[U-Boot] Please pull u-boot-riscv
Hi Tom,
Please pull some riscv update: 1. Fix BBL may be corrupted problem. 2. Support U-Boot run in S-mode.
https://travis-ci.org/rickchen36/u-boot-riscv/builds/463646974
Thanks
Rick
The following changes since commit 2e2a2a5d4f0c2e2642326d9000ce1f1553632e6a:
Merge branch 'master' of git://git.denx.de/u-boot-sh (2018-12-04 19:22:31 -0500)
git://git.denx.de/u-boot-riscv.git
for you to fetch changes up to 48cbf6246052de10d35b616b5efb2f783904a49d:
riscv: ax25-ae350: Pass dtb address to u-boot with a1 register (2018-12-05 14:14:16 +0800)
---------------------------------------------------------------- Anup Patel (3): riscv: Add kconfig option to run U-Boot in S-mode riscv: qemu: Use different SYS_TEXT_BASE for S-mode riscv: Add S-mode defconfigs for QEMU virt machine
Rick Chen (1): riscv: ax25-ae350: Pass dtb address to u-boot with a1 register
arch/riscv/Kconfig | 5 +++++ arch/riscv/cpu/start.S | 25 +++++++++++++++---------- arch/riscv/include/asm/encoding.h | 6 ++++++ arch/riscv/lib/interrupts.c | 31 ++++++++++++++++++++++--------- board/AndesTech/ax25-ae350/ax25-ae350.c | 3 ++- board/emulation/qemu-riscv/Kconfig | 3 ++- board/emulation/qemu-riscv/MAINTAINERS | 2 ++ configs/qemu-riscv32_smode_defconfig | 10 ++++++++++ configs/qemu-riscv64_smode_defconfig | 11 +++++++++++ 9 files changed, 75 insertions(+), 21 deletions(-) create mode 100644 configs/qemu-riscv32_smode_defconfig create mode 100644 configs/qemu-riscv64_smode_defconfig
On Wed, Dec 05, 2018 at 03:12:29PM +0800, Rick Chen wrote:
Hi Tom,
- Fix BBL may be corrupted problem.
- Support U-Boot run in S-mode.
Thanks
Rick
Rick Chen
