[U-Boot] [PATCH 1/2] sunxi: dts: Sync with kernel
Sync the sunxi dts files with the changes queued up for kernel-4.3 in mripard's sunxi/dt-for-4.3 branch.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/{sun8i-a23.dtsi => axp152.dtsi} | 29 +----- arch/arm/dts/axp209.dtsi | 5 - arch/arm/dts/sun4i-a10-ba10-tvbox.dts | 15 +++ arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts | 34 +++++++ arch/arm/dts/sun4i-a10-cubieboard.dts | 19 ++++ ...oard.dts => sun4i-a10-itead-iteaduino-plus.dts} | 39 ++----- arch/arm/dts/sun4i-a10-mini-xplus.dts | 15 +++ arch/arm/dts/sun4i-a10-olinuxino-lime.dts | 32 ++++++ arch/arm/dts/sun4i-a10.dtsi | 16 ++- arch/arm/dts/sun5i-a10s-olinuxino-micro.dts | 37 ++++++- arch/arm/dts/sun5i-a13-hsg-h702.dts | 58 +++++++++++ arch/arm/dts/sun5i-a13-olinuxino.dts | 37 +++++++ arch/arm/dts/sun5i-a13-utoo-p66.dts | 29 +++++- arch/arm/dts/sun5i.dtsi | 16 ++- arch/arm/dts/sun6i-a31-m9.dts | 2 +- arch/arm/dts/sun6i-a31-mele-a1000g-quad.dts | 5 + arch/arm/dts/sun6i-a31.dtsi | 16 ++- arch/arm/dts/sun6i-a31s-cs908.dts | 5 + arch/arm/dts/sun7i-a20-cubietruck.dts | 56 ++++++++--- arch/arm/dts/sun7i-a20-i12-tvbox.dts | 2 +- arch/arm/dts/sun7i-a20-olinuxino-lime.dts | 32 ++++++ arch/arm/dts/sun7i-a20-olinuxino-micro.dts | 32 ++++++ arch/arm/dts/sun7i-a20.dtsi | 16 ++- arch/arm/dts/sun8i-a23-a33.dtsi | 7 +- arch/arm/dts/sun8i-a23-ippo-q8h-v5.dts | 9 ++ arch/arm/dts/sun8i-a23.dtsi | 33 ++++++ arch/arm/dts/sun8i-a33-ga10h-v1.1.dts | 9 ++ arch/arm/dts/sun8i-a33-ippo-q8h-v1.2.dts | 112 ++++++++++++++++++++- arch/arm/dts/sun8i-a33-sinlinx-sina33.dts | 13 +++ arch/arm/dts/sun8i-a33.dtsi | 33 ++++++ arch/arm/dts/sunxi-common-regulators.dtsi | 2 + 32 files changed, 673 insertions(+), 93 deletions(-) copy arch/arm/dts/{sun8i-a23.dtsi => axp152.dtsi} (79%) copy arch/arm/dts/{sun4i-a10-cubieboard.dts => sun4i-a10-itead-iteaduino-plus.dts} (85%)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ba63553..34346da 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -73,6 +73,7 @@ dtb-$(CONFIG_MACH_SUN4I) += \ sun4i-a10-inet-3f.dtb \ sun4i-a10-inet-3w.dtb \ sun4i-a10-inet97fv2.dtb \ + sun4i-a10-itead-iteaduino-plus.dtb \ sun4i-a10-jesurun-q5.dtb \ sun4i-a10-marsboard.dtb \ sun4i-a10-mini-xplus.dtb \ diff --git a/arch/arm/dts/sun8i-a23.dtsi b/arch/arm/dts/axp152.dtsi similarity index 79% copy from arch/arm/dts/sun8i-a23.dtsi copy to arch/arm/dts/axp152.dtsi index 8698f7a..f90ad6c 100644 --- a/arch/arm/dts/sun8i-a23.dtsi +++ b/arch/arm/dts/axp152.dtsi @@ -1,5 +1,5 @@ /* - * Copyright 2014 Chen-Yu Tsai + * Copyright 2015 Chen-Yu Tsai * * Chen-Yu Tsai wens@csie.org * @@ -42,27 +42,8 @@ * OTHER DEALINGS IN THE SOFTWARE. */
-#include "sun8i-a23-a33.dtsi" - -/ { - memory { - reg = <0x40000000 0x40000000>; - }; - - clocks { - mbus_clk: clk@01c2015c { - #clock-cells = <0>; - compatible = "allwinner,sun8i-a23-mbus-clk"; - reg = <0x01c2015c 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll5>; - clock-output-names = "mbus"; - }; - }; -}; - -&pio { - compatible = "allwinner,sun8i-a23-pinctrl"; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; +&axp152 { + compatible = "x-powers,axp152"; + interrupt-controller; + #interrupt-cells = <1>; }; diff --git a/arch/arm/dts/axp209.dtsi b/arch/arm/dts/axp209.dtsi index c20cf53..24c935c 100644 --- a/arch/arm/dts/axp209.dtsi +++ b/arch/arm/dts/axp209.dtsi @@ -18,11 +18,6 @@ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * - * You should have received a copy of the GNU General Public - * License along with this file; if not, write to the Free - * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - * * Or, alternatively, * * b) Permission is hereby granted, free of charge, to any person diff --git a/arch/arm/dts/sun4i-a10-ba10-tvbox.dts b/arch/arm/dts/sun4i-a10-ba10-tvbox.dts index 93d4356..f3cb297 100644 --- a/arch/arm/dts/sun4i-a10-ba10-tvbox.dts +++ b/arch/arm/dts/sun4i-a10-ba10-tvbox.dts @@ -125,12 +125,21 @@ status = "okay"; };
+&otg_sram { + status = "okay"; +}; + &pio { usb2_vbus_pin_a: usb2_vbus_pin@0 { allwinner,pins = "PH12"; }; };
+®_usb0_vbus { + regulator-boot-on; + status = "okay"; +}; + ®_usb1_vbus { status = "okay"; }; @@ -146,7 +155,13 @@ status = "okay"; };
+&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + &usbphy { + usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_usb1_vbus>; usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; diff --git a/arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts b/arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts index 5878a0b..1430568 100644 --- a/arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts +++ b/arch/arm/dts/sun4i-a10-chuwi-v7-cw0825.dts @@ -114,6 +114,30 @@ status = "okay"; };
+&otg_sram { + status = "okay"; +}; + +&pio { + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PH4"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PH5"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_DOWN>; + }; +}; + +®_usb0_vbus { + status = "okay"; +}; + ®_usb2_vbus { status = "okay"; }; @@ -124,7 +148,17 @@ status = "okay"; };
+&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + &usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; + usb0_id_det-gpio = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH4 */ + usb0_vbus_det-gpio = <&pio 7 5 GPIO_ACTIVE_HIGH>; /* PH5 */ + usb0_vbus-supply = <®_usb0_vbus>; usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; }; diff --git a/arch/arm/dts/sun4i-a10-cubieboard.dts b/arch/arm/dts/sun4i-a10-cubieboard.dts index 9afb4e0..046a84d 100644 --- a/arch/arm/dts/sun4i-a10-cubieboard.dts +++ b/arch/arm/dts/sun4i-a10-cubieboard.dts @@ -155,6 +155,10 @@ status = "okay"; };
+&otg_sram { + status = "okay"; +}; + &pio { led_pins_cubieboard: led_pins@0 { allwinner,pins = "PH20", "PH21"; @@ -162,6 +166,13 @@ allwinner,drive = <SUN4I_PINCTRL_20_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PH4"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; };
®_ahci_5v { @@ -216,7 +227,15 @@ status = "okay"; };
+&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + &usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>; + usb0_id_det-gpio = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH4 */ usb1_vbus-supply = <®_usb1_vbus>; usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; diff --git a/arch/arm/dts/sun4i-a10-cubieboard.dts b/arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts similarity index 85% copy from arch/arm/dts/sun4i-a10-cubieboard.dts copy to arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts index 9afb4e0..985e155 100644 --- a/arch/arm/dts/sun4i-a10-cubieboard.dts +++ b/arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts @@ -1,6 +1,5 @@ /* - * Copyright 2012 Stefan Roese - * Stefan Roese sr@denx.de + * Copyright 2015 Josef Gajdusek atx@atx.name * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual @@ -49,8 +48,8 @@ #include <dt-bindings/pinctrl/sun4i-a10.h>
/ { - model = "Cubietech Cubieboard"; - compatible = "cubietech,a10-cubieboard", "allwinner,sun4i-a10"; + model = "Iteaduino Plus A10"; + compatible = "itead,iteaduino-plus-a10", "allwinner,sun4i-a10";
aliases { serial0 = &uart0; @@ -59,23 +58,6 @@ chosen { stdout-path = "serial0:115200n8"; }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_cubieboard>; - - blue { - label = "cubieboard:blue:usr"; - gpios = <&pio 7 21 GPIO_ACTIVE_HIGH>; /* LED1 */ - }; - - green { - label = "cubieboard:green:usr"; - gpios = <&pio 7 20 GPIO_ACTIVE_HIGH>; /* LED2 */ - linux,default-trigger = "heartbeat"; - }; - }; };
&ahci { @@ -123,6 +105,12 @@ status = "okay"; };
+&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins_a>; + status = "okay"; +}; + &ir0 { pinctrl-names = "default"; pinctrl-0 = <&ir0_rx_pins_a>; @@ -155,15 +143,6 @@ status = "okay"; };
-&pio { - led_pins_cubieboard: led_pins@0 { - allwinner,pins = "PH20", "PH21"; - allwinner,function = "gpio_out"; - allwinner,drive = <SUN4I_PINCTRL_20_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; -}; - ®_ahci_5v { status = "okay"; }; diff --git a/arch/arm/dts/sun4i-a10-mini-xplus.dts b/arch/arm/dts/sun4i-a10-mini-xplus.dts index ebe2a04..a7dd86d 100644 --- a/arch/arm/dts/sun4i-a10-mini-xplus.dts +++ b/arch/arm/dts/sun4i-a10-mini-xplus.dts @@ -114,6 +114,15 @@ status = "okay"; };
+&otg_sram { + status = "okay"; +}; + +®_usb0_vbus { + regulator-boot-on; + status = "okay"; +}; + ®_usb1_vbus { status = "okay"; }; @@ -128,7 +137,13 @@ status = "okay"; };
+&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + &usbphy { + usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_usb1_vbus>; usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; diff --git a/arch/arm/dts/sun4i-a10-olinuxino-lime.dts b/arch/arm/dts/sun4i-a10-olinuxino-lime.dts index b64aa4e..28e32ad 100644 --- a/arch/arm/dts/sun4i-a10-olinuxino-lime.dts +++ b/arch/arm/dts/sun4i-a10-olinuxino-lime.dts @@ -150,6 +150,10 @@ status = "okay"; };
+&otg_sram { + status = "okay"; +}; + &pio { ahci_pwr_pin_olinuxinolime: ahci_pwr_pin@1 { allwinner,pins = "PC3"; @@ -164,6 +168,20 @@ allwinner,drive = <SUN4I_PINCTRL_20_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PH4"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PH5"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_DOWN>; + }; };
®_ahci_5v { @@ -172,6 +190,10 @@ status = "okay"; };
+®_usb0_vbus { + status = "okay"; +}; + ®_usb1_vbus { status = "okay"; }; @@ -186,7 +208,17 @@ status = "okay"; };
+&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + &usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; + usb0_id_det-gpio = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH4 */ + usb0_vbus_det-gpio = <&pio 7 5 GPIO_ACTIVE_HIGH>; /* PH5 */ + usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_usb1_vbus>; usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; diff --git a/arch/arm/dts/sun4i-a10.dtsi b/arch/arm/dts/sun4i-a10.dtsi index 61c03d1..463bacd 100644 --- a/arch/arm/dts/sun4i-a10.dtsi +++ b/arch/arm/dts/sun4i-a10.dtsi @@ -611,6 +611,19 @@ #size-cells = <0>; };
+ usb_otg: usb@01c13000 { + compatible = "allwinner,sun4i-a10-musb"; + reg = <0x01c13000 0x0400>; + clocks = <&ahb_gates 0>; + interrupts = <38>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + allwinner,sram = <&otg_sram 1>; + status = "disabled"; + }; + usbphy: phy@01c13400 { #phy-cells = <1>; compatible = "allwinner,sun4i-a10-usb-phy"; @@ -713,8 +726,7 @@ clocks = <&apb0_gates 5>; gpio-controller; interrupt-controller; - #interrupt-cells = <2>; - #size-cells = <0>; + #interrupt-cells = <3>; #gpio-cells = <3>;
pwm0_pins_a: pwm0@0 { diff --git a/arch/arm/dts/sun5i-a10s-olinuxino-micro.dts b/arch/arm/dts/sun5i-a10s-olinuxino-micro.dts index a7e19e4..5a422c1 100644 --- a/arch/arm/dts/sun5i-a10s-olinuxino-micro.dts +++ b/arch/arm/dts/sun5i-a10s-olinuxino-micro.dts @@ -96,8 +96,15 @@ pinctrl-names = "default"; pinctrl-0 = <&i2c0_pins_a>; status = "okay"; + + axp152: pmic@30 { + reg = <0x30>; + interrupts = <0>; + }; };
+#include "axp152.dtsi" + &i2c1 { pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins_a>; @@ -189,6 +196,10 @@ status = "okay"; };
+&otg_sram { + status = "okay"; +}; + &pio { mmc0_cd_pin_olinuxino_micro: mmc0_cd_pin@0 { allwinner,pins = "PG1"; @@ -217,6 +228,18 @@ allwinner,drive = <SUN4I_PINCTRL_10_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PG12"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; +}; + +®_usb0_vbus { + gpio = <&pio 6 11 GPIO_ACTIVE_HIGH>; /* PG11 */ + status = "okay"; };
®_usb1_vbus { @@ -243,8 +266,20 @@ status = "okay"; };
+&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usb0_vbus_pin_a { + allwinner,pins = "PG11"; +}; + &usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>; + usb0_id_det-gpio = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */ + usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_usb1_vbus>; status = "okay"; }; - diff --git a/arch/arm/dts/sun5i-a13-hsg-h702.dts b/arch/arm/dts/sun5i-a13-hsg-h702.dts index 990f9d6..3724b98 100644 --- a/arch/arm/dts/sun5i-a13-hsg-h702.dts +++ b/arch/arm/dts/sun5i-a13-hsg-h702.dts @@ -45,6 +45,7 @@ #include "sunxi-common-regulators.dtsi"
#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> #include <dt-bindings/pinctrl/sun4i-a10.h>
/ { @@ -96,6 +97,25 @@ status = "okay"; };
+&lradc { + vref-supply = <®_ldo2>; + status = "okay"; + + button@200 { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + channel = <0>; + voltage = <200000>; + }; + + button@400 { + label = "Volume Down"; + linux,code = <KEY_VOLUMEDOWN>; + channel = <0>; + voltage = <400000>; + }; +}; + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_h702>; @@ -110,6 +130,10 @@ status = "okay"; };
+&otg_sram { + status = "okay"; +}; + &pio { mmc0_cd_pin_h702: mmc0_cd_pin@0 { allwinner,pins = "PG0"; @@ -117,6 +141,20 @@ allwinner,drive = <SUN4I_PINCTRL_10_MA>; allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PG2"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PG1"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; };
#include "axp209.dtsi" @@ -152,13 +190,33 @@ regulator-name = "vcc-wifi"; };
+®_usb0_vbus { + pinctrl-0 = <&usb0_vbus_pin_a>; + gpio = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */ + status = "okay"; +}; + &uart1 { pinctrl-names = "default"; pinctrl-0 = <&uart1_pins_b>; status = "okay"; };
+&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usb0_vbus_pin_a { + allwinner,pins = "PG12"; +}; + &usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; + usb0_id_det-gpios = <&pio 6 2 GPIO_ACTIVE_HIGH>; /* PG2 */ + usb0_vbus_det-gpios = <&pio 6 1 GPIO_ACTIVE_HIGH>; /* PG1 */ + usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_ldo3>; status = "okay"; }; diff --git a/arch/arm/dts/sun5i-a13-olinuxino.dts b/arch/arm/dts/sun5i-a13-olinuxino.dts index 4232400..b3c234c 100644 --- a/arch/arm/dts/sun5i-a13-olinuxino.dts +++ b/arch/arm/dts/sun5i-a13-olinuxino.dts @@ -159,6 +159,10 @@ status = "okay"; };
+&otg_sram { + status = "okay"; +}; + &pio { mmc0_cd_pin_olinuxino: mmc0_cd_pin@0 { allwinner,pins = "PG0"; @@ -174,6 +178,20 @@ allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; };
+ usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PG2"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PG1"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_DOWN>; + }; + usb1_vbus_pin_olinuxino: usb1_vbus_pin@0 { allwinner,pins = "PG11"; allwinner,function = "gpio_out"; @@ -182,6 +200,11 @@ }; };
+®_usb0_vbus { + status = "okay"; + gpio = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */ +}; + ®_usb1_vbus { pinctrl-0 = <&usb1_vbus_pin_olinuxino>; gpio = <&pio 6 11 GPIO_ACTIVE_HIGH>; @@ -194,7 +217,21 @@ status = "okay"; };
+&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usb0_vbus_pin_a { + allwinner,pins = "PG12"; +}; + &usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; + usb0_id_det-gpio = <&pio 6 2 GPIO_ACTIVE_HIGH>; /* PG2 */ + usb0_vbus_det-gpio = <&pio 6 1 GPIO_ACTIVE_HIGH>; /* PG1 */ + usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_usb1_vbus>; status = "okay"; }; diff --git a/arch/arm/dts/sun5i-a13-utoo-p66.dts b/arch/arm/dts/sun5i-a13-utoo-p66.dts index 514f159..eb793d5 100644 --- a/arch/arm/dts/sun5i-a13-utoo-p66.dts +++ b/arch/arm/dts/sun5i-a13-utoo-p66.dts @@ -93,7 +93,7 @@ compatible = "chipone,icn8318"; reg = <0x40>; interrupt-parent = <&pio>; - interrupts = <9 IRQ_TYPE_EDGE_FALLING>; /* EINT9 (PG9) */ + interrupts = <6 9 IRQ_TYPE_EDGE_FALLING>; /* EINT9 (PG9) */ pinctrl-names = "default"; pinctrl-0 = <&ts_wake_pin_p66>; wake-gpios = <&pio 1 3 GPIO_ACTIVE_HIGH>; /* PB3 */ @@ -153,6 +153,10 @@ }; };
+&otg_sram { + status = "okay"; +}; + &pio { mmc0_cd_pin_p66: mmc0_cd_pin@0 { allwinner,pins = "PG0"; @@ -161,6 +165,20 @@ allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; };
+ usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PG1"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_DOWN>; + }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PG2"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + i2c_lcd_pins: i2c_lcd_pin@0 { allwinner,pins = "PG10", "PG12"; allwinner,function = "gpio_out"; @@ -219,7 +237,16 @@ status = "okay"; };
+&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + &usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; + usb0_id_det-gpio = <&pio 6 2 GPIO_ACTIVE_HIGH>; /* PG2 */ + usb0_vbus_det-gpio = <&pio 6 1 GPIO_ACTIVE_HIGH>; /* PG1 */ usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_ldo3>; status = "okay"; diff --git a/arch/arm/dts/sun5i.dtsi b/arch/arm/dts/sun5i.dtsi index 54b0978..759117d 100644 --- a/arch/arm/dts/sun5i.dtsi +++ b/arch/arm/dts/sun5i.dtsi @@ -416,6 +416,19 @@ #size-cells = <0>; };
+ usb_otg: usb@01c13000 { + compatible = "allwinner,sun4i-a10-musb"; + reg = <0x01c13000 0x0400>; + clocks = <&ahb_gates 0>; + interrupts = <38>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + allwinner,sram = <&otg_sram 1>; + status = "disabled"; + }; + usbphy: phy@01c13400 { #phy-cells = <1>; compatible = "allwinner,sun5i-a13-usb-phy"; @@ -475,8 +488,7 @@ clocks = <&apb0_gates 5>; gpio-controller; interrupt-controller; - #interrupt-cells = <2>; - #size-cells = <0>; + #interrupt-cells = <3>; #gpio-cells = <3>;
i2c0_pins_a: i2c0@0 { diff --git a/arch/arm/dts/sun6i-a31-m9.dts b/arch/arm/dts/sun6i-a31-m9.dts index a5660d6..6e0e568 100644 --- a/arch/arm/dts/sun6i-a31-m9.dts +++ b/arch/arm/dts/sun6i-a31-m9.dts @@ -48,7 +48,7 @@ #include <dt-bindings/pinctrl/sun4i-a10.h>
/ { - model = "Mele M9 / A1000G Quad top set box"; + model = "Mele M9 top set box"; compatible = "mele,m9", "allwinner,sun6i-a31";
aliases { diff --git a/arch/arm/dts/sun6i-a31-mele-a1000g-quad.dts b/arch/arm/dts/sun6i-a31-mele-a1000g-quad.dts index 4404f37..4dd70cc 100644 --- a/arch/arm/dts/sun6i-a31-mele-a1000g-quad.dts +++ b/arch/arm/dts/sun6i-a31-mele-a1000g-quad.dts @@ -143,6 +143,11 @@ status = "okay"; };
+&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + &usbphy { usb1_vbus-supply = <®_usb1_vbus>; status = "okay"; diff --git a/arch/arm/dts/sun6i-a31.dtsi b/arch/arm/dts/sun6i-a31.dtsi index 008047a..39953e7 100644 --- a/arch/arm/dts/sun6i-a31.dtsi +++ b/arch/arm/dts/sun6i-a31.dtsi @@ -512,6 +512,19 @@ #size-cells = <0>; };
+ usb_otg: usb@01c19000 { + compatible = "allwinner,sun6i-a31-musb"; + reg = <0x01c19000 0x0400>; + clocks = <&ahb1_gates 24>; + resets = <&ahb1_rst 24>; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + status = "disabled"; + }; + usbphy: phy@01c19400 { compatible = "allwinner,sun6i-a31-usb-phy"; reg = <0x01c19400 0x10>, @@ -599,8 +612,7 @@ clocks = <&apb1_gates 5>; gpio-controller; interrupt-controller; - #interrupt-cells = <2>; - #size-cells = <0>; + #interrupt-cells = <3>; #gpio-cells = <3>;
uart0_pins_a: uart0@0 { diff --git a/arch/arm/dts/sun6i-a31s-cs908.dts b/arch/arm/dts/sun6i-a31s-cs908.dts index 1e2411a..5e8f8c4 100644 --- a/arch/arm/dts/sun6i-a31s-cs908.dts +++ b/arch/arm/dts/sun6i-a31s-cs908.dts @@ -93,6 +93,11 @@ status = "okay"; };
+&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + &usbphy { status = "okay"; }; diff --git a/arch/arm/dts/sun7i-a20-cubietruck.dts b/arch/arm/dts/sun7i-a20-cubietruck.dts index 4611e2f..e6b0192 100644 --- a/arch/arm/dts/sun7i-a20-cubietruck.dts +++ b/arch/arm/dts/sun7i-a20-cubietruck.dts @@ -88,15 +88,11 @@ }; };
- reg_vmmc3: vmmc3 { - compatible = "regulator-fixed"; + mmc3_pwrseq: mmc3_pwrseq { + compatible = "mmc-pwrseq-simple"; pinctrl-names = "default"; - pinctrl-0 = <&vmmc3_pin_cubietruck>; - regulator-name = "vmmc3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - enable-active-high; - gpio = <&pio 7 9 GPIO_ACTIVE_HIGH>; + pinctrl-0 = <&mmc3_pwrseq_pin_cubietruck>; + reset-gpios = <&pio 7 9 GPIO_ACTIVE_LOW>; /* PH9 WIFI_EN */ }; };
@@ -172,7 +168,8 @@ &mmc3 { pinctrl-names = "default"; pinctrl-0 = <&mmc3_pins_a>; - vmmc-supply = <®_vmmc3>; + vmmc-supply = <®_vcc3v3>; + mmc-pwrseq = <&mmc3_pwrseq>; bus-width = <4>; non-removable; status = "okay"; @@ -181,7 +178,7 @@ reg = <1>; compatible = "brcm,bcm4329-fmac"; interrupt-parent = <&pio>; - interrupts = <10 IRQ_TYPE_LEVEL_LOW>; /* PH10 / EINT10 */ + interrupts = <7 10 IRQ_TYPE_LEVEL_LOW>; /* PH10 / EINT10 */ interrupt-names = "host-wake"; }; }; @@ -199,23 +196,27 @@ status = "okay"; };
+&otg_sram { + status = "okay"; +}; + &pio { - vmmc3_pin_cubietruck: vmmc3_pin@0 { - allwinner,pins = "PH9"; + ahci_pwr_pin_cubietruck: ahci_pwr_pin@1 { + allwinner,pins = "PH12"; allwinner,function = "gpio_out"; allwinner,drive = <SUN4I_PINCTRL_10_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; };
- ahci_pwr_pin_cubietruck: ahci_pwr_pin@1 { - allwinner,pins = "PH12"; + led_pins_cubietruck: led_pins@0 { + allwinner,pins = "PH7", "PH11", "PH20", "PH21"; allwinner,function = "gpio_out"; allwinner,drive = <SUN4I_PINCTRL_10_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; };
- led_pins_cubietruck: led_pins@0 { - allwinner,pins = "PH7", "PH11", "PH20", "PH21"; + mmc3_pwrseq_pin_cubietruck: mmc3_pwrseq_pin@0 { + allwinner,pins = "PH9"; allwinner,function = "gpio_out"; allwinner,drive = <SUN4I_PINCTRL_10_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; @@ -227,6 +228,20 @@ allwinner,drive = <SUN4I_PINCTRL_10_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PH19"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PH22"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; };
&pwm { @@ -288,7 +303,16 @@ status = "okay"; };
+&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + &usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; + usb0_id_det-gpios = <&pio 7 19 GPIO_ACTIVE_HIGH>; /* PH19 */ + usb0_vbus_det-gpios = <&pio 7 22 GPIO_ACTIVE_HIGH>; /* PH22 */ usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_usb1_vbus>; usb2_vbus-supply = <®_usb2_vbus>; diff --git a/arch/arm/dts/sun7i-a20-i12-tvbox.dts b/arch/arm/dts/sun7i-a20-i12-tvbox.dts index f32f6f2..1e6bd36 100644 --- a/arch/arm/dts/sun7i-a20-i12-tvbox.dts +++ b/arch/arm/dts/sun7i-a20-i12-tvbox.dts @@ -178,7 +178,7 @@ reg = <1>; compatible = "brcm,bcm4329-fmac"; interrupt-parent = <&pio>; - interrupts = <10 IRQ_TYPE_LEVEL_LOW>; /* PH10 / EINT10 */ + interrupts = <7 10 IRQ_TYPE_LEVEL_LOW>; /* PH10 / EINT10 */ interrupt-names = "host-wake"; }; }; diff --git a/arch/arm/dts/sun7i-a20-olinuxino-lime.dts b/arch/arm/dts/sun7i-a20-olinuxino-lime.dts index 769726d..0423708 100644 --- a/arch/arm/dts/sun7i-a20-olinuxino-lime.dts +++ b/arch/arm/dts/sun7i-a20-olinuxino-lime.dts @@ -135,6 +135,10 @@ status = "okay"; };
+&otg_sram { + status = "okay"; +}; + &pio { ahci_pwr_pin_olinuxinolime: ahci_pwr_pin@1 { allwinner,pins = "PC3"; @@ -149,6 +153,20 @@ allwinner,drive = <SUN4I_PINCTRL_20_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PH4"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PH5"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_DOWN>; + }; };
®_ahci_5v { @@ -157,6 +175,10 @@ status = "okay"; };
+®_usb0_vbus { + status = "okay"; +}; + ®_usb1_vbus { status = "okay"; }; @@ -171,7 +193,17 @@ status = "okay"; };
+&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + &usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; + usb0_id_det-gpio = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH4 */ + usb0_vbus_det-gpio = <&pio 7 5 GPIO_ACTIVE_HIGH>; /* PH5 */ + usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_usb1_vbus>; usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; diff --git a/arch/arm/dts/sun7i-a20-olinuxino-micro.dts b/arch/arm/dts/sun7i-a20-olinuxino-micro.dts index 00f8f25..c5d70ca 100644 --- a/arch/arm/dts/sun7i-a20-olinuxino-micro.dts +++ b/arch/arm/dts/sun7i-a20-olinuxino-micro.dts @@ -215,6 +215,10 @@ status = "okay"; };
+&otg_sram { + status = "okay"; +}; + &pio { mmc3_cd_pin_olinuxinom: mmc3_cd_pin@0 { allwinner,pins = "PH11"; @@ -229,12 +233,30 @@ allwinner,drive = <SUN4I_PINCTRL_20_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PH4"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PH5"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_DOWN>; + }; };
+®_usb0_vbus { + status = "okay"; +}; + ®_usb1_vbus { status = "okay"; }; @@ -275,7 +297,17 @@ status = "okay"; };
+&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + &usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; + usb0_id_det-gpio = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH4 */ + usb0_vbus_det-gpio = <&pio 7 5 GPIO_ACTIVE_HIGH>; /* PH5 */ + usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_usb1_vbus>; usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; diff --git a/arch/arm/dts/sun7i-a20.dtsi b/arch/arm/dts/sun7i-a20.dtsi index 6a63f30..71ab6b8 100644 --- a/arch/arm/dts/sun7i-a20.dtsi +++ b/arch/arm/dts/sun7i-a20.dtsi @@ -699,6 +699,19 @@ #size-cells = <0>; };
+ usb_otg: usb@01c13000 { + compatible = "allwinner,sun4i-a10-musb"; + reg = <0x01c13000 0x0400>; + clocks = <&ahb_gates 0>; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + allwinner,sram = <&otg_sram 1>; + status = "disabled"; + }; + usbphy: phy@01c13400 { #phy-cells = <1>; compatible = "allwinner,sun7i-a20-usb-phy"; @@ -794,8 +807,7 @@ clocks = <&apb0_gates 5>; gpio-controller; interrupt-controller; - #interrupt-cells = <2>; - #size-cells = <0>; + #interrupt-cells = <3>; #gpio-cells = <3>;
pwm0_pins_a: pwm0@0 { diff --git a/arch/arm/dts/sun8i-a23-a33.dtsi b/arch/arm/dts/sun8i-a23-a33.dtsi index 5cd2e92..9c4a55c 100644 --- a/arch/arm/dts/sun8i-a23-a33.dtsi +++ b/arch/arm/dts/sun8i-a23-a33.dtsi @@ -338,6 +338,8 @@ interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ahb1_gates 26>; resets = <&ahb1_rst 26>; + phys = <&usbphy 1>; + phy-names = "usb"; status = "disabled"; };
@@ -347,6 +349,8 @@ interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ahb1_gates 29>, <&usb_clk 16>; resets = <&ahb1_rst 29>; + phys = <&usbphy 1>; + phy-names = "usb"; status = "disabled"; };
@@ -357,8 +361,7 @@ clocks = <&apb1_gates 5>; gpio-controller; interrupt-controller; - #address-cells = <1>; - #size-cells = <0>; + #interrupt-cells = <3>; #gpio-cells = <3>;
uart0_pins_a: uart0@0 { diff --git a/arch/arm/dts/sun8i-a23-ippo-q8h-v5.dts b/arch/arm/dts/sun8i-a23-ippo-q8h-v5.dts index 95134c6..8d9da68 100644 --- a/arch/arm/dts/sun8i-a23-ippo-q8h-v5.dts +++ b/arch/arm/dts/sun8i-a23-ippo-q8h-v5.dts @@ -125,3 +125,12 @@ pinctrl-0 = <&r_uart_pins_a>; status = "okay"; }; + +&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; diff --git a/arch/arm/dts/sun8i-a23.dtsi b/arch/arm/dts/sun8i-a23.dtsi index 8698f7a..2cc27c7 100644 --- a/arch/arm/dts/sun8i-a23.dtsi +++ b/arch/arm/dts/sun8i-a23.dtsi @@ -58,6 +58,39 @@ clock-output-names = "mbus"; }; }; + + soc@01c00000 { + usb_otg: usb@01c19000 { + compatible = "allwinner,sun6i-a31-musb"; + reg = <0x01c19000 0x0400>; + clocks = <&ahb1_gates 24>; + resets = <&ahb1_rst 24>; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + status = "disabled"; + }; + + usbphy: phy@01c19400 { + compatible = "allwinner,sun8i-a23-usb-phy"; + reg = <0x01c19400 0x10>, + <0x01c1a800 0x4>; + reg-names = "phy_ctrl", + "pmu1"; + clocks = <&usb_clk 8>, + <&usb_clk 9>; + clock-names = "usb0_phy", + "usb1_phy"; + resets = <&usb_clk 0>, + <&usb_clk 1>; + reset-names = "usb0_reset", + "usb1_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + }; };
&pio { diff --git a/arch/arm/dts/sun8i-a33-ga10h-v1.1.dts b/arch/arm/dts/sun8i-a33-ga10h-v1.1.dts index da16343..1aefc67 100644 --- a/arch/arm/dts/sun8i-a33-ga10h-v1.1.dts +++ b/arch/arm/dts/sun8i-a33-ga10h-v1.1.dts @@ -131,3 +131,12 @@ pinctrl-0 = <&r_uart_pins_a>; status = "okay"; }; + +&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; diff --git a/arch/arm/dts/sun8i-a33-ippo-q8h-v1.2.dts b/arch/arm/dts/sun8i-a33-ippo-q8h-v1.2.dts index 9777149..a438975 100644 --- a/arch/arm/dts/sun8i-a33-ippo-q8h-v1.2.dts +++ b/arch/arm/dts/sun8i-a33-ippo-q8h-v1.2.dts @@ -1,17 +1,56 @@ /* * Copyright 2015 Hans de Goede hdegoede@redhat.com * - * Minimal dts file for the Ippo Q8H V1.2 (A33, 1024x600) for u-boot only + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. * - * SPDX-License-Identifier: GPL-2.0+ or X11 + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. */
/dts-v1/; #include "sun8i-a33.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/sun4i-a10.h>
/ { - model = "Ippo Q8H V1.2 (A33, 1024x600)"; - compatible = "ippo,q8h-v1.2-a33-lcd1024x600", "allwinner,sun8i-a23"; + model = "Ippo Q8H Quad Core Tablet (v1.2)"; + compatible = "ippo,a33-q8h-v1.2", "allwinner,sun8i-a33";
aliases { serial0 = &r_uart; @@ -22,8 +61,73 @@ }; };
+&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins_a>; + status = "okay"; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins_a>; + status = "okay"; +}; + +&lradc { + vref-supply = <®_vcc3v0>; + status = "okay"; + + button@200 { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + channel = <0>; + voltage = <200000>; + }; + + button@400 { + label = "Volume Down"; + linux,code = <KEY_VOLUMEDOWN>; + channel = <0>; + voltage = <400000>; + }; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_q8h>; + vmmc-supply = <®_vcc3v0>; + bus-width = <4>; + cd-gpios = <&pio 1 4 GPIO_ACTIVE_HIGH>; /* PB4 */ + cd-inverted; + status = "okay"; +}; + +&pio { + mmc0_cd_pin_q8h: mmc0_cd_pin@0 { + allwinner,pins = "PB4"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; +}; + &r_uart { pinctrl-names = "default"; pinctrl-0 = <&r_uart_pins_a>; status = "okay"; }; + +/* + * FIXME for now we only support host mode and rely on u-boot to have + * turned on Vbus which is controlled by the axp223 pmic on the board. + * + * Once we have axp223 support we should switch to fully supporting otg. + */ +&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; diff --git a/arch/arm/dts/sun8i-a33-sinlinx-sina33.dts b/arch/arm/dts/sun8i-a33-sinlinx-sina33.dts index 5788c29..1d5390d 100644 --- a/arch/arm/dts/sun8i-a33-sinlinx-sina33.dts +++ b/arch/arm/dts/sun8i-a33-sinlinx-sina33.dts @@ -63,6 +63,10 @@ }; };
+&ehci0 { + status = "okay"; +}; + &lradc { vref-supply = <®_vcc3v0>; status = "okay"; @@ -113,6 +117,10 @@ allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; };
+&ohci0 { + status = "okay"; +}; + &pio { mmc0_cd_pin_sina33: mmc0_cd_pin@0 { allwinner,pins = "PB4"; @@ -127,3 +135,8 @@ pinctrl-0 = <&uart0_pins_b>; status = "okay"; }; + +&usbphy { + status = "okay"; + usb1_vbus-supply = <®_vcc5v0>; /* USB1 VBUS is always on */ +}; diff --git a/arch/arm/dts/sun8i-a33.dtsi b/arch/arm/dts/sun8i-a33.dtsi index 85ee080..faa7d3c 100644 --- a/arch/arm/dts/sun8i-a33.dtsi +++ b/arch/arm/dts/sun8i-a33.dtsi @@ -80,6 +80,39 @@ clock-output-names = "mbus"; }; }; + + soc@01c00000 { + usb_otg: usb@01c19000 { + compatible = "allwinner,sun8i-a33-musb"; + reg = <0x01c19000 0x0400>; + clocks = <&ahb1_gates 24>; + resets = <&ahb1_rst 24>; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + status = "disabled"; + }; + + usbphy: phy@01c19400 { + compatible = "allwinner,sun8i-a33-usb-phy"; + reg = <0x01c19400 0x14>, + <0x01c1a800 0x4>; + reg-names = "phy_ctrl", + "pmu1"; + clocks = <&usb_clk 8>, + <&usb_clk 9>; + clock-names = "usb0_phy", + "usb1_phy"; + resets = <&usb_clk 0>, + <&usb_clk 1>; + reset-names = "usb0_reset", + "usb1_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + }; };
&pio { diff --git a/arch/arm/dts/sunxi-common-regulators.dtsi b/arch/arm/dts/sunxi-common-regulators.dtsi index 51cc838..f1953b0 100644 --- a/arch/arm/dts/sunxi-common-regulators.dtsi +++ b/arch/arm/dts/sunxi-common-regulators.dtsi @@ -108,6 +108,7 @@ regulator-name = "usb1-vbus"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; + regulator-boot-on; enable-active-high; gpio = <&pio 7 6 GPIO_ACTIVE_HIGH>; status = "disabled"; @@ -120,6 +121,7 @@ regulator-name = "usb2-vbus"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; + regulator-boot-on; enable-active-high; gpio = <&pio 7 3 GPIO_ACTIVE_HIGH>; status = "disabled";
The Auxtek-T003 HDMI stick is an A10s based HDMI stick with USB wifi, and composite video out support.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun5i-a10s-auxtek-t003.dts | 145 ++++++++++++++++++++++++++++++++ configs/Auxtek-T003_defconfig | 15 ++++ 3 files changed, 161 insertions(+) create mode 100644 arch/arm/dts/sun5i-a10s-auxtek-t003.dts create mode 100644 configs/Auxtek-T003_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 34346da..6e0ab63 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -82,6 +82,7 @@ dtb-$(CONFIG_MACH_SUN4I) += \ sun4i-a10-olinuxino-lime.dtb \ sun4i-a10-pcduino.dtb dtb-$(CONFIG_MACH_SUN5I) += \ + sun5i-a10s-auxtek-t003.dtb \ sun5i-a10s-auxtek-t004.dtb \ sun5i-a10s-mk802.dtb \ sun5i-a10s-olinuxino-micro.dtb \ diff --git a/arch/arm/dts/sun5i-a10s-auxtek-t003.dts b/arch/arm/dts/sun5i-a10s-auxtek-t003.dts new file mode 100644 index 0000000..85026e3 --- /dev/null +++ b/arch/arm/dts/sun5i-a10s-auxtek-t003.dts @@ -0,0 +1,145 @@ +/* + * Copyright 2015 Hans de Goede hdegoede@redhat.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun5i-a10s.dtsi" +#include "sunxi-common-regulators.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "Auxtek t003 A10s hdmi tv-stick"; + compatible = "allwinner,auxtek-t003", "allwinner,sun5i-a10s"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins_t003>; + + red { + label = "t003-tv-dongle:red:usr"; + gpios = <&pio 1 2 GPIO_ACTIVE_HIGH>; /* PB2 */ + default-state = "on"; + }; + }; +}; + +&ehci0 { + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_t003>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 6 1 GPIO_ACTIVE_HIGH>; /* PG1 */ + cd-inverted; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&otg_sram { + status = "okay"; +}; + +&pio { + mmc0_cd_pin_t003: mmc0_cd_pin@0 { + allwinner,pins = "PG1"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + led_pins_t003: led_pins@0 { + allwinner,pins = "PB2"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_20_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +®_usb0_vbus { + gpio = <&pio 6 13 GPIO_ACTIVE_HIGH>; /* PG13 */ + status = "okay"; +}; + +®_usb1_vbus { + gpio = <&pio 1 10 GPIO_ACTIVE_HIGH>; /* PB10 */ + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usb0_vbus_pin_a { + allwinner,pins = "PG13"; +}; + +&usb1_vbus_pin_a { + allwinner,pins = "PB10"; +}; + +&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbphy { + usb0_vbus-supply = <®_usb0_vbus>; + usb1_vbus-supply = <®_usb1_vbus>; + status = "okay"; +}; diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig new file mode 100644 index 0000000..b9692dc --- /dev/null +++ b/configs/Auxtek-T003_defconfig @@ -0,0 +1,15 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN5I=y +CONFIG_DRAM_CLK=408 +CONFIG_DRAM_EMR1=0 +CONFIG_USB1_VBUS_PIN="PB10" +CONFIG_VIDEO_COMPOSITE=y +CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t003" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="AXP152_POWER" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_USB_EHCI_HCD=y
This is missing a MAINTAINERS update. With that added: Acked-by: Ian Campbell ijc@hellion.org.uk
without reading since it's just a sync: Acked-by: Ian Campbell ijc@hellion.org.uk
Hans de Goede
Ian Campbell
