[PATCH v4 00/27] Make LMB memory map global and persistent
This is a follow-up from an earlier RFC series [1] for making the LMB and EFI memory allocations work together. This is a non-rfc version with only the LMB part of the patches, for making the LMB memory map global and persistent.
This is part one of a set of patches which aim to have the LMB and EFI memory allocations work together. This requires making the LMB memory map global and persistent, instead of having local, caller specific maps. This is being done keeping in mind the usage of LMB memory by platforms where the same memory region can be used to load multiple different images. What is not allowed is to overwrite memory that has been allocated by the other module, currently the EFI memory module. This is being achieved by introducing a new flag, LMB_NOOVERWRITE, which represents memory which cannot be re-requested once allocated.
The data structures (alloced lists) required for maintaining the LMB map are initialised during board init. The LMB module is enabled by default for the main U-Boot image, while it needs to be enabled for SPL. This version also uses a stack implementation, as suggested by Simon Glass to temporarily store the lmb structure instance which is used during normal operation when running lmb tests. This does away with the need to run the lmb tests separately.
The tests have been tweaked where needed because of these changes.
The second part of the patches, to be sent subsequently, would work on having the EFI allocations work with the LMB API's.
[1] - https://lore.kernel.org/u-boot/20240704073544.670249-1-sughosh.ganu@linaro.o...
Notes:
1) These patches are on next, as the alist patches have been applied to that branch. 2) I have tested the boot on the ST DK2 board, but it would be good to get a T-b/R-b from the ST maintainers. 3) It will be good to test these changes on a PowerPC platform (ideally an 85xx, as I do not have one).
Changes since V3: * Fix checkpatch warnings of spaces between function name and open parantheses. * s/uint64_t/u64 as suggested by checkpatch. * Remove unneccessary parantheses in lmb.c as suggested by checkpatch. * Fix alignment in test/cmd/bdinfo.c as suggested by checkpatch. * Do away with multiple assignments in lmb_resize_regions() as suggested by checkpatch. * Fix the alignment in arch_lmb_reserve_generic() as suggested by checkpatch. * Removed the additional blank line in arch/powerpc/lib/misc.c as suggested by checkpatch. * Added spaces in the CFG_SYS_LINUX_LOWMEM_MAX_SIZE value as suggested by checkpatch. * Added a missing blank line in arch/powerpc/lib/misc.c as suggested by checkpatch. * s/16384/SZ_16K in lmb_reserve_uboot_region(). * Fix the corresponding comment for the above change. * Fixed the alignment in lmb_reserve_uboot_region() as suggested by checkpatch. * s/uint32_t/u32 in optee_get_reserved_memory() as suggested by checkpatch. * Put the tertiary expression in the puts() function call as suggested by Simon Glass. * s/uin64_t/u64 in lmb_print_region_flags() as suggested by checkpatch.
Sughosh Ganu (27): alist: add a helper to check if the list is full lmb: remove the unused lmb_is_reserved() function lmb: staticize __lmb_alloc_base() lmb: use the BIT macro for lmb flags lmb: make LMB memory map persistent and global lmb: allow for resizing lmb regions lmb: remove config symbols used for lmb region count lmb: config: add lmb config symbols for SPL lmb: allow lmb module to be used in SPL lmb: introduce a function to add memory to the lmb memory map lmb: reserve common areas during board init lmb: remove the lmb_init_and_reserve() function lmb: remove lmb_init_and_reserve_range() function lmb: bootm: remove superfluous lmb stub functions lmb: init: initialise the lmb data structures during board init ppc: lmb: move arch specific lmb reservations to arch_misc_init() lmb: do away with arch_lmb_reserve() lmb: remove the unused board_lmb_reserve() function sandbox: move the TCG event log to the start of ram memory spl: call spl_board_init() at the end of the spl init sequence spl: sandbox: initialise the ram banksize in spl sandbox: spl: enable lmb config for SPL sandbox: iommu: remove lmb allocation in the driver zynq: lmb: do not add to lmb map before relocation stm32mp: allow calling optee_get_reserved_memory() from U-Boot stm32mp: compute ram_top based on the optee base address lmb: add logic to print lmb flag strings
arch/arc/lib/cache.c | 14 - arch/arm/lib/stack.c | 14 - arch/arm/mach-apple/board.c | 17 +- arch/arm/mach-snapdragon/board.c | 17 +- arch/arm/mach-stm32mp/dram_init.c | 33 +- arch/arm/mach-stm32mp/include/mach/stm32mp.h | 11 + arch/arm/mach-stm32mp/stm32mp1/cpu.c | 7 +- arch/arm/mach-stm32mp/stm32mp1/spl.c | 17 +- arch/m68k/lib/bootm.c | 20 +- arch/microblaze/lib/bootm.c | 14 - arch/mips/lib/bootm.c | 22 +- arch/nios2/lib/bootm.c | 13 - arch/powerpc/cpu/mpc85xx/cpu_init.c | 16 - arch/powerpc/cpu/mpc85xx/mp.c | 4 +- arch/powerpc/include/asm/mp.h | 4 +- arch/powerpc/lib/Makefile | 1 + arch/powerpc/lib/bootm.c | 55 +- arch/powerpc/lib/misc.c | 62 ++ arch/riscv/lib/bootm.c | 13 - arch/sandbox/cpu/spl.c | 13 +- arch/sandbox/dts/test.dts | 2 +- arch/sandbox/include/asm/test.h | 4 + arch/sh/lib/bootm.c | 13 - arch/x86/lib/bootm.c | 18 - arch/xtensa/lib/bootm.c | 13 - board/xilinx/common/board.c | 33 - boot/bootm.c | 38 +- boot/bootm_os.c | 5 +- boot/image-board.c | 36 +- boot/image-fdt.c | 35 +- cmd/bdinfo.c | 5 +- cmd/booti.c | 2 +- cmd/bootz.c | 2 +- cmd/elf.c | 2 +- cmd/load.c | 7 +- common/board_r.c | 10 + common/spl/spl.c | 9 +- configs/a3y17lte_defconfig | 1 - configs/a5y17lte_defconfig | 1 - configs/a7y17lte_defconfig | 1 - configs/apple_m1_defconfig | 1 - configs/mt7981_emmc_rfb_defconfig | 1 - configs/mt7981_rfb_defconfig | 1 - configs/mt7981_sd_rfb_defconfig | 1 - configs/mt7986_rfb_defconfig | 1 - configs/mt7986a_bpir3_emmc_defconfig | 1 - configs/mt7986a_bpir3_sd_defconfig | 1 - configs/mt7988_rfb_defconfig | 1 - configs/mt7988_sd_rfb_defconfig | 1 - configs/qcom_defconfig | 1 - configs/sandbox_noinst_defconfig | 1 + configs/sandbox_spl_defconfig | 3 +- configs/stm32mp13_defconfig | 3 - configs/stm32mp15_basic_defconfig | 3 - configs/stm32mp15_defconfig | 3 - configs/stm32mp15_trusted_defconfig | 3 - configs/stm32mp25_defconfig | 3 - configs/th1520_lpi4a_defconfig | 1 - doc/arch/sandbox/sandbox.rst | 5 +- drivers/iommu/apple_dart.c | 8 +- drivers/iommu/sandbox_iommu.c | 35 +- fs/fs.c | 10 +- include/alist.h | 11 + include/image.h | 28 +- include/lmb.h | 129 ++-- lib/Kconfig | 45 +- lib/Makefile | 2 +- lib/efi_loader/efi_dt_fixup.c | 2 +- lib/efi_loader/efi_helper.c | 2 +- lib/lmb.c | 693 ++++++++++++------- net/tftp.c | 39 +- net/wget.c | 9 +- test/cmd/bdinfo.c | 41 +- test/lib/lmb.c | 542 +++++++-------- 74 files changed, 1044 insertions(+), 1191 deletions(-) create mode 100644 arch/arm/mach-stm32mp/include/mach/stm32mp.h create mode 100644 arch/powerpc/lib/misc.c
Add a helper function to check if the alist is full. This can then be used to extend the alist.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V3: None
include/alist.h | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/include/alist.h b/include/alist.h index 586a1efa5c..68d268f01a 100644 --- a/include/alist.h +++ b/include/alist.h @@ -82,6 +82,17 @@ static inline bool alist_err(struct alist *lst) return lst->flags & ALISTF_FAIL; }
+/** + * alist_full() - Check if the alist is full + * + * @lst: List to check + * Return: true if full, false otherwise + */ +static inline bool alist_full(struct alist *lst) +{ + return lst->count == lst->alloc; +} + /** * alist_get_ptr() - Get the value of a pointer *
The lmb_is_reserved() API is not used. There is another API, lmb_is_reserved_flags() which can be used to check if a particular memory region is reserved. Remove the unused API.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V3: None
include/lmb.h | 11 ----------- lib/lmb.c | 5 ----- 2 files changed, 16 deletions(-)
diff --git a/include/lmb.h b/include/lmb.h index 231b68b27d..6c50d93e83 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -117,17 +117,6 @@ phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phys_addr_t lmb_alloc_addr(struct lmb *lmb, phys_addr_t base, phys_size_t size); phys_size_t lmb_get_free_size(struct lmb *lmb, phys_addr_t addr);
-/** - * lmb_is_reserved() - test if address is in reserved region - * - * The function checks if a reserved region comprising @addr exists. - * - * @lmb: the logical memory block struct - * @addr: address to be tested - * Return: 1 if reservation exists, 0 otherwise - */ -int lmb_is_reserved(struct lmb *lmb, phys_addr_t addr); - /** * lmb_is_reserved_flags() - test if address is in reserved region with flag bits set * diff --git a/lib/lmb.c b/lib/lmb.c index 44f9820531..adc3abd5b4 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -565,11 +565,6 @@ int lmb_is_reserved_flags(struct lmb *lmb, phys_addr_t addr, int flags) return 0; }
-int lmb_is_reserved(struct lmb *lmb, phys_addr_t addr) -{ - return lmb_is_reserved_flags(lmb, addr, LMB_NONE); -} - __weak void board_lmb_reserve(struct lmb *lmb) { /* please define platform specific board_lmb_reserve() */
The __lmb_alloc_base() function is only called from within the lmb module. Moreover, the lmb_alloc() and lmb_alloc_base() API's are good enough for the allocation API calls. Make the __lmb_alloc_base() function static.
include/lmb.h | 2 -- lib/lmb.c | 39 ++++++++++++++++++++------------------- 2 files changed, 20 insertions(+), 21 deletions(-)
diff --git a/include/lmb.h b/include/lmb.h index 6c50d93e83..7b87181b9e 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -112,8 +112,6 @@ long lmb_reserve_flags(struct lmb *lmb, phys_addr_t base, phys_addr_t lmb_alloc(struct lmb *lmb, phys_size_t size, ulong align); phys_addr_t lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phys_addr_t max_addr); -phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, - phys_addr_t max_addr); phys_addr_t lmb_alloc_addr(struct lmb *lmb, phys_addr_t base, phys_size_t size); phys_size_t lmb_get_free_size(struct lmb *lmb, phys_addr_t addr);
diff --git a/lib/lmb.c b/lib/lmb.c index adc3abd5b4..4d39c0d1f9 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -435,30 +435,13 @@ static long lmb_overlaps_region(struct lmb_region *rgn, phys_addr_t base, return (i < rgn->cnt) ? i : -1; }
-phys_addr_t lmb_alloc(struct lmb *lmb, phys_size_t size, ulong align) -{ - return lmb_alloc_base(lmb, size, align, LMB_ALLOC_ANYWHERE); -} - -phys_addr_t lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phys_addr_t max_addr) -{ - phys_addr_t alloc; - - alloc = __lmb_alloc_base(lmb, size, align, max_addr); - - if (alloc == 0) - printf("ERROR: Failed to allocate 0x%lx bytes below 0x%lx.\n", - (ulong)size, (ulong)max_addr); - - return alloc; -} - static phys_addr_t lmb_align_down(phys_addr_t addr, phys_size_t size) { return addr & ~(size - 1); }
-phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phys_addr_t max_addr) +static phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, + ulong align, phys_addr_t max_addr) { long i, rgn; phys_addr_t base = 0; @@ -499,6 +482,24 @@ phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phy return 0; }
+phys_addr_t lmb_alloc(struct lmb *lmb, phys_size_t size, ulong align) +{ + return lmb_alloc_base(lmb, size, align, LMB_ALLOC_ANYWHERE); +} + +phys_addr_t lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phys_addr_t max_addr) +{ + phys_addr_t alloc; + + alloc = __lmb_alloc_base(lmb, size, align, max_addr); + + if (alloc == 0) + printf("ERROR: Failed to allocate 0x%lx bytes below 0x%lx.\n", + (ulong)size, (ulong)max_addr); + + return alloc; +} + /* * Try to allocate a specific address range: must be in defined memory but not * reserved
Use the BIT macro for assigning values to the LMB flags instead of assigning random values to them.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since V3: None
include/lmb.h | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/include/lmb.h b/include/lmb.h index 7b87181b9e..3de29d42de 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -5,6 +5,7 @@
#include <asm/types.h> #include <asm/u-boot.h> +#include <linux/bitops.h>
/* * Logical memory blocks. @@ -18,8 +19,8 @@ * @LMB_NOMAP: don't add to mmu configuration */ enum lmb_flags { - LMB_NONE = 0x0, - LMB_NOMAP = 0x4, + LMB_NONE = 0, + LMB_NOMAP = BIT(1), };
The current LMB API's for allocating and reserving memory use a per-caller based memory view. Memory allocated by a caller can then be overwritten by another caller. Make these allocations and reservations persistent using the alloced list data structure.
Two alloced lists are declared -- one for the available(free) memory, and one for the used memory. Once full, the list can then be extended at runtime.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Signed-off-by: Simon Glass sjg@chromium.org [sjg: Optimise the logic to add a region in lmb_add_region_flags()] [sjg: Use a stack to store pointer of lmb struct when running lmb tests] --- Changes since V3: * Fix checkpatch warnings of spaces between function name and open parantheses. * s/uint64_t/u64 as suggested by checkpatch. * Remove unneccessary parantheses in lmb.c as suggested by checkpatch. * Fix alignment in test/cmd/bdinfo.c as suggested by checkpatch.
arch/arc/lib/cache.c | 4 +- arch/arm/lib/stack.c | 4 +- arch/arm/mach-apple/board.c | 17 +- arch/arm/mach-snapdragon/board.c | 17 +- arch/arm/mach-stm32mp/dram_init.c | 8 +- arch/arm/mach-stm32mp/stm32mp1/cpu.c | 6 +- arch/m68k/lib/bootm.c | 7 +- arch/microblaze/lib/bootm.c | 4 +- arch/mips/lib/bootm.c | 11 +- arch/nios2/lib/bootm.c | 4 +- arch/powerpc/cpu/mpc85xx/mp.c | 4 +- arch/powerpc/include/asm/mp.h | 4 +- arch/powerpc/lib/bootm.c | 14 +- arch/riscv/lib/bootm.c | 4 +- arch/sh/lib/bootm.c | 4 +- arch/x86/lib/bootm.c | 4 +- arch/xtensa/lib/bootm.c | 4 +- board/xilinx/common/board.c | 8 +- boot/bootm.c | 26 +- boot/bootm_os.c | 5 +- boot/image-board.c | 34 +- boot/image-fdt.c | 35 +- cmd/bdinfo.c | 6 +- cmd/booti.c | 2 +- cmd/bootz.c | 2 +- cmd/elf.c | 2 +- cmd/load.c | 7 +- drivers/iommu/apple_dart.c | 8 +- drivers/iommu/sandbox_iommu.c | 16 +- fs/fs.c | 7 +- include/image.h | 28 +- include/lmb.h | 111 ++---- lib/efi_loader/efi_dt_fixup.c | 2 +- lib/efi_loader/efi_helper.c | 2 +- lib/lmb.c | 446 +++++++++++++--------- net/tftp.c | 5 +- net/wget.c | 5 +- test/cmd/bdinfo.c | 41 +- test/lib/lmb.c | 542 +++++++++++++-------------- 39 files changed, 714 insertions(+), 746 deletions(-)
diff --git a/arch/arc/lib/cache.c b/arch/arc/lib/cache.c index 22e748868a..5151af917a 100644 --- a/arch/arc/lib/cache.c +++ b/arch/arc/lib/cache.c @@ -829,7 +829,7 @@ static ulong get_sp(void) return ret; }
-void arch_lmb_reserve(struct lmb *lmb) +void arch_lmb_reserve(void) { - arch_lmb_reserve_generic(lmb, get_sp(), gd->ram_top, 4096); + arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); } diff --git a/arch/arm/lib/stack.c b/arch/arm/lib/stack.c index ea1b937add..87d5c962d7 100644 --- a/arch/arm/lib/stack.c +++ b/arch/arm/lib/stack.c @@ -42,7 +42,7 @@ static ulong get_sp(void) return ret; }
-void arch_lmb_reserve(struct lmb *lmb) +void arch_lmb_reserve(void) { - arch_lmb_reserve_generic(lmb, get_sp(), gd->ram_top, 16384); + arch_lmb_reserve_generic(get_sp(), gd->ram_top, 16384); } diff --git a/arch/arm/mach-apple/board.c b/arch/arm/mach-apple/board.c index 8bace3005e..213390d6e8 100644 --- a/arch/arm/mach-apple/board.c +++ b/arch/arm/mach-apple/board.c @@ -773,23 +773,22 @@ u64 get_page_table_size(void)
int board_late_init(void) { - struct lmb lmb; u32 status = 0;
- lmb_init_and_reserve(&lmb, gd->bd, (void *)gd->fdt_blob); + lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob);
/* somewhat based on the Linux Kernel boot requirements: * align by 2M and maximal FDT size 2M */ - status |= env_set_hex("loadaddr", lmb_alloc(&lmb, SZ_1G, SZ_2M)); - status |= env_set_hex("fdt_addr_r", lmb_alloc(&lmb, SZ_2M, SZ_2M)); - status |= env_set_hex("kernel_addr_r", lmb_alloc(&lmb, SZ_128M, SZ_2M)); - status |= env_set_hex("ramdisk_addr_r", lmb_alloc(&lmb, SZ_1G, SZ_2M)); + status |= env_set_hex("loadaddr", lmb_alloc(SZ_1G, SZ_2M)); + status |= env_set_hex("fdt_addr_r", lmb_alloc(SZ_2M, SZ_2M)); + status |= env_set_hex("kernel_addr_r", lmb_alloc(SZ_128M, SZ_2M)); + status |= env_set_hex("ramdisk_addr_r", lmb_alloc(SZ_1G, SZ_2M)); status |= env_set_hex("kernel_comp_addr_r", - lmb_alloc(&lmb, KERNEL_COMP_SIZE, SZ_2M)); + lmb_alloc(KERNEL_COMP_SIZE, SZ_2M)); status |= env_set_hex("kernel_comp_size", KERNEL_COMP_SIZE); - status |= env_set_hex("scriptaddr", lmb_alloc(&lmb, SZ_4M, SZ_2M)); - status |= env_set_hex("pxefile_addr_r", lmb_alloc(&lmb, SZ_4M, SZ_2M)); + status |= env_set_hex("scriptaddr", lmb_alloc(SZ_4M, SZ_2M)); + status |= env_set_hex("pxefile_addr_r", lmb_alloc(SZ_4M, SZ_2M));
if (status) log_warning("late_init: Failed to set run time variables\n"); diff --git a/arch/arm/mach-snapdragon/board.c b/arch/arm/mach-snapdragon/board.c index b439a19ec7..a63c8bec45 100644 --- a/arch/arm/mach-snapdragon/board.c +++ b/arch/arm/mach-snapdragon/board.c @@ -275,24 +275,23 @@ void __weak qcom_late_init(void)
#define KERNEL_COMP_SIZE SZ_64M
-#define addr_alloc(lmb, size) lmb_alloc(lmb, size, SZ_2M) +#define addr_alloc(size) lmb_alloc(size, SZ_2M)
/* Stolen from arch/arm/mach-apple/board.c */ int board_late_init(void) { - struct lmb lmb; u32 status = 0;
/* We need to be fairly conservative here as we support boards with just 1G of TOTAL RAM */ - status |= env_set_hex("kernel_addr_r", addr_alloc(&lmb, SZ_128M)); - status |= env_set_hex("ramdisk_addr_r", addr_alloc(&lmb, SZ_128M)); - status |= env_set_hex("kernel_comp_addr_r", addr_alloc(&lmb, KERNEL_COMP_SIZE)); + status |= env_set_hex("kernel_addr_r", addr_alloc(SZ_128M)); + status |= env_set_hex("ramdisk_addr_r", addr_alloc(SZ_128M)); + status |= env_set_hex("kernel_comp_addr_r", addr_alloc(KERNEL_COMP_SIZE)); status |= env_set_hex("kernel_comp_size", KERNEL_COMP_SIZE); - status |= env_set_hex("scriptaddr", addr_alloc(&lmb, SZ_4M)); - status |= env_set_hex("pxefile_addr_r", addr_alloc(&lmb, SZ_4M)); - status |= env_set_hex("fdt_addr_r", addr_alloc(&lmb, SZ_2M)); + status |= env_set_hex("scriptaddr", addr_alloc(SZ_4M)); + status |= env_set_hex("pxefile_addr_r", addr_alloc(SZ_4M)); + status |= env_set_hex("fdt_addr_r", addr_alloc(SZ_2M));
if (status) log_warning("%s: Failed to set run time variables\n", __func__); diff --git a/arch/arm/mach-stm32mp/dram_init.c b/arch/arm/mach-stm32mp/dram_init.c index 6024959b97..e8b0a38be1 100644 --- a/arch/arm/mach-stm32mp/dram_init.c +++ b/arch/arm/mach-stm32mp/dram_init.c @@ -47,7 +47,6 @@ phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { phys_size_t size; phys_addr_t reg; - struct lmb lmb;
if (!total_size) return gd->ram_top; @@ -59,12 +58,11 @@ phys_addr_t board_get_usable_ram_top(phys_size_t total_size) gd->ram_top = clamp_val(gd->ram_top, 0, SZ_4G - 1);
/* found enough not-reserved memory to relocated U-Boot */ - lmb_init(&lmb); - lmb_add(&lmb, gd->ram_base, gd->ram_top - gd->ram_base); - boot_fdt_add_mem_rsv_regions(&lmb, (void *)gd->fdt_blob); + lmb_add(gd->ram_base, gd->ram_top - gd->ram_base); + boot_fdt_add_mem_rsv_regions((void *)gd->fdt_blob); /* add 8M for reserved memory for display, fdt, gd,... */ size = ALIGN(SZ_8M + CONFIG_SYS_MALLOC_LEN + total_size, MMU_SECTION_SIZE), - reg = lmb_alloc(&lmb, size, MMU_SECTION_SIZE); + reg = lmb_alloc(size, MMU_SECTION_SIZE);
if (!reg) reg = gd->ram_top - size; diff --git a/arch/arm/mach-stm32mp/stm32mp1/cpu.c b/arch/arm/mach-stm32mp/stm32mp1/cpu.c index 478c3efae7..a913737342 100644 --- a/arch/arm/mach-stm32mp/stm32mp1/cpu.c +++ b/arch/arm/mach-stm32mp/stm32mp1/cpu.c @@ -30,8 +30,6 @@ */ u8 early_tlb[PGTABLE_SIZE] __section(".data") __aligned(0x4000);
-struct lmb lmb; - u32 get_bootmode(void) { /* read bootmode from TAMP backup register */ @@ -80,7 +78,7 @@ void dram_bank_mmu_setup(int bank) i < (start >> MMU_SECTION_SHIFT) + (size >> MMU_SECTION_SHIFT); i++) { option = DCACHE_DEFAULT_OPTION; - if (use_lmb && lmb_is_reserved_flags(&lmb, i << MMU_SECTION_SHIFT, LMB_NOMAP)) + if (use_lmb && lmb_is_reserved_flags(i << MMU_SECTION_SHIFT, LMB_NOMAP)) option = 0; /* INVALID ENTRY in TLB */ set_section_dcache(i, option); } @@ -144,7 +142,7 @@ int mach_cpu_init(void) void enable_caches(void) { /* parse device tree when data cache is still activated */ - lmb_init_and_reserve(&lmb, gd->bd, (void *)gd->fdt_blob); + lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob);
/* I-cache is already enabled in start.S: icache_enable() not needed */
diff --git a/arch/m68k/lib/bootm.c b/arch/m68k/lib/bootm.c index f2d02e4376..aee95f1e18 100644 --- a/arch/m68k/lib/bootm.c +++ b/arch/m68k/lib/bootm.c @@ -30,9 +30,9 @@ DECLARE_GLOBAL_DATA_PTR; static ulong get_sp (void); static void set_clocks_in_mhz (struct bd_info *kbd);
-void arch_lmb_reserve(struct lmb *lmb) +void arch_lmb_reserve(void) { - arch_lmb_reserve_generic(lmb, get_sp(), gd->ram_top, 1024); + arch_lmb_reserve_generic(get_sp(), gd->ram_top, 1024); }
int do_bootm_linux(int flag, struct bootm_info *bmi) @@ -41,7 +41,6 @@ int do_bootm_linux(int flag, struct bootm_info *bmi) int ret; struct bd_info *kbd; void (*kernel) (struct bd_info *, ulong, ulong, ulong, ulong); - struct lmb *lmb = &images->lmb;
/* * allow the PREP bootm subcommand, it is required for bootm to work @@ -53,7 +52,7 @@ int do_bootm_linux(int flag, struct bootm_info *bmi) return 1;
/* allocate space for kernel copy of board info */ - ret = boot_get_kbd (lmb, &kbd); + ret = boot_get_kbd(&kbd); if (ret) { puts("ERROR with allocation of kernel bd\n"); goto error; diff --git a/arch/microblaze/lib/bootm.c b/arch/microblaze/lib/bootm.c index cbe9d85aa9..ce96bca28f 100644 --- a/arch/microblaze/lib/bootm.c +++ b/arch/microblaze/lib/bootm.c @@ -32,9 +32,9 @@ static ulong get_sp(void) return ret; }
static void boot_jump_linux(struct bootm_headers *images, int flag) diff --git a/arch/mips/lib/bootm.c b/arch/mips/lib/bootm.c index adb6b6cc22..8fb3a3923f 100644 --- a/arch/mips/lib/bootm.c +++ b/arch/mips/lib/bootm.c @@ -37,9 +37,9 @@ static ulong arch_get_sp(void) return ret; }
-void arch_lmb_reserve(struct lmb *lmb) +void arch_lmb_reserve(void) { - arch_lmb_reserve_generic(lmb, arch_get_sp(), gd->ram_top, 4096); + arch_lmb_reserve_generic(arch_get_sp(), gd->ram_top, 4096); }
static void linux_cmdline_init(void) @@ -225,9 +225,8 @@ static int boot_reloc_fdt(struct bootm_headers *images) }
#if CONFIG_IS_ENABLED(MIPS_BOOT_FDT) && CONFIG_IS_ENABLED(OF_LIBFDT) - boot_fdt_add_mem_rsv_regions(&images->lmb, images->ft_addr); - return boot_relocate_fdt(&images->lmb, &images->ft_addr, - &images->ft_len); + boot_fdt_add_mem_rsv_regions(images->ft_addr); + return boot_relocate_fdt(&images->ft_addr, &images->ft_len); #else return 0; #endif @@ -248,7 +247,7 @@ static int boot_setup_fdt(struct bootm_headers *images) images->initrd_start = virt_to_phys((void *)images->initrd_start); images->initrd_end = virt_to_phys((void *)images->initrd_end);
- return image_setup_libfdt(images, images->ft_addr, &images->lmb); + return image_setup_libfdt(images, images->ft_addr, true); }
static void boot_prep_linux(struct bootm_headers *images) diff --git a/arch/nios2/lib/bootm.c b/arch/nios2/lib/bootm.c index ce939ff5e1..d33d45d28f 100644 --- a/arch/nios2/lib/bootm.c +++ b/arch/nios2/lib/bootm.c @@ -73,7 +73,7 @@ static ulong get_sp(void) return ret; }
-void arch_lmb_reserve(struct lmb *lmb) +void arch_lmb_reserve(void) { - arch_lmb_reserve_generic(lmb, get_sp(), gd->ram_top, 4096); + arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); } diff --git a/arch/powerpc/cpu/mpc85xx/mp.c b/arch/powerpc/cpu/mpc85xx/mp.c index 03f801ebbb..bed465cb2c 100644 --- a/arch/powerpc/cpu/mpc85xx/mp.c +++ b/arch/powerpc/cpu/mpc85xx/mp.c @@ -408,11 +408,11 @@ static void plat_mp_up(unsigned long bootpg, unsigned int pagesize) } #endif
-void cpu_mp_lmb_reserve(struct lmb *lmb) +void cpu_mp_lmb_reserve(void) { u32 bootpg = determine_mp_bootpg(NULL);
- lmb_reserve(lmb, bootpg, 4096); + lmb_reserve(bootpg, 4096); }
void setup_mp(void) diff --git a/arch/powerpc/include/asm/mp.h b/arch/powerpc/include/asm/mp.h index 8dacd2781d..b3f59be840 100644 --- a/arch/powerpc/include/asm/mp.h +++ b/arch/powerpc/include/asm/mp.h @@ -6,10 +6,8 @@ #ifndef _ASM_MP_H_ #define _ASM_MP_H_
-#include <lmb.h> - void setup_mp(void); -void cpu_mp_lmb_reserve(struct lmb *lmb); +void cpu_mp_lmb_reserve(void); u32 determine_mp_bootpg(unsigned int *pagesize); int is_core_disabled(int nr);
diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index 61e08728dd..752f72f873 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -116,7 +116,7 @@ static void boot_jump_linux(struct bootm_headers *images) return; }
-void arch_lmb_reserve(struct lmb *lmb) +void arch_lmb_reserve(void) { phys_size_t bootm_size; ulong size, bootmap_base; @@ -139,13 +139,13 @@ void arch_lmb_reserve(struct lmb *lmb) ulong base = bootmap_base + size; printf("WARNING: adjusting available memory from 0x%lx to 0x%llx\n", size, (unsigned long long)bootm_size); - lmb_reserve(lmb, base, bootm_size - size); + lmb_reserve(base, bootm_size - size); }
#ifdef CONFIG_MP - cpu_mp_lmb_reserve(lmb); + cpu_mp_lmb_reserve(); #endif
return; @@ -166,7 +166,6 @@ static void boot_prep_linux(struct bootm_headers *images) static int boot_cmdline_linux(struct bootm_headers *images) { ulong of_size = images->ft_len; - struct lmb *lmb = &images->lmb; ulong *cmd_start = &images->cmdline_start; ulong *cmd_end = &images->cmdline_end;
@@ -174,7 +173,7 @@ static int boot_cmdline_linux(struct bootm_headers *images)
if (!of_size) { /* allocate space and init command line */ - ret = boot_get_cmdline (lmb, cmd_start, cmd_end); + ret = boot_get_cmdline(cmd_start, cmd_end); if (ret) { puts("ERROR with allocation of cmdline\n"); return ret; @@ -187,14 +186,13 @@ static int boot_cmdline_linux(struct bootm_headers *images) static int boot_bd_t_linux(struct bootm_headers *images) { ulong of_size = images->ft_len; - struct lmb *lmb = &images->lmb; struct bd_info **kbd = &images->kbd;
int ret = 0;
if (!of_size) { /* allocate space for kernel copy of board info */ - ret = boot_get_kbd (lmb, kbd); + ret = boot_get_kbd(kbd); if (ret) { puts("ERROR with allocation of kernel bd\n"); return ret; diff --git a/arch/riscv/lib/bootm.c b/arch/riscv/lib/bootm.c index 13cbaaba68..bbf62f9e05 100644 --- a/arch/riscv/lib/bootm.c +++ b/arch/riscv/lib/bootm.c @@ -142,7 +142,7 @@ static ulong get_sp(void) return ret; }
-void arch_lmb_reserve(struct lmb *lmb) +void arch_lmb_reserve(void) { - arch_lmb_reserve_generic(lmb, get_sp(), gd->ram_top, 4096); + arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); } diff --git a/arch/sh/lib/bootm.c b/arch/sh/lib/bootm.c index e298d766b5..44ac05988c 100644 --- a/arch/sh/lib/bootm.c +++ b/arch/sh/lib/bootm.c @@ -110,7 +110,7 @@ static ulong get_sp(void) return ret; }
-void arch_lmb_reserve(struct lmb *lmb) +void arch_lmb_reserve(void) { - arch_lmb_reserve_generic(lmb, get_sp(), gd->ram_top, 4096); + arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); } diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index 2c889bcd33..114b31012e 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -267,7 +267,7 @@ static ulong get_sp(void) return ret; }
-void arch_lmb_reserve(struct lmb *lmb) +void arch_lmb_reserve(void) { - arch_lmb_reserve_generic(lmb, get_sp(), gd->ram_top, 4096); + arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); } diff --git a/arch/xtensa/lib/bootm.c b/arch/xtensa/lib/bootm.c index 1de06b7fb5..bdbd6d4692 100644 --- a/arch/xtensa/lib/bootm.c +++ b/arch/xtensa/lib/bootm.c @@ -206,7 +206,7 @@ static ulong get_sp(void) return ret; }
-void arch_lmb_reserve(struct lmb *lmb) +void arch_lmb_reserve(void) { - arch_lmb_reserve_generic(lmb, get_sp(), gd->ram_top, 4096); + arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); } diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 0b43407b9e..4056884400 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -675,7 +675,6 @@ phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { phys_size_t size; phys_addr_t reg; - struct lmb lmb;
if (!total_size) return gd->ram_top; @@ -684,11 +683,10 @@ phys_addr_t board_get_usable_ram_top(phys_size_t total_size) panic("Not 64bit aligned DT location: %p\n", gd->fdt_blob);
/* found enough not-reserved memory to relocated U-Boot */ - lmb_init(&lmb); - lmb_add(&lmb, gd->ram_base, gd->ram_size); - boot_fdt_add_mem_rsv_regions(&lmb, (void *)gd->fdt_blob); + lmb_add(gd->ram_base, gd->ram_size); + boot_fdt_add_mem_rsv_regions((void *)gd->fdt_blob); size = ALIGN(CONFIG_SYS_MALLOC_LEN + total_size, MMU_SECTION_SIZE); - reg = lmb_alloc(&lmb, size, MMU_SECTION_SIZE); + reg = lmb_alloc(size, MMU_SECTION_SIZE);
if (!reg) reg = gd->ram_top - size; diff --git a/boot/bootm.c b/boot/bootm.c index 480f8e6a0e..d47feddb9b 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -240,7 +240,7 @@ static int boot_get_kernel(const char *addr_fit, struct bootm_headers *images, }
#ifdef CONFIG_LMB -static void boot_start_lmb(struct bootm_headers *images) +static void boot_start_lmb(void) { phys_addr_t mem_start; phys_size_t mem_size; @@ -248,12 +248,11 @@ static void boot_start_lmb(struct bootm_headers *images) mem_start = env_get_bootm_low(); mem_size = env_get_bootm_size();
- lmb_init_and_reserve_range(&images->lmb, mem_start, - mem_size, NULL); + lmb_init_and_reserve_range(mem_start, mem_size, NULL); } #else -#define lmb_reserve(lmb, base, size) -static inline void boot_start_lmb(struct bootm_headers *images) { } +#define lmb_reserve(base, size) +static inline void boot_start_lmb(void) { } #endif
static int bootm_start(void) @@ -261,7 +260,7 @@ static int bootm_start(void) memset((void *)&images, 0, sizeof(images)); images.verify = env_get_yesno("verify");
- boot_start_lmb(&images); + boot_start_lmb();
bootstage_mark_name(BOOTSTAGE_ID_BOOTM_START, "bootm_start"); images.state = BOOTM_STATE_START; @@ -640,7 +639,7 @@ static int bootm_load_os(struct bootm_headers *images, int boot_progress) if (os.type == IH_TYPE_KERNEL_NOLOAD && os.comp != IH_COMP_NONE) { ulong req_size = ALIGN(image_len * 4, SZ_1M);
- load = lmb_alloc(&images->lmb, req_size, SZ_2M); + load = lmb_alloc(req_size, SZ_2M); if (!load) return 1; os.load = load; @@ -714,8 +713,7 @@ static int bootm_load_os(struct bootm_headers *images, int boot_progress) images->os.end = relocated_addr + image_size; }
- lmb_reserve(&images->lmb, images->os.load, (load_end - - images->os.load)); + lmb_reserve(images->os.load, (load_end - images->os.load)); return 0; }
@@ -1029,8 +1027,9 @@ int bootm_run_states(struct bootm_info *bmi, int states) if (!ret && (states & BOOTM_STATE_RAMDISK)) { ulong rd_len = images->rd_end - images->rd_start;
- ret = boot_ramdisk_high(&images->lmb, images->rd_start, - rd_len, &images->initrd_start, &images->initrd_end); + ret = boot_ramdisk_high(images->rd_start, rd_len, + &images->initrd_start, + &images->initrd_end); if (!ret) { env_set_hex("initrd_start", images->initrd_start); env_set_hex("initrd_end", images->initrd_end); @@ -1039,9 +1038,8 @@ int bootm_run_states(struct bootm_info *bmi, int states) #endif #if CONFIG_IS_ENABLED(OF_LIBFDT) && defined(CONFIG_LMB) if (!ret && (states & BOOTM_STATE_FDT)) { - boot_fdt_add_mem_rsv_regions(&images->lmb, images->ft_addr); - ret = boot_relocate_fdt(&images->lmb, &images->ft_addr, - &images->ft_len); + boot_fdt_add_mem_rsv_regions(images->ft_addr); + ret = boot_relocate_fdt(&images->ft_addr, &images->ft_len); } #endif
diff --git a/boot/bootm_os.c b/boot/bootm_os.c index 6a6621706f..e9522cd329 100644 --- a/boot/bootm_os.c +++ b/boot/bootm_os.c @@ -260,12 +260,11 @@ static void do_bootvx_fdt(struct bootm_headers *images) char *bootline; ulong of_size = images->ft_len; char **of_flat_tree = &images->ft_addr; - struct lmb *lmb = &images->lmb;
if (*of_flat_tree) { - boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree); + boot_fdt_add_mem_rsv_regions(*of_flat_tree);
- ret = boot_relocate_fdt(lmb, of_flat_tree, &of_size); + ret = boot_relocate_fdt(of_flat_tree, &of_size); if (ret) return;
diff --git a/boot/image-board.c b/boot/image-board.c index f212401304..1f8c1ac69f 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -515,7 +515,6 @@ int boot_get_ramdisk(char const *select, struct bootm_headers *images,
/** * boot_ramdisk_high - relocate init ramdisk - * @lmb: pointer to lmb handle, will be used for memory mgmt * @rd_data: ramdisk data start address * @rd_len: ramdisk data length * @initrd_start: pointer to a ulong variable, will hold final init ramdisk @@ -534,8 +533,8 @@ int boot_get_ramdisk(char const *select, struct bootm_headers *images, * 0 - success * -1 - failure */ -int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, - ulong *initrd_start, ulong *initrd_end) +int boot_ramdisk_high(ulong rd_data, ulong rd_len, ulong *initrd_start, + ulong *initrd_end) { char *s; phys_addr_t initrd_high; @@ -561,13 +560,14 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, debug(" in-place initrd\n"); *initrd_start = rd_data; *initrd_end = rd_data + rd_len; - lmb_reserve(lmb, rd_data, rd_len); + lmb_reserve(rd_data, rd_len); } else { if (initrd_high) - *initrd_start = (ulong)lmb_alloc_base(lmb, - rd_len, 0x1000, initrd_high); + *initrd_start = (ulong)lmb_alloc_base(rd_len, + 0x1000, + initrd_high); else - *initrd_start = (ulong)lmb_alloc(lmb, rd_len, + *initrd_start = (ulong)lmb_alloc(rd_len, 0x1000);
if (*initrd_start == 0) { @@ -800,7 +800,6 @@ int boot_get_loadable(struct bootm_headers *images)
/** * boot_get_cmdline - allocate and initialize kernel cmdline - * @lmb: pointer to lmb handle, will be used for memory mgmt * @cmd_start: pointer to a ulong variable, will hold cmdline start * @cmd_end: pointer to a ulong variable, will hold cmdline end * @@ -813,7 +812,7 @@ int boot_get_loadable(struct bootm_headers *images) * 0 - success * -1 - failure */ -int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end) +int boot_get_cmdline(ulong *cmd_start, ulong *cmd_end) { int barg; char *cmdline; @@ -827,7 +826,7 @@ int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end) return 0;
barg = IF_ENABLED_INT(CONFIG_SYS_BOOT_GET_CMDLINE, CONFIG_SYS_BARGSIZE); - cmdline = (char *)(ulong)lmb_alloc_base(lmb, barg, 0xf, + cmdline = (char *)(ulong)lmb_alloc_base(barg, 0xf, env_get_bootm_mapsize() + env_get_bootm_low()); if (!cmdline) return -1; @@ -848,7 +847,6 @@ int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end)
/** * boot_get_kbd - allocate and initialize kernel copy of board info - * @lmb: pointer to lmb handle, will be used for memory mgmt * @kbd: double pointer to board info data * * boot_get_kbd() allocates space for kernel copy of board info data below @@ -859,10 +857,9 @@ int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end) * 0 - success * -1 - failure */ -int boot_get_kbd(struct lmb *lmb, struct bd_info **kbd) +int boot_get_kbd(struct bd_info **kbd) { - *kbd = (struct bd_info *)(ulong)lmb_alloc_base(lmb, - sizeof(struct bd_info), + *kbd = (struct bd_info *)(ulong)lmb_alloc_base(sizeof(struct bd_info), 0xf, env_get_bootm_mapsize() + env_get_bootm_low()); @@ -883,17 +880,16 @@ int image_setup_linux(struct bootm_headers *images) { ulong of_size = images->ft_len; char **of_flat_tree = &images->ft_addr; - struct lmb *lmb = images_lmb(images); int ret;
/* This function cannot be called without lmb support */ if (!IS_ENABLED(CONFIG_LMB)) return -EFAULT; if (CONFIG_IS_ENABLED(OF_LIBFDT)) - boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree); + boot_fdt_add_mem_rsv_regions(*of_flat_tree);
if (IS_ENABLED(CONFIG_SYS_BOOT_GET_CMDLINE)) { - ret = boot_get_cmdline(lmb, &images->cmdline_start, + ret = boot_get_cmdline(&images->cmdline_start, &images->cmdline_end); if (ret) { puts("ERROR with allocation of cmdline\n"); @@ -902,13 +898,13 @@ int image_setup_linux(struct bootm_headers *images) }
if (CONFIG_IS_ENABLED(OF_LIBFDT)) { - ret = boot_relocate_fdt(lmb, of_flat_tree, &of_size); + ret = boot_relocate_fdt(of_flat_tree, &of_size); if (ret) return ret; }
if (CONFIG_IS_ENABLED(OF_LIBFDT) && of_size) { - ret = image_setup_libfdt(images, *of_flat_tree, lmb); + ret = image_setup_libfdt(images, *of_flat_tree, true); if (ret) return ret; } diff --git a/boot/image-fdt.c b/boot/image-fdt.c index 8332792b8e..8eda521693 100644 --- a/boot/image-fdt.c +++ b/boot/image-fdt.c @@ -68,12 +68,11 @@ static const struct legacy_img_hdr *image_get_fdt(ulong fdt_addr) } #endif
-static void boot_fdt_reserve_region(struct lmb *lmb, uint64_t addr, - uint64_t size, enum lmb_flags flags) +static void boot_fdt_reserve_region(u64 addr, u64 size, enum lmb_flags flags) { long ret;
- ret = lmb_reserve_flags(lmb, addr, size, flags); + ret = lmb_reserve_flags(addr, size, flags); if (ret >= 0) { debug(" reserving fdt memory region: addr=%llx size=%llx flags=%x\n", (unsigned long long)addr, @@ -89,14 +88,13 @@ static void boot_fdt_reserve_region(struct lmb *lmb, uint64_t addr, /** * boot_fdt_add_mem_rsv_regions - Mark the memreserve and reserved-memory * sections as unusable - * @lmb: pointer to lmb handle, will be used for memory mgmt * @fdt_blob: pointer to fdt blob base address * * Adds the and reserved-memorymemreserve regions in the dtb to the lmb block. * Adding the memreserve regions prevents u-boot from using them to store the * initrd or the fdt blob. */ -void boot_fdt_add_mem_rsv_regions(struct lmb *lmb, void *fdt_blob) +void boot_fdt_add_mem_rsv_regions(void *fdt_blob) { uint64_t addr, size; int i, total, ret; @@ -112,7 +110,7 @@ void boot_fdt_add_mem_rsv_regions(struct lmb *lmb, void *fdt_blob) for (i = 0; i < total; i++) { if (fdt_get_mem_rsv(fdt_blob, i, &addr, &size) != 0) continue; - boot_fdt_reserve_region(lmb, addr, size, LMB_NONE); + boot_fdt_reserve_region(addr, size, LMB_NONE); }
/* process reserved-memory */ @@ -130,7 +128,7 @@ void boot_fdt_add_mem_rsv_regions(struct lmb *lmb, void *fdt_blob) flags = LMB_NOMAP; addr = res.start; size = res.end - res.start + 1; - boot_fdt_reserve_region(lmb, addr, size, flags); + boot_fdt_reserve_region(addr, size, flags); }
subnode = fdt_next_subnode(fdt_blob, subnode); @@ -140,7 +138,6 @@ void boot_fdt_add_mem_rsv_regions(struct lmb *lmb, void *fdt_blob)
/** * boot_relocate_fdt - relocate flat device tree - * @lmb: pointer to lmb handle, will be used for memory mgmt * @of_flat_tree: pointer to a char* variable, will hold fdt start address * @of_size: pointer to a ulong variable, will hold fdt length * @@ -155,7 +152,7 @@ void boot_fdt_add_mem_rsv_regions(struct lmb *lmb, void *fdt_blob) * 0 - success * 1 - failure */ -int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) +int boot_relocate_fdt(char **of_flat_tree, ulong *of_size) { u64 start, size, usable, addr, low, mapsize; void *fdt_blob = *of_flat_tree; @@ -187,18 +184,17 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) if (desired_addr == ~0UL) { /* All ones means use fdt in place */ of_start = fdt_blob; - lmb_reserve(lmb, map_to_sysmem(of_start), of_len); + lmb_reserve(map_to_sysmem(of_start), of_len); disable_relocation = 1; } else if (desired_addr) { - addr = lmb_alloc_base(lmb, of_len, 0x1000, - desired_addr); + addr = lmb_alloc_base(of_len, 0x1000, desired_addr); of_start = map_sysmem(addr, of_len); if (of_start == NULL) { puts("Failed using fdt_high value for Device Tree"); goto error; } } else { - addr = lmb_alloc(lmb, of_len, 0x1000); + addr = lmb_alloc(of_len, 0x1000); of_start = map_sysmem(addr, of_len); } } else { @@ -220,7 +216,7 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) * for LMB allocation. */ usable = min(start + size, low + mapsize); - addr = lmb_alloc_base(lmb, of_len, 0x1000, usable); + addr = lmb_alloc_base(of_len, 0x1000, usable); of_start = map_sysmem(addr, of_len); /* Allocation succeeded, use this block. */ if (of_start != NULL) @@ -569,8 +565,7 @@ __weak int arch_fixup_fdt(void *blob) return 0; }
-int image_setup_libfdt(struct bootm_headers *images, void *blob, - struct lmb *lmb) +int image_setup_libfdt(struct bootm_headers *images, void *blob, bool lmb) { ulong *initrd_start = &images->initrd_start; ulong *initrd_end = &images->initrd_end; @@ -670,8 +665,8 @@ int image_setup_libfdt(struct bootm_headers *images, void *blob, }
/* Delete the old LMB reservation */ - if (lmb) - lmb_free(lmb, map_to_sysmem(blob), fdt_totalsize(blob)); + if (CONFIG_IS_ENABLED(LMB) && lmb) + lmb_free(map_to_sysmem(blob), fdt_totalsize(blob));
ret = fdt_shrink_to_minimum(blob, 0); if (ret < 0) @@ -679,8 +674,8 @@ int image_setup_libfdt(struct bootm_headers *images, void *blob, of_size = ret;
/* Create a new LMB reservation */ - if (lmb) - lmb_reserve(lmb, map_to_sysmem(blob), of_size); + if (CONFIG_IS_ENABLED(LMB) && lmb) + lmb_reserve(map_to_sysmem(blob), of_size);
#if defined(CONFIG_ARCH_KEYSTONE) if (IS_ENABLED(CONFIG_OF_BOARD_SETUP)) diff --git a/cmd/bdinfo.c b/cmd/bdinfo.c index 437ac4e863..b31e0208df 100644 --- a/cmd/bdinfo.c +++ b/cmd/bdinfo.c @@ -162,10 +162,8 @@ static int bdinfo_print_all(struct bd_info *bd) bdinfo_print_num_l("multi_dtb_fit", (ulong)gd->multi_dtb_fit); #endif if (IS_ENABLED(CONFIG_LMB) && gd->fdt_blob) { - struct lmb lmb; - - lmb_init_and_reserve(&lmb, gd->bd, (void *)gd->fdt_blob); - lmb_dump_all_force(&lmb); + lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob); + lmb_dump_all_force(); if (IS_ENABLED(CONFIG_OF_REAL)) printf("devicetree = %s\n", fdtdec_get_srcname()); } diff --git a/cmd/booti.c b/cmd/booti.c index 62b19e8343..6018cbacf0 100644 --- a/cmd/booti.c +++ b/cmd/booti.c @@ -87,7 +87,7 @@ static int booti_start(struct bootm_info *bmi) images->os.start = relocated_addr; images->os.end = relocated_addr + image_size;
- lmb_reserve(&images->lmb, images->ep, le32_to_cpu(image_size)); + lmb_reserve(images->ep, le32_to_cpu(image_size));
/* * Handle the BOOTM_STATE_FINDOTHER state ourselves as we do not diff --git a/cmd/bootz.c b/cmd/bootz.c index 55837a7599..787203f5bd 100644 --- a/cmd/bootz.c +++ b/cmd/bootz.c @@ -56,7 +56,7 @@ static int bootz_start(struct cmd_tbl *cmdtp, int flag, int argc, if (ret != 0) return 1;
- lmb_reserve(&images->lmb, images->ep, zi_end - zi_start); + lmb_reserve(images->ep, zi_end - zi_start);
/* * Handle the BOOTM_STATE_FINDOTHER state ourselves as we do not diff --git a/cmd/elf.c b/cmd/elf.c index 673c6c3051..f07e344a59 100644 --- a/cmd/elf.c +++ b/cmd/elf.c @@ -70,7 +70,7 @@ int do_bootelf(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[])
fdt_set_totalsize((void *)fdt_addr, fdt_totalsize(fdt_addr) + CONFIG_SYS_FDT_PAD); - if (image_setup_libfdt(&img, (void *)fdt_addr, NULL)) + if (image_setup_libfdt(&img, (void *)fdt_addr, false)) return 1; } #endif diff --git a/cmd/load.c b/cmd/load.c index d773a25d70..56da3a4c5d 100644 --- a/cmd/load.c +++ b/cmd/load.c @@ -141,7 +141,6 @@ static int do_load_serial(struct cmd_tbl *cmdtp, int flag, int argc,
static ulong load_serial(long offset) { - struct lmb lmb; char record[SREC_MAXRECLEN + 1]; /* buffer for one S-Record */ char binbuf[SREC_MAXBINLEN]; /* buffer for binary data */ int binlen; /* no. of data bytes in S-Rec. */ @@ -154,7 +153,7 @@ static ulong load_serial(long offset) int line_count = 0; long ret;
while (read_record(record, SREC_MAXRECLEN + 1) >= 0) { type = srec_decode(record, &binlen, &addr, binbuf); @@ -182,7 +181,7 @@ static ulong load_serial(long offset) { void *dst;
- ret = lmb_reserve(&lmb, store_addr, binlen); + ret = lmb_reserve(store_addr, binlen); if (ret) { printf("\nCannot overwrite reserved area (%08lx..%08lx)\n", store_addr, store_addr + binlen); @@ -191,7 +190,7 @@ static ulong load_serial(long offset) dst = map_sysmem(store_addr, binlen); memcpy(dst, binbuf, binlen); unmap_sysmem(dst); - lmb_free(&lmb, store_addr, binlen); + lmb_free(store_addr, binlen); } if ((store_addr) < start_addr) start_addr = store_addr; diff --git a/drivers/iommu/apple_dart.c b/drivers/iommu/apple_dart.c index 9327dea1e3..611ac7cd6d 100644 --- a/drivers/iommu/apple_dart.c +++ b/drivers/iommu/apple_dart.c @@ -70,7 +70,6 @@
struct apple_dart_priv { void *base; - struct lmb lmb; u64 *l1, *l2; int bypass, shift;
@@ -124,7 +123,7 @@ static dma_addr_t apple_dart_map(struct udevice *dev, void *addr, size_t size) off = (phys_addr_t)addr - paddr; psize = ALIGN(size + off, DART_PAGE_SIZE);
- dva = lmb_alloc(&priv->lmb, psize, DART_PAGE_SIZE); + dva = lmb_alloc(psize, DART_PAGE_SIZE);
idx = dva / DART_PAGE_SIZE; for (i = 0; i < psize / DART_PAGE_SIZE; i++) { @@ -160,7 +159,7 @@ static void apple_dart_unmap(struct udevice *dev, dma_addr_t addr, size_t size) (unsigned long)&priv->l2[idx + i]); priv->flush_tlb(priv);
- lmb_free(&priv->lmb, dva, psize); + lmb_free(dva, psize); }
static struct iommu_ops apple_dart_ops = { @@ -213,8 +212,7 @@ static int apple_dart_probe(struct udevice *dev) priv->dvabase = DART_PAGE_SIZE; priv->dvaend = SZ_4G - DART_PAGE_SIZE;
- lmb_init(&priv->lmb); - lmb_add(&priv->lmb, priv->dvabase, priv->dvaend - priv->dvabase); + lmb_add(priv->dvabase, priv->dvaend - priv->dvabase);
/* Disable translations. */ for (sid = 0; sid < priv->nsid; sid++) diff --git a/drivers/iommu/sandbox_iommu.c b/drivers/iommu/sandbox_iommu.c index e37976f86f..5b4a6a8982 100644 --- a/drivers/iommu/sandbox_iommu.c +++ b/drivers/iommu/sandbox_iommu.c @@ -11,14 +11,9 @@
#define IOMMU_PAGE_SIZE SZ_4K
-struct sandbox_iommu_priv { - struct lmb lmb; -}; - static dma_addr_t sandbox_iommu_map(struct udevice *dev, void *addr, size_t size) { - struct sandbox_iommu_priv *priv = dev_get_priv(dev); phys_addr_t paddr, dva; phys_size_t psize, off;
@@ -26,7 +21,7 @@ static dma_addr_t sandbox_iommu_map(struct udevice *dev, void *addr, off = virt_to_phys(addr) - paddr; psize = ALIGN(size + off, IOMMU_PAGE_SIZE);
- dva = lmb_alloc(&priv->lmb, psize, IOMMU_PAGE_SIZE); + dva = lmb_alloc(psize, IOMMU_PAGE_SIZE);
return dva + off; } @@ -34,7 +29,6 @@ static dma_addr_t sandbox_iommu_map(struct udevice *dev, void *addr, static void sandbox_iommu_unmap(struct udevice *dev, dma_addr_t addr, size_t size) { - struct sandbox_iommu_priv *priv = dev_get_priv(dev); phys_addr_t dva; phys_size_t psize;
@@ -42,7 +36,7 @@ static void sandbox_iommu_unmap(struct udevice *dev, dma_addr_t addr, psize = size + (addr - dva); psize = ALIGN(psize, IOMMU_PAGE_SIZE);
static struct iommu_ops sandbox_iommu_ops = { @@ -52,10 +46,7 @@ static struct iommu_ops sandbox_iommu_ops = {
static int sandbox_iommu_probe(struct udevice *dev) { - struct sandbox_iommu_priv *priv = dev_get_priv(dev); - - lmb_init(&priv->lmb); - lmb_add(&priv->lmb, 0x89abc000, SZ_16K); + lmb_add(0x89abc000, SZ_16K);
return 0; } @@ -69,7 +60,6 @@ U_BOOT_DRIVER(sandbox_iommu) = { .name = "sandbox_iommu", .id = UCLASS_IOMMU, .of_match = sandbox_iommu_ids, - .priv_auto = sizeof(struct sandbox_iommu_priv), .ops = &sandbox_iommu_ops, .probe = sandbox_iommu_probe, }; diff --git a/fs/fs.c b/fs/fs.c index 0c47943f33..2c835eef86 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -531,7 +531,6 @@ int fs_size(const char *filename, loff_t *size) static int fs_read_lmb_check(const char *filename, ulong addr, loff_t offset, loff_t len, struct fstype_info *info) { - struct lmb lmb; int ret; loff_t size; loff_t read_len; @@ -550,10 +549,10 @@ static int fs_read_lmb_check(const char *filename, ulong addr, loff_t offset, if (len && len < read_len) read_len = len;
- lmb_init_and_reserve(&lmb, gd->bd, (void *)gd->fdt_blob); - lmb_dump_all(&lmb); + lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob); + lmb_dump_all();
- if (lmb_alloc_addr(&lmb, addr, read_len) == addr) + if (lmb_alloc_addr(addr, read_len) == addr) return 0;
log_err("** Reading file would overwrite reserved memory **\n"); diff --git a/include/image.h b/include/image.h index dd4042d1bd..74838a2f75 100644 --- a/include/image.h +++ b/include/image.h @@ -20,7 +20,6 @@ #include <stdbool.h>
/* Define this to avoid #ifdefs later on */ -struct lmb; struct fdt_region;
#ifdef USE_HOSTCC @@ -412,18 +411,8 @@ struct bootm_headers { #define BOOTM_STATE_PRE_LOAD 0x00000800 #define BOOTM_STATE_MEASURE 0x00001000 int state; - -#if defined(CONFIG_LMB) && !defined(USE_HOSTCC) - struct lmb lmb; /* for memory mgmt */ -#endif };
-#ifdef CONFIG_LMB -#define images_lmb(_images) (&(_images)->lmb) -#else -#define images_lmb(_images) NULL -#endif - extern struct bootm_headers images;
/* @@ -835,13 +824,13 @@ int boot_get_fdt(void *buf, const char *select, uint arch, struct bootm_headers *images, char **of_flat_tree, ulong *of_size);
-void boot_fdt_add_mem_rsv_regions(struct lmb *lmb, void *fdt_blob); -int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size); +void boot_fdt_add_mem_rsv_regions(void *fdt_blob); +int boot_relocate_fdt(char **of_flat_tree, ulong *of_size);
-int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, - ulong *initrd_start, ulong *initrd_end); -int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end); -int boot_get_kbd(struct lmb *lmb, struct bd_info **kbd); +int boot_ramdisk_high(ulong rd_data, ulong rd_len, ulong *initrd_start, + ulong *initrd_end); +int boot_get_cmdline(ulong *cmd_start, ulong *cmd_end); +int boot_get_kbd(struct bd_info **kbd);
/*******************************************************************/ /* Legacy format specific code (prefixed with image_) */ @@ -1029,11 +1018,10 @@ int image_decomp(int comp, ulong load, ulong image_start, int type, * * @images: Images information * @blob: FDT to update - * @lmb: Points to logical memory block structure + * @lmb: Flag indicating use of lmb for reserving FDT memory region * Return: 0 if ok, <0 on failure */ -int image_setup_libfdt(struct bootm_headers *images, void *blob, - struct lmb *lmb); +int image_setup_libfdt(struct bootm_headers *images, void *blob, bool lmb);
/** * Set up the FDT to use for booting a kernel diff --git a/include/lmb.h b/include/lmb.h index 3de29d42de..0979dcebc0 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -3,6 +3,7 @@ #define _LINUX_LMB_H #ifdef __KERNEL__
+#include <alist.h> #include <asm/types.h> #include <asm/u-boot.h> #include <linux/bitops.h> @@ -24,97 +25,62 @@ enum lmb_flags { };
/** - * struct lmb_property - Description of one region. + * struct lmb_region - Description of one region. * * @base: Base address of the region. * @size: Size of the region * @flags: memory region attributes */ -struct lmb_property { +struct lmb_region { phys_addr_t base; phys_size_t size; enum lmb_flags flags; };
-/* - * For regions size management, see LMB configuration in KConfig - * all the #if test are done with CONFIG_LMB_USE_MAX_REGIONS (boolean) - * - * case 1. CONFIG_LMB_USE_MAX_REGIONS is defined (legacy mode) - * => CONFIG_LMB_MAX_REGIONS is used to configure the region size, - * directly in the array lmb_region.region[], with the same - * configuration for memory and reserved regions. - * - * case 2. CONFIG_LMB_USE_MAX_REGIONS is not defined, the size of each - * region is configurated *independently* with - * => CONFIG_LMB_MEMORY_REGIONS: struct lmb.memory_regions - * => CONFIG_LMB_RESERVED_REGIONS: struct lmb.reserved_regions - * lmb_region.region is only a pointer to the correct buffer, - * initialized in lmb_init(). This configuration is useful to manage - * more reserved memory regions with CONFIG_LMB_RESERVED_REGIONS. - */ - /** - * struct lmb_region - Description of a set of region. + * struct lmb - The LMB structure * - * @cnt: Number of regions. - * @max: Size of the region array, max value of cnt. - * @region: Array of the region properties + * @free_mem: List of free memory regions + * @used_mem: List of used/reserved memory regions */ -struct lmb_region { - unsigned long cnt; - unsigned long max; -#if IS_ENABLED(CONFIG_LMB_USE_MAX_REGIONS) - struct lmb_property region[CONFIG_LMB_MAX_REGIONS]; -#else - struct lmb_property *region; -#endif +struct lmb { + struct alist free_mem; + struct alist used_mem; };
/** - * struct lmb - Logical memory block handle. + * lmb_init() - Initialise the LMB module * - * Clients provide storage for Logical memory block (lmb) handles. - * The content of the structure is managed by the lmb library. - * A lmb struct is initialized by lmb_init() functions. - * The lmb struct is passed to all other lmb APIs. + * Initialise the LMB lists needed for keeping the memory map. There + * are two lists, in form of alloced list data structure. One for the + * available memory, and one for the used memory. Initialise the two + * lists as part of board init. Add memory to the available memory + * list and reserve common areas by adding them to the used memory + * list. * - * @memory: Description of memory regions. - * @reserved: Description of reserved regions. - * @memory_regions: Array of the memory regions (statically allocated) - * @reserved_regions: Array of the reserved regions (statically allocated) + * Return: 0 on success, -ve on error */ -struct lmb { - struct lmb_region memory; - struct lmb_region reserved; -#if !IS_ENABLED(CONFIG_LMB_USE_MAX_REGIONS) - struct lmb_property memory_regions[CONFIG_LMB_MEMORY_REGIONS]; - struct lmb_property reserved_regions[CONFIG_LMB_RESERVED_REGIONS]; -#endif -}; +int lmb_init(void);
-void lmb_init(struct lmb *lmb); -void lmb_init_and_reserve(struct lmb *lmb, struct bd_info *bd, void *fdt_blob); -void lmb_init_and_reserve_range(struct lmb *lmb, phys_addr_t base, - phys_size_t size, void *fdt_blob); -long lmb_add(struct lmb *lmb, phys_addr_t base, phys_size_t size); -long lmb_reserve(struct lmb *lmb, phys_addr_t base, phys_size_t size); +void lmb_init_and_reserve(struct bd_info *bd, void *fdt_blob); +void lmb_init_and_reserve_range(phys_addr_t base, phys_size_t size, + void *fdt_blob); +long lmb_add(phys_addr_t base, phys_size_t size); +long lmb_reserve(phys_addr_t base, phys_size_t size); /** * lmb_reserve_flags - Reserve one region with a specific flags bitfield. * - * @lmb: the logical memory block struct * @base: base address of the memory region * @size: size of the memory region * @flags: flags for the memory region * Return: 0 if OK, > 0 for coalesced region or a negative error code. */ -long lmb_reserve_flags(struct lmb *lmb, phys_addr_t base, - phys_size_t size, enum lmb_flags flags); -phys_addr_t lmb_alloc(struct lmb *lmb, phys_size_t size, ulong align); -phys_addr_t lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, - phys_addr_t max_addr); -phys_addr_t lmb_alloc_addr(struct lmb *lmb, phys_addr_t base, phys_size_t size); -phys_size_t lmb_get_free_size(struct lmb *lmb, phys_addr_t addr); +long lmb_reserve_flags(phys_addr_t base, phys_size_t size, + enum lmb_flags flags); +phys_addr_t lmb_alloc(phys_size_t size, ulong align); +phys_addr_t lmb_alloc_base(phys_size_t size, ulong align, phys_addr_t max_addr); +phys_addr_t lmb_alloc_addr(phys_addr_t base, phys_size_t size); +phys_size_t lmb_get_free_size(phys_addr_t addr);
/** * lmb_is_reserved_flags() - test if address is in reserved region with flag bits set @@ -122,21 +88,24 @@ phys_size_t lmb_get_free_size(struct lmb *lmb, phys_addr_t addr); * The function checks if a reserved region comprising @addr exists which has * all flag bits set which are set in @flags. * - * @lmb: the logical memory block struct * @addr: address to be tested * @flags: bitmap with bits to be tested * Return: 1 if matching reservation exists, 0 otherwise */ -int lmb_is_reserved_flags(struct lmb *lmb, phys_addr_t addr, int flags); +int lmb_is_reserved_flags(phys_addr_t addr, int flags); + +long lmb_free(phys_addr_t base, phys_size_t size);
-long lmb_free(struct lmb *lmb, phys_addr_t base, phys_size_t size); +void lmb_dump_all(void); +void lmb_dump_all_force(void);
-void lmb_dump_all(struct lmb *lmb); -void lmb_dump_all_force(struct lmb *lmb); +void board_lmb_reserve(void); +void arch_lmb_reserve(void); +void arch_lmb_reserve_generic(ulong sp, ulong end, ulong align);
-void board_lmb_reserve(struct lmb *lmb); -void arch_lmb_reserve(struct lmb *lmb); -void arch_lmb_reserve_generic(struct lmb *lmb, ulong sp, ulong end, ulong align); +struct lmb *lmb_get(void); +int lmb_push(struct lmb *store); +void lmb_pop(struct lmb *store);
#endif /* __KERNEL__ */
diff --git a/lib/efi_loader/efi_dt_fixup.c b/lib/efi_loader/efi_dt_fixup.c index 9886e6897c..9d017804ee 100644 --- a/lib/efi_loader/efi_dt_fixup.c +++ b/lib/efi_loader/efi_dt_fixup.c @@ -172,7 +172,7 @@ efi_dt_fixup(struct efi_dt_fixup_protocol *this, void *dtb, }
fdt_set_totalsize(dtb, *buffer_size); - if (image_setup_libfdt(&img, dtb, NULL)) { + if (image_setup_libfdt(&img, dtb, false)) { log_err("failed to process device tree\n"); ret = EFI_INVALID_PARAMETER; goto out; diff --git a/lib/efi_loader/efi_helper.c b/lib/efi_loader/efi_helper.c index 65d2116381..9907b2b23c 100644 --- a/lib/efi_loader/efi_helper.c +++ b/lib/efi_loader/efi_helper.c @@ -513,7 +513,7 @@ efi_status_t efi_install_fdt(void *fdt) return EFI_OUT_OF_RESOURCES; }
- if (image_setup_libfdt(&img, fdt, NULL)) { + if (image_setup_libfdt(&img, fdt, false)) { log_err("ERROR: failed to process device tree\n"); return EFI_LOAD_ERROR; } diff --git a/lib/lmb.c b/lib/lmb.c index 4d39c0d1f9..0aa2d8bd3b 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -6,6 +6,7 @@ * Copyright (C) 2001 Peter Bergner. */
+#include <alist.h> #include <efi_loader.h> #include <image.h> #include <mapmem.h> @@ -15,41 +16,46 @@
#include <asm/global_data.h> #include <asm/sections.h> +#include <linux/kernel.h>
#define LMB_ALLOC_ANYWHERE 0 +#define LMB_ALIST_INITIAL_SIZE 4
-static void lmb_dump_region(struct lmb_region *rgn, char *name) +static struct lmb lmb; + +static void lmb_dump_region(struct alist *lmb_rgn_lst, char *name) { + struct lmb_region *rgn = lmb_rgn_lst->data; unsigned long long base, size, end; enum lmb_flags flags; int i;
- printf(" %s.cnt = 0x%lx / max = 0x%lx\n", name, rgn->cnt, rgn->max); + printf(" %s.count = 0x%x\n", name, lmb_rgn_lst->count);
- for (i = 0; i < rgn->cnt; i++) { - base = rgn->region[i].base; - size = rgn->region[i].size; + for (i = 0; i < lmb_rgn_lst->count; i++) { + base = rgn[i].base; + size = rgn[i].size; end = base + size - 1; - flags = rgn->region[i].flags; + flags = rgn[i].flags;
printf(" %s[%d]\t[0x%llx-0x%llx], 0x%08llx bytes flags: %x\n", name, i, base, end, size, flags); } }
-void lmb_dump_all_force(struct lmb *lmb) +void lmb_dump_all_force(void) { printf("lmb_dump_all:\n"); - lmb_dump_region(&lmb->memory, "memory"); - lmb_dump_region(&lmb->reserved, "reserved"); + lmb_dump_region(&lmb.free_mem, "memory"); + lmb_dump_region(&lmb.used_mem, "reserved"); }
-void lmb_dump_all(struct lmb *lmb) +void lmb_dump_all(void) { #ifdef DEBUG - lmb_dump_all_force(lmb); + lmb_dump_all_force(); #endif }
@@ -73,79 +79,74 @@ static long lmb_addrs_adjacent(phys_addr_t base1, phys_size_t size1, return 0; }
-static long lmb_regions_overlap(struct lmb_region *rgn, unsigned long r1, +static long lmb_regions_overlap(struct alist *lmb_rgn_lst, unsigned long r1, unsigned long r2) { - phys_addr_t base1 = rgn->region[r1].base; - phys_size_t size1 = rgn->region[r1].size; - phys_addr_t base2 = rgn->region[r2].base; - phys_size_t size2 = rgn->region[r2].size; + struct lmb_region *rgn = lmb_rgn_lst->data; + + phys_addr_t base1 = rgn[r1].base; + phys_size_t size1 = rgn[r1].size; + phys_addr_t base2 = rgn[r2].base; + phys_size_t size2 = rgn[r2].size;
return lmb_addrs_overlap(base1, size1, base2, size2); } -static long lmb_regions_adjacent(struct lmb_region *rgn, unsigned long r1, + +static long lmb_regions_adjacent(struct alist *lmb_rgn_lst, unsigned long r1, unsigned long r2) { - phys_addr_t base1 = rgn->region[r1].base; - phys_size_t size1 = rgn->region[r1].size; - phys_addr_t base2 = rgn->region[r2].base; - phys_size_t size2 = rgn->region[r2].size; + struct lmb_region *rgn = lmb_rgn_lst->data; + + phys_addr_t base1 = rgn[r1].base; + phys_size_t size1 = rgn[r1].size; + phys_addr_t base2 = rgn[r2].base; + phys_size_t size2 = rgn[r2].size; return lmb_addrs_adjacent(base1, size1, base2, size2); }
-static void lmb_remove_region(struct lmb_region *rgn, unsigned long r) +static void lmb_remove_region(struct alist *lmb_rgn_lst, unsigned long r) { unsigned long i; + struct lmb_region *rgn = lmb_rgn_lst->data;
- for (i = r; i < rgn->cnt - 1; i++) { - rgn->region[i].base = rgn->region[i + 1].base; - rgn->region[i].size = rgn->region[i + 1].size; - rgn->region[i].flags = rgn->region[i + 1].flags; + for (i = r; i < lmb_rgn_lst->count - 1; i++) { + rgn[i].base = rgn[i + 1].base; + rgn[i].size = rgn[i + 1].size; + rgn[i].flags = rgn[i + 1].flags; } - rgn->cnt--; + lmb_rgn_lst->count--; }
/* Assumption: base addr of region 1 < base addr of region 2 */ -static void lmb_coalesce_regions(struct lmb_region *rgn, unsigned long r1, +static void lmb_coalesce_regions(struct alist *lmb_rgn_lst, unsigned long r1, unsigned long r2) { - rgn->region[r1].size += rgn->region[r2].size; - lmb_remove_region(rgn, r2); + struct lmb_region *rgn = lmb_rgn_lst->data; + + rgn[r1].size += rgn[r2].size; + lmb_remove_region(lmb_rgn_lst, r2); }
/*Assumption : base addr of region 1 < base addr of region 2*/ -static void lmb_fix_over_lap_regions(struct lmb_region *rgn, unsigned long r1, - unsigned long r2) +static void lmb_fix_over_lap_regions(struct alist *lmb_rgn_lst, + unsigned long r1, unsigned long r2) { - phys_addr_t base1 = rgn->region[r1].base; - phys_size_t size1 = rgn->region[r1].size; - phys_addr_t base2 = rgn->region[r2].base; - phys_size_t size2 = rgn->region[r2].size; + struct lmb_region *rgn = lmb_rgn_lst->data; + + phys_addr_t base1 = rgn[r1].base; + phys_size_t size1 = rgn[r1].size; + phys_addr_t base2 = rgn[r2].base; + phys_size_t size2 = rgn[r2].size;
if (base1 + size1 > base2 + size2) { printf("This will not be a case any time\n"); return; } - rgn->region[r1].size = base2 + size2 - base1; - lmb_remove_region(rgn, r2); + rgn[r1].size = base2 + size2 - base1; + lmb_remove_region(lmb_rgn_lst, r2); }
-void lmb_init(struct lmb *lmb) -{ -#if IS_ENABLED(CONFIG_LMB_USE_MAX_REGIONS) - lmb->memory.max = CONFIG_LMB_MAX_REGIONS; - lmb->reserved.max = CONFIG_LMB_MAX_REGIONS; -#else - lmb->memory.max = CONFIG_LMB_MEMORY_REGIONS; - lmb->reserved.max = CONFIG_LMB_RESERVED_REGIONS; - lmb->memory.region = lmb->memory_regions; - lmb->reserved.region = lmb->reserved_regions; -#endif - lmb->memory.cnt = 0; - lmb->reserved.cnt = 0; -} - -void arch_lmb_reserve_generic(struct lmb *lmb, ulong sp, ulong end, ulong align) +void arch_lmb_reserve_generic(ulong sp, ulong end, ulong align) { ulong bank_end; int bank; @@ -171,10 +172,10 @@ void arch_lmb_reserve_generic(struct lmb *lmb, ulong sp, ulong end, ulong align) if (bank_end > end) bank_end = end - 1;
- lmb_reserve(lmb, sp, bank_end - sp + 1); + lmb_reserve(sp, bank_end - sp + 1);
if (gd->flags & GD_FLG_SKIP_RELOC) - lmb_reserve(lmb, (phys_addr_t)(uintptr_t)_start, gd->mon_len); + lmb_reserve((phys_addr_t)(uintptr_t)_start, gd->mon_len);
break; } @@ -186,10 +187,9 @@ void arch_lmb_reserve_generic(struct lmb *lmb, ulong sp, ulong end, ulong align) * Add reservations for all EFI memory areas that are not * EFI_CONVENTIONAL_MEMORY. * - * @lmb: lmb environment * Return: 0 on success, 1 on failure */ -static __maybe_unused int efi_lmb_reserve(struct lmb *lmb) +static __maybe_unused int efi_lmb_reserve(void) { struct efi_mem_desc *memmap = NULL, *map; efi_uintn_t i, map_size = 0; @@ -201,8 +201,7 @@ static __maybe_unused int efi_lmb_reserve(struct lmb *lmb)
for (i = 0, map = memmap; i < map_size / sizeof(*map); ++map, ++i) { if (map->type != EFI_CONVENTIONAL_MEMORY) { - lmb_reserve_flags(lmb, - map_to_sysmem((void *)(uintptr_t) + lmb_reserve_flags(map_to_sysmem((void *)(uintptr_t) map->physical_start), map->num_pages * EFI_PAGE_SIZE, map->type == EFI_RESERVED_MEMORY_TYPE @@ -214,64 +213,69 @@ static __maybe_unused int efi_lmb_reserve(struct lmb *lmb) return 0; }
-static void lmb_reserve_common(struct lmb *lmb, void *fdt_blob) +static void lmb_reserve_common(void *fdt_blob) { - arch_lmb_reserve(lmb); - board_lmb_reserve(lmb); + arch_lmb_reserve(); + board_lmb_reserve();
if (CONFIG_IS_ENABLED(OF_LIBFDT) && fdt_blob) - boot_fdt_add_mem_rsv_regions(lmb, fdt_blob); + boot_fdt_add_mem_rsv_regions(fdt_blob);
if (CONFIG_IS_ENABLED(EFI_LOADER)) - efi_lmb_reserve(lmb); + efi_lmb_reserve(); }
/* Initialize the struct, add memory and call arch/board reserve functions */ -void lmb_init_and_reserve(struct lmb *lmb, struct bd_info *bd, void *fdt_blob) +void lmb_init_and_reserve(struct bd_info *bd, void *fdt_blob) { int i;
- lmb_init(lmb); - for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { - if (bd->bi_dram[i].size) { - lmb_add(lmb, bd->bi_dram[i].start, - bd->bi_dram[i].size); - } + if (bd->bi_dram[i].size) + lmb_add(bd->bi_dram[i].start, bd->bi_dram[i].size); }
- lmb_reserve_common(lmb, fdt_blob); + lmb_reserve_common(fdt_blob); }
/* Initialize the struct, add memory and call arch/board reserve functions */ -void lmb_init_and_reserve_range(struct lmb *lmb, phys_addr_t base, - phys_size_t size, void *fdt_blob) +void lmb_init_and_reserve_range(phys_addr_t base, phys_size_t size, + void *fdt_blob) { - lmb_init(lmb); - lmb_add(lmb, base, size); - lmb_reserve_common(lmb, fdt_blob); + lmb_add(base, size); + lmb_reserve_common(fdt_blob); }
-/* This routine called with relocation disabled. */ -static long lmb_add_region_flags(struct lmb_region *rgn, phys_addr_t base, +/** + * lmb_add_region_flags() - Add an lmb region to the given list + * @lmb_rgn_lst: LMB list to which region is to be added(free/used) + * @base: Start address of the region + * @size: Size of the region to be added + * @flags: Attributes of the LMB region + * + * Add a region of memory to the list. If the region does not exist, add + * it to the list. Depending on the attributes of the region to be added, + * the function might resize an already existing region or coalesce two + * adjacent regions. + * + * + * Returns: 0 if the region addition successful, -1 on failure + */ +static long lmb_add_region_flags(struct alist *lmb_rgn_lst, phys_addr_t base, phys_size_t size, enum lmb_flags flags) { unsigned long coalesced = 0; long adjacent, i; + struct lmb_region *rgn = lmb_rgn_lst->data;
- if (rgn->cnt == 0) { - rgn->region[0].base = base; - rgn->region[0].size = size; - rgn->region[0].flags = flags; - rgn->cnt = 1; - return 0; - } + if (alist_err(lmb_rgn_lst)) + return -1;
/* First try and coalesce this LMB with another. */ - for (i = 0; i < rgn->cnt; i++) { - phys_addr_t rgnbase = rgn->region[i].base; - phys_size_t rgnsize = rgn->region[i].size; - phys_size_t rgnflags = rgn->region[i].flags; + for (i = 0; i < lmb_rgn_lst->count; i++) { + phys_addr_t rgnbase = rgn[i].base; + phys_size_t rgnsize = rgn[i].size; + phys_size_t rgnflags = rgn[i].flags; phys_addr_t end = base + size - 1; phys_addr_t rgnend = rgnbase + rgnsize - 1; if (rgnbase <= base && end <= rgnend) { @@ -286,14 +290,14 @@ static long lmb_add_region_flags(struct lmb_region *rgn, phys_addr_t base, if (adjacent > 0) { if (flags != rgnflags) break; - rgn->region[i].base -= size; - rgn->region[i].size += size; + rgn[i].base -= size; + rgn[i].size += size; coalesced++; break; } else if (adjacent < 0) { if (flags != rgnflags) break; - rgn->region[i].size += size; + rgn[i].size += size; coalesced++; break; } else if (lmb_addrs_overlap(base, size, rgnbase, rgnsize)) { @@ -302,99 +306,98 @@ static long lmb_add_region_flags(struct lmb_region *rgn, phys_addr_t base, } }
- if (i < rgn->cnt - 1 && rgn->region[i].flags == rgn->region[i + 1].flags) { - if (lmb_regions_adjacent(rgn, i, i + 1)) { - lmb_coalesce_regions(rgn, i, i + 1); - coalesced++; - } else if (lmb_regions_overlap(rgn, i, i + 1)) { - /* fix overlapping area */ - lmb_fix_over_lap_regions(rgn, i, i + 1); - coalesced++; + if (lmb_rgn_lst->count && i < lmb_rgn_lst->count - 1) { + rgn = lmb_rgn_lst->data; + if (rgn[i].flags == rgn[i + 1].flags) { + if (lmb_regions_adjacent(lmb_rgn_lst, i, i + 1)) { + lmb_coalesce_regions(lmb_rgn_lst, i, i + 1); + coalesced++; + } else if (lmb_regions_overlap(lmb_rgn_lst, i, i + 1)) { + /* fix overlapping area */ + lmb_fix_over_lap_regions(lmb_rgn_lst, i, i + 1); + coalesced++; + } } }
if (coalesced) return coalesced; - if (rgn->cnt >= rgn->max) + + if (alist_full(lmb_rgn_lst) && + !alist_expand_by(lmb_rgn_lst, lmb_rgn_lst->alloc)) return -1; + rgn = lmb_rgn_lst->data;
/* Couldn't coalesce the LMB, so add it to the sorted table. */ - for (i = rgn->cnt-1; i >= 0; i--) { - if (base < rgn->region[i].base) { - rgn->region[i + 1].base = rgn->region[i].base; - rgn->region[i + 1].size = rgn->region[i].size; - rgn->region[i + 1].flags = rgn->region[i].flags; + for (i = lmb_rgn_lst->count; i >= 0; i--) { + if (i && base < rgn[i - 1].base) { + rgn[i] = rgn[i - 1]; } else { - rgn->region[i + 1].base = base; - rgn->region[i + 1].size = size; - rgn->region[i + 1].flags = flags; + rgn[i].base = base; + rgn[i].size = size; + rgn[i].flags = flags; break; } }
- if (base < rgn->region[0].base) { - rgn->region[0].base = base; - rgn->region[0].size = size; - rgn->region[0].flags = flags; - } - - rgn->cnt++; + lmb_rgn_lst->count++;
return 0; }
-static long lmb_add_region(struct lmb_region *rgn, phys_addr_t base, +static long lmb_add_region(struct alist *lmb_rgn_lst, phys_addr_t base, phys_size_t size) { - return lmb_add_region_flags(rgn, base, size, LMB_NONE); + return lmb_add_region_flags(lmb_rgn_lst, base, size, LMB_NONE); }
/* This routine may be called with relocation disabled. */ -long lmb_add(struct lmb *lmb, phys_addr_t base, phys_size_t size) +long lmb_add(phys_addr_t base, phys_size_t size) { - struct lmb_region *_rgn = &(lmb->memory); + struct alist *lmb_rgn_lst = &lmb.free_mem;
- return lmb_add_region(_rgn, base, size); + return lmb_add_region(lmb_rgn_lst, base, size); }
-long lmb_free(struct lmb *lmb, phys_addr_t base, phys_size_t size) +long lmb_free(phys_addr_t base, phys_size_t size) { - struct lmb_region *rgn = &(lmb->reserved); + struct lmb_region *rgn; + struct alist *lmb_rgn_lst = &lmb.used_mem; phys_addr_t rgnbegin, rgnend; phys_addr_t end = base + size - 1; int i;
rgnbegin = rgnend = 0; /* supress gcc warnings */ - + rgn = lmb_rgn_lst->data; /* Find the region where (base, size) belongs to */ - for (i = 0; i < rgn->cnt; i++) { - rgnbegin = rgn->region[i].base; - rgnend = rgnbegin + rgn->region[i].size - 1; + for (i = 0; i < lmb_rgn_lst->count; i++) { + rgnbegin = rgn[i].base; + rgnend = rgnbegin + rgn[i].size - 1;
if ((rgnbegin <= base) && (end <= rgnend)) break; }
/* Didn't find the region */ - if (i == rgn->cnt) + if (i == lmb_rgn_lst->count) return -1;
/* Check to see if we are removing entire region */ if ((rgnbegin == base) && (rgnend == end)) { - lmb_remove_region(rgn, i); + lmb_remove_region(lmb_rgn_lst, i); return 0; }
/* Check to see if region is matching at the front */ if (rgnbegin == base) { - rgn->region[i].base = end + 1; - rgn->region[i].size -= size; + rgn[i].base = end + 1; + rgn[i].size -= size; return 0; }
/* Check to see if the region is matching at the end */ if (rgnend == end) { - rgn->region[i].size -= size; + rgn[i].size -= size; return 0; }
@@ -402,37 +405,37 @@ long lmb_free(struct lmb *lmb, phys_addr_t base, phys_size_t size) * We need to split the entry - adjust the current one to the * beginging of the hole and add the region after hole. */ - rgn->region[i].size = base - rgn->region[i].base; - return lmb_add_region_flags(rgn, end + 1, rgnend - end, - rgn->region[i].flags); + rgn[i].size = base - rgn[i].base; + return lmb_add_region_flags(lmb_rgn_lst, end + 1, rgnend - end, + rgn[i].flags); }
-long lmb_reserve_flags(struct lmb *lmb, phys_addr_t base, phys_size_t size, - enum lmb_flags flags) +long lmb_reserve_flags(phys_addr_t base, phys_size_t size, enum lmb_flags flags) { - struct lmb_region *_rgn = &(lmb->reserved); + struct alist *lmb_rgn_lst = &lmb.used_mem;
- return lmb_add_region_flags(_rgn, base, size, flags); + return lmb_add_region_flags(lmb_rgn_lst, base, size, flags); }
-long lmb_reserve(struct lmb *lmb, phys_addr_t base, phys_size_t size) +long lmb_reserve(phys_addr_t base, phys_size_t size) { - return lmb_reserve_flags(lmb, base, size, LMB_NONE); + return lmb_reserve_flags(base, size, LMB_NONE); }
-static long lmb_overlaps_region(struct lmb_region *rgn, phys_addr_t base, +static long lmb_overlaps_region(struct alist *lmb_rgn_lst, phys_addr_t base, phys_size_t size) { unsigned long i; + struct lmb_region *rgn = lmb_rgn_lst->data;
- for (i = 0; i < rgn->cnt; i++) { - phys_addr_t rgnbase = rgn->region[i].base; - phys_size_t rgnsize = rgn->region[i].size; + for (i = 0; i < lmb_rgn_lst->count; i++) { + phys_addr_t rgnbase = rgn[i].base; + phys_size_t rgnsize = rgn[i].size; if (lmb_addrs_overlap(base, size, rgnbase, rgnsize)) break; }
- return (i < rgn->cnt) ? i : -1; + return (i < lmb_rgn_lst->count) ? i : -1; }
static phys_addr_t lmb_align_down(phys_addr_t addr, phys_size_t size) @@ -440,16 +443,18 @@ static phys_addr_t lmb_align_down(phys_addr_t addr, phys_size_t size) return addr & ~(size - 1); }
-static phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, - ulong align, phys_addr_t max_addr) +static phys_addr_t __lmb_alloc_base(phys_size_t size, ulong align, + phys_addr_t max_addr) { long i, rgn; phys_addr_t base = 0; phys_addr_t res_base; + struct lmb_region *lmb_used = lmb.used_mem.data; + struct lmb_region *lmb_memory = lmb.free_mem.data;
- for (i = lmb->memory.cnt - 1; i >= 0; i--) { - phys_addr_t lmbbase = lmb->memory.region[i].base; - phys_size_t lmbsize = lmb->memory.region[i].size; + for (i = lmb.free_mem.count - 1; i >= 0; i--) { + phys_addr_t lmbbase = lmb_memory[i].base; + phys_size_t lmbsize = lmb_memory[i].size;
if (lmbsize < size) continue; @@ -465,15 +470,16 @@ static phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, continue;
while (base && lmbbase <= base) { - rgn = lmb_overlaps_region(&lmb->reserved, base, size); + rgn = lmb_overlaps_region(&lmb.used_mem, base, size); if (rgn < 0) { /* This area isn't reserved, take it */ - if (lmb_add_region(&lmb->reserved, base, + if (lmb_add_region(&lmb.used_mem, base, size) < 0) return 0; return base; } - res_base = lmb->reserved.region[rgn].base; + + res_base = lmb_used[rgn].base; if (res_base < size) break; base = lmb_align_down(res_base - size, align); @@ -482,16 +488,16 @@ static phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, return 0; }
-phys_addr_t lmb_alloc(struct lmb *lmb, phys_size_t size, ulong align) +phys_addr_t lmb_alloc(phys_size_t size, ulong align) { - return lmb_alloc_base(lmb, size, align, LMB_ALLOC_ANYWHERE); + return lmb_alloc_base(size, align, LMB_ALLOC_ANYWHERE); }
-phys_addr_t lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phys_addr_t max_addr) +phys_addr_t lmb_alloc_base(phys_size_t size, ulong align, phys_addr_t max_addr) { phys_addr_t alloc;
- alloc = __lmb_alloc_base(lmb, size, align, max_addr); + alloc = __lmb_alloc_base(size, align, max_addr);
if (alloc == 0) printf("ERROR: Failed to allocate 0x%lx bytes below 0x%lx.\n", @@ -504,22 +510,23 @@ phys_addr_t lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phys_ * Try to allocate a specific address range: must be in defined memory but not * reserved */ -phys_addr_t lmb_alloc_addr(struct lmb *lmb, phys_addr_t base, phys_size_t size) +phys_addr_t lmb_alloc_addr(phys_addr_t base, phys_size_t size) { long rgn; + struct lmb_region *lmb_memory = lmb.free_mem.data;
/* Check if the requested address is in one of the memory regions */ - rgn = lmb_overlaps_region(&lmb->memory, base, size); + rgn = lmb_overlaps_region(&lmb.free_mem, base, size); if (rgn >= 0) { /* * Check if the requested end address is in the same memory * region we found. */ - if (lmb_addrs_overlap(lmb->memory.region[rgn].base, - lmb->memory.region[rgn].size, + if (lmb_addrs_overlap(lmb_memory[rgn].base, + lmb_memory[rgn].size, base + size - 1, 1)) { /* ok, reserve the memory */ - if (lmb_reserve(lmb, base, size) >= 0) + if (lmb_reserve(base, size) >= 0) return base; } } @@ -527,51 +534,126 @@ phys_addr_t lmb_alloc_addr(struct lmb *lmb, phys_addr_t base, phys_size_t size) }
/* Return number of bytes from a given address that are free */ -phys_size_t lmb_get_free_size(struct lmb *lmb, phys_addr_t addr) +phys_size_t lmb_get_free_size(phys_addr_t addr) { int i; long rgn; + struct lmb_region *lmb_used = lmb.used_mem.data; + struct lmb_region *lmb_memory = lmb.free_mem.data;
/* check if the requested address is in the memory regions */ - rgn = lmb_overlaps_region(&lmb->memory, addr, 1); + rgn = lmb_overlaps_region(&lmb.free_mem, addr, 1); if (rgn >= 0) { - for (i = 0; i < lmb->reserved.cnt; i++) { - if (addr < lmb->reserved.region[i].base) { + for (i = 0; i < lmb.used_mem.count; i++) { + if (addr < lmb_used[i].base) { /* first reserved range > requested address */ - return lmb->reserved.region[i].base - addr; + return lmb_used[i].base - addr; } - if (lmb->reserved.region[i].base + - lmb->reserved.region[i].size > addr) { + if (lmb_used[i].base + + lmb_used[i].size > addr) { /* requested addr is in this reserved range */ return 0; } } /* if we come here: no reserved ranges above requested addr */ - return lmb->memory.region[lmb->memory.cnt - 1].base + - lmb->memory.region[lmb->memory.cnt - 1].size - addr; + return lmb_memory[lmb.free_mem.count - 1].base + + lmb_memory[lmb.free_mem.count - 1].size - addr; } return 0; }
-int lmb_is_reserved_flags(struct lmb *lmb, phys_addr_t addr, int flags) +int lmb_is_reserved_flags(phys_addr_t addr, int flags) { int i; + struct lmb_region *lmb_used = lmb.used_mem.data;
- for (i = 0; i < lmb->reserved.cnt; i++) { - phys_addr_t upper = lmb->reserved.region[i].base + - lmb->reserved.region[i].size - 1; - if ((addr >= lmb->reserved.region[i].base) && (addr <= upper)) - return (lmb->reserved.region[i].flags & flags) == flags; + for (i = 0; i < lmb.used_mem.count; i++) { + phys_addr_t upper = lmb_used[i].base + + lmb_used[i].size - 1; + if (addr >= lmb_used[i].base && addr <= upper) + return (lmb_used[i].flags & flags) == flags; } return 0; }
-__weak void board_lmb_reserve(struct lmb *lmb) +__weak void board_lmb_reserve(void) { /* please define platform specific board_lmb_reserve() */ }
-__weak void arch_lmb_reserve(struct lmb *lmb) +__weak void arch_lmb_reserve(void) { /* please define platform specific arch_lmb_reserve() */ } + +static int lmb_setup(void) +{ + bool ret; + + ret = alist_init(&lmb.free_mem, sizeof(struct lmb_region), + (uint)LMB_ALIST_INITIAL_SIZE); + if (!ret) { + log_debug("Unable to initialise the list for LMB free memory\n"); + return -ENOMEM; + } + + ret = alist_init(&lmb.used_mem, sizeof(struct lmb_region), + (uint)LMB_ALIST_INITIAL_SIZE); + if (!ret) { + log_debug("Unable to initialise the list for LMB used memory\n"); + return -ENOMEM; + } + + return 0; +} + +/** + * lmb_init() - Initialise the LMB module + * + * Initialise the LMB lists needed for keeping the memory map. There + * are two lists, in form of alloced list data structure. One for the + * available memory, and one for the used memory. Initialise the two + * lists as part of board init. Add memory to the available memory + * list and reserve common areas by adding them to the used memory + * list. + * + * Return: 0 on success, -ve on error + */ +int lmb_init(void) +{ + int ret; + + ret = lmb_setup(); + if (ret) { + log_info("Unable to init LMB\n"); + return ret; + } + + return 0; +} + +#if CONFIG_IS_ENABLED(UNIT_TEST) +struct lmb *lmb_get(void) +{ + return &lmb; +} + +int lmb_push(struct lmb *store) +{ + int ret; + + *store = lmb; + ret = lmb_setup(); + if (ret) + return ret; + + return 0; +} + +void lmb_pop(struct lmb *store) +{ + alist_uninit(&lmb.free_mem); + alist_uninit(&lmb.used_mem); + lmb = *store; +} +#endif /* UNIT_TEST */ diff --git a/net/tftp.c b/net/tftp.c index 2e073183d5..c0a6210b9d 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -717,12 +717,11 @@ static void tftp_timeout_handler(void) static int tftp_init_load_addr(void) { #ifdef CONFIG_LMB - struct lmb lmb; phys_size_t max_size;
- max_size = lmb_get_free_size(&lmb, image_load_addr); + max_size = lmb_get_free_size(image_load_addr); if (!max_size) return -1;
diff --git a/net/wget.c b/net/wget.c index 945bfd2669..c1cd8216bc 100644 --- a/net/wget.c +++ b/net/wget.c @@ -73,12 +73,11 @@ static ulong wget_load_size; */ static int wget_init_load_size(void) { - struct lmb lmb; phys_size_t max_size;
diff --git a/test/cmd/bdinfo.c b/test/cmd/bdinfo.c index 027848c3e2..34e1ef6510 100644 --- a/test/cmd/bdinfo.c +++ b/test/cmd/bdinfo.c @@ -5,6 +5,7 @@ * Copyright 2023 Marek Vasut marek.vasut+renesas@mailbox.org */
+#include <alist.h> #include <console.h> #include <mapmem.h> #include <asm/global_data.h> @@ -99,44 +100,39 @@ static int test_video_info(struct unit_test_state *uts) }
static int lmb_test_dump_region(struct unit_test_state *uts, - struct lmb_region *rgn, char *name) + struct alist *lmb_rgn_lst, char *name) { + struct lmb_region *rgn = lmb_rgn_lst->data; unsigned long long base, size, end; enum lmb_flags flags; int i;
- ut_assert_nextline(" %s.cnt = 0x%lx / max = 0x%lx", name, rgn->cnt, rgn->max); + ut_assert_nextline(" %s.count = 0x%hx", name, lmb_rgn_lst->count);
- for (i = 0; i < rgn->cnt; i++) { - base = rgn->region[i].base; - size = rgn->region[i].size; + for (i = 0; i < lmb_rgn_lst->count; i++) { + base = rgn[i].base; + size = rgn[i].size; end = base + size - 1; - flags = rgn->region[i].flags; - - /* - * this entry includes the stack (get_sp()) on many platforms - * so will different each time lmb_init_and_reserve() is called. - * We could instead have the bdinfo command put its lmb region - * in a known location, so we can check it directly, rather than - * calling lmb_init_and_reserve() to create a new (and hopefully - * identical one). But for now this seems good enough. - */ + flags = rgn[i].flags; + if (!IS_ENABLED(CONFIG_SANDBOX) && i == 3) { ut_assert_nextlinen(" %s[%d]\t[", name, i); continue; } - ut_assert_nextline(" %s[%d]\t[0x%llx-0x%llx], 0x%08llx bytes flags: %x", - name, i, base, end, size, flags); + ut_assert_nextlinen(" %s[%d]\t[0x%llx-0x%llx], 0x%08llx bytes flags: ", + name, i, base, end, size); }
return 0; }
-static int lmb_test_dump_all(struct unit_test_state *uts, struct lmb *lmb) +static int lmb_test_dump_all(struct unit_test_state *uts) { + struct lmb *lmb = lmb_get(); + ut_assert_nextline("lmb_dump_all:"); - ut_assertok(lmb_test_dump_region(uts, &lmb->memory, "memory")); - ut_assertok(lmb_test_dump_region(uts, &lmb->reserved, "reserved")); + ut_assertok(lmb_test_dump_region(uts, &lmb->free_mem, "memory")); + ut_assertok(lmb_test_dump_region(uts, &lmb->used_mem, "reserved"));
return 0; } @@ -198,10 +194,7 @@ static int bdinfo_test_all(struct unit_test_state *uts) #endif
if (IS_ENABLED(CONFIG_LMB) && gd->fdt_blob) { - struct lmb lmb; - - lmb_init_and_reserve(&lmb, gd->bd, (void *)gd->fdt_blob); - ut_assertok(lmb_test_dump_all(uts, &lmb)); + ut_assertok(lmb_test_dump_all(uts)); if (IS_ENABLED(CONFIG_OF_REAL)) ut_assert_nextline("devicetree = %s", fdtdec_get_srcname()); } diff --git a/test/lib/lmb.c b/test/lib/lmb.c index 4b5b6e5e20..c01f38f7d4 100644 --- a/test/lib/lmb.c +++ b/test/lib/lmb.c @@ -3,6 +3,7 @@ * (C) Copyright 2018 Simon Goldschmidt */
+#include <alist.h> #include <dm.h> #include <lmb.h> #include <log.h> @@ -12,50 +13,64 @@ #include <test/test.h> #include <test/ut.h>
-static inline bool lmb_is_nomap(struct lmb_property *m) +static inline bool lmb_is_nomap(struct lmb_region *m) { return m->flags & LMB_NOMAP; }
-static int check_lmb(struct unit_test_state *uts, struct lmb *lmb, - phys_addr_t ram_base, phys_size_t ram_size, - unsigned long num_reserved, +static int check_lmb(struct unit_test_state *uts, struct alist *mem_lst, + struct alist *used_lst, phys_addr_t ram_base, + phys_size_t ram_size, unsigned long num_reserved, phys_addr_t base1, phys_size_t size1, phys_addr_t base2, phys_size_t size2, phys_addr_t base3, phys_size_t size3) { + struct lmb_region *mem, *used; + + mem = mem_lst->data; + used = used_lst->data; + if (ram_size) { - ut_asserteq(lmb->memory.cnt, 1); - ut_asserteq(lmb->memory.region[0].base, ram_base); - ut_asserteq(lmb->memory.region[0].size, ram_size); + ut_asserteq(mem_lst->count, 1); + ut_asserteq(mem[0].base, ram_base); + ut_asserteq(mem[0].size, ram_size); }
- ut_asserteq(lmb->reserved.cnt, num_reserved); + ut_asserteq(used_lst->count, num_reserved); if (num_reserved > 0) { - ut_asserteq(lmb->reserved.region[0].base, base1); - ut_asserteq(lmb->reserved.region[0].size, size1); + ut_asserteq(used[0].base, base1); + ut_asserteq(used[0].size, size1); } if (num_reserved > 1) { - ut_asserteq(lmb->reserved.region[1].base, base2); - ut_asserteq(lmb->reserved.region[1].size, size2); + ut_asserteq(used[1].base, base2); + ut_asserteq(used[1].size, size2); } if (num_reserved > 2) { - ut_asserteq(lmb->reserved.region[2].base, base3); - ut_asserteq(lmb->reserved.region[2].size, size3); + ut_asserteq(used[2].base, base3); + ut_asserteq(used[2].size, size3); } return 0; }
-#define ASSERT_LMB(lmb, ram_base, ram_size, num_reserved, base1, size1, \ +#define ASSERT_LMB(mem_lst, used_lst, ram_base, ram_size, num_reserved, base1, size1, \ base2, size2, base3, size3) \ - ut_assert(!check_lmb(uts, lmb, ram_base, ram_size, \ + ut_assert(!check_lmb(uts, mem_lst, used_lst, ram_base, ram_size, \ num_reserved, base1, size1, base2, size2, base3, \ size3))
-/* - * Test helper function that reserves 64 KiB somewhere in the simulated RAM and - * then does some alloc + free tests. - */ +static int setup_lmb_test(struct unit_test_state *uts, struct lmb *store, + struct alist **mem_lstp, struct alist **used_lstp) +{ + struct lmb *lmb; + + ut_assertok(lmb_push(store)); + lmb = lmb_get(); + *mem_lstp = &lmb->free_mem; + *used_lstp = &lmb->used_mem; + + return 0; +} + static int test_multi_alloc(struct unit_test_state *uts, const phys_addr_t ram, const phys_size_t ram_size, const phys_addr_t ram0, const phys_size_t ram0_size, @@ -64,9 +79,11 @@ static int test_multi_alloc(struct unit_test_state *uts, const phys_addr_t ram, const phys_addr_t ram_end = ram + ram_size; const phys_addr_t alloc_64k_end = alloc_64k_addr + 0x10000;
- struct lmb lmb; long ret; + struct alist *mem_lst, *used_lst; + struct lmb_region *mem, *used; phys_addr_t a, a2, b, b2, c, d; + struct lmb store;
/* check for overflow */ ut_assert(ram_end == 0 || ram_end > ram); @@ -75,106 +92,110 @@ static int test_multi_alloc(struct unit_test_state *uts, const phys_addr_t ram, ut_assert(alloc_64k_addr >= ram + 8); ut_assert(alloc_64k_end <= ram_end - 8);
- lmb_init(&lmb); + ut_assertok(setup_lmb_test(uts, &store, &mem_lst, &used_lst)); + mem = mem_lst->data; + used = used_lst->data;
if (ram0_size) { - ret = lmb_add(&lmb, ram0, ram0_size); + ret = lmb_add(ram0, ram0_size); ut_asserteq(ret, 0); }
- ret = lmb_add(&lmb, ram, ram_size); + ret = lmb_add(ram, ram_size); ut_asserteq(ret, 0);
if (ram0_size) { - ut_asserteq(lmb.memory.cnt, 2); - ut_asserteq(lmb.memory.region[0].base, ram0); - ut_asserteq(lmb.memory.region[0].size, ram0_size); - ut_asserteq(lmb.memory.region[1].base, ram); - ut_asserteq(lmb.memory.region[1].size, ram_size); + ut_asserteq(mem_lst->count, 2); + ut_asserteq(mem[0].base, ram0); + ut_asserteq(mem[0].size, ram0_size); + ut_asserteq(mem[1].base, ram); + ut_asserteq(mem[1].size, ram_size); } else { - ut_asserteq(lmb.memory.cnt, 1); - ut_asserteq(lmb.memory.region[0].base, ram); - ut_asserteq(lmb.memory.region[0].size, ram_size); + ut_asserteq(mem_lst->count, 1); + ut_asserteq(mem[0].base, ram); + ut_asserteq(mem[0].size, ram_size); }
/* reserve 64KiB somewhere */ - ret = lmb_reserve(&lmb, alloc_64k_addr, 0x10000); + ret = lmb_reserve(alloc_64k_addr, 0x10000); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, 0, 0, 1, alloc_64k_addr, 0x10000, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 1, alloc_64k_addr, 0x10000, 0, 0, 0, 0);
/* allocate somewhere, should be at the end of RAM */ - a = lmb_alloc(&lmb, 4, 1); + a = lmb_alloc(4, 1); ut_asserteq(a, ram_end - 4); - ASSERT_LMB(&lmb, 0, 0, 2, alloc_64k_addr, 0x10000, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 2, alloc_64k_addr, 0x10000, ram_end - 4, 4, 0, 0); /* alloc below end of reserved region -> below reserved region */ - b = lmb_alloc_base(&lmb, 4, 1, alloc_64k_end); + b = lmb_alloc_base(4, 1, alloc_64k_end); ut_asserteq(b, alloc_64k_addr - 4); - ASSERT_LMB(&lmb, 0, 0, 2, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 2, alloc_64k_addr - 4, 0x10000 + 4, ram_end - 4, 4, 0, 0);
/* 2nd time */ - c = lmb_alloc(&lmb, 4, 1); + c = lmb_alloc(4, 1); ut_asserteq(c, ram_end - 8); - ASSERT_LMB(&lmb, 0, 0, 2, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 2, alloc_64k_addr - 4, 0x10000 + 4, ram_end - 8, 8, 0, 0); - d = lmb_alloc_base(&lmb, 4, 1, alloc_64k_end); + d = lmb_alloc_base(4, 1, alloc_64k_end); ut_asserteq(d, alloc_64k_addr - 8); - ASSERT_LMB(&lmb, 0, 0, 2, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 2, alloc_64k_addr - 8, 0x10000 + 8, ram_end - 8, 8, 0, 0);
- ret = lmb_free(&lmb, a, 4); + ret = lmb_free(a, 4); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, 0, 0, 2, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 2, alloc_64k_addr - 8, 0x10000 + 8, ram_end - 8, 4, 0, 0); /* allocate again to ensure we get the same address */ - a2 = lmb_alloc(&lmb, 4, 1); + a2 = lmb_alloc(4, 1); ut_asserteq(a, a2); - ASSERT_LMB(&lmb, 0, 0, 2, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 2, alloc_64k_addr - 8, 0x10000 + 8, ram_end - 8, 8, 0, 0); - ret = lmb_free(&lmb, a2, 4); + ret = lmb_free(a2, 4); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, 0, 0, 2, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 2, alloc_64k_addr - 8, 0x10000 + 8, ram_end - 8, 4, 0, 0);
- ret = lmb_free(&lmb, b, 4); + ret = lmb_free(b, 4); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, 0, 0, 3, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 3, alloc_64k_addr - 8, 4, alloc_64k_addr, 0x10000, ram_end - 8, 4); /* allocate again to ensure we get the same address */ - b2 = lmb_alloc_base(&lmb, 4, 1, alloc_64k_end); + b2 = lmb_alloc_base(4, 1, alloc_64k_end); ut_asserteq(b, b2); - ASSERT_LMB(&lmb, 0, 0, 2, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 2, alloc_64k_addr - 8, 0x10000 + 8, ram_end - 8, 4, 0, 0); - ret = lmb_free(&lmb, b2, 4); + ret = lmb_free(b2, 4); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, 0, 0, 3, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 3, alloc_64k_addr - 8, 4, alloc_64k_addr, 0x10000, ram_end - 8, 4);
- ret = lmb_free(&lmb, c, 4); + ret = lmb_free(c, 4); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, 0, 0, 2, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 2, alloc_64k_addr - 8, 4, alloc_64k_addr, 0x10000, 0, 0); - ret = lmb_free(&lmb, d, 4); + ret = lmb_free(d, 4); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, 0, 0, 1, alloc_64k_addr, 0x10000, + ASSERT_LMB(mem_lst, used_lst, 0, 0, 1, alloc_64k_addr, 0x10000, 0, 0, 0, 0);
+ lmb_pop(&store); + return 0; }
@@ -229,48 +250,51 @@ static int test_bigblock(struct unit_test_state *uts, const phys_addr_t ram) const phys_size_t big_block_size = 0x10000000; const phys_addr_t ram_end = ram + ram_size; const phys_addr_t alloc_64k_addr = ram + 0x10000000; - struct lmb lmb; + struct alist *mem_lst, *used_lst; long ret; phys_addr_t a, b; + struct lmb store;
/* reserve 64KiB in the middle of RAM */ - ret = lmb_reserve(&lmb, alloc_64k_addr, 0x10000); + ret = lmb_reserve(alloc_64k_addr, 0x10000); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, alloc_64k_addr, 0x10000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, alloc_64k_addr, 0x10000, 0, 0, 0, 0);
/* allocate a big block, should be below reserved */ - a = lmb_alloc(&lmb, big_block_size, 1); + a = lmb_alloc(big_block_size, 1); ut_asserteq(a, ram); - ASSERT_LMB(&lmb, ram, ram_size, 1, a, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, a, big_block_size + 0x10000, 0, 0, 0, 0); /* allocate 2nd big block */ /* This should fail, printing an error */ - b = lmb_alloc(&lmb, big_block_size, 1); + b = lmb_alloc(big_block_size, 1); ut_asserteq(b, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, a, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, a, big_block_size + 0x10000, 0, 0, 0, 0);
- ret = lmb_free(&lmb, a, big_block_size); + ret = lmb_free(a, big_block_size); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, alloc_64k_addr, 0x10000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, alloc_64k_addr, 0x10000, 0, 0, 0, 0);
/* allocate too big block */ /* This should fail, printing an error */ - a = lmb_alloc(&lmb, ram_size, 1); + a = lmb_alloc(ram_size, 1); ut_asserteq(a, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, alloc_64k_addr, 0x10000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, alloc_64k_addr, 0x10000, 0, 0, 0, 0);
@@ -294,56 +318,62 @@ static int test_noreserved(struct unit_test_state *uts, const phys_addr_t ram, { const phys_size_t ram_size = 0x20000000; const phys_addr_t ram_end = ram + ram_size; - struct lmb lmb; long ret; phys_addr_t a, b; + struct lmb store; + struct alist *mem_lst, *used_lst; const phys_addr_t alloc_size_aligned = (alloc_size + align - 1) & ~(align - 1);
- ret = lmb_add(&lmb, ram, ram_size); + ret = lmb_add(ram, ram_size); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 0, 0, 0, 0, 0, 0, 0); + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 0, 0, 0, 0, 0, 0, 0);
/* allocate a block */ - a = lmb_alloc(&lmb, alloc_size, align); + a = lmb_alloc(alloc_size, align); ut_assert(a != 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, ram + ram_size - alloc_size_aligned, - alloc_size, 0, 0, 0, 0); + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, + ram + ram_size - alloc_size_aligned, alloc_size, 0, 0, 0, 0); + /* allocate another block */ - b = lmb_alloc(&lmb, alloc_size, align); + b = lmb_alloc(alloc_size, align); ut_assert(b != 0); if (alloc_size == alloc_size_aligned) { - ASSERT_LMB(&lmb, ram, ram_size, 1, ram + ram_size - + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, ram + ram_size - (alloc_size_aligned * 2), alloc_size * 2, 0, 0, 0, 0); } else { - ASSERT_LMB(&lmb, ram, ram_size, 2, ram + ram_size - + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 2, ram + ram_size - (alloc_size_aligned * 2), alloc_size, ram + ram_size - alloc_size_aligned, alloc_size, 0, 0); } /* and free them */ - ret = lmb_free(&lmb, b, alloc_size); + ret = lmb_free(b, alloc_size); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, ram + ram_size - alloc_size_aligned, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, + ram + ram_size - alloc_size_aligned, alloc_size, 0, 0, 0, 0); - ret = lmb_free(&lmb, a, alloc_size); + ret = lmb_free(a, alloc_size); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 0, 0, 0, 0, 0, 0, 0); + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 0, 0, 0, 0, 0, 0, 0);
/* allocate a block with base*/ - b = lmb_alloc_base(&lmb, alloc_size, align, ram_end); + b = lmb_alloc_base(alloc_size, align, ram_end); ut_assert(a == b); - ASSERT_LMB(&lmb, ram, ram_size, 1, ram + ram_size - alloc_size_aligned, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, + ram + ram_size - alloc_size_aligned, alloc_size, 0, 0, 0, 0); /* and free it */ - ret = lmb_free(&lmb, b, alloc_size); + ret = lmb_free(b, alloc_size); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 0, 0, 0, 0, 0, 0, 0); + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 0, 0, 0, 0, 0, 0, 0); + + lmb_pop(&store);
return 0; } @@ -385,36 +415,39 @@ static int lib_test_lmb_at_0(struct unit_test_state *uts) { const phys_addr_t ram = 0; const phys_size_t ram_size = 0x20000000; - struct lmb lmb; + struct lmb store; + struct alist *mem_lst, *used_lst; long ret; phys_addr_t a, b;
/* allocate nearly everything */ - a = lmb_alloc(&lmb, ram_size - 4, 1); + a = lmb_alloc(ram_size - 4, 1); ut_asserteq(a, ram + 4); - ASSERT_LMB(&lmb, ram, ram_size, 1, a, ram_size - 4, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, a, ram_size - 4, 0, 0, 0, 0); /* allocate the rest */ /* This should fail as the allocated address would be 0 */ - b = lmb_alloc(&lmb, 4, 1); + b = lmb_alloc(4, 1); ut_asserteq(b, 0); /* check that this was an error by checking lmb */ - ASSERT_LMB(&lmb, ram, ram_size, 1, a, ram_size - 4, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, a, ram_size - 4, 0, 0, 0, 0); /* check that this was an error by freeing b */ - ret = lmb_free(&lmb, b, 4); + ret = lmb_free(b, 4); ut_asserteq(ret, -1); - ASSERT_LMB(&lmb, ram, ram_size, 1, a, ram_size - 4, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, a, ram_size - 4, 0, 0, 0, 0);
- ret = lmb_free(&lmb, a, ram_size - 4); + ret = lmb_free(a, ram_size - 4); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 0, 0, 0, 0, 0, 0, 0); + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 0, 0, 0, 0, 0, 0, 0); + + lmb_pop(&store);
return 0; } @@ -425,45 +458,50 @@ static int lib_test_lmb_overlapping_reserve(struct unit_test_state *uts) { const phys_addr_t ram = 0x40000000; const phys_size_t ram_size = 0x20000000; - struct lmb lmb; + struct lmb store; + struct alist *mem_lst, *used_lst; long ret;
- ret = lmb_reserve(&lmb, 0x40010000, 0x10000); + ret = lmb_reserve(0x40010000, 0x10000); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40010000, 0x10000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40010000, 0x10000, 0, 0, 0, 0); - /* allocate overlapping region should fail */ - ret = lmb_reserve(&lmb, 0x40011000, 0x10000); - ut_asserteq(ret, -1); - ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40010000, 0x10000, + + /* allocate overlapping region should return the coalesced count */ + ret = lmb_reserve(0x40011000, 0x10000); + ut_asserteq(ret, 1); + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40010000, 0x11000, 0, 0, 0, 0); /* allocate 3nd region */ - ret = lmb_reserve(&lmb, 0x40030000, 0x10000); + ret = lmb_reserve(0x40030000, 0x10000); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 2, 0x40010000, 0x10000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 2, 0x40010000, 0x11000, 0x40030000, 0x10000, 0, 0); /* allocate 2nd region , This should coalesced all region into one */ - ret = lmb_reserve(&lmb, 0x40020000, 0x10000); + ret = lmb_reserve(0x40020000, 0x10000); ut_assert(ret >= 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40010000, 0x30000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40010000, 0x30000, 0, 0, 0, 0);
/* allocate 2nd region, which should be added as first region */ - ret = lmb_reserve(&lmb, 0x40000000, 0x8000); + ret = lmb_reserve(0x40000000, 0x8000); ut_assert(ret >= 0); - ASSERT_LMB(&lmb, ram, ram_size, 2, 0x40000000, 0x8000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 2, 0x40000000, 0x8000, 0x40010000, 0x30000, 0, 0);
/* allocate 3rd region, coalesce with first and overlap with second */ - ret = lmb_reserve(&lmb, 0x40008000, 0x10000); + ret = lmb_reserve(0x40008000, 0x10000); ut_assert(ret >= 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40000000, 0x40000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40000000, 0x40000, 0, 0, 0, 0); + + lmb_pop(&store); + return 0; } LIB_TEST(lib_test_lmb_overlapping_reserve, 0); @@ -474,112 +512,116 @@ LIB_TEST(lib_test_lmb_overlapping_reserve, 0); */ static int test_alloc_addr(struct unit_test_state *uts, const phys_addr_t ram) { + struct lmb store; + struct alist *mem_lst, *used_lst; const phys_size_t ram_size = 0x20000000; const phys_addr_t ram_end = ram + ram_size; const phys_size_t alloc_addr_a = ram + 0x8000000; const phys_size_t alloc_addr_b = ram + 0x8000000 * 2; const phys_size_t alloc_addr_c = ram + 0x8000000 * 3; - struct lmb lmb; long ret; phys_addr_t a, b, c, d, e;
/* reserve 3 blocks */ - ret = lmb_reserve(&lmb, alloc_addr_a, 0x10000); + ret = lmb_reserve(alloc_addr_a, 0x10000); ut_asserteq(ret, 0); - ret = lmb_reserve(&lmb, alloc_addr_b, 0x10000); + ret = lmb_reserve(alloc_addr_b, 0x10000); ut_asserteq(ret, 0); - ret = lmb_reserve(&lmb, alloc_addr_c, 0x10000); + ret = lmb_reserve(alloc_addr_c, 0x10000); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 3, alloc_addr_a, 0x10000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 3, alloc_addr_a, 0x10000, alloc_addr_b, 0x10000, alloc_addr_c, 0x10000);
/* allocate blocks */ - a = lmb_alloc_addr(&lmb, ram, alloc_addr_a - ram); + a = lmb_alloc_addr(ram, alloc_addr_a - ram); ut_asserteq(a, ram); - ASSERT_LMB(&lmb, ram, ram_size, 3, ram, 0x8010000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 3, ram, 0x8010000, alloc_addr_b, 0x10000, alloc_addr_c, 0x10000); - b = lmb_alloc_addr(&lmb, alloc_addr_a + 0x10000, + b = lmb_alloc_addr(alloc_addr_a + 0x10000, alloc_addr_b - alloc_addr_a - 0x10000); ut_asserteq(b, alloc_addr_a + 0x10000); - ASSERT_LMB(&lmb, ram, ram_size, 2, ram, 0x10010000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 2, ram, 0x10010000, alloc_addr_c, 0x10000, 0, 0); - c = lmb_alloc_addr(&lmb, alloc_addr_b + 0x10000, + c = lmb_alloc_addr(alloc_addr_b + 0x10000, alloc_addr_c - alloc_addr_b - 0x10000); ut_asserteq(c, alloc_addr_b + 0x10000); - ASSERT_LMB(&lmb, ram, ram_size, 1, ram, 0x18010000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, ram, 0x18010000, 0, 0, 0, 0); - d = lmb_alloc_addr(&lmb, alloc_addr_c + 0x10000, + d = lmb_alloc_addr(alloc_addr_c + 0x10000, ram_end - alloc_addr_c - 0x10000); ut_asserteq(d, alloc_addr_c + 0x10000); - ASSERT_LMB(&lmb, ram, ram_size, 1, ram, ram_size, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, ram, ram_size, 0, 0, 0, 0);
/* allocating anything else should fail */ - e = lmb_alloc(&lmb, 1, 1); + e = lmb_alloc(1, 1); ut_asserteq(e, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, ram, ram_size, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, ram, ram_size, 0, 0, 0, 0);
- ret = lmb_free(&lmb, d, ram_end - alloc_addr_c - 0x10000); + ret = lmb_free(d, ram_end - alloc_addr_c - 0x10000); ut_asserteq(ret, 0);
/* allocate at 3 points in free range */
- d = lmb_alloc_addr(&lmb, ram_end - 4, 4); + d = lmb_alloc_addr(ram_end - 4, 4); ut_asserteq(d, ram_end - 4); - ASSERT_LMB(&lmb, ram, ram_size, 2, ram, 0x18010000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 2, ram, 0x18010000, d, 4, 0, 0); - ret = lmb_free(&lmb, d, 4); + ret = lmb_free(d, 4); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, ram, 0x18010000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, ram, 0x18010000, 0, 0, 0, 0);
- d = lmb_alloc_addr(&lmb, ram_end - 128, 4); + d = lmb_alloc_addr(ram_end - 128, 4); ut_asserteq(d, ram_end - 128); - ASSERT_LMB(&lmb, ram, ram_size, 2, ram, 0x18010000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 2, ram, 0x18010000, d, 4, 0, 0); - ret = lmb_free(&lmb, d, 4); + ret = lmb_free(d, 4); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, ram, 0x18010000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, ram, 0x18010000, 0, 0, 0, 0);
- d = lmb_alloc_addr(&lmb, alloc_addr_c + 0x10000, 4); + d = lmb_alloc_addr(alloc_addr_c + 0x10000, 4); ut_asserteq(d, alloc_addr_c + 0x10000); - ASSERT_LMB(&lmb, ram, ram_size, 1, ram, 0x18010004, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, ram, 0x18010004, 0, 0, 0, 0); - ret = lmb_free(&lmb, d, 4); + ret = lmb_free(d, 4); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, ram, 0x18010000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, ram, 0x18010000, 0, 0, 0, 0);
/* allocate at the bottom */ - ret = lmb_free(&lmb, a, alloc_addr_a - ram); + ret = lmb_free(a, alloc_addr_a - ram); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, ram + 0x8000000, 0x10010000, - 0, 0, 0, 0); - d = lmb_alloc_addr(&lmb, ram, 4); + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, ram + 0x8000000, + 0x10010000, 0, 0, 0, 0); + + d = lmb_alloc_addr(ram, 4); ut_asserteq(d, ram); - ASSERT_LMB(&lmb, ram, ram_size, 2, d, 4, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 2, d, 4, ram + 0x8000000, 0x10010000, 0, 0);
/* check that allocating outside memory fails */ if (ram_end != 0) { - ret = lmb_alloc_addr(&lmb, ram_end, 1); + ret = lmb_alloc_addr(ram_end, 1); ut_asserteq(ret, 0); } if (ram != 0) { - ret = lmb_alloc_addr(&lmb, ram - 1, 1); + ret = lmb_alloc_addr(ram - 1, 1); ut_asserteq(ret, 0); }
@@ -601,55 +643,57 @@ LIB_TEST(lib_test_lmb_alloc_addr, 0); static int test_get_unreserved_size(struct unit_test_state *uts, const phys_addr_t ram) { + struct lmb store; + struct alist *mem_lst, *used_lst; const phys_size_t ram_size = 0x20000000; const phys_addr_t ram_end = ram + ram_size; const phys_size_t alloc_addr_a = ram + 0x8000000; const phys_size_t alloc_addr_b = ram + 0x8000000 * 2; const phys_size_t alloc_addr_c = ram + 0x8000000 * 3; - struct lmb lmb; long ret; phys_size_t s;
/* check for overflow */ ut_assert(ram_end == 0 || ram_end > ram); + ut_assertok(setup_lmb_test(uts, &store, &mem_lst, &used_lst));
- lmb_init(&lmb); - - ret = lmb_add(&lmb, ram, ram_size); + ret = lmb_add(ram, ram_size); ut_asserteq(ret, 0);
/* check addresses in between blocks */ - s = lmb_get_free_size(&lmb, ram); + s = lmb_get_free_size(ram); ut_asserteq(s, alloc_addr_a - ram); - s = lmb_get_free_size(&lmb, ram + 0x10000); + s = lmb_get_free_size(ram + 0x10000); ut_asserteq(s, alloc_addr_a - ram - 0x10000); - s = lmb_get_free_size(&lmb, alloc_addr_a - 4); + s = lmb_get_free_size(alloc_addr_a - 4); ut_asserteq(s, 4);
- s = lmb_get_free_size(&lmb, alloc_addr_a + 0x10000); + s = lmb_get_free_size(alloc_addr_a + 0x10000); ut_asserteq(s, alloc_addr_b - alloc_addr_a - 0x10000); - s = lmb_get_free_size(&lmb, alloc_addr_a + 0x20000); + s = lmb_get_free_size(alloc_addr_a + 0x20000); ut_asserteq(s, alloc_addr_b - alloc_addr_a - 0x20000); - s = lmb_get_free_size(&lmb, alloc_addr_b - 4); + s = lmb_get_free_size(alloc_addr_b - 4); ut_asserteq(s, 4);
- s = lmb_get_free_size(&lmb, alloc_addr_c + 0x10000); + s = lmb_get_free_size(alloc_addr_c + 0x10000); ut_asserteq(s, ram_end - alloc_addr_c - 0x10000); - s = lmb_get_free_size(&lmb, alloc_addr_c + 0x20000); + s = lmb_get_free_size(alloc_addr_c + 0x20000); ut_asserteq(s, ram_end - alloc_addr_c - 0x20000); - s = lmb_get_free_size(&lmb, ram_end - 4); + s = lmb_get_free_size(ram_end - 4); ut_asserteq(s, 4);
@@ -667,158 +711,94 @@ static int lib_test_lmb_get_free_size(struct unit_test_state *uts) } LIB_TEST(lib_test_lmb_get_free_size, 0);
-#ifdef CONFIG_LMB_USE_MAX_REGIONS -static int lib_test_lmb_max_regions(struct unit_test_state *uts) -{ - const phys_addr_t ram = 0x00000000; - /* - * All of 32bit memory space will contain regions for this test, so - * we need to scale ram_size (which in this case is the size of the lmb - * region) to match. - */ - const phys_size_t ram_size = ((0xFFFFFFFF >> CONFIG_LMB_MAX_REGIONS) - + 1) * CONFIG_LMB_MAX_REGIONS; - const phys_size_t blk_size = 0x10000; - phys_addr_t offset; - struct lmb lmb; - int ret, i; - - lmb_init(&lmb); - - ut_asserteq(lmb.memory.cnt, 0); - ut_asserteq(lmb.memory.max, CONFIG_LMB_MAX_REGIONS); - ut_asserteq(lmb.reserved.cnt, 0); - ut_asserteq(lmb.reserved.max, CONFIG_LMB_MAX_REGIONS); - - /* Add CONFIG_LMB_MAX_REGIONS memory regions */ - for (i = 0; i < CONFIG_LMB_MAX_REGIONS; i++) { - offset = ram + 2 * i * ram_size; - ret = lmb_add(&lmb, offset, ram_size); - ut_asserteq(ret, 0); - } - ut_asserteq(lmb.memory.cnt, CONFIG_LMB_MAX_REGIONS); - ut_asserteq(lmb.reserved.cnt, 0); - - /* error for the (CONFIG_LMB_MAX_REGIONS + 1) memory regions */ - offset = ram + 2 * (CONFIG_LMB_MAX_REGIONS + 1) * ram_size; - ret = lmb_add(&lmb, offset, ram_size); - ut_asserteq(ret, -1); - - ut_asserteq(lmb.memory.cnt, CONFIG_LMB_MAX_REGIONS); - ut_asserteq(lmb.reserved.cnt, 0); - - /* reserve CONFIG_LMB_MAX_REGIONS regions */ - for (i = 0; i < CONFIG_LMB_MAX_REGIONS; i++) { - offset = ram + 2 * i * blk_size; - ret = lmb_reserve(&lmb, offset, blk_size); - ut_asserteq(ret, 0); - } - - ut_asserteq(lmb.memory.cnt, CONFIG_LMB_MAX_REGIONS); - ut_asserteq(lmb.reserved.cnt, CONFIG_LMB_MAX_REGIONS); - - /* error for the 9th reserved blocks */ - offset = ram + 2 * (CONFIG_LMB_MAX_REGIONS + 1) * blk_size; - ret = lmb_reserve(&lmb, offset, blk_size); - ut_asserteq(ret, -1); - - ut_asserteq(lmb.memory.cnt, CONFIG_LMB_MAX_REGIONS); - ut_asserteq(lmb.reserved.cnt, CONFIG_LMB_MAX_REGIONS); - - /* check each regions */ - for (i = 0; i < CONFIG_LMB_MAX_REGIONS; i++) - ut_asserteq(lmb.memory.region[i].base, ram + 2 * i * ram_size); - - for (i = 0; i < CONFIG_LMB_MAX_REGIONS; i++) - ut_asserteq(lmb.reserved.region[i].base, ram + 2 * i * blk_size); - - return 0; -} -LIB_TEST(lib_test_lmb_max_regions, 0); -#endif - static int lib_test_lmb_flags(struct unit_test_state *uts) { + struct lmb store; + struct lmb_region *mem, *used; + struct alist *mem_lst, *used_lst; const phys_addr_t ram = 0x40000000; const phys_size_t ram_size = 0x20000000; - struct lmb lmb; long ret;
/* reserve, same flag */ - ret = lmb_reserve_flags(&lmb, 0x40010000, 0x10000, LMB_NOMAP); + ret = lmb_reserve_flags(0x40010000, 0x10000, LMB_NOMAP); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40010000, 0x10000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40010000, 0x10000, 0, 0, 0, 0);
/* reserve again, same flag */ - ret = lmb_reserve_flags(&lmb, 0x40010000, 0x10000, LMB_NOMAP); + ret = lmb_reserve_flags(0x40010000, 0x10000, LMB_NOMAP); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40010000, 0x10000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40010000, 0x10000, 0, 0, 0, 0);
/* reserve again, new flag */ - ret = lmb_reserve_flags(&lmb, 0x40010000, 0x10000, LMB_NONE); + ret = lmb_reserve_flags(0x40010000, 0x10000, LMB_NONE); ut_asserteq(ret, -1); - ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40010000, 0x10000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40010000, 0x10000, 0, 0, 0, 0);
- ut_asserteq(lmb_is_nomap(&lmb.reserved.region[0]), 1); + ut_asserteq(lmb_is_nomap(&used[0]), 1);
/* merge after */ - ret = lmb_reserve_flags(&lmb, 0x40020000, 0x10000, LMB_NOMAP); + ret = lmb_reserve_flags(0x40020000, 0x10000, LMB_NOMAP); ut_asserteq(ret, 1); - ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40010000, 0x20000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40010000, 0x20000, 0, 0, 0, 0);
/* merge before */ - ret = lmb_reserve_flags(&lmb, 0x40000000, 0x10000, LMB_NOMAP); + ret = lmb_reserve_flags(0x40000000, 0x10000, LMB_NOMAP); ut_asserteq(ret, 1); - ASSERT_LMB(&lmb, ram, ram_size, 1, 0x40000000, 0x30000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 1, 0x40000000, 0x30000, 0, 0, 0, 0);
- ret = lmb_reserve_flags(&lmb, 0x40030000, 0x10000, LMB_NONE); + ret = lmb_reserve_flags(0x40030000, 0x10000, LMB_NONE); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 2, 0x40000000, 0x30000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 2, 0x40000000, 0x30000, 0x40030000, 0x10000, 0, 0);
- ut_asserteq(lmb_is_nomap(&lmb.reserved.region[0]), 1); - ut_asserteq(lmb_is_nomap(&lmb.reserved.region[1]), 0); + ut_asserteq(lmb_is_nomap(&used[0]), 1); + ut_asserteq(lmb_is_nomap(&used[1]), 0);
/* test that old API use LMB_NONE */ - ret = lmb_reserve(&lmb, 0x40040000, 0x10000); + ret = lmb_reserve(0x40040000, 0x10000); ut_asserteq(ret, 1); - ASSERT_LMB(&lmb, ram, ram_size, 2, 0x40000000, 0x30000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 2, 0x40000000, 0x30000, 0x40030000, 0x20000, 0, 0);
- ret = lmb_reserve_flags(&lmb, 0x40070000, 0x10000, LMB_NOMAP); + ret = lmb_reserve_flags(0x40070000, 0x10000, LMB_NOMAP); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 3, 0x40000000, 0x30000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 3, 0x40000000, 0x30000, 0x40030000, 0x20000, 0x40070000, 0x10000);
- ret = lmb_reserve_flags(&lmb, 0x40050000, 0x10000, LMB_NOMAP); + ret = lmb_reserve_flags(0x40050000, 0x10000, LMB_NOMAP); ut_asserteq(ret, 0); - ASSERT_LMB(&lmb, ram, ram_size, 4, 0x40000000, 0x30000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 4, 0x40000000, 0x30000, 0x40030000, 0x20000, 0x40050000, 0x10000);
/* merge with 2 adjacent regions */ - ret = lmb_reserve_flags(&lmb, 0x40060000, 0x10000, LMB_NOMAP); + ret = lmb_reserve_flags(0x40060000, 0x10000, LMB_NOMAP); ut_asserteq(ret, 2); - ASSERT_LMB(&lmb, ram, ram_size, 3, 0x40000000, 0x30000, + ASSERT_LMB(mem_lst, used_lst, ram, ram_size, 3, 0x40000000, 0x30000, 0x40030000, 0x20000, 0x40050000, 0x30000);
- ut_asserteq(lmb_is_nomap(&lmb.reserved.region[0]), 1); - ut_asserteq(lmb_is_nomap(&lmb.reserved.region[1]), 0); - ut_asserteq(lmb_is_nomap(&lmb.reserved.region[2]), 1); + ut_asserteq(lmb_is_nomap(&used[0]), 1); + ut_asserteq(lmb_is_nomap(&used[1]), 0); + ut_asserteq(lmb_is_nomap(&used[2]), 1); + + lmb_pop(&store);
return 0; }
Hi Sughosh
On 26/08/24 17:29, Sughosh Ganu wrote:
The current LMB API's for allocating and reserving memory use a per-caller based memory view. Memory allocated by a caller can then be overwritten by another caller. Make these allocations and reservations persistent using the alloced list data structure.
Two alloced lists are declared -- one for the available(free) memory, and one for the used memory. Once full, the list can then be extended at runtime.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Signed-off-by: Simon Glass sjg@chromium.org [sjg: Optimise the logic to add a region in lmb_add_region_flags()] [sjg: Use a stack to store pointer of lmb struct when running lmb tests]
Changes since V3:
Fix checkpatch warnings of spaces between function name and open parantheses.
s/uint64_t/u64 as suggested by checkpatch.
Remove unneccessary parantheses in lmb.c as suggested by checkpatch.
Fix alignment in test/cmd/bdinfo.c as suggested by checkpatch.
arch/arc/lib/cache.c | 4 +- arch/arm/lib/stack.c | 4 +- arch/arm/mach-apple/board.c | 17 +- arch/arm/mach-snapdragon/board.c | 17 +- arch/arm/mach-stm32mp/dram_init.c | 8 +- arch/arm/mach-stm32mp/stm32mp1/cpu.c | 6 +- arch/m68k/lib/bootm.c | 7 +- arch/microblaze/lib/bootm.c | 4 +- arch/mips/lib/bootm.c | 11 +- arch/nios2/lib/bootm.c | 4 +- arch/powerpc/cpu/mpc85xx/mp.c | 4 +- arch/powerpc/include/asm/mp.h | 4 +- arch/powerpc/lib/bootm.c | 14 +- arch/riscv/lib/bootm.c | 4 +- arch/sh/lib/bootm.c | 4 +- arch/x86/lib/bootm.c | 4 +- arch/xtensa/lib/bootm.c | 4 +- board/xilinx/common/board.c | 8 +- boot/bootm.c | 26 +- boot/bootm_os.c | 5 +- boot/image-board.c | 34 +- boot/image-fdt.c | 35 +- cmd/bdinfo.c | 6 +- cmd/booti.c | 2 +- cmd/bootz.c | 2 +- cmd/elf.c | 2 +- cmd/load.c | 7 +- drivers/iommu/apple_dart.c | 8 +- drivers/iommu/sandbox_iommu.c | 16 +- fs/fs.c | 7 +-
In fs the reserved region is not being freed after read, while other loaders free them (cmd/load.c), this patch uncovers the issue since now other loaders cannot use the same memory location for load. For example now someone cannot do:
mmc load .. $loadaddr ... <do something with above contents> tftp $loadaddr ..
where this worked previously since it was not global, I have sent a fix for this : https://lore.kernel.org/all/20240916054038.2125910-1-vaishnav.a@ti.com/
Thanks and Regards, Vaishnav
include/image.h | 28 +- include/lmb.h | 111 ++---- lib/efi_loader/efi_dt_fixup.c | 2 +- lib/efi_loader/efi_helper.c | 2 +- lib/lmb.c | 446 +++++++++++++--------- net/tftp.c | 5 +- net/wget.c | 5 +- test/cmd/bdinfo.c | 41 +- test/lib/lmb.c | 542 +++++++++++++-------------- 39 files changed, 714 insertions(+), 746 deletions(-)
On Mon, 16 Sept 2024 at 11:34, Vaishnav Achath vaishnav.a@ti.com wrote:
Hi Sughosh
Changes since V3:
The idea with the LMB memory is that it is not really an allocation, but setting aside memory for use. Now there was a discussion earlier on the mailing list if this is actually an allocation or not, but this is what the functions have been called from it's early days. But the way the code is designed now, even with the global and persistent memory map, we have the LMB_NONE flag which is used to allow for the same memory region to be re-allocated/re-reserved.
The issue above is what I mentioned to Prasad in one of my earlier replies to the patch that he had sent [1]. What can be done is to unify the manner in which callers ask for LMB memory -- that would mean changing the behaviour of the tftp code to use the logic used in the fs_read_lmb_check() function. I believe this method of loading to an address is more beneficial as it allows memory re-use.
-sughosh
[1] - https://lists.denx.de/pipermail/u-boot/2024-September/564610.html
Changes since V3:
- Fix checkpatch warnings of spaces between function name and open parantheses.
- s/uint64_t/u64 as suggested by checkpatch.
- Remove unneccessary parantheses in lmb.c as suggested by checkpatch.
- Fix alignment in test/cmd/bdinfo.c as suggested by checkpatch.
diff --git a/drivers/iommu/apple_dart.c b/drivers/iommu/apple_dart.c index 9327dea1e3..611ac7cd6d 100644 --- a/drivers/iommu/apple_dart.c +++ b/drivers/iommu/apple_dart.c @@ -70,7 +70,6 @@
struct apple_dart_priv { void *base;
- struct lmb lmb; u64 *l1, *l2; int bypass, shift;
@@ -124,7 +123,7 @@ static dma_addr_t apple_dart_map(struct udevice *dev, void *addr, size_t size) off = (phys_addr_t)addr - paddr; psize = ALIGN(size + off, DART_PAGE_SIZE);
- dva = lmb_alloc(&priv->lmb, psize, DART_PAGE_SIZE);
dva = lmb_alloc(psize, DART_PAGE_SIZE);
idx = dva / DART_PAGE_SIZE; for (i = 0; i < psize / DART_PAGE_SIZE; i++) {
@@ -160,7 +159,7 @@ static void apple_dart_unmap(struct udevice *dev, dma_addr_t addr, size_t size) (unsigned long)&priv->l2[idx + i]); priv->flush_tlb(priv);
- lmb_free(&priv->lmb, dva, psize);
- lmb_free(dva, psize);
static struct iommu_ops apple_dart_ops = { @@ -213,8 +212,7 @@ static int apple_dart_probe(struct udevice *dev) priv->dvabase = DART_PAGE_SIZE; priv->dvaend = SZ_4G - DART_PAGE_SIZE;
- lmb_init(&priv->lmb);
- lmb_add(&priv->lmb, priv->dvabase, priv->dvaend - priv->dvabase);
- lmb_add(priv->dvabase, priv->dvaend - priv->dvabase);
no. This breaks everything. apple_dart is an iommu and used struct lmb to manage the IO virtual address space. This has nothing to do with system memory. Depending on the allocation strategy this will cause all sorts of problems since the IO and the physical memory address space does not overlap on apple silicon devices. IOVA is for many devices only 32-bit but physical memory starts at 0x10_0000_0000 or 0x100_0000_0000. Every device has its own iommu / IOVA space so sharing the space between all of them is another problem. I'd assume only theoretical due to the limited driver support and memory use in u-boot.
My current plan to fix this is to resurrect the old lmb code under a different name.
Not sure about the same change in sandbox_iommu but I guess it could be ok as there is no sandbox.
Janne
Changes since V3:
Oh damn, sorry. Perhaps it can be brought back in the iommu framework more directly? I asked Caleb and they said snapdragon doesn't need something like this.
Changes since V3:
dva = lmb_alloc(psize, DART_PAGE_SIZE); idx = dva / DART_PAGE_SIZE; for (i = 0; i < psize / DART_PAGE_SIZE; i++) {
Firstly, apologies for breaking the driver. Looking at the code, it looks like the driver works with a dva address range in the first 4GB. I think what the driver expects is fairly straightforward, with a top-down allocation scheme. I have sent a patch [1] which replaces the LMB calls with a call to the allocation function. Can you please check if this works on the board? Looking at how the driver is obtaining the dva addresses, I think this logic should suffice. Thanks.
-sughosh
[1] - https://patchwork.ozlabs.org/project/uboot/patch/20241029033915.423211-1-sug...
-sughosh
Janne
Changes since V3:
-sughosh
This would not work as it does not consider freeing of the va addresses. So there might be a need for a parallel lmb instance for this.
-sughosh
-sughosh
Janne
Changes since V3:
-sughosh
-sughosh
-sughosh
I have pushed the changes for the driver to one of my github branch [1]. Can you please try it out and let me know. Thanks.
-sughosh
[1] - https://github.com/sughoshg/u-boot/tree/apple_dart_changes
Janne
Allow for resizing of LMB regions if the region attributes match. The current code returns a failure status on detecting an overlapping address. This worked up until now since the LMB calls were not persistent and global -- the LMB memory map was specific and private to a given caller of the LMB API's.
With the change in the LMB code to make the LMB reservations persistent, there needs to be a check on whether the memory region can be resized, and then do it if so. To distinguish between memory that cannot be resized, add a new flag, LMB_NOOVERWRITE. Reserving a region of memory with this attribute would indicate that the region cannot be resized.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V3: * Do away with multiple assignments in lmb_resize_regions() as suggested by checkpatch.
include/lmb.h | 1 + lib/lmb.c | 99 ++++++++++++++++++++++++++++++++++++++++++--------- 2 files changed, 84 insertions(+), 16 deletions(-)
diff --git a/include/lmb.h b/include/lmb.h index 0979dcebc0..cc2c426c13 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -22,6 +22,7 @@ enum lmb_flags { LMB_NONE = 0, LMB_NOMAP = BIT(1), + LMB_NOOVERWRITE = BIT(2), };
/** diff --git a/lib/lmb.c b/lib/lmb.c index 0aa2d8bd3b..8be0c1a583 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -246,6 +246,57 @@ void lmb_init_and_reserve_range(phys_addr_t base, phys_size_t size, lmb_reserve_common(fdt_blob); }
+static long lmb_resize_regions(struct alist *lmb_rgn_lst, + unsigned long idx_start, + phys_addr_t base, phys_size_t size) +{ + phys_size_t rgnsize; + unsigned long rgn_cnt, idx, idx_end; + phys_addr_t rgnbase, rgnend; + phys_addr_t mergebase, mergeend; + struct lmb_region *rgn = lmb_rgn_lst->data; + + rgn_cnt = 0; + idx = idx_start; + idx_end = idx_start; + + /* + * First thing to do is to identify how many regions + * the requested region overlaps. + * If the flags match, combine all these overlapping + * regions into a single region, and remove the merged + * regions. + */ + while (idx <= lmb_rgn_lst->count - 1) { + rgnbase = rgn[idx].base; + rgnsize = rgn[idx].size; + + if (lmb_addrs_overlap(base, size, rgnbase, + rgnsize)) { + if (rgn[idx].flags != LMB_NONE) + return -1; + rgn_cnt++; + idx_end = idx; + } + idx++; + } + + /* The merged region's base and size */ + rgnbase = rgn[idx_start].base; + mergebase = min(base, rgnbase); + rgnend = rgn[idx_end].base + rgn[idx_end].size; + mergeend = max(rgnend, (base + size)); + + rgn[idx_start].base = mergebase; + rgn[idx_start].size = mergeend - mergebase; + + /* Now remove the merged regions */ + while (--rgn_cnt) + lmb_remove_region(lmb_rgn_lst, idx_start + 1); + + return 0; +} + /** * lmb_add_region_flags() - Add an lmb region to the given list * @lmb_rgn_lst: LMB list to which region is to be added(free/used) @@ -265,7 +316,7 @@ static long lmb_add_region_flags(struct alist *lmb_rgn_lst, phys_addr_t base, phys_size_t size, enum lmb_flags flags) { unsigned long coalesced = 0; - long adjacent, i; + long ret, i; struct lmb_region *rgn = lmb_rgn_lst->data;
if (alist_err(lmb_rgn_lst)) @@ -286,23 +337,32 @@ static long lmb_add_region_flags(struct alist *lmb_rgn_lst, phys_addr_t base, return -1; /* regions with new flags */ }
- adjacent = lmb_addrs_adjacent(base, size, rgnbase, rgnsize); - if (adjacent > 0) { + ret = lmb_addrs_adjacent(base, size, rgnbase, rgnsize); + if (ret > 0) { if (flags != rgnflags) break; rgn[i].base -= size; rgn[i].size += size; coalesced++; break; - } else if (adjacent < 0) { + } else if (ret < 0) { if (flags != rgnflags) break; rgn[i].size += size; coalesced++; break; } else if (lmb_addrs_overlap(base, size, rgnbase, rgnsize)) { - /* regions overlap */ - return -1; + if (flags == LMB_NONE) { + ret = lmb_resize_regions(lmb_rgn_lst, i, base, + size); + if (ret < 0) + return -1; + + coalesced++; + break; + } else { + return -1; + } } }
@@ -444,7 +504,7 @@ static phys_addr_t lmb_align_down(phys_addr_t addr, phys_size_t size) }
static phys_addr_t __lmb_alloc_base(phys_size_t size, ulong align, - phys_addr_t max_addr) + phys_addr_t max_addr, enum lmb_flags flags) { long i, rgn; phys_addr_t base = 0; @@ -473,8 +533,8 @@ static phys_addr_t __lmb_alloc_base(phys_size_t size, ulong align, rgn = lmb_overlaps_region(&lmb.used_mem, base, size); if (rgn < 0) { /* This area isn't reserved, take it */ - if (lmb_add_region(&lmb.used_mem, base, - size) < 0) + if (lmb_add_region_flags(&lmb.used_mem, base, + size, flags) < 0) return 0; return base; } @@ -497,7 +557,7 @@ phys_addr_t lmb_alloc_base(phys_size_t size, ulong align, phys_addr_t max_addr) { phys_addr_t alloc;
- alloc = __lmb_alloc_base(size, align, max_addr); + alloc = __lmb_alloc_base(size, align, max_addr, LMB_NONE);
if (alloc == 0) printf("ERROR: Failed to allocate 0x%lx bytes below 0x%lx.\n", @@ -506,11 +566,8 @@ phys_addr_t lmb_alloc_base(phys_size_t size, ulong align, phys_addr_t max_addr) return alloc; }
-/* - * Try to allocate a specific address range: must be in defined memory but not - * reserved - */ -phys_addr_t lmb_alloc_addr(phys_addr_t base, phys_size_t size) +static phys_addr_t __lmb_alloc_addr(phys_addr_t base, phys_size_t size, + enum lmb_flags flags) { long rgn; struct lmb_region *lmb_memory = lmb.free_mem.data; @@ -526,13 +583,23 @@ phys_addr_t lmb_alloc_addr(phys_addr_t base, phys_size_t size) lmb_memory[rgn].size, base + size - 1, 1)) { /* ok, reserve the memory */ - if (lmb_reserve(base, size) >= 0) + if (lmb_reserve_flags(base, size, flags) >= 0) return base; } } + return 0; }
+/* + * Try to allocate a specific address range: must be in defined memory but not + * reserved + */ +phys_addr_t lmb_alloc_addr(phys_addr_t base, phys_size_t size) +{ + return __lmb_alloc_addr(base, size, LMB_NONE); +} + /* Return number of bytes from a given address that are free */ phys_size_t lmb_get_free_size(phys_addr_t addr) {
The LMB memory maps are now being maintained through a couple of alloced lists, one for the available(added) memory, and one for the used memory. These lists are not static arrays but can be extended at runtime. Remove the config symbols which were being used to define the size of these lists with the earlier implementation of static arrays.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V3: None
configs/a3y17lte_defconfig | 1 - configs/a5y17lte_defconfig | 1 - configs/a7y17lte_defconfig | 1 - configs/apple_m1_defconfig | 1 - configs/mt7981_emmc_rfb_defconfig | 1 - configs/mt7981_rfb_defconfig | 1 - configs/mt7981_sd_rfb_defconfig | 1 - configs/mt7986_rfb_defconfig | 1 - configs/mt7986a_bpir3_emmc_defconfig | 1 - configs/mt7986a_bpir3_sd_defconfig | 1 - configs/mt7988_rfb_defconfig | 1 - configs/mt7988_sd_rfb_defconfig | 1 - configs/qcom_defconfig | 1 - configs/stm32mp13_defconfig | 3 --- configs/stm32mp15_basic_defconfig | 3 --- configs/stm32mp15_defconfig | 3 --- configs/stm32mp15_trusted_defconfig | 3 --- configs/stm32mp25_defconfig | 3 --- configs/th1520_lpi4a_defconfig | 1 - lib/Kconfig | 34 ---------------------------- 20 files changed, 63 deletions(-)
diff --git a/configs/a3y17lte_defconfig b/configs/a3y17lte_defconfig index 5c15d51fdc..b012b985a3 100644 --- a/configs/a3y17lte_defconfig +++ b/configs/a3y17lte_defconfig @@ -23,4 +23,3 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_DM_I2C_GPIO=y -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/a5y17lte_defconfig b/configs/a5y17lte_defconfig index 7c9b6b2511..25a7d5bc98 100644 --- a/configs/a5y17lte_defconfig +++ b/configs/a5y17lte_defconfig @@ -23,4 +23,3 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_DM_I2C_GPIO=y -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/a7y17lte_defconfig b/configs/a7y17lte_defconfig index c7297f7d75..c87379ab39 100644 --- a/configs/a7y17lte_defconfig +++ b/configs/a7y17lte_defconfig @@ -23,4 +23,3 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_DM_I2C_GPIO=y -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/apple_m1_defconfig b/configs/apple_m1_defconfig index 20d2cff93f..dca6e0ca8b 100644 --- a/configs/apple_m1_defconfig +++ b/configs/apple_m1_defconfig @@ -26,4 +26,3 @@ CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_NO_FB_CLEAR=y CONFIG_VIDEO_SIMPLE=y # CONFIG_SMBIOS is not set -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/mt7981_emmc_rfb_defconfig b/configs/mt7981_emmc_rfb_defconfig index 76ee2aa2d6..d3e833905f 100644 --- a/configs/mt7981_emmc_rfb_defconfig +++ b/configs/mt7981_emmc_rfb_defconfig @@ -62,4 +62,3 @@ CONFIG_MTK_SERIAL=y CONFIG_FAT_WRITE=y CONFIG_HEXDUMP=y # CONFIG_EFI_LOADER is not set -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/mt7981_rfb_defconfig b/configs/mt7981_rfb_defconfig index 3989c79d2b..4bc2173f13 100644 --- a/configs/mt7981_rfb_defconfig +++ b/configs/mt7981_rfb_defconfig @@ -65,4 +65,3 @@ CONFIG_DM_SPI=y CONFIG_MTK_SPIM=y CONFIG_HEXDUMP=y # CONFIG_EFI_LOADER is not set -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/mt7981_sd_rfb_defconfig b/configs/mt7981_sd_rfb_defconfig index 9b33245527..8721b4074a 100644 --- a/configs/mt7981_sd_rfb_defconfig +++ b/configs/mt7981_sd_rfb_defconfig @@ -62,4 +62,3 @@ CONFIG_MTK_SERIAL=y CONFIG_FAT_WRITE=y CONFIG_HEXDUMP=y # CONFIG_EFI_LOADER is not set -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/mt7986_rfb_defconfig b/configs/mt7986_rfb_defconfig index 4d0cc85d0e..15c31de236 100644 --- a/configs/mt7986_rfb_defconfig +++ b/configs/mt7986_rfb_defconfig @@ -65,4 +65,3 @@ CONFIG_DM_SPI=y CONFIG_MTK_SPIM=y CONFIG_HEXDUMP=y # CONFIG_EFI_LOADER is not set -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/mt7986a_bpir3_emmc_defconfig b/configs/mt7986a_bpir3_emmc_defconfig index 3c296ab803..56921f3605 100644 --- a/configs/mt7986a_bpir3_emmc_defconfig +++ b/configs/mt7986a_bpir3_emmc_defconfig @@ -62,4 +62,3 @@ CONFIG_MTK_SERIAL=y CONFIG_FAT_WRITE=y CONFIG_HEXDUMP=y # CONFIG_EFI_LOADER is not set -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/mt7986a_bpir3_sd_defconfig b/configs/mt7986a_bpir3_sd_defconfig index f644070f4e..4ed06b72d5 100644 --- a/configs/mt7986a_bpir3_sd_defconfig +++ b/configs/mt7986a_bpir3_sd_defconfig @@ -62,4 +62,3 @@ CONFIG_MTK_SERIAL=y CONFIG_FAT_WRITE=y CONFIG_HEXDUMP=y # CONFIG_EFI_LOADER is not set -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/mt7988_rfb_defconfig b/configs/mt7988_rfb_defconfig index d0ed2cc1c9..f7ceaceb30 100644 --- a/configs/mt7988_rfb_defconfig +++ b/configs/mt7988_rfb_defconfig @@ -81,4 +81,3 @@ CONFIG_MTK_SPIM=y CONFIG_LZO=y CONFIG_HEXDUMP=y # CONFIG_EFI_LOADER is not set -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/mt7988_sd_rfb_defconfig b/configs/mt7988_sd_rfb_defconfig index 5631eaa338..808c8b9011 100644 --- a/configs/mt7988_sd_rfb_defconfig +++ b/configs/mt7988_sd_rfb_defconfig @@ -69,4 +69,3 @@ CONFIG_MTK_SPIM=y CONFIG_LZO=y CONFIG_HEXDUMP=y # CONFIG_EFI_LOADER is not set -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/qcom_defconfig b/configs/qcom_defconfig index 8852e83a52..edbb624baf 100644 --- a/configs/qcom_defconfig +++ b/configs/qcom_defconfig @@ -117,4 +117,3 @@ CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_NO_FB_CLEAR=y CONFIG_VIDEO_SIMPLE=y CONFIG_HEXDUMP=y -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/stm32mp13_defconfig b/configs/stm32mp13_defconfig index caaabf39ef..9aa3560c7e 100644 --- a/configs/stm32mp13_defconfig +++ b/configs/stm32mp13_defconfig @@ -103,6 +103,3 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_ERRNO_STR=y -# CONFIG_LMB_USE_MAX_REGIONS is not set -CONFIG_LMB_MEMORY_REGIONS=2 -CONFIG_LMB_RESERVED_REGIONS=16 diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 2e22bf8600..806935f389 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -190,6 +190,3 @@ CONFIG_WDT=y CONFIG_WDT_STM32MP=y # CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y -# CONFIG_LMB_USE_MAX_REGIONS is not set -CONFIG_LMB_MEMORY_REGIONS=2 -CONFIG_LMB_RESERVED_REGIONS=16 diff --git a/configs/stm32mp15_defconfig b/configs/stm32mp15_defconfig index ffe7512650..5f050ee0d0 100644 --- a/configs/stm32mp15_defconfig +++ b/configs/stm32mp15_defconfig @@ -166,6 +166,3 @@ CONFIG_WDT=y CONFIG_WDT_STM32MP=y # CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y -# CONFIG_LMB_USE_MAX_REGIONS is not set -CONFIG_LMB_MEMORY_REGIONS=2 -CONFIG_LMB_RESERVED_REGIONS=16 diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 74deaaba2e..3c591d74af 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -166,6 +166,3 @@ CONFIG_WDT=y CONFIG_WDT_STM32MP=y # CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y -# CONFIG_LMB_USE_MAX_REGIONS is not set -CONFIG_LMB_MEMORY_REGIONS=2 -CONFIG_LMB_RESERVED_REGIONS=16 diff --git a/configs/stm32mp25_defconfig b/configs/stm32mp25_defconfig index 87038cc773..f5623a19bb 100644 --- a/configs/stm32mp25_defconfig +++ b/configs/stm32mp25_defconfig @@ -49,6 +49,3 @@ CONFIG_WDT_STM32MP=y CONFIG_WDT_ARM_SMC=y CONFIG_ERRNO_STR=y # CONFIG_EFI_LOADER is not set -# CONFIG_LMB_USE_MAX_REGIONS is not set -CONFIG_LMB_MEMORY_REGIONS=2 -CONFIG_LMB_RESERVED_REGIONS=32 diff --git a/configs/th1520_lpi4a_defconfig b/configs/th1520_lpi4a_defconfig index 49ff92f6de..db80e33870 100644 --- a/configs/th1520_lpi4a_defconfig +++ b/configs/th1520_lpi4a_defconfig @@ -79,4 +79,3 @@ CONFIG_BZIP2=y CONFIG_ZSTD=y CONFIG_LIB_RATIONAL=y # CONFIG_EFI_LOADER is not set -# CONFIG_LMB_USE_MAX_REGIONS is not set diff --git a/lib/Kconfig b/lib/Kconfig index 2059219a12..f8ac8daad3 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -1105,40 +1105,6 @@ config LMB help Support the library logical memory blocks.
-config LMB_USE_MAX_REGIONS - bool "Use a common number of memory and reserved regions in lmb lib" - default y - help - Define the number of supported memory regions in the library logical - memory blocks. - This feature allow to reduce the lmb library size by using compiler - optimization when LMB_MEMORY_REGIONS == LMB_RESERVED_REGIONS. - -config LMB_MAX_REGIONS - int "Number of memory and reserved regions in lmb lib" - depends on LMB_USE_MAX_REGIONS - default 16 - help - Define the number of supported regions, memory and reserved, in the - library logical memory blocks. - -config LMB_MEMORY_REGIONS - int "Number of memory regions in lmb lib" - depends on !LMB_USE_MAX_REGIONS - default 8 - help - Define the number of supported memory regions in the library logical - memory blocks. - The minimal value is CONFIG_NR_DRAM_BANKS. - -config LMB_RESERVED_REGIONS - int "Number of reserved regions in lmb lib" - depends on !LMB_USE_MAX_REGIONS - default 8 - help - Define the number of supported reserved regions in the library logical - memory blocks. - config PHANDLE_CHECK_SEQ bool "Enable phandle check while getting sequence number" help
default y
help
memory blocks.
default 16
help
default 8
help
memory blocks.
default 8
help
memory blocks.
config PHANDLE_CHECK_SEQ bool "Enable phandle check while getting sequence number" help -- 2.34.1
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Add separate config symbols for enabling the LMB module for the SPL phase. The LMB module implementation now relies on alloced list data structure which requires heap area to be present. Add specific config symbol for the SPL phase of U-Boot so that this can be enabled on platforms which support a heap in SPL.
lib/Kconfig | 12 +++++++++++- 1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/lib/Kconfig b/lib/Kconfig index f8ac8daad3..6a9338390a 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -1103,7 +1103,17 @@ config LMB default y if ARC || ARM || M68K || MICROBLAZE || MIPS || \ NIOS2 || PPC || RISCV || SANDBOX || SH || X86 || XTENSA help - Support the library logical memory blocks. + Support the library logical memory blocks. This will require + a malloc() implementation for defining the data structures + needed for maintaining the LMB memory map. + +config SPL_LMB + bool "Enable LMB module for SPL" + depends on SPL && SPL_FRAMEWORK && SPL_SYS_MALLOC + help + Enable support for Logical Memory Block library routines in + SPL. This will require a malloc() implementation for defining + the data structures needed for maintaining the LMB memory map.
+config SPL_LMB
help
config PHANDLE_CHECK_SEQ bool "Enable phandle check while getting sequence number" -- 2.34.1
With the introduction of separate config symbols for the SPL phase of U-Boot, the condition checks need to be tweaked so that platforms that enable the LMB module in SPL are also able to call the LMB API's. Use the appropriate condition checks to achieve this.
board/xilinx/common/board.c | 2 +- boot/bootm.c | 4 ++-- boot/image-board.c | 2 +- fs/fs.c | 4 ++-- lib/Makefile | 2 +- net/tftp.c | 40 ++++++++++++++++++------------------- net/wget.c | 4 ++-- 7 files changed, 29 insertions(+), 29 deletions(-)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 4056884400..f04c92a70f 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -665,7 +665,7 @@ int embedded_dtb_select(void) } #endif
-#if defined(CONFIG_LMB) +#if IS_ENABLED(CONFIG_LMB)
#ifndef MMU_SECTION_SIZE #define MMU_SECTION_SIZE (1 * 1024 * 1024) diff --git a/boot/bootm.c b/boot/bootm.c index d47feddb9b..e244b9b410 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -239,7 +239,7 @@ static int boot_get_kernel(const char *addr_fit, struct bootm_headers *images, return 0; }
-#ifdef CONFIG_LMB +#if CONFIG_IS_ENABLED(LMB) static void boot_start_lmb(void) { phys_addr_t mem_start; @@ -1036,7 +1036,7 @@ int bootm_run_states(struct bootm_info *bmi, int states) } } #endif -#if CONFIG_IS_ENABLED(OF_LIBFDT) && defined(CONFIG_LMB) +#if CONFIG_IS_ENABLED(OF_LIBFDT) && CONFIG_IS_ENABLED(LMB) if (!ret && (states & BOOTM_STATE_FDT)) { boot_fdt_add_mem_rsv_regions(images->ft_addr); ret = boot_relocate_fdt(&images->ft_addr, &images->ft_len); diff --git a/boot/image-board.c b/boot/image-board.c index 1f8c1ac69f..99ee7968ba 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -883,7 +883,7 @@ int image_setup_linux(struct bootm_headers *images) int ret;
/* This function cannot be called without lmb support */ - if (!IS_ENABLED(CONFIG_LMB)) + if (!CONFIG_IS_ENABLED(LMB)) return -EFAULT; if (CONFIG_IS_ENABLED(OF_LIBFDT)) boot_fdt_add_mem_rsv_regions(*of_flat_tree); diff --git a/fs/fs.c b/fs/fs.c index 2c835eef86..3fb00590be 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -526,7 +526,7 @@ int fs_size(const char *filename, loff_t *size) return ret; }
-#ifdef CONFIG_LMB +#if CONFIG_IS_ENABLED(LMB) /* Check if a file may be read to the given address */ static int fs_read_lmb_check(const char *filename, ulong addr, loff_t offset, loff_t len, struct fstype_info *info) @@ -567,7 +567,7 @@ static int _fs_read(const char *filename, ulong addr, loff_t offset, loff_t len, void *buf; int ret;
-#ifdef CONFIG_LMB +#if CONFIG_IS_ENABLED(LMB) if (do_lmb_check) { ret = fs_read_lmb_check(filename, addr, offset, len, info); if (ret) diff --git a/lib/Makefile b/lib/Makefile index 81b503ab52..d300249f57 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -118,7 +118,7 @@ obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += fdtdec.o fdtdec_common.o obj-y += hang.o obj-y += linux_compat.o obj-y += linux_string.o -obj-$(CONFIG_LMB) += lmb.o +obj-$(CONFIG_$(SPL_TPL_)LMB) += lmb.o obj-y += membuff.o obj-$(CONFIG_REGEX) += slre.o obj-y += string.o diff --git a/net/tftp.c b/net/tftp.c index c0a6210b9d..99b2ab9fca 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -82,9 +82,7 @@ static ulong tftp_block_wrap; static ulong tftp_block_wrap_offset; static int tftp_state; static ulong tftp_load_addr; -#ifdef CONFIG_LMB static ulong tftp_load_size; -#endif #ifdef CONFIG_TFTP_TSIZE /* The file size reported by the server */ static int tftp_tsize; @@ -160,19 +158,20 @@ static inline int store_block(int block, uchar *src, unsigned int len) ulong store_addr = tftp_load_addr + offset; void *ptr;
-#ifdef CONFIG_LMB - ulong end_addr = tftp_load_addr + tftp_load_size; + if (CONFIG_IS_ENABLED(LMB)) { + ulong end_addr = tftp_load_addr + tftp_load_size;
- if (!end_addr) - end_addr = ULONG_MAX; + if (!end_addr) + end_addr = ULONG_MAX;
- if (store_addr < tftp_load_addr || - store_addr + len > end_addr) { - puts("\nTFTP error: "); - puts("trying to overwrite reserved memory...\n"); - return -1; + if (store_addr < tftp_load_addr || + store_addr + len > end_addr) { + puts("\nTFTP error: "); + puts("trying to overwrite reserved memory...\n"); + return -1; + } } -#endif + ptr = map_sysmem(store_addr, len); memcpy(ptr, src, len); unmap_sysmem(ptr); @@ -716,17 +715,18 @@ static void tftp_timeout_handler(void) /* Initialize tftp_load_addr and tftp_load_size from image_load_addr and lmb */ static int tftp_init_load_addr(void) { -#ifdef CONFIG_LMB - phys_size_t max_size; + if (CONFIG_IS_ENABLED(LMB)) { + phys_size_t max_size;
- lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob); + lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob);
- max_size = lmb_get_free_size(image_load_addr); - if (!max_size) - return -1; + max_size = lmb_get_free_size(image_load_addr); + if (!max_size) + return -1; + + tftp_load_size = max_size; + }
- tftp_load_size = max_size; -#endif tftp_load_addr = image_load_addr; return 0; } diff --git a/net/wget.c b/net/wget.c index c1cd8216bc..241465b9b4 100644 --- a/net/wget.c +++ b/net/wget.c @@ -98,7 +98,7 @@ static inline int store_block(uchar *src, unsigned int offset, unsigned int len) ulong newsize = offset + len; uchar *ptr;
- if (IS_ENABLED(CONFIG_LMB)) { + if (CONFIG_IS_ENABLED(LMB)) { ulong end_addr = image_load_addr + wget_load_size;
if (!end_addr) @@ -495,7 +495,7 @@ void wget_start(void) debug_cond(DEBUG_WGET, "\nwget:Load address: 0x%lx\nLoading: *\b", image_load_addr);
- if (IS_ENABLED(CONFIG_LMB)) { + if (CONFIG_IS_ENABLED(LMB)) { if (wget_init_load_size()) { printf("\nwget error: "); printf("trying to overwrite reserved memory...\n");
-#ifdef CONFIG_LMB
if (!end_addr)
if (!end_addr)
return -1;
return -1;
-#endif
if (!max_size)
return -1;
if (!max_size)
return -1;
if (CONFIG_IS_ENABLED(LMB)) { ulong end_addr = image_load_addr + wget_load_size; if (!end_addr)
-- 2.34.1
Introduce a function lmb_add_memory() to add available memory to the LMB memory map. Call this function during board init once the LMB data structures have been initialised.
include/lmb.h | 11 +++++++++++ lib/lmb.c | 39 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 50 insertions(+)
diff --git a/include/lmb.h b/include/lmb.h index cc2c426c13..70191456e5 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -66,6 +66,17 @@ int lmb_init(void); void lmb_init_and_reserve(struct bd_info *bd, void *fdt_blob); void lmb_init_and_reserve_range(phys_addr_t base, phys_size_t size, void *fdt_blob); + +/** + * lmb_add_memory() - Add memory range for LMB allocations + * + * Add the entire available memory range to the pool of memory that + * can be used by the LMB module for allocations. + * + * Return: None + */ +void lmb_add_memory(void); + long lmb_add(phys_addr_t base, phys_size_t size); long lmb_reserve(phys_addr_t base, phys_size_t size); /** diff --git a/lib/lmb.c b/lib/lmb.c index 8be0c1a583..44ecf96811 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -246,6 +246,43 @@ void lmb_init_and_reserve_range(phys_addr_t base, phys_size_t size, lmb_reserve_common(fdt_blob); }
+/** + * lmb_add_memory() - Add memory range for LMB allocations + * + * Add the entire available memory range to the pool of memory that + * can be used by the LMB module for allocations. + * + * Return: None + */ +void lmb_add_memory(void) +{ + int i; + phys_size_t size; + phys_addr_t rgn_top; + u64 ram_top = gd->ram_top; + struct bd_info *bd = gd->bd; + + /* Assume a 4GB ram_top if not defined */ + if (!ram_top) + ram_top = 0x100000000ULL; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + size = bd->bi_dram[i].size; + if (size) { + if (bd->bi_dram[i].start > ram_top) + continue; + + rgn_top = bd->bi_dram[i].start + + bd->bi_dram[i].size; + + if (rgn_top > ram_top) + size -= rgn_top - ram_top; + + lmb_add(bd->bi_dram[i].start, size); + } + } +} + static long lmb_resize_regions(struct alist *lmb_rgn_lst, unsigned long idx_start, phys_addr_t base, phys_size_t size) @@ -696,6 +733,8 @@ int lmb_init(void) return ret; }
+ lmb_add_memory(); + return 0; }
The LMB module provides API's for allocating and reserving chunks of memory which is then typically used for things like loading images for booting. Reserve the portion of memory that is occupied by the U-Boot image itself, and other parts of memory that might have been marked as reserved in the board's DTB. When executing in SPL, reserve the sections that get relocated to the ram memory, the stack and the global data structure and also the bss.
Mark these regions of memory with the LMB_NOOVERWRITE flag to indicate that these regions cannot be re-requested or overwritten.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V3: * Fix the alignment in arch_lmb_reserve_generic() as suggested by checkpatch.
lib/lmb.c | 36 ++++++++++++++++++++++++++++++++++-- 1 file changed, 34 insertions(+), 2 deletions(-)
diff --git a/lib/lmb.c b/lib/lmb.c index 44ecf96811..9b1854223d 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -13,6 +13,7 @@ #include <lmb.h> #include <log.h> #include <malloc.h> +#include <spl.h>
#include <asm/global_data.h> #include <asm/sections.h> @@ -172,10 +173,11 @@ void arch_lmb_reserve_generic(ulong sp, ulong end, ulong align) if (bank_end > end) bank_end = end - 1;
- lmb_reserve(sp, bank_end - sp + 1); + lmb_reserve_flags(sp, bank_end - sp + 1, LMB_NOOVERWRITE);
if (gd->flags & GD_FLG_SKIP_RELOC) - lmb_reserve((phys_addr_t)(uintptr_t)_start, gd->mon_len); + lmb_reserve_flags((phys_addr_t)(uintptr_t)_start, + gd->mon_len, LMB_NOOVERWRITE);
break; } @@ -246,6 +248,30 @@ void lmb_init_and_reserve_range(phys_addr_t base, phys_size_t size, lmb_reserve_common(fdt_blob); }
+static __maybe_unused void lmb_reserve_common_spl(void) +{ + phys_addr_t rsv_start; + phys_size_t rsv_size; + + /* + * Assume a SPL stack of 16KB. This must be + * more than enough for the SPL stage. + */ + if (IS_ENABLED(CONFIG_SPL_STACK_R_ADDR)) { + rsv_start = gd->start_addr_sp - 16384; + rsv_size = 16384; + lmb_reserve_flags(rsv_start, rsv_size, LMB_NOOVERWRITE); + } + + if (IS_ENABLED(CONFIG_SPL_SEPARATE_BSS)) { + /* Reserve the bss region */ + rsv_start = (phys_addr_t)(uintptr_t)__bss_start; + rsv_size = (phys_addr_t)(uintptr_t)__bss_end - + (phys_addr_t)(uintptr_t)__bss_start; + lmb_reserve_flags(rsv_start, rsv_size, LMB_NOOVERWRITE); + } +} + /** * lmb_add_memory() - Add memory range for LMB allocations * @@ -735,6 +761,12 @@ int lmb_init(void)
lmb_add_memory();
+ /* Reserve the U-Boot image region once U-Boot has relocated */ + if (spl_phase() == PHASE_SPL) + lmb_reserve_common_spl(); + else if (spl_phase() == PHASE_BOARD_R) + lmb_reserve_common((void *)gd->fdt_blob); + return 0; }
With the changes to make the LMB reservations persistent, the common memory regions are being added during board init. Remove the now superfluous lmb_init_and_reserve() function.
arch/arm/mach-apple/board.c | 2 -- arch/arm/mach-snapdragon/board.c | 2 -- arch/arm/mach-stm32mp/stm32mp1/cpu.c | 3 --- cmd/bdinfo.c | 1 - cmd/load.c | 2 -- fs/fs.c | 1 - include/lmb.h | 1 - lib/lmb.c | 13 ------------- net/tftp.c | 2 -- net/wget.c | 2 -- 10 files changed, 29 deletions(-)
diff --git a/arch/arm/mach-apple/board.c b/arch/arm/mach-apple/board.c index 213390d6e8..0b6d290b8a 100644 --- a/arch/arm/mach-apple/board.c +++ b/arch/arm/mach-apple/board.c @@ -775,8 +775,6 @@ int board_late_init(void) { u32 status = 0;
- lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob); - /* somewhat based on the Linux Kernel boot requirements: * align by 2M and maximal FDT size 2M */ diff --git a/arch/arm/mach-snapdragon/board.c b/arch/arm/mach-snapdragon/board.c index a63c8bec45..22a7d2a637 100644 --- a/arch/arm/mach-snapdragon/board.c +++ b/arch/arm/mach-snapdragon/board.c @@ -282,8 +282,6 @@ int board_late_init(void) { u32 status = 0;
- lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob); - /* We need to be fairly conservative here as we support boards with just 1G of TOTAL RAM */ status |= env_set_hex("kernel_addr_r", addr_alloc(SZ_128M)); status |= env_set_hex("ramdisk_addr_r", addr_alloc(SZ_128M)); diff --git a/arch/arm/mach-stm32mp/stm32mp1/cpu.c b/arch/arm/mach-stm32mp/stm32mp1/cpu.c index a913737342..64480da9f8 100644 --- a/arch/arm/mach-stm32mp/stm32mp1/cpu.c +++ b/arch/arm/mach-stm32mp/stm32mp1/cpu.c @@ -141,9 +141,6 @@ int mach_cpu_init(void)
void enable_caches(void) { - /* parse device tree when data cache is still activated */ - lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob); - /* I-cache is already enabled in start.S: icache_enable() not needed */
/* deactivate the data cache, early enabled in arch_cpu_init() */ diff --git a/cmd/bdinfo.c b/cmd/bdinfo.c index b31e0208df..3c40dee143 100644 --- a/cmd/bdinfo.c +++ b/cmd/bdinfo.c @@ -162,7 +162,6 @@ static int bdinfo_print_all(struct bd_info *bd) bdinfo_print_num_l("multi_dtb_fit", (ulong)gd->multi_dtb_fit); #endif if (IS_ENABLED(CONFIG_LMB) && gd->fdt_blob) { - lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob); lmb_dump_all_force(); if (IS_ENABLED(CONFIG_OF_REAL)) printf("devicetree = %s\n", fdtdec_get_srcname()); diff --git a/cmd/load.c b/cmd/load.c index 56da3a4c5d..20d802502a 100644 --- a/cmd/load.c +++ b/cmd/load.c @@ -153,8 +153,6 @@ static ulong load_serial(long offset) int line_count = 0; long ret;
- lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob); - while (read_record(record, SREC_MAXRECLEN + 1) >= 0) { type = srec_decode(record, &binlen, &addr, binbuf);
diff --git a/fs/fs.c b/fs/fs.c index 3fb00590be..4bc28d1dff 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -549,7 +549,6 @@ static int fs_read_lmb_check(const char *filename, ulong addr, loff_t offset, if (len && len < read_len) read_len = len;
- lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob); lmb_dump_all();
if (lmb_alloc_addr(addr, read_len) == addr) diff --git a/include/lmb.h b/include/lmb.h index 70191456e5..04558724a7 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -63,7 +63,6 @@ struct lmb { */ int lmb_init(void);
-void lmb_init_and_reserve(struct bd_info *bd, void *fdt_blob); void lmb_init_and_reserve_range(phys_addr_t base, phys_size_t size, void *fdt_blob);
diff --git a/lib/lmb.c b/lib/lmb.c index 9b1854223d..de4d0d1803 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -227,19 +227,6 @@ static void lmb_reserve_common(void *fdt_blob) efi_lmb_reserve(); }
-/* Initialize the struct, add memory and call arch/board reserve functions */ -void lmb_init_and_reserve(struct bd_info *bd, void *fdt_blob) -{ - int i; - - for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { - if (bd->bi_dram[i].size) - lmb_add(bd->bi_dram[i].start, bd->bi_dram[i].size); - } - - lmb_reserve_common(fdt_blob); -} - /* Initialize the struct, add memory and call arch/board reserve functions */ void lmb_init_and_reserve_range(phys_addr_t base, phys_size_t size, void *fdt_blob) diff --git a/net/tftp.c b/net/tftp.c index 99b2ab9fca..b5d227d8bc 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -718,8 +718,6 @@ static int tftp_init_load_addr(void) if (CONFIG_IS_ENABLED(LMB)) { phys_size_t max_size;
- lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob); - max_size = lmb_get_free_size(image_load_addr); if (!max_size) return -1; diff --git a/net/wget.c b/net/wget.c index 241465b9b4..4a168641c6 100644 --- a/net/wget.c +++ b/net/wget.c @@ -75,8 +75,6 @@ static int wget_init_load_size(void) { phys_size_t max_size;
/* I-cache is already enabled in start.S: icache_enable() not needed */ /* deactivate the data cache, early enabled in arch_cpu_init() */
lmb_init_and_reserve(gd->bd, (void *)gd->fdt_blob); lmb_dump_all(); if (lmb_alloc_addr(addr, read_len) == addr)
int i;
-- 2.34.1
With the move to make the LMB allocations persistent and the common memory regions being reserved during board init, there is no need for an explicit reservation of a memory range. Remove the lmb_init_and_reserve_range() function.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V3: None
boot/bootm.c | 15 +-------------- include/lmb.h | 3 --- lib/lmb.c | 8 -------- 3 files changed, 1 insertion(+), 25 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index e244b9b410..ddede08979 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -239,18 +239,7 @@ static int boot_get_kernel(const char *addr_fit, struct bootm_headers *images, return 0; }
-#if CONFIG_IS_ENABLED(LMB) -static void boot_start_lmb(void) -{ - phys_addr_t mem_start; - phys_size_t mem_size; - - mem_start = env_get_bootm_low(); - mem_size = env_get_bootm_size(); - - lmb_init_and_reserve_range(mem_start, mem_size, NULL); -} -#else +#if !CONFIG_IS_ENABLED(LMB) #define lmb_reserve(base, size) static inline void boot_start_lmb(void) { } #endif @@ -260,8 +249,6 @@ static int bootm_start(void) memset((void *)&images, 0, sizeof(images)); images.verify = env_get_yesno("verify");
- boot_start_lmb(); - bootstage_mark_name(BOOTSTAGE_ID_BOOTM_START, "bootm_start"); images.state = BOOTM_STATE_START;
diff --git a/include/lmb.h b/include/lmb.h index 04558724a7..2f155d706e 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -63,9 +63,6 @@ struct lmb { */ int lmb_init(void);
-void lmb_init_and_reserve_range(phys_addr_t base, phys_size_t size, - void *fdt_blob); - /** * lmb_add_memory() - Add memory range for LMB allocations * diff --git a/lib/lmb.c b/lib/lmb.c index de4d0d1803..686988e34f 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -227,14 +227,6 @@ static void lmb_reserve_common(void *fdt_blob) efi_lmb_reserve(); }
-/* Initialize the struct, add memory and call arch/board reserve functions */ -void lmb_init_and_reserve_range(phys_addr_t base, phys_size_t size, - void *fdt_blob) -{ - lmb_add(base, size); - lmb_reserve_common(fdt_blob); -} - static __maybe_unused void lmb_reserve_common_spl(void) { phys_addr_t rsv_start;
Remove a couple of superfluous LMB stub functions, and instead put a check for calling the lmb_reserve() function.
boot/bootm.c | 9 +++------ 1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index ddede08979..a61bbcfb45 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -239,11 +239,6 @@ static int boot_get_kernel(const char *addr_fit, struct bootm_headers *images, return 0; }
-#if !CONFIG_IS_ENABLED(LMB) -#define lmb_reserve(base, size) -static inline void boot_start_lmb(void) { } -#endif - static int bootm_start(void) { memset((void *)&images, 0, sizeof(images)); @@ -700,7 +695,9 @@ static int bootm_load_os(struct bootm_headers *images, int boot_progress) images->os.end = relocated_addr + image_size; }
- lmb_reserve(images->os.load, (load_end - images->os.load)); + if (CONFIG_IS_ENABLED(LMB)) + lmb_reserve(images->os.load, (load_end - images->os.load)); + return 0; }
-- 2.34.1
The memory map maintained by the LMB module is now persistent and global. This memory map is being maintained through the alloced list structure which can be extended at runtime -- there is one list for the available memory, and one for the used memory. Allocate and initialise these lists during the board init.
common/board_r.c | 10 ++++++++++ common/spl/spl.c | 3 +++ 2 files changed, 13 insertions(+)
diff --git a/common/board_r.c b/common/board_r.c index f445803d7a..a60da39a29 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -22,6 +22,7 @@ #include <hang.h> #include <image.h> #include <irq_func.h> +#include <lmb.h> #include <log.h> #include <net.h> #include <asm/cache.h> @@ -510,6 +511,14 @@ int initr_mem(void) } #endif
+static int initr_lmb(void) +{ + if (CONFIG_IS_ENABLED(LMB)) + return lmb_init(); + else + return 0; +} + static int dm_announce(void) { int device_count; @@ -612,6 +621,7 @@ static init_fnc_t init_sequence_r[] = { #ifdef CONFIG_CLOCKS set_cpu_clk_info, /* Setup clock information */ #endif + initr_lmb, #ifdef CONFIG_EFI_LOADER efi_memory_init, #endif diff --git a/common/spl/spl.c b/common/spl/spl.c index 7c6e322ffd..ad2dc6a908 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -721,6 +721,9 @@ void board_init_r(gd_t *dummy1, ulong dummy2) IS_ENABLED(CONFIG_SPL_ATF)) dram_init_banksize();
+ if (IS_ENABLED(CONFIG_SPL_LMB)) + lmb_init(); + if (CONFIG_IS_ENABLED(PCI) && !(gd->flags & GD_FLG_DM_DEAD)) { ret = pci_init(); if (ret)
return lmb_init();
else
initr_lmb,
lmb_init();
-- 2.34.1
All the current function definitions of arch_lmb_reserve() are doing the same thing -- reserve the U-Boot memory region. The powerpc(ppc) architecture, in addition, is making some LMB reservations for the bootm related image loading. Move these ppc specific reservations to the arch_misc_init() function. This allows to move the U-Boot memory region reservation to a different function, and remove arch_lmb_reserve() in a subsequent commit.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V3: * Removed the additional blank line in arch/powerpc/lib/misc.c as suggested by checkpatch. * Added spaces in the CFG_SYS_LINUX_LOWMEM_MAX_SIZE value as suggested by checkpatch. * Added a missing blank line in arch/powerpc/lib/misc.c as suggested by checkpatch.
arch/powerpc/cpu/mpc85xx/cpu_init.c | 16 -------- arch/powerpc/lib/Makefile | 1 + arch/powerpc/lib/bootm.c | 40 ------------------- arch/powerpc/lib/misc.c | 62 +++++++++++++++++++++++++++++ lib/Kconfig | 1 + 5 files changed, 64 insertions(+), 56 deletions(-) create mode 100644 arch/powerpc/lib/misc.c
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index a7b805bc67..739d14f800 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -940,22 +940,6 @@ int cpu_init_r(void) return 0; }
-#ifdef CONFIG_ARCH_MISC_INIT -int arch_misc_init(void) -{ - if (IS_ENABLED(CONFIG_FSL_CAAM)) { - struct udevice *dev; - int ret; - - ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); - if (ret) - printf("Failed to initialize caam_jr: %d\n", ret); - } - - return 0; -} -#endif - void arch_preboot_os(void) { u32 msr; diff --git a/arch/powerpc/lib/Makefile b/arch/powerpc/lib/Makefile index bb819dcbb6..ecc2aba8f3 100644 --- a/arch/powerpc/lib/Makefile +++ b/arch/powerpc/lib/Makefile @@ -39,6 +39,7 @@ obj-y += cache.o obj-y += extable.o obj-y += interrupts.o obj-$(CONFIG_CMD_KGDB) += kgdb.o +obj-y += misc.o obj-y += stack.o obj-y += time.o obj-y += traps.o diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index 752f72f873..8f21cdb0a5 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -12,7 +12,6 @@ #include <cpu_func.h> #include <env.h> #include <init.h> -#include <lmb.h> #include <log.h> #include <watchdog.h> #include <command.h> @@ -41,10 +40,6 @@ static ulong get_sp (void); extern void ft_fixup_num_cores(void *blob); static void set_clocks_in_mhz (struct bd_info *kbd);
-#ifndef CFG_SYS_LINUX_LOWMEM_MAX_SIZE -#define CFG_SYS_LINUX_LOWMEM_MAX_SIZE (768*1024*1024) -#endif - static void boot_jump_linux(struct bootm_headers *images) { void (*kernel)(struct bd_info *, ulong r4, ulong r5, ulong r6, @@ -116,41 +111,6 @@ static void boot_jump_linux(struct bootm_headers *images) return; }
-void arch_lmb_reserve(void) -{ - phys_size_t bootm_size; - ulong size, bootmap_base; - - bootmap_base = env_get_bootm_low(); - bootm_size = env_get_bootm_size(); - -#ifdef DEBUG - if (((u64)bootmap_base + bootm_size) > - (CFG_SYS_SDRAM_BASE + (u64)gd->ram_size)) - puts("WARNING: bootm_low + bootm_size exceed total memory\n"); - if ((bootmap_base + bootm_size) > get_effective_memsize()) - puts("WARNING: bootm_low + bootm_size exceed eff. memory\n"); -#endif - - size = min(bootm_size, get_effective_memsize()); - size = min(size, (ulong)CFG_SYS_LINUX_LOWMEM_MAX_SIZE); - - if (size < bootm_size) { - ulong base = bootmap_base + size; - printf("WARNING: adjusting available memory from 0x%lx to 0x%llx\n", - size, (unsigned long long)bootm_size); - lmb_reserve(base, bootm_size - size); - } - - arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); - -#ifdef CONFIG_MP - cpu_mp_lmb_reserve(); -#endif - - return; -} - static void boot_prep_linux(struct bootm_headers *images) { #ifdef CONFIG_MP diff --git a/arch/powerpc/lib/misc.c b/arch/powerpc/lib/misc.c new file mode 100644 index 0000000000..4cd23b3406 --- /dev/null +++ b/arch/powerpc/lib/misc.c @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2024 Linaro Ltd. + */ + +#include <image.h> +#include <init.h> +#include <lmb.h> + +#include <asm/mp.h> +#include <dm/device.h> +#include <dm/uclass.h> + +#ifndef CFG_SYS_LINUX_LOWMEM_MAX_SIZE +#define CFG_SYS_LINUX_LOWMEM_MAX_SIZE (768 * 1024 * 1024) +#endif + +int arch_misc_init(void) +{ + if (CONFIG_IS_ENABLED(CMD_BOOTM)) { + phys_size_t bootm_size; + ulong size, bootmap_base; + + bootmap_base = env_get_bootm_low(); + bootm_size = env_get_bootm_size(); + +#ifdef DEBUG + if (((u64)bootmap_base + bootm_size) > + (CFG_SYS_SDRAM_BASE + (u64)gd->ram_size)) + puts("WARNING: bootm_low + bootm_size exceed total memory\n"); + if ((bootmap_base + bootm_size) > get_effective_memsize()) + puts("WARNING: bootm_low + bootm_size exceed eff. memory\n"); +#endif + + size = min(bootm_size, get_effective_memsize()); + size = min(size, (ulong)CFG_SYS_LINUX_LOWMEM_MAX_SIZE); + + if (size < bootm_size) { + ulong base = bootmap_base + size; + + printf("WARNING: adjusting available memory from 0x%lx to 0x%llx\n", + size, (unsigned long long)bootm_size); + lmb_reserve(base, bootm_size - size); + } + +#ifdef CONFIG_MP + cpu_mp_lmb_reserve(); +#endif + } + + if (IS_ENABLED(CONFIG_FSL_CAAM)) { + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize caam_jr: %d\n", ret); + } + + return 0; +} diff --git a/lib/Kconfig b/lib/Kconfig index 6a9338390a..e352b5550a 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -1102,6 +1102,7 @@ config LMB bool "Enable the logical memory blocks library (lmb)" default y if ARC || ARM || M68K || MICROBLAZE || MIPS || \ NIOS2 || PPC || RISCV || SANDBOX || SH || X86 || XTENSA + select ARCH_MISC_INIT if PPC help Support the library logical memory blocks. This will require a malloc() implementation for defining the data structures
All of the current definitions of arch_lmb_reserve() are doing the same thing -- reserve the region of memory occupied by U-Boot, starting from the current stack address to the ram_top. Introduce a function lmb_reserve_uboot_region() which does this, and do away with the arch_lmb_reserve() function.
Instead of using the current value of stack pointer for starting the reserved region, have a fixed value, considering the stack size config value.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V3: * s/16384/SZ_16K in lmb_reserve_uboot_region(). * Fix the corresponding comment for the above change. * Fixed the alignment in lmb_reserve_uboot_region() as suggested by checkpatch.
arch/arc/lib/cache.c | 14 ------- arch/arm/lib/stack.c | 14 ------- arch/m68k/lib/bootm.c | 17 -------- arch/microblaze/lib/bootm.c | 14 ------- arch/mips/lib/bootm.c | 15 ------- arch/nios2/lib/bootm.c | 13 ------ arch/powerpc/lib/bootm.c | 9 ---- arch/riscv/lib/bootm.c | 13 ------ arch/sh/lib/bootm.c | 13 ------ arch/x86/lib/bootm.c | 18 -------- arch/xtensa/lib/bootm.c | 13 ------ include/lmb.h | 2 - lib/lmb.c | 84 ++++++++++++++++++------------------- 13 files changed, 42 insertions(+), 197 deletions(-)
diff --git a/arch/arc/lib/cache.c b/arch/arc/lib/cache.c index 5151af917a..5169fc627f 100644 --- a/arch/arc/lib/cache.c +++ b/arch/arc/lib/cache.c @@ -10,7 +10,6 @@ #include <linux/compiler.h> #include <linux/kernel.h> #include <linux/log2.h> -#include <lmb.h> #include <asm/arcregs.h> #include <asm/arc-bcr.h> #include <asm/cache.h> @@ -820,16 +819,3 @@ void sync_n_cleanup_cache_all(void)
__ic_entire_invalidate(); } - -static ulong get_sp(void) -{ - ulong ret; - - asm("mov %0, sp" : "=r"(ret) : ); - return ret; -} - -void arch_lmb_reserve(void) -{ - arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); -} diff --git a/arch/arm/lib/stack.c b/arch/arm/lib/stack.c index 87d5c962d7..2b21ec0734 100644 --- a/arch/arm/lib/stack.c +++ b/arch/arm/lib/stack.c @@ -11,7 +11,6 @@ * Marius Groeger mgroeger@sysgo.de */ #include <init.h> -#include <lmb.h> #include <asm/global_data.h>
DECLARE_GLOBAL_DATA_PTR; @@ -33,16 +32,3 @@ int arch_reserve_stacks(void)
return 0; } - -static ulong get_sp(void) -{ - ulong ret; - - asm("mov %0, sp" : "=r"(ret) : ); - return ret; -} - -void arch_lmb_reserve(void) -{ - arch_lmb_reserve_generic(get_sp(), gd->ram_top, 16384); -} diff --git a/arch/m68k/lib/bootm.c b/arch/m68k/lib/bootm.c index aee95f1e18..3dcff8076e 100644 --- a/arch/m68k/lib/bootm.c +++ b/arch/m68k/lib/bootm.c @@ -9,7 +9,6 @@ #include <command.h> #include <env.h> #include <image.h> -#include <lmb.h> #include <log.h> #include <asm/global_data.h> #include <u-boot/zlib.h> @@ -27,14 +26,8 @@ DECLARE_GLOBAL_DATA_PTR; #define LINUX_MAX_ENVS 256 #define LINUX_MAX_ARGS 256
-static ulong get_sp (void); static void set_clocks_in_mhz (struct bd_info *kbd);
-void arch_lmb_reserve(void) -{ - arch_lmb_reserve_generic(get_sp(), gd->ram_top, 1024); -} - int do_bootm_linux(int flag, struct bootm_info *bmi) { struct bootm_headers *images = bmi->images; @@ -88,16 +81,6 @@ error: return 1; }
-static ulong get_sp (void) -{ - ulong sp; - - asm("movel %%a7, %%d0\n" - "movel %%d0, %0\n": "=d"(sp): :"%d0"); - - return sp; -} - static void set_clocks_in_mhz (struct bd_info *kbd) { char *s; diff --git a/arch/microblaze/lib/bootm.c b/arch/microblaze/lib/bootm.c index ce96bca28f..4879a41aab 100644 --- a/arch/microblaze/lib/bootm.c +++ b/arch/microblaze/lib/bootm.c @@ -15,7 +15,6 @@ #include <fdt_support.h> #include <hang.h> #include <image.h> -#include <lmb.h> #include <log.h> #include <asm/cache.h> #include <asm/global_data.h> @@ -24,19 +23,6 @@
-static ulong get_sp(void) -{ - ulong ret; - - asm("addik %0, r1, 0" : "=r"(ret) : ); - return ret; -} - -void arch_lmb_reserve(void) -{ - arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); -} - static void boot_jump_linux(struct bootm_headers *images, int flag) { void (*thekernel)(char *cmdline, ulong rd, ulong dt); diff --git a/arch/mips/lib/bootm.c b/arch/mips/lib/bootm.c index 8fb3a3923f..8719510002 100644 --- a/arch/mips/lib/bootm.c +++ b/arch/mips/lib/bootm.c @@ -9,7 +9,6 @@ #include <env.h> #include <image.h> #include <fdt_support.h> -#include <lmb.h> #include <log.h> #include <asm/addrspace.h> #include <asm/global_data.h> @@ -28,20 +27,6 @@ static char **linux_env; static char *linux_env_p; static int linux_env_idx;
-static ulong arch_get_sp(void) -{ - ulong ret; - - __asm__ __volatile__("move %0, $sp" : "=r"(ret) : ); - - return ret; -} - -void arch_lmb_reserve(void) -{ - arch_lmb_reserve_generic(arch_get_sp(), gd->ram_top, 4096); -} - static void linux_cmdline_init(void) { linux_argc = 1; diff --git a/arch/nios2/lib/bootm.c b/arch/nios2/lib/bootm.c index d33d45d28f..71319839ba 100644 --- a/arch/nios2/lib/bootm.c +++ b/arch/nios2/lib/bootm.c @@ -64,16 +64,3 @@ int do_bootm_linux(int flag, struct bootm_info *bmi)
return 1; } - -static ulong get_sp(void) -{ - ulong ret; - - asm("mov %0, sp" : "=r"(ret) : ); - return ret; -} - -void arch_lmb_reserve(void) -{ - arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); -} diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index 8f21cdb0a5..dc44bf3ab3 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -36,7 +36,6 @@
-static ulong get_sp (void); extern void ft_fixup_num_cores(void *blob); static void set_clocks_in_mhz (struct bd_info *kbd);
@@ -210,14 +209,6 @@ int do_bootm_linux(int flag, struct bootm_info *bmi) return 0; }
-static ulong get_sp (void) -{ - ulong sp; - - asm( "mr %0,1": "=r"(sp) : ); - return sp; -} - static void set_clocks_in_mhz (struct bd_info *kbd) { char *s; diff --git a/arch/riscv/lib/bootm.c b/arch/riscv/lib/bootm.c index bbf62f9e05..82502972ee 100644 --- a/arch/riscv/lib/bootm.c +++ b/arch/riscv/lib/bootm.c @@ -133,16 +133,3 @@ int do_bootm_vxworks(int flag, struct bootm_info *bmi) { return do_bootm_linux(flag, bmi); } - -static ulong get_sp(void) -{ - ulong ret; - - asm("mv %0, sp" : "=r"(ret) : ); - return ret; -} - -void arch_lmb_reserve(void) -{ - arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); -} diff --git a/arch/sh/lib/bootm.c b/arch/sh/lib/bootm.c index 44ac05988c..bb0f59e0aa 100644 --- a/arch/sh/lib/bootm.c +++ b/arch/sh/lib/bootm.c @@ -101,16 +101,3 @@ int do_bootm_linux(int flag, struct bootm_info *bmi) /* does not return */ return 1; } - -static ulong get_sp(void) -{ - ulong ret; - - asm("mov r15, %0" : "=r"(ret) : ); - return ret; -} - -void arch_lmb_reserve(void) -{ - arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); -} diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index 114b31012e..55f581836d 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -253,21 +253,3 @@ int do_bootm_linux(int flag, struct bootm_info *bmi)
return boot_jump_linux(images); } - -static ulong get_sp(void) -{ - ulong ret; - -#if CONFIG_IS_ENABLED(X86_64) - asm("mov %%rsp, %0" : "=r"(ret) : ); -#else - asm("mov %%esp, %0" : "=r"(ret) : ); -#endif - - return ret; -} - -void arch_lmb_reserve(void) -{ - arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); -} diff --git a/arch/xtensa/lib/bootm.c b/arch/xtensa/lib/bootm.c index bdbd6d4692..2958f20739 100644 --- a/arch/xtensa/lib/bootm.c +++ b/arch/xtensa/lib/bootm.c @@ -197,16 +197,3 @@ int do_bootm_linux(int flag, struct bootm_info *bmi)
return 1; } - -static ulong get_sp(void) -{ - ulong ret; - - asm("mov %0, a1" : "=r"(ret) : ); - return ret; -} - -void arch_lmb_reserve(void) -{ - arch_lmb_reserve_generic(get_sp(), gd->ram_top, 4096); -} diff --git a/include/lmb.h b/include/lmb.h index 2f155d706e..fb1a6db8e2 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -108,8 +108,6 @@ void lmb_dump_all(void); void lmb_dump_all_force(void);
void board_lmb_reserve(void); -void arch_lmb_reserve(void); -void arch_lmb_reserve_generic(ulong sp, ulong end, ulong align);
struct lmb *lmb_get(void); int lmb_push(struct lmb *store); diff --git a/lib/lmb.c b/lib/lmb.c index 686988e34f..dbbc19ede9 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -18,6 +18,7 @@ #include <asm/global_data.h> #include <asm/sections.h> #include <linux/kernel.h> +#include <linux/sizes.h>
@@ -147,42 +148,6 @@ static void lmb_fix_over_lap_regions(struct alist *lmb_rgn_lst, lmb_remove_region(lmb_rgn_lst, r2); }
-void arch_lmb_reserve_generic(ulong sp, ulong end, ulong align) -{ - ulong bank_end; - int bank; - - /* - * Reserve memory from aligned address below the bottom of U-Boot stack - * until end of U-Boot area using LMB to prevent U-Boot from overwriting - * that memory. - */ - debug("## Current stack ends at 0x%08lx ", sp); - - /* adjust sp by 4K to be safe */ - sp -= align; - for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { - if (!gd->bd->bi_dram[bank].size || - sp < gd->bd->bi_dram[bank].start) - continue; - /* Watch out for RAM at end of address space! */ - bank_end = gd->bd->bi_dram[bank].start + - gd->bd->bi_dram[bank].size - 1; - if (sp > bank_end) - continue; - if (bank_end > end) - bank_end = end - 1; - - lmb_reserve_flags(sp, bank_end - sp + 1, LMB_NOOVERWRITE); - - if (gd->flags & GD_FLG_SKIP_RELOC) - lmb_reserve_flags((phys_addr_t)(uintptr_t)_start, - gd->mon_len, LMB_NOOVERWRITE); - - break; - } -} - /** * efi_lmb_reserve() - add reservations for EFI memory * @@ -215,10 +180,50 @@ static __maybe_unused int efi_lmb_reserve(void) return 0; }
+static void lmb_reserve_uboot_region(void) +{ + int bank; + ulong end, bank_end; + phys_addr_t rsv_start; + + rsv_start = gd->start_addr_sp - CONFIG_STACK_SIZE; + end = gd->ram_top; + + /* + * Reserve memory from aligned address below the bottom of U-Boot stack + * until end of RAM area to prevent LMB from overwriting that memory. + */ + debug("## Current stack ends at 0x%08lx ", (ulong)rsv_start); + + /* adjust sp by 16K to be safe */ + rsv_start -= SZ_16K; + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { + if (!gd->bd->bi_dram[bank].size || + rsv_start < gd->bd->bi_dram[bank].start) + continue; + /* Watch out for RAM at end of address space! */ + bank_end = gd->bd->bi_dram[bank].start + + gd->bd->bi_dram[bank].size - 1; + if (rsv_start > bank_end) + continue; + if (bank_end > end) + bank_end = end - 1; + + lmb_reserve_flags(rsv_start, bank_end - rsv_start + 1, + LMB_NOOVERWRITE); + + if (gd->flags & GD_FLG_SKIP_RELOC) + lmb_reserve_flags((phys_addr_t)(uintptr_t)_start, + gd->mon_len, LMB_NOOVERWRITE); + + break; + } +} + static void lmb_reserve_common(void *fdt_blob) { - arch_lmb_reserve(); board_lmb_reserve(); + lmb_reserve_uboot_region();
if (CONFIG_IS_ENABLED(OF_LIBFDT) && fdt_blob) boot_fdt_add_mem_rsv_regions(fdt_blob); @@ -690,11 +695,6 @@ __weak void board_lmb_reserve(void) /* please define platform specific board_lmb_reserve() */ }
-__weak void arch_lmb_reserve(void) -{ - /* please define platform specific arch_lmb_reserve() */ -} - static int lmb_setup(void) { bool ret;
Changes since V3:
- s/16384/SZ_16K in lmb_reserve_uboot_region().
- Fix the corresponding comment for the above change.
- Fixed the alignment in lmb_reserve_uboot_region() as suggested by checkpatch.
ulong ret;
return ret;
- Marius Groeger mgroeger@sysgo.de
ulong ret;
return ret;
ulong sp;
return sp;
ulong ret;
return ret;
ulong ret;
return ret;
return 1;
ulong ret;
return ret;
ulong sp;
return sp;
ulong ret;
return ret;
ulong ret;
return ret;
ulong ret;
-#else
-#endif
return ret;
return 1;
ulong ret;
return ret;
ulong bank_end;
int bank;
* that memory.
sp -= align;
continue;
if (sp > bank_end)
continue;
if (bank_end > end)
bank_end = end - 1;
break;
- efi_lmb_reserve() - add reservations for EFI memory
int bank;
end = gd->ram_top;
continue;
continue;
if (bank_end > end)
bank_end = end - 1;
LMB_NOOVERWRITE);
break;
lmb_reserve_uboot_region(); if (CONFIG_IS_ENABLED(OF_LIBFDT) && fdt_blob) boot_fdt_add_mem_rsv_regions(fdt_blob);
static int lmb_setup(void) { bool ret; -- 2.34.1
Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org
The board_lmb_reserve() function is not being used, and currently there is only an empty weak function defined. Remove this unused function.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since V3: None
include/lmb.h | 2 -- lib/lmb.c | 6 ------ 2 files changed, 8 deletions(-)
diff --git a/include/lmb.h b/include/lmb.h index fb1a6db8e2..fc2daaa7bf 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -107,8 +107,6 @@ long lmb_free(phys_addr_t base, phys_size_t size); void lmb_dump_all(void); void lmb_dump_all_force(void);
-void board_lmb_reserve(void); - struct lmb *lmb_get(void); int lmb_push(struct lmb *store); void lmb_pop(struct lmb *store); diff --git a/lib/lmb.c b/lib/lmb.c index dbbc19ede9..9f1bb5ec7d 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -222,7 +222,6 @@ static void lmb_reserve_uboot_region(void)
static void lmb_reserve_common(void *fdt_blob) { - board_lmb_reserve(); lmb_reserve_uboot_region();
if (CONFIG_IS_ENABLED(OF_LIBFDT) && fdt_blob) @@ -690,11 +689,6 @@ int lmb_is_reserved_flags(phys_addr_t addr, int flags) return 0; }
-__weak void board_lmb_reserve(void) -{ - /* please define platform specific board_lmb_reserve() */ -} - static int lmb_setup(void) { bool ret;
The TCG event log buffer is being set at the end of ram memory. This region of memory is to be reserved as LMB_NOMAP memory in the LMB memory map. The current location of this buffer overlaps with the memory region reserved for the U-Boot image, which is at the top of the usable memory. This worked earlier as the LMB memory map was not global but caller specific, but fails now because of the overlap.
Move the TCG event log buffer to the start of the ram memory region instead. Move the location of the early trace buffer and the load buffer for U-Boot(spl boot) accordingly.
arch/sandbox/dts/test.dts | 2 +- configs/sandbox_spl_defconfig | 2 +- doc/arch/sandbox/sandbox.rst | 5 +++-- lib/Kconfig | 2 +- 4 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 5fb5eac862..8412506c17 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -78,7 +78,7 @@
event_log: tcg_event_log { no-map; - reg = <(CFG_SYS_SDRAM_SIZE - 0x2000) 0x2000>; + reg = <(CFG_SYS_SDRAM_BASE + 0x100000) 0x2000>; }; };
diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index f7b92dc844..826a82d092 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -1,4 +1,4 @@ -CONFIG_TEXT_BASE=0x200000 +CONFIG_TEXT_BASE=0x400000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/doc/arch/sandbox/sandbox.rst b/doc/arch/sandbox/sandbox.rst index 5f8db12665..4967551724 100644 --- a/doc/arch/sandbox/sandbox.rst +++ b/doc/arch/sandbox/sandbox.rst @@ -662,7 +662,8 @@ Addr Config Usage b000 CONFIG_BLOBLIST_ADDR Blob list 10000 CFG_MALLOC_F_ADDR Early memory allocation f0000 CONFIG_PRE_CON_BUF_ADDR Pre-console buffer - 100000 CONFIG_TRACE_EARLY_ADDR Early trace buffer (if enabled). Also used + 100000 TCG Event log TCG Event Log + 200000 CONFIG_TRACE_EARLY_ADDR Early trace buffer (if enabled). Also used as the SPL load buffer in spl_test_load(). - 200000 CONFIG_TEXT_BASE Load buffer for U-Boot (sandbox_spl only) + 400000 CONFIG_TEXT_BASE Load buffer for U-Boot (sandbox_spl only) ======= ======================== =============================== diff --git a/lib/Kconfig b/lib/Kconfig index e352b5550a..5f282ecb54 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -403,7 +403,7 @@ config TRACE_EARLY_CALL_DEPTH_LIMIT config TRACE_EARLY_ADDR hex "Address of early trace buffer in U-Boot" depends on TRACE_EARLY - default 0x00100000 + default 0x00200000 help Sets the address of the early trace buffer in U-Boot. This memory must be accessible before relocation.
The spl_board_init() function on sandbox invokes the unit tests. Invoking the tests should be done once the rest of the system has been initialised. Call the spl_board_init() function at the very end, once the rest of the initilisation functions have been called, including the setting up of the LMB memory map.
common/spl/spl.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index ad2dc6a908..c3a4424072 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -711,9 +711,6 @@ void board_init_r(gd_t *dummy1, ulong dummy2) if (CONFIG_IS_ENABLED(SOC_INIT)) spl_soc_init();
- if (CONFIG_IS_ENABLED(BOARD_INIT)) - spl_board_init(); - if (IS_ENABLED(CONFIG_SPL_WATCHDOG) && CONFIG_IS_ENABLED(WDT)) initr_watchdog();
@@ -731,6 +728,9 @@ void board_init_r(gd_t *dummy1, ulong dummy2) /* Don't fail. We still can try other boot methods. */ }
+ if (CONFIG_IS_ENABLED(BOARD_INIT)) + spl_board_init(); + bootcount_inc();
/* Dump driver model states to aid analysis */
Initialise the ram bank information for sandbox in SPL. The ram bank information gets initialised as part of the SPL initialisation sequence in board_init_r(), which is then used for adding available memory to the LMB memory map.
arch/sandbox/cpu/spl.c | 13 +++++++++---- 1 file changed, 9 insertions(+), 4 deletions(-)
diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index cc46965b73..1c33a520c6 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -127,6 +127,15 @@ static int load_from_image(struct spl_image_info *spl_image, } SPL_LOAD_IMAGE_METHOD("sandbox_image", 7, BOOT_DEVICE_BOARD, load_from_image);
+int dram_init_banksize(void) +{ + /* These are necessary so TFTP can use LMBs to check its load address */ + gd->bd->bi_dram[0].start = gd->ram_base; + gd->bd->bi_dram[0].size = get_effective_memsize(); + + return 0; +} + void spl_board_init(void) { struct sandbox_state *state = state_get_current(); @@ -134,10 +143,6 @@ void spl_board_init(void) if (!CONFIG_IS_ENABLED(UNIT_TEST)) return;
- /* These are necessary so TFTP can use LMBs to check its load address */ - gd->bd->bi_dram[0].start = gd->ram_base; - gd->bd->bi_dram[0].size = get_effective_memsize(); - if (state->run_unittests) { struct unit_test *tests = UNIT_TEST_ALL_START(); const int count = UNIT_TEST_ALL_COUNT();
Enable the LMB config in SPL. This helps in testing the LMB code in SPL on sandbox.
configs/sandbox_noinst_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/sandbox_noinst_defconfig b/configs/sandbox_noinst_defconfig index bfd95e2398..eb0f064ad2 100644 --- a/configs/sandbox_noinst_defconfig +++ b/configs/sandbox_noinst_defconfig @@ -286,3 +286,4 @@ CONFIG_UNIT_TEST=y CONFIG_SPL_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_SPL_LMB=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 826a82d092..bc6a430fa3 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -253,3 +253,4 @@ CONFIG_UNIT_TEST=y CONFIG_SPL_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_SPL_LMB=y
The sandbox iommu driver uses the LMB module to allocate a particular range of memory for the device virtual address(DVA). This used to work earlier since the LMB memory map was caller specific and not global. But with the change to make the LMB allocations global and persistent, adding this memory range has other side effects. On the other hand, the sandbox iommu test expects to see this particular value of the DVA. Use the DVA address directly, instead of mapping it in the LMB memory map, and then have it allocated.
arch/sandbox/include/asm/test.h | 4 ++++ drivers/iommu/sandbox_iommu.c | 25 ++++++------------------- 2 files changed, 10 insertions(+), 19 deletions(-)
diff --git a/arch/sandbox/include/asm/test.h b/arch/sandbox/include/asm/test.h index 17159f8d67..0e8d19ce23 100644 --- a/arch/sandbox/include/asm/test.h +++ b/arch/sandbox/include/asm/test.h @@ -49,6 +49,10 @@ struct unit_test_state; #define PCI_EA_BAR2_MAGIC 0x72727272 #define PCI_EA_BAR4_MAGIC 0x74747474
+/* Used by the sandbox iommu driver */ +#define SANDBOX_IOMMU_DVA_ADDR 0x89abc000 +#define SANDBOX_IOMMU_PAGE_SIZE SZ_4K + enum { SANDBOX_IRQN_PEND = 1, /* Interrupt number for 'pending' test */ }; diff --git a/drivers/iommu/sandbox_iommu.c b/drivers/iommu/sandbox_iommu.c index 5b4a6a8982..c5eefec218 100644 --- a/drivers/iommu/sandbox_iommu.c +++ b/drivers/iommu/sandbox_iommu.c @@ -5,23 +5,20 @@
#include <dm.h> #include <iommu.h> -#include <lmb.h> #include <asm/io.h> +#include <asm/test.h> #include <linux/sizes.h>
-#define IOMMU_PAGE_SIZE SZ_4K - static dma_addr_t sandbox_iommu_map(struct udevice *dev, void *addr, size_t size) { phys_addr_t paddr, dva; phys_size_t psize, off;
- paddr = ALIGN_DOWN(virt_to_phys(addr), IOMMU_PAGE_SIZE); + paddr = ALIGN_DOWN(virt_to_phys(addr), SANDBOX_IOMMU_PAGE_SIZE); off = virt_to_phys(addr) - paddr; - psize = ALIGN(size + off, IOMMU_PAGE_SIZE); - - dva = lmb_alloc(psize, IOMMU_PAGE_SIZE); + psize = ALIGN(size + off, SANDBOX_IOMMU_PAGE_SIZE); + dva = (phys_addr_t)SANDBOX_IOMMU_DVA_ADDR;
return dva + off; } @@ -32,11 +29,9 @@ static void sandbox_iommu_unmap(struct udevice *dev, dma_addr_t addr, phys_addr_t dva; phys_size_t psize;
- dva = ALIGN_DOWN(addr, IOMMU_PAGE_SIZE); + dva = ALIGN_DOWN(addr, SANDBOX_IOMMU_PAGE_SIZE); psize = size + (addr - dva); - psize = ALIGN(psize, IOMMU_PAGE_SIZE); - - lmb_free(dva, psize); + psize = ALIGN(psize, SANDBOX_IOMMU_PAGE_SIZE); }
static struct iommu_ops sandbox_iommu_ops = { @@ -44,13 +39,6 @@ static struct iommu_ops sandbox_iommu_ops = { .unmap = sandbox_iommu_unmap, };
-static int sandbox_iommu_probe(struct udevice *dev) -{ - lmb_add(0x89abc000, SZ_16K); - - return 0; -} - static const struct udevice_id sandbox_iommu_ids[] = { { .compatible = "sandbox,iommu" }, { /* sentinel */ } @@ -61,5 +49,4 @@ U_BOOT_DRIVER(sandbox_iommu) = { .id = UCLASS_IOMMU, .of_match = sandbox_iommu_ids, .ops = &sandbox_iommu_ops, - .probe = sandbox_iommu_probe, };
The LMB memory is typically not needed very early in the platform's boot. Do not add memory to the LMB map before relocation. Reservation of common areas and adding of memory is done after relocation.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V3: None
board/xilinx/common/board.c | 31 ------------------------------- 1 file changed, 31 deletions(-)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index f04c92a70f..3440402ab4 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -12,7 +12,6 @@ #include <image.h> #include <init.h> #include <jffs2/load_kernel.h> -#include <lmb.h> #include <log.h> #include <asm/global_data.h> #include <asm/sections.h> @@ -665,36 +664,6 @@ int embedded_dtb_select(void) } #endif
-#if IS_ENABLED(CONFIG_LMB) - -#ifndef MMU_SECTION_SIZE -#define MMU_SECTION_SIZE (1 * 1024 * 1024) -#endif - -phys_addr_t board_get_usable_ram_top(phys_size_t total_size) -{ - phys_size_t size; - phys_addr_t reg; - - if (!total_size) - return gd->ram_top; - - if (!IS_ALIGNED((ulong)gd->fdt_blob, 0x8)) - panic("Not 64bit aligned DT location: %p\n", gd->fdt_blob); - - /* found enough not-reserved memory to relocated U-Boot */ - lmb_add(gd->ram_base, gd->ram_size); - boot_fdt_add_mem_rsv_regions((void *)gd->fdt_blob); - size = ALIGN(CONFIG_SYS_MALLOC_LEN + total_size, MMU_SECTION_SIZE); - reg = lmb_alloc(size, MMU_SECTION_SIZE); - - if (!reg) - reg = gd->ram_top - size; - - return reg + size; -} -#endif - #ifdef CONFIG_OF_BOARD_SETUP #define MAX_RAND_SIZE 8 int ft_board_setup(void *blob, struct bd_info *bd)
The optee_get_reserved_memory() function returns the OP-TEE base address and size. The function gets these values from the FDT. Currently, this function is defined only to be called in the SPL phase. Move this function to a place where it can be invoked from the main U-Boot phase, where it will be used to compute the ram_top address.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V3: * s/uint32_t/u32 in optee_get_reserved_memory() as suggested by checkpatch.
arch/arm/mach-stm32mp/dram_init.c | 17 +++++++++++++++++ arch/arm/mach-stm32mp/include/mach/stm32mp.h | 11 +++++++++++ arch/arm/mach-stm32mp/stm32mp1/spl.c | 17 +---------------- 3 files changed, 29 insertions(+), 16 deletions(-) create mode 100644 arch/arm/mach-stm32mp/include/mach/stm32mp.h
diff --git a/arch/arm/mach-stm32mp/dram_init.c b/arch/arm/mach-stm32mp/dram_init.c index e8b0a38be1..286791be2e 100644 --- a/arch/arm/mach-stm32mp/dram_init.c +++ b/arch/arm/mach-stm32mp/dram_init.c @@ -14,9 +14,26 @@ #include <ram.h> #include <asm/global_data.h> #include <asm/system.h> +#include <mach/stm32mp.h>
+int optee_get_reserved_memory(u32 *start, u32 *size) +{ + fdt_addr_t fdt_mem_size; + fdt_addr_t fdt_start; + ofnode node; + + node = ofnode_path("/reserved-memory/optee"); + if (!ofnode_valid(node)) + return -ENOENT; + + fdt_start = ofnode_get_addr_size(node, "reg", &fdt_mem_size); + *start = fdt_start; + *size = fdt_mem_size; + return (fdt_start < 0) ? fdt_start : 0; +} + int dram_init(void) { struct ram_info ram; diff --git a/arch/arm/mach-stm32mp/include/mach/stm32mp.h b/arch/arm/mach-stm32mp/include/mach/stm32mp.h new file mode 100644 index 0000000000..506a42559b --- /dev/null +++ b/arch/arm/mach-stm32mp/include/mach/stm32mp.h @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause */ +/* + * Copyright (C) 2024, STMicroelectronics - All Rights Reserved + */ + +#ifndef __MACH_STM32MP_H_ +#define __MACH_STM32MP_H_ + +int optee_get_reserved_memory(u32 *start, u32 *size); + +#endif diff --git a/arch/arm/mach-stm32mp/stm32mp1/spl.c b/arch/arm/mach-stm32mp/stm32mp1/spl.c index 6eae5c2f55..9c4fafbf47 100644 --- a/arch/arm/mach-stm32mp/stm32mp1/spl.c +++ b/arch/arm/mach-stm32mp/stm32mp1/spl.c @@ -18,6 +18,7 @@ #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <mach/tzc.h> +#include <mach/stm32mp.h> #include <linux/libfdt.h>
u32 spl_boot_device(void) @@ -110,22 +111,6 @@ uint32_t stm32mp_get_dram_size(void) return ram.size; }
-static int optee_get_reserved_memory(uint32_t *start, uint32_t *size) -{ - fdt_addr_t fdt_mem_size; - fdt_addr_t fdt_start; - ofnode node; - - node = ofnode_path("/reserved-memory/optee"); - if (!ofnode_valid(node)) - return -ENOENT; - - fdt_start = ofnode_get_addr_size(node, "reg", &fdt_mem_size); - *start = fdt_start; - *size = fdt_mem_size; - return (fdt_start < 0) ? fdt_start : 0; -} - #define CFG_SHMEM_SIZE 0x200000 #define STM32_TZC_NSID_ALL 0xffff #define STM32_TZC_FILTER_ALL 3
The value of ram_top address currently gets computed in an indirect manner. The boot_fdt_add_mem_rsv_regions() function gets called first to reserve the memory region occupied by OP-TEE in the LMB memory map. This is followed by a call to the lmb_alloc() API, which returns an address which is below the OP-TEE base address. This address is the value of ram_top returned by the board_get_usable_ram_top() function.
This has now changed, as the LMB memory map, which is no longer local, gets set up after relocation. Get the OP-TEE base address by reading the device tree, and set the ram_top from this value.
arch/arm/mach-stm32mp/dram_init.c | 14 +++++--------- 1 file changed, 5 insertions(+), 9 deletions(-)
diff --git a/arch/arm/mach-stm32mp/dram_init.c b/arch/arm/mach-stm32mp/dram_init.c index 286791be2e..198785353f 100644 --- a/arch/arm/mach-stm32mp/dram_init.c +++ b/arch/arm/mach-stm32mp/dram_init.c @@ -62,8 +62,10 @@ int dram_init(void)
phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { + int ret; phys_size_t size; phys_addr_t reg; + u32 optee_start, optee_size;
if (!total_size) return gd->ram_top; @@ -73,16 +75,10 @@ phys_addr_t board_get_usable_ram_top(phys_size_t total_size) * if the effective available memory is bigger */ gd->ram_top = clamp_val(gd->ram_top, 0, SZ_4G - 1); + size = ALIGN(SZ_8M + CONFIG_SYS_MALLOC_LEN + total_size, MMU_SECTION_SIZE);
- /* found enough not-reserved memory to relocated U-Boot */ - lmb_add(gd->ram_base, gd->ram_top - gd->ram_base); - boot_fdt_add_mem_rsv_regions((void *)gd->fdt_blob); - /* add 8M for reserved memory for display, fdt, gd,... */ - size = ALIGN(SZ_8M + CONFIG_SYS_MALLOC_LEN + total_size, MMU_SECTION_SIZE), - reg = lmb_alloc(size, MMU_SECTION_SIZE); - - if (!reg) - reg = gd->ram_top - size; + ret = optee_get_reserved_memory(&optee_start, &optee_size); + reg = (!ret ? optee_start : gd->ram_top) - size;
/* before relocation, mark the U-Boot memory as cacheable by default */ if (!(gd->flags & GD_FLG_RELOC))
Instead of printing the LMB flags as numerical values, print them as strings. This makes it easier to understand what flags are associated with the lmb region. Also make corresponding changes to the bdinfo command's test code.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V3: * Put the tertiary expression in the puts() function call as suggested by Simon Glass. * s/uin64_t/u64 in lmb_print_region_flags() as suggested by checkpatch.
lib/lmb.c | 18 ++++++++++++++++-- 1 file changed, 16 insertions(+), 2 deletions(-)
diff --git a/lib/lmb.c b/lib/lmb.c index 9f1bb5ec7d..3ed570fb29 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -27,6 +27,19 @@ DECLARE_GLOBAL_DATA_PTR;
static struct lmb lmb;
+static void lmb_print_region_flags(enum lmb_flags flags) +{ + u64 bitpos; + const char *flag_str[] = { "none", "no-map", "no-overwrite" }; + + do { + bitpos = flags ? fls(flags) - 1 : 0; + printf("%s", flag_str[bitpos]); + flags &= ~(1ull << bitpos); + puts(flags ? ", " : "\n"); + } while (flags); +} + static void lmb_dump_region(struct alist *lmb_rgn_lst, char *name) { struct lmb_region *rgn = lmb_rgn_lst->data; @@ -42,8 +55,9 @@ static void lmb_dump_region(struct alist *lmb_rgn_lst, char *name) end = base + size - 1; flags = rgn[i].flags;
- printf(" %s[%d]\t[0x%llx-0x%llx], 0x%08llx bytes flags: %x\n", - name, i, base, end, size, flags); + printf(" %s[%d]\t[0x%llx-0x%llx], 0x%08llx bytes flags: ", + name, i, base, end, size); + lmb_print_region_flags(flags); } }
On Mon, 26 Aug 2024 17:29:13 +0530, Sughosh Ganu wrote:
This is a follow-up from an earlier RFC series [1] for making the LMB and EFI memory allocations work together. This is a non-rfc version with only the LMB part of the patches, for making the LMB memory map global and persistent.
This is part one of a set of patches which aim to have the LMB and EFI memory allocations work together. This requires making the LMB memory map global and persistent, instead of having local, caller specific maps. This is being done keeping in mind the usage of LMB memory by platforms where the same memory region can be used to load multiple different images. What is not allowed is to overwrite memory that has been allocated by the other module, currently the EFI memory module. This is being achieved by introducing a new flag, LMB_NOOVERWRITE, which represents memory which cannot be re-requested once allocated.
participants (5)
Ilias Apalodimas
Janne Grunau
Sughosh Ganu
Vaishnav Achath
