[PATCH v2 0/2] board: ti: am6x: Switch to standard boot
This series switches am64x to standard boot flow. Also minor fix to am62x boot targets.
NOTE: Tested on AM64x GP EVM but I had to hand edit the grub.cfg file provided with the TI release [1]
from,
menuentry 'boot'{ linux /Image root=PARTUUID=3a4a99a8-02 rootwait rootfstype=ext4 }
to,
menuentry 'boot'{ linux /Image console=ttyS2,115200n8 root=PARTUUID=3a4a99a8-02 rootwait rootfstype=ext4 }
else there is no console output.
[1] https://dr-download.ti.com/software-development/software-development-kit-sdk...
cheers, -roger
Changelog: v2: - Added Nishanth's Reviewed-by for patch 1 - Dropped unnecessary headers and macro from patch 2
Roger Quadros (2): board: ti: am62x: am62x.env: Fix boot_targets board: ti: am64x: Switch to standard boot flow
board/ti/am62x/am62x.env | 2 +- board/ti/am64x/am64x.env | 1 + configs/am64x_evm_a53_defconfig | 5 +++-- include/configs/am64x_evm.h | 9 --------- 4 files changed, 5 insertions(+), 12 deletions(-)
base-commit: e29b932aa07fa0226d325b35d96cd4eea0370129 prerequisite-patch-id: afb49f33f198747451687f83936f039049365924 prerequisite-patch-id: 1d8297eb0a3b44d8578cae785cc22f0fb6077239 prerequisite-patch-id: 4ae9fdc0b3737e55289a78a59d546a08c03d62e5 prerequisite-patch-id: 2be0e0caf153bec2c453b2f21342ba207c1ee13d prerequisite-patch-id: 7710703ce9a41b72ff3fb89abf0823625a5b5454 prerequisite-patch-id: 60d61440bf0ab8c0bea8b971ef18aa6d0d26e113 prerequisite-patch-id: c974e6d80489cbb0ee8cc1f3e19bcc9cf47f25b6
ti_mmc is not a valid boot_target for standard boot flow so remove it. Prefer mmc1 (sd-card) over mmc0 (emmc).
Signed-off-by: Roger Quadros rogerq@kernel.org Reviewed-by: Nishanth Menon nm@ti.com --- board/ti/am62x/am62x.env | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/ti/am62x/am62x.env b/board/ti/am62x/am62x.env index 22a6c2c91b..e53a55c38f 100644 --- a/board/ti/am62x/am62x.env +++ b/board/ti/am62x/am62x.env @@ -8,7 +8,7 @@ args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000 ${mtdparts} run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}
-boot_targets=ti_mmc mmc0 mmc1 usb pxe dhcp +boot_targets=mmc1 mmc0 usb pxe dhcp boot=mmc mmcdev=1 bootpart=1:2
Switch to using bootstd. Note with this change, we will stop using distro_bootcmd and instead depend entirely on bootflow method of starting the system up.
Drop header files that are no longer needed in am64x_evm.h. k3_dfu.h is available via k3_dfu.env in am64x.env.
Drop unused macro CFG_SYS_SDRAM_BASE1.
Signed-off-by: Roger Quadros rogerq@kernel.org --- board/ti/am64x/am64x.env | 1 + configs/am64x_evm_a53_defconfig | 5 +++-- include/configs/am64x_evm.h | 9 --------- 3 files changed, 4 insertions(+), 11 deletions(-)
diff --git a/board/ti/am64x/am64x.env b/board/ti/am64x/am64x.env index 68e42222b7..efd736b99b 100644 --- a/board/ti/am64x/am64x.env +++ b/board/ti/am64x/am64x.env @@ -15,6 +15,7 @@ console=ttyS2,115200n8 args_all=setenv optargs earlycon=ns16550a,mmio32,0x02800000 ${mtdparts} run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}
+boot_targets=mmc1 mmc0 usb pxe dhcp boot=mmc mmcdev=1 bootpart=1:2 diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 718ad176cb..43bfcf957a 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -31,8 +31,9 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="run envboot; run distro_bootcmd;" +CONFIG_BOOTSTD_FULL=y +CONFIG_BOOTSTD_DEFAULTS=y +CONFIG_BOOTCOMMAND="run envboot; bootflow scan -lb" CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x180000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/include/configs/am64x_evm.h b/include/configs/am64x_evm.h index 062102a610..f9f8c7bc2f 100644 --- a/include/configs/am64x_evm.h +++ b/include/configs/am64x_evm.h @@ -9,15 +9,6 @@ #ifndef __CONFIG_AM642_EVM_H #define __CONFIG_AM642_EVM_H
-#include <linux/sizes.h> -#include <config_distro_bootcmd.h> -#include <env/ti/mmc.h> -#include <asm/arch/am64_hardware.h> -#include <env/ti/k3_dfu.h> - -/* DDR Configuration */ -#define CFG_SYS_SDRAM_BASE1 0x880000000 - /* Now for the remaining common defines */ #include <configs/ti_armv7_common.h>
-- 2.34.1
Hi Roger,
It looks like this file still includes distro_bootcmd and defines all the BOOT_TARGET things. Can they be dropped? Perhaps for now they could be put behind an #ifdef if other boards need them?
I suspect that with your patch as is, the environment is still full of scripts?
-- 2.34.1
On Thu, Oct 05, 2023 at 09:01:42AM -0600, Simon Glass wrote:
Hi Roger,
There's a lot of TI platforms, so I'm not sure what "#if" you're thinking of might make it cleaner? We could / should move some of the still relevant content and comments from that file to include/env/ti/ti_armv7_common.env as I do think some of the K3 platforms could just drop <configs/ti_armv7_common.h> at this point.
On 12:31-20231005, Tom Rini wrote: [...]
Is'nt the header distro_bootcmd.h and related stuff under #ifdef CONFIG_DISTRO_DEFAULTS already?
So, all we are picking up in effect is really CFG_SYS_SDRAM_BASE - which is consistent across platforms.
That's true too. The file (and probably all of the other *common.h ones) likely need some cleaning out of dead comments, etc, from the Kconfig migration.
Hi Tom,
Hi Roger,
OK so if they are using text env then the header-file stuff doesn't matter since I believe it is ignored? I was thinking of something like:
do all the distro #defines
#endif
Hi Simon,
On 05/10/2023 20:22, Simon Glass wrote:
Hi Tom,
Hi Roger,
#endif
This is already done, although within #ifdef CONFIG_ARM64 ...
All we are picking up is really CFG_SYS_SDRAM_BASE.
Cleaning up ti_armv7_common.h should be a separate series and involve testing on all affected platforms (entire TI range) :P.
Nishanth Menon
Roger Quadros
