[U-Boot] [PATCH 2/8 v2] UBIFS: Implement read-only UBIFS support in U-Boot (Part 2)
This patchset adds UBIFS read-only support to U-Boot. The following commands are implemented:
- ubifsmount Mount an UBIFS volume
- ubifsls List a directory of the mounted UBIFS volume
- ubifsload Load a file from the mounted UBIFS volume to memory
The U-Boot UBIFS implementation is largely a direct copy from the current Linux version (2.6.29-rc6). As already done in the UBI version we have an "abstraction layer" to redefine or remove some OS calls (e.g. mutex_lock() ...). This makes it possible to use the original Linux code with very little changes. And by this we can better update to later Linux versions.
I removed some of the Linux features that are not used in the U-Boot version (e.g. garbage-collection, write support).
Signed-off-by: Stefan Roese sr@denx.de CC: Artem Bityutskiy dedekind@infradead.org CC: Adrian Hunter ext-Adrian.Hunter@nokia.com --- Changes in v2: - Now symbolic links are handled correctly
fs/ubifs/io.c | 316 ++++++++++++++ fs/ubifs/key.h | 557 +++++++++++++++++++++++++ fs/ubifs/log.c | 104 +++++ fs/ubifs/lprops.c | 842 +++++++++++++++++++++++++++++++++++++ fs/ubifs/lpt.c | 1105 +++++++++++++++++++++++++++++++++++++++++++++++++ fs/ubifs/lpt_commit.c | 171 ++++++++ 6 files changed, 3095 insertions(+), 0 deletions(-) create mode 100644 fs/ubifs/io.c create mode 100644 fs/ubifs/key.h create mode 100644 fs/ubifs/log.c create mode 100644 fs/ubifs/lprops.c create mode 100644 fs/ubifs/lpt.c create mode 100644 fs/ubifs/lpt_commit.c
diff --git a/fs/ubifs/io.c b/fs/ubifs/io.c new file mode 100644 index 0000000..aae5c65 --- /dev/null +++ b/fs/ubifs/io.c @@ -0,0 +1,316 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * Copyright (C) 2006, 2007 University of Szeged, Hungary + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Artem Bityutskiy (Битюцкий Артём) + * Adrian Hunter + * Zoltan Sogor + */ + +/* + * This file implements UBIFS I/O subsystem which provides various I/O-related + * helper functions (reading/writing/checking/validating nodes) and implements + * write-buffering support. Write buffers help to save space which otherwise + * would have been wasted for padding to the nearest minimal I/O unit boundary. + * Instead, data first goes to the write-buffer and is flushed when the + * buffer is full or when it is not used for some time (by timer). This is + * similar to the mechanism is used by JFFS2. + * + * Write-buffers are defined by 'struct ubifs_wbuf' objects and protected by + * mutexes defined inside these objects. Since sometimes upper-level code + * has to lock the write-buffer (e.g. journal space reservation code), many + * functions related to write-buffers have "nolock" suffix which means that the + * caller has to lock the write-buffer before calling this function. + * + * UBIFS stores nodes at 64 bit-aligned addresses. If the node length is not + * aligned, UBIFS starts the next node from the aligned address, and the padded + * bytes may contain any rubbish. In other words, UBIFS does not put padding + * bytes in those small gaps. Common headers of nodes store real node lengths, + * not aligned lengths. Indexing nodes also store real lengths in branches. + * + * UBIFS uses padding when it pads to the next min. I/O unit. In this case it + * uses padding nodes or padding bytes, if the padding node does not fit. + * + * All UBIFS nodes are protected by CRC checksums and UBIFS checks all nodes + * every time they are read from the flash media. + */ + +#include "ubifs.h" + +/** + * ubifs_ro_mode - switch UBIFS to read read-only mode. + * @c: UBIFS file-system description object + * @err: error code which is the reason of switching to R/O mode + */ +void ubifs_ro_mode(struct ubifs_info *c, int err) +{ + if (!c->ro_media) { + c->ro_media = 1; + c->no_chk_data_crc = 0; + ubifs_warn("switched to read-only mode, error %d", err); + dbg_dump_stack(); + } +} + +/** + * ubifs_check_node - check node. + * @c: UBIFS file-system description object + * @buf: node to check + * @lnum: logical eraseblock number + * @offs: offset within the logical eraseblock + * @quiet: print no messages + * @must_chk_crc: indicates whether to always check the CRC + * + * This function checks node magic number and CRC checksum. This function also + * validates node length to prevent UBIFS from becoming crazy when an attacker + * feeds it a file-system image with incorrect nodes. For example, too large + * node length in the common header could cause UBIFS to read memory outside of + * allocated buffer when checking the CRC checksum. + * + * This function may skip data nodes CRC checking if @c->no_chk_data_crc is + * true, which is controlled by corresponding UBIFS mount option. However, if + * @must_chk_crc is true, then @c->no_chk_data_crc is ignored and CRC is + * checked. Similarly, if @c->always_chk_crc is true, @c->no_chk_data_crc is + * ignored and CRC is checked. + * + * This function returns zero in case of success and %-EUCLEAN in case of bad + * CRC or magic. + */ +int ubifs_check_node(const struct ubifs_info *c, const void *buf, int lnum, + int offs, int quiet, int must_chk_crc) +{ + int err = -EINVAL, type, node_len; + uint32_t crc, node_crc, magic; + const struct ubifs_ch *ch = buf; + + ubifs_assert(lnum >= 0 && lnum < c->leb_cnt && offs >= 0); + ubifs_assert(!(offs & 7) && offs < c->leb_size); + + magic = le32_to_cpu(ch->magic); + if (magic != UBIFS_NODE_MAGIC) { + if (!quiet) + ubifs_err("bad magic %#08x, expected %#08x", + magic, UBIFS_NODE_MAGIC); + err = -EUCLEAN; + goto out; + } + + type = ch->node_type; + if (type < 0 || type >= UBIFS_NODE_TYPES_CNT) { + if (!quiet) + ubifs_err("bad node type %d", type); + goto out; + } + + node_len = le32_to_cpu(ch->len); + if (node_len + offs > c->leb_size) + goto out_len; + + if (c->ranges[type].max_len == 0) { + if (node_len != c->ranges[type].len) + goto out_len; + } else if (node_len < c->ranges[type].min_len || + node_len > c->ranges[type].max_len) + goto out_len; + + if (!must_chk_crc && type == UBIFS_DATA_NODE && !c->always_chk_crc && + c->no_chk_data_crc) + return 0; + + crc = crc32(UBIFS_CRC32_INIT, buf + 8, node_len - 8); + node_crc = le32_to_cpu(ch->crc); + if (crc != node_crc) { + if (!quiet) + ubifs_err("bad CRC: calculated %#08x, read %#08x", + crc, node_crc); + err = -EUCLEAN; + goto out; + } + + return 0; + +out_len: + if (!quiet) + ubifs_err("bad node length %d", node_len); +out: + if (!quiet) { + ubifs_err("bad node at LEB %d:%d", lnum, offs); + dbg_dump_node(c, buf); + dbg_dump_stack(); + } + return err; +} + +/** + * ubifs_pad - pad flash space. + * @c: UBIFS file-system description object + * @buf: buffer to put padding to + * @pad: how many bytes to pad + * + * The flash media obliges us to write only in chunks of %c->min_io_size and + * when we have to write less data we add padding node to the write-buffer and + * pad it to the next minimal I/O unit's boundary. Padding nodes help when the + * media is being scanned. If the amount of wasted space is not enough to fit a + * padding node which takes %UBIFS_PAD_NODE_SZ bytes, we write padding bytes + * pattern (%UBIFS_PADDING_BYTE). + * + * Padding nodes are also used to fill gaps when the "commit-in-gaps" method is + * used. + */ +void ubifs_pad(const struct ubifs_info *c, void *buf, int pad) +{ + uint32_t crc; + + ubifs_assert(pad >= 0 && !(pad & 7)); + + if (pad >= UBIFS_PAD_NODE_SZ) { + struct ubifs_ch *ch = buf; + struct ubifs_pad_node *pad_node = buf; + + ch->magic = cpu_to_le32(UBIFS_NODE_MAGIC); + ch->node_type = UBIFS_PAD_NODE; + ch->group_type = UBIFS_NO_NODE_GROUP; + ch->padding[0] = ch->padding[1] = 0; + ch->sqnum = 0; + ch->len = cpu_to_le32(UBIFS_PAD_NODE_SZ); + pad -= UBIFS_PAD_NODE_SZ; + pad_node->pad_len = cpu_to_le32(pad); + crc = crc32(UBIFS_CRC32_INIT, buf + 8, UBIFS_PAD_NODE_SZ - 8); + ch->crc = cpu_to_le32(crc); + memset(buf + UBIFS_PAD_NODE_SZ, 0, pad); + } else if (pad > 0) + /* Too little space, padding node won't fit */ + memset(buf, UBIFS_PADDING_BYTE, pad); +} + +/** + * next_sqnum - get next sequence number. + * @c: UBIFS file-system description object + */ +static unsigned long long next_sqnum(struct ubifs_info *c) +{ + unsigned long long sqnum; + + spin_lock(&c->cnt_lock); + sqnum = ++c->max_sqnum; + spin_unlock(&c->cnt_lock); + + if (unlikely(sqnum >= SQNUM_WARN_WATERMARK)) { + if (sqnum >= SQNUM_WATERMARK) { + ubifs_err("sequence number overflow %llu, end of life", + sqnum); + ubifs_ro_mode(c, -EINVAL); + } + ubifs_warn("running out of sequence numbers, end of life soon"); + } + + return sqnum; +} + +/** + * ubifs_prepare_node - prepare node to be written to flash. + * @c: UBIFS file-system description object + * @node: the node to pad + * @len: node length + * @pad: if the buffer has to be padded + * + * This function prepares node at @node to be written to the media - it + * calculates node CRC, fills the common header, and adds proper padding up to + * the next minimum I/O unit if @pad is not zero. + */ +void ubifs_prepare_node(struct ubifs_info *c, void *node, int len, int pad) +{ + uint32_t crc; + struct ubifs_ch *ch = node; + unsigned long long sqnum = next_sqnum(c); + + ubifs_assert(len >= UBIFS_CH_SZ); + + ch->magic = cpu_to_le32(UBIFS_NODE_MAGIC); + ch->len = cpu_to_le32(len); + ch->group_type = UBIFS_NO_NODE_GROUP; + ch->sqnum = cpu_to_le64(sqnum); + ch->padding[0] = ch->padding[1] = 0; + crc = crc32(UBIFS_CRC32_INIT, node + 8, len - 8); + ch->crc = cpu_to_le32(crc); + + if (pad) { + len = ALIGN(len, 8); + pad = ALIGN(len, c->min_io_size) - len; + ubifs_pad(c, node + len, pad); + } +} + +/** + * ubifs_read_node - read node. + * @c: UBIFS file-system description object + * @buf: buffer to read to + * @type: node type + * @len: node length (not aligned) + * @lnum: logical eraseblock number + * @offs: offset within the logical eraseblock + * + * This function reads a node of known type and and length, checks it and + * stores in @buf. Returns zero in case of success, %-EUCLEAN if CRC mismatched + * and a negative error code in case of failure. + */ +int ubifs_read_node(const struct ubifs_info *c, void *buf, int type, int len, + int lnum, int offs) +{ + int err, l; + struct ubifs_ch *ch = buf; + + dbg_io("LEB %d:%d, %s, length %d", lnum, offs, dbg_ntype(type), len); + ubifs_assert(lnum >= 0 && lnum < c->leb_cnt && offs >= 0); + ubifs_assert(len >= UBIFS_CH_SZ && offs + len <= c->leb_size); + ubifs_assert(!(offs & 7) && offs < c->leb_size); + ubifs_assert(type >= 0 && type < UBIFS_NODE_TYPES_CNT); + + err = ubi_read(c->ubi, lnum, buf, offs, len); + if (err && err != -EBADMSG) { + ubifs_err("cannot read node %d from LEB %d:%d, error %d", + type, lnum, offs, err); + return err; + } + + if (type != ch->node_type) { + ubifs_err("bad node type (%d but expected %d)", + ch->node_type, type); + goto out; + } + + err = ubifs_check_node(c, buf, lnum, offs, 0, 0); + if (err) { + ubifs_err("expected node type %d", type); + return err; + } + + l = le32_to_cpu(ch->len); + if (l != len) { + ubifs_err("bad node length %d, expected %d", l, len); + goto out; + } + + return 0; + +out: + ubifs_err("bad node at LEB %d:%d", lnum, offs); + dbg_dump_node(c, buf); + dbg_dump_stack(); + return -EINVAL; +} diff --git a/fs/ubifs/key.h b/fs/ubifs/key.h new file mode 100644 index 0000000..efb3430 --- /dev/null +++ b/fs/ubifs/key.h @@ -0,0 +1,557 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Artem Bityutskiy (Битюцкий Артём) + * Adrian Hunter + */ + +/* + * This header contains various key-related definitions and helper function. + * UBIFS allows several key schemes, so we access key fields only via these + * helpers. At the moment only one key scheme is supported. + * + * Simple key scheme + * ~~~~~~~~~~~~~~~~~ + * + * Keys are 64-bits long. First 32-bits are inode number (parent inode number + * in case of direntry key). Next 3 bits are node type. The last 29 bits are + * 4KiB offset in case of inode node, and direntry hash in case of a direntry + * node. We use "r5" hash borrowed from reiserfs. + */ + +#ifndef __UBIFS_KEY_H__ +#define __UBIFS_KEY_H__ + +/** + * key_mask_hash - mask a valid hash value. + * @val: value to be masked + * + * We use hash values as offset in directories, so values %0 and %1 are + * reserved for "." and "..". %2 is reserved for "end of readdir" marker. This + * function makes sure the reserved values are not used. + */ +static inline uint32_t key_mask_hash(uint32_t hash) +{ + hash &= UBIFS_S_KEY_HASH_MASK; + if (unlikely(hash <= 2)) + hash += 3; + return hash; +} + +/** + * key_r5_hash - R5 hash function (borrowed from reiserfs). + * @s: direntry name + * @len: name length + */ +static inline uint32_t key_r5_hash(const char *s, int len) +{ + uint32_t a = 0; + const signed char *str = (const signed char *)s; + + while (*str) { + a += *str << 4; + a += *str >> 4; + a *= 11; + str++; + } + + return key_mask_hash(a); +} + +/** + * key_test_hash - testing hash function. + * @str: direntry name + * @len: name length + */ +static inline uint32_t key_test_hash(const char *str, int len) +{ + uint32_t a = 0; + + len = min_t(uint32_t, len, 4); + memcpy(&a, str, len); + return key_mask_hash(a); +} + +/** + * ino_key_init - initialize inode key. + * @c: UBIFS file-system description object + * @key: key to initialize + * @inum: inode number + */ +static inline void ino_key_init(const struct ubifs_info *c, + union ubifs_key *key, ino_t inum) +{ + key->u32[0] = inum; + key->u32[1] = UBIFS_INO_KEY << UBIFS_S_KEY_BLOCK_BITS; +} + +/** + * ino_key_init_flash - initialize on-flash inode key. + * @c: UBIFS file-system description object + * @k: key to initialize + * @inum: inode number + */ +static inline void ino_key_init_flash(const struct ubifs_info *c, void *k, + ino_t inum) +{ + union ubifs_key *key = k; + + key->j32[0] = cpu_to_le32(inum); + key->j32[1] = cpu_to_le32(UBIFS_INO_KEY << UBIFS_S_KEY_BLOCK_BITS); + memset(k + 8, 0, UBIFS_MAX_KEY_LEN - 8); +} + +/** + * lowest_ino_key - get the lowest possible inode key. + * @c: UBIFS file-system description object + * @key: key to initialize + * @inum: inode number + */ +static inline void lowest_ino_key(const struct ubifs_info *c, + union ubifs_key *key, ino_t inum) +{ + key->u32[0] = inum; + key->u32[1] = 0; +} + +/** + * highest_ino_key - get the highest possible inode key. + * @c: UBIFS file-system description object + * @key: key to initialize + * @inum: inode number + */ +static inline void highest_ino_key(const struct ubifs_info *c, + union ubifs_key *key, ino_t inum) +{ + key->u32[0] = inum; + key->u32[1] = 0xffffffff; +} + +/** + * dent_key_init - initialize directory entry key. + * @c: UBIFS file-system description object + * @key: key to initialize + * @inum: parent inode number + * @nm: direntry name and length + */ +static inline void dent_key_init(const struct ubifs_info *c, + union ubifs_key *key, ino_t inum, + const struct qstr *nm) +{ + uint32_t hash = c->key_hash(nm->name, nm->len); + + ubifs_assert(!(hash & ~UBIFS_S_KEY_HASH_MASK)); + key->u32[0] = inum; + key->u32[1] = hash | (UBIFS_DENT_KEY << UBIFS_S_KEY_HASH_BITS); +} + +/** + * dent_key_init_hash - initialize directory entry key without re-calculating + * hash function. + * @c: UBIFS file-system description object + * @key: key to initialize + * @inum: parent inode number + * @hash: direntry name hash + */ +static inline void dent_key_init_hash(const struct ubifs_info *c, + union ubifs_key *key, ino_t inum, + uint32_t hash) +{ + ubifs_assert(!(hash & ~UBIFS_S_KEY_HASH_MASK)); + key->u32[0] = inum; + key->u32[1] = hash | (UBIFS_DENT_KEY << UBIFS_S_KEY_HASH_BITS); +} + +/** + * dent_key_init_flash - initialize on-flash directory entry key. + * @c: UBIFS file-system description object + * @k: key to initialize + * @inum: parent inode number + * @nm: direntry name and length + */ +static inline void dent_key_init_flash(const struct ubifs_info *c, void *k, + ino_t inum, const struct qstr *nm) +{ + union ubifs_key *key = k; + uint32_t hash = c->key_hash(nm->name, nm->len); + + ubifs_assert(!(hash & ~UBIFS_S_KEY_HASH_MASK)); + key->j32[0] = cpu_to_le32(inum); + key->j32[1] = cpu_to_le32(hash | + (UBIFS_DENT_KEY << UBIFS_S_KEY_HASH_BITS)); + memset(k + 8, 0, UBIFS_MAX_KEY_LEN - 8); +} + +/** + * lowest_dent_key - get the lowest possible directory entry key. + * @c: UBIFS file-system description object + * @key: where to store the lowest key + * @inum: parent inode number + */ +static inline void lowest_dent_key(const struct ubifs_info *c, + union ubifs_key *key, ino_t inum) +{ + key->u32[0] = inum; + key->u32[1] = UBIFS_DENT_KEY << UBIFS_S_KEY_HASH_BITS; +} + +/** + * xent_key_init - initialize extended attribute entry key. + * @c: UBIFS file-system description object + * @key: key to initialize + * @inum: host inode number + * @nm: extended attribute entry name and length + */ +static inline void xent_key_init(const struct ubifs_info *c, + union ubifs_key *key, ino_t inum, + const struct qstr *nm) +{ + uint32_t hash = c->key_hash(nm->name, nm->len); + + ubifs_assert(!(hash & ~UBIFS_S_KEY_HASH_MASK)); + key->u32[0] = inum; + key->u32[1] = hash | (UBIFS_XENT_KEY << UBIFS_S_KEY_HASH_BITS); +} + +/** + * xent_key_init_hash - initialize extended attribute entry key without + * re-calculating hash function. + * @c: UBIFS file-system description object + * @key: key to initialize + * @inum: host inode number + * @hash: extended attribute entry name hash + */ +static inline void xent_key_init_hash(const struct ubifs_info *c, + union ubifs_key *key, ino_t inum, + uint32_t hash) +{ + ubifs_assert(!(hash & ~UBIFS_S_KEY_HASH_MASK)); + key->u32[0] = inum; + key->u32[1] = hash | (UBIFS_XENT_KEY << UBIFS_S_KEY_HASH_BITS); +} + +/** + * xent_key_init_flash - initialize on-flash extended attribute entry key. + * @c: UBIFS file-system description object + * @k: key to initialize + * @inum: host inode number + * @nm: extended attribute entry name and length + */ +static inline void xent_key_init_flash(const struct ubifs_info *c, void *k, + ino_t inum, const struct qstr *nm) +{ + union ubifs_key *key = k; + uint32_t hash = c->key_hash(nm->name, nm->len); + + ubifs_assert(!(hash & ~UBIFS_S_KEY_HASH_MASK)); + key->j32[0] = cpu_to_le32(inum); + key->j32[1] = cpu_to_le32(hash | + (UBIFS_XENT_KEY << UBIFS_S_KEY_HASH_BITS)); + memset(k + 8, 0, UBIFS_MAX_KEY_LEN - 8); +} + +/** + * lowest_xent_key - get the lowest possible extended attribute entry key. + * @c: UBIFS file-system description object + * @key: where to store the lowest key + * @inum: host inode number + */ +static inline void lowest_xent_key(const struct ubifs_info *c, + union ubifs_key *key, ino_t inum) +{ + key->u32[0] = inum; + key->u32[1] = UBIFS_XENT_KEY << UBIFS_S_KEY_HASH_BITS; +} + +/** + * data_key_init - initialize data key. + * @c: UBIFS file-system description object + * @key: key to initialize + * @inum: inode number + * @block: block number + */ +static inline void data_key_init(const struct ubifs_info *c, + union ubifs_key *key, ino_t inum, + unsigned int block) +{ + ubifs_assert(!(block & ~UBIFS_S_KEY_BLOCK_MASK)); + key->u32[0] = inum; + key->u32[1] = block | (UBIFS_DATA_KEY << UBIFS_S_KEY_BLOCK_BITS); +} + +/** + * data_key_init_flash - initialize on-flash data key. + * @c: UBIFS file-system description object + * @k: key to initialize + * @inum: inode number + * @block: block number + */ +static inline void data_key_init_flash(const struct ubifs_info *c, void *k, + ino_t inum, unsigned int block) +{ + union ubifs_key *key = k; + + ubifs_assert(!(block & ~UBIFS_S_KEY_BLOCK_MASK)); + key->j32[0] = cpu_to_le32(inum); + key->j32[1] = cpu_to_le32(block | + (UBIFS_DATA_KEY << UBIFS_S_KEY_BLOCK_BITS)); + memset(k + 8, 0, UBIFS_MAX_KEY_LEN - 8); +} + +/** + * trun_key_init - initialize truncation node key. + * @c: UBIFS file-system description object + * @key: key to initialize + * @inum: inode number + * + * Note, UBIFS does not have truncation keys on the media and this function is + * only used for purposes of replay. + */ +static inline void trun_key_init(const struct ubifs_info *c, + union ubifs_key *key, ino_t inum) +{ + key->u32[0] = inum; + key->u32[1] = UBIFS_TRUN_KEY << UBIFS_S_KEY_BLOCK_BITS; +} + +/** + * key_type - get key type. + * @c: UBIFS file-system description object + * @key: key to get type of + */ +static inline int key_type(const struct ubifs_info *c, + const union ubifs_key *key) +{ + return key->u32[1] >> UBIFS_S_KEY_BLOCK_BITS; +} + +/** + * key_type_flash - get type of a on-flash formatted key. + * @c: UBIFS file-system description object + * @k: key to get type of + */ +static inline int key_type_flash(const struct ubifs_info *c, const void *k) +{ + const union ubifs_key *key = k; + + return le32_to_cpu(key->j32[1]) >> UBIFS_S_KEY_BLOCK_BITS; +} + +/** + * key_inum - fetch inode number from key. + * @c: UBIFS file-system description object + * @k: key to fetch inode number from + */ +static inline ino_t key_inum(const struct ubifs_info *c, const void *k) +{ + const union ubifs_key *key = k; + + return key->u32[0]; +} + +/** + * key_inum_flash - fetch inode number from an on-flash formatted key. + * @c: UBIFS file-system description object + * @k: key to fetch inode number from + */ +static inline ino_t key_inum_flash(const struct ubifs_info *c, const void *k) +{ + const union ubifs_key *key = k; + + return le32_to_cpu(key->j32[0]); +} + +/** + * key_hash - get directory entry hash. + * @c: UBIFS file-system description object + * @key: the key to get hash from + */ +static inline int key_hash(const struct ubifs_info *c, + const union ubifs_key *key) +{ + return key->u32[1] & UBIFS_S_KEY_HASH_MASK; +} + +/** + * key_hash_flash - get directory entry hash from an on-flash formatted key. + * @c: UBIFS file-system description object + * @k: the key to get hash from + */ +static inline int key_hash_flash(const struct ubifs_info *c, const void *k) +{ + const union ubifs_key *key = k; + + return le32_to_cpu(key->j32[1]) & UBIFS_S_KEY_HASH_MASK; +} + +/** + * key_block - get data block number. + * @c: UBIFS file-system description object + * @key: the key to get the block number from + */ +static inline unsigned int key_block(const struct ubifs_info *c, + const union ubifs_key *key) +{ + return key->u32[1] & UBIFS_S_KEY_BLOCK_MASK; +} + +/** + * key_block_flash - get data block number from an on-flash formatted key. + * @c: UBIFS file-system description object + * @k: the key to get the block number from + */ +static inline unsigned int key_block_flash(const struct ubifs_info *c, + const void *k) +{ + const union ubifs_key *key = k; + + return le32_to_cpu(key->j32[1]) & UBIFS_S_KEY_BLOCK_MASK; +} + +/** + * key_read - transform a key to in-memory format. + * @c: UBIFS file-system description object + * @from: the key to transform + * @to: the key to store the result + */ +static inline void key_read(const struct ubifs_info *c, const void *from, + union ubifs_key *to) +{ + const union ubifs_key *f = from; + + to->u32[0] = le32_to_cpu(f->j32[0]); + to->u32[1] = le32_to_cpu(f->j32[1]); +} + +/** + * key_write - transform a key from in-memory format. + * @c: UBIFS file-system description object + * @from: the key to transform + * @to: the key to store the result + */ +static inline void key_write(const struct ubifs_info *c, + const union ubifs_key *from, void *to) +{ + union ubifs_key *t = to; + + t->j32[0] = cpu_to_le32(from->u32[0]); + t->j32[1] = cpu_to_le32(from->u32[1]); + memset(to + 8, 0, UBIFS_MAX_KEY_LEN - 8); +} + +/** + * key_write_idx - transform a key from in-memory format for the index. + * @c: UBIFS file-system description object + * @from: the key to transform + * @to: the key to store the result + */ +static inline void key_write_idx(const struct ubifs_info *c, + const union ubifs_key *from, void *to) +{ + union ubifs_key *t = to; + + t->j32[0] = cpu_to_le32(from->u32[0]); + t->j32[1] = cpu_to_le32(from->u32[1]); +} + +/** + * key_copy - copy a key. + * @c: UBIFS file-system description object + * @from: the key to copy from + * @to: the key to copy to + */ +static inline void key_copy(const struct ubifs_info *c, + const union ubifs_key *from, union ubifs_key *to) +{ + to->u64[0] = from->u64[0]; +} + +/** + * keys_cmp - compare keys. + * @c: UBIFS file-system description object + * @key1: the first key to compare + * @key2: the second key to compare + * + * This function compares 2 keys and returns %-1 if @key1 is less than + * @key2, %0 if the keys are equivalent and %1 if @key1 is greater than @key2. + */ +static inline int keys_cmp(const struct ubifs_info *c, + const union ubifs_key *key1, + const union ubifs_key *key2) +{ + if (key1->u32[0] < key2->u32[0]) + return -1; + if (key1->u32[0] > key2->u32[0]) + return 1; + if (key1->u32[1] < key2->u32[1]) + return -1; + if (key1->u32[1] > key2->u32[1]) + return 1; + + return 0; +} + +/** + * keys_eq - determine if keys are equivalent. + * @c: UBIFS file-system description object + * @key1: the first key to compare + * @key2: the second key to compare + * + * This function compares 2 keys and returns %1 if @key1 is equal to @key2 and + * %0 if not. + */ +static inline int keys_eq(const struct ubifs_info *c, + const union ubifs_key *key1, + const union ubifs_key *key2) +{ + if (key1->u32[0] != key2->u32[0]) + return 0; + if (key1->u32[1] != key2->u32[1]) + return 0; + return 1; +} + +/** + * is_hash_key - is a key vulnerable to hash collisions. + * @c: UBIFS file-system description object + * @key: key + * + * This function returns %1 if @key is a hashed key or %0 otherwise. + */ +static inline int is_hash_key(const struct ubifs_info *c, + const union ubifs_key *key) +{ + int type = key_type(c, key); + + return type == UBIFS_DENT_KEY || type == UBIFS_XENT_KEY; +} + +/** + * key_max_inode_size - get maximum file size allowed by current key format. + * @c: UBIFS file-system description object + */ +static inline unsigned long long key_max_inode_size(const struct ubifs_info *c) +{ + switch (c->key_fmt) { + case UBIFS_SIMPLE_KEY_FMT: + return (1ULL << UBIFS_S_KEY_BLOCK_BITS) * UBIFS_BLOCK_SIZE; + default: + return 0; + } +} +#endif /* !__UBIFS_KEY_H__ */ diff --git a/fs/ubifs/log.c b/fs/ubifs/log.c new file mode 100644 index 0000000..68a9bd9 --- /dev/null +++ b/fs/ubifs/log.c @@ -0,0 +1,104 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Artem Bityutskiy (Битюцкий Артём) + * Adrian Hunter + */ + +/* + * This file is a part of UBIFS journal implementation and contains various + * functions which manipulate the log. The log is a fixed area on the flash + * which does not contain any data but refers to buds. The log is a part of the + * journal. + */ + +#include "ubifs.h" + +/** + * ubifs_search_bud - search bud LEB. + * @c: UBIFS file-system description object + * @lnum: logical eraseblock number to search + * + * This function searches bud LEB @lnum. Returns bud description object in case + * of success and %NULL if there is no bud with this LEB number. + */ +struct ubifs_bud *ubifs_search_bud(struct ubifs_info *c, int lnum) +{ + struct rb_node *p; + struct ubifs_bud *bud; + + spin_lock(&c->buds_lock); + p = c->buds.rb_node; + while (p) { + bud = rb_entry(p, struct ubifs_bud, rb); + if (lnum < bud->lnum) + p = p->rb_left; + else if (lnum > bud->lnum) + p = p->rb_right; + else { + spin_unlock(&c->buds_lock); + return bud; + } + } + spin_unlock(&c->buds_lock); + return NULL; +} + +/** + * ubifs_add_bud - add bud LEB to the tree of buds and its journal head list. + * @c: UBIFS file-system description object + * @bud: the bud to add + */ +void ubifs_add_bud(struct ubifs_info *c, struct ubifs_bud *bud) +{ + struct rb_node **p, *parent = NULL; + struct ubifs_bud *b; + struct ubifs_jhead *jhead; + + spin_lock(&c->buds_lock); + p = &c->buds.rb_node; + while (*p) { + parent = *p; + b = rb_entry(parent, struct ubifs_bud, rb); + ubifs_assert(bud->lnum != b->lnum); + if (bud->lnum < b->lnum) + p = &(*p)->rb_left; + else + p = &(*p)->rb_right; + } + + rb_link_node(&bud->rb, parent, p); + rb_insert_color(&bud->rb, &c->buds); + if (c->jheads) { + jhead = &c->jheads[bud->jhead]; + list_add_tail(&bud->list, &jhead->buds_list); + } else + ubifs_assert(c->replaying && (c->vfs_sb->s_flags & MS_RDONLY)); + + /* + * Note, although this is a new bud, we anyway account this space now, + * before any data has been written to it, because this is about to + * guarantee fixed mount time, and this bud will anyway be read and + * scanned. + */ + c->bud_bytes += c->leb_size - bud->start; + + dbg_log("LEB %d:%d, jhead %d, bud_bytes %lld", bud->lnum, + bud->start, bud->jhead, c->bud_bytes); + spin_unlock(&c->buds_lock); +} diff --git a/fs/ubifs/lprops.c b/fs/ubifs/lprops.c new file mode 100644 index 0000000..8ce4949 --- /dev/null +++ b/fs/ubifs/lprops.c @@ -0,0 +1,842 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Adrian Hunter + * Artem Bityutskiy (Битюцкий Артём) + */ + +/* + * This file implements the functions that access LEB properties and their + * categories. LEBs are categorized based on the needs of UBIFS, and the + * categories are stored as either heaps or lists to provide a fast way of + * finding a LEB in a particular category. For example, UBIFS may need to find + * an empty LEB for the journal, or a very dirty LEB for garbage collection. + */ + +#include "ubifs.h" + +/** + * get_heap_comp_val - get the LEB properties value for heap comparisons. + * @lprops: LEB properties + * @cat: LEB category + */ +static int get_heap_comp_val(struct ubifs_lprops *lprops, int cat) +{ + switch (cat) { + case LPROPS_FREE: + return lprops->free; + case LPROPS_DIRTY_IDX: + return lprops->free + lprops->dirty; + default: + return lprops->dirty; + } +} + +/** + * move_up_lpt_heap - move a new heap entry up as far as possible. + * @c: UBIFS file-system description object + * @heap: LEB category heap + * @lprops: LEB properties to move + * @cat: LEB category + * + * New entries to a heap are added at the bottom and then moved up until the + * parent's value is greater. In the case of LPT's category heaps, the value + * is either the amount of free space or the amount of dirty space, depending + * on the category. + */ +static void move_up_lpt_heap(struct ubifs_info *c, struct ubifs_lpt_heap *heap, + struct ubifs_lprops *lprops, int cat) +{ + int val1, val2, hpos; + + hpos = lprops->hpos; + if (!hpos) + return; /* Already top of the heap */ + val1 = get_heap_comp_val(lprops, cat); + /* Compare to parent and, if greater, move up the heap */ + do { + int ppos = (hpos - 1) / 2; + + val2 = get_heap_comp_val(heap->arr[ppos], cat); + if (val2 >= val1) + return; + /* Greater than parent so move up */ + heap->arr[ppos]->hpos = hpos; + heap->arr[hpos] = heap->arr[ppos]; + heap->arr[ppos] = lprops; + lprops->hpos = ppos; + hpos = ppos; + } while (hpos); +} + +/** + * adjust_lpt_heap - move a changed heap entry up or down the heap. + * @c: UBIFS file-system description object + * @heap: LEB category heap + * @lprops: LEB properties to move + * @hpos: heap position of @lprops + * @cat: LEB category + * + * Changed entries in a heap are moved up or down until the parent's value is + * greater. In the case of LPT's category heaps, the value is either the amount + * of free space or the amount of dirty space, depending on the category. + */ +static void adjust_lpt_heap(struct ubifs_info *c, struct ubifs_lpt_heap *heap, + struct ubifs_lprops *lprops, int hpos, int cat) +{ + int val1, val2, val3, cpos; + + val1 = get_heap_comp_val(lprops, cat); + /* Compare to parent and, if greater than parent, move up the heap */ + if (hpos) { + int ppos = (hpos - 1) / 2; + + val2 = get_heap_comp_val(heap->arr[ppos], cat); + if (val1 > val2) { + /* Greater than parent so move up */ + while (1) { + heap->arr[ppos]->hpos = hpos; + heap->arr[hpos] = heap->arr[ppos]; + heap->arr[ppos] = lprops; + lprops->hpos = ppos; + hpos = ppos; + if (!hpos) + return; + ppos = (hpos - 1) / 2; + val2 = get_heap_comp_val(heap->arr[ppos], cat); + if (val1 <= val2) + return; + /* Still greater than parent so keep going */ + } + } + } + + /* Not greater than parent, so compare to children */ + while (1) { + /* Compare to left child */ + cpos = hpos * 2 + 1; + if (cpos >= heap->cnt) + return; + val2 = get_heap_comp_val(heap->arr[cpos], cat); + if (val1 < val2) { + /* Less than left child, so promote biggest child */ + if (cpos + 1 < heap->cnt) { + val3 = get_heap_comp_val(heap->arr[cpos + 1], + cat); + if (val3 > val2) + cpos += 1; /* Right child is bigger */ + } + heap->arr[cpos]->hpos = hpos; + heap->arr[hpos] = heap->arr[cpos]; + heap->arr[cpos] = lprops; + lprops->hpos = cpos; + hpos = cpos; + continue; + } + /* Compare to right child */ + cpos += 1; + if (cpos >= heap->cnt) + return; + val3 = get_heap_comp_val(heap->arr[cpos], cat); + if (val1 < val3) { + /* Less than right child, so promote right child */ + heap->arr[cpos]->hpos = hpos; + heap->arr[hpos] = heap->arr[cpos]; + heap->arr[cpos] = lprops; + lprops->hpos = cpos; + hpos = cpos; + continue; + } + return; + } +} + +/** + * add_to_lpt_heap - add LEB properties to a LEB category heap. + * @c: UBIFS file-system description object + * @lprops: LEB properties to add + * @cat: LEB category + * + * This function returns %1 if @lprops is added to the heap for LEB category + * @cat, otherwise %0 is returned because the heap is full. + */ +static int add_to_lpt_heap(struct ubifs_info *c, struct ubifs_lprops *lprops, + int cat) +{ + struct ubifs_lpt_heap *heap = &c->lpt_heap[cat - 1]; + + if (heap->cnt >= heap->max_cnt) { + const int b = LPT_HEAP_SZ / 2 - 1; + int cpos, val1, val2; + + /* Compare to some other LEB on the bottom of heap */ + /* Pick a position kind of randomly */ + cpos = (((size_t)lprops >> 4) & b) + b; + ubifs_assert(cpos >= b); + ubifs_assert(cpos < LPT_HEAP_SZ); + ubifs_assert(cpos < heap->cnt); + + val1 = get_heap_comp_val(lprops, cat); + val2 = get_heap_comp_val(heap->arr[cpos], cat); + if (val1 > val2) { + struct ubifs_lprops *lp; + + lp = heap->arr[cpos]; + lp->flags &= ~LPROPS_CAT_MASK; + lp->flags |= LPROPS_UNCAT; + list_add(&lp->list, &c->uncat_list); + lprops->hpos = cpos; + heap->arr[cpos] = lprops; + move_up_lpt_heap(c, heap, lprops, cat); + dbg_check_heap(c, heap, cat, lprops->hpos); + return 1; /* Added to heap */ + } + dbg_check_heap(c, heap, cat, -1); + return 0; /* Not added to heap */ + } else { + lprops->hpos = heap->cnt++; + heap->arr[lprops->hpos] = lprops; + move_up_lpt_heap(c, heap, lprops, cat); + dbg_check_heap(c, heap, cat, lprops->hpos); + return 1; /* Added to heap */ + } +} + +/** + * remove_from_lpt_heap - remove LEB properties from a LEB category heap. + * @c: UBIFS file-system description object + * @lprops: LEB properties to remove + * @cat: LEB category + */ +static void remove_from_lpt_heap(struct ubifs_info *c, + struct ubifs_lprops *lprops, int cat) +{ + struct ubifs_lpt_heap *heap; + int hpos = lprops->hpos; + + heap = &c->lpt_heap[cat - 1]; + ubifs_assert(hpos >= 0 && hpos < heap->cnt); + ubifs_assert(heap->arr[hpos] == lprops); + heap->cnt -= 1; + if (hpos < heap->cnt) { + heap->arr[hpos] = heap->arr[heap->cnt]; + heap->arr[hpos]->hpos = hpos; + adjust_lpt_heap(c, heap, heap->arr[hpos], hpos, cat); + } + dbg_check_heap(c, heap, cat, -1); +} + +/** + * lpt_heap_replace - replace lprops in a category heap. + * @c: UBIFS file-system description object + * @old_lprops: LEB properties to replace + * @new_lprops: LEB properties with which to replace + * @cat: LEB category + * + * During commit it is sometimes necessary to copy a pnode (see dirty_cow_pnode) + * and the lprops that the pnode contains. When that happens, references in + * the category heaps to those lprops must be updated to point to the new + * lprops. This function does that. + */ +static void lpt_heap_replace(struct ubifs_info *c, + struct ubifs_lprops *old_lprops, + struct ubifs_lprops *new_lprops, int cat) +{ + struct ubifs_lpt_heap *heap; + int hpos = new_lprops->hpos; + + heap = &c->lpt_heap[cat - 1]; + heap->arr[hpos] = new_lprops; +} + +/** + * ubifs_add_to_cat - add LEB properties to a category list or heap. + * @c: UBIFS file-system description object + * @lprops: LEB properties to add + * @cat: LEB category to which to add + * + * LEB properties are categorized to enable fast find operations. + */ +void ubifs_add_to_cat(struct ubifs_info *c, struct ubifs_lprops *lprops, + int cat) +{ + switch (cat) { + case LPROPS_DIRTY: + case LPROPS_DIRTY_IDX: + case LPROPS_FREE: + if (add_to_lpt_heap(c, lprops, cat)) + break; + /* No more room on heap so make it uncategorized */ + cat = LPROPS_UNCAT; + /* Fall through */ + case LPROPS_UNCAT: + list_add(&lprops->list, &c->uncat_list); + break; + case LPROPS_EMPTY: + list_add(&lprops->list, &c->empty_list); + break; + case LPROPS_FREEABLE: + list_add(&lprops->list, &c->freeable_list); + c->freeable_cnt += 1; + break; + case LPROPS_FRDI_IDX: + list_add(&lprops->list, &c->frdi_idx_list); + break; + default: + ubifs_assert(0); + } + lprops->flags &= ~LPROPS_CAT_MASK; + lprops->flags |= cat; +} + +/** + * ubifs_remove_from_cat - remove LEB properties from a category list or heap. + * @c: UBIFS file-system description object + * @lprops: LEB properties to remove + * @cat: LEB category from which to remove + * + * LEB properties are categorized to enable fast find operations. + */ +static void ubifs_remove_from_cat(struct ubifs_info *c, + struct ubifs_lprops *lprops, int cat) +{ + switch (cat) { + case LPROPS_DIRTY: + case LPROPS_DIRTY_IDX: + case LPROPS_FREE: + remove_from_lpt_heap(c, lprops, cat); + break; + case LPROPS_FREEABLE: + c->freeable_cnt -= 1; + ubifs_assert(c->freeable_cnt >= 0); + /* Fall through */ + case LPROPS_UNCAT: + case LPROPS_EMPTY: + case LPROPS_FRDI_IDX: + ubifs_assert(!list_empty(&lprops->list)); + list_del(&lprops->list); + break; + default: + ubifs_assert(0); + } +} + +/** + * ubifs_replace_cat - replace lprops in a category list or heap. + * @c: UBIFS file-system description object + * @old_lprops: LEB properties to replace + * @new_lprops: LEB properties with which to replace + * + * During commit it is sometimes necessary to copy a pnode (see dirty_cow_pnode) + * and the lprops that the pnode contains. When that happens, references in + * category lists and heaps must be replaced. This function does that. + */ +void ubifs_replace_cat(struct ubifs_info *c, struct ubifs_lprops *old_lprops, + struct ubifs_lprops *new_lprops) +{ + int cat; + + cat = new_lprops->flags & LPROPS_CAT_MASK; + switch (cat) { + case LPROPS_DIRTY: + case LPROPS_DIRTY_IDX: + case LPROPS_FREE: + lpt_heap_replace(c, old_lprops, new_lprops, cat); + break; + case LPROPS_UNCAT: + case LPROPS_EMPTY: + case LPROPS_FREEABLE: + case LPROPS_FRDI_IDX: + list_replace(&old_lprops->list, &new_lprops->list); + break; + default: + ubifs_assert(0); + } +} + +/** + * ubifs_ensure_cat - ensure LEB properties are categorized. + * @c: UBIFS file-system description object + * @lprops: LEB properties + * + * A LEB may have fallen off of the bottom of a heap, and ended up as + * uncategorized even though it has enough space for us now. If that is the case + * this function will put the LEB back onto a heap. + */ +void ubifs_ensure_cat(struct ubifs_info *c, struct ubifs_lprops *lprops) +{ + int cat = lprops->flags & LPROPS_CAT_MASK; + + if (cat != LPROPS_UNCAT) + return; + cat = ubifs_categorize_lprops(c, lprops); + if (cat == LPROPS_UNCAT) + return; + ubifs_remove_from_cat(c, lprops, LPROPS_UNCAT); + ubifs_add_to_cat(c, lprops, cat); +} + +/** + * ubifs_categorize_lprops - categorize LEB properties. + * @c: UBIFS file-system description object + * @lprops: LEB properties to categorize + * + * LEB properties are categorized to enable fast find operations. This function + * returns the LEB category to which the LEB properties belong. Note however + * that if the LEB category is stored as a heap and the heap is full, the + * LEB properties may have their category changed to %LPROPS_UNCAT. + */ +int ubifs_categorize_lprops(const struct ubifs_info *c, + const struct ubifs_lprops *lprops) +{ + if (lprops->flags & LPROPS_TAKEN) + return LPROPS_UNCAT; + + if (lprops->free == c->leb_size) { + ubifs_assert(!(lprops->flags & LPROPS_INDEX)); + return LPROPS_EMPTY; + } + + if (lprops->free + lprops->dirty == c->leb_size) { + if (lprops->flags & LPROPS_INDEX) + return LPROPS_FRDI_IDX; + else + return LPROPS_FREEABLE; + } + + if (lprops->flags & LPROPS_INDEX) { + if (lprops->dirty + lprops->free >= c->min_idx_node_sz) + return LPROPS_DIRTY_IDX; + } else { + if (lprops->dirty >= c->dead_wm && + lprops->dirty > lprops->free) + return LPROPS_DIRTY; + if (lprops->free > 0) + return LPROPS_FREE; + } + + return LPROPS_UNCAT; +} + +/** + * change_category - change LEB properties category. + * @c: UBIFS file-system description object + * @lprops: LEB properties to recategorize + * + * LEB properties are categorized to enable fast find operations. When the LEB + * properties change they must be recategorized. + */ +static void change_category(struct ubifs_info *c, struct ubifs_lprops *lprops) +{ + int old_cat = lprops->flags & LPROPS_CAT_MASK; + int new_cat = ubifs_categorize_lprops(c, lprops); + + if (old_cat == new_cat) { + struct ubifs_lpt_heap *heap = &c->lpt_heap[new_cat - 1]; + + /* lprops on a heap now must be moved up or down */ + if (new_cat < 1 || new_cat > LPROPS_HEAP_CNT) + return; /* Not on a heap */ + heap = &c->lpt_heap[new_cat - 1]; + adjust_lpt_heap(c, heap, lprops, lprops->hpos, new_cat); + } else { + ubifs_remove_from_cat(c, lprops, old_cat); + ubifs_add_to_cat(c, lprops, new_cat); + } +} + +/** + * calc_dark - calculate LEB dark space size. + * @c: the UBIFS file-system description object + * @spc: amount of free and dirty space in the LEB + * + * This function calculates amount of dark space in an LEB which has @spc bytes + * of free and dirty space. Returns the calculations result. + * + * Dark space is the space which is not always usable - it depends on which + * nodes are written in which order. E.g., if an LEB has only 512 free bytes, + * it is dark space, because it cannot fit a large data node. So UBIFS cannot + * count on this LEB and treat these 512 bytes as usable because it is not true + * if, for example, only big chunks of uncompressible data will be written to + * the FS. + */ +static int calc_dark(struct ubifs_info *c, int spc) +{ + ubifs_assert(!(spc & 7)); + + if (spc < c->dark_wm) + return spc; + + /* + * If we have slightly more space then the dark space watermark, we can + * anyway safely assume it we'll be able to write a node of the + * smallest size there. + */ + if (spc - c->dark_wm < MIN_WRITE_SZ) + return spc - MIN_WRITE_SZ; + + return c->dark_wm; +} + +/** + * is_lprops_dirty - determine if LEB properties are dirty. + * @c: the UBIFS file-system description object + * @lprops: LEB properties to test + */ +static int is_lprops_dirty(struct ubifs_info *c, struct ubifs_lprops *lprops) +{ + struct ubifs_pnode *pnode; + int pos; + + pos = (lprops->lnum - c->main_first) & (UBIFS_LPT_FANOUT - 1); + pnode = (struct ubifs_pnode *)container_of(lprops - pos, + struct ubifs_pnode, + lprops[0]); + return !test_bit(COW_ZNODE, &pnode->flags) && + test_bit(DIRTY_CNODE, &pnode->flags); +} + +/** + * ubifs_change_lp - change LEB properties. + * @c: the UBIFS file-system description object + * @lp: LEB properties to change + * @free: new free space amount + * @dirty: new dirty space amount + * @flags: new flags + * @idx_gc_cnt: change to the count of idx_gc list + * + * This function changes LEB properties (@free, @dirty or @flag). However, the + * property which has the %LPROPS_NC value is not changed. Returns a pointer to + * the updated LEB properties on success and a negative error code on failure. + * + * Note, the LEB properties may have had to be copied (due to COW) and + * consequently the pointer returned may not be the same as the pointer + * passed. + */ +const struct ubifs_lprops *ubifs_change_lp(struct ubifs_info *c, + const struct ubifs_lprops *lp, + int free, int dirty, int flags, + int idx_gc_cnt) +{ + /* + * This is the only function that is allowed to change lprops, so we + * discard the const qualifier. + */ + struct ubifs_lprops *lprops = (struct ubifs_lprops *)lp; + + dbg_lp("LEB %d, free %d, dirty %d, flags %d", + lprops->lnum, free, dirty, flags); + + ubifs_assert(mutex_is_locked(&c->lp_mutex)); + ubifs_assert(c->lst.empty_lebs >= 0 && + c->lst.empty_lebs <= c->main_lebs); + ubifs_assert(c->freeable_cnt >= 0); + ubifs_assert(c->freeable_cnt <= c->main_lebs); + ubifs_assert(c->lst.taken_empty_lebs >= 0); + ubifs_assert(c->lst.taken_empty_lebs <= c->lst.empty_lebs); + ubifs_assert(!(c->lst.total_free & 7) && !(c->lst.total_dirty & 7)); + ubifs_assert(!(c->lst.total_dead & 7) && !(c->lst.total_dark & 7)); + ubifs_assert(!(c->lst.total_used & 7)); + ubifs_assert(free == LPROPS_NC || free >= 0); + ubifs_assert(dirty == LPROPS_NC || dirty >= 0); + + if (!is_lprops_dirty(c, lprops)) { + lprops = ubifs_lpt_lookup_dirty(c, lprops->lnum); + if (IS_ERR(lprops)) + return lprops; + } else + ubifs_assert(lprops == ubifs_lpt_lookup_dirty(c, lprops->lnum)); + + ubifs_assert(!(lprops->free & 7) && !(lprops->dirty & 7)); + + spin_lock(&c->space_lock); + if ((lprops->flags & LPROPS_TAKEN) && lprops->free == c->leb_size) + c->lst.taken_empty_lebs -= 1; + + if (!(lprops->flags & LPROPS_INDEX)) { + int old_spc; + + old_spc = lprops->free + lprops->dirty; + if (old_spc < c->dead_wm) + c->lst.total_dead -= old_spc; + else + c->lst.total_dark -= calc_dark(c, old_spc); + + c->lst.total_used -= c->leb_size - old_spc; + } + + if (free != LPROPS_NC) { + free = ALIGN(free, 8); + c->lst.total_free += free - lprops->free; + + /* Increase or decrease empty LEBs counter if needed */ + if (free == c->leb_size) { + if (lprops->free != c->leb_size) + c->lst.empty_lebs += 1; + } else if (lprops->free == c->leb_size) + c->lst.empty_lebs -= 1; + lprops->free = free; + } + + if (dirty != LPROPS_NC) { + dirty = ALIGN(dirty, 8); + c->lst.total_dirty += dirty - lprops->dirty; + lprops->dirty = dirty; + } + + if (flags != LPROPS_NC) { + /* Take care about indexing LEBs counter if needed */ + if ((lprops->flags & LPROPS_INDEX)) { + if (!(flags & LPROPS_INDEX)) + c->lst.idx_lebs -= 1; + } else if (flags & LPROPS_INDEX) + c->lst.idx_lebs += 1; + lprops->flags = flags; + } + + if (!(lprops->flags & LPROPS_INDEX)) { + int new_spc; + + new_spc = lprops->free + lprops->dirty; + if (new_spc < c->dead_wm) + c->lst.total_dead += new_spc; + else + c->lst.total_dark += calc_dark(c, new_spc); + + c->lst.total_used += c->leb_size - new_spc; + } + + if ((lprops->flags & LPROPS_TAKEN) && lprops->free == c->leb_size) + c->lst.taken_empty_lebs += 1; + + change_category(c, lprops); + c->idx_gc_cnt += idx_gc_cnt; + spin_unlock(&c->space_lock); + return lprops; +} + +/** + * ubifs_get_lp_stats - get lprops statistics. + * @c: UBIFS file-system description object + * @st: return statistics + */ +void ubifs_get_lp_stats(struct ubifs_info *c, struct ubifs_lp_stats *lst) +{ + spin_lock(&c->space_lock); + memcpy(lst, &c->lst, sizeof(struct ubifs_lp_stats)); + spin_unlock(&c->space_lock); +} + +/** + * ubifs_change_one_lp - change LEB properties. + * @c: the UBIFS file-system description object + * @lnum: LEB to change properties for + * @free: amount of free space + * @dirty: amount of dirty space + * @flags_set: flags to set + * @flags_clean: flags to clean + * @idx_gc_cnt: change to the count of idx_gc list + * + * This function changes properties of LEB @lnum. It is a helper wrapper over + * 'ubifs_change_lp()' which hides lprops get/release. The arguments are the + * same as in case of 'ubifs_change_lp()'. Returns zero in case of success and + * a negative error code in case of failure. + */ +int ubifs_change_one_lp(struct ubifs_info *c, int lnum, int free, int dirty, + int flags_set, int flags_clean, int idx_gc_cnt) +{ + int err = 0, flags; + const struct ubifs_lprops *lp; + + ubifs_get_lprops(c); + + lp = ubifs_lpt_lookup_dirty(c, lnum); + if (IS_ERR(lp)) { + err = PTR_ERR(lp); + goto out; + } + + flags = (lp->flags | flags_set) & ~flags_clean; + lp = ubifs_change_lp(c, lp, free, dirty, flags, idx_gc_cnt); + if (IS_ERR(lp)) + err = PTR_ERR(lp); + +out: + ubifs_release_lprops(c); + return err; +} + +/** + * ubifs_update_one_lp - update LEB properties. + * @c: the UBIFS file-system description object + * @lnum: LEB to change properties for + * @free: amount of free space + * @dirty: amount of dirty space to add + * @flags_set: flags to set + * @flags_clean: flags to clean + * + * This function is the same as 'ubifs_change_one_lp()' but @dirty is added to + * current dirty space, not substitutes it. + */ +int ubifs_update_one_lp(struct ubifs_info *c, int lnum, int free, int dirty, + int flags_set, int flags_clean) +{ + int err = 0, flags; + const struct ubifs_lprops *lp; + + ubifs_get_lprops(c); + + lp = ubifs_lpt_lookup_dirty(c, lnum); + if (IS_ERR(lp)) { + err = PTR_ERR(lp); + goto out; + } + + flags = (lp->flags | flags_set) & ~flags_clean; + lp = ubifs_change_lp(c, lp, free, lp->dirty + dirty, flags, 0); + if (IS_ERR(lp)) + err = PTR_ERR(lp); + +out: + ubifs_release_lprops(c); + return err; +} + +/** + * ubifs_read_one_lp - read LEB properties. + * @c: the UBIFS file-system description object + * @lnum: LEB to read properties for + * @lp: where to store read properties + * + * This helper function reads properties of a LEB @lnum and stores them in @lp. + * Returns zero in case of success and a negative error code in case of + * failure. + */ +int ubifs_read_one_lp(struct ubifs_info *c, int lnum, struct ubifs_lprops *lp) +{ + int err = 0; + const struct ubifs_lprops *lpp; + + ubifs_get_lprops(c); + + lpp = ubifs_lpt_lookup(c, lnum); + if (IS_ERR(lpp)) { + err = PTR_ERR(lpp); + goto out; + } + + memcpy(lp, lpp, sizeof(struct ubifs_lprops)); + +out: + ubifs_release_lprops(c); + return err; +} + +/** + * ubifs_fast_find_free - try to find a LEB with free space quickly. + * @c: the UBIFS file-system description object + * + * This function returns LEB properties for a LEB with free space or %NULL if + * the function is unable to find a LEB quickly. + */ +const struct ubifs_lprops *ubifs_fast_find_free(struct ubifs_info *c) +{ + struct ubifs_lprops *lprops; + struct ubifs_lpt_heap *heap; + + ubifs_assert(mutex_is_locked(&c->lp_mutex)); + + heap = &c->lpt_heap[LPROPS_FREE - 1]; + if (heap->cnt == 0) + return NULL; + + lprops = heap->arr[0]; + ubifs_assert(!(lprops->flags & LPROPS_TAKEN)); + ubifs_assert(!(lprops->flags & LPROPS_INDEX)); + return lprops; +} + +/** + * ubifs_fast_find_empty - try to find an empty LEB quickly. + * @c: the UBIFS file-system description object + * + * This function returns LEB properties for an empty LEB or %NULL if the + * function is unable to find an empty LEB quickly. + */ +const struct ubifs_lprops *ubifs_fast_find_empty(struct ubifs_info *c) +{ + struct ubifs_lprops *lprops; + + ubifs_assert(mutex_is_locked(&c->lp_mutex)); + + if (list_empty(&c->empty_list)) + return NULL; + + lprops = list_entry(c->empty_list.next, struct ubifs_lprops, list); + ubifs_assert(!(lprops->flags & LPROPS_TAKEN)); + ubifs_assert(!(lprops->flags & LPROPS_INDEX)); + ubifs_assert(lprops->free == c->leb_size); + return lprops; +} + +/** + * ubifs_fast_find_freeable - try to find a freeable LEB quickly. + * @c: the UBIFS file-system description object + * + * This function returns LEB properties for a freeable LEB or %NULL if the + * function is unable to find a freeable LEB quickly. + */ +const struct ubifs_lprops *ubifs_fast_find_freeable(struct ubifs_info *c) +{ + struct ubifs_lprops *lprops; + + ubifs_assert(mutex_is_locked(&c->lp_mutex)); + + if (list_empty(&c->freeable_list)) + return NULL; + + lprops = list_entry(c->freeable_list.next, struct ubifs_lprops, list); + ubifs_assert(!(lprops->flags & LPROPS_TAKEN)); + ubifs_assert(!(lprops->flags & LPROPS_INDEX)); + ubifs_assert(lprops->free + lprops->dirty == c->leb_size); + ubifs_assert(c->freeable_cnt > 0); + return lprops; +} + +/** + * ubifs_fast_find_frdi_idx - try to find a freeable index LEB quickly. + * @c: the UBIFS file-system description object + * + * This function returns LEB properties for a freeable index LEB or %NULL if the + * function is unable to find a freeable index LEB quickly. + */ +const struct ubifs_lprops *ubifs_fast_find_frdi_idx(struct ubifs_info *c) +{ + struct ubifs_lprops *lprops; + + ubifs_assert(mutex_is_locked(&c->lp_mutex)); + + if (list_empty(&c->frdi_idx_list)) + return NULL; + + lprops = list_entry(c->frdi_idx_list.next, struct ubifs_lprops, list); + ubifs_assert(!(lprops->flags & LPROPS_TAKEN)); + ubifs_assert((lprops->flags & LPROPS_INDEX)); + ubifs_assert(lprops->free + lprops->dirty == c->leb_size); + return lprops; +} diff --git a/fs/ubifs/lpt.c b/fs/ubifs/lpt.c new file mode 100644 index 0000000..1a50d4c --- /dev/null +++ b/fs/ubifs/lpt.c @@ -0,0 +1,1105 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Adrian Hunter + * Artem Bityutskiy (Битюцкий Артём) + */ + +/* + * This file implements the LEB properties tree (LPT) area. The LPT area + * contains the LEB properties tree, a table of LPT area eraseblocks (ltab), and + * (for the "big" model) a table of saved LEB numbers (lsave). The LPT area sits + * between the log and the orphan area. + * + * The LPT area is like a miniature self-contained file system. It is required + * that it never runs out of space, is fast to access and update, and scales + * logarithmically. The LEB properties tree is implemented as a wandering tree + * much like the TNC, and the LPT area has its own garbage collection. + * + * The LPT has two slightly different forms called the "small model" and the + * "big model". The small model is used when the entire LEB properties table + * can be written into a single eraseblock. In that case, garbage collection + * consists of just writing the whole table, which therefore makes all other + * eraseblocks reusable. In the case of the big model, dirty eraseblocks are + * selected for garbage collection, which consists of marking the clean nodes in + * that LEB as dirty, and then only the dirty nodes are written out. Also, in + * the case of the big model, a table of LEB numbers is saved so that the entire + * LPT does not to be scanned looking for empty eraseblocks when UBIFS is first + * mounted. + */ + +#include "ubifs.h" +#include "crc16.h" +#include <linux/math64.h> + +/** + * do_calc_lpt_geom - calculate sizes for the LPT area. + * @c: the UBIFS file-system description object + * + * Calculate the sizes of LPT bit fields, nodes, and tree, based on the + * properties of the flash and whether LPT is "big" (c->big_lpt). + */ +static void do_calc_lpt_geom(struct ubifs_info *c) +{ + int i, n, bits, per_leb_wastage, max_pnode_cnt; + long long sz, tot_wastage; + + n = c->main_lebs + c->max_leb_cnt - c->leb_cnt; + max_pnode_cnt = DIV_ROUND_UP(n, UBIFS_LPT_FANOUT); + + c->lpt_hght = 1; + n = UBIFS_LPT_FANOUT; + while (n < max_pnode_cnt) { + c->lpt_hght += 1; + n <<= UBIFS_LPT_FANOUT_SHIFT; + } + + c->pnode_cnt = DIV_ROUND_UP(c->main_lebs, UBIFS_LPT_FANOUT); + + n = DIV_ROUND_UP(c->pnode_cnt, UBIFS_LPT_FANOUT); + c->nnode_cnt = n; + for (i = 1; i < c->lpt_hght; i++) { + n = DIV_ROUND_UP(n, UBIFS_LPT_FANOUT); + c->nnode_cnt += n; + } + + c->space_bits = fls(c->leb_size) - 3; + c->lpt_lnum_bits = fls(c->lpt_lebs); + c->lpt_offs_bits = fls(c->leb_size - 1); + c->lpt_spc_bits = fls(c->leb_size); + + n = DIV_ROUND_UP(c->max_leb_cnt, UBIFS_LPT_FANOUT); + c->pcnt_bits = fls(n - 1); + + c->lnum_bits = fls(c->max_leb_cnt - 1); + + bits = UBIFS_LPT_CRC_BITS + UBIFS_LPT_TYPE_BITS + + (c->big_lpt ? c->pcnt_bits : 0) + + (c->space_bits * 2 + 1) * UBIFS_LPT_FANOUT; + c->pnode_sz = (bits + 7) / 8; + + bits = UBIFS_LPT_CRC_BITS + UBIFS_LPT_TYPE_BITS + + (c->big_lpt ? c->pcnt_bits : 0) + + (c->lpt_lnum_bits + c->lpt_offs_bits) * UBIFS_LPT_FANOUT; + c->nnode_sz = (bits + 7) / 8; + + bits = UBIFS_LPT_CRC_BITS + UBIFS_LPT_TYPE_BITS + + c->lpt_lebs * c->lpt_spc_bits * 2; + c->ltab_sz = (bits + 7) / 8; + + bits = UBIFS_LPT_CRC_BITS + UBIFS_LPT_TYPE_BITS + + c->lnum_bits * c->lsave_cnt; + c->lsave_sz = (bits + 7) / 8; + + /* Calculate the minimum LPT size */ + c->lpt_sz = (long long)c->pnode_cnt * c->pnode_sz; + c->lpt_sz += (long long)c->nnode_cnt * c->nnode_sz; + c->lpt_sz += c->ltab_sz; + if (c->big_lpt) + c->lpt_sz += c->lsave_sz; + + /* Add wastage */ + sz = c->lpt_sz; + per_leb_wastage = max_t(int, c->pnode_sz, c->nnode_sz); + sz += per_leb_wastage; + tot_wastage = per_leb_wastage; + while (sz > c->leb_size) { + sz += per_leb_wastage; + sz -= c->leb_size; + tot_wastage += per_leb_wastage; + } + tot_wastage += ALIGN(sz, c->min_io_size) - sz; + c->lpt_sz += tot_wastage; +} + +/** + * ubifs_calc_lpt_geom - calculate and check sizes for the LPT area. + * @c: the UBIFS file-system description object + * + * This function returns %0 on success and a negative error code on failure. + */ +int ubifs_calc_lpt_geom(struct ubifs_info *c) +{ + int lebs_needed; + long long sz; + + do_calc_lpt_geom(c); + + /* Verify that lpt_lebs is big enough */ + sz = c->lpt_sz * 2; /* Must have at least 2 times the size */ + lebs_needed = div_u64(sz + c->leb_size - 1, c->leb_size); + if (lebs_needed > c->lpt_lebs) { + ubifs_err("too few LPT LEBs"); + return -EINVAL; + } + + /* Verify that ltab fits in a single LEB (since ltab is a single node */ + if (c->ltab_sz > c->leb_size) { + ubifs_err("LPT ltab too big"); + return -EINVAL; + } + + c->check_lpt_free = c->big_lpt; + return 0; +} + +/** + * ubifs_unpack_bits - unpack bit fields. + * @addr: address at which to unpack (passed and next address returned) + * @pos: bit position at which to unpack (passed and next position returned) + * @nrbits: number of bits of value to unpack (1-32) + * + * This functions returns the value unpacked. + */ +uint32_t ubifs_unpack_bits(uint8_t **addr, int *pos, int nrbits) +{ + const int k = 32 - nrbits; + uint8_t *p = *addr; + int b = *pos; + uint32_t uninitialized_var(val); + const int bytes = (nrbits + b + 7) >> 3; + + ubifs_assert(nrbits > 0); + ubifs_assert(nrbits <= 32); + ubifs_assert(*pos >= 0); + ubifs_assert(*pos < 8); + if (b) { + switch (bytes) { + case 2: + val = p[1]; + break; + case 3: + val = p[1] | ((uint32_t)p[2] << 8); + break; + case 4: + val = p[1] | ((uint32_t)p[2] << 8) | + ((uint32_t)p[3] << 16); + break; + case 5: + val = p[1] | ((uint32_t)p[2] << 8) | + ((uint32_t)p[3] << 16) | + ((uint32_t)p[4] << 24); + } + val <<= (8 - b); + val |= *p >> b; + nrbits += b; + } else { + switch (bytes) { + case 1: + val = p[0]; + break; + case 2: + val = p[0] | ((uint32_t)p[1] << 8); + break; + case 3: + val = p[0] | ((uint32_t)p[1] << 8) | + ((uint32_t)p[2] << 16); + break; + case 4: + val = p[0] | ((uint32_t)p[1] << 8) | + ((uint32_t)p[2] << 16) | + ((uint32_t)p[3] << 24); + break; + } + } + val <<= k; + val >>= k; + b = nrbits & 7; + p += nrbits >> 3; + *addr = p; + *pos = b; + ubifs_assert((val >> nrbits) == 0 || nrbits - b == 32); + return val; +} + +/** + * ubifs_add_lpt_dirt - add dirty space to LPT LEB properties. + * @c: UBIFS file-system description object + * @lnum: LEB number to which to add dirty space + * @dirty: amount of dirty space to add + */ +void ubifs_add_lpt_dirt(struct ubifs_info *c, int lnum, int dirty) +{ + if (!dirty || !lnum) + return; + dbg_lp("LEB %d add %d to %d", + lnum, dirty, c->ltab[lnum - c->lpt_first].dirty); + ubifs_assert(lnum >= c->lpt_first && lnum <= c->lpt_last); + c->ltab[lnum - c->lpt_first].dirty += dirty; +} + +/** + * ubifs_add_nnode_dirt - add dirty space to LPT LEB properties. + * @c: UBIFS file-system description object + * @nnode: nnode for which to add dirt + */ +void ubifs_add_nnode_dirt(struct ubifs_info *c, struct ubifs_nnode *nnode) +{ + struct ubifs_nnode *np = nnode->parent; + + if (np) + ubifs_add_lpt_dirt(c, np->nbranch[nnode->iip].lnum, + c->nnode_sz); + else { + ubifs_add_lpt_dirt(c, c->lpt_lnum, c->nnode_sz); + if (!(c->lpt_drty_flgs & LTAB_DIRTY)) { + c->lpt_drty_flgs |= LTAB_DIRTY; + ubifs_add_lpt_dirt(c, c->ltab_lnum, c->ltab_sz); + } + } +} + +/** + * add_pnode_dirt - add dirty space to LPT LEB properties. + * @c: UBIFS file-system description object + * @pnode: pnode for which to add dirt + */ +static void add_pnode_dirt(struct ubifs_info *c, struct ubifs_pnode *pnode) +{ + ubifs_add_lpt_dirt(c, pnode->parent->nbranch[pnode->iip].lnum, + c->pnode_sz); +} + +/** + * calc_nnode_num_from_parent - calculate nnode number. + * @c: UBIFS file-system description object + * @parent: parent nnode + * @iip: index in parent + * + * The nnode number is a number that uniquely identifies a nnode and can be used + * easily to traverse the tree from the root to that nnode. + * + * This function calculates and returns the nnode number based on the parent's + * nnode number and the index in parent. + */ +static int calc_nnode_num_from_parent(const struct ubifs_info *c, + struct ubifs_nnode *parent, int iip) +{ + int num, shft; + + if (!parent) + return 1; + shft = (c->lpt_hght - parent->level) * UBIFS_LPT_FANOUT_SHIFT; + num = parent->num ^ (1 << shft); + num |= (UBIFS_LPT_FANOUT + iip) << shft; + return num; +} + +/** + * calc_pnode_num_from_parent - calculate pnode number. + * @c: UBIFS file-system description object + * @parent: parent nnode + * @iip: index in parent + * + * The pnode number is a number that uniquely identifies a pnode and can be used + * easily to traverse the tree from the root to that pnode. + * + * This function calculates and returns the pnode number based on the parent's + * nnode number and the index in parent. + */ +static int calc_pnode_num_from_parent(const struct ubifs_info *c, + struct ubifs_nnode *parent, int iip) +{ + int i, n = c->lpt_hght - 1, pnum = parent->num, num = 0; + + for (i = 0; i < n; i++) { + num <<= UBIFS_LPT_FANOUT_SHIFT; + num |= pnum & (UBIFS_LPT_FANOUT - 1); + pnum >>= UBIFS_LPT_FANOUT_SHIFT; + } + num <<= UBIFS_LPT_FANOUT_SHIFT; + num |= iip; + return num; +} + +/** + * update_cats - add LEB properties of a pnode to LEB category lists and heaps. + * @c: UBIFS file-system description object + * @pnode: pnode + * + * When a pnode is loaded into memory, the LEB properties it contains are added, + * by this function, to the LEB category lists and heaps. + */ +static void update_cats(struct ubifs_info *c, struct ubifs_pnode *pnode) +{ + int i; + + for (i = 0; i < UBIFS_LPT_FANOUT; i++) { + int cat = pnode->lprops[i].flags & LPROPS_CAT_MASK; + int lnum = pnode->lprops[i].lnum; + + if (!lnum) + return; + ubifs_add_to_cat(c, &pnode->lprops[i], cat); + } +} + +/** + * replace_cats - add LEB properties of a pnode to LEB category lists and heaps. + * @c: UBIFS file-system description object + * @old_pnode: pnode copied + * @new_pnode: pnode copy + * + * During commit it is sometimes necessary to copy a pnode + * (see dirty_cow_pnode). When that happens, references in + * category lists and heaps must be replaced. This function does that. + */ +static void replace_cats(struct ubifs_info *c, struct ubifs_pnode *old_pnode, + struct ubifs_pnode *new_pnode) +{ + int i; + + for (i = 0; i < UBIFS_LPT_FANOUT; i++) { + if (!new_pnode->lprops[i].lnum) + return; + ubifs_replace_cat(c, &old_pnode->lprops[i], + &new_pnode->lprops[i]); + } +} + +/** + * check_lpt_crc - check LPT node crc is correct. + * @c: UBIFS file-system description object + * @buf: buffer containing node + * @len: length of node + * + * This function returns %0 on success and a negative error code on failure. + */ +static int check_lpt_crc(void *buf, int len) +{ + int pos = 0; + uint8_t *addr = buf; + uint16_t crc, calc_crc; + + crc = ubifs_unpack_bits(&addr, &pos, UBIFS_LPT_CRC_BITS); + calc_crc = crc16(-1, buf + UBIFS_LPT_CRC_BYTES, + len - UBIFS_LPT_CRC_BYTES); + if (crc != calc_crc) { + ubifs_err("invalid crc in LPT node: crc %hx calc %hx", crc, + calc_crc); + dbg_dump_stack(); + return -EINVAL; + } + return 0; +} + +/** + * check_lpt_type - check LPT node type is correct. + * @c: UBIFS file-system description object + * @addr: address of type bit field is passed and returned updated here + * @pos: position of type bit field is passed and returned updated here + * @type: expected type + * + * This function returns %0 on success and a negative error code on failure. + */ +static int check_lpt_type(uint8_t **addr, int *pos, int type) +{ + int node_type; + + node_type = ubifs_unpack_bits(addr, pos, UBIFS_LPT_TYPE_BITS); + if (node_type != type) { + ubifs_err("invalid type (%d) in LPT node type %d", node_type, + type); + dbg_dump_stack(); + return -EINVAL; + } + return 0; +} + +/** + * unpack_pnode - unpack a pnode. + * @c: UBIFS file-system description object + * @buf: buffer containing packed pnode to unpack + * @pnode: pnode structure to fill + * + * This function returns %0 on success and a negative error code on failure. + */ +static int unpack_pnode(const struct ubifs_info *c, void *buf, + struct ubifs_pnode *pnode) +{ + uint8_t *addr = buf + UBIFS_LPT_CRC_BYTES; + int i, pos = 0, err; + + err = check_lpt_type(&addr, &pos, UBIFS_LPT_PNODE); + if (err) + return err; + if (c->big_lpt) + pnode->num = ubifs_unpack_bits(&addr, &pos, c->pcnt_bits); + for (i = 0; i < UBIFS_LPT_FANOUT; i++) { + struct ubifs_lprops * const lprops = &pnode->lprops[i]; + + lprops->free = ubifs_unpack_bits(&addr, &pos, c->space_bits); + lprops->free <<= 3; + lprops->dirty = ubifs_unpack_bits(&addr, &pos, c->space_bits); + lprops->dirty <<= 3; + + if (ubifs_unpack_bits(&addr, &pos, 1)) + lprops->flags = LPROPS_INDEX; + else + lprops->flags = 0; + lprops->flags |= ubifs_categorize_lprops(c, lprops); + } + err = check_lpt_crc(buf, c->pnode_sz); + return err; +} + +/** + * ubifs_unpack_nnode - unpack a nnode. + * @c: UBIFS file-system description object + * @buf: buffer containing packed nnode to unpack + * @nnode: nnode structure to fill + * + * This function returns %0 on success and a negative error code on failure. + */ +int ubifs_unpack_nnode(const struct ubifs_info *c, void *buf, + struct ubifs_nnode *nnode) +{ + uint8_t *addr = buf + UBIFS_LPT_CRC_BYTES; + int i, pos = 0, err; + + err = check_lpt_type(&addr, &pos, UBIFS_LPT_NNODE); + if (err) + return err; + if (c->big_lpt) + nnode->num = ubifs_unpack_bits(&addr, &pos, c->pcnt_bits); + for (i = 0; i < UBIFS_LPT_FANOUT; i++) { + int lnum; + + lnum = ubifs_unpack_bits(&addr, &pos, c->lpt_lnum_bits) + + c->lpt_first; + if (lnum == c->lpt_last + 1) + lnum = 0; + nnode->nbranch[i].lnum = lnum; + nnode->nbranch[i].offs = ubifs_unpack_bits(&addr, &pos, + c->lpt_offs_bits); + } + err = check_lpt_crc(buf, c->nnode_sz); + return err; +} + +/** + * unpack_ltab - unpack the LPT's own lprops table. + * @c: UBIFS file-system description object + * @buf: buffer from which to unpack + * + * This function returns %0 on success and a negative error code on failure. + */ +static int unpack_ltab(const struct ubifs_info *c, void *buf) +{ + uint8_t *addr = buf + UBIFS_LPT_CRC_BYTES; + int i, pos = 0, err; + + err = check_lpt_type(&addr, &pos, UBIFS_LPT_LTAB); + if (err) + return err; + for (i = 0; i < c->lpt_lebs; i++) { + int free = ubifs_unpack_bits(&addr, &pos, c->lpt_spc_bits); + int dirty = ubifs_unpack_bits(&addr, &pos, c->lpt_spc_bits); + + if (free < 0 || free > c->leb_size || dirty < 0 || + dirty > c->leb_size || free + dirty > c->leb_size) + return -EINVAL; + + c->ltab[i].free = free; + c->ltab[i].dirty = dirty; + c->ltab[i].tgc = 0; + c->ltab[i].cmt = 0; + } + err = check_lpt_crc(buf, c->ltab_sz); + return err; +} + +/** + * validate_nnode - validate a nnode. + * @c: UBIFS file-system description object + * @nnode: nnode to validate + * @parent: parent nnode (or NULL for the root nnode) + * @iip: index in parent + * + * This function returns %0 on success and a negative error code on failure. + */ +static int validate_nnode(const struct ubifs_info *c, struct ubifs_nnode *nnode, + struct ubifs_nnode *parent, int iip) +{ + int i, lvl, max_offs; + + if (c->big_lpt) { + int num = calc_nnode_num_from_parent(c, parent, iip); + + if (nnode->num != num) + return -EINVAL; + } + lvl = parent ? parent->level - 1 : c->lpt_hght; + if (lvl < 1) + return -EINVAL; + if (lvl == 1) + max_offs = c->leb_size - c->pnode_sz; + else + max_offs = c->leb_size - c->nnode_sz; + for (i = 0; i < UBIFS_LPT_FANOUT; i++) { + int lnum = nnode->nbranch[i].lnum; + int offs = nnode->nbranch[i].offs; + + if (lnum == 0) { + if (offs != 0) + return -EINVAL; + continue; + } + if (lnum < c->lpt_first || lnum > c->lpt_last) + return -EINVAL; + if (offs < 0 || offs > max_offs) + return -EINVAL; + } + return 0; +} + +/** + * validate_pnode - validate a pnode. + * @c: UBIFS file-system description object + * @pnode: pnode to validate + * @parent: parent nnode + * @iip: index in parent + * + * This function returns %0 on success and a negative error code on failure. + */ +static int validate_pnode(const struct ubifs_info *c, struct ubifs_pnode *pnode, + struct ubifs_nnode *parent, int iip) +{ + int i; + + if (c->big_lpt) { + int num = calc_pnode_num_from_parent(c, parent, iip); + + if (pnode->num != num) + return -EINVAL; + } + for (i = 0; i < UBIFS_LPT_FANOUT; i++) { + int free = pnode->lprops[i].free; + int dirty = pnode->lprops[i].dirty; + + if (free < 0 || free > c->leb_size || free % c->min_io_size || + (free & 7)) + return -EINVAL; + if (dirty < 0 || dirty > c->leb_size || (dirty & 7)) + return -EINVAL; + if (dirty + free > c->leb_size) + return -EINVAL; + } + return 0; +} + +/** + * set_pnode_lnum - set LEB numbers on a pnode. + * @c: UBIFS file-system description object + * @pnode: pnode to update + * + * This function calculates the LEB numbers for the LEB properties it contains + * based on the pnode number. + */ +static void set_pnode_lnum(const struct ubifs_info *c, + struct ubifs_pnode *pnode) +{ + int i, lnum; + + lnum = (pnode->num << UBIFS_LPT_FANOUT_SHIFT) + c->main_first; + for (i = 0; i < UBIFS_LPT_FANOUT; i++) { + if (lnum >= c->leb_cnt) + return; + pnode->lprops[i].lnum = lnum++; + } +} + +/** + * ubifs_read_nnode - read a nnode from flash and link it to the tree in memory. + * @c: UBIFS file-system description object + * @parent: parent nnode (or NULL for the root) + * @iip: index in parent + * + * This function returns %0 on success and a negative error code on failure. + */ +int ubifs_read_nnode(struct ubifs_info *c, struct ubifs_nnode *parent, int iip) +{ + struct ubifs_nbranch *branch = NULL; + struct ubifs_nnode *nnode = NULL; + void *buf = c->lpt_nod_buf; + int err, lnum, offs; + + if (parent) { + branch = &parent->nbranch[iip]; + lnum = branch->lnum; + offs = branch->offs; + } else { + lnum = c->lpt_lnum; + offs = c->lpt_offs; + } + nnode = kzalloc(sizeof(struct ubifs_nnode), GFP_NOFS); + if (!nnode) { + err = -ENOMEM; + goto out; + } + if (lnum == 0) { + /* + * This nnode was not written which just means that the LEB + * properties in the subtree below it describe empty LEBs. We + * make the nnode as though we had read it, which in fact means + * doing almost nothing. + */ + if (c->big_lpt) + nnode->num = calc_nnode_num_from_parent(c, parent, iip); + } else { + err = ubi_read(c->ubi, lnum, buf, offs, c->nnode_sz); + if (err) + goto out; + err = ubifs_unpack_nnode(c, buf, nnode); + if (err) + goto out; + } + err = validate_nnode(c, nnode, parent, iip); + if (err) + goto out; + if (!c->big_lpt) + nnode->num = calc_nnode_num_from_parent(c, parent, iip); + if (parent) { + branch->nnode = nnode; + nnode->level = parent->level - 1; + } else { + c->nroot = nnode; + nnode->level = c->lpt_hght; + } + nnode->parent = parent; + nnode->iip = iip; + return 0; + +out: + ubifs_err("error %d reading nnode at %d:%d", err, lnum, offs); + kfree(nnode); + return err; +} + +/** + * read_pnode - read a pnode from flash and link it to the tree in memory. + * @c: UBIFS file-system description object + * @parent: parent nnode + * @iip: index in parent + * + * This function returns %0 on success and a negative error code on failure. + */ +static int read_pnode(struct ubifs_info *c, struct ubifs_nnode *parent, int iip) +{ + struct ubifs_nbranch *branch; + struct ubifs_pnode *pnode = NULL; + void *buf = c->lpt_nod_buf; + int err, lnum, offs; + + branch = &parent->nbranch[iip]; + lnum = branch->lnum; + offs = branch->offs; + pnode = kzalloc(sizeof(struct ubifs_pnode), GFP_NOFS); + if (!pnode) { + err = -ENOMEM; + goto out; + } + if (lnum == 0) { + /* + * This pnode was not written which just means that the LEB + * properties in it describe empty LEBs. We make the pnode as + * though we had read it. + */ + int i; + + if (c->big_lpt) + pnode->num = calc_pnode_num_from_parent(c, parent, iip); + for (i = 0; i < UBIFS_LPT_FANOUT; i++) { + struct ubifs_lprops * const lprops = &pnode->lprops[i]; + + lprops->free = c->leb_size; + lprops->flags = ubifs_categorize_lprops(c, lprops); + } + } else { + err = ubi_read(c->ubi, lnum, buf, offs, c->pnode_sz); + if (err) + goto out; + err = unpack_pnode(c, buf, pnode); + if (err) + goto out; + } + err = validate_pnode(c, pnode, parent, iip); + if (err) + goto out; + if (!c->big_lpt) + pnode->num = calc_pnode_num_from_parent(c, parent, iip); + branch->pnode = pnode; + pnode->parent = parent; + pnode->iip = iip; + set_pnode_lnum(c, pnode); + c->pnodes_have += 1; + return 0; + +out: + ubifs_err("error %d reading pnode at %d:%d", err, lnum, offs); + dbg_dump_pnode(c, pnode, parent, iip); + dbg_msg("calc num: %d", calc_pnode_num_from_parent(c, parent, iip)); + kfree(pnode); + return err; +} + +/** + * read_ltab - read LPT's own lprops table. + * @c: UBIFS file-system description object + * + * This function returns %0 on success and a negative error code on failure. + */ +static int read_ltab(struct ubifs_info *c) +{ + int err; + void *buf; + + buf = vmalloc(c->ltab_sz); + if (!buf) + return -ENOMEM; + err = ubi_read(c->ubi, c->ltab_lnum, buf, c->ltab_offs, c->ltab_sz); + if (err) + goto out; + err = unpack_ltab(c, buf); +out: + vfree(buf); + return err; +} + +/** + * ubifs_get_nnode - get a nnode. + * @c: UBIFS file-system description object + * @parent: parent nnode (or NULL for the root) + * @iip: index in parent + * + * This function returns a pointer to the nnode on success or a negative error + * code on failure. + */ +struct ubifs_nnode *ubifs_get_nnode(struct ubifs_info *c, + struct ubifs_nnode *parent, int iip) +{ + struct ubifs_nbranch *branch; + struct ubifs_nnode *nnode; + int err; + + branch = &parent->nbranch[iip]; + nnode = branch->nnode; + if (nnode) + return nnode; + err = ubifs_read_nnode(c, parent, iip); + if (err) + return ERR_PTR(err); + return branch->nnode; +} + +/** + * ubifs_get_pnode - get a pnode. + * @c: UBIFS file-system description object + * @parent: parent nnode + * @iip: index in parent + * + * This function returns a pointer to the pnode on success or a negative error + * code on failure. + */ +struct ubifs_pnode *ubifs_get_pnode(struct ubifs_info *c, + struct ubifs_nnode *parent, int iip) +{ + struct ubifs_nbranch *branch; + struct ubifs_pnode *pnode; + int err; + + branch = &parent->nbranch[iip]; + pnode = branch->pnode; + if (pnode) + return pnode; + err = read_pnode(c, parent, iip); + if (err) + return ERR_PTR(err); + update_cats(c, branch->pnode); + return branch->pnode; +} + +/** + * ubifs_lpt_lookup - lookup LEB properties in the LPT. + * @c: UBIFS file-system description object + * @lnum: LEB number to lookup + * + * This function returns a pointer to the LEB properties on success or a + * negative error code on failure. + */ +struct ubifs_lprops *ubifs_lpt_lookup(struct ubifs_info *c, int lnum) +{ + int err, i, h, iip, shft; + struct ubifs_nnode *nnode; + struct ubifs_pnode *pnode; + + if (!c->nroot) { + err = ubifs_read_nnode(c, NULL, 0); + if (err) + return ERR_PTR(err); + } + nnode = c->nroot; + i = lnum - c->main_first; + shft = c->lpt_hght * UBIFS_LPT_FANOUT_SHIFT; + for (h = 1; h < c->lpt_hght; h++) { + iip = ((i >> shft) & (UBIFS_LPT_FANOUT - 1)); + shft -= UBIFS_LPT_FANOUT_SHIFT; + nnode = ubifs_get_nnode(c, nnode, iip); + if (IS_ERR(nnode)) + return ERR_PTR(PTR_ERR(nnode)); + } + iip = ((i >> shft) & (UBIFS_LPT_FANOUT - 1)); + shft -= UBIFS_LPT_FANOUT_SHIFT; + pnode = ubifs_get_pnode(c, nnode, iip); + if (IS_ERR(pnode)) + return ERR_PTR(PTR_ERR(pnode)); + iip = (i & (UBIFS_LPT_FANOUT - 1)); + dbg_lp("LEB %d, free %d, dirty %d, flags %d", lnum, + pnode->lprops[iip].free, pnode->lprops[iip].dirty, + pnode->lprops[iip].flags); + return &pnode->lprops[iip]; +} + +/** + * dirty_cow_nnode - ensure a nnode is not being committed. + * @c: UBIFS file-system description object + * @nnode: nnode to check + * + * Returns dirtied nnode on success or negative error code on failure. + */ +static struct ubifs_nnode *dirty_cow_nnode(struct ubifs_info *c, + struct ubifs_nnode *nnode) +{ + struct ubifs_nnode *n; + int i; + + if (!test_bit(COW_CNODE, &nnode->flags)) { + /* nnode is not being committed */ + if (!test_and_set_bit(DIRTY_CNODE, &nnode->flags)) { + c->dirty_nn_cnt += 1; + ubifs_add_nnode_dirt(c, nnode); + } + return nnode; + } + + /* nnode is being committed, so copy it */ + n = kmalloc(sizeof(struct ubifs_nnode), GFP_NOFS); + if (unlikely(!n)) + return ERR_PTR(-ENOMEM); + + memcpy(n, nnode, sizeof(struct ubifs_nnode)); + n->cnext = NULL; + __set_bit(DIRTY_CNODE, &n->flags); + __clear_bit(COW_CNODE, &n->flags); + + /* The children now have new parent */ + for (i = 0; i < UBIFS_LPT_FANOUT; i++) { + struct ubifs_nbranch *branch = &n->nbranch[i]; + + if (branch->cnode) + branch->cnode->parent = n; + } + + ubifs_assert(!test_bit(OBSOLETE_CNODE, &nnode->flags)); + __set_bit(OBSOLETE_CNODE, &nnode->flags); + + c->dirty_nn_cnt += 1; + ubifs_add_nnode_dirt(c, nnode); + if (nnode->parent) + nnode->parent->nbranch[n->iip].nnode = n; + else + c->nroot = n; + return n; +} + +/** + * dirty_cow_pnode - ensure a pnode is not being committed. + * @c: UBIFS file-system description object + * @pnode: pnode to check + * + * Returns dirtied pnode on success or negative error code on failure. + */ +static struct ubifs_pnode *dirty_cow_pnode(struct ubifs_info *c, + struct ubifs_pnode *pnode) +{ + struct ubifs_pnode *p; + + if (!test_bit(COW_CNODE, &pnode->flags)) { + /* pnode is not being committed */ + if (!test_and_set_bit(DIRTY_CNODE, &pnode->flags)) { + c->dirty_pn_cnt += 1; + add_pnode_dirt(c, pnode); + } + return pnode; + } + + /* pnode is being committed, so copy it */ + p = kmalloc(sizeof(struct ubifs_pnode), GFP_NOFS); + if (unlikely(!p)) + return ERR_PTR(-ENOMEM); + + memcpy(p, pnode, sizeof(struct ubifs_pnode)); + p->cnext = NULL; + __set_bit(DIRTY_CNODE, &p->flags); + __clear_bit(COW_CNODE, &p->flags); + replace_cats(c, pnode, p); + + ubifs_assert(!test_bit(OBSOLETE_CNODE, &pnode->flags)); + __set_bit(OBSOLETE_CNODE, &pnode->flags); + + c->dirty_pn_cnt += 1; + add_pnode_dirt(c, pnode); + pnode->parent->nbranch[p->iip].pnode = p; + return p; +} + +/** + * ubifs_lpt_lookup_dirty - lookup LEB properties in the LPT. + * @c: UBIFS file-system description object + * @lnum: LEB number to lookup + * + * This function returns a pointer to the LEB properties on success or a + * negative error code on failure. + */ +struct ubifs_lprops *ubifs_lpt_lookup_dirty(struct ubifs_info *c, int lnum) +{ + int err, i, h, iip, shft; + struct ubifs_nnode *nnode; + struct ubifs_pnode *pnode; + + if (!c->nroot) { + err = ubifs_read_nnode(c, NULL, 0); + if (err) + return ERR_PTR(err); + } + nnode = c->nroot; + nnode = dirty_cow_nnode(c, nnode); + if (IS_ERR(nnode)) + return ERR_PTR(PTR_ERR(nnode)); + i = lnum - c->main_first; + shft = c->lpt_hght * UBIFS_LPT_FANOUT_SHIFT; + for (h = 1; h < c->lpt_hght; h++) { + iip = ((i >> shft) & (UBIFS_LPT_FANOUT - 1)); + shft -= UBIFS_LPT_FANOUT_SHIFT; + nnode = ubifs_get_nnode(c, nnode, iip); + if (IS_ERR(nnode)) + return ERR_PTR(PTR_ERR(nnode)); + nnode = dirty_cow_nnode(c, nnode); + if (IS_ERR(nnode)) + return ERR_PTR(PTR_ERR(nnode)); + } + iip = ((i >> shft) & (UBIFS_LPT_FANOUT - 1)); + shft -= UBIFS_LPT_FANOUT_SHIFT; + pnode = ubifs_get_pnode(c, nnode, iip); + if (IS_ERR(pnode)) + return ERR_PTR(PTR_ERR(pnode)); + pnode = dirty_cow_pnode(c, pnode); + if (IS_ERR(pnode)) + return ERR_PTR(PTR_ERR(pnode)); + iip = (i & (UBIFS_LPT_FANOUT - 1)); + dbg_lp("LEB %d, free %d, dirty %d, flags %d", lnum, + pnode->lprops[iip].free, pnode->lprops[iip].dirty, + pnode->lprops[iip].flags); + ubifs_assert(test_bit(DIRTY_CNODE, &pnode->flags)); + return &pnode->lprops[iip]; +} + +/** + * lpt_init_rd - initialize the LPT for reading. + * @c: UBIFS file-system description object + * + * This function returns %0 on success and a negative error code on failure. + */ +static int lpt_init_rd(struct ubifs_info *c) +{ + int err, i; + + c->ltab = vmalloc(sizeof(struct ubifs_lpt_lprops) * c->lpt_lebs); + if (!c->ltab) + return -ENOMEM; + + i = max_t(int, c->nnode_sz, c->pnode_sz); + c->lpt_nod_buf = kmalloc(i, GFP_KERNEL); + if (!c->lpt_nod_buf) + return -ENOMEM; + + for (i = 0; i < LPROPS_HEAP_CNT; i++) { + c->lpt_heap[i].arr = kmalloc(sizeof(void *) * LPT_HEAP_SZ, + GFP_KERNEL); + if (!c->lpt_heap[i].arr) + return -ENOMEM; + c->lpt_heap[i].cnt = 0; + c->lpt_heap[i].max_cnt = LPT_HEAP_SZ; + } + + c->dirty_idx.arr = kmalloc(sizeof(void *) * LPT_HEAP_SZ, GFP_KERNEL); + if (!c->dirty_idx.arr) + return -ENOMEM; + c->dirty_idx.cnt = 0; + c->dirty_idx.max_cnt = LPT_HEAP_SZ; + + err = read_ltab(c); + if (err) + return err; + + dbg_lp("space_bits %d", c->space_bits); + dbg_lp("lpt_lnum_bits %d", c->lpt_lnum_bits); + dbg_lp("lpt_offs_bits %d", c->lpt_offs_bits); + dbg_lp("lpt_spc_bits %d", c->lpt_spc_bits); + dbg_lp("pcnt_bits %d", c->pcnt_bits); + dbg_lp("lnum_bits %d", c->lnum_bits); + dbg_lp("pnode_sz %d", c->pnode_sz); + dbg_lp("nnode_sz %d", c->nnode_sz); + dbg_lp("ltab_sz %d", c->ltab_sz); + dbg_lp("lsave_sz %d", c->lsave_sz); + dbg_lp("lsave_cnt %d", c->lsave_cnt); + dbg_lp("lpt_hght %d", c->lpt_hght); + dbg_lp("big_lpt %d", c->big_lpt); + dbg_lp("LPT root is at %d:%d", c->lpt_lnum, c->lpt_offs); + dbg_lp("LPT head is at %d:%d", c->nhead_lnum, c->nhead_offs); + dbg_lp("LPT ltab is at %d:%d", c->ltab_lnum, c->ltab_offs); + if (c->big_lpt) + dbg_lp("LPT lsave is at %d:%d", c->lsave_lnum, c->lsave_offs); + + return 0; +} + +/** + * ubifs_lpt_init - initialize the LPT. + * @c: UBIFS file-system description object + * @rd: whether to initialize lpt for reading + * @wr: whether to initialize lpt for writing + * + * For mounting 'rw', @rd and @wr are both true. For mounting 'ro', @rd is true + * and @wr is false. For mounting from 'ro' to 'rw', @rd is false and @wr is + * true. + * + * This function returns %0 on success and a negative error code on failure. + */ +int ubifs_lpt_init(struct ubifs_info *c, int rd, int wr) +{ + int err; + + if (rd) { + err = lpt_init_rd(c); + if (err) + return err; + } + + return 0; +} diff --git a/fs/ubifs/lpt_commit.c b/fs/ubifs/lpt_commit.c new file mode 100644 index 0000000..c0af818 --- /dev/null +++ b/fs/ubifs/lpt_commit.c @@ -0,0 +1,171 @@ +/* + * This file is part of UBIFS. + * + * Copyright (C) 2006-2008 Nokia Corporation. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License version 2 as published by + * the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., 51 + * Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + * + * Authors: Adrian Hunter + * Artem Bityutskiy (Битюцкий Артём) + */ + +/* + * This file implements commit-related functionality of the LEB properties + * subsystem. + */ + +#include "crc16.h" +#include "ubifs.h" + +/** + * free_obsolete_cnodes - free obsolete cnodes for commit end. + * @c: UBIFS file-system description object + */ +static void free_obsolete_cnodes(struct ubifs_info *c) +{ + struct ubifs_cnode *cnode, *cnext; + + cnext = c->lpt_cnext; + if (!cnext) + return; + do { + cnode = cnext; + cnext = cnode->cnext; + if (test_bit(OBSOLETE_CNODE, &cnode->flags)) + kfree(cnode); + else + cnode->cnext = NULL; + } while (cnext != c->lpt_cnext); + c->lpt_cnext = NULL; +} + +/** + * first_nnode - find the first nnode in memory. + * @c: UBIFS file-system description object + * @hght: height of tree where nnode found is returned here + * + * This function returns a pointer to the nnode found or %NULL if no nnode is + * found. This function is a helper to 'ubifs_lpt_free()'. + */ +static struct ubifs_nnode *first_nnode(struct ubifs_info *c, int *hght) +{ + struct ubifs_nnode *nnode; + int h, i, found; + + nnode = c->nroot; + *hght = 0; + if (!nnode) + return NULL; + for (h = 1; h < c->lpt_hght; h++) { + found = 0; + for (i = 0; i < UBIFS_LPT_FANOUT; i++) { + if (nnode->nbranch[i].nnode) { + found = 1; + nnode = nnode->nbranch[i].nnode; + *hght = h; + break; + } + } + if (!found) + break; + } + return nnode; +} + +/** + * next_nnode - find the next nnode in memory. + * @c: UBIFS file-system description object + * @nnode: nnode from which to start. + * @hght: height of tree where nnode is, is passed and returned here + * + * This function returns a pointer to the nnode found or %NULL if no nnode is + * found. This function is a helper to 'ubifs_lpt_free()'. + */ +static struct ubifs_nnode *next_nnode(struct ubifs_info *c, + struct ubifs_nnode *nnode, int *hght) +{ + struct ubifs_nnode *parent; + int iip, h, i, found; + + parent = nnode->parent; + if (!parent) + return NULL; + if (nnode->iip == UBIFS_LPT_FANOUT - 1) { + *hght -= 1; + return parent; + } + for (iip = nnode->iip + 1; iip < UBIFS_LPT_FANOUT; iip++) { + nnode = parent->nbranch[iip].nnode; + if (nnode) + break; + } + if (!nnode) { + *hght -= 1; + return parent; + } + for (h = *hght + 1; h < c->lpt_hght; h++) { + found = 0; + for (i = 0; i < UBIFS_LPT_FANOUT; i++) { + if (nnode->nbranch[i].nnode) { + found = 1; + nnode = nnode->nbranch[i].nnode; + *hght = h; + break; + } + } + if (!found) + break; + } + return nnode; +} + +/** + * ubifs_lpt_free - free resources owned by the LPT. + * @c: UBIFS file-system description object + * @wr_only: free only resources used for writing + */ +void ubifs_lpt_free(struct ubifs_info *c, int wr_only) +{ + struct ubifs_nnode *nnode; + int i, hght; + + /* Free write-only things first */ + + free_obsolete_cnodes(c); /* Leftover from a failed commit */ + + vfree(c->ltab_cmt); + c->ltab_cmt = NULL; + vfree(c->lpt_buf); + c->lpt_buf = NULL; + kfree(c->lsave); + c->lsave = NULL; + + if (wr_only) + return; + + /* Now free the rest */ + + nnode = first_nnode(c, &hght); + while (nnode) { + for (i = 0; i < UBIFS_LPT_FANOUT; i++) + kfree(nnode->nbranch[i].nnode); + nnode = next_nnode(c, nnode, &hght); + } + for (i = 0; i < LPROPS_HEAP_CNT; i++) + kfree(c->lpt_heap[i].arr); + kfree(c->dirty_idx.arr); + kfree(c->nroot); + vfree(c->ltab); + kfree(c->lpt_nod_buf); +}
Stefan Roese
