[U-Boot] AT91SAM9xxx SDCard/MMC support?
Hello,
apparently none of the mainstream u-boot designs use SDCard/MMC.
It appears that this task should not be a huge problem, the MCI for both AVR32 and AT91SAM9 seems to be identical (and MCI on AVR32 works).
But before I perhaps reinvent anything already done, I prefer to ask here. Also any input what obstacles have been found would be appreciated.
I need the support for 9260/9G20/9XE.
Best Regards Reinhard
Reinhard Meyer (-VC) schrieb:
Hello,
After some hacking I get the following results:
TOP9000> mmc init mmc: bus_hz is 99328000, setting clock 150000 Hz, block size 512 mmc: requested clock 150000 is too low; setting CLKDIV to 255; resulting clock is 194000 mmc: CMD0 0x0 (flags 0x0) mmc: status 0x0000c0e5
mmc: CMD0 0x0 (flags 0x100) mmc: status 0x0000c0e5
mmc: CMD55 0x0 (flags 0x1040) mmc: status 0x0000c0e5 mmc: response: 00000120 mmc: CMD41 0x100000 (flags 0x41) mmc: status 0x0004c0e5 mmc: response: 00ff8000 mmc: CMD55 0x0 (flags 0x1040) mmc: status 0x0000c0e5 mmc: response: 00000120 mmc: CMD41 0x100000 (flags 0x41) mmc: status 0x0004c0e5 mmc: response: 80ff8000 mmc: CMD2 0x0 (flags 0x80) mmc: status 0x0000c0e5 mmc: response: 19445953 4d495344 10000073 f30054bb Manufacturer ID: 19 OEM/Application ID: 4459 Product name: SMISD Product Revision: 1.0 Product Serial Number: 29683 Manufacturing Date: 05/04 mmc: CMD3 0x0 (flags 0x1040) mmc: status 0x0000c0e5 mmc: response: b3680500 SD Card detected (RCA 45928) mmc: CMD9 0xb3680000 (flags 0x1080) mmc: status 0x0000c0e5 mmc: response: 005e0032 1f5983d0 6db7bf9f 96400005 CSD data: 005e0032 1f5983d0 6db7bf9f 96400005 CSD structure version: 1.2 MMC System Spec version: 12 Card command classes: 3d0 Read block length: 256 Supports partial reads Write block length: 1 Does not support partial writes Does not support group WP Card capacity: 131072000 bytes File format: 1/2 Write protection: permanent mmc: Using 983040 cycles data timeout (DTOR=0x6f) Card does not support 512 byte reads, aborting. No MMC card found
It IS a 1 GB Card, and sure has 512 Byte sectors (it worked well on the ATNGW100) with the same driver source.
What I notice is that the current driver (atmel_mci.c) nowhere sets the MMCI_SDCR register, therefore using the bus in 1 bit mode. But that is the case in the AVR32 case as well, and there MCI did work...
TOP9000> mmc init Manufacturer ID: 19 OEM/Application ID: 4459 Product name: SMISD Product Revision: 1.0 Product Serial Number: 29683 Manufacturing Date: 05/04 SD Card detected (RCA 45928) CSD data: 005e0032 1f5983d0 6db7bf9f 96400005 CSD structure version: 1.2 MMC System Spec version: 12 Card command classes: 3d0 Read block length: 256 Supports partial reads Write block length: 1 Does not support partial writes Does not support group WP Card capacity: 131072000 bytes File format: 1/2 Write protection: permanent Card does not support 512 byte reads, aborting. No MMC card found
on AVR32 the ouput is: top7000> mmc init Manufacturer ID: 19 OEM/Application ID: 4459 Product name: SMISD Product Revision: 1.0 Product Serial Number: 29683 Manufacturing Date: 05/04 SD Card detected (RCA 45928) CSD data: 005e0032 1f5983d0 6db7bf9f 96400005 CSD structure version: 1.0 MMC System Spec version: 0 Card command classes: 1f5 Read block length: 512 Supports partial reads Write block length: 512 Does not support partial writes Supports group WP: 32 Card capacity: 1023934464 bytes File format: 0/0 Write protection: mmc: Using 262144 cycles data timeout (DTOR=0x64)
*** the CSD Data is the same, the interpretation of non-byte values is different. Looks like an alignment or byteswap issue...
The issue has been solved: A bitfielded struct was effectively unioned with a u32 array... Bad by design. SD/MMC now works for 9260/9XE, probably for 9G20, too. After a bit more cleanup I will provide a patch.
Reinhard Meyer
