[U-Boot] [PATCH v6 04/10] mips: ath79: add support for QCA953x SOCs
This patch enable work for qca953x SOC.
Signed-off-by: Wills Wang wills.wang@live.com ---
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
arch/mips/mach-ath79/Kconfig | 10 + arch/mips/mach-ath79/Makefile | 3 +- arch/mips/mach-ath79/qca953x/Makefile | 7 + arch/mips/mach-ath79/qca953x/clk.c | 112 +++++++ arch/mips/mach-ath79/qca953x/ddr.c | 463 +++++++++++++++++++++++++++ arch/mips/mach-ath79/qca953x/lowlevel_init.S | 186 +++++++++++ 6 files changed, 780 insertions(+), 1 deletion(-) create mode 100644 arch/mips/mach-ath79/qca953x/Makefile create mode 100644 arch/mips/mach-ath79/qca953x/clk.c create mode 100644 arch/mips/mach-ath79/qca953x/ddr.c create mode 100644 arch/mips/mach-ath79/qca953x/lowlevel_init.S
diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach-ath79/Kconfig index ff2c491..f7801e4 100644 --- a/arch/mips/mach-ath79/Kconfig +++ b/arch/mips/mach-ath79/Kconfig @@ -17,4 +17,14 @@ config SOC_AR933X help This supports QCA/Atheros ar933x family SOCs.
+config SOC_QCA953X + bool + select SUPPORTS_BIG_ENDIAN + select SUPPORTS_CPU_MIPS32_R1 + select SUPPORTS_CPU_MIPS32_R2 + select SYS_MIPS_CACHE_INIT_RAM_LOAD + select MIPS_TUNE_24KC + help + This supports QCA/Atheros qca953x family SOCs. + endmenu diff --git a/arch/mips/mach-ath79/Makefile b/arch/mips/mach-ath79/Makefile index 9b9447e..160dfaa 100644 --- a/arch/mips/mach-ath79/Makefile +++ b/arch/mips/mach-ath79/Makefile @@ -6,4 +6,5 @@ obj-y += reset.o obj-y += cpu.o obj-y += dram.o
-obj-$(CONFIG_SOC_AR933X) += ar933x/ \ No newline at end of file +obj-$(CONFIG_SOC_AR933X) += ar933x/ +obj-$(CONFIG_SOC_QCA953X) += qca953x/ \ No newline at end of file diff --git a/arch/mips/mach-ath79/qca953x/Makefile b/arch/mips/mach-ath79/qca953x/Makefile new file mode 100644 index 0000000..fd74f0c --- /dev/null +++ b/arch/mips/mach-ath79/qca953x/Makefile @@ -0,0 +1,7 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += clk.o +obj-y += ddr.o +obj-y += lowlevel_init.o diff --git a/arch/mips/mach-ath79/qca953x/clk.c b/arch/mips/mach-ath79/qca953x/clk.c new file mode 100644 index 0000000..2c0dbbb --- /dev/null +++ b/arch/mips/mach-ath79/qca953x/clk.c @@ -0,0 +1,112 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/reset.h> + +DECLARE_GLOBAL_DATA_PTR; + +static u32 qca953x_get_xtal(void) +{ + u32 val; + + val = get_bootstrap(); + if (val & QCA953X_BOOTSTRAP_REF_CLK_40) + return 40000000; + else + return 25000000; +} + +int get_serial_clock(void) +{ + return qca953x_get_xtal(); +} + +int get_clocks(void) +{ + void __iomem *regs; + u32 val, ctrl, xtal, pll, div; + + regs = map_physmem(AR71XX_PLL_BASE, AR71XX_PLL_SIZE, + MAP_NOCACHE); + + xtal = qca953x_get_xtal(); + ctrl = readl(regs + QCA953X_PLL_CLK_CTRL_REG); + val = readl(regs + QCA953X_PLL_CPU_CONFIG_REG); + + /* VCOOUT = XTAL * DIV_INT */ + div = (val >> QCA953X_PLL_CPU_CONFIG_REFDIV_SHIFT) + & QCA953X_PLL_CPU_CONFIG_REFDIV_MASK; + pll = xtal / div; + + /* PLLOUT = VCOOUT * (1/2^OUTDIV) */ + div = (val >> QCA953X_PLL_CPU_CONFIG_NINT_SHIFT) + & QCA953X_PLL_CPU_CONFIG_NINT_MASK; + pll *= div; + div = (val >> QCA953X_PLL_CPU_CONFIG_OUTDIV_SHIFT) + & QCA953X_PLL_CPU_CONFIG_OUTDIV_MASK; + if (!div) + div = 1; + pll >>= div; + + /* CPU_CLK = PLLOUT / CPU_POST_DIV */ + div = ((ctrl >> QCA953X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT) + & QCA953X_PLL_CLK_CTRL_CPU_POST_DIV_MASK) + 1; + gd->cpu_clk = pll / div; + + + val = readl(regs + QCA953X_PLL_DDR_CONFIG_REG); + /* VCOOUT = XTAL * DIV_INT */ + div = (val >> QCA953X_PLL_DDR_CONFIG_REFDIV_SHIFT) + & QCA953X_PLL_DDR_CONFIG_REFDIV_MASK; + pll = xtal / div; + + /* PLLOUT = VCOOUT * (1/2^OUTDIV) */ + div = (val >> QCA953X_PLL_DDR_CONFIG_NINT_SHIFT) + & QCA953X_PLL_DDR_CONFIG_NINT_MASK; + pll *= div; + div = (val >> QCA953X_PLL_DDR_CONFIG_OUTDIV_SHIFT) + & QCA953X_PLL_DDR_CONFIG_OUTDIV_MASK; + if (!div) + div = 1; + pll >>= div; + + /* DDR_CLK = PLLOUT / DDR_POST_DIV */ + div = ((ctrl >> QCA953X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT) + & QCA953X_PLL_CLK_CTRL_DDR_POST_DIV_MASK) + 1; + gd->mem_clk = pll / div; + + div = ((ctrl >> QCA953X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT) + & QCA953X_PLL_CLK_CTRL_AHB_POST_DIV_MASK) + 1; + if (ctrl & QCA953X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL) { + /* AHB_CLK = DDR_CLK / AHB_POST_DIV */ + gd->bus_clk = gd->mem_clk / (div + 1); + } else { + /* AHB_CLK = CPU_CLK / AHB_POST_DIV */ + gd->bus_clk = gd->cpu_clk / (div + 1); + } + + return 0; +} + +ulong get_bus_freq(ulong dummy) +{ + if (!gd->bus_clk) + get_clocks(); + return gd->bus_clk; +} + +ulong get_ddr_freq(ulong dummy) +{ + if (!gd->mem_clk) + get_clocks(); + return gd->mem_clk; +} diff --git a/arch/mips/mach-ath79/qca953x/ddr.c b/arch/mips/mach-ath79/qca953x/ddr.c new file mode 100644 index 0000000..520af07 --- /dev/null +++ b/arch/mips/mach-ath79/qca953x/ddr.c @@ -0,0 +1,463 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/reset.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define DDR_CTRL_UPD_EMR3S BIT(5) +#define DDR_CTRL_UPD_EMR2S BIT(4) +#define DDR_CTRL_PRECHARGE BIT(3) +#define DDR_CTRL_AUTO_REFRESH BIT(2) +#define DDR_CTRL_UPD_EMRS BIT(1) +#define DDR_CTRL_UPD_MRS BIT(0) + +#define DDR_REFRESH_EN BIT(14) +#define DDR_REFRESH_M 0x3ff +#define DDR_REFRESH(x) ((x) & DDR_REFRESH_M) +#define DDR_REFRESH_VAL (DDR_REFRESH_EN | DDR_REFRESH(312)) + +#define DDR_TRAS_S 0 +#define DDR_TRAS_M 0x1f +#define DDR_TRAS(x) (((x) & DDR_TRAS_M) << DDR_TRAS_S) +#define DDR_TRCD_M 0xf +#define DDR_TRCD_S 5 +#define DDR_TRCD(x) (((x) & DDR_TRCD_M) << DDR_TRCD_S) +#define DDR_TRP_M 0xf +#define DDR_TRP_S 9 +#define DDR_TRP(x) (((x) & DDR_TRP_M) << DDR_TRP_S) +#define DDR_TRRD_M 0xf +#define DDR_TRRD_S 13 +#define DDR_TRRD(x) (((x) & DDR_TRRD_M) << DDR_TRRD_S) +#define DDR_TRFC_M 0x7f +#define DDR_TRFC_S 17 +#define DDR_TRFC(x) (((x) & DDR_TRFC_M) << DDR_TRFC_S) +#define DDR_TMRD_M 0xf +#define DDR_TMRD_S 23 +#define DDR_TMRD(x) (((x) & DDR_TMRD_M) << DDR_TMRD_S) +#define DDR_CAS_L_M 0x17 +#define DDR_CAS_L_S 27 +#define DDR_CAS_L(x) (((x) & DDR_CAS_L_M) << DDR_CAS_L_S) +#define DDR_OPEN BIT(30) +#define DDR1_CONF_REG_VAL (DDR_TRAS(16) | DDR_TRCD(6) | \ + DDR_TRP(6) | DDR_TRRD(4) | \ + DDR_TRFC(7) | DDR_TMRD(5) | \ + DDR_CAS_L(7) | DDR_OPEN) +#define DDR2_CONF_REG_VAL (DDR_TRAS(27) | DDR_TRCD(9) | \ + DDR_TRP(9) | DDR_TRRD(7) | \ + DDR_TRFC(21) | DDR_TMRD(15) | \ + DDR_CAS_L(17) | DDR_OPEN) + +#define DDR_BURST_LEN_S 0 +#define DDR_BURST_LEN_M 0xf +#define DDR_BURST_LEN(x) ((x) << DDR_BURST_LEN_S) +#define DDR_BURST_TYPE BIT(4) +#define DDR_CNTL_OE_EN BIT(5) +#define DDR_PHASE_SEL BIT(6) +#define DDR_CKE BIT(7) +#define DDR_TWR_S 8 +#define DDR_TWR_M 0xf +#define DDR_TWR(x) (((x) & DDR_TWR_M) << DDR_TWR_S) +#define DDR_TRTW_S 12 +#define DDR_TRTW_M 0x1f +#define DDR_TRTW(x) (((x) & DDR_TRTW_M) << DDR_TRTW_S) +#define DDR_TRTP_S 17 +#define DDR_TRTP_M 0xf +#define DDR_TRTP(x) (((x) & DDR_TRTP_M) << DDR_TRTP_S) +#define DDR_TWTR_S 21 +#define DDR_TWTR_M 0x1f +#define DDR_TWTR(x) (((x) & DDR_TWTR_M) << DDR_TWTR_S) +#define DDR_G_OPEN_L_S 26 +#define DDR_G_OPEN_L_M 0xf +#define DDR_G_OPEN_L(x) ((x) << DDR_G_OPEN_L_S) +#define DDR_HALF_WIDTH_LOW BIT(31) +#define DDR1_CONF2_REG_VAL (DDR_BURST_LEN(8) | DDR_CNTL_OE_EN | \ + DDR_CKE | DDR_TWR(13) | DDR_TRTW(14) | \ + DDR_TRTP(8) | DDR_TWTR(14) | \ + DDR_G_OPEN_L(6) | DDR_HALF_WIDTH_LOW) +#define DDR2_CONF2_REG_VAL (DDR_BURST_LEN(8) | DDR_CNTL_OE_EN | \ + DDR_CKE | DDR_TWR(1) | DDR_TRTW(14) | \ + DDR_TRTP(9) | DDR_TWTR(21) | \ + DDR_G_OPEN_L(8) | DDR_HALF_WIDTH_LOW) + +#define DDR_TWR_MSB BIT(3) +#define DDR_TRAS_MSB BIT(2) +#define DDR_TRFC_MSB_M 0x3 +#define DDR_TRFC_MSB(x) (x) +#define DDR1_CONF3_REG_VAL 0 +#define DDR2_CONF3_REG_VAL (DDR_TWR_MSB | DDR_TRFC_MSB(2)) + +#define DDR_CTL_SRAM_TSEL BIT(30) +#define DDR_CTL_SRAM_GE0_SYNC BIT(20) +#define DDR_CTL_SRAM_GE1_SYNC BIT(19) +#define DDR_CTL_SRAM_USB_SYNC BIT(18) +#define DDR_CTL_SRAM_PCIE_SYNC BIT(17) +#define DDR_CTL_SRAM_WMAC_SYNC BIT(16) +#define DDR_CTL_SRAM_MISC1_SYNC BIT(15) +#define DDR_CTL_SRAM_MISC2_SYNC BIT(14) +#define DDR_CTL_PAD_DDR2_SEL BIT(6) +#define DDR_CTL_HALF_WIDTH BIT(1) +#define DDR_CTL_CONFIG_VAL (DDR_CTL_SRAM_TSEL | \ + DDR_CTL_SRAM_GE0_SYNC | \ + DDR_CTL_SRAM_GE1_SYNC | \ + DDR_CTL_SRAM_USB_SYNC | \ + DDR_CTL_SRAM_PCIE_SYNC | \ + DDR_CTL_SRAM_WMAC_SYNC | \ + DDR_CTL_HALF_WIDTH) + +#define DDR_BURST_GE0_MAX_BL_S 0 +#define DDR_BURST_GE0_MAX_BL_M 0xf +#define DDR_BURST_GE0_MAX_BL(x) \ + (((x) & DDR_BURST_GE0_MAX_BL_M) << DDR_BURST_GE0_MAX_BL_S) +#define DDR_BURST_GE1_MAX_BL_S 4 +#define DDR_BURST_GE1_MAX_BL_M 0xf +#define DDR_BURST_GE1_MAX_BL(x) \ + (((x) & DDR_BURST_GE1_MAX_BL_M) << DDR_BURST_GE1_MAX_BL_S) +#define DDR_BURST_PCIE_MAX_BL_S 8 +#define DDR_BURST_PCIE_MAX_BL_M 0xf +#define DDR_BURST_PCIE_MAX_BL(x) \ + (((x) & DDR_BURST_PCIE_MAX_BL_M) << DDR_BURST_PCIE_MAX_BL_S) +#define DDR_BURST_USB_MAX_BL_S 12 +#define DDR_BURST_USB_MAX_BL_M 0xf +#define DDR_BURST_USB_MAX_BL(x) \ + (((x) & DDR_BURST_USB_MAX_BL_M) << DDR_BURST_USB_MAX_BL_S) +#define DDR_BURST_CPU_MAX_BL_S 16 +#define DDR_BURST_CPU_MAX_BL_M 0xf +#define DDR_BURST_CPU_MAX_BL(x) \ + (((x) & DDR_BURST_CPU_MAX_BL_M) << DDR_BURST_CPU_MAX_BL_S) +#define DDR_BURST_RD_MAX_BL_S 20 +#define DDR_BURST_RD_MAX_BL_M 0xf +#define DDR_BURST_RD_MAX_BL(x) \ + (((x) & DDR_BURST_RD_MAX_BL_M) << DDR_BURST_RD_MAX_BL_S) +#define DDR_BURST_WR_MAX_BL_S 24 +#define DDR_BURST_WR_MAX_BL_M 0xf +#define DDR_BURST_WR_MAX_BL(x) \ + (((x) & DDR_BURST_WR_MAX_BL_M) << DDR_BURST_WR_MAX_BL_S) +#define DDR_BURST_RWP_MASK_EN_S 28 +#define DDR_BURST_RWP_MASK_EN_M 0x3 +#define DDR_BURST_RWP_MASK_EN(x) \ + (((x) & DDR_BURST_RWP_MASK_EN_M) << DDR_BURST_RWP_MASK_EN_S) +#define DDR_BURST_CPU_PRI_BE BIT(30) +#define DDR_BURST_CPU_PRI BIT(31) +#define DDR_BURST_VAL (DDR_BURST_CPU_PRI_BE | \ + DDR_BURST_RWP_MASK_EN(3) | \ + DDR_BURST_WR_MAX_BL(4) | \ + DDR_BURST_RD_MAX_BL(4) | \ + DDR_BURST_CPU_MAX_BL(4) | \ + DDR_BURST_USB_MAX_BL(4) | \ + DDR_BURST_PCIE_MAX_BL(4) | \ + DDR_BURST_GE1_MAX_BL(4) | \ + DDR_BURST_GE0_MAX_BL(4)) + +#define DDR_BURST_WMAC_MAX_BL_S 0 +#define DDR_BURST_WMAC_MAX_BL_M 0xf +#define DDR_BURST_WMAC_MAX_BL(x) \ + (((x) & DDR_BURST_WMAC_MAX_BL_M) << DDR_BURST_WMAC_MAX_BL_S) +#define DDR_BURST2_VAL DDR_BURST_WMAC_MAX_BL(4) + +#define DDR2_CONF_TWL_S 10 +#define DDR2_CONF_TWL_M 0xf +#define DDR2_CONF_TWL(x) \ + (((x) & DDR2_CONF_TWL_M) << DDR2_CONF_TWL_S) +#define DDR2_CONF_ODT BIT(9) +#define DDR2_CONF_TFAW_S 2 +#define DDR2_CONF_TFAW_M 0x3f +#define DDR2_CONF_TFAW(x) \ + (((x) & DDR2_CONF_TFAW_M) << DDR2_CONF_TFAW_S) +#define DDR2_CONF_EN BIT(0) +#define DDR2_CONF_VAL (DDR2_CONF_TWL(5) | \ + DDR2_CONF_TFAW(31) | \ + DDR2_CONF_ODT | \ + DDR2_CONF_EN) + +#define DDR1_EXT_MODE_VAL 0 +#define DDR2_EXT_MODE_VAL 0x402 +#define DDR2_EXT_MODE_OCD_VAL 0x782 +#define DDR1_MODE_DLL_VAL 0x133 +#define DDR2_MODE_DLL_VAL 0x143 +#define DDR1_MODE_VAL 0x33 +#define DDR2_MODE_VAL 0x43 +#define DDR1_TAP_VAL 0x20 +#define DDR2_TAP_VAL 0x10 + +#define DDR_REG_BIST_MASK_ADDR_0 0x2c +#define DDR_REG_BIST_MASK_ADDR_1 0x30 +#define DDR_REG_BIST_MASK_AHB_GE0_0 0x34 +#define DDR_REG_BIST_COMP_AHB_GE0_0 0x38 +#define DDR_REG_BIST_MASK_AHB_GE1_0 0x3c +#define DDR_REG_BIST_COMP_AHB_GE1_0 0x40 +#define DDR_REG_BIST_COMP_ADDR_0 0x64 +#define DDR_REG_BIST_COMP_ADDR_1 0x68 +#define DDR_REG_BIST_MASK_AHB_GE0_1 0x6c +#define DDR_REG_BIST_COMP_AHB_GE0_1 0x70 +#define DDR_REG_BIST_MASK_AHB_GE1_1 0x74 +#define DDR_REG_BIST_COMP_AHB_GE1_1 0x78 +#define DDR_REG_BIST 0x11c +#define DDR_REG_BIST_STATUS 0x120 + +#define DDR_BIST_COMP_CNT_S 1 +#define DDR_BIST_COMP_CNT_M 0xff +#define DDR_BIST_COMP_CNT(x) \ + (((x) & DDR_BIST_COMP_CNT_M) << DDR_BIST_COMP_CNT_S) +#define DDR_BIST_COMP_CNT_MASK \ + (DDR_BIST_COMP_CNT_M << DDR_BIST_COMP_CNT_S) +#define DDR_BIST_TEST_START BIT(0) +#define DDR_BIST_STATUS_DONE BIT(0) + +/* 4 Row Address Bits, 4 Column Address Bits, 2 BA bits */ +#define DDR_BIST_MASK_ADDR_VAL 0xfa5de83f + +#define DDR_TAP_MAGIC_VAL 0xaa55aa55 +#define DDR_TAP_MAX_VAL 0x40 + +void ddr_init(void) +{ + void __iomem *regs; + u32 val; + + regs = map_physmem(AR71XX_DDR_CTRL_BASE, AR71XX_DDR_CTRL_SIZE, + MAP_NOCACHE); + val = get_bootstrap(); + if (val & QCA953X_BOOTSTRAP_DDR1) { + writel(DDR_CTL_CONFIG_VAL, regs + QCA953X_DDR_REG_CTL_CONF); + udelay(10); + + /* For 16-bit DDR */ + writel(0xffff, regs + AR71XX_DDR_REG_RD_CYCLE); + udelay(100); + + /* Burst size */ + writel(DDR_BURST_VAL, regs + QCA953X_DDR_REG_BURST); + udelay(100); + writel(DDR_BURST2_VAL, regs + QCA953X_DDR_REG_BURST2); + udelay(100); + + /* AHB maximum timeout */ + writel(0xfffff, regs + QCA953X_DDR_REG_TIMEOUT_MAX); + udelay(100); + + /* DRAM timing */ + writel(DDR1_CONF_REG_VAL, regs + AR71XX_DDR_REG_CONFIG); + udelay(100); + writel(DDR1_CONF2_REG_VAL, regs + AR71XX_DDR_REG_CONFIG2); + udelay(100); + writel(DDR1_CONF3_REG_VAL, regs + QCA953X_DDR_REG_CONFIG3); + udelay(100); + + /* Precharge All */ + writel(DDR_CTRL_PRECHARGE, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* ODT disable, Full strength, Enable DLL */ + writel(DDR1_EXT_MODE_VAL, regs + AR71XX_DDR_REG_EMR); + udelay(100); + /* Update Extended Mode Register Set (EMRS) */ + writel(DDR_CTRL_UPD_EMRS, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Reset DLL, CAS Latency 3, Burst Length 8 */ + writel(DDR1_MODE_DLL_VAL, regs + AR71XX_DDR_REG_MODE); + udelay(100); + /* Update Mode Register Set (MRS) */ + writel(DDR_CTRL_UPD_MRS, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Precharge All */ + writel(DDR_CTRL_PRECHARGE, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Auto Refresh */ + writel(DDR_CTRL_AUTO_REFRESH, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + writel(DDR_CTRL_AUTO_REFRESH, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Normal DLL, CAS Latency 3, Burst Length 8 */ + writel(DDR1_MODE_VAL, regs + AR71XX_DDR_REG_MODE); + udelay(100); + /* Update Mode Register Set (MRS) */ + writel(DDR_CTRL_UPD_MRS, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Refresh time control */ + writel(DDR_REFRESH_VAL, regs + AR71XX_DDR_REG_REFRESH); + udelay(100); + + /* DQS 0 Tap Control */ + writel(DDR1_TAP_VAL, regs + AR71XX_DDR_REG_TAP_CTRL0); + /* DQS 1 Tap Control */ + writel(DDR1_TAP_VAL, regs + AR71XX_DDR_REG_TAP_CTRL1); + } else { + writel(DDR_CTRL_UPD_EMR2S, regs + AR71XX_DDR_REG_CONTROL); + udelay(10); + writel(DDR_CTRL_UPD_EMR3S, regs + AR71XX_DDR_REG_CONTROL); + udelay(10); + writel(DDR_CTL_CONFIG_VAL | DDR_CTL_PAD_DDR2_SEL, + regs + QCA953X_DDR_REG_CTL_CONF); + udelay(10); + + /* For 16-bit DDR */ + writel(0xffff, regs + AR71XX_DDR_REG_RD_CYCLE); + udelay(100); + + /* Burst size */ + writel(DDR_BURST_VAL, regs + QCA953X_DDR_REG_BURST); + udelay(100); + writel(DDR_BURST2_VAL, regs + QCA953X_DDR_REG_BURST2); + udelay(100); + + /* AHB maximum timeout */ + writel(0xfffff, regs + QCA953X_DDR_REG_TIMEOUT_MAX); + udelay(100); + + /* DRAM timing */ + writel(DDR2_CONF_REG_VAL, regs + AR71XX_DDR_REG_CONFIG); + udelay(100); + writel(DDR2_CONF2_REG_VAL, regs + AR71XX_DDR_REG_CONFIG2); + udelay(100); + writel(DDR2_CONF3_REG_VAL, regs + QCA953X_DDR_REG_CONFIG3); + udelay(100); + + /* Enable DDR2 */ + writel(DDR2_CONF_VAL, regs + QCA953X_DDR_REG_DDR2_CONFIG); + udelay(100); + + /* Precharge All */ + writel(DDR_CTRL_PRECHARGE, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Update Extended Mode Register 2 Set (EMR2S) */ + writel(DDR_CTRL_UPD_EMR2S, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Update Extended Mode Register 3 Set (EMR3S) */ + writel(DDR_CTRL_UPD_EMR3S, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* 150 ohm, Reduced strength, Enable DLL */ + writel(DDR2_EXT_MODE_VAL, regs + AR71XX_DDR_REG_EMR); + udelay(100); + /* Update Extended Mode Register Set (EMRS) */ + writel(DDR_CTRL_UPD_EMRS, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Reset DLL, CAS Latency 4, Burst Length 8 */ + writel(DDR2_MODE_DLL_VAL, regs + AR71XX_DDR_REG_MODE); + udelay(100); + + /* Update Mode Register Set (MRS) */ + writel(DDR_CTRL_UPD_MRS, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Precharge All */ + writel(DDR_CTRL_PRECHARGE, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Auto Refresh */ + writel(DDR_CTRL_AUTO_REFRESH, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + writel(DDR_CTRL_AUTO_REFRESH, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Normal DLL, CAS Latency 4, Burst Length 8 */ + writel(DDR2_MODE_VAL, regs + AR71XX_DDR_REG_MODE); + udelay(100); + /* Mode Register Set (MRS) */ + writel(DDR_CTRL_UPD_MRS, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Enable OCD, Enable DLL, Reduced Drive Strength */ + writel(DDR2_EXT_MODE_OCD_VAL, regs + AR71XX_DDR_REG_EMR); + udelay(100); + /* Update Extended Mode Register Set (EMRS) */ + writel(DDR_CTRL_UPD_EMRS, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* OCD diable, Enable DLL, Reduced Drive Strength */ + writel(DDR2_EXT_MODE_VAL, regs + AR71XX_DDR_REG_EMR); + udelay(100); + /* Update Extended Mode Register Set (EMRS) */ + writel(DDR_CTRL_UPD_EMRS, regs + AR71XX_DDR_REG_CONTROL); + udelay(100); + + /* Refresh time control */ + writel(DDR_REFRESH_VAL, regs + AR71XX_DDR_REG_REFRESH); + udelay(100); + + /* DQS 0 Tap Control */ + writel(DDR2_TAP_VAL, regs + AR71XX_DDR_REG_TAP_CTRL0); + /* DQS 1 Tap Control */ + writel(DDR2_TAP_VAL, regs + AR71XX_DDR_REG_TAP_CTRL1); + } +} + +void ddr_tap_tuning(void) +{ + void __iomem *regs; + u32 val, pass, tap, cnt, tap_val, last, first; + + regs = map_physmem(AR71XX_DDR_CTRL_BASE, AR71XX_DDR_CTRL_SIZE, + MAP_NOCACHE); + + tap_val = readl(regs + AR71XX_DDR_REG_TAP_CTRL0); + first = DDR_TAP_MAGIC_VAL; + last = 0; + cnt = 0; + tap = 0; + + do { + writel(tap, regs + AR71XX_DDR_REG_TAP_CTRL0); + writel(tap, regs + AR71XX_DDR_REG_TAP_CTRL1); + + writel(DDR_BIST_COMP_CNT(8), regs + DDR_REG_BIST_COMP_ADDR_1); + writel(DDR_BIST_MASK_ADDR_VAL, regs + DDR_REG_BIST_MASK_ADDR_0); + writel(0xffff, regs + DDR_REG_BIST_COMP_AHB_GE0_1); + writel(0xffff, regs + DDR_REG_BIST_COMP_AHB_GE1_0); + writel(0xffff, regs + DDR_REG_BIST_COMP_AHB_GE1_1); + writel(0xffff, regs + DDR_REG_BIST_MASK_AHB_GE0_0); + writel(0xffff, regs + DDR_REG_BIST_MASK_AHB_GE0_1); + writel(0xffff, regs + DDR_REG_BIST_MASK_AHB_GE1_0); + writel(0xffff, regs + DDR_REG_BIST_MASK_AHB_GE1_1); + writel(0xffff, regs + DDR_REG_BIST_COMP_AHB_GE0_0); + + /* Start BIST test */ + writel(DDR_BIST_TEST_START, regs + DDR_REG_BIST); + + do { + val = readl(regs + DDR_REG_BIST_STATUS); + } while (!(val & DDR_BIST_STATUS_DONE)); + + /* Stop BIST test */ + writel(0, regs + DDR_REG_BIST); + + pass = val & DDR_BIST_COMP_CNT_MASK; + pass ^= DDR_BIST_COMP_CNT(8); + if (!pass) { + if (first != DDR_TAP_MAGIC_VAL) { + last = tap; + } else { + first = tap; + last = tap; + } + cnt++; + } + tap++; + } while (tap < DDR_TAP_MAX_VAL); + + if (cnt) { + tap_val = (first + last) / 2; + tap_val %= DDR_TAP_MAX_VAL; + } + + writel(tap_val, regs + AR71XX_DDR_REG_TAP_CTRL0); + writel(tap_val, regs + AR71XX_DDR_REG_TAP_CTRL1); +} diff --git a/arch/mips/mach-ath79/qca953x/lowlevel_init.S b/arch/mips/mach-ath79/qca953x/lowlevel_init.S new file mode 100644 index 0000000..06b6720 --- /dev/null +++ b/arch/mips/mach-ath79/qca953x/lowlevel_init.S @@ -0,0 +1,186 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <mach/ar71xx_regs.h> + +#define MK_PLL_CONF(divint, refdiv, range, outdiv) \ + (((0x3F & divint) << 10) | \ + ((0x1F & refdiv) << 16) | \ + ((0x1 & range) << 21) | \ + ((0x7 & outdiv) << 23) ) + +#define MK_CLK_CNTL(cpudiv, ddrdiv, ahbdiv) \ + (((0x3 & (cpudiv - 1)) << 5) | \ + ((0x3 & (ddrdiv - 1)) << 10) | \ + ((0x3 & (ahbdiv - 1)) << 15) ) + +#define SET_FIELD(name, v) (((v) & QCA953X_##name##_MASK) << \ + QCA953X_##name##_SHIFT) + +#define DPLL2_KI(v) SET_FIELD(SRIF_DPLL2_KI, v) +#define DPLL2_KD(v) SET_FIELD(SRIF_DPLL2_KD, v) +#define DPLL2_PWD QCA953X_SRIF_DPLL2_PWD +#define MK_DPLL2(ki, kd) (DPLL2_KI(ki) | DPLL2_KD(kd) | DPLL2_PWD) + +#define PLL_CPU_NFRAC(v) SET_FIELD(PLL_CPU_CONFIG_NFRAC, v) +#define PLL_CPU_NINT(v) SET_FIELD(PLL_CPU_CONFIG_NINT, v) +#define PLL_CPU_REFDIV(v) SET_FIELD(PLL_CPU_CONFIG_REFDIV, v) +#define PLL_CPU_OUTDIV(v) SET_FIELD(PLL_CPU_CONFIG_OUTDIV, v) +#define MK_PLL_CPU_CONF(frac, nint, ref, outdiv) \ + (PLL_CPU_NFRAC(frac) | \ + PLL_CPU_NINT(nint) | \ + PLL_CPU_REFDIV(ref) | \ + PLL_CPU_OUTDIV(outdiv)) + +#define PLL_DDR_NFRAC(v) SET_FIELD(PLL_DDR_CONFIG_NFRAC, v) +#define PLL_DDR_NINT(v) SET_FIELD(PLL_DDR_CONFIG_NINT, v) +#define PLL_DDR_REFDIV(v) SET_FIELD(PLL_DDR_CONFIG_REFDIV, v) +#define PLL_DDR_OUTDIV(v) SET_FIELD(PLL_DDR_CONFIG_OUTDIV, v) +#define MK_PLL_DDR_CONF(frac, nint, ref, outdiv) \ + (PLL_DDR_NFRAC(frac) | \ + PLL_DDR_REFDIV(ref) | \ + PLL_DDR_NINT(nint) | \ + PLL_DDR_OUTDIV(outdiv) | \ + QCA953X_PLL_CONFIG_PWD) + +#define PLL_CPU_CONF_VAL MK_PLL_CPU_CONF(0, 26, 1, 0) +#define PLL_DDR_CONF_VAL MK_PLL_DDR_CONF(0, 15, 1, 0) + +#define PLL_CLK_CTRL_PLL_BYPASS (QCA953X_PLL_CLK_CTRL_CPU_PLL_BYPASS | \ + QCA953X_PLL_CLK_CTRL_DDR_PLL_BYPASS | \ + QCA953X_PLL_CLK_CTRL_AHB_PLL_BYPASS) + +#define PLL_CLK_CTRL_CPU_DIV(v) SET_FIELD(PLL_CLK_CTRL_CPU_POST_DIV, v) +#define PLL_CLK_CTRL_DDR_DIV(v) SET_FIELD(PLL_CLK_CTRL_DDR_POST_DIV, v) +#define PLL_CLK_CTRL_AHB_DIV(v) SET_FIELD(PLL_CLK_CTRL_AHB_POST_DIV, v) +#define MK_PLL_CLK_CTRL(cpu, ddr, ahb) \ + (PLL_CLK_CTRL_CPU_DIV(cpu) | \ + PLL_CLK_CTRL_DDR_DIV(ddr) | \ + PLL_CLK_CTRL_AHB_DIV(ahb)) +#define PLL_CLK_CTRL_VAL (MK_PLL_CLK_CTRL(0, 0, 2) | \ + PLL_CLK_CTRL_PLL_BYPASS | \ + QCA953X_PLL_CLK_CTRL_CPUCLK_FROM_CPUPLL | \ + QCA953X_PLL_CLK_CTRL_DDRCLK_FROM_DDRPLL) + +#define PLL_DDR_DIT_FRAC_MAX(v) SET_FIELD(PLL_DDR_DIT_FRAC_MAX, v) +#define PLL_DDR_DIT_FRAC_MIN(v) SET_FIELD(PLL_DDR_DIT_FRAC_MIN, v) +#define PLL_DDR_DIT_FRAC_STEP(v) SET_FIELD(PLL_DDR_DIT_FRAC_STEP, v) +#define PLL_DDR_DIT_UPD_CNT(v) SET_FIELD(PLL_DDR_DIT_UPD_CNT, v) +#define PLL_CPU_DIT_FRAC_MAX(v) SET_FIELD(PLL_CPU_DIT_FRAC_MAX, v) +#define PLL_CPU_DIT_FRAC_MIN(v) SET_FIELD(PLL_CPU_DIT_FRAC_MIN, v) +#define PLL_CPU_DIT_FRAC_STEP(v) SET_FIELD(PLL_CPU_DIT_FRAC_STEP, v) +#define PLL_CPU_DIT_UPD_CNT(v) SET_FIELD(PLL_CPU_DIT_UPD_CNT, v) +#define MK_PLL_DDR_DIT_FRAC(max, min, step, cnt) \ + (QCA953X_PLL_DIT_FRAC_EN | \ + PLL_DDR_DIT_FRAC_MAX(max) | \ + PLL_DDR_DIT_FRAC_MIN(min) | \ + PLL_DDR_DIT_FRAC_STEP(step) | \ + PLL_DDR_DIT_UPD_CNT(cnt)) +#define MK_PLL_CPU_DIT_FRAC(max, min, step, cnt) \ + (QCA953X_PLL_DIT_FRAC_EN | \ + PLL_CPU_DIT_FRAC_MAX(max) | \ + PLL_CPU_DIT_FRAC_MIN(min) | \ + PLL_CPU_DIT_FRAC_STEP(step) | \ + PLL_CPU_DIT_UPD_CNT(cnt)) +#define PLL_CPU_DIT_FRAC_VAL MK_PLL_CPU_DIT_FRAC(63, 0, 1, 15) +#define PLL_DDR_DIT_FRAC_VAL MK_PLL_DDR_DIT_FRAC(763, 635, 1, 15) + + .text + .set noreorder + +LEAF(lowlevel_init) + /* RTC Reset */ + li t0, KSEG1ADDR(AR71XX_RESET_BASE) + lw t1, QCA953X_RESET_REG_RESET_MODULE(t0) + li t2, 0x08000000 + or t1, t1, t2 + sw t1, QCA953X_RESET_REG_RESET_MODULE(t0) + nop + lw t1, QCA953X_RESET_REG_RESET_MODULE(t0) + li t2, 0xf7ffffff + and t1, t1, t2 + sw t1, QCA953X_RESET_REG_RESET_MODULE(t0) + nop + + /* RTC Force Wake */ + li t0, KSEG1ADDR(QCA953X_RTC_BASE) + li t1, 0x01 + sw t1, QCA953X_RTC_REG_SYNC_RESET(t0) + nop + nop + + /* Wait for RTC in on state */ +1: + lw t1, QCA953X_RTC_REG_SYNC_STATUS(t0) + andi t1, t1, 0x02 + beqz t1, 1b + nop + + li t0, KSEG1ADDR(QCA953X_SRIF_BASE) + li t1, MK_DPLL2(2, 16) + sw t1, QCA953X_SRIF_BB_DPLL2_REG(t0) + sw t1, QCA953X_SRIF_PCIE_DPLL2_REG(t0) + sw t1, QCA953X_SRIF_DDR_DPLL2_REG(t0) + sw t1, QCA953X_SRIF_CPU_DPLL2_REG(t0) + + li t0, KSEG1ADDR(AR71XX_PLL_BASE) + lw t1, QCA953X_PLL_CLK_CTRL_REG(t0) + ori t1, PLL_CLK_CTRL_PLL_BYPASS + sw t1, QCA953X_PLL_CLK_CTRL_REG(t0) + nop + + li t1, PLL_CPU_CONF_VAL + sw t1, QCA953X_PLL_CPU_CONFIG_REG(t0) + nop + + li t1, PLL_DDR_CONF_VAL + sw t1, QCA953X_PLL_DDR_CONFIG_REG(t0) + nop + + li t1, PLL_CLK_CTRL_VAL + sw t1, QCA953X_PLL_CLK_CTRL_REG(t0) + nop + + lw t1, QCA953X_PLL_CPU_CONFIG_REG(t0) + li t2, ~QCA953X_PLL_CONFIG_PWD + and t1, t1, t2 + sw t1, QCA953X_PLL_CPU_CONFIG_REG(t0) + nop + + lw t1, QCA953X_PLL_DDR_CONFIG_REG(t0) + li t2, ~QCA953X_PLL_CONFIG_PWD + and t1, t1, t2 + sw t1, QCA953X_PLL_DDR_CONFIG_REG(t0) + nop + + lw t1, QCA953X_PLL_CLK_CTRL_REG(t0) + li t2, ~PLL_CLK_CTRL_PLL_BYPASS + and t1, t1, t2 + sw t1, QCA953X_PLL_CLK_CTRL_REG(t0) + nop + + li t1, PLL_DDR_DIT_FRAC_VAL + sw t1, QCA953X_PLL_DDR_DIT_FRAC_REG(t0) + nop + + li t1, PLL_CPU_DIT_FRAC_VAL + sw t1, QCA953X_PLL_CPU_DIT_FRAC_REG(t0) + nop + + li t0, KSEG1ADDR(AR71XX_RESET_BASE) + lui t1, 0x03fc + sw t1, 0xb4(t0) + + nop + jr ra + nop + END(lowlevel_init)
Wills Wang
