[U-Boot] [PATCH] dm: usb.h: Always declare usb func. prototypes when CONFIG_DM_USB=y
When CONFIG_DM_USB=y the various usb functions are available regardless of any controller drivers being enabled, so always the usb function prototypes when CONFIG_DM_USB=y.
This fixes compile warnings due to missing prototypes on ARCHs where the ARCH Kconfig always enables CONFIG_DM_USB and various usb drivers.
One could argue that in the case of no controllers CONFIG_DM_USB should not be set, but this problem is typically seen during bringup of boards which do actually have usb controllers.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- include/usb.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/usb.h b/include/usb.h index c709ce2..54ad33a 100644 --- a/include/usb.h +++ b/include/usb.h @@ -180,7 +180,7 @@ enum usb_init_type { defined(CONFIG_USB_MUSB_DSPS) || defined(CONFIG_USB_MUSB_AM35X) || \ defined(CONFIG_USB_MUSB_OMAP2PLUS) || defined(CONFIG_USB_MUSB_SUNXI) || \ defined(CONFIG_USB_XHCI) || defined(CONFIG_USB_DWC2) || \ - defined(CONFIG_USB_EMUL) + defined(CONFIG_USB_EMUL) || defined(CONFIG_DM_USB)
int usb_lowlevel_init(int index, enum usb_init_type init, void **controller); int usb_lowlevel_stop(int index);
- defined(CONFIG_USB_EMUL) || defined(CONFIG_DM_USB)
What would happen in case we instead dropped this horrible ifdef altogether, do you think it'd break anything ?
Best regards, Marek Vasut
I've not audited the code, but I believe that it only declares a bunch of function prototypes, so I think that dropping the entire #ifdef is fine.
Regards,
Hans
So do I :)
So do I :)
I was actually hoping that you would do it :)
Regards,
Hans
So do I :)
So V2 is coming ? :)
Hans de Goede
