[U-Boot] [Patch V7 03/18] net/fm: Fix the endian issue to support both endianness platforms
The Frame Manager(FMan) is a big-endian peripheral, so the registers, internal MURAM and BDs, which are allocated in main memory and used to communication between core and FMan, should be accessed in big-endian. The big-endian platforms can access them directly as the code implemented so far, while for the little-endian platforms it need to swap the byte-order.
Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V7: - No change. V6: - No change. V5: - No change. V4: - No change. V3: - Modify the subject to make the aim clear. V2: - No change.
drivers/net/fm/eth.c | 70 +++++++++++++++++++++++++++------------------------- drivers/net/fm/fm.c | 11 +++++---- 2 files changed, 43 insertions(+), 38 deletions(-)
diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index 6702f5a..368d554 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -109,7 +109,7 @@ static int tgec_is_fibre(struct eth_device *dev) static u16 muram_readw(u16 *addr) { u32 base = (u32)addr & ~0x3; - u32 val32 = *(u32 *)base; + u32 val32 = in_be32((u32 *)base); int byte_pos; u16 ret;
@@ -125,7 +125,7 @@ static u16 muram_readw(u16 *addr) static void muram_writew(u16 *addr, u16 val) { u32 base = (u32)addr & ~0x3; - u32 org32 = *(u32 *)base; + u32 org32 = in_be32((u32 *)base); u32 val32; int byte_pos;
@@ -135,7 +135,7 @@ static void muram_writew(u16 *addr, u16 val) else val32 = (org32 & 0x0000ffff) | ((u32)val << 16);
- *(u32 *)base = val32; + out_be32((u32 *)base, val32); }
static void bmi_rx_port_disable(struct fm_bmi_rx_port *rx_port) @@ -213,10 +213,10 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) pram_page_offset = (u32)pram - fm_muram_base(fm_eth->fm_index);
/* enable global mode- snooping data buffers and BDs */ - pram->mode = PRAM_MODE_GLOBAL; + out_be32(&pram->mode, PRAM_MODE_GLOBAL);
/* init the Rx queue descriptor pionter */ - pram->rxqd_ptr = pram_page_offset + 0x20; + out_be32(&pram->rxqd_ptr, pram_page_offset + 0x20);
/* set the max receive buffer length, power of 2 */ muram_writew(&pram->mrblr, MAX_RXBUF_LOG2); @@ -243,10 +243,11 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) /* init Rx BDs ring */ rxbd = (struct fm_port_bd *)rx_bd_ring_base; for (i = 0; i < RX_BD_RING_SIZE; i++) { - rxbd->status = RxBD_EMPTY; - rxbd->len = 0; - rxbd->buf_ptr_hi = 0; - rxbd->buf_ptr_lo = (u32)rx_buf_pool + i * MAX_RXBUF_LEN; + muram_writew(&rxbd->status, RxBD_EMPTY); + muram_writew(&rxbd->len, 0); + muram_writew(&rxbd->buf_ptr_hi, 0); + out_be32(&rxbd->buf_ptr_lo, (u32)rx_buf_pool + + i * MAX_RXBUF_LEN); rxbd++; }
@@ -254,7 +255,7 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) rxqd = &pram->rxqd; muram_writew(&rxqd->gen, 0); muram_writew(&rxqd->bd_ring_base_hi, 0); - rxqd->bd_ring_base_lo = (u32)rx_bd_ring_base; + out_be32(&rxqd->bd_ring_base_lo, (u32)rx_bd_ring_base); muram_writew(&rxqd->bd_ring_size, sizeof(struct fm_port_bd) * RX_BD_RING_SIZE); muram_writew(&rxqd->offset_in, 0); @@ -285,10 +286,10 @@ static int fm_eth_tx_port_parameter_init(struct fm_eth *fm_eth) pram_page_offset = (u32)pram - fm_muram_base(fm_eth->fm_index);
/* init the Tx queue descriptor pionter */ - pram->txqd_ptr = pram_page_offset + 0x40; + out_be32(&pram->txqd_ptr, pram_page_offset + 0x40);
/* alloc Tx buffer descriptors from main memory */ tx_bd_ring_base = malloc(sizeof(struct fm_port_bd) @@ -304,16 +305,17 @@ static int fm_eth_tx_port_parameter_init(struct fm_eth *fm_eth) /* init Tx BDs ring */ txbd = (struct fm_port_bd *)tx_bd_ring_base; for (i = 0; i < TX_BD_RING_SIZE; i++) { - txbd->status = TxBD_LAST; - txbd->len = 0; - txbd->buf_ptr_hi = 0; - txbd->buf_ptr_lo = 0; + muram_writew(&txbd->status, TxBD_LAST); + muram_writew(&txbd->len, 0); + muram_writew(&txbd->buf_ptr_hi, 0); + out_be32(&txbd->buf_ptr_lo, 0); + txbd++; }
/* set the Tx queue decriptor */ txqd = &pram->txqd; muram_writew(&txqd->bd_ring_base_hi, 0); - txqd->bd_ring_base_lo = (u32)tx_bd_ring_base; + out_be32(&txqd->bd_ring_base_lo, (u32)tx_bd_ring_base); muram_writew(&txqd->bd_ring_size, sizeof(struct fm_port_bd) * TX_BD_RING_SIZE); muram_writew(&txqd->offset_in, 0); @@ -368,7 +370,7 @@ static void fmc_tx_port_graceful_stop_enable(struct fm_eth *fm_eth)
pram = fm_eth->tx_pram; /* graceful stop transmission of frames */ - pram->mode |= PRAM_MODE_GRACEFUL_STOP; + setbits_be32(&pram->mode, PRAM_MODE_GRACEFUL_STOP); sync(); }
@@ -378,7 +380,7 @@ static void fmc_tx_port_graceful_stop_disable(struct fm_eth *fm_eth)
pram = fm_eth->tx_pram; /* re-enable transmission of frames */ - pram->mode &= ~PRAM_MODE_GRACEFUL_STOP; + clrbits_be32(&pram->mode, PRAM_MODE_GRACEFUL_STOP); sync(); }
@@ -469,19 +471,20 @@ static int fm_eth_send(struct eth_device *dev, void *buf, int len) txbd = fm_eth->cur_txbd;
/* find one empty TxBD */ - for (i = 0; txbd->status & TxBD_READY; i++) { + for (i = 0; muram_readw(&txbd->status) & TxBD_READY; i++) { udelay(100); if (i > 0x1000) { - printf("%s: Tx buffer not ready\n", dev->name); + printf("%s: Tx buffer not ready, txbd->status = 0x%x\n", + dev->name, muram_readw(&txbd->status)); return 0; } } /* setup TxBD */ - txbd->buf_ptr_hi = 0; - txbd->buf_ptr_lo = (u32)buf; - txbd->len = len; + muram_writew(&txbd->buf_ptr_hi, 0); + out_be32(&txbd->buf_ptr_lo, (u32)buf); + muram_writew(&txbd->len, len); sync(); - txbd->status = TxBD_READY | TxBD_LAST; + muram_writew(&txbd->status, TxBD_READY | TxBD_LAST); sync();
/* update TxQD, let RISC to send the packet */ @@ -493,10 +496,11 @@ static int fm_eth_send(struct eth_device *dev, void *buf, int len) sync();
/* wait for buffer to be transmitted */ - for (i = 0; txbd->status & TxBD_READY; i++) { + for (i = 0; muram_readw(&txbd->status) & TxBD_READY; i++) { udelay(100); if (i > 0x10000) { - printf("%s: Tx error\n", dev->name); + printf("%s: Tx error, txbd->status = 0x%x\n", + dev->name, muram_readw(&txbd->status)); return 0; } } @@ -525,12 +529,12 @@ static int fm_eth_recv(struct eth_device *dev) fm_eth = (struct fm_eth *)dev->priv; pram = fm_eth->rx_pram; rxbd = fm_eth->cur_rxbd; - status = rxbd->status; + status = muram_readw(&rxbd->status);
while (!(status & RxBD_EMPTY)) { if (!(status & RxBD_ERROR)) { - data = (u8 *)rxbd->buf_ptr_lo; - len = rxbd->len; + data = (u8 *)in_be32(&rxbd->buf_ptr_lo); + len = muram_readw(&rxbd->len); net_process_received_packet(data, len); } else { printf("%s: Rx error\n", dev->name); @@ -538,8 +542,8 @@ static int fm_eth_recv(struct eth_device *dev) }
/* clear the RxBDs */ - rxbd->status = RxBD_EMPTY; - rxbd->len = 0; + muram_writew(&rxbd->status, RxBD_EMPTY); + muram_writew(&rxbd->len, 0); sync();
/* advance RxBD */ @@ -548,7 +552,7 @@ static int fm_eth_recv(struct eth_device *dev) if (rxbd >= (rxbd_base + RX_BD_RING_SIZE)) rxbd = rxbd_base; /* read next status */ - status = rxbd->status; + status = muram_readw(&rxbd->status);
/* update RxQD */ offset_out = muram_readw(&pram->rxqd.offset_out); diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index 400e9dd..eb0eb3d 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -80,11 +80,11 @@ static void fm_upload_ucode(int fm_idx, struct fm_imem *imem, out_be32(&imem->iadd, IRAM_IADD_AIE); /* write microcode to IRAM */ for (i = 0; i < size / 4; i++) - out_be32(&imem->idata, ucode[i]); + out_be32(&imem->idata, (be32_to_cpu(ucode[i])));
/* verify if the writing is over */ out_be32(&imem->iadd, 0); - while ((in_be32(&imem->idata) != ucode[0]) && --timeout) + while ((in_be32(&imem->idata) != be32_to_cpu(ucode[0])) && --timeout) ; if (!timeout) printf("Fman%u: microcode upload timeout\n", fm_idx + 1); @@ -177,14 +177,15 @@ static int fman_upload_firmware(int fm_idx, const struct qe_microcode *ucode = &firmware->microcode[i];
/* Upload a microcode if it's present */ - if (ucode->code_offset) { + if (be32_to_cpu(ucode->code_offset)) { u32 ucode_size; u32 *code; printf("Fman%u: Uploading microcode version %u.%u.%u\n", fm_idx + 1, ucode->major, ucode->minor, ucode->revision); - code = (void *)firmware + ucode->code_offset; - ucode_size = sizeof(u32) * ucode->count; + code = (void *)firmware + + be32_to_cpu(ucode->code_offset); + ucode_size = sizeof(u32) * be32_to_cpu(ucode->count); fm_upload_ucode(fm_idx, fm_imem, code, ucode_size); } }
Use mb() instead of sync() to be compatible for both ARM and PowerPC.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V7: - No change. V6: - No change. V5: - No change. V4: - No change. V3: - New patch. Separated from patch 'net: Move some header files to include/'
drivers/net/fm/eth.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index 368d554..ad02c66 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -371,7 +371,7 @@ static void fmc_tx_port_graceful_stop_enable(struct fm_eth *fm_eth) pram = fm_eth->tx_pram; /* graceful stop transmission of frames */ setbits_be32(&pram->mode, PRAM_MODE_GRACEFUL_STOP); - sync(); + mb(); }
static void fmc_tx_port_graceful_stop_disable(struct fm_eth *fm_eth) @@ -381,7 +381,7 @@ static void fmc_tx_port_graceful_stop_disable(struct fm_eth *fm_eth) pram = fm_eth->tx_pram; /* re-enable transmission of frames */ clrbits_be32(&pram->mode, PRAM_MODE_GRACEFUL_STOP); - sync(); + mb(); }
static int fm_eth_open(struct eth_device *dev, bd_t *bd) @@ -483,9 +483,9 @@ static int fm_eth_send(struct eth_device *dev, void *buf, int len) muram_writew(&txbd->buf_ptr_hi, 0); out_be32(&txbd->buf_ptr_lo, (u32)buf); muram_writew(&txbd->len, len); - sync(); + mb(); muram_writew(&txbd->status, TxBD_READY | TxBD_LAST); - sync(); + mb();
/* update TxQD, let RISC to send the packet */ offset_in = muram_readw(&pram->txqd.offset_in); @@ -493,7 +493,7 @@ static int fm_eth_send(struct eth_device *dev, void *buf, int len) if (offset_in >= muram_readw(&pram->txqd.bd_ring_size)) offset_in = 0; muram_writew(&pram->txqd.offset_in, offset_in); - sync(); + mb();
/* wait for buffer to be transmitted */ for (i = 0; muram_readw(&txbd->status) & TxBD_READY; i++) { @@ -544,7 +544,7 @@ static int fm_eth_recv(struct eth_device *dev) /* clear the RxBDs */ muram_writew(&rxbd->status, RxBD_EMPTY); muram_writew(&rxbd->len, 0); - sync(); + mb();
/* advance RxBD */ rxbd++; @@ -560,7 +560,7 @@ static int fm_eth_recv(struct eth_device *dev) if (offset_out >= muram_readw(&pram->rxqd.bd_ring_size)) offset_out = 0; muram_writew(&pram->rxqd.offset_out, offset_out); - sync(); + mb(); } fm_eth->cur_rxbd = (void *)rxbd;
V7:
- No change.
V6:
- No change.
V5:
- No change.
V4:
- No change.
V3:
sync();
mb();
sync();
mb();
Why is it needed at all? The I/O accessors should include the necessary barriers.
-Scott
-----Original Message----- From: Wood Scott-B07421 Sent: 2015年10月23日 7:11 To: Gong Qianyu-B52263 Cc: u-boot@lists.denx.de; Hu Mingkai-B21284; Sun York-R58495; Hou Zhiqiang-B48286; Xie Shaohui-B21989; Song Wenbin-B53747; Wood Scott- B07421; Kushwaha Prabhakar-B32579; Wang Huan-B18965 Subject: Re: [Patch V7 04/18] net/fm/eth: Use mb() to be compatible for both ARM and PowerPC
V7:
- No change.
V6:
- No change.
V5:
- No change.
V4:
- No change.
V3:
include/'
sync();
mb();
sync();
mb();
The I/O accessors of powerpc does include the barrier, but it absents from ARMs'.
Thanks, Zhiqiang
V7:
- No change.
V6:
- No change.
V5:
- No change.
V4:
- No change.
V3:
include/'
sync();
mb();
sync();
mb();
Then fix ARM's accessors if they're missing barriers that are required. But first, consider whether the barrier is required on ARM. What is special about FM that it needs it where all other drivers don't?
-Scott
-----Original Message----- From: Wood Scott-B07421 Sent: Friday, October 23, 2015 9:42 PM To: Hou Zhiqiang-B48286 Cc: Gong Qianyu-B52263; u-boot@lists.denx.de; Hu Mingkai-B21284; Sun York-R58495; Xie Shaohui-B21989; Song Wenbin-B53747; Kushwaha Prabhakar- B32579; Wang Huan-B18965 Subject: Re: [Patch V7 04/18] net/fm/eth: Use mb() to be compatible for both ARM and PowerPC
PowerPC.
V7:
- No change.
V6:
- No change.
V5:
- No change.
V4:
- No change.
V3:
include/'
sync();
mb();
sync();
mb();
-Scott
I tested on both LS1043ARDB and T2080RDB board just now. FM still works well without the barrier.
Gong Q.Y.
Gong Qianyu
Hou Zhiqiang
Scott Wood
