[U-Boot] [PATCH][v4] powerpc/mpc8xxxx: FSL DDR debugger auto run of stored commands
This patch adds the ability for the FSL DDR interactive debugger to automatically run the sequence of commands stored in the ddr_interactive environment variable. Commands are separated using ';'.
ddr_interactive=compute; edit c0 d0 dimmparms caslat_X 0x3FC0; go
Signed-off-by: James Yang James.Yang@freescale.com --- arch/powerpc/cpu/mpc8xxx/ddr/ddr.h | 3 +- arch/powerpc/cpu/mpc8xxx/ddr/interactive.c | 47 ++++++++++++++++++++++++--- arch/powerpc/cpu/mpc8xxx/ddr/main.c | 8 ++-- 3 files changed, 47 insertions(+), 11 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h b/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h index c8b0f91..4dd55fc 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h @@ -86,7 +86,8 @@ void fsl_ddr_set_lawbar( unsigned int memctl_interleaved, unsigned int ctrl_num);
-unsigned long long fsl_ddr_interactive(fsl_ddr_info_t *pinfo); +int fsl_ddr_interactive_env_var_exists(void); +unsigned long long fsl_ddr_interactive(fsl_ddr_info_t *pinfo, int var_is_set); void fsl_ddr_get_spd(generic_spd_eeprom_t *ctrl_dimms_spd, unsigned int ctrl_num);
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c b/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c index ab82dc6..5d34ceb 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c @@ -1430,11 +1430,23 @@ static unsigned int fsl_ddr_parse_interactive_cmd ( return error; }
-unsigned long long fsl_ddr_interactive(fsl_ddr_info_t *pinfo) +int fsl_ddr_interactive_env_var_exists(void) +{ + char buffer[CONFIG_SYS_CBSIZE]; + + if (getenv_f("ddr_interactive", buffer, CONFIG_SYS_CBSIZE) >= 0) + return 1; + + return 0; +} + +unsigned long long fsl_ddr_interactive(fsl_ddr_info_t *pinfo, int var_is_set) { unsigned long long ddrsize; const char *prompt = "FSL DDR>"; char buffer[CONFIG_SYS_CBSIZE]; + char buffer2[CONFIG_SYS_CBSIZE]; + char *p = NULL; char *argv[CONFIG_SYS_MAXARGS + 1]; /* NULL terminated */ int argc; unsigned int next_step = STEP_GET_SPD; @@ -1451,16 +1463,39 @@ unsigned long long fsl_ddr_interactive(fsl_ddr_info_t *pinfo) "go program the memory controller and continue with u-boot\n" };
+ if (var_is_set) { + if (getenv_f("ddr_interactive", buffer2, CONFIG_SYS_CBSIZE) > 0) { + p = buffer2; + } else { + var_is_set = 0; + } + } + /* * The strategy for next_step is that it points to the next * step in the computation process that needs to be done. */ while (1) { - /* - * No need to worry for buffer overflow here in - * this function; readline() maxes out at CFG_CBSIZE - */ - readline_into_buffer(prompt, buffer, 0); + if (var_is_set) { + char *pend = strchr(p, ';'); + if (pend) { + /* found command separator, copy sub-command */ + *pend = '\0'; + strcpy(buffer, p); + p = pend + 1; + } else { + /* separator not found, copy whole string */ + strcpy(buffer, p); + p = NULL; + var_is_set = 0; + } + } else { + /* + * No need to worry for buffer overflow here in + * this function; readline() maxes out at CFG_CBSIZE + */ + readline_into_buffer(prompt, buffer, 0); + } argc = parse_line(buffer, argv); if (argc == 0) continue; diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/main.c b/arch/powerpc/cpu/mpc8xxx/ddr/main.c index 276894c..7a8636d 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/main.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/main.c @@ -537,10 +537,10 @@ phys_size_t fsl_ddr_sdram(void)
/* Compute it once normally. */ #ifdef CONFIG_FSL_DDR_INTERACTIVE - if (getenv("ddr_interactive")) { - total_memory = fsl_ddr_interactive(&info); - } else if (tstc() && (getc() == 'd')) { /* we got a key press of 'd' */ - total_memory = fsl_ddr_interactive(&info); + if (tstc() && (getc() == 'd')) { /* we got a key press of 'd' */ + total_memory = fsl_ddr_interactive(&info, 0); + } else if (fsl_ddr_interactive_env_var_exists()) { + total_memory = fsl_ddr_interactive(&info, 1); } else #endif total_memory = fsl_ddr_compute(&info, STEP_GET_SPD, 0);
Applied to master branch, replaced early commit.
York
Oops, sorry. Posted to wrong list. I meant to post to an internal list.
York
York Sun
