[PATCH] sunxi: Fix serial console for A10s-OLinuXino-MICRO
On this board CONFIG_CONS_INDEX needs to be 1 unlike other sun5i boards. Since this is the default, remove to bogus setting.
Fixes: 7095f8641863 ("sunxi: Convert CONS_INDEX to Kconfig") Signed-off-by: Mark Kettenis kettenis@openbsd.org --- configs/A10s-OLinuXino-M_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 2ac68039b0..37ebeb9c85 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -17,6 +17,5 @@ CONFIG_SYS_I2C_SPEED=400000 CONFIG_MII=y CONFIG_SUN4I_EMAC=y CONFIG_AXP152_POWER=y -CONFIG_CONS_INDEX=2 CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y
Indeed, UART1 is not even configured in the DT, and Olimex' user manual mentions explicitly that UART0 should be used for debug.
Reviewed-by: Andre Przywara andre.przywara@arm.com
Thanks, Andre
Andre Przywara
Mark Kettenis
