[U-Boot] [PATCH] Default to HOSTARCH if ARCH isn't specified
Its possible to build natively on several platforms so we might not explicitly set ARCH but detect it via HOSTARCH. As such there are some things that expect ARCH to be set to work correctly.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- Makefile | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/Makefile b/Makefile index e91c051..c56d6db 100644 --- a/Makefile +++ b/Makefile @@ -137,6 +137,10 @@ ifeq ($(ARCH),powerpc) ARCH = ppc endif
+ifndef ARCH +ARCH = $(HOSTARCH) +endif + ifeq ($(obj)include/config.mk,$(wildcard $(obj)include/config.mk))
# load ARCH, BOARD, and CPU configuration
Acked-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
Best Regards, J.
Dear Kumar Gala,
In message 1240247017-1069-1-git-send-email-galak@kernel.crashing.org you wrote:
In current mainline U-Boot, such a patch is not needed (which is just a friendly version of saying it does not make sense :-), because ARCH gets loaded from include/config.mk after running "make <board>_config".
Wolfgang Denk wrote:
Dear Kumar Gala,
In which case, we should probably add "override" to the place where it is set, so as to avoid interference from any ARCH variable that might be set (we could then remove the powerpc->ppc bit).
-Scott
Kumar Gala
Scott Wood
