Re: [U-Boot] [PATCH] cmd: usb_mass_storage: add protection for block_dev
Hi Marek and Lucaz
I have found this old patch: See https://lists.denx.de/pipermail/u-boot/2017-October/309716.html
On 10/18/2017 10:22 PM, Marek Vasut-3 wrote:
On 10/18/2017 06:27 PM, Tom Rini wrote:
On Wed, Oct 18, 2017 at 04:03:21PM +0200, Patrick Delaunay wrote:
solve data abort for the command "ums 0 ubi 0" because result of case blk_get_device_part_str() result is OK but with block_dev = 0 when CONFIG_CMD_UBIFS is activate and ubi volume is mounted
Signed-off-by: Patrick Delaunay <[hidden email]>
This is UMS, so Lukasz ... please review _thoroughly_ , as I suspect there might be some weird underlying issue .
cmd/usb_mass_storage.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c index cfeecb7..c0563ca 100644 --- a/cmd/usb_mass_storage.c +++ b/cmd/usb_mass_storage.c @@ -85,7 +85,7 @@ static int ums_init(const char *devtype, const char *devnums_part_str) partnum = 0;
/* f_mass_storage.c assumes SECTOR_SIZE sectors */
- if (block_dev->blksz != SECTOR_SIZE)
if (!block_dev || block_dev->blksz != SECTOR_SIZE) goto cleanup;
ums_new = realloc(ums, (ums_count + 1) * sizeof(*ums));
Adding in Marek..
-- Best regards, Marek Vasut
Do you think that this patch is needed. I check and the issue is still present on U-Boot v2018.09 :
STM32MP> ubi part UBI STM32MP> ubifsmount ubi0:boot STM32MP> ums 0 ubi 0 data abort pc : [<ffc60abc>] lr : [<ffc60ab3>] reloc pc : [<c0110abc>] lr : [<c0110ab3>] sp : fdc3e460 ip : fdc3e518 fp : fdcf06a8 r10: fdcf06b8 r9 : fdc4eed8 r8 : 00000000 r7 : ffce3d84 r6 : fdcf0740 r5 : fdcf0740 r4 : ffce3d88 r3 : 00000000 r2 : 00000000 r1 : 0000003a r0 : 00000000 Flags: nZCv IRQs off FIQs off Mode SVC_32 Code: f04f4628 9b06fd2a bf082800 0800f04f (f5b3695b) Resetting CPU ...
Even If the command is invalid, I think that data abort should be avoid.
Regards
Patrick
On 09/21/2018 04:01 PM, Patrick DELAUNAY wrote:
Hi Marek and Lucaz
Adding in Marek..
I think so too, send an updated patch please.
Patrick DELAUNAY
