[U-Boot] [PATCH] km/common: remove printfs for i2c deblocking code
This code will also be used before reallocation and during this time we are not allowed to do these printings.
Signed-off-by: Holger Brunck holger.brunck@keymile.com --- board/keymile/common/common.c | 3 --- 1 files changed, 0 insertions(+), 3 deletions(-)
diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index 1013f42..a90f112 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -151,7 +151,6 @@ int i2c_make_abort(void) sda_state = get_sda(); if (scl_state && sda_state) { ret = 0; - printf("[INFO] i2c abort after %d clocks\n", i); break; } } @@ -159,8 +158,6 @@ int i2c_make_abort(void) if (ret == 0) for (i = 0; i < 5; i++) i2c_write_start_seq(); - else - printf("[ERROR] i2c abort failed\n");
/* respect stop setup time */ udelay(DELAY_ABORT_SEQ);
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot- bounces@lists.denx.de] On Behalf Of Gerlando Falauto Sent: 27 July 2012 20:28 To: u-boot@lists.denx.de Cc: Holger Brunck Subject: [U-Boot] [PATCH] km/common: remove printfs for i2c deblocking code
}printf("[INFO] i2c abort after %d clocks\n", i); break; }
else
Acked-By: Prafulla Wadaskar Prafulla@marvell.com
Regards... Prafulla . . .
Hello Gerlando,
Signed-off-by: Holger Brunckholger.brunck@keymile.com
Acked-by: Heiko Schocherhs@denx.de
@Prafulla: Is it OK for you, if I pick this patch up to my i2c tree?
bye, Heiko
-----Original Message----- From: Heiko Schocher [mailto:hs@denx.de] Sent: 30 July 2012 14:53 To: Gerlando Falauto Cc: u-boot@lists.denx.de; Holger Brunck; Prafulla Wadaskar Subject: Re: [U-Boot] [PATCH] km/common: remove printfs for i2c deblocking code
Hello Gerlando,
we
Hi Heiko Yes, I am okay with it, please pick it.
Gerlando Falauto
Heiko Schocher
Prafulla Wadaskar
