[PATCH v2 0/3] J7 merge HS configs
This series depends on the fixes provided for j721e as that series also includes some base support for running the other HS platforms.
Link for dependent series - https://lore.kernel.org/u-boot/20230324-j721e-upstream-hs-v6-0-5aa43a4817a9@...
( This can be ignored due to the change on how the series is being merged with binman )
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- Changes in v2: - Rebased on top of master - Link to v1: https://lore.kernel.org/r/20230405-j721s2-hs-evm-upstream-v1-0-de446c5fa0d0@...
--- Manorit Chawdhry (3): configs: j721s2: Merge the HS and non-HS defconfigs Kconfig: j721s2: Change K3_MCU_SCRATCHPAD_BASE to non firewalled region configs: j7200: Merge the HS and non-HS defconfigs
MAINTAINERS | 4 - arch/arm/mach-k3/Kconfig | 2 +- configs/j7200_evm_a72_defconfig | 3 +- configs/j7200_evm_r5_defconfig | 1 + configs/j7200_hs_evm_a72_defconfig | 205 ---------------------------------- configs/j7200_hs_evm_r5_defconfig | 170 ----------------------------- configs/j721s2_evm_a72_defconfig | 3 +- configs/j721s2_evm_r5_defconfig | 1 + configs/j721s2_hs_evm_a72_defconfig | 212 ------------------------------------ configs/j721s2_hs_evm_r5_defconfig | 175 ----------------------------- 10 files changed, 7 insertions(+), 769 deletions(-) --- base-commit: bb2dcbf052051953297778bd0e62a017d83c8f6b change-id: 20230405-j721s2-hs-evm-upstream-bad9551303cd
K3 devices have runtime type board detection. Make the default defconfig include the secure configuration. Then remove the HS specific config.
Non-HS devices will continue to boot due to runtime device type detection. If TI_SECURE_DEV_PKG is not set the build will emit warnings, for non-HS devices these can be ignored.
Reviewed-by: Kamlesh Gurudasani kamlesh@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- MAINTAINERS | 2 - configs/j721s2_evm_a72_defconfig | 3 +- configs/j721s2_evm_r5_defconfig | 1 + configs/j721s2_hs_evm_a72_defconfig | 212 ------------------------------------ configs/j721s2_hs_evm_r5_defconfig | 175 ----------------------------- 5 files changed, 3 insertions(+), 390 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 2feb500aa39f..cb3d927a335b 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1496,8 +1496,6 @@ F: configs/am65x_hs_evm_r5_defconfig F: configs/am65x_hs_evm_a53_defconfig F: configs/j7200_hs_evm_a72_defconfig F: configs/j7200_hs_evm_r5_defconfig -F: configs/j721s2_hs_evm_a72_defconfig -F: configs/j721s2_hs_evm_r5_defconfig
TPM DRIVERS M: Ilias Apalodimas ilias.apalodimas@linaro.org diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index addae9f6a290..594c8dad2cae 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y @@ -31,7 +32,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_OF_SYSTEM_SETUP=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; if test ${boot_fit} -eq 1; then run get_fit_${boot}; run get_overlaystring; run run_fit; else; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; fi;" CONFIG_LOGLEVEL=7 CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 343e3c16305f..7416ba2d38d7 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x10000 CONFIG_SPL_GPIO=y diff --git a/configs/j721s2_hs_evm_a72_defconfig b/configs/j721s2_hs_evm_a72_defconfig deleted file mode 100644 index d8089cb7dbc1..000000000000 --- a/configs/j721s2_hs_evm_a72_defconfig +++ /dev/null @@ -1,212 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SOC_K3_J721S2=y -CONFIG_TARGET_J721S2_A72_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 -CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_OFFSET=0x680000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j721s2-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x80080000 -CONFIG_OF_LIBFDT_OVERLAY=y -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_ENV_OFFSET_REDUND=0x6A0000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_PSCI_RESET is not set -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -CONFIG_OF_SYSTEM_SETUP=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_fit_${boot}; run get_overlaystring; run run_fit" -CONFIG_LOGLEVEL=7 -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x80a00000 -CONFIG_SPL_BSS_MAX_SIZE=0x80000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 -CONFIG_SPL_THERMAL=y -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_ASKENV=y -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_MTD=y -CONFIG_CMD_REMOTEPROC=y -CONFIG_CMD_UFS=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" -CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_ISO_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_CLK_CCF=y -CONFIG_CLK_TI_SCI=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_DFU_SF=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_SYS_DFU_MAX_FILE_SIZE=0x800000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x82000000 -CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_DM_I2C_GPIO=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ADMA=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_SOFT_RESET=y -CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_MT35XU=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_MTD=y -CONFIG_MULTIPLEXER=y -CONFIG_MUX_MMIO=y -CONFIG_PHY_TI_DP83867=y -CONFIG_PHY_FIXED=y -CONFIG_TI_AM65_CPSW_NUSS=y -CONFIG_PHY=y -CONFIG_SPL_PHY=y -CONFIG_PHY_CADENCE_TORRENT=y -CONFIG_PHY_J721E_WIZ=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y -CONFIG_REMOTEPROC_TI_K3_DSP=y -CONFIG_REMOTEPROC_TI_K3_R5F=y -CONFIG_RESET_TI_SCI=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_DM_THERMAL=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_USB_CDNS3_HOST=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6168 -CONFIG_UFS=y -CONFIG_CADENCE_UFS=y -CONFIG_TI_J721E_UFS=y diff --git a/configs/j721s2_hs_evm_r5_defconfig b/configs/j721s2_hs_evm_r5_defconfig deleted file mode 100644 index c8433a1de950..000000000000 --- a/configs/j721s2_hs_evm_r5_defconfig +++ /dev/null @@ -1,175 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x10000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SOC_K3_J721S2=y -CONFIG_K3_EARLY_CONS=y -CONFIG_TARGET_J721S2_R5_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41c76000 -CONFIG_ENV_SIZE=0x20000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j721s2-r5-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x41c00000 -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_SIZE_LIMIT=0x80000 -CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x4000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -CONFIG_USE_BOOTCOMMAND=y -# CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y -CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x41c76000 -CONFIG_SPL_BSS_MAX_SIZE=0xa000 -CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 -CONFIG_SPL_EARLY_BSS=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_EXT4=y -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -CONFIG_SPL_REMOTEPROC=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 -CONFIG_SPL_THERMAL=y -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=64 -CONFIG_SYS_BOOTM_LEN=0x4000000 -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPT=y -CONFIG_CMD_MMC=y -CONFIG_CMD_REMOTEPROC=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_SPL_CLK_CCF=y -CONFIG_SPL_CLK_K3_PLL=y -CONFIG_SPL_CLK_K3=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_I2C_SET_DEFAULT_BUS_NUM=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_FS_LOADER=y -CONFIG_SPL_FS_LOADER=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_SOFT_RESET=y -CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_MT35XU=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_POWER_DOMAIN=y -CONFIG_K3_SYSTEM_CONTROLLER=y -CONFIG_REMOTEPROC_TI_K3_ARM64=y -CONFIG_RESET_TI_SCI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_DM_THERMAL=y -CONFIG_TIMER=y -CONFIG_SPL_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6168 -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y -CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 -CONFIG_PANIC_HANG=y -CONFIG_LIB_RATIONAL=y -CONFIG_SPL_LIB_RATIONAL=y
On K3 HS-SE devices all the firewalls are locked by default until sysfw comes up. Rom configures some of the firewall for its usage along with the SRAM for R5 but the PSRAM region is still locked.
The K3 MCU Scratchpad for j721s2 was set to a PSRAM region triggering the firewall exception before sysfw came up. The exception started happening after adding multi dtb support that accesses the scratchpad for reading EEPROM contents.
Old map: ┌─────────────────────────────────────┐ 0x41c00000 │ SPL │ ├─────────────────────────────────────┤ 0x41c61f20 (approx) │ STACK │ ├─────────────────────────────────────┤ 0x41c65f20 │ Global data │ │ sizeof(struct global_data) = 0xd8 │ ├─────────────────────────────────────┤ gd->malloc_base = 0x41c66000 │ HEAP │ │ CONFIG_SYS_MALLOC_F_LEN = 0x10000 │ ├─────────────────────────────────────┤ CONFIG_SPL_BSS_START_ADDR │ SPL BSS │ (0x41c76000) │ CONFIG_SPL_BSS_MAX_SIZE = 0xA000 │ ├─────────────────────────────────────┤ (0x41c80000) │ DM DATA │ ├─────────────────────────────────────┤ (0x41c84130) (approx) │ EMPTY │ └─────────────────────────────────────┘ CONFIG_SYS_K3_BOOT_PARAM_TABLE_INDEX (0x41cffbfc)
New map: ┌─────────────────────────────────────┐ 0x41c00000 │ SPL │ ├─────────────────────────────────────┤ 0x41c61f20 (approx) │ STACK │ ├─────────────────────────────────────┤ 0x41c65f20 │ Global data │ │ sizeof(struct global_data) = 0xd8 │ ├─────────────────────────────────────┤ gd->malloc_base = 0x41c66000 │ HEAP │ │ CONFIG_SYS_MALLOC_F_LEN = 0x10000 │ ├─────────────────────────────────────┤ CONFIG_SPL_BSS_START_ADDR │ SPL BSS │ (0x41c76000) │ CONFIG_SPL_BSS_MAX_SIZE = 0xA000 │ ├─────────────────────────────────────┤ (0x41c80000) │ DM DATA │ ├─────────────────────────────────────┤ (0x41c84130) (approx) │ EMPTY │ ├─────────────────────────────────────┤ SYS_K3_MCU_SCRATCHPAD_BASE │ SCRATCHPAD │ (0x41cff9fc) │ SYS_K3_MCU_SCRATCHPAD_SIZE = 0x200 │ └─────────────────────────────────────┘ CONFIG_SYS_K3_BOOT_PARAM_TABLE_INDEX (0x41cffbfc)
Reviewed-by: Kamlesh Gurudasani kamlesh@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- arch/arm/mach-k3/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index bae0a827c29f..bf1c3c51a41c 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -52,7 +52,7 @@ config SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE config SYS_K3_MCU_SCRATCHPAD_BASE hex default 0x40280000 if SOC_K3_AM654 - default 0x40280000 if SOC_K3_J721S2 + default 0x41cff9fc if SOC_K3_J721S2 default 0x41cff9fc if SOC_K3_J721E help Describes the base address of MCU Scratchpad RAM.
Manorit,
I just finally caught up with this patch, Sorry for the late response-> Thank you for clearly elaborating this in commit message, BUT:
Can we start documenting this in rst after we have incorporated the binman changes? The memory map on the SRAM is a black magic(at least for me) that needs explanation in a single doc without needing to dig through commit messages and variables and defconfigs..
Documentation should clearly indicate what parameters from: * binman configuration. * various config header files * defconfig
We should explain the rationale, variations (HS-SE for example: if any or if not any) - including risks such as stack-heap collisions. Any interplay with firmware components in the heterogenous system that folks need to be careful about needs to be called out as well.
Hi Nishanth,
On 08:45-20230505, Nishanth Menon wrote:
Manorit,
- binman configuration.
- various config header files
- defconfig
Thanks for the insights! Queueing this up when binman get merged. Would be good to let me know a place also to document all this as I couldn't find any j721s2 specific documentation, I believe these things can become device specific also based on the requirements as j721s2 and j721e have a different map of SPL for them.
Regards, Manorit
-- Regards, Nishanth Menon Key (0xDDB5849D1736249D) / Fingerprint: F8A2 8693 54EB 8232 17A3 1A34 DDB5 849D 1736 249D
On 08/05/23 10:21, Manorit Chawdhry wrote:
Hi Nishanth,
Manorit,
- defconfig
doc/board/ti/ is the right place IMO. We need an equivalent for j721e_evm.rst which explains combined image boot flow and SRAM layout for J721s2 / j784s4 (and possibly same for J7200)?
Regards Vignesh
Hi Nishanth,
Manorit,
- defconfig
Regards Vignesh
Thanks Vignesh, would do the needful.
Regards, Manorit
-- Regards Vignesh
Reviewed-by: Kamlesh Gurudasani kamlesh@ti.com Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com --- MAINTAINERS | 2 - configs/j7200_evm_a72_defconfig | 3 +- configs/j7200_evm_r5_defconfig | 1 + configs/j7200_hs_evm_a72_defconfig | 205 ------------------------------------- configs/j7200_hs_evm_r5_defconfig | 170 ------------------------------ 5 files changed, 3 insertions(+), 378 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index cb3d927a335b..9d203d5f42d6 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1494,8 +1494,6 @@ F: configs/k2g_hs_evm_defconfig F: configs/k2l_hs_evm_defconfig F: configs/am65x_hs_evm_r5_defconfig F: configs/am65x_hs_evm_a53_defconfig -F: configs/j7200_hs_evm_a72_defconfig -F: configs/j7200_hs_evm_r5_defconfig
TPM DRIVERS M: Ilias Apalodimas ilias.apalodimas@linaro.org diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index 058e33149684..e40900fffa49 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y @@ -34,7 +35,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; if test ${boot_fit} -eq 1; then run get_fit_${boot}; run get_overlaystring; run run_fit; else; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; fi;" CONFIG_LOGLEVEL=7 CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index 00ec48b83b78..dd4454943c36 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x70000 CONFIG_SPL_GPIO=y diff --git a/configs/j7200_hs_evm_a72_defconfig b/configs/j7200_hs_evm_a72_defconfig deleted file mode 100644 index d9560727edb3..000000000000 --- a/configs/j7200_hs_evm_a72_defconfig +++ /dev/null @@ -1,205 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SOC_K3_J721E=y -CONFIG_TARGET_J7200_A72_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 -CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_OFFSET=0x680000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j7200-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x80080000 -CONFIG_OF_LIBFDT_OVERLAY=y -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_ENV_OFFSET_REDUND=0x6A0000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_PSCI_RESET is not set -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -CONFIG_OF_BOARD_SETUP=y -CONFIG_OF_SYSTEM_SETUP=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_fit_${boot}; run get_overlaystring; run run_fit" -CONFIG_LOGLEVEL=7 -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x80a00000 -CONFIG_SPL_BSS_MAX_SIZE=0x80000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_ASKENV=y -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_MTD=y -CONFIG_CMD_REMOTEPROC=y -CONFIG_CMD_UFS=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" -CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_ISO_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_CLK_CCF=y -CONFIG_CLK_TI_SCI=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_DFU_SF=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_SYS_DFU_MAX_FILE_SIZE=0x800000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x82000000 -CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_DM_I2C_GPIO=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ADMA=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_HBMC_AM654=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_STMICRO=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_MTD=y -CONFIG_MULTIPLEXER=y -CONFIG_MUX_MMIO=y -CONFIG_PHY_FIXED=y -CONFIG_TI_AM65_CPSW_NUSS=y -CONFIG_PHY=y -CONFIG_SPL_PHY=y -CONFIG_PHY_CADENCE_TORRENT=y -CONFIG_PHY_J721E_WIZ=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y -CONFIG_REMOTEPROC_TI_K3_R5F=y -CONFIG_RESET_TI_SCI=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_USB_CDNS3_HOST=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6164 -CONFIG_UFS=y -CONFIG_CADENCE_UFS=y -CONFIG_TI_J721E_UFS=y diff --git a/configs/j7200_hs_evm_r5_defconfig b/configs/j7200_hs_evm_r5_defconfig deleted file mode 100644 index 94a6523f06c2..000000000000 --- a/configs/j7200_hs_evm_r5_defconfig +++ /dev/null @@ -1,170 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x70000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SOC_K3_J721E=y -CONFIG_K3_EARLY_CONS=y -CONFIG_TARGET_J7200_R5_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41cf5bfc -CONFIG_ENV_SIZE=0x20000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j7200-r5-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x41c00000 -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -CONFIG_USE_BOOTCOMMAND=y -# CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x41cf5bfc -CONFIG_SPL_BSS_MAX_SIZE=0xa000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 -CONFIG_SPL_EARLY_BSS=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_EXT4=y -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -CONFIG_SPL_REMOTEPROC=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=64 -CONFIG_SYS_BOOTM_LEN=0x4000000 -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPT=y -CONFIG_CMD_MMC=y -CONFIG_CMD_REMOTEPROC=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_SPL_CLK_CCF=y -CONFIG_SPL_CLK_K3_PLL=y -CONFIG_SPL_CLK_K3=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_I2C_SET_DEFAULT_BUS_NUM=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_FS_LOADER=y -CONFIG_SPL_FS_LOADER=y -CONFIG_K3_AVS0=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_HBMC_AM654=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_TI_POWER_DOMAIN=y -CONFIG_DM_PMIC=y -CONFIG_PMIC_TPS65941=y -CONFIG_DM_REGULATOR=y -CONFIG_SPL_DM_REGULATOR=y -CONFIG_DM_REGULATOR_TPS65941=y -CONFIG_K3_SYSTEM_CONTROLLER=y -CONFIG_REMOTEPROC_TI_K3_ARM64=y -CONFIG_RESET_TI_SCI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_TIMER=y -CONFIG_SPL_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6164 -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y -CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 -CONFIG_LIB_RATIONAL=y -CONFIG_SPL_LIB_RATIONAL=y
Manorit Chawdhry
Nishanth Menon
Vignesh Raghavendra
