[U-Boot] MPC8555CDS broken on TOT (commit 8fd4166c, ELDK 4.2)
Hello,
TOT U-Boot (commit 8fd4166c, compiled with ELDK 4.2) for the MPC8555CDS target is broken with the following symptoms:
[flash the 8fd4166c image and reset the board]
U-Boot 2008.10-rc2-00018-g8fd4166 (Sep 23 2008 - 10:23:59)
CPU: 8555E, Version: 1.1, (0x80790011) Core: E500, Version: 2.0, (0x80200020) Clock Configuration: CPU: 825 MHz, CCB: 330 MHz, DDR: 165 MHz (330 MT/s data rate), LBC: 82 MHz CPM: 330 Mhz L1: D-cache 32 kB enabled I-cache 32 kB enabled Board: CDS Version 0x11, PCI Slot 1 CPU Board Revision 0.0 (0x0000) PCI1: 32 bit, 33 MHz, sync PCI2: 32 bit, 66 MHz, sync I2C: ready DRAM: Initializing SDRAM: 64 MB DDR: 256 MB
And the output stops here, console is dead. Can't give more details as to what's going on the board -- don't have a HW debugger available.
After a power-cycle, the board doesn't go as far as the first time after reset:
Subsequent power-cycles result in the same output, i.e., the output dies after the "I-cache 32 kB enabled" line.
The U-Boot works fine as of commit 71074abb, but can't do a full bisection at the moment (can't flash the board easily).
Brief search of the ML archives didn't reveal any such issue reported, so I'm posting this as a data point, and in the hopes that someone can take further investigation from here. I'll be happy to provide more details if needed, and might also be able to test a potential fix.
Regards, Bartlomiej Sieka
On Tue, Sep 23, 2008 at 5:05 AM, Bartlomiej Sieka tur@semihalf.com wrote:
Hello,
Did Rafal Czubak's patch solve your problem?
Andy
Hello,
Yes, it did (actually this problem was the reason Rafal started the work that lead to the patch you're mentioning).
Andy Fleming
Bartlomiej Sieka
