define DMC_TCKE 4 +#define DMC_CL0 0 +#define DMC_CL123 7 +#define DMC_WRRECOV 6 +#define DMC_MR1_DLLEN 0 +#define DMC_MR1_DIC0 0 +#define DMC_MR1_RTT0 0 +#define DMC_MR1_AL 0 +#define DMC_MR1_DIC1 0 +#define DMC_MR1_RTT1 1 +#define DMC_MR1_WL 0 +#define DMC_MR1_RTT2 0 +#define DMC_MR1_TDQS 0 +#define DMC_MR1_QOFF 0 +#define DMC_WL 3 +#define DMC_RDTOWR 5 +#define DMC_CTL_AL_EN 1 +#if defined(MEM_ISSI_4Gb_DDR3_800MHZ) + #define SDR_CHIP_SIZE (ENUM_DMC_CFG_SDRSIZE4G) + #define DMC_TRFC 208ul +#elif defined(MEM_ISSI_8Gb_DDR3_800MHZ) + #define SDR_CHIP_SIZE (ENUM_DMC_CFG_SDRSIZE8G) + #define DMC_TRFC 280ul +#else + #error "Need to select MEM_ISSI_4Gb_DDR3_800MHZ or MEM_ISSI_8Gb_DDR3_800MHZ" +#endif + +#endif diff --git a/arch/arm/mach-sc5xx/init/mem/mt41k128m16jt.h b/arch/arm/mach-sc5xx/init/mem/mt41k128m16jt.h new file mode 100644 index 0000000000..7d94788f3a --- /dev/null +++ b/arch/arm/mach-sc5xx/init/mem/mt41k128m16jt.h @@ -0,0 +1,51 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#ifndef MT41K128M16JT_H +#define MT41K128M16JT_H + +/* Default DDR3 part assumed: MT41K128M16JT-125, 2Gb part */ +/* For DCLK= 450 MHz */ +#define MEM_DDR3 +#define DMC_DLLCALRDCNT 72 +#define DMC_DATACYC 9 +#define DMC_TRCD 6 +#define DMC_TWTR 4 +#define DMC_TRP 6 +#define DMC_TRAS 17 +#define DMC_TRC 23 +#define DMC_TMRD 4 +#define DMC_TREF 3510 +#define DMC_TRFC 72 +#define DMC_TRRD 4 +#define DMC_TFAW 17 +#define DMC_TRTP 4 +#define DMC_TWR 7 +#define DMC_TXP 4 +#define DMC_TCKE 3 +#define DMC_CL0 0 +#define DMC_CL123 3 +#define DMC_WRRECOV (DMC_TWR - 1) +#define DMC_MR1_DLLEN 0 +#define DMC_MR1_DIC0 1 +#define DMC_MR1_RTT0 1 +#define DMC_MR1_AL 0 +#define DMC_MR1_DIC1 0 +#define DMC_MR1_RTT1 0 +#define DMC_MR1_WL 0 +#define DMC_MR1_RTT2 0 +#define DMC_MR1_TDQS 0 +#define DMC_MR1_QOFF 0 +#define DMC_WL 1 +#define DMC_RDTOWR 2 +#define DMC_CTL_AL_EN 0 +#define SDR_CHIP_SIZE ENUM_DMC_CFG_SDRSIZE2G + +#endif diff --git a/arch/arm/mach-sc5xx/init/mem/mt41k512m16ha.h b/arch/arm/mach-sc5xx/init/mem/mt41k512m16ha.h new file mode 100644 index 0000000000..6740e4bf66 --- /dev/null +++ b/arch/arm/mach-sc5xx/init/mem/mt41k512m16ha.h @@ -0,0 +1,51 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#ifndef MT41K512M16HA_H +#define MT41K512M16HA_H + +/* Default DDR3 part assumed: MT41K512M16HA-107, 8Gb part */ +/* For DCLK= 450 MHz */ +#define MEM_DDR3 +#define DMC_DLLCALRDCNT 72 +#define DMC_DATACYC 9 +#define DMC_TRCD 7 +#define DMC_TWTR 4 +#define DMC_TRP 7 +#define DMC_TRAS 10 +#define DMC_TRC 16 +#define DMC_TMRD 4 +#define DMC_TREF 3510 +#define DMC_TRFC 158 +#define DMC_TRRD 6 +#define DMC_TFAW 16 +#define DMC_TRTP 4 +#define DMC_TWR 7 +#define DMC_TXP 3 +#define DMC_TCKE 3 +#define DMC_CL0 0 +#define DMC_CL123 3 +#define DMC_WRRECOV (DMC_TWR - 1) +#define DMC_MR1_DLLEN 0 +#define DMC_MR1_DIC0 1 +#define DMC_MR1_RTT0 1 +#define DMC_MR1_AL 0 +#define DMC_MR1_DIC1 0 +#define DMC_MR1_RTT1 0 +#define DMC_MR1_WL 0 +#define DMC_MR1_RTT2 0 +#define DMC_MR1_TDQS 0 +#define DMC_MR1_QOFF 0 +#define DMC_WL 1 +#define DMC_RDTOWR 2 +#define DMC_CTL_AL_EN 0 +#define SDR_CHIP_SIZE ENUM_DMC_CFG_SDRSIZE8G + +#endif diff --git a/arch/arm/mach-sc5xx/init/mem/mt47h128m16rt.h b/arch/arm/mach-sc5xx/init/mem/mt47h128m16rt.h new file mode 100644 index 0000000000..ddd9c4efba --- /dev/null +++ b/arch/arm/mach-sc5xx/init/mem/mt47h128m16rt.h @@ -0,0 +1,50 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#ifndef MT47H128M16RT_H +#define MT47H128M16RT_H + +/* Default DDR2 part: MT47H128M16RT-25E XIT:C, 2 Gb part */ +/* For DCLK= 400 MHz */ +#define MEM_DDR2 +#define DMC_DLLCALRDCNT 72 +#define DMC_DATACYC 9 +#define DMC_TRCD 5 +#define DMC_TWTR 3 +#define DMC_TRP 5 +#define DMC_TRAS 16 +#define DMC_TRC 22 +#define DMC_TMRD 2 +#define DMC_TREF 3120 +#define DMC_TRFC 78 +#define DMC_TRRD 4 +#define DMC_TFAW 18 +#define DMC_TRTP 3 +#define DMC_TWR 6 +#define DMC_TXP 2 +#define DMC_TCKE 3 +#define DMC_CL 5 +#define DMC_WRRECOV (DMC_TWR - 1) +#define DMC_MR1_DLLEN 0 +#define DMC_MR1_DIC0 1 +#define DMC_MR1_RTT0 1 +#define DMC_MR1_AL 4 +#define DMC_MR1_DIC1 0 +#define DMC_MR1_RTT1 0 +#define DMC_MR1_WL 0 +#define DMC_MR1_RTT2 0 +#define DMC_MR1_TDQS 0 +#define DMC_MR1_QOFF 0 +#define DMC_BL 4 +#define DMC_RDTOWR 2 +#define DMC_CTL_AL_EN 0 +#define SDR_CHIP_SIZE ENUM_DMC_CFG_SDRSIZE2G + +#endif diff --git a/arch/arm/mach-sc5xx/rcu.c b/arch/arm/mach-sc5xx/rcu.c new file mode 100644 index 0000000000..49357501a9 --- /dev/null +++ b/arch/arm/mach-sc5xx/rcu.c @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2024 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Ian Roberts ian.roberts@timesys.com + */ + +#include <dm.h> +#include <syscon.h> + +static const struct udevice_id adi_syscon_ids[] = { + { .compatible = "adi,reset-controller" }, + { } +}; + +U_BOOT_DRIVER(syscon_sc5xx_rcu) = { + .name = "sc5xx_rcu", + .id = UCLASS_SYSCON, + .of_match = adi_syscon_ids, +}; diff --git a/arch/arm/mach-sc5xx/sc57x.c b/arch/arm/mach-sc5xx/sc57x.c new file mode 100644 index 0000000000..936f206a01 --- /dev/null +++ b/arch/arm/mach-sc5xx/sc57x.c @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2024 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#include <asm/io.h> +#include <asm/arch-adi/sc5xx/sc5xx.h> + +#define REG_PADS0_PCFG0 0x31004404 + +adi_rom_boot = (void (*)(void *, uint32_t, int32_t, void *, uint32_t))0x000000e1; + +void sc5xx_enable_rgmii(void) +{ + writel((readl(REG_PADS0_PCFG0) | 0xc), REG_PADS0_PCFG0); +} diff --git a/arch/arm/mach-sc5xx/sc58x.c b/arch/arm/mach-sc5xx/sc58x.c new file mode 100644 index 0000000000..936f206a01 --- /dev/null +++ b/arch/arm/mach-sc5xx/sc58x.c @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2024 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#include <asm/io.h> +#include <asm/arch-adi/sc5xx/sc5xx.h> + +#define REG_PADS0_PCFG0 0x31004404 + +adi_rom_boot = (void (*)(void *, uint32_t, int32_t, void *, uint32_t))0x000000e1; + +void sc5xx_enable_rgmii(void) +{ + writel((readl(REG_PADS0_PCFG0) | 0xc), REG_PADS0_PCFG0); +} diff --git a/arch/arm/mach-sc5xx/sc59x.c b/arch/arm/mach-sc5xx/sc59x.c new file mode 100644 index 0000000000..0ba3125c5e --- /dev/null +++ b/arch/arm/mach-sc5xx/sc59x.c @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2024 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#include <asm/io.h> +#include <asm/arch-adi/sc5xx/sc5xx.h> + +#define REG_PADS0_PCFG0 0x31004604 + +#define REG_SCB5_SPI2_OSPI_REMAP 0x30400000 +#define BITM_SCB5_SPI2_OSPI_REMAP_REMAP 0x00000003 +#define ENUM_SCB5_SPI2_OSPI_REMAP_OSPI0 0x00000001 + +adi_rom_boot = (void (*)(void *, uint32_t, int32_t, void *, uint32_t))0x000000e9; + +void sc5xx_enable_rgmii(void) +{ + writel((readl(REG_PADS0_PCFG0) | 0xc), REG_PADS0_PCFG0); +} + +void sc59x_remap_ospi(void) +{ + clrsetbits_le32(REG_SCB5_SPI2_OSPI_REMAP, + BITM_SCB5_SPI2_OSPI_REMAP_REMAP, + ENUM_SCB5_SPI2_OSPI_REMAP_OSPI0); +} diff --git a/arch/arm/mach-sc5xx/sc59x_64.c b/arch/arm/mach-sc5xx/sc59x_64.c new file mode 100644 index 0000000000..c084182c8d --- /dev/null +++ b/arch/arm/mach-sc5xx/sc59x_64.c @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2024 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#include <asm/io.h> +#include <asm/arch-adi/sc5xx/sc5xx.h> + +#define REG_PADS0_PCFG0 0x31004604 + +#define REG_SCB5_SPI2_OSPI_REMAP 0x30400000 +#define BITM_SCB5_SPI2_OSPI_REMAP_REMAP 0x00000003 +#define ENUM_SCB5_SPI2_OSPI_REMAP_OSPI0 0x00000001 + +adi_rom_boot = (void (*)(void *, uint32_t, int32_t, void *, uint32_t))0x000000e4; + +void sc5xx_enable_rgmii(void) +{ + writel((readl(REG_PADS0_PCFG0) | 0xc), REG_PADS0_PCFG0); + + // Set dw for little endian operation as well + writel(readl(REG_PADS0_PCFG0) & ~(1 << 19), REG_PADS0_PCFG0); + writel(readl(REG_PADS0_PCFG0) & ~(1 << 20), REG_PADS0_PCFG0); +} + +void sc59x_remap_ospi(void) +{ + clrsetbits_le32(REG_SCB5_SPI2_OSPI_REMAP, + BITM_SCB5_SPI2_OSPI_REMAP_REMAP, + ENUM_SCB5_SPI2_OSPI_REMAP_OSPI0); +} diff --git a/arch/arm/mach-sc5xx/soc.c b/arch/arm/mach-sc5xx/soc.c new file mode 100644 index 0000000000..bb11668054 --- /dev/null +++ b/arch/arm/mach-sc5xx/soc.c @@ -0,0 +1,142 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#include <asm/arch-adi/sc5xx/sc5xx.h> +#include <asm/io.h> +#include <asm/system.h> +#include <cpu_func.h> + +#include <asm/arch-adi/sc5xx/soc.h> + +DECLARE_GLOBAL_DATA_PTR; + +void reset_cpu(void) +{ + writel(1, RCU0_CTL); +} + +void enable_caches(void) +{ + if (!IS_ENABLED(CONFIG_SYS_DCACHE_OFF)) + dcache_enable(); +} + +/* + * Don't try to configure the L2 cache in uboot because there's not quite + * enough documentation on which implementations we have + */ +void v7_outer_cache_enable(void) +{ +} + +int arch_cpu_init(void) +{ + return 0; +} + +const char *sc5xx_get_boot_mode(u32 *bmode) +{ + static const char * const bmodes[] = { + "JTAG/BOOTROM", + "QSPI Master", + "QSPI Slave", + "UART", + "LP0 Slave", + "OSPI", +#ifdef CONFIG_SC59X_64 + "eMMC" +#endif + }; + u32 local_mode; + + local_mode = (readl(RCU0_STAT) & BITM_RCU_STAT_BMODE) >> BITP_RCU_STAT_BMODE; + +#if CONFIG_ADI_SPL_FORCE_BMODE != 0 + /* + * In case we want to force boot sequences such as: + * QSPI -> OSPI + * QSPI -> eMMC + * If this is not set, then we will always try to use the BMODE setting + * for both stages... i.e. + * QSPI -> QSPI + */ + + // (Don't allow skipping JTAG/UART BMODE settings) + if (local_mode != 0 && local_mode != 3) + local_mode = CONFIG_ADI_SPL_FORCE_BMODE; +#endif + + *bmode = local_mode; + + if (local_mode >= 0 && local_mode <= ARRAY_SIZE(bmodes)) + return bmodes[local_mode]; + return "unknown"; +} + +void print_cpu_id(void) +{ + if (!IS_ENABLED(CONFIG_ARM64)) { + u32 cpuid = 0; + + __asm__ __volatile__("mrc p15, 0, %0, c0, c0, 0" : "=r"(cpuid)); + + printf("Detected Revision: %d.%d\n", cpuid & 0xf00000 >> 20, cpuid & 0xf); + } +} + +int print_cpuinfo(void) +{ + u32 bmode; + + printf("CPU: ADSP %s (%s boot)\n", CONFIG_LDR_CPU, sc5xx_get_boot_mode(&bmode)); + print_cpu_id(); + + return 0; +} + +void fixup_dp83867_phy(struct phy_device *phydev) +{ + int phy_data = 0; + + phy_data = phy_read(phydev, MDIO_DEVAD_NONE, 0x32); + phy_write(phydev, MDIO_DEVAD_NONE, 0x32, (1 << 7) | phy_data); + int cfg3 = 0; + #define MII_DP83867_CFG3 (0x1e) + /* + * Pin INT/PWDN on DP83867 should be configured as an Interrupt Output + * instead of a Power-Down Input on ADI SC5XX boards in order to + * prevent the signal interference from other peripherals during they + * are running at the same time. + */ + cfg3 = phy_read(phydev, MDIO_DEVAD_NONE, MII_DP83867_CFG3); + cfg3 |= (1 << 7); + phy_write(phydev, MDIO_DEVAD_NONE, MII_DP83867_CFG3, cfg3); + + // Mystery second port fixup on ezkits with two PHYs + if (CONFIG_DW_PORTS & 2) + phy_write(phydev, MDIO_DEVAD_NONE, 0x11, 3); + + if (IS_ENABLED(CONFIG_ADI_BUG_EZKHW21)) { + phydev->advertising &= PHY_BASIC_FEATURES; + phydev->speed = SPEED_100; + } + + if (phydev->drv->config) + phydev->drv->config(phydev); + + if (IS_ENABLED(CONFIG_ADI_BUG_EZKHW21)) + phy_write(phydev, MDIO_DEVAD_NONE, 0, 0x3100); +} + +int dram_init(void) +{ + gd->ram_size = CFG_SYS_SDRAM_SIZE; + return 0; +} diff --git a/arch/arm/mach-sc5xx/spl.c b/arch/arm/mach-sc5xx/spl.c new file mode 100644 index 0000000000..d8877110e4 --- /dev/null +++ b/arch/arm/mach-sc5xx/spl.c @@ -0,0 +1,140 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + */ + +#include <spl.h> +#include <asm/arch-adi/sc5xx/spl.h> +#include "init/init.h" + +static bool adi_start_uboot_proper; + +static int adi_sf_default_bus = CONFIG_SF_DEFAULT_BUS; +static int adi_sf_default_cs = CONFIG_SF_DEFAULT_CS; +static int adi_sf_default_speed = CONFIG_SF_DEFAULT_SPEED; + +u32 bmode; + +int spl_start_uboot(void) +{ + return adi_start_uboot_proper; +} + +unsigned int spl_spi_get_default_speed(void) +{ + return adi_sf_default_speed; +} + +unsigned int spl_spi_get_default_bus(void) +{ + return adi_sf_default_bus; +} + +unsigned int spl_spi_get_default_cs(void) +{ + return adi_sf_default_cs; +} + +void board_boot_order(u32 *spl_boot_list) +{ + const char *bmodestring = sc5xx_get_boot_mode(&bmode); + + printf("ADI Boot Mode: 0x%x (%s)\n", bmode, bmodestring); + + /* + * By default everything goes back to the bootrom, where we'll read table + * parameters and ask for another image to be loaded + */ + spl_boot_list[0] = BOOT_DEVICE_BOOTROM; + + if (bmode == 0) { + printf("SPL execution has completed. Please load U-Boot Proper via JTAG"); + while (1) + ; + } +} + +int32_t __weak adi_rom_boot_hook(struct ADI_ROM_BOOT_CONFIG *config, int32_t cause) +{ + return 0; +} + +int board_return_to_bootrom(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev) +{ +#if CONFIG_ADI_SPL_FORCE_BMODE != 0 + // see above + if (bmode != 0 && bmode != 3) + bmode = CONFIG_ADI_SPL_FORCE_BMODE; +#endif + + if (bmode >= (ARRAY_SIZE(adi_rom_boot_args))) + bmode = 0; + + adi_rom_boot((void *)adi_rom_boot_args[bmode].addr, + adi_rom_boot_args[bmode].flags, + 0, &adi_rom_boot_hook, + adi_rom_boot_args[bmode].cmd); + return 0; +}; + +int dram_init_banksize(void) +{ + return 0; +} + +void board_init_f(ulong dummy) +{ + int ret; + + if (IS_ENABLED(CONFIG_SC59X_64)) { + phys_addr_t smpus[] = { + 0x31007800, //SMPU0 + 0x31083800, //SMPU2 + 0x31084800, //SMPU3 + 0x31085800, //SMPU4 + 0x31086800, //SMPU5 + 0x31087800, //SMPU6 + 0x310A0800, //SMPU9 + 0x310A1800, //SMPU11 + 0x31012800, //SMPU12 + }; + size_t i; + + /* Alter outstanding transactions property of A55*/ + writel(0x1, 0x30643108); /* SCB6 A55 M0 Ib.fn Mod */ + isb(); + + /* configure DDR prefetch behavior, per ADI */ + writel(0x1, 0x31076000); + + /* configure smart mode, per ADI */ + writel(0x1307, 0x31076004); + + /* configure spu0 */ + for (i = 0; i < 214; ++i) + writel(0, 0x3108BA00 + 4 * i); + + /* configure spu0 wp */ + for (i = 0; i < 214; ++i) + writel(0, 0x3108B400 + i * 4); + + /* configure smpus permissively */ + for (i = 0; i < ARRAY_SIZE(smpus); ++i) + writel(0x500, smpus[i]); + } + + adi_initcode_shared(); + + ret = spl_early_init(); + if (ret) + panic("spl_early_init() failed\n"); + + preloader_console_init(); +} + diff --git a/include/configs/sc_adi_common.h b/include/configs/sc_adi_common.h new file mode 100644 index 0000000000..a1d66e92dd --- /dev/null +++ b/include/configs/sc_adi_common.h @@ -0,0 +1,226 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + * + */ + +#ifndef __CONFIG_SC_ADI_COMMON_H +#define __CONFIG_SC_ADI_COMMON_H + +/* + * Env Settings + */ +#ifdef CONFIG_SC59X_64 + #define ADI_EARLYPRINTK "earlycon=adi_uart,0x31003000 " + #if !CONFIG_IS_ENABLED(FIT) + #define IMAGEFILE "Image" + #define ADI_BOOT_INITRD "booti ${loadaddr} ${initramaddr} ${dtbaddr};" + #define ADI_BOOT "booti ${loadaddr} - ${dtbaddr};" + #else + #define IMAGEFILE "fitImage" + #define ADI_BOOT_INITRD "bootm ${loadaddr};" + #define ADI_BOOT "bootm ${loadaddr};" + #endif +#else + #define ADI_EARLYPRINTK "earlyprintk=serial,uart0," \ + __stringify(CONFIG_BAUDRATE) " " + #if !CONFIG_IS_ENABLED(FIT) + #define IMAGEFILE "zImage" + #define ADI_BOOT_INITRD "bootz ${loadaddr} ${initramaddr} ${dtbaddr};" + #define ADI_BOOT "bootz ${loadaddr} - ${dtbaddr};" + #else + #define IMAGEFILE "fitImage" + #define ADI_BOOT_INITRD "bootm ${loadaddr};" + #define ADI_BOOT "bootm ${loadaddr};" + #endif +#endif + +#define ADI_UPDATE_SPI_UBOOT_CMD " run update_spi_uboot;" +#define ADI_UPDATE_SPI_RFS_CMD " run update_spi_rfs;" + +#if CONFIG_IS_ENABLED(FIT) + #define ADI_UPDATE_SPI_DTB_CMD "" + #define ADI_UPDATE_SPI_IMAGE_CMD "" + #define ADI_UPDATE_SPI_FIT_CMD " run update_spi_fit;" + #define ADI_SPI_BOOTCMD "sf read ${loadaddr} " ADI_IMG_OFFSET \ + " ${imagesize}; bootm ${loadaddr};" + #define ADI_MMC_LOAD "ext4load mmc 0:1 ${loadaddr} /boot/fitImage;" + #define ADI_TFTP_DTB "" + #define ADI_TFTP_INITRD "" +#else + #define ADI_UPDATE_SPI_DTB_CMD " run update_spi_dtb;" + #define ADI_UPDATE_SPI_IMAGE_CMD " run update_spi_image;" + #define ADI_UPDATE_SPI_FIT_CMD "" + #define ADI_SPI_BOOTCMD "sf read ${loadaddr} " ADI_IMG_OFFSET \ + " ${imagesize}; sf read ${dtbaddr} ${dtbloadaddr} ${dtbsize}; " \ + "booti ${loadaddr} - ${dtbaddr}" + #define ADI_MMC_LOAD "ext4load mmc 0:1 ${dtbaddr} /boot/" CONFIG_DTBNAME "; " \ + "ext4load mmc 0:1 ${loadaddr} /boot/Image;" + #define ADI_TFTP_DTB "tftp ${dtbaddr} ${tftp_dir_prefix}${dtbfile}; " + #define ADI_TFTP_INITRD "tftp ${initramaddr} ${tftp_dir_prefix}${initramfile}; " +#endif + +#define ADI_MMC_BOOTCMD "run mmcargs; " ADI_BOOT "" + +#define ADI_BOOTARGS_CONSOLE \ + ADI_EARLYPRINTK \ + "console=ttySC" __stringify(CONFIG_UART_CONSOLE) "," \ + __stringify(CONFIG_BAUDRATE) " " \ + "vmalloc=512M " + +#define ADI_BOOTARGS_MMC \ + "root=/dev/mmcblk0p1 rw " \ + "rootfstype=ext4 rootwait " \ + ADI_BOOTARGS_CONSOLE + +#define ADI_BOOTARGS_SPI \ + "root=/dev/mtdblock4 rw " \ + "rootfstype=jffs2 " \ + ADI_BOOTARGS_CONSOLE + +#define ADI_BOOTARGS_NFS \ + "root=/dev/nfs rw " \ + "nfsroot=${serverip}:/romfs,tcp,nfsvers=3 " \ + ADI_BOOTARGS_CONSOLE + +#define UBOOT_ENV_FILE "u-boot-" CONFIG_SYS_BOARD ".ldr" + +#define ADI_INIT_ETHERNET \ + "init_ethernet=mii info; dhcp; setenv serverip ${tftpserverip};\0" + +#define ADI_NFS_BOOT \ + "nfsargs=setenv bootargs " ADI_BOOTARGS_NFS "\0" \ + "nfsboot=" \ + "run init_ethernet; " \ + "tftp ${loadaddr} ${tftp_dir_prefix}${imagefile};" \ + ADI_TFTP_DTB \ + "run nfsargs;" \ + "run addip;" \ + ADI_BOOT \ + "\0" + +#define ADI_RAM_BOOT \ + "ramboot=" \ + "run init_ethernet; " \ + "tftp ${loadaddr} ${tftp_dir_prefix}${imagefile}; " \ + ADI_TFTP_DTB \ + ADI_TFTP_INITRD \ + "run ramargs; " \ + ADI_BOOT_INITRD \ + "\0" + +#define STAGE_1_FILE "stage1-boot.ldr" +#define STAGE_2_FILE "stage2-boot.ldr" +#define ADI_UPDATE_SPI_UBOOT \ + "stage1file=" STAGE_1_FILE "\0" \ + "stage2file=" STAGE_2_FILE "\0" \ + "update_spi_uboot_stage1=tftp ${loadaddr} ${tftp_dir_prefix}${stage1file}; " \ + "sf probe ${sfdev}; sf update ${loadaddr} 0x0 ${filesize};\0" \ + "update_spi_uboot_stage2=tftp ${loadaddr} ${tftp_dir_prefix}${stage2file}; " \ + "sf probe ${sfdev}; sf update ${loadaddr} " ADI_UBOOT_OFFSET " ${filesize};\0" \ + "update_spi_uboot=run update_spi_uboot_stage1; run update_spi_uboot_stage2;\0" + +#if CONFIG_IS_ENABLED(FIT) + #define ADI_UPDATE_SPI_DTB "" +#else + #define ADI_UPDATE_SPI_DTB \ + "update_spi_dtb=tftp ${loadaddr} ${tftp_dir_prefix}${dtbfile}; " \ + "sf probe ${sfdev}; " \ + "setexpr dtbloadaddr ${imagesize} + " ADI_IMG_OFFSET "; " \ + "sf update ${loadaddr} ${dtbloadaddr} ${filesize}; " \ + "setenv dtbsize ${filesize};\0" +#endif + +#define ADI_ERASE_SPI \ + "erase_spi=setenv sfdev " __stringify(CONFIG_SC_BOOT_SPI_BUS) \ + ":" __stringify(CONFIG_SC_BOOT_SPI_SSEL) "; " \ + "setenv sfsize " ADI_SPI_SIZE "; sf probe ${sfdev}; sf erase 0 ${sfsize};\0" + +#define ADI_UPDATE_SPI \ + "start_update_spi=run init_ethernet; sf probe ${sfdev};" \ + ADI_UPDATE_SPI_UBOOT_CMD \ + ADI_UPDATE_SPI_IMAGE_CMD \ + ADI_UPDATE_SPI_FIT_CMD \ + ADI_UPDATE_SPI_DTB_CMD \ + ADI_UPDATE_SPI_RFS_CMD \ + " sleep 3; saveenv\0" \ + ADI_UPDATE_SPI_UBOOT \ + ADI_UPDATE_SPI_DTB \ + "update_spi_image=tftp ${loadaddr} ${tftp_dir_prefix}${imagefile}; " \ + "sf probe ${sfdev}; sf update ${loadaddr} " ADI_IMG_OFFSET " ${filesize}; " \ + "setenv imagesize ${filesize};\0" \ + "update_spi_fit=tftp ${loadaddr} ${tftp_dir_prefix}${imagefile}; " \ + "sf probe ${sfdev}; sf update ${loadaddr} " ADI_IMG_OFFSET " ${filesize}; " \ + "setenv imagesize ${filesize};\0" \ + "update_spi_rfs=tftp ${loadaddr} ${tftp_dir_prefix}${jffs2file}; " \ + "sf probe ${sfdev}; sf update ${loadaddr} " ADI_RFS_OFFSET " ${filesize};\0" + +#define ADI_UPDATE_SPI_UBOOT_ONLY \ + "start_update_spi_uboot_only=run init_ethernet; sf probe ${sfdev};" \ + ADI_UPDATE_SPI_UBOOT_CMD \ + " sleep 3; saveenv\0" \ + ADI_UPDATE_SPI_UBOOT \ + +#define ADI_ERASE_OSPI \ + "erase_ospi=setenv sfdev " __stringify(CONFIG_SC_BOOT_OSPI_BUS) ":" \ + __stringify(CONFIG_SC_BOOT_OSPI_SSEL) "; " \ + "setenv sfsize " ADI_OSPI_SIZE "; sf probe ${sfdev}; sf erase 0 ${sfsize};\0" + +#define ADI_OSPI_BOOT \ + "update_ospi=setenv sfdev " __stringify(CONFIG_SC_BOOT_OSPI_BUS) ":" \ + __stringify(CONFIG_SC_BOOT_OSPI_SSEL) "; " \ + "setenv sfsize " ADI_OSPI_SIZE "; setenv bootcmd 'run ospiboot'; " \ + "setenv argscmd ospiargs; run start_update_spi;\0" \ + "update_ospi_uboot_only=setenv sfdev " __stringify(CONFIG_SC_BOOT_OSPI_BUS) ":" \ + __stringify(CONFIG_SC_BOOT_OSPI_SSEL) "; run start_update_spi_uboot_only;\0" \ + "ospiargs=setenv bootargs " ADI_BOOTARGS_SPI "\0" \ + "ospi_boot=run ospiargs; sf probe ${sfdev};" ADI_SPI_BOOTCMD "\0" \ + "ospiboot=run ospi_boot\0" + +#define ADI_SPI_BOOT \ + "update_spi=setenv sfdev " __stringify(CONFIG_SC_BOOT_SPI_BUS) ":" \ + __stringify(CONFIG_SC_BOOT_SPI_SSEL) "; setenv sfsize " ADI_SPI_SIZE "; " \ + "setenv bootcmd 'run spiboot'; setenv argscmd spiargs; " \ + "run start_update_spi;\0" \ + "update_spi_uboot_only=setenv sfdev " __stringify(CONFIG_SC_BOOT_SPI_BUS) ":" \ + __stringify(CONFIG_SC_BOOT_SPI_SSEL) "; run start_update_spi_uboot_only;\0" \ + "spiargs=setenv bootargs " ADI_BOOTARGS_SPI "\0" \ + "spi_boot=run spiargs; sf probe ${sfdev};" ADI_SPI_BOOTCMD "\0" \ + "spiboot=run spi_boot\0" + +#define ADI_MMC_BOOT \ + "update_mmc=setenv bootcmd 'run mmcboot'; saveenv; " \ + "setenv imagefile fitImage-emmc-tools; run ramboot\0" \ + "mmcargs=setenv bootargs " ADI_BOOTARGS_MMC "\0" \ + "mmcload=" ADI_MMC_LOAD "\0" \ + "mmc_boot=" ADI_MMC_BOOTCMD "\0" \ + "mmcboot=mmc rescan; run mmcload; run mmc_boot\0" + +#define ETH0ADDR "02:80:ad:20:31:e8" +#define ETH1ADDR "02:80:ad:20:31:e9" + +#define CFG_EXTRA_ENV_SETTINGS \ + "autoload=no\0" \ + "ubootfile=" UBOOT_ENV_FILE "\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:" \ + "${hostname}:eth0:off" \ + "\0" \ + \ + "imagefile=" IMAGEFILE "\0" \ + "initramfile=adsp-sc5xx-ramdisk-adsp-" CONFIG_SYS_BOARD ".cpio.xz.u-boot\0" \ + "jffs2file=adsp-sc5xx-" ADI_JFFS2_FILE "-adsp-" CONFIG_SYS_BOARD ".jffs2\0" \ + "initramaddr=" INITRAMADDR "\0" \ + "dtbfile=" DTBNAME "\0" \ + "dtbaddr=" DTBLOADADDR "\0" \ + "loadaddr=" __stringify(LOADADDR) "\0" \ + "ramargs=setenv bootargs " ADI_BOOTARGS_CONSOLE "\0" \ + "ethaddr=" ETH0ADDR "\0" \ + ADI_ENV_SETTINGS + +#endif
On Thu, Apr 11, 2024 at 07:37:28PM -0400, Greg Malysa wrote:
From: Nathan Barrett-Morrison nathan.morrison@timesys.com
Add support for the SC5xx machine type from Analog Devices. This includes support for the SC57x, SC58x, SC59x, and SC59x-64 SoCs, which have many common features such as common ADI IP blocks, and SHARC DSP cores. This commit introduces core functionality required for all boards using an SC5xx SoC, such as:
- SPL configuration
- Required CPU hooks such as reset
- Boot ROM interaction to load the stage 2 bootloader in the reference configuration. Other options are possible but not officially supported at this time
- SoC-common configuration expected to be reused by all boards
- Early initialization for system clocks and DDR controller
Co-developed-by: Greg Malysa greg.malysa@timesys.com Signed-off-by: Greg Malysa greg.malysa@timesys.com Co-developed-by: Ian Roberts ian.roberts@timesys.com Signed-off-by: Ian Roberts ian.roberts@timesys.com Signed-off-by: Vasileios Bimpikas vasileios.bimpikas@analog.com Signed-off-by: Utsav Agarwal utsav.agarwal@analog.com Signed-off-by: Arturs Artamonovs arturs.artamonovs@analog.com Signed-off-by: Nathan Barrett-Morrison nathan.morrison@timesys.com
MAINTAINERS | 13 + arch/arm/Kconfig | 6 + arch/arm/Makefile | 1 + arch/arm/include/asm/arch-adi/sc5xx/sc5xx.h | 115 +++ arch/arm/include/asm/arch-adi/sc5xx/soc.h | 18 + arch/arm/include/asm/arch-adi/sc5xx/spl.h | 41 + arch/arm/include/asm/mach-types.h | 4 +
We shouldn't be adding more to mach-types.h.
arch/arm/mach-sc5xx/Kconfig | 464 +++++++++
Here and elsewhere I think I saw whitespace issues (help should be <TAB><space><space>) in the entries, along with adding "default n" for new options, and that's not needed as n is the default.
[snip]
diff --git a/arch/arm/mach-sc5xx/config.mk b/arch/arm/mach-sc5xx/config.mk new file mode 100644 index 0000000000..b80644d6dc --- /dev/null +++ b/arch/arm/mach-sc5xx/config.mk
[snip]
+ifndef CONFIG_SC59X_64
- # Select the Analog Devices processor.
- PLATFORM_RELFLAGS += -fno-stack-protector -std=gnu89
+endif
We should be using the defaults here.
Also: - Please switch to plain text environment instead of defining in board.h and so on. - Audit your #include usage, I saw more <config.h> that is likely needed for example.
Hi Tom,
Thanks for the quick feedback. I'll go through our patches and review the #include usage as part of preparing for v2, and we'll work out switching to the plain text environment as well. I'll drop the custom compiler options and make sure we weren't actually relying on them--possibly it was just necessary for the initial set of init code we started with. I believe we're not using the mach type constants anywhere so that will be straightforward to drop as well.
Thanks, Greg
- SPL configuration
[snip]
[snip]
+endif
Also:
-- Tom
This adds support for the SC5XX clock trees which are required for reading clock speeds on the SoCs. This is largely a port of the same support for Linux, which has not yet been submitted upstream.
Co-developed-by: Greg Malysa greg.malysa@timesys.com Signed-off-by: Greg Malysa greg.malysa@timesys.com Co-developed-by: Ian Roberts ian.roberts@timesys.com Signed-off-by: Ian Roberts ian.roberts@timesys.com Signed-off-by: Vasileios Bimpikas vasileios.bimpikas@analog.com Signed-off-by: Utsav Agarwal utsav.agarwal@analog.com Signed-off-by: Arturs Artamonovs arturs.artamonovs@analog.com Signed-off-by: Nathan Barrett-Morrison nathan.morrison@timesys.com ---
MAINTAINERS | 1 + drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/adi/Kconfig | 83 ++++++ drivers/clk/adi/Makefile | 16 + drivers/clk/adi/clk-adi-pll.c | 94 ++++++ drivers/clk/adi/clk-adi-sc57x.c | 205 +++++++++++++ drivers/clk/adi/clk-adi-sc58x.c | 221 ++++++++++++++ drivers/clk/adi/clk-adi-sc594.c | 230 +++++++++++++++ drivers/clk/adi/clk-adi-sc598.c | 307 ++++++++++++++++++++ drivers/clk/adi/clk-shared.c | 48 +++ drivers/clk/adi/clk.h | 122 ++++++++ include/dt-bindings/clock/adi-sc5xx-clock.h | 271 +++++++++++++++++ 13 files changed, 1600 insertions(+) create mode 100644 drivers/clk/adi/Kconfig create mode 100644 drivers/clk/adi/Makefile create mode 100644 drivers/clk/adi/clk-adi-pll.c create mode 100644 drivers/clk/adi/clk-adi-sc57x.c create mode 100644 drivers/clk/adi/clk-adi-sc58x.c create mode 100644 drivers/clk/adi/clk-adi-sc594.c create mode 100644 drivers/clk/adi/clk-adi-sc598.c create mode 100644 drivers/clk/adi/clk-shared.c create mode 100644 drivers/clk/adi/clk.h create mode 100644 include/dt-bindings/clock/adi-sc5xx-clock.h
diff --git a/MAINTAINERS b/MAINTAINERS index 9693b86ddd..a9f52a6c7e 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -609,6 +609,7 @@ S: Supported T: git https://github.com/analogdevicesinc/lnxdsp-u-boot F: arch/arm/include/asm/arch-adi/ F: arch/arm/mach-sc5xx/ +F: drivers/clk/adi/ F: include/configs/sc_adi_common.h
ARM SNAPDRAGON diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 017dd260a5..d8c619add4 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -246,6 +246,7 @@ config CLK_ZYNQMP This clock driver adds support for clock realted settings for ZynqMP platform.
+source "drivers/clk/adi/Kconfig" source "drivers/clk/analogbits/Kconfig" source "drivers/clk/at91/Kconfig" source "drivers/clk/exynos/Kconfig" diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 638ad04bae..847b9b2911 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -12,6 +12,7 @@ obj-$(CONFIG_$(SPL_TPL_)CLK_CCF) += clk-fixed-factor.o obj-$(CONFIG_$(SPL_TPL_)CLK_COMPOSITE_CCF) += clk-composite.o obj-$(CONFIG_$(SPL_TPL_)CLK_GPIO) += clk-gpio.o
+obj-y += adi/ obj-y += analogbits/ obj-y += imx/ obj-$(CONFIG_CLK_JH7110) += starfive/ diff --git a/drivers/clk/adi/Kconfig b/drivers/clk/adi/Kconfig new file mode 100644 index 0000000000..5745bedf88 --- /dev/null +++ b/drivers/clk/adi/Kconfig @@ -0,0 +1,83 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# (C) Copyright 2022 - Analog Devices, Inc. +# +# Written and/or maintained by Timesys Corporation +# +# Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com +# Contact: Greg Malysa greg.malysa@timesys.com +# + +config COMMON_CLK_ADI_SHARED + bool "Enable shared ADI clock framework code" + help + Required for shared code between SoC clock drivers. Automatically + selected by an appropriate SoC-specific clock driver version. + +config COMMON_CLK_ADI_SC598 + bool "Clock driver for ADI SC598 SoCs" + select DM + select CLK + select CLK_CCF + select OF_CONTROL + select CMD_CLK + select SPL_DM if SPL + select SPL_CLK if SPL + select SPL_CLK_CCF if SPL + select SPL_OF_CONTROL if SPL + select COMMON_CLK_ADI_SHARED + depends on SC59X_64 + help + This driver supports the system clocks on Analog Devices SC598-series + SoCs. It includes CGU and CDU clocks and supports gating unused clocks. + Modifying PLL configuration is not supported; that must be done prior + to booting the kernel. Clock dividers after the PLLs may be configured. + +config COMMON_CLK_ADI_SC594 + bool "Clock driver for ADI SC594 SoCs" + select DM + select CLK + select CLK_CCF + select OF_CONTROL + select CMD_CLK + select SPL_DM if SPL + select SPL_CLK if SPL + select SPL_CLK_CCF if SPL + select SPL_OF_CONTROL if SPL + select COMMON_CLK_ADI_SHARED + depends on SC59X + help + This driver supports the system clocks on Analog Devices SC594-series + SoCs. It includes CGU and CDU clocks and supports gating unused clocks. + Modifying PLL configuration is not supported; that must be done prior + to booting the kernel. Clock dividers after the PLLs may be configured. + +config COMMON_CLK_ADI_SC58X + bool "Clock driver for ADI SC58X SoCs" + select DM + select CLK + select CLK_CCF + select OF_CONTROL + select CMD_CLK + select COMMON_CLK_ADI_SHARED + depends on SC58X + help + This driver supports the system clocks on Analog Devices SC58x-series + SoCs. It includes CGU and CDU clocks and supports gating unused clocks. + Modifying PLL configuration is not supported; that must be done prior + to booting the kernel. Clock dividers after the PLLs may be configured. + +config COMMON_CLK_ADI_SC57X + bool "Clock driver for ADI SC57X SoCs" + select DM + select CLK + select CLK_CCF + select OF_CONTROL + select CMD_CLK + select COMMON_CLK_ADI_SHARED + depends on SC57X + help + This driver supports the system clocks on Analog Devices SC57x-series + SoCs. It includes CGU and CDU clocks and supports gating unused clocks. + Modifying PLL configuration is not supported; that must be done prior + to booting the kernel. Clock dividers after the PLLs may be configured. diff --git a/drivers/clk/adi/Makefile b/drivers/clk/adi/Makefile new file mode 100644 index 0000000000..f3f1fd92e5 --- /dev/null +++ b/drivers/clk/adi/Makefile @@ -0,0 +1,16 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# (C) Copyright 2022 - Analog Devices, Inc. +# +# Written and/or maintained by Timesys Corporation +# +# Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com +# Contact: Greg Malysa greg.malysa@timesys.com +# + +obj-$(CONFIG_COMMON_CLK_ADI_SHARED) += clk-shared.o clk-adi-pll.o + +obj-$(CONFIG_COMMON_CLK_ADI_SC594) += clk-adi-sc594.o +obj-$(CONFIG_COMMON_CLK_ADI_SC598) += clk-adi-sc598.o +obj-$(CONFIG_COMMON_CLK_ADI_SC58X) += clk-adi-sc58x.o +obj-$(CONFIG_COMMON_CLK_ADI_SC57X) += clk-adi-sc57x.o diff --git a/drivers/clk/adi/clk-adi-pll.c b/drivers/clk/adi/clk-adi-pll.c new file mode 100644 index 0000000000..6a99011b86 --- /dev/null +++ b/drivers/clk/adi/clk-adi-pll.c @@ -0,0 +1,94 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Author: Greg Malysa greg.malysa@timesys.com + * + * Ported from Linux: Nathan Barrett-Morrison nathan.morrison@timesys.com + */ + +#include <asm/io.h> +#include <div64.h> +#include <malloc.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <dm/devres.h> +#include <dm/uclass.h> +#include <clk.h> +#include "clk.h" +#include <linux/err.h> + +#define ADI_CLK_PLL_GENERIC "adi_clk_pll_generic" + +struct clk_sc5xx_cgu_pll { + struct clk clk; + void __iomem *base; + u32 mask; + u32 max; + u32 m_offset; + u8 shift; + bool half_m; +}; + +#define to_clk_sc5xx_cgu_pll(_clk) container_of(_clk, struct clk_sc5xx_cgu_pll, clk) + +static unsigned long sc5xx_cgu_pll_get_rate(struct clk *clk) +{ + struct clk_sc5xx_cgu_pll *pll = to_clk_sc5xx_cgu_pll(dev_get_clk_ptr(clk->dev)); + unsigned long parent_rate = clk_get_parent_rate(clk); + + u32 reg = readl(pll->base); + u32 m = ((reg & pll->mask) >> pll->shift) + pll->m_offset; + + if (m == 0) + m = pll->max; + + if (pll->half_m) + return parent_rate * m * 2; + return parent_rate * m; +} + +static const struct clk_ops clk_sc5xx_cgu_pll_ops = { + .get_rate = sc5xx_cgu_pll_get_rate, +}; + +struct clk *sc5xx_cgu_pll(const char *name, const char *parent_name, + void __iomem *base, u8 shift, u8 width, u32 m_offset, + bool half_m) +{ + struct clk_sc5xx_cgu_pll *pll; + struct clk *clk; + int ret; + char *drv_name = ADI_CLK_PLL_GENERIC; + + pll = kzalloc(sizeof(*pll), GFP_KERNEL); + if (!pll) + return ERR_PTR(-ENOMEM); + + pll->base = base; + pll->shift = shift; + pll->mask = GENMASK(width - 1, 0) << shift; + pll->max = pll->mask + 1; + pll->m_offset = m_offset; + pll->half_m = half_m; + + clk = &pll->clk; + + ret = clk_register(clk, drv_name, name, parent_name); + if (ret) { + pr_err("Failed to register %s in %s: %d\n", name, __func__, ret); + kfree(pll); + return ERR_PTR(ret); + } + + return clk; +} + +U_BOOT_DRIVER(clk_adi_pll_generic) = { + .name = ADI_CLK_PLL_GENERIC, + .id = UCLASS_CLK, + .ops = &clk_sc5xx_cgu_pll_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/drivers/clk/adi/clk-adi-sc57x.c b/drivers/clk/adi/clk-adi-sc57x.c new file mode 100644 index 0000000000..6756c9f77c --- /dev/null +++ b/drivers/clk/adi/clk-adi-sc57x.c @@ -0,0 +1,205 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Author: Greg Malysa greg.malysa@timesys.com + * + * Ported from Linux: Nathan Barrett-Morrison nathan.morrison@timesys.com + */ + +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <log.h> +#include <linux/types.h> +#include <linux/clk-provider.h> +#include <linux/ioport.h> +#include <linux/io.h> +#include <dt-bindings/clock/adi-sc5xx-clock.h> + +#include "clk.h" + +static const char * const cgu1_in_sels[] = {"sys_clkin0", "sys_clkin1"}; +static const char * const sharc0_sels[] = {"cclk0_0", "sysclk_0", "dummy", "dummy"}; +static const char * const sharc1_sels[] = {"cclk0_0", "sysclk_0", "dummy", "dummy"}; +static const char * const arm_sels[] = {"cclk1_0", "sysclk_0", "dummy", "dummy"}; +static const char * const cdu_ddr_sels[] = {"dclk_0", "dclk_1", "dummy", "dummy"}; +static const char * const can_sels[] = {"oclk_0", "oclk_1", "dclk_1", "oclk_0_half"}; +static const char * const spdif_sels[] = {"oclk_0", "oclk_1", "dclk_1", "dclk_0"}; +static const char * const gige_sels[] = {"sclk1_0", "sclk1_1", "cclk0_1", "oclk_0"}; +static const char * const sdio_sels[] = {"oclk_0_half", "cclk1_1_half", "cclk1_1", + "dclk_1"}; + +static int sc57x_clock_probe(struct udevice *dev) +{ + void __iomem *cgu0; + void __iomem *cgu1; + void __iomem *cdu; + int ret; + struct resource res; + + struct clk *clks[ADSP_SC57X_CLK_END]; + struct clk dummy, clkin0, clkin1; + + ret = dev_read_resource_byname(dev, "cgu0", &res); + if (ret) + return ret; + cgu0 = devm_ioremap(dev, res.start, resource_size(&res)); + + ret = dev_read_resource_byname(dev, "cgu1", &res); + if (ret) + return ret; + cgu1 = devm_ioremap(dev, res.start, resource_size(&res)); + + ret = dev_read_resource_byname(dev, "cdu", &res); + if (ret) + return ret; + cdu = devm_ioremap(dev, res.start, resource_size(&res)); + + // Input clock configuration + clk_get_by_name(dev, "dummy", &dummy); + clk_get_by_name(dev, "sys_clkin0", &clkin0); + clk_get_by_name(dev, "sys_clkin1", &clkin1); + + clks[ADSP_SC57X_CLK_DUMMY] = &dummy; + clks[ADSP_SC57X_CLK_SYS_CLKIN0] = &clkin0; + clks[ADSP_SC57X_CLK_SYS_CLKIN1] = &clkin1; + + clks[ADSP_SC57X_CLK_CGU1_IN] = clk_register_mux(NULL, "cgu1_in_sel", cgu1_in_sels, + 2, CLK_SET_RATE_PARENT, + cdu + CDU_CLKINSEL, 0, 1, 0); + + // CGU configuration and internal clocks + clks[ADSP_SC57X_CLK_CGU0_PLL_IN] = clk_register_divider(NULL, "cgu0_df", + "sys_clkin0", + CLK_SET_RATE_PARENT, + cgu0 + CGU_CTL, 0, 1, 0); + clks[ADSP_SC57X_CLK_CGU1_PLL_IN] = clk_register_divider(NULL, "cgu1_df", + "cgu1_in_sel", + CLK_SET_RATE_PARENT, + cgu1 + CGU_CTL, 0, 1, 0); + + // VCO output == PLL output + clks[ADSP_SC57X_CLK_CGU0_PLLCLK] = sc5xx_cgu_pll("cgu0_pllclk", "cgu0_df", + cgu0 + CGU_CTL, CGU_MSEL_SHIFT, + CGU_MSEL_WIDTH, 0, false); + clks[ADSP_SC57X_CLK_CGU1_PLLCLK] = sc5xx_cgu_pll("cgu1_pllclk", "cgu1_df", + cgu1 + CGU_CTL, CGU_MSEL_SHIFT, + CGU_MSEL_WIDTH, 0, false); + + // Dividers from pll output + clks[ADSP_SC57X_CLK_CGU0_CDIV] = cgu_divider("cgu0_cdiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 0, 5, 0); + clks[ADSP_SC57X_CLK_CGU0_SYSCLK] = cgu_divider("sysclk_0", "cgu0_pllclk", + cgu0 + CGU_DIV, 8, 5, 0); + clks[ADSP_SC57X_CLK_CGU0_DDIV] = cgu_divider("cgu0_ddiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 16, 5, 0); + clks[ADSP_SC57X_CLK_CGU0_ODIV] = cgu_divider("cgu0_odiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 22, 7, 0); + clks[ADSP_SC57X_CLK_CGU0_S0SELDIV] = cgu_divider("cgu0_s0seldiv", "sysclk_0", + cgu0 + CGU_DIV, 5, 3, 0); + clks[ADSP_SC57X_CLK_CGU0_S1SELDIV] = cgu_divider("cgu0_s1seldiv", "sysclk_0", + cgu0 + CGU_DIV, 13, 3, 0); + + clks[ADSP_SC57X_CLK_CGU1_CDIV] = cgu_divider("cgu1_cdiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 0, 5, 0); + clks[ADSP_SC57X_CLK_CGU1_SYSCLK] = cgu_divider("sysclk_1", "cgu1_pllclk", + cgu1 + CGU_DIV, 8, 5, 0); + clks[ADSP_SC57X_CLK_CGU1_DDIV] = cgu_divider("cgu1_ddiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 16, 5, 0); + clks[ADSP_SC57X_CLK_CGU1_ODIV] = cgu_divider("cgu1_odiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 22, 7, 0); + clks[ADSP_SC57X_CLK_CGU1_S0SELDIV] = cgu_divider("cgu1_s0seldiv", + "sysclk_1", cgu1 + CGU_DIV, 5, + 3, 0); + clks[ADSP_SC57X_CLK_CGU1_S1SELDIV] = cgu_divider("cgu1_s1seldiv", + "sysclk_1", cgu1 + CGU_DIV, 13, + 3, 0); + + // Gates to enable CGU outputs + clks[ADSP_SC57X_CLK_CGU0_CCLK0] = cgu_gate("cclk0_0", "cgu0_cdiv", + cgu0 + CGU_CCBF_DIS, 0); + clks[ADSP_SC57X_CLK_CGU0_CCLK1] = cgu_gate("cclk1_0", "cgu0_cdiv", + cgu1 + CGU_CCBF_DIS, 1); + clks[ADSP_SC57X_CLK_CGU0_OCLK] = cgu_gate("oclk_0", "cgu0_odiv", + cgu0 + CGU_SCBF_DIS, 3); + clks[ADSP_SC57X_CLK_CGU0_DCLK] = cgu_gate("dclk_0", "cgu0_ddiv", + cgu0 + CGU_SCBF_DIS, 2); + clks[ADSP_SC57X_CLK_CGU0_SCLK1] = cgu_gate("sclk1_0", "cgu0_s1seldiv", + cgu0 + CGU_SCBF_DIS, 1); + clks[ADSP_SC57X_CLK_CGU0_SCLK0] = cgu_gate("sclk0_0", "cgu0_s0seldiv", + cgu0 + CGU_SCBF_DIS, 0); + + clks[ADSP_SC57X_CLK_CGU1_CCLK0] = cgu_gate("cclk0_1", "cgu1_cdiv", + cgu1 + CGU_CCBF_DIS, 0); + clks[ADSP_SC57X_CLK_CGU1_CCLK1] = cgu_gate("cclk1_1", "cgu1_cdiv", + cgu1 + CGU_CCBF_DIS, 1); + clks[ADSP_SC57X_CLK_CGU1_OCLK] = cgu_gate("oclk_1", "cgu1_odiv", + cgu1 + CGU_SCBF_DIS, 3); + clks[ADSP_SC57X_CLK_CGU1_DCLK] = cgu_gate("dclk_1", "cgu1_ddiv", + cgu1 + CGU_SCBF_DIS, 2); + clks[ADSP_SC57X_CLK_CGU1_SCLK1] = cgu_gate("sclk1_1", "cgu1_s1seldiv", + cgu1 + CGU_SCBF_DIS, 1); + clks[ADSP_SC57X_CLK_CGU1_SCLK0] = cgu_gate("sclk0_1", "cgu1_s0seldiv", + cgu1 + CGU_SCBF_DIS, 0); + + // Extra half rate clocks generated in the CDU + clks[ADSP_SC57X_CLK_OCLK0_HALF] = clk_register_fixed_factor(NULL, "oclk_0_half", + "oclk_0", + CLK_SET_RATE_PARENT, + 1, 2); + clks[ADSP_SC57X_CLK_CCLK1_1_HALF] = clk_register_fixed_factor(NULL, + "cclk1_1_half", + "cclk1_1", + CLK_SET_RATE_PARENT, + 1, 2); + + // CDU output muxes + clks[ADSP_SC57X_CLK_SHARC0_SEL] = cdu_mux("sharc0_sel", cdu + CDU_CFG0, + sharc0_sels); + clks[ADSP_SC57X_CLK_SHARC1_SEL] = cdu_mux("sharc1_sel", cdu + CDU_CFG1, + sharc1_sels); + clks[ADSP_SC57X_CLK_ARM_SEL] = cdu_mux("arm_sel", cdu + CDU_CFG2, arm_sels); + clks[ADSP_SC57X_CLK_CDU_DDR_SEL] = cdu_mux("cdu_ddr_sel", cdu + CDU_CFG3, + cdu_ddr_sels); + clks[ADSP_SC57X_CLK_CAN_SEL] = cdu_mux("can_sel", cdu + CDU_CFG4, can_sels); + clks[ADSP_SC57X_CLK_SPDIF_SEL] = cdu_mux("spdif_sel", cdu + CDU_CFG5, spdif_sels); + clks[ADSP_SC57X_CLK_GIGE_SEL] = cdu_mux("gige_sel", cdu + CDU_CFG7, gige_sels); + clks[ADSP_SC57X_CLK_SDIO_SEL] = cdu_mux("sdio_sel", cdu + CDU_CFG9, sdio_sels); + + // CDU output enable gates + clks[ADSP_SC57X_CLK_SHARC0] = cdu_gate("sharc0", "sharc0_sel", cdu + CDU_CFG0, + CLK_IS_CRITICAL); + clks[ADSP_SC57X_CLK_SHARC1] = cdu_gate("sharc1", "sharc1_sel", cdu + CDU_CFG1, + CLK_IS_CRITICAL); + clks[ADSP_SC57X_CLK_ARM] = cdu_gate("arm", "arm_sel", cdu + CDU_CFG2, + CLK_IS_CRITICAL); + clks[ADSP_SC57X_CLK_CDU_DDR] = cdu_gate("cdu_ddr", "cdu_ddr_sel", cdu + CDU_CFG3, + CLK_IS_CRITICAL); + clks[ADSP_SC57X_CLK_CAN] = cdu_gate("can", "can_sel", cdu + CDU_CFG4, 0); + clks[ADSP_SC57X_CLK_SPDIF] = cdu_gate("spdif", "spdif_sel", cdu + CDU_CFG5, 0); + clks[ADSP_SC57X_CLK_GIGE] = cdu_gate("gige", "gige_sel", cdu + CDU_CFG7, 0); + clks[ADSP_SC57X_CLK_SDIO] = cdu_gate("sdio", "sdio_sel", cdu + CDU_CFG9, 0); + + ret = cdu_check_clocks(clks, ARRAY_SIZE(clks)); + if (ret) + pr_err("CDU error detected\n"); + + return ret; +} + +static const struct udevice_id adi_sc57x_clk_ids[] = { + { .compatible = "adi,sc57x-clocks" }, + { }, +}; + +U_BOOT_DRIVER(adi_sc57x_clk) = { + .name = "clk_adi_sc57x", + .id = UCLASS_CLK, + .of_match = adi_sc57x_clk_ids, + .ops = &adi_clk_ops, + .probe = sc57x_clock_probe, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/drivers/clk/adi/clk-adi-sc58x.c b/drivers/clk/adi/clk-adi-sc58x.c new file mode 100644 index 0000000000..07df7acaa5 --- /dev/null +++ b/drivers/clk/adi/clk-adi-sc58x.c @@ -0,0 +1,221 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Author: Greg Malysa greg.malysa@timesys.com + * + * Ported from Linux: Nathan Barrett-Morrison nathan.morrison@timesys.com + */ + +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <log.h> +#include <linux/types.h> +#include <linux/clk-provider.h> +#include <linux/ioport.h> +#include <linux/io.h> +#include <dt-bindings/clock/adi-sc5xx-clock.h> + +#include "clk.h" + +static const char * const cgu1_in_sels[] = {"sys_clkin0", "sys_clkin1"}; +static const char * const sharc0_sels[] = {"cclk0_0", "sysclk_0", "dummy", "dummy"}; +static const char * const sharc1_sels[] = {"cclk0_0", "sysclk_0", "dummy", "dummy"}; +static const char * const arm_sels[] = {"cclk1_0", "sysclk_0", "dummy", "dummy"}; +static const char * const cdu_ddr_sels[] = {"dclk_0", "dclk_1", "dummy", "dummy"}; +static const char * const can_sels[] = {"oclk_0", "oclk_1", "dclk_1", "dummy"}; +static const char * const spdif_sels[] = {"oclk_0", "oclk_1", "dclk_1", "dclk_0"}; +static const char * const reserved_sels[] = {"sclk0_0", "oclk_0", "dummy", "dummy"}; +static const char * const gige_sels[] = {"sclk0_0", "sclk1_1", "cclk0_1", "oclk_0"}; +static const char * const lp_sels[] = {"sclk0_0", "sclk0_1", "cclk1_1", "dclk_1"}; +static const char * const sdio_sels[] = {"oclk_0_half", "cclk1_1_half", "cclk1_1", + "dclk_1"}; + +static int sc58x_clock_probe(struct udevice *dev) +{ + void __iomem *cgu0; + void __iomem *cgu1; + void __iomem *cdu; + int ret; + struct resource res; + + struct clk *clks[ADSP_SC58X_CLK_END]; + struct clk dummy, clkin0, clkin1; + + ret = dev_read_resource_byname(dev, "cgu0", &res); + if (ret) + return ret; + cgu0 = devm_ioremap(dev, res.start, resource_size(&res)); + + ret = dev_read_resource_byname(dev, "cgu1", &res); + if (ret) + return ret; + cgu1 = devm_ioremap(dev, res.start, resource_size(&res)); + + ret = dev_read_resource_byname(dev, "cdu", &res); + if (ret) + return ret; + cdu = devm_ioremap(dev, res.start, resource_size(&res)); + + // Input clock configuration + clk_get_by_name(dev, "dummy", &dummy); + clk_get_by_name(dev, "sys_clkin0", &clkin0); + clk_get_by_name(dev, "sys_clkin1", &clkin1); + + clks[ADSP_SC58X_CLK_DUMMY] = &dummy; + clks[ADSP_SC58X_CLK_SYS_CLKIN0] = &clkin0; + clks[ADSP_SC58X_CLK_SYS_CLKIN1] = &clkin1; + + clks[ADSP_SC58X_CLK_CGU1_IN] = clk_register_mux(NULL, "cgu1_in_sel", cgu1_in_sels, + 2, CLK_SET_RATE_PARENT, + cdu + CDU_CLKINSEL, 0, 1, 0); + + // CGU configuration and internal clocks + clks[ADSP_SC58X_CLK_CGU0_PLL_IN] = clk_register_divider(NULL, "cgu0_df", + "sys_clkin0", + CLK_SET_RATE_PARENT, + cgu0 + CGU_CTL, 0, 1, 0); + clks[ADSP_SC58X_CLK_CGU1_PLL_IN] = clk_register_divider(NULL, "cgu1_df", + "cgu1_in_sel", + CLK_SET_RATE_PARENT, + cgu1 + CGU_CTL, 0, 1, 0); + + // VCO output inside PLL + clks[ADSP_SC58X_CLK_CGU0_VCO_OUT] = sc5xx_cgu_pll("cgu0_vco", "cgu0_df", + cgu0 + CGU_CTL, CGU_MSEL_SHIFT, + CGU_MSEL_WIDTH, 0, false); + clks[ADSP_SC58X_CLK_CGU1_VCO_OUT] = sc5xx_cgu_pll("cgu1_vco", "cgu1_df", + cgu1 + CGU_CTL, CGU_MSEL_SHIFT, + CGU_MSEL_WIDTH, 0, false); + + // Final PLL output + clks[ADSP_SC58X_CLK_CGU0_PLLCLK] = clk_register_fixed_factor(NULL, "cgu0_pllclk", + "cgu0_vco", + CLK_SET_RATE_PARENT, + 1, 1); + clks[ADSP_SC58X_CLK_CGU1_PLLCLK] = clk_register_fixed_factor(NULL, "cgu1_pllclk", + "cgu1_vco", + CLK_SET_RATE_PARENT, + 1, 1); + + // Dividers from pll output + clks[ADSP_SC58X_CLK_CGU0_CDIV] = cgu_divider("cgu0_cdiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 0, 5, 0); + clks[ADSP_SC58X_CLK_CGU0_SYSCLK] = cgu_divider("sysclk_0", "cgu0_pllclk", + cgu0 + CGU_DIV, 8, 5, 0); + clks[ADSP_SC58X_CLK_CGU0_DDIV] = cgu_divider("cgu0_ddiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 16, 5, 0); + clks[ADSP_SC58X_CLK_CGU0_ODIV] = cgu_divider("cgu0_odiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 22, 7, 0); + clks[ADSP_SC58X_CLK_CGU0_S0SELDIV] = cgu_divider("cgu0_s0seldiv", "sysclk_0", + cgu0 + CGU_DIV, 5, 3, 0); + clks[ADSP_SC58X_CLK_CGU0_S1SELDIV] = cgu_divider("cgu0_s1seldiv", "sysclk_0", + cgu0 + CGU_DIV, 13, 3, 0); + + clks[ADSP_SC58X_CLK_CGU1_CDIV] = cgu_divider("cgu1_cdiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 0, 5, 0); + clks[ADSP_SC58X_CLK_CGU1_SYSCLK] = cgu_divider("sysclk_1", "cgu1_pllclk", + cgu1 + CGU_DIV, 8, 5, 0); + clks[ADSP_SC58X_CLK_CGU1_DDIV] = cgu_divider("cgu1_ddiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 16, 5, 0); + clks[ADSP_SC58X_CLK_CGU1_ODIV] = cgu_divider("cgu1_odiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 22, 7, 0); + clks[ADSP_SC58X_CLK_CGU1_S0SELDIV] = cgu_divider("cgu1_s0seldiv", "sysclk_1", + cgu1 + CGU_DIV, 5, 3, 0); + clks[ADSP_SC58X_CLK_CGU1_S1SELDIV] = cgu_divider("cgu1_s1seldiv", "sysclk_1", + cgu1 + CGU_DIV, 13, 3, 0); + + // Gates to enable CGU outputs + clks[ADSP_SC58X_CLK_CGU0_CCLK0] = cgu_gate("cclk0_0", "cgu0_cdiv", + cgu0 + CGU_CCBF_DIS, 0); + clks[ADSP_SC58X_CLK_CGU0_CCLK1] = cgu_gate("cclk1_0", "cgu0_cdiv", + cgu1 + CGU_CCBF_DIS, 1); + clks[ADSP_SC58X_CLK_CGU0_OCLK] = cgu_gate("oclk_0", "cgu0_odiv", + cgu0 + CGU_SCBF_DIS, 3); + clks[ADSP_SC58X_CLK_CGU0_DCLK] = cgu_gate("dclk_0", "cgu0_ddiv", + cgu0 + CGU_SCBF_DIS, 2); + clks[ADSP_SC58X_CLK_CGU0_SCLK1] = cgu_gate("sclk1_0", "cgu0_s1seldiv", + cgu0 + CGU_SCBF_DIS, 1); + clks[ADSP_SC58X_CLK_CGU0_SCLK0] = cgu_gate("sclk0_0", "cgu0_s0seldiv", + cgu0 + CGU_SCBF_DIS, 0); + + clks[ADSP_SC58X_CLK_CGU1_CCLK0] = cgu_gate("cclk0_1", "cgu1_cdiv", + cgu1 + CGU_CCBF_DIS, 0); + clks[ADSP_SC58X_CLK_CGU1_CCLK1] = cgu_gate("cclk1_1", "cgu1_cdiv", + cgu1 + CGU_CCBF_DIS, 1); + clks[ADSP_SC58X_CLK_CGU1_OCLK] = cgu_gate("oclk_1", "cgu1_odiv", + cgu1 + CGU_SCBF_DIS, 3); + clks[ADSP_SC58X_CLK_CGU1_DCLK] = cgu_gate("dclk_1", "cgu1_ddiv", + cgu1 + CGU_SCBF_DIS, 2); + clks[ADSP_SC58X_CLK_CGU1_SCLK1] = cgu_gate("sclk1_1", "cgu1_s1seldiv", + cgu1 + CGU_SCBF_DIS, 1); + clks[ADSP_SC58X_CLK_CGU1_SCLK0] = cgu_gate("sclk0_1", "cgu1_s0seldiv", + cgu1 + CGU_SCBF_DIS, 0); + + // Extra half rate clocks generated in the CDU + clks[ADSP_SC58X_CLK_OCLK0_HALF] = clk_register_fixed_factor(NULL, "oclk_0_half", + "oclk_0", + CLK_SET_RATE_PARENT, + 1, 2); + clks[ADSP_SC58X_CLK_CCLK1_1_HALF] = clk_register_fixed_factor(NULL, + "cclk1_1_half", + "cclk1_1", + CLK_SET_RATE_PARENT, + 1, 2); + + // CDU output muxes + clks[ADSP_SC58X_CLK_SHARC0_SEL] = cdu_mux("sharc0_sel", cdu + CDU_CFG0, + sharc0_sels); + clks[ADSP_SC58X_CLK_SHARC1_SEL] = cdu_mux("sharc1_sel", cdu + CDU_CFG1, + sharc1_sels); + clks[ADSP_SC58X_CLK_ARM_SEL] = cdu_mux("arm_sel", cdu + CDU_CFG2, arm_sels); + clks[ADSP_SC58X_CLK_CDU_DDR_SEL] = cdu_mux("cdu_ddr_sel", cdu + CDU_CFG3, + cdu_ddr_sels); + clks[ADSP_SC58X_CLK_CAN_SEL] = cdu_mux("can_sel", cdu + CDU_CFG4, can_sels); + clks[ADSP_SC58X_CLK_SPDIF_SEL] = cdu_mux("spdif_sel", cdu + CDU_CFG5, spdif_sels); + clks[ADSP_SC58X_CLK_RESERVED_SEL] = cdu_mux("reserved_sel", cdu + CDU_CFG6, + reserved_sels); + clks[ADSP_SC58X_CLK_GIGE_SEL] = cdu_mux("gige_sel", cdu + CDU_CFG7, gige_sels); + clks[ADSP_SC58X_CLK_LP_SEL] = cdu_mux("lp_sel", cdu + CDU_CFG8, lp_sels); + clks[ADSP_SC58X_CLK_SDIO_SEL] = cdu_mux("sdio_sel", cdu + CDU_CFG9, sdio_sels); + + // CDU output enable gates + clks[ADSP_SC58X_CLK_SHARC0] = cdu_gate("sharc0", "sharc0_sel", cdu + CDU_CFG0, + CLK_IS_CRITICAL); + clks[ADSP_SC58X_CLK_SHARC1] = cdu_gate("sharc1", "sharc1_sel", cdu + CDU_CFG1, + CLK_IS_CRITICAL); + clks[ADSP_SC58X_CLK_ARM] = cdu_gate("arm", "arm_sel", cdu + CDU_CFG2, + CLK_IS_CRITICAL); + clks[ADSP_SC58X_CLK_CDU_DDR] = cdu_gate("cdu_ddr", "cdu_ddr_sel", cdu + CDU_CFG3, + CLK_IS_CRITICAL); + clks[ADSP_SC58X_CLK_CAN] = cdu_gate("can", "can_sel", cdu + CDU_CFG4, 0); + clks[ADSP_SC58X_CLK_SPDIF] = cdu_gate("spdif", "spdif_sel", cdu + CDU_CFG5, 0); + clks[ADSP_SC58X_CLK_RESERVED] = cdu_gate("reserved", "reserved_sel", + cdu + CDU_CFG6, 0); + clks[ADSP_SC58X_CLK_GIGE] = cdu_gate("gige", "gige_sel", cdu + CDU_CFG7, 0); + clks[ADSP_SC58X_CLK_LP] = cdu_gate("lp", "lp_sel", cdu + CDU_CFG8, 0); + clks[ADSP_SC58X_CLK_SDIO] = cdu_gate("sdio", "sdio_sel", cdu + CDU_CFG9, 0); + + ret = cdu_check_clocks(clks, ARRAY_SIZE(clks)); + if (ret) + pr_err("CDU error detected\n"); + + return ret; +} + +static const struct udevice_id adi_sc58x_clk_ids[] = { + { .compatible = "adi,sc58x-clocks" }, + { }, +}; + +U_BOOT_DRIVER(adi_sc58x_clk) = { + .name = "clk_adi_sc58x", + .id = UCLASS_CLK, + .of_match = adi_sc58x_clk_ids, + .ops = &adi_clk_ops, + .probe = sc58x_clock_probe, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/drivers/clk/adi/clk-adi-sc594.c b/drivers/clk/adi/clk-adi-sc594.c new file mode 100644 index 0000000000..b248f8ea97 --- /dev/null +++ b/drivers/clk/adi/clk-adi-sc594.c @@ -0,0 +1,230 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Author: Greg Malysa greg.malysa@timesys.com + * + * Ported from Linux: Nathan Barrett-Morrison nathan.morrison@timesys.com + */ + +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <log.h> +#include <linux/types.h> +#include <linux/clk-provider.h> +#include <linux/ioport.h> +#include <linux/io.h> +#include <dt-bindings/clock/adi-sc5xx-clock.h> + +#include "clk.h" + +static const char * const cgu1_in_sels[] = {"sys_clkin0", "sys_clkin1"}; +static const char * const cgu0_s1sels[] = {"cgu0_s1seldiv", "cgu0_s1selexdiv"}; +static const char * const cgu1_s1sels[] = {"cgu1_s1seldiv", "cgu1_s1selexdiv"}; +static const char * const sharc0_sels[] = {"cclk0_0", "dummy", "dummy", "dummy"}; +static const char * const sharc1_sels[] = {"cclk0_0", "dummy", "dummy", "dummy"}; +static const char * const arm_sels[] = {"cclk1_0", "dummy", "dummy", "dummy"}; +static const char * const cdu_ddr_sels[] = {"dclk_0", "dclk_1", "dummy", "dummy"}; +static const char * const can_sels[] = {"oclk_0", "oclk_1", "dummy", "dummy"}; +static const char * const spdif_sels[] = {"sclk1_0", "dummy", "dummy", "dummy"}; +static const char * const spi_sels[] = {"sclk0_0", "oclk_0", "dummy", "dummy"}; +static const char * const gige_sels[] = {"sclk0_0", "sclk0_1", "cclk0_1", "dummy"}; +static const char * const lp_sels[] = {"oclk_0", "sclk0_0", "cclk0_1", "dummy"}; +static const char * const lpddr_sels[] = {"oclk_0", "dclk_0", "sysclkin_1", "dummy"}; +static const char * const ospi_sels[] = {"sysclk_0", "sclk0_0", "sclk1_1", "dummy"}; +static const char * const trace_sels[] = {"sclk0_0", "dummy", "dummy", "dummy"}; + +static int sc594_clock_probe(struct udevice *dev) +{ + void __iomem *cgu0; + void __iomem *cgu1; + void __iomem *cdu; + int ret; + struct resource res; + + struct clk *clks[ADSP_SC594_CLK_END]; + struct clk dummy, clkin0, clkin1; + + ret = dev_read_resource_byname(dev, "cgu0", &res); + if (ret) + return ret; + cgu0 = devm_ioremap(dev, res.start, resource_size(&res)); + + ret = dev_read_resource_byname(dev, "cgu1", &res); + if (ret) + return ret; + cgu1 = devm_ioremap(dev, res.start, resource_size(&res)); + + ret = dev_read_resource_byname(dev, "cdu", &res); + if (ret) + return ret; + cdu = devm_ioremap(dev, res.start, resource_size(&res)); + + // Input clock configuration + clk_get_by_name(dev, "dummy", &dummy); + clk_get_by_name(dev, "sys_clkin0", &clkin0); + clk_get_by_name(dev, "sys_clkin1", &clkin1); + + clks[ADSP_SC594_CLK_DUMMY] = &dummy; + clks[ADSP_SC594_CLK_SYS_CLKIN0] = &clkin0; + clks[ADSP_SC594_CLK_SYS_CLKIN1] = &clkin1; + clks[ADSP_SC594_CLK_CGU1_IN] = clk_register_mux(NULL, "cgu1_in_sel", cgu1_in_sels, + 2, CLK_SET_RATE_PARENT, + cdu + CDU_CLKINSEL, 0, 1, 0); + + // CGU configuration and internal clocks + clks[ADSP_SC594_CLK_CGU0_PLL_IN] = clk_register_divider(NULL, "cgu0_df", + "sys_clkin0", + CLK_SET_RATE_PARENT, + cgu0 + CGU_CTL, 0, 1, 0); + clks[ADSP_SC594_CLK_CGU1_PLL_IN] = clk_register_divider(NULL, "cgu1_df", + "cgu1_in_sel", + CLK_SET_RATE_PARENT, + cgu1 + CGU_CTL, 0, 1, 0); + + // VCO output inside PLL + clks[ADSP_SC594_CLK_CGU0_VCO_OUT] = sc5xx_cgu_pll("cgu0_vco", "cgu0_df", + cgu0 + CGU_CTL, CGU_MSEL_SHIFT, + CGU_MSEL_WIDTH, 0, false); + clks[ADSP_SC594_CLK_CGU1_VCO_OUT] = sc5xx_cgu_pll("cgu1_vco", "cgu1_df", + cgu1 + CGU_CTL, CGU_MSEL_SHIFT, + CGU_MSEL_WIDTH, 0, false); + + // Final PLL output + clks[ADSP_SC594_CLK_CGU0_PLLCLK] = clk_register_fixed_factor(NULL, "cgu0_pllclk", + "cgu0_vco", + CLK_SET_RATE_PARENT, + 1, 1); + clks[ADSP_SC594_CLK_CGU1_PLLCLK] = clk_register_fixed_factor(NULL, "cgu1_pllclk", + "cgu1_vco", + CLK_SET_RATE_PARENT, + 1, 1); + + // Dividers from pll output + clks[ADSP_SC594_CLK_CGU0_CDIV] = cgu_divider("cgu0_cdiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 0, 5, 0); + clks[ADSP_SC594_CLK_CGU0_SYSCLK] = cgu_divider("sysclk_0", "cgu0_pllclk", + cgu0 + CGU_DIV, 8, 5, 0); + clks[ADSP_SC594_CLK_CGU0_DDIV] = cgu_divider("cgu0_ddiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 16, 5, 0); + clks[ADSP_SC594_CLK_CGU0_ODIV] = cgu_divider("cgu0_odiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 22, 7, 0); + clks[ADSP_SC594_CLK_CGU0_S0SELDIV] = cgu_divider("cgu0_s0seldiv", "sysclk_0", + cgu0 + CGU_DIV, 5, 3, 0); + clks[ADSP_SC594_CLK_CGU0_S1SELDIV] = cgu_divider("cgu0_s1seldiv", "sysclk_0", + cgu0 + CGU_DIV, 13, 3, 0); + clks[ADSP_SC594_CLK_CGU0_S1SELEXDIV] = cgu_divider("cgu0_s1selexdiv", + "cgu0_pllclk", + cgu0 + CGU_DIVEX, 16, 8, 0); + clks[ADSP_SC594_CLK_CGU0_S1SEL] = clk_register_mux(NULL, "cgu0_sclk1sel", + cgu0_s1sels, 2, + CLK_SET_RATE_PARENT, + cgu0 + CGU_CTL, 17, 1, 0); + + clks[ADSP_SC594_CLK_CGU1_CDIV] = cgu_divider("cgu1_cdiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 0, 5, 0); + clks[ADSP_SC594_CLK_CGU1_SYSCLK] = cgu_divider("sysclk_1", "cgu1_pllclk", + cgu1 + CGU_DIV, 8, 5, 0); + clks[ADSP_SC594_CLK_CGU1_DDIV] = cgu_divider("cgu1_ddiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 16, 5, 0); + clks[ADSP_SC594_CLK_CGU1_ODIV] = cgu_divider("cgu1_odiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 22, 7, 0); + clks[ADSP_SC594_CLK_CGU1_S0SELDIV] = cgu_divider("cgu1_s0seldiv", "sysclk_1", + cgu1 + CGU_DIV, 5, 3, 0); + clks[ADSP_SC594_CLK_CGU1_S1SELDIV] = cgu_divider("cgu1_s1seldiv", "sysclk_1", + cgu1 + CGU_DIV, 13, 3, 0); + clks[ADSP_SC594_CLK_CGU1_S1SELEXDIV] = cgu_divider("cgu1_s1selexdiv", + "cgu1_pllclk", + cgu1 + CGU_DIVEX, 16, 8, 0); + clks[ADSP_SC594_CLK_CGU1_S1SEL] = clk_register_mux(NULL, "cgu1_sclk1sel", + cgu1_s1sels, 2, + CLK_SET_RATE_PARENT, + cgu1 + CGU_CTL, 17, 1, 0); + + // Gates to enable CGU outputs + clks[ADSP_SC594_CLK_CGU0_CCLK0] = cgu_gate("cclk0_0", "cgu0_cdiv", + cgu0 + CGU_CCBF_DIS, 0); + clks[ADSP_SC594_CLK_CGU0_CCLK1] = cgu_gate("cclk1_0", "cgu0_cdiv", + cgu1 + CGU_CCBF_DIS, 1); + clks[ADSP_SC594_CLK_CGU0_OCLK] = cgu_gate("oclk_0", "cgu0_odiv", + cgu0 + CGU_SCBF_DIS, 3); + clks[ADSP_SC594_CLK_CGU0_DCLK] = cgu_gate("dclk_0", "cgu0_ddiv", + cgu0 + CGU_SCBF_DIS, 2); + clks[ADSP_SC594_CLK_CGU0_SCLK1] = cgu_gate("sclk1_0", "cgu0_sclk1sel", + cgu0 + CGU_SCBF_DIS, 1); + clks[ADSP_SC594_CLK_CGU0_SCLK0] = cgu_gate("sclk0_0", "cgu0_s0seldiv", + cgu0 + CGU_SCBF_DIS, 0); + + clks[ADSP_SC594_CLK_CGU1_CCLK0] = cgu_gate("cclk0_1", "cgu1_cdiv", + cgu1 + CGU_CCBF_DIS, 0); + clks[ADSP_SC594_CLK_CGU1_CCLK1] = cgu_gate("cclk1_1", "cgu1_cdiv", + cgu1 + CGU_CCBF_DIS, 1); + clks[ADSP_SC594_CLK_CGU1_OCLK] = cgu_gate("oclk_1", "cgu1_odiv", + cgu1 + CGU_SCBF_DIS, 3); + clks[ADSP_SC594_CLK_CGU1_DCLK] = cgu_gate("dclk_1", "cgu1_ddiv", + cgu1 + CGU_SCBF_DIS, 2); + clks[ADSP_SC594_CLK_CGU1_SCLK1] = cgu_gate("sclk1_1", "cgu1_sclk1sel", + cgu1 + CGU_SCBF_DIS, 1); + clks[ADSP_SC594_CLK_CGU1_SCLK0] = cgu_gate("sclk0_1", "cgu1_s0seldiv", + cgu1 + CGU_SCBF_DIS, 0); + + // CDU output muxes + clks[ADSP_SC594_CLK_SHARC0_SEL] = cdu_mux("sharc0_sel", cdu + CDU_CFG0, + sharc0_sels); + clks[ADSP_SC594_CLK_SHARC1_SEL] = cdu_mux("sharc1_sel", cdu + CDU_CFG1, + sharc1_sels); + clks[ADSP_SC594_CLK_ARM_SEL] = cdu_mux("arm_sel", cdu + CDU_CFG2, arm_sels); + clks[ADSP_SC594_CLK_CDU_DDR_SEL] = cdu_mux("cdu_ddr_sel", cdu + CDU_CFG3, + cdu_ddr_sels); + clks[ADSP_SC594_CLK_CAN_SEL] = cdu_mux("can_sel", cdu + CDU_CFG4, can_sels); + clks[ADSP_SC594_CLK_SPDIF_SEL] = cdu_mux("spdif_sel", cdu + CDU_CFG5, spdif_sels); + clks[ADSP_SC594_CLK_RESERVED_SEL] = cdu_mux("spi_sel", cdu + CDU_CFG6, spi_sels); + clks[ADSP_SC594_CLK_GIGE_SEL] = cdu_mux("gige_sel", cdu + CDU_CFG7, gige_sels); + clks[ADSP_SC594_CLK_LP_SEL] = cdu_mux("lp_sel", cdu + CDU_CFG8, lp_sels); + clks[ADSP_SC594_CLK_LPDDR_SEL] = cdu_mux("lpddr_sel", cdu + CDU_CFG9, lpddr_sels); + clks[ADSP_SC594_CLK_OSPI_SEL] = cdu_mux("ospi_sel", cdu + CDU_CFG10, + ospi_sels); + clks[ADSP_SC594_CLK_TRACE_SEL] = cdu_mux("trace_sel", cdu + CDU_CFG12, + trace_sels); + + // CDU output enable gates + clks[ADSP_SC594_CLK_SHARC0] = cdu_gate("sharc0", "sharc0_sel", + cdu + CDU_CFG0, CLK_IS_CRITICAL); + clks[ADSP_SC594_CLK_SHARC1] = cdu_gate("sharc1", "sharc1_sel", + cdu + CDU_CFG1, CLK_IS_CRITICAL); + clks[ADSP_SC594_CLK_ARM] = cdu_gate("arm", "arm_sel", cdu + CDU_CFG2, + CLK_IS_CRITICAL); + clks[ADSP_SC594_CLK_CDU_DDR] = cdu_gate("cdu_ddr", "cdu_ddr_sel", + cdu + CDU_CFG3, CLK_IS_CRITICAL); + clks[ADSP_SC594_CLK_CAN] = cdu_gate("can", "can_sel", cdu + CDU_CFG4, 0); + clks[ADSP_SC594_CLK_SPDIF] = cdu_gate("spdif", "spdif_sel", cdu + CDU_CFG5, 0); + clks[ADSP_SC594_CLK_SPI] = cdu_gate("spi", "spi_sel", cdu + CDU_CFG6, 0); + clks[ADSP_SC594_CLK_GIGE] = cdu_gate("gige", "gige_sel", cdu + CDU_CFG7, 0); + clks[ADSP_SC594_CLK_LP] = cdu_gate("lp", "lp_sel", cdu + CDU_CFG8, 0); + clks[ADSP_SC594_CLK_LPDDR] = cdu_gate("lpddr", "lpddr_sel", cdu + CDU_CFG9, 0); + clks[ADSP_SC594_CLK_OSPI] = cdu_gate("ospi", "ospi_sel", cdu + CDU_CFG10, 0); + clks[ADSP_SC594_CLK_TRACE] = cdu_gate("trace", "trace_sel", cdu + CDU_CFG12, 0); + + ret = cdu_check_clocks(clks, ARRAY_SIZE(clks)); + if (ret) + pr_err("CDU error detected\n"); + + return ret; +} + +static const struct udevice_id adi_sc594_clk_ids[] = { + { .compatible = "adi,sc594-clocks" }, + { }, +}; + +U_BOOT_DRIVER(adi_sc594_clk) = { + .name = "clk_adi_sc594", + .id = UCLASS_CLK, + .of_match = adi_sc594_clk_ids, + .ops = &adi_clk_ops, + .probe = sc594_clock_probe, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/drivers/clk/adi/clk-adi-sc598.c b/drivers/clk/adi/clk-adi-sc598.c new file mode 100644 index 0000000000..7b63ba6b60 --- /dev/null +++ b/drivers/clk/adi/clk-adi-sc598.c @@ -0,0 +1,307 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Author: Greg Malysa greg.malysa@timesys.com + * + * Ported from Linux: Nathan Barrett-Morrison nathan.morrison@timesys.com + */ + +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <log.h> +#include <linux/types.h> +#include <linux/clk-provider.h> +#include <linux/ioport.h> +#include <linux/io.h> +#include <dt-bindings/clock/adi-sc5xx-clock.h> + +#include "clk.h" + +static const char * const cgu1_in_sels[] = {"sys_clkin0", "sys_clkin1"}; +static const char * const cgu0_s1sels[] = {"cgu0_s1seldiv", "cgu0_s1selexdiv"}; +static const char * const cgu1_s0sels[] = {"cgu1_s0seldiv", "cgu1_s0selexdiv"}; +static const char * const cgu1_s1sels[] = {"cgu1_s1seldiv", "cgu1_s1selexdiv"}; +static const char * const sharc0_sels[] = {"cclk0_0", "dummy", "dummy", "dummy"}; +static const char * const sharc1_sels[] = {"cclk0_0", "dummy", "dummy", "dummy"}; +static const char * const arm_sels[] = {"dummy", "dummy", "cclk2_0", "cclk2_1"}; +static const char * const cdu_ddr_sels[] = {"dclk_0", "dclk_1", "dummy", "dummy"}; +static const char * const can_sels[] = {"dummy", "oclk_1", "dummy", "dummy"}; +static const char * const spdif_sels[] = {"sclk1_0", "dummy", "dummy", "dummy"}; +static const char * const spi_sels[] = {"sclk0_0", "oclk_0", "dummy", "dummy"}; +static const char * const gige_sels[] = {"sclk0_0", "sclk0_1", "dummy", "dummy"}; +static const char * const lp_sels[] = {"oclk_0", "sclk0_0", "cclk0_1", "dummy"}; +static const char * const lp_ddr_sels[] = {"oclk_0", "dclk_0", "sysclk_1", "dummy"}; +static const char * const ospi_refclk_sels[] = {"sysclk_0", "sclk0_0", "sclk1_1", + "dummy"}; +static const char * const trace_sels[] = {"sclk0_0", "dummy", "dummy", "dummy"}; +static const char * const emmc_sels[] = {"oclk_0", "sclk0_1", "dclk_0_half", + "dclk_1_half"}; +static const char * const emmc_timer_sels[] = {"dummy", "sclk1_1_half", "dummy", + "dummy"}; +static const char * const ddr_sels[] = {"cdu_ddr", "3pll_ddiv"}; + +static int sc598_clock_probe(struct udevice *dev) +{ + void __iomem *cgu0; + void __iomem *cgu1; + void __iomem *cdu; + void __iomem *pll3; + int ret; + struct resource res; + + struct clk *clks[ADSP_SC598_CLK_END]; + struct clk dummy, clkin0, clkin1; + + ret = dev_read_resource_byname(dev, "cgu0", &res); + if (ret) + return ret; + cgu0 = devm_ioremap(dev, res.start, resource_size(&res)); + + ret = dev_read_resource_byname(dev, "cgu1", &res); + if (ret) + return ret; + cgu1 = devm_ioremap(dev, res.start, resource_size(&res)); + + ret = dev_read_resource_byname(dev, "cdu", &res); + if (ret) + return ret; + cdu = devm_ioremap(dev, res.start, resource_size(&res)); + + ret = dev_read_resource_byname(dev, "pll3", &res); + if (ret) + return ret; + pll3 = devm_ioremap(dev, res.start, resource_size(&res)); + + // We only access this one register for pll3 + pll3 = pll3 + PLL3_OFFSET; + + // Input clock configuration + clk_get_by_name(dev, "dummy", &dummy); + clk_get_by_name(dev, "sys_clkin0", &clkin0); + clk_get_by_name(dev, "sys_clkin1", &clkin1); + + clks[ADSP_SC598_CLK_DUMMY] = &dummy; + clks[ADSP_SC598_CLK_SYS_CLKIN0] = &clkin0; + clks[ADSP_SC598_CLK_SYS_CLKIN1] = &clkin1; + + clks[ADSP_SC598_CLK_CGU1_IN] = clk_register_mux(NULL, "cgu1_in_sel", cgu1_in_sels, + 2, CLK_SET_RATE_PARENT, + cdu + CDU_CLKINSEL, 0, 1, 0); + + // 3rd pll reuses cgu1 clk in selection, feeds directly into 3pll df + // changing the cgu1 in sel mux will affect 3pll so reuse the same clocks + + // CGU configuration and internal clocks + clks[ADSP_SC598_CLK_CGU0_PLL_IN] = clk_register_divider(NULL, "cgu0_df", + "sys_clkin0", + CLK_SET_RATE_PARENT, + cgu0 + CGU_CTL, 0, 1, 0); + clks[ADSP_SC598_CLK_CGU1_PLL_IN] = clk_register_divider(NULL, "cgu1_df", + "cgu1_in_sel", + CLK_SET_RATE_PARENT, + cgu1 + CGU_CTL, 0, 1, 0); + clks[ADSP_SC598_CLK_3PLL_PLL_IN] = clk_register_divider(NULL, "3pll_df", + "cgu1_in_sel", + CLK_SET_RATE_PARENT, + pll3, 3, 1, 0); + + // VCO output inside PLL + clks[ADSP_SC598_CLK_CGU0_VCO_OUT] = sc5xx_cgu_pll("cgu0_vco", "cgu0_df", + cgu0 + CGU_CTL, CGU_MSEL_SHIFT, + CGU_MSEL_WIDTH, 0, true); + clks[ADSP_SC598_CLK_CGU1_VCO_OUT] = sc5xx_cgu_pll("cgu1_vco", "cgu1_df", + cgu1 + CGU_CTL, CGU_MSEL_SHIFT, + CGU_MSEL_WIDTH, 0, true); + clks[ADSP_SC598_CLK_3PLL_VCO_OUT] = sc5xx_cgu_pll("3pll_vco", "3pll_df", + pll3, PLL3_MSEL_SHIFT, + PLL3_MSEL_WIDTH, 1, true); + + // Final PLL output + clks[ADSP_SC598_CLK_CGU0_PLLCLK] = clk_register_fixed_factor(NULL, "cgu0_pllclk", + "cgu0_vco", + CLK_SET_RATE_PARENT, + 1, 2); + clks[ADSP_SC598_CLK_CGU1_PLLCLK] = clk_register_fixed_factor(NULL, "cgu1_pllclk", + "cgu1_vco", + CLK_SET_RATE_PARENT, + 1, 2); + clks[ADSP_SC598_CLK_3PLL_PLLCLK] = clk_register_fixed_factor(NULL, "3pll_pllclk", + "3pll_vco", + CLK_SET_RATE_PARENT, + 1, 2); + + // Dividers from pll output + clks[ADSP_SC598_CLK_CGU0_CDIV] = cgu_divider("cgu0_cdiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 0, 5, 0); + clks[ADSP_SC598_CLK_CGU0_SYSCLK] = cgu_divider("sysclk_0", "cgu0_pllclk", + cgu0 + CGU_DIV, 8, 5, 0); + clks[ADSP_SC598_CLK_CGU0_DDIV] = cgu_divider("cgu0_ddiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 16, 5, 0); + clks[ADSP_SC598_CLK_CGU0_ODIV] = cgu_divider("cgu0_odiv", "cgu0_pllclk", + cgu0 + CGU_DIV, 22, 7, 0); + clks[ADSP_SC598_CLK_CGU0_S0SELDIV] = cgu_divider("cgu0_s0seldiv", "sysclk_0", + cgu0 + CGU_DIV, 5, 3, 0); + clks[ADSP_SC598_CLK_CGU0_S1SELDIV] = cgu_divider("cgu0_s1seldiv", "sysclk_0", + cgu0 + CGU_DIV, 13, 3, 0); + clks[ADSP_SC598_CLK_CGU0_S1SELEXDIV] = cgu_divider("cgu0_s1selexdiv", + "cgu0_pllclk", + cgu0 + CGU_DIVEX, 16, 8, 0); + clks[ADSP_SC598_CLK_CGU0_S1SEL] = clk_register_mux(NULL, "cgu0_sclk1sel", + cgu0_s1sels, 2, + CLK_SET_RATE_PARENT, + cgu0 + CGU_CTL, 17, 1, 0); + clks[ADSP_SC598_CLK_CGU0_CCLK2] = clk_register_fixed_factor(NULL, "cclk2_0", + "cgu0_vco", + CLK_SET_RATE_PARENT, + 1, 3); + + clks[ADSP_SC598_CLK_CGU1_CDIV] = cgu_divider("cgu1_cdiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 0, 5, 0); + clks[ADSP_SC598_CLK_CGU1_SYSCLK] = cgu_divider("sysclk_1", "cgu1_pllclk", + cgu1 + CGU_DIV, 8, 5, 0); + clks[ADSP_SC598_CLK_CGU1_DDIV] = cgu_divider("cgu1_ddiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 16, 5, 0); + clks[ADSP_SC598_CLK_CGU1_ODIV] = cgu_divider("cgu1_odiv", "cgu1_pllclk", + cgu1 + CGU_DIV, 22, 7, 0); + clks[ADSP_SC598_CLK_CGU1_S0SELDIV] = cgu_divider("cgu1_s0seldiv", "sysclk_1", + cgu1 + CGU_DIV, 5, 3, 0); + clks[ADSP_SC598_CLK_CGU1_S1SELDIV] = cgu_divider("cgu1_s1seldiv", "sysclk_1", + cgu1 + CGU_DIV, 13, 3, 0); + clks[ADSP_SC598_CLK_CGU1_S0SELEXDIV] = cgu_divider("cgu1_s0selexdiv", + "cgu1_pllclk", + cgu1 + CGU_DIVEX, 0, 8, 0); + clks[ADSP_SC598_CLK_CGU1_S1SELEXDIV] = cgu_divider("cgu1_s1selexdiv", + "cgu1_pllclk", + cgu1 + CGU_DIVEX, 16, 8, 0); + clks[ADSP_SC598_CLK_CGU1_S0SEL] = clk_register_mux(NULL, "cgu1_sclk0sel", + cgu1_s0sels, 2, + CLK_SET_RATE_PARENT, + cgu1 + CGU_CTL, 16, 1, 0); + clks[ADSP_SC598_CLK_CGU1_S1SEL] = clk_register_mux(NULL, "cgu1_sclk1sel", + cgu1_s1sels, 2, + CLK_SET_RATE_PARENT, + cgu1 + CGU_CTL, 17, 1, 0); + clks[ADSP_SC598_CLK_CGU1_CCLK2] = clk_register_fixed_factor(NULL, "cclk2_1", + "cgu1_vco", + CLK_SET_RATE_PARENT, + 1, 3); + + clks[ADSP_SC598_CLK_3PLL_DDIV] = clk_register_divider(NULL, "3pll_ddiv", + "3pll_pllclk", + CLK_SET_RATE_PARENT, pll3, + 12, 5, 0); + + // Gates to enable CGU outputs + clks[ADSP_SC598_CLK_CGU0_CCLK0] = cgu_gate("cclk0_0", "cgu0_cdiv", + cgu0 + CGU_CCBF_DIS, 0); + clks[ADSP_SC598_CLK_CGU0_OCLK] = cgu_gate("oclk_0", "cgu0_odiv", + cgu0 + CGU_SCBF_DIS, 3); + clks[ADSP_SC598_CLK_CGU0_DCLK] = cgu_gate("dclk_0", "cgu0_ddiv", + cgu0 + CGU_SCBF_DIS, 2); + clks[ADSP_SC598_CLK_CGU0_SCLK1] = cgu_gate("sclk1_0", "cgu0_sclk1sel", + cgu0 + CGU_SCBF_DIS, 1); + clks[ADSP_SC598_CLK_CGU0_SCLK0] = cgu_gate("sclk0_0", "cgu0_s0seldiv", + cgu0 + CGU_SCBF_DIS, 0); + + clks[ADSP_SC598_CLK_CGU1_CCLK0] = cgu_gate("cclk0_1", "cgu1_cdiv", + cgu1 + CGU_CCBF_DIS, 0); + clks[ADSP_SC598_CLK_CGU1_OCLK] = cgu_gate("oclk_1", "cgu1_odiv", + cgu1 + CGU_SCBF_DIS, 3); + clks[ADSP_SC598_CLK_CGU1_DCLK] = cgu_gate("dclk_1", "cgu1_ddiv", + cgu1 + CGU_SCBF_DIS, 2); + clks[ADSP_SC598_CLK_CGU1_SCLK1] = cgu_gate("sclk1_1", "cgu1_sclk1sel", + cgu1 + CGU_SCBF_DIS, 1); + clks[ADSP_SC598_CLK_CGU1_SCLK0] = cgu_gate("sclk0_1", "cgu1_sclk0sel", + cgu1 + CGU_SCBF_DIS, 0); + + // Extra half rate clocks generated in the CDU + clks[ADSP_SC598_CLK_DCLK0_HALF] = clk_register_fixed_factor(NULL, "dclk_0_half", + "dclk_0", + CLK_SET_RATE_PARENT, + 1, 2); + clks[ADSP_SC598_CLK_DCLK1_HALF] = clk_register_fixed_factor(NULL, "dclk_1_half", + "dclk_1", + CLK_SET_RATE_PARENT, + 1, 2); + clks[ADSP_SC598_CLK_CGU1_SCLK1_HALF] = clk_register_fixed_factor(NULL, + "sclk1_1_half", + "sclk1_1", + CLK_SET_RATE_PARENT, + 1, 2); + + // CDU output muxes + clks[ADSP_SC598_CLK_SHARC0_SEL] = cdu_mux("sharc0_sel", cdu + CDU_CFG0, + sharc0_sels); + clks[ADSP_SC598_CLK_SHARC1_SEL] = cdu_mux("sharc1_sel", cdu + CDU_CFG1, + sharc1_sels); + clks[ADSP_SC598_CLK_ARM_SEL] = cdu_mux("arm_sel", cdu + CDU_CFG2, arm_sels); + clks[ADSP_SC598_CLK_CDU_DDR_SEL] = cdu_mux("cdu_ddr_sel", cdu + CDU_CFG3, + cdu_ddr_sels); + clks[ADSP_SC598_CLK_CAN_SEL] = cdu_mux("can_sel", cdu + CDU_CFG4, can_sels); + clks[ADSP_SC598_CLK_SPDIF_SEL] = cdu_mux("spdif_sel", cdu + CDU_CFG5, spdif_sels); + clks[ADSP_SC598_CLK_SPI_SEL] = cdu_mux("spi_sel", cdu + CDU_CFG6, spi_sels); + clks[ADSP_SC598_CLK_GIGE_SEL] = cdu_mux("gige_sel", cdu + CDU_CFG7, gige_sels); + clks[ADSP_SC598_CLK_LP_SEL] = cdu_mux("lp_sel", cdu + CDU_CFG8, lp_sels); + clks[ADSP_SC598_CLK_LP_DDR_SEL] = cdu_mux("lp_ddr_sel", cdu + CDU_CFG9, + lp_ddr_sels); + clks[ADSP_SC598_CLK_OSPI_REFCLK_SEL] = cdu_mux("ospi_refclk_sel", cdu + CDU_CFG10, + ospi_refclk_sels); + clks[ADSP_SC598_CLK_TRACE_SEL] = cdu_mux("trace_sel", cdu + CDU_CFG12, + trace_sels); + clks[ADSP_SC598_CLK_EMMC_SEL] = cdu_mux("emmc_sel", cdu + CDU_CFG13, emmc_sels); + clks[ADSP_SC598_CLK_EMMC_TIMER_QMC_SEL] = cdu_mux("emmc_timer_qmc_sel", + cdu + CDU_CFG14, + emmc_timer_sels); + + // CDU output enable gates + clks[ADSP_SC598_CLK_SHARC0] = cdu_gate("sharc0", "sharc0_sel", cdu + CDU_CFG0, + CLK_IS_CRITICAL); + clks[ADSP_SC598_CLK_SHARC1] = cdu_gate("sharc1", "sharc1_sel", cdu + CDU_CFG1, + CLK_IS_CRITICAL); + clks[ADSP_SC598_CLK_ARM] = cdu_gate("arm", "arm_sel", cdu + CDU_CFG2, + CLK_IS_CRITICAL); + clks[ADSP_SC598_CLK_CDU_DDR] = cdu_gate("cdu_ddr", "cdu_ddr_sel", cdu + CDU_CFG3, + 0); + clks[ADSP_SC598_CLK_CAN] = cdu_gate("can", "can_sel", cdu + CDU_CFG4, 0); + clks[ADSP_SC598_CLK_SPDIF] = cdu_gate("spdif", "spdif_sel", cdu + CDU_CFG5, 0); + clks[ADSP_SC598_CLK_SPI] = cdu_gate("spi", "spi_sel", cdu + CDU_CFG6, 0); + clks[ADSP_SC598_CLK_GIGE] = cdu_gate("gige", "gige_sel", cdu + CDU_CFG7, 0); + clks[ADSP_SC598_CLK_LP] = cdu_gate("lp", "lp_sel", cdu + CDU_CFG8, 0); + clks[ADSP_SC598_CLK_LP_DDR] = cdu_gate("lp_ddr", "lp_ddr_sel", cdu + CDU_CFG9, 0); + clks[ADSP_SC598_CLK_OSPI_REFCLK] = cdu_gate("ospi_refclk", "ospi_refclk_sel", + cdu + CDU_CFG10, 0); + clks[ADSP_SC598_CLK_TRACE] = cdu_gate("trace", "trace_sel", cdu + CDU_CFG12, 0); + clks[ADSP_SC598_CLK_EMMC] = cdu_gate("emmc", "emmc_sel", cdu + CDU_CFG13, 0); + clks[ADSP_SC598_CLK_EMMC_TIMER_QMC] = cdu_gate("emmc_timer_qmc", + "emmc_timer_qmc_sel", + cdu + CDU_CFG14, 0); + + // Dedicated DDR output mux + clks[ADSP_SC598_CLK_DDR] = clk_register_mux(NULL, "ddr", ddr_sels, 2, + CLK_SET_RATE_PARENT | CLK_IS_CRITICAL, + pll3, 11, 1, 0); + + ret = cdu_check_clocks(clks, ARRAY_SIZE(clks)); + if (ret) + pr_err("CDU error detected\n"); + + return ret; +} + +static const struct udevice_id adi_sc598_clk_ids[] = { + { .compatible = "adi,sc598-clocks" }, + { }, +}; + +U_BOOT_DRIVER(adi_sc598_clk) = { + .name = "clk_adi_sc598", + .id = UCLASS_CLK, + .of_match = adi_sc598_clk_ids, + .ops = &adi_clk_ops, + .probe = sc598_clock_probe, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/drivers/clk/adi/clk-shared.c b/drivers/clk/adi/clk-shared.c new file mode 100644 index 0000000000..dcadcafa9d --- /dev/null +++ b/drivers/clk/adi/clk-shared.c @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Author: Greg Malysa greg.malysa@timesys.com + */ + +#include "clk.h" + +static ulong adi_get_rate(struct clk *clk) +{ + struct clk *c; + int ret; + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + return clk_get_rate(c); +} + +static ulong adi_set_rate(struct clk *clk, ulong rate) +{ + //Not yet implemented + return 0; +} + +static int adi_enable(struct clk *clk) +{ + //Not yet implemented + return 0; +} + +static int adi_disable(struct clk *clk) +{ + //Not yet implemented + return 0; +} + +const struct clk_ops adi_clk_ops = { + .set_rate = adi_set_rate, + .get_rate = adi_get_rate, + .enable = adi_enable, + .disable = adi_disable, +}; + diff --git a/drivers/clk/adi/clk.h b/drivers/clk/adi/clk.h new file mode 100644 index 0000000000..7cceda412a --- /dev/null +++ b/drivers/clk/adi/clk.h @@ -0,0 +1,122 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Author: Greg Malysa greg.malysa@timesys.com + * + * Ported from Linux: Nathan Barrett-Morrison nathan.morrison@timesys.com + */ + +#ifndef CLK_ADI_CLK_H +#define CLK_ADI_CLK_H + +#include <linux/types.h> +#include <linux/clk-provider.h> + +#define CGU_CTL 0x00 +#define CGU_PLLCTL 0x04 +#define CGU_STAT 0x08 +#define CGU_DIV 0x0C +#define CGU_CLKOUTSEL 0x10 +#define CGU_OSCWDCTL 0x14 +#define CGU_TSCTL 0x18 +#define CGU_TSVALUE0 0x1C +#define CGU_TSVALUE1 0x20 +#define CGU_TSCOUNT0 0x24 +#define CGU_TSCOUNT1 0x28 +#define CGU_CCBF_DIS 0x2C +#define CGU_CCBF_STAT 0x30 +#define CGU_SCBF_DIS 0x38 +#define CGU_SCBF_STAT 0x3C +#define CGU_DIVEX 0x40 +#define CGU_REVID 0x48 + +#define CDU_CFG0 0x00 +#define CDU_CFG1 0x04 +#define CDU_CFG2 0x08 +#define CDU_CFG3 0x0C +#define CDU_CFG4 0x10 +#define CDU_CFG5 0x14 +#define CDU_CFG6 0x18 +#define CDU_CFG7 0x1C +#define CDU_CFG8 0x20 +#define CDU_CFG9 0x24 +#define CDU_CFG10 0x28 +#define CDU_CFG11 0x2C +#define CDU_CFG12 0x30 +#define CDU_CFG13 0x34 +#define CDU_CFG14 0x38 + +#define PLL3_OFFSET 0x2c + +#define CDU_CLKINSEL 0x44 + +#define CGU_MSEL_SHIFT 8 +#define CGU_MSEL_WIDTH 7 + +#define PLL3_MSEL_SHIFT 4 +#define PLL3_MSEL_WIDTH 7 + +#define CDU_MUX_SIZE 4 +#define CDU_MUX_SHIFT 1 +#define CDU_MUX_WIDTH 2 +#define CDU_EN_BIT 0 + +extern const struct clk_ops adi_clk_ops; + +struct clk *sc5xx_cgu_pll(const char *name, const char *parent_name, + void __iomem *base, u8 shift, u8 width, u32 m_offset, bool half_m); + +/** + * All CDU clock muxes are the same size + */ +static inline struct clk *cdu_mux(const char *name, void __iomem *reg, + const char * const *parents) +{ + return clk_register_mux(NULL, name, parents, CDU_MUX_SIZE, + CLK_SET_RATE_PARENT, reg, CDU_MUX_SHIFT, CDU_MUX_WIDTH, 0); +} + +static inline struct clk *cgu_divider(const char *name, const char *parent, + void __iomem *reg, u8 shift, u8 width, u8 extra_flags) +{ + return clk_register_divider(NULL, name, parent, CLK_SET_RATE_PARENT, + reg, shift, width, CLK_DIVIDER_MAX_AT_ZERO | extra_flags); +} + +static inline struct clk *cdu_gate(const char *name, const char *parent, + void __iomem *reg, u32 flags) +{ + return clk_register_gate(NULL, name, parent, CLK_SET_RATE_PARENT | flags, + reg, CDU_EN_BIT, 0, NULL); +} + +static inline struct clk *cgu_gate(const char *name, const char *parent, + void __iomem *reg, u8 bit) +{ + return clk_register_gate(NULL, name, parent, CLK_SET_RATE_PARENT, reg, bit, + CLK_GATE_SET_TO_DISABLE, NULL); +} + +static inline int cdu_check_clocks(struct clk *clks[], size_t count) +{ + size_t i; + + for (i = 0; i < count; ++i) { + if (clks[i]) { + if (IS_ERR(clks[i])) { + pr_err("Clock %zu failed to register: %ld\n", i, PTR_ERR(clks[i])); + return PTR_ERR(clks[i]); + } + clks[i]->id = i; + } else { + pr_err("ADI Clock framework: Null pointer detected on clock %zu\n", i); + } + } + + return 0; +} + +#endif diff --git a/include/dt-bindings/clock/adi-sc5xx-clock.h b/include/dt-bindings/clock/adi-sc5xx-clock.h new file mode 100644 index 0000000000..4a5373d114 --- /dev/null +++ b/include/dt-bindings/clock/adi-sc5xx-clock.h @@ -0,0 +1,271 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + * + */ + +#ifndef DT_BINDINGS_CLOCK_ADI_SC5XX_CLOCK_H +#define DT_BINDINGS_CLOCK_ADI_SC5XX_CLOCK_H + +//ADSP-SC594 +#define ADSP_SC594_CLK_DUMMY 0 +#define ADSP_SC594_CLK_SYS_CLKIN0 1 +#define ADSP_SC594_CLK_SYS_CLKIN1 2 +#define ADSP_SC594_CLK_CGU1_IN 3 +#define ADSP_SC594_CLK_CGU0_PLL_IN 4 +#define ADSP_SC594_CLK_CGU1_PLL_IN 5 +#define ADSP_SC594_CLK_CGU0_VCO_OUT 6 +#define ADSP_SC594_CLK_CGU1_VCO_OUT 7 +#define ADSP_SC594_CLK_CGU0_PLLCLK 8 +#define ADSP_SC594_CLK_CGU1_PLLCLK 9 +#define ADSP_SC594_CLK_CGU0_CDIV 10 +#define ADSP_SC594_CLK_CGU0_SYSCLK 11 +#define ADSP_SC594_CLK_CGU0_DDIV 12 +#define ADSP_SC594_CLK_CGU0_ODIV 13 +#define ADSP_SC594_CLK_CGU0_S0SELDIV 14 +#define ADSP_SC594_CLK_CGU0_S1SELDIV 15 +#define ADSP_SC594_CLK_CGU0_S1SELEXDIV 16 +#define ADSP_SC594_CLK_CGU0_S1SEL 17 +#define ADSP_SC594_CLK_CGU1_CDIV 18 +#define ADSP_SC594_CLK_CGU1_SYSCLK 19 +#define ADSP_SC594_CLK_CGU1_DDIV 20 +#define ADSP_SC594_CLK_CGU1_ODIV 21 +#define ADSP_SC594_CLK_CGU1_S0SELDIV 22 +#define ADSP_SC594_CLK_CGU1_S1SELDIV 23 +#define ADSP_SC594_CLK_CGU1_S1SELEXDIV 24 +#define ADSP_SC594_CLK_CGU1_S1SEL 25 +#define ADSP_SC594_CLK_CGU0_CCLK0 26 +#define ADSP_SC594_CLK_CGU0_CCLK1 27 +#define ADSP_SC594_CLK_CGU0_OCLK 28 +#define ADSP_SC594_CLK_CGU0_DCLK 29 +#define ADSP_SC594_CLK_CGU0_SCLK1 30 +#define ADSP_SC594_CLK_CGU0_SCLK0 31 +#define ADSP_SC594_CLK_CGU1_CCLK0 32 +#define ADSP_SC594_CLK_CGU1_CCLK1 33 +#define ADSP_SC594_CLK_CGU1_OCLK 34 +#define ADSP_SC594_CLK_CGU1_DCLK 35 +#define ADSP_SC594_CLK_CGU1_SCLK1 36 +#define ADSP_SC594_CLK_CGU1_SCLK0 37 +#define ADSP_SC594_CLK_SHARC0_SEL 38 +#define ADSP_SC594_CLK_SHARC1_SEL 39 +#define ADSP_SC594_CLK_ARM_SEL 40 +#define ADSP_SC594_CLK_CDU_DDR_SEL 41 +#define ADSP_SC594_CLK_CAN_SEL 42 +#define ADSP_SC594_CLK_SPDIF_SEL 43 +#define ADSP_SC594_CLK_RESERVED_SEL 44 +#define ADSP_SC594_CLK_GIGE_SEL 45 +#define ADSP_SC594_CLK_LP_SEL 46 +#define ADSP_SC594_CLK_LPDDR_SEL 47 +#define ADSP_SC594_CLK_OSPI_SEL 48 +#define ADSP_SC594_CLK_TRACE_SEL 49 +#define ADSP_SC594_CLK_SHARC0 50 +#define ADSP_SC594_CLK_SHARC1 51 +#define ADSP_SC594_CLK_ARM 52 +#define ADSP_SC594_CLK_CDU_DDR 53 +#define ADSP_SC594_CLK_CAN 54 +#define ADSP_SC594_CLK_SPDIF 55 +#define ADSP_SC594_CLK_SPI 56 +#define ADSP_SC594_CLK_GIGE 57 +#define ADSP_SC594_CLK_LP 58 +#define ADSP_SC594_CLK_LPDDR 59 +#define ADSP_SC594_CLK_OSPI 60 +#define ADSP_SC594_CLK_TRACE 61 +#define ADSP_SC594_CLK_END 62 + +//ADSP-SC598 +#define ADSP_SC598_CLK_DUMMY 0 +#define ADSP_SC598_CLK_SYS_CLKIN0 1 +#define ADSP_SC598_CLK_SYS_CLKIN1 2 +#define ADSP_SC598_CLK_CGU0_PLL_IN 3 +#define ADSP_SC598_CLK_CGU0_VCO_OUT 4 +#define ADSP_SC598_CLK_CGU0_PLLCLK 5 +#define ADSP_SC598_CLK_CGU1_IN 6 +#define ADSP_SC598_CLK_CGU1_PLL_IN 7 +#define ADSP_SC598_CLK_CGU1_VCO_OUT 8 +#define ADSP_SC598_CLK_CGU1_PLLCLK 9 +#define ADSP_SC598_CLK_CGU0_CDIV 10 +#define ADSP_SC598_CLK_CGU0_SYSCLK 11 +#define ADSP_SC598_CLK_CGU0_DDIV 12 +#define ADSP_SC598_CLK_CGU0_ODIV 13 +#define ADSP_SC598_CLK_CGU0_S0SELDIV 14 +#define ADSP_SC598_CLK_CGU0_S1SELDIV 15 +#define ADSP_SC598_CLK_CGU0_S1SELEXDIV 16 +#define ADSP_SC598_CLK_CGU0_S1SEL 17 +#define ADSP_SC598_CLK_CGU1_CDIV 18 +#define ADSP_SC598_CLK_CGU1_SYSCLK 19 +#define ADSP_SC598_CLK_CGU1_DDIV 20 +#define ADSP_SC598_CLK_CGU1_ODIV 21 +#define ADSP_SC598_CLK_CGU1_S0SELDIV 22 +#define ADSP_SC598_CLK_CGU1_S1SELDIV 23 +#define ADSP_SC598_CLK_CGU1_S0SELEXDIV 24 +#define ADSP_SC598_CLK_CGU1_S1SELEXDIV 25 +#define ADSP_SC598_CLK_CGU1_S0SEL 26 +#define ADSP_SC598_CLK_CGU1_S1SEL 27 +#define ADSP_SC598_CLK_CGU0_CCLK2 28 +#define ADSP_SC598_CLK_CGU0_CCLK0 29 +#define ADSP_SC598_CLK_CGU0_OCLK 30 +#define ADSP_SC598_CLK_CGU0_DCLK 31 +#define ADSP_SC598_CLK_CGU0_SCLK1 32 +#define ADSP_SC598_CLK_CGU0_SCLK0 33 +#define ADSP_SC598_CLK_CGU1_CCLK0 34 +#define ADSP_SC598_CLK_CGU1_OCLK 35 +#define ADSP_SC598_CLK_CGU1_DCLK 36 +#define ADSP_SC598_CLK_CGU1_SCLK1 37 +#define ADSP_SC598_CLK_CGU1_SCLK0 38 +#define ADSP_SC598_CLK_CGU1_CCLK2 39 +#define ADSP_SC598_CLK_DCLK0_HALF 40 +#define ADSP_SC598_CLK_DCLK1_HALF 41 +#define ADSP_SC598_CLK_CGU1_SCLK1_HALF 42 +#define ADSP_SC598_CLK_SHARC0_SEL 43 +#define ADSP_SC598_CLK_SHARC1_SEL 44 +#define ADSP_SC598_CLK_ARM_SEL 45 +#define ADSP_SC598_CLK_CDU_DDR_SEL 46 +#define ADSP_SC598_CLK_CAN_SEL 47 +#define ADSP_SC598_CLK_SPDIF_SEL 48 +#define ADSP_SC598_CLK_SPI_SEL 49 +#define ADSP_SC598_CLK_GIGE_SEL 50 +#define ADSP_SC598_CLK_LP_SEL 51 +#define ADSP_SC598_CLK_LP_DDR_SEL 52 +#define ADSP_SC598_CLK_OSPI_REFCLK_SEL 53 +#define ADSP_SC598_CLK_TRACE_SEL 54 +#define ADSP_SC598_CLK_EMMC_SEL 55 +#define ADSP_SC598_CLK_EMMC_TIMER_QMC_SEL 56 +#define ADSP_SC598_CLK_SHARC0 57 +#define ADSP_SC598_CLK_SHARC1 58 +#define ADSP_SC598_CLK_ARM 59 +#define ADSP_SC598_CLK_CDU_DDR 60 +#define ADSP_SC598_CLK_CAN 61 +#define ADSP_SC598_CLK_SPDIF 62 +#define ADSP_SC598_CLK_SPI 63 +#define ADSP_SC598_CLK_GIGE 64 +#define ADSP_SC598_CLK_LP 65 +#define ADSP_SC598_CLK_LP_DDR 66 +#define ADSP_SC598_CLK_OSPI_REFCLK 67 +#define ADSP_SC598_CLK_TRACE 68 +#define ADSP_SC598_CLK_EMMC 69 +#define ADSP_SC598_CLK_EMMC_TIMER_QMC 70 +#define ADSP_SC598_CLK_3PLL_PLL_IN 71 +#define ADSP_SC598_CLK_3PLL_VCO_OUT 72 +#define ADSP_SC598_CLK_3PLL_PLLCLK 73 +#define ADSP_SC598_CLK_3PLL_DDIV 74 +#define ADSP_SC598_CLK_DDR 75 +#define ADSP_SC598_CLK_END 76 + +//ADSP-SC58X +#define ADSP_SC58X_CLK_DUMMY 0 +#define ADSP_SC58X_CLK_SYS_CLKIN0 1 +#define ADSP_SC58X_CLK_SYS_CLKIN1 2 +#define ADSP_SC58X_CLK_CGU0_PLL_IN 3 +#define ADSP_SC58X_CLK_CGU0_VCO_OUT 4 +#define ADSP_SC58X_CLK_CGU0_PLLCLK 5 +#define ADSP_SC58X_CLK_CGU1_IN 6 +#define ADSP_SC58X_CLK_CGU1_PLL_IN 7 +#define ADSP_SC58X_CLK_CGU1_VCO_OUT 8 +#define ADSP_SC58X_CLK_CGU1_PLLCLK 9 +#define ADSP_SC58X_CLK_CGU0_CDIV 10 +#define ADSP_SC58X_CLK_CGU0_SYSCLK 11 +#define ADSP_SC58X_CLK_CGU0_DDIV 12 +#define ADSP_SC58X_CLK_CGU0_ODIV 13 +#define ADSP_SC58X_CLK_CGU0_S0SELDIV 14 +#define ADSP_SC58X_CLK_CGU0_S1SELDIV 15 +#define ADSP_SC58X_CLK_CGU1_CDIV 16 +#define ADSP_SC58X_CLK_CGU1_SYSCLK 17 +#define ADSP_SC58X_CLK_CGU1_DDIV 18 +#define ADSP_SC58X_CLK_CGU1_ODIV 19 +#define ADSP_SC58X_CLK_CGU1_S0SELDIV 20 +#define ADSP_SC58X_CLK_CGU1_S1SELDIV 21 +#define ADSP_SC58X_CLK_CGU0_CCLK0 22 +#define ADSP_SC58X_CLK_CGU0_CCLK1 23 +#define ADSP_SC58X_CLK_CGU0_OCLK 24 +#define ADSP_SC58X_CLK_CGU0_DCLK 25 +#define ADSP_SC58X_CLK_CGU0_SCLK1 26 +#define ADSP_SC58X_CLK_CGU0_SCLK0 27 +#define ADSP_SC58X_CLK_CGU1_CCLK0 28 +#define ADSP_SC58X_CLK_CGU1_CCLK1 29 +#define ADSP_SC58X_CLK_CGU1_OCLK 30 +#define ADSP_SC58X_CLK_CGU1_DCLK 31 +#define ADSP_SC58X_CLK_CGU1_SCLK1 32 +#define ADSP_SC58X_CLK_CGU1_SCLK0 33 +#define ADSP_SC58X_CLK_OCLK0_HALF 34 +#define ADSP_SC58X_CLK_CCLK1_1_HALF 35 +#define ADSP_SC58X_CLK_SHARC0_SEL 36 +#define ADSP_SC58X_CLK_SHARC1_SEL 37 +#define ADSP_SC58X_CLK_ARM_SEL 38 +#define ADSP_SC58X_CLK_CDU_DDR_SEL 39 +#define ADSP_SC58X_CLK_CAN_SEL 40 +#define ADSP_SC58X_CLK_SPDIF_SEL 41 +#define ADSP_SC58X_CLK_RESERVED_SEL 42 +#define ADSP_SC58X_CLK_GIGE_SEL 43 +#define ADSP_SC58X_CLK_LP_SEL 44 +#define ADSP_SC58X_CLK_SDIO_SEL 45 +#define ADSP_SC58X_CLK_SHARC0 46 +#define ADSP_SC58X_CLK_SHARC1 47 +#define ADSP_SC58X_CLK_ARM 48 +#define ADSP_SC58X_CLK_CDU_DDR 49 +#define ADSP_SC58X_CLK_CAN 50 +#define ADSP_SC58X_CLK_SPDIF 51 +#define ADSP_SC58X_CLK_RESERVED 52 +#define ADSP_SC58X_CLK_GIGE 53 +#define ADSP_SC58X_CLK_LP 54 +#define ADSP_SC58X_CLK_SDIO 55 +#define ADSP_SC58X_CLK_END 56 + +//ADSP-SC57X +#define ADSP_SC57X_CLK_DUMMY 0 +#define ADSP_SC57X_CLK_SYS_CLKIN0 1 +#define ADSP_SC57X_CLK_SYS_CLKIN1 2 +#define ADSP_SC57X_CLK_CGU0_PLL_IN 3 +#define ADSP_SC57X_CLK_CGU0_PLLCLK 4 +#define ADSP_SC57X_CLK_CGU1_IN 5 +#define ADSP_SC57X_CLK_CGU1_PLL_IN 6 +#define ADSP_SC57X_CLK_CGU1_PLLCLK 7 +#define ADSP_SC57X_CLK_CGU0_CDIV 8 +#define ADSP_SC57X_CLK_CGU0_SYSCLK 9 +#define ADSP_SC57X_CLK_CGU0_DDIV 10 +#define ADSP_SC57X_CLK_CGU0_ODIV 11 +#define ADSP_SC57X_CLK_CGU0_S0SELDIV 12 +#define ADSP_SC57X_CLK_CGU0_S1SELDIV 13 +#define ADSP_SC57X_CLK_CGU1_CDIV 14 +#define ADSP_SC57X_CLK_CGU1_SYSCLK 15 +#define ADSP_SC57X_CLK_CGU1_DDIV 16 +#define ADSP_SC57X_CLK_CGU1_ODIV 17 +#define ADSP_SC57X_CLK_CGU1_S0SELDIV 18 +#define ADSP_SC57X_CLK_CGU1_S1SELDIV 19 +#define ADSP_SC57X_CLK_CGU0_CCLK0 20 +#define ADSP_SC57X_CLK_CGU0_CCLK1 21 +#define ADSP_SC57X_CLK_CGU0_OCLK 22 +#define ADSP_SC57X_CLK_CGU0_DCLK 23 +#define ADSP_SC57X_CLK_CGU0_SCLK1 24 +#define ADSP_SC57X_CLK_CGU0_SCLK0 25 +#define ADSP_SC57X_CLK_CGU1_CCLK0 26 +#define ADSP_SC57X_CLK_CGU1_CCLK1 27 +#define ADSP_SC57X_CLK_CGU1_OCLK 28 +#define ADSP_SC57X_CLK_CGU1_DCLK 29 +#define ADSP_SC57X_CLK_CGU1_SCLK1 30 +#define ADSP_SC57X_CLK_CGU1_SCLK0 31 +#define ADSP_SC57X_CLK_OCLK0_HALF 32 +#define ADSP_SC57X_CLK_CCLK1_1_HALF 33 +#define ADSP_SC57X_CLK_SHARC0_SEL 34 +#define ADSP_SC57X_CLK_SHARC1_SEL 35 +#define ADSP_SC57X_CLK_ARM_SEL 36 +#define ADSP_SC57X_CLK_CDU_DDR_SEL 37 +#define ADSP_SC57X_CLK_CAN_SEL 38 +#define ADSP_SC57X_CLK_SPDIF_SEL 39 +#define ADSP_SC57X_CLK_GIGE_SEL 40 +#define ADSP_SC57X_CLK_SDIO_SEL 41 +#define ADSP_SC57X_CLK_SHARC0 42 +#define ADSP_SC57X_CLK_SHARC1 43 +#define ADSP_SC57X_CLK_ARM 44 +#define ADSP_SC57X_CLK_CDU_DDR 45 +#define ADSP_SC57X_CLK_CAN 46 +#define ADSP_SC57X_CLK_SPDIF 47 +#define ADSP_SC57X_CLK_GIGE 48 +#define ADSP_SC57X_CLK_SDIO 49 +#define ADSP_SC57X_CLK_END 50 + +#endif
From: Nathan Barrett-Morrison nathan.morrison@timesys.com
Co-developed-by: Greg Malysa greg.malysa@timesys.com Signed-off-by: Greg Malysa greg.malysa@timesys.com Co-developed-by: Ian Roberts ian.roberts@timesys.com Signed-off-by: Ian Roberts ian.roberts@timesys.com Signed-off-by: Vasileios Bimpikas vasileios.bimpikas@analog.com Signed-off-by: Utsav Agarwal utsav.agarwal@analog.com Signed-off-by: Arturs Artamonovs arturs.artamonovs@analog.com Signed-off-by: Nathan Barrett-Morrison nathan.morrison@timesys.com ---
MAINTAINERS | 1 + drivers/serial/Makefile | 1 + drivers/serial/serial_adi_uart4.c | 228 ++++++++++++++++++++++++++++++ 3 files changed, 230 insertions(+) create mode 100644 drivers/serial/serial_adi_uart4.c
diff --git a/MAINTAINERS b/MAINTAINERS index a9f52a6c7e..b1f206bb05 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -610,6 +610,7 @@ T: git https://github.com/analogdevicesinc/lnxdsp-u-boot F: arch/arm/include/asm/arch-adi/ F: arch/arm/mach-sc5xx/ F: drivers/clk/adi/ +F: drivers/serial/serial_adi_uart4.c F: include/configs/sc_adi_common.h
ARM SNAPDRAGON diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 403ab1ded6..dbe598b740 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -65,3 +65,4 @@ obj-$(CONFIG_S5P4418_PL011_SERIAL) += serial_s5p4418_pl011.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_USB_TTY) += usbtty.o endif +obj-$(CONFIG_UART4_SERIAL) += serial_adi_uart4.o diff --git a/drivers/serial/serial_adi_uart4.c b/drivers/serial/serial_adi_uart4.c new file mode 100644 index 0000000000..b92ce3ddd1 --- /dev/null +++ b/drivers/serial/serial_adi_uart4.c @@ -0,0 +1,228 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2022 - Analog Devices, Inc. + * + * Written and/or maintained by Timesys Corporation + * + * Converted to driver model by Nathan Barrett-Morrison + * + * Contact: Nathan Barrett-Morrison nathan.morrison@timesys.com + * Contact: Greg Malysa greg.malysa@timesys.com + * + */ + +#include <dm.h> +#include <errno.h> +#include <post.h> +#include <watchdog.h> +#include <serial.h> +#include <asm/io.h> +#include <linux/compiler.h> +#include <linux/bitops.h> +#include <clk.h> + +/* + * UART4 Masks + */ + +/* UART_CONTROL */ +#define UEN BIT(0) +#define LOOP_ENA BIT(1) +#define UMOD (3 << 4) +#define UMOD_UART (0 << 4) +#define UMOD_MDB BIT(4) +#define UMOD_IRDA BIT(4) +#define WLS (3 << 8) +#define WLS_5 (0 << 8) +#define WLS_6 BIT(8) +#define WLS_7 (2 << 8) +#define WLS_8 (3 << 8) +#define STB BIT(12) +#define STBH BIT(13) +#define PEN BIT(14) +#define EPS BIT(15) +#define STP BIT(16) +#define FPE BIT(17) +#define FFE BIT(18) +#define SB BIT(19) +#define FCPOL BIT(22) +#define RPOLC BIT(23) +#define TPOLC BIT(24) +#define MRTS BIT(25) +#define XOFF BIT(26) +#define ARTS BIT(27) +#define ACTS BIT(28) +#define RFIT BIT(29) +#define RFRT BIT(30) + +/* UART_STATUS */ +#define DR BIT(0) +#define OE BIT(1) +#define PE BIT(2) +#define FE BIT(3) +#define BI BIT(4) +#define THRE BIT(5) +#define TEMT BIT(7) +#define TFI BIT(8) +#define ASTKY BIT(9) +#define ADDR BIT(10) +#define RO BIT(11) +#define SCTS BIT(12) +#define CTS BIT(16) +#define RFCS BIT(17) + +/* UART_EMASK */ +#define ERBFI BIT(0) +#define ETBEI BIT(1) +#define ELSI BIT(2) +#define EDSSI BIT(3) +#define EDTPTI BIT(4) +#define ETFI BIT(5) +#define ERFCI BIT(6) +#define EAWI BIT(7) +#define ERXS BIT(8) +#define ETXS BIT(9) + +DECLARE_GLOBAL_DATA_PTR; + +struct uart4_reg { + u32 revid; + u32 control; + u32 status; + u32 scr; + u32 clock; + u32 emask; + u32 emaskst; + u32 emaskcl; + u32 rbr; + u32 thr; + u32 taip; + u32 tsr; + u32 rsr; + u32 txdiv_cnt; + u32 rxdiv_cnt; +}; + +struct adi_uart4_platdata { + // Hardware registers + struct uart4_reg *regs; + + // Enable divide-by-one baud rate setting + bool edbo; +}; + +static int adi_uart4_set_brg(struct udevice *dev, int baudrate) +{ + struct adi_uart4_platdata *plat = dev_get_plat(dev); + struct uart4_reg *regs = plat->regs; + u32 divisor, uart_base_clk_rate; + struct clk uart_base_clk; + + if (clk_get_by_index(dev, 0, &uart_base_clk)) { + printf("%s: Could not get UART base clock\n", dev->name); + return -1; + } + + uart_base_clk_rate = clk_get_rate(&uart_base_clk); + + if (plat->edbo) { + u16 divisor16 = (uart_base_clk_rate + (baudrate / 2)) / baudrate; + + divisor = divisor16 | BIT(31); + } else { + // Divisor is only 16 bits + divisor = 0x0000ffff & ((uart_base_clk_rate + (baudrate * 8)) / (baudrate * 16)); + } + + writel(divisor, ®s->clock); + return 0; +} + +static int adi_uart4_pending(struct udevice *dev, bool input) +{ + struct adi_uart4_platdata *plat = dev_get_plat(dev); + struct uart4_reg *regs = plat->regs; + + if (input) + return (readl(®s->status) & DR) ? 1 : 0; + else + return (readl(®s->status) & THRE) ? 0 : 1; +} + +static int adi_uart4_getc(struct udevice *dev) +{ + struct adi_uart4_platdata *plat = dev_get_plat(dev); + struct uart4_reg *regs = plat->regs; + int uart_rbr_val; + + if (!adi_uart4_pending(dev, true)) + return -EAGAIN; + + uart_rbr_val = readl(®s->rbr); + writel(-1, ®s->status); + + return uart_rbr_val; +} + +static int adi_uart4_putc(struct udevice *dev, const char ch) +{ + struct adi_uart4_platdata *plat = dev_get_plat(dev); + struct uart4_reg *regs = plat->regs; + + if (adi_uart4_pending(dev, false)) + return -EAGAIN; + + writel(ch, ®s->thr); + return 0; +} + +static const struct dm_serial_ops adi_uart4_serial_ops = { + .setbrg = adi_uart4_set_brg, + .getc = adi_uart4_getc, + .putc = adi_uart4_putc, + .pending = adi_uart4_pending, +}; + +static int adi_uart4_of_to_plat(struct udevice *dev) +{ + struct adi_uart4_platdata *plat = dev_get_plat(dev); + fdt_addr_t addr; + + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->regs = (struct uart4_reg *)addr; + plat->edbo = dev_read_bool(dev, "adi,enable-edbo"); + + return 0; +} + +static int adi_uart4_probe(struct udevice *dev) +{ + struct adi_uart4_platdata *plat = dev_get_plat(dev); + struct uart4_reg *regs = plat->regs; + + /* always enable UART to 8-bit mode */ + writel(UEN | UMOD_UART | WLS_8, ®s->control); + + writel(-1, ®s->status); + + return 0; +} + +static const struct udevice_id adi_uart4_serial_ids[] = { + { .compatible = "adi,uart4" }, + { } +}; + +U_BOOT_DRIVER(serial_adi_uart4) = { + .name = "serial_adi_uart4", + .id = UCLASS_SERIAL, + .of_match = adi_uart4_serial_ids, + .of_to_plat = adi_uart4_of_to_plat, + .plat_auto = sizeof(struct adi_uart4_platdata), + .probe = adi_uart4_probe, + .ops = &adi_uart4_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +};
On Thu, Apr 11, 2024 at 07:37:27PM -0400, Greg Malysa wrote:
This series adds support for the ADI SC5xx machine type and includes two core drivers that are required for being able to boot any board--a UART driver and the clock tree driver. Our corresponding Linux support relies on u-boot configuring the clocks correctly before booting, so it is not possible to boot any board without the CGU/CDU configuration happening here. The clock tree itself is only used by the UART in this minimal patch set, but is of course broadly useful for all other peripheral drivers to be submitted in future patch sets. There are also no board files or defconfigs included here, but some common definitions that will be used to build board files currently are.
Some of the configuration code in dmcinit and clkinit is quite scary and causes a lot of checkpatch violations. It is modified from code initially provided by ADI, but it has not been fully rewritten. There's a question of how important it is to clean up this code--it has some quality violations, but it has been in use (including in production) for over two years and is known to work for performing the low level SoC initialization, while a rewrite might introduce bugs that could take a significant amount of time to detect in the future.
Please provide any feedback or comments that will be helpful in creating a v2 of this patch that will be ready to submit for inclusion into the main tree, as well as general observations that we should consider in other driver patches before submitting them.
Does this series pass CI currently? Thanks.
I'm afraid I have to admit I don't know. I'll work with our IT team to make sure we can run CI locally, and when v2 comes around the answer will be yes.
-- Tom
AFAIR, I think you the only exception to open a PR in the github fork is to run CI.
- Nuno Sá
Greg Malysa
Nuno Sá
