[U-Boot] [PATCH 1/4] arm: iproc: add NAND driver
Add support for the iproc NAND, and enable on Cygnus and NSP boards.
Signed-off-by: Jiandong Zheng jdzheng@broadcom.com Signed-off-by: Steve Rae srae@broadcom.com --- There was a previous attempt to implement this "iproc NAND" (see: http://patchwork.ozlabs.org/patch/505399), however, due to the amount of changes required, it seemed better to implement the code in a series of steps. This is the first step, where the "iproc_nand.c" is essentially an empty file (with one function required to allow this commit to build successfully).
arch/arm/include/asm/arch-bcmcygnus/configs.h | 11 +++ arch/arm/include/asm/arch-bcmnsp/configs.h | 11 +++ drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/iproc_nand.c | 11 +++ drivers/mtd/nand/iproc_nand_cygnus.h | 111 +++++++++++++++++++++++++ drivers/mtd/nand/iproc_nand_ns_plus.h | 113 ++++++++++++++++++++++++++ 6 files changed, 258 insertions(+) create mode 100644 drivers/mtd/nand/iproc_nand.c create mode 100644 drivers/mtd/nand/iproc_nand_cygnus.h create mode 100644 drivers/mtd/nand/iproc_nand_ns_plus.h
diff --git a/arch/arm/include/asm/arch-bcmcygnus/configs.h b/arch/arm/include/asm/arch-bcmcygnus/configs.h index 3c07160..3bf7395 100644 --- a/arch/arm/include/asm/arch-bcmcygnus/configs.h +++ b/arch/arm/include/asm/arch-bcmcygnus/configs.h @@ -10,6 +10,7 @@ #include <asm/iproc-common/configs.h>
/* uArchitecture specifics */ +#include <../../../drivers/mtd/nand/iproc_nand_cygnus.h>
/* Serial Info */ /* Post pad 3 bytes after each reg addr */ @@ -33,4 +34,14 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_MII
+/* NAND configuration */ +#define CONFIG_CMD_NAND +#define CONFIG_NAND_IPROC +#define CONFIG_SYS_NAND_IPROC_TIMING_MODE 5 +#define CONFIG_SYS_NAND_BASE 0 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_MAX_NAND_CHIPS 1 +#define CONFIG_SYS_NAND_SELF_INIT +#define CONFIG_SYS_NAND_ONFI_DETECTION + #endif /* __ARCH_CONFIGS_H */ diff --git a/arch/arm/include/asm/arch-bcmnsp/configs.h b/arch/arm/include/asm/arch-bcmnsp/configs.h index 786deae..aeaea6a 100644 --- a/arch/arm/include/asm/arch-bcmnsp/configs.h +++ b/arch/arm/include/asm/arch-bcmnsp/configs.h @@ -10,6 +10,7 @@ #include <asm/iproc-common/configs.h>
/* uArchitecture specifics */ +#include <../../../drivers/mtd/nand/iproc_nand_ns_plus.h>
/* Serial Info */ /* no padding */ @@ -19,4 +20,14 @@ #define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_COM1 0x18000300
+/* NAND configuration */ +#define CONFIG_CMD_NAND +#define CONFIG_NAND_IPROC +#define CONFIG_SYS_NAND_IPROC_TIMING_MODE 5 +#define CONFIG_SYS_NAND_BASE 0 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_MAX_NAND_CHIPS 1 +#define CONFIG_SYS_NAND_SELF_INIT +#define CONFIG_SYS_NAND_ONFI_DETECTION + #endif /* __ARCH_CONFIGS_H */ diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 6fb3718..bb3adbc 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -50,6 +50,7 @@ obj-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o obj-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_nand.o obj-$(CONFIG_NAND_FSL_UPM) += fsl_upm.o obj-$(CONFIG_NAND_FSMC) += fsmc_nand.o +obj-$(CONFIG_NAND_IPROC) += iproc_nand.o obj-$(CONFIG_NAND_JZ4740) += jz4740_nand.o obj-$(CONFIG_NAND_KB9202) += kb9202_nand.o obj-$(CONFIG_NAND_KIRKWOOD) += kirkwood_nand.o diff --git a/drivers/mtd/nand/iproc_nand.c b/drivers/mtd/nand/iproc_nand.c new file mode 100644 index 0000000..74f885a --- /dev/null +++ b/drivers/mtd/nand/iproc_nand.c @@ -0,0 +1,11 @@ +/* + * Copyright 2015 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +void board_nand_init(void) +{ +} diff --git a/drivers/mtd/nand/iproc_nand_cygnus.h b/drivers/mtd/nand/iproc_nand_cygnus.h new file mode 100644 index 0000000..26a00a9 --- /dev/null +++ b/drivers/mtd/nand/iproc_nand_cygnus.h @@ -0,0 +1,111 @@ +/* + * Copyright 2015 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _IPROC_NAND_CYGNUS_H_ +#define _IPROC_NAND_CYGNUS_H_ + +/* + * SoC specific definitions (Cygnus) + */ + +#define REG_NAND_BASE 0x18046000 +#define REG_NAND_IDM_BASE 0xf8105000 + +#define NAND_STRAP_TYPE_MASK 0x000f0000 +#define NAND_STRAP_TYPE_SHIFT 16 +#define NAND_STRAP_PAGE_MASK 0x00300000 +#define NAND_STRAP_PAGE_SHIFT 20 +#define NAND_STRAP_WIDTH_MASK 0x01000000 +#define NAND_STRAP_WIDTH_SHIFT 24 + +#define NAND_STRAP_TYPE_DATA \ +/* sector_1k, ecclevel, spare_size */ \ +{ \ + { 0, 0, 16 }, \ + { 0, 1, 16 }, \ + { 0, 4, 16 }, \ + { 0, 8, 16 }, \ + { 0, 8, 27 }, \ + { 0, 12, 27 }, \ + { 1, 12, 27 }, \ + { 1, 15, 27 }, \ + { 1, 20, 45 } \ +} + +#define NAND_STRAP_PAGE_DATA \ +{ \ + 1024, 2048, 4096, 8192 \ +} + +/* + * iProc NAND timing configurations for ONFI timing modes [0-5] + * + * Clock tick = 10ns + * Multiplier: + * x1: tWP tWH tRP tREH tCLH tALH + * x2: tCS tADL tWB tWHR + */ +#define NAND_TIMING_DATA \ +{ \ + /* ONFI timing mode 0 : */ \ + /* tWC=100ns tWP=50ns tWH=30ns */ \ + /* tRC=100ns tRP=50ns tREH=30ns */ \ + /* tCS=70ns tCLH=20ns tALH=20ns tADL=200ns */ \ + /* tWB=200ns tWHR=120ns tREA=40ns */ \ + { \ + .timing1 = 0x6565435b, \ + .timing2 = 0x00001e85, \ + }, \ + /* ONFI timing mode 1 : */ \ + /* tWC=45 tWP=25ns tWH=15ns */ \ + /* tRC=50 tRP=25ns tREH=15ns */ \ + /* tCS=35ns tCLH=10ns tALH=10ns tADL=100ns */ \ + /* tWB=100ns tWHR=80ns tREA=30ns */ \ + { \ + .timing1 = 0x33333236, \ + .timing2 = 0x00001064, \ + }, \ + /* ONFI timing mode 2 : */ \ + /* tWC=35ns tWP=17ns tWH=15ns */ \ + /* tRC=35ns tRP=17ns tREH=15ns */ \ + /* tCS=25ns tCLH=10ns tALH=10ns tADL=100ns */ \ + /* tWB=100ns tWHR=80ns tREA=25ns */ \ + { \ + .timing1 = 0x32322226, \ + .timing2 = 0x00001063, \ + }, \ + /* ONFI timing mode 3 : */ \ + /* tWC=30ns tWP=15ns tWH=10ns */ \ + /* tRC=30ns tRP=15ns tREH=10ns */ \ + /* tCS=25ns tCLH=5ns tALH=5ns tADL=100ns */ \ + /* tWB=100ns tWHR=60ns tREA=20ns */ \ + { \ + .timing1 = 0x22222126, \ + .timing2 = 0x00001043, \ + }, \ + /* ONFI timing mode 4 : */ \ + /* tWC=25ns tWP=12ns tWH=10ns */ \ + /* tRC=25ns tRP=12ns tREH=10ns */ \ + /* tCS=20ns tCLH=5ns tALH=5ns tADL=70ns */ \ + /* tWB=100ns tWHR=60ns tREA=20ns */ \ + { \ + .timing1 = 0x21212114, \ + .timing2 = 0x00001042, \ + }, \ + /* ONFI timing mode 5 : */ \ + /* tWC=20ns tWP=10ns tWH=7ns */ \ + /* tRC=20ns tRP=10ns tREH=7ns */ \ + /* tCS=15ns tCLH=5ns tALH=5ns tADL=70ns */ \ + /* tWB=100ns tWHR=60ns tREA=16ns */ \ + { \ + .timing1 = 0x11111114, \ + .timing2 = 0x00001042, \ + }, \ +} + +#define NAND_MAX_CS 2 + +#endif /* _IPROC_NAND_CYGNUS_H_ */ diff --git a/drivers/mtd/nand/iproc_nand_ns_plus.h b/drivers/mtd/nand/iproc_nand_ns_plus.h new file mode 100644 index 0000000..41d5da7 --- /dev/null +++ b/drivers/mtd/nand/iproc_nand_ns_plus.h @@ -0,0 +1,113 @@ +/* + * Copyright 2015 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _IPROC_NAND_NS_PLUS_H_ +#define _IPROC_NAND_NS_PLUS_H_ + +/* + * SoC specific definitions (NorthStar Plus) + */ + +#define REG_NAND_BASE 0x18026000 +#define REG_NAND_IDM_BASE 0x1811b000 +#define REG_NAND_STRAPS_BASE 0x1803f2a0 + +#define NAND_STRAP_TYPE_MASK 0x0000f000 +#define NAND_STRAP_TYPE_SHIFT 12 +#define NAND_STRAP_PAGE_MASK 0x00000c00 +#define NAND_STRAP_PAGE_SHIFT 10 +/* No bus width strap */ +#define NAND_STRAP_WIDTH_MASK 0x0 +#define NAND_STRAP_WIDTH_SHIFT 0 + +#define NAND_STRAP_TYPE_DATA \ +/* sector_1k, ecclevel, spare_size */ \ +{ \ + { 0, 0, 16 }, \ + { 0, 15, 16 }, /* Hamming ECC */ \ + { 0, 4, 16 }, \ + { 0, 8, 16 }, \ + { 0, 8, 27 }, \ + { 0, 12, 27 }, \ + { 1, 12, 27 }, \ + { 1, 15, 27 }, \ + { 1, 20, 45 } \ +} + +#define NAND_STRAP_PAGE_DATA \ +{ \ + 2048, 2048, 4096, 8192 \ +} + +/* + * iProc NAND timing configurations for ONFI timing modes [0-5] + * + * Clock tick = 4ns + * Multiplier: + * x1: tWP tWH tRP tREH tCLH tALH + * x4: tCS tADL tWB tWHR + */ +#define NAND_TIMING_DATA \ +{ \ + /* ONFI timing mode 0 : */ \ + /* tWC=100ns tWP=50ns tWH=30ns */ \ + /* tRC=100ns tRP=50ns tREH=30ns */ \ + /* tCS=70ns tCLH=20ns tALH=20ns tADL=200ns */ \ + /* tWB=200ns tWHR=120ns tREA=40ns */ \ + { \ + .timing1 = 0xfafa558d, \ + .timing2 = 0x00001a85, \ + }, \ + /* ONFI timing mode 1 : */ \ + /* tWC=45 tWP=25ns tWH=15ns */ \ + /* tRC=50 tRP=25ns tREH=15ns */ \ + /* tCS=35ns tCLH=10ns tALH=10ns tADL=100ns */ \ + /* tWB=100ns tWHR=80ns tREA=30ns */ \ + { \ + .timing1 = 0x85853347, \ + .timing2 = 0x00000e64, \ + }, \ + /* ONFI timing mode 2 : */ \ + /* tWC=35ns tWP=17ns tWH=15ns */ \ + /* tRC=35ns tRP=17ns tREH=15ns */ \ + /* tCS=25ns tCLH=10ns tALH=10ns tADL=100ns */ \ + /* tWB=100ns tWHR=80ns tREA=25ns */ \ + { \ + .timing1 = 0x54542347, \ + .timing2 = 0x00000e63, \ + }, \ + /* ONFI timing mode 3 : */ \ + /* tWC=30ns tWP=15ns tWH=10ns */ \ + /* tRC=30ns tRP=15ns tREH=10ns */ \ + /* tCS=25ns tCLH=5ns tALH=5ns tADL=100ns */ \ + /* tWB=100ns tWHR=60ns tREA=20ns */ \ + { \ + .timing1 = 0x44442237, \ + .timing2 = 0x00000e43, \ + }, \ + /* ONFI timing mode 4 : */ \ + /* tWC=25ns tWP=12ns tWH=10ns */ \ + /* tRC=25ns tRP=12ns tREH=10ns */ \ + /* tCS=20ns tCLH=5ns tALH=5ns tADL=70ns */ \ + /* tWB=100ns tWHR=60ns tREA=20ns */ \ + { \ + .timing1 = 0x43432235, \ + .timing2 = 0x00000e42, \ + }, \ + /* ONFI timing mode 5 : */ \ + /* tWC=20ns tWP=10ns tWH=7ns */ \ + /* tRC=20ns tRP=10ns tREH=7ns */ \ + /* tCS=15ns tCLH=5ns tALH=5ns tADL=70ns */ \ + /* tWB=100ns tWHR=60ns tREA=16ns */ \ + { \ + .timing1 = 0x32321225, \ + .timing2 = 0x00000e42, \ + }, \ +} + +#define NAND_MAX_CS 1 + +#endif /* _IPROC_NAND_NS_PLUS_H_ */
- add missing declaration - update debug output format specifiers
Signed-off-by: Steve Rae srae@broadcom.com --- the checkpatch warning: warning: cmd/mtdparts.c,1494: quoted string split across lines is for the existing code; it is not introduced with this change...
cmd/mtdparts.c | 4 ++-- include/linux/mtd/mtd.h | 8 ++++++++ 2 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index 86a4689..579eff1 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -1491,7 +1491,7 @@ static int spread_partitions(void) part = list_entry(pentry, struct part_info, link);
debug("spread_partitions: device = %s%d, partition %d =" - " (%s) 0x%08x@0x%08x\n", + " (%s) 0x%08llx@0x%08llx\n", MTD_DEV_TYPE(dev->id->type), dev->id->num, part_num, part->name, part->size, part->offset); @@ -2009,7 +2009,7 @@ static int do_mtdparts(cmd_tbl_t *cmdtp, int flag, int argc,
if (!strcmp(&argv[1][3], ".spread")) { spread_partition(mtd, p, &next_offset); - debug("increased %s to %d bytes\n", p->name, p->size); + debug("increased %s to %llu bytes\n", p->name, p->size); } #endif
diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index 9da77ec..9c36f02 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -495,5 +495,13 @@ int mtd_arg_off(const char *arg, int *idx, loff_t *off, loff_t *size, int mtd_arg_off_size(int argc, char *const argv[], int *idx, loff_t *off, loff_t *size, loff_t *maxsize, int devtype, uint64_t chipsize); + +#ifdef CONFIG_CMD_MTDPARTS_SPREAD +/* drivers/mtd/mtdcore.c */ +void mtd_get_len_incl_bad(struct mtd_info *mtd, uint64_t offset, + const uint64_t length, uint64_t *len_incl_bad, + int *truncated); +#endif /* CONFIG_CMD_MTDPARTS_SPREAD */ + #endif #endif /* __MTD_MTD_H__ */
Enable MTD support on Cygnus and NSP boards.
arch/arm/include/asm/arch-bcmcygnus/configs.h | 6 ++++++ arch/arm/include/asm/arch-bcmnsp/configs.h | 6 ++++++ 2 files changed, 12 insertions(+)
diff --git a/arch/arm/include/asm/arch-bcmcygnus/configs.h b/arch/arm/include/asm/arch-bcmcygnus/configs.h index 3bf7395..40a9f0e 100644 --- a/arch/arm/include/asm/arch-bcmcygnus/configs.h +++ b/arch/arm/include/asm/arch-bcmcygnus/configs.h @@ -44,4 +44,10 @@ #define CONFIG_SYS_NAND_SELF_INIT #define CONFIG_SYS_NAND_ONFI_DETECTION
+/* MTD configuration */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_MTDPARTS_SPREAD + #endif /* __ARCH_CONFIGS_H */ diff --git a/arch/arm/include/asm/arch-bcmnsp/configs.h b/arch/arm/include/asm/arch-bcmnsp/configs.h index aeaea6a..ac4f69e 100644 --- a/arch/arm/include/asm/arch-bcmnsp/configs.h +++ b/arch/arm/include/asm/arch-bcmnsp/configs.h @@ -30,4 +30,10 @@ #define CONFIG_SYS_NAND_SELF_INIT #define CONFIG_SYS_NAND_ONFI_DETECTION
Configure the NAND device, define partition sizes, and create the environment space for Cygnus and NSP boards.
arch/arm/include/asm/arch-bcmcygnus/configs.h | 33 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-bcmnsp/configs.h | 33 +++++++++++++++++++++++++++ include/configs/bcm_ep_board.h | 3 --- 3 files changed, 66 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-bcmcygnus/configs.h b/arch/arm/include/asm/arch-bcmcygnus/configs.h index 40a9f0e..ad94e31 100644 --- a/arch/arm/include/asm/arch-bcmcygnus/configs.h +++ b/arch/arm/include/asm/arch-bcmcygnus/configs.h @@ -44,6 +44,39 @@ #define CONFIG_SYS_NAND_SELF_INIT #define CONFIG_SYS_NAND_ONFI_DETECTION
+/* Configuration for Micron MT29F8G08ABACA */ +#define CONFIG_NAND_CHIPSIZE (1 << 30) /* 1GB */ +#define CONFIG_NAND_BLOCKSIZE (1 << 18) /* 256KB */ +#define CONFIG_NAND_PAGE_SHIFT 12 /* 4KiB */ +#define CONFIG_NAND_BLOCK_SHIFT 18 /* 256 KiB */ + +/* Configure the Environment and the u-boot-env partition */ +#define MTD_PART_BOOT1_SIZE 0x00200000 +#define MTD_PART_GPT_SIZE 0x00100000 +#define MTD_PART_SSB_SIZE 0x00200000 +#define MTD_PART_UBOOT_SIZE 0x00200000 +#define MTD_PART_UBOOT_ENV_SIZE 0x00200000 +#define MTD_PART_DTB_SIZE 0x00100000 +#define MTD_PART_KERNEL_SIZE 0x01000000 +#define MTD_PART_ROOT_SIZE 0x1c000000 +/* + * WARNING: When changing the order of the partitions, make sure you update + * CONFIG_ENV_OFFSET accordingly. + */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_RANGE (2 * CONFIG_NAND_BLOCKSIZE) +#define CONFIG_ENV_OFFSET (MTD_PART_BOOT1_SIZE + MTD_PART_GPT_SIZE + \ + MTD_PART_SSB_SIZE + MTD_PART_UBOOT_SIZE) +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) +/* + * Check that the u-boot-env partition is big enough to accomodate the + * u-boot environment data and its redundant copy + */ +#if ((2 * CONFIG_ENV_RANGE) > MTD_PART_UBOOT_ENV_SIZE) +#error u-boot-env partition size is to small +#endif + /* MTD configuration */ #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS diff --git a/arch/arm/include/asm/arch-bcmnsp/configs.h b/arch/arm/include/asm/arch-bcmnsp/configs.h index ac4f69e..debccc0 100644 --- a/arch/arm/include/asm/arch-bcmnsp/configs.h +++ b/arch/arm/include/asm/arch-bcmnsp/configs.h @@ -30,6 +30,39 @@ #define CONFIG_SYS_NAND_SELF_INIT #define CONFIG_SYS_NAND_ONFI_DETECTION
+/* Configuration for Micron MT29F8G08ABACA */ +#define CONFIG_NAND_CHIPSIZE (1 << 30) /* 1GB */ +#define CONFIG_NAND_BLOCKSIZE (1 << 18) /* 256KB */ +#define CONFIG_NAND_PAGE_SHIFT 12 /* 4KiB */ +#define CONFIG_NAND_BLOCK_SHIFT 18 /* 256 KiB */ + +/* Configure the Environment and the u-boot-env partition */ +#define MTD_PART_BOOT1_SIZE 0x00200000 +#define MTD_PART_GPT_SIZE 0x00100000 +#define MTD_PART_SSB_SIZE 0x00200000 +#define MTD_PART_UBOOT_SIZE 0x00200000 +#define MTD_PART_UBOOT_ENV_SIZE 0x00200000 +#define MTD_PART_DTB_SIZE 0x00100000 +#define MTD_PART_KERNEL_SIZE 0x01000000 +#define MTD_PART_ROOT_SIZE 0x0c000000 +/* + * WARNING: When changing the order of the partitions, make sure you update + * CONFIG_ENV_OFFSET accordingly. + */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_RANGE (2 * CONFIG_NAND_BLOCKSIZE) +#define CONFIG_ENV_OFFSET (MTD_PART_BOOT1_SIZE + MTD_PART_GPT_SIZE + \ + MTD_PART_SSB_SIZE + MTD_PART_UBOOT_SIZE) +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) +/* + * Check that the u-boot-env partition is big enough to accomodate the + * u-boot environment data and its redundant copy + */ +#if ((2 * CONFIG_ENV_RANGE) > MTD_PART_UBOOT_ENV_SIZE) +#error u-boot-env partition size is to small +#endif + /* MTD configuration */ #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index 1d4869b..fe97a40 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -50,9 +50,6 @@
#define CONFIG_BAUDRATE 115200
-#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_IS_NOWHERE - #define CONFIG_SYS_NO_FLASH /* Not using NAND/NOR unmanaged flash */
/* console configuration */
We need to be adding Kconfig entries here at a minimum.
Is it expected the _every_ CONFIG_* and CONFIG_SYS_* will be moved to Kconfig? What about #defines that will absolutely never used by anyone else? for example, I (may) have a code fragment that distinguishes between "CONFIG_CYGNUS" and "CONFIG_NSPLUS"... Would these need to be Kconfig? or would that just clutter Kconfig with useless entries? Thanks for clarifying!
-- Tom
Well, at some point yes, pretty much everything will be in Kconfig, like the Linux Kernel does. I suppose one way to think of it is that if it's not something that should be configured but is rather a property of the device, it doesn't belong as CONFIG_ it should just be a define in the header. Take a look at the other NAND drivers which have been converted and be at least as converted as they are. More conversions are always appreciated but we have to keep at least a minimal level :) Thanks!
Thanks for this clarification...
-- Tom
I don't see the value of applying a such a do-nothing patch. It's fine to leave out unnecessary features, things that improve performance, etc. but to be applied a patchset should accomplish something useful and correct, not just be a staging area for future patches.
No.
-Scott
Scott Wood
Steve Rae
Steve Rae
