[U-Boot] [PATCH 01/11] fpga: Protect GZIP usage when LOADMK is enabled
For case where CMD_FPGA_LOADMK is enabled and GZIP disable.
Warning log: common/built-in.o: In function `do_fpga': /mnt/disk/u-boot/common/cmd_fpga.c:218: undefined reference to `gunzip'
common/cmd_fpga.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/common/cmd_fpga.c b/common/cmd_fpga.c index 8c5bf440fbb0..484a6c6ce036 100644 --- a/common/cmd_fpga.c +++ b/common/cmd_fpga.c @@ -211,6 +211,7 @@ int do_fpga(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[])
comp = image_get_comp(hdr); if (comp == IH_COMP_GZIP) { +#if defined(CONFIG_GZIP) ulong image_buf = image_get_data(hdr); data = image_get_load(hdr); ulong image_size = ~0UL; @@ -222,6 +223,10 @@ int do_fpga(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) return 1; } data_size = image_size; +#else + puts("Gunzip image is not supported\n"); + return 1; +#endif } else { data = (ulong)image_get_data(hdr); data_size = image_get_data_size(hdr); -- 1.8.2.3
This problem is reported by checkpatch.pl Warnings: CHECK: extern prototypes should be avoided in .h files
include/fpga.h | 26 +++++++++++++------------- 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/include/fpga.h b/include/fpga.h index 914024c17cb8..ef044e936294 100644 --- a/include/fpga.h +++ b/include/fpga.h @@ -49,18 +49,18 @@ typedef enum { } bitstream_type;
/* root function definitions */ -extern void fpga_init(void); -extern int fpga_add(fpga_type devtype, void *desc); -extern int fpga_count(void); -extern int fpga_load(int devnum, const void *buf, size_t bsize, - bitstream_type bstype); -extern int fpga_fsload(int devnum, const void *buf, size_t size, - fpga_fs_info *fpga_fsinfo); -extern int fpga_loadbitstream(int devnum, char *fpgadata, size_t size, - bitstream_type bstype); -extern int fpga_dump(int devnum, const void *buf, size_t bsize); -extern int fpga_info(int devnum); -extern const fpga_desc *const fpga_validate(int devnum, const void *buf, - size_t bsize, char *fn); +void fpga_init(void); +int fpga_add(fpga_type devtype, void *desc); +int fpga_count(void); +int fpga_load(int devnum, const void *buf, size_t bsize, + bitstream_type bstype); +int fpga_fsload(int devnum, const void *buf, size_t size, + fpga_fs_info *fpga_fsinfo); +int fpga_loadbitstream(int devnum, char *fpgadata, size_t size, + bitstream_type bstype); +int fpga_dump(int devnum, const void *buf, size_t bsize); +int fpga_info(int devnum); +const fpga_desc *const fpga_validate(int devnum, const void *buf, + size_t bsize, char *fn);
#endif /* _FPGA_H_ */ -- 1.8.2.3
SPL needs to detect FPGA device which will be used for loading bitstream.
drivers/fpga/fpga.c | 2 +- include/fpga.h | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/fpga/fpga.c b/drivers/fpga/fpga.c index 37946d5e183a..d94eb5cc25c4 100644 --- a/drivers/fpga/fpga.c +++ b/drivers/fpga/fpga.c @@ -38,7 +38,7 @@ static void fpga_no_sup(char *fn, char *msg) /* fpga_get_desc * map a device number to a descriptor */ -static const fpga_desc *const fpga_get_desc(int devnum) +const fpga_desc *const fpga_get_desc(int devnum) { fpga_desc *desc = (fpga_desc *)NULL;
diff --git a/include/fpga.h b/include/fpga.h index ef044e936294..e0d12981b283 100644 --- a/include/fpga.h +++ b/include/fpga.h @@ -52,6 +52,7 @@ typedef enum { void fpga_init(void); int fpga_add(fpga_type devtype, void *desc); int fpga_count(void); +const fpga_desc *const fpga_get_desc(int devnum); int fpga_load(int devnum, const void *buf, size_t bsize, bitstream_type bstype); int fpga_fsload(int devnum, const void *buf, size_t size, -- 1.8.2.3
Set fpga operations to NULL for cases where FPGA is setup in board file but driver is not added.
include/spartan2.h | 38 +++++++++++++++++++++++++++----------- 1 file changed, 27 insertions(+), 11 deletions(-)
diff --git a/include/spartan2.h b/include/spartan2.h index 2aca954e73ab..14606c303180 100644 --- a/include/spartan2.h +++ b/include/spartan2.h @@ -38,7 +38,12 @@ typedef struct { xilinx_post_fn post; } xilinx_spartan2_slave_serial_fns;
+#if defined(CONFIG_FPGA_SPARTAN2) extern struct xilinx_fpga_op spartan2_op; +# define FPGA_SPARTAN2_OPS &spartan2_op +#else +# define FPGA_SPARTAN2_OPS NULL +#endif
/* Device Image Sizes *********************************************************************/ @@ -61,36 +66,47 @@ extern struct xilinx_fpga_op spartan2_op; *********************************************************************/ /* Spartan-II devices */ #define XILINX_XC2S15_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S15_SIZE, fn_table, cookie, &spartan2_op } +{ xilinx_spartan2, iface, XILINX_XC2S15_SIZE, fn_table, cookie, \ + FPGA_SPARTAN2_OPS }
#define XILINX_XC2S30_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S30_SIZE, fn_table, cookie, &spartan2_op } +{ xilinx_spartan2, iface, XILINX_XC2S30_SIZE, fn_table, cookie, \ + FPGA_SPARTAN2_OPS }
#define XILINX_XC2S50_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S50_SIZE, fn_table, cookie, &spartan2_op } +{ xilinx_spartan2, iface, XILINX_XC2S50_SIZE, fn_table, cookie, \ + FPGA_SPARTAN2_OPS }
#define XILINX_XC2S100_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S100_SIZE, fn_table, cookie, &spartan2_op } +{ xilinx_spartan2, iface, XILINX_XC2S100_SIZE, fn_table, cookie, \ + FPGA_SPARTAN2_OPS }
#define XILINX_XC2S150_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S150_SIZE, fn_table, cookie, &spartan2_op } +{ xilinx_spartan2, iface, XILINX_XC2S150_SIZE, fn_table, cookie, \ + FPGA_SPARTAN2_OPS }
#define XILINX_XC2S200_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S200_SIZE, fn_table, cookie, &spartan2_op } +{ xilinx_spartan2, iface, XILINX_XC2S200_SIZE, fn_table, cookie, \ + FPGA_SPARTAN2_OPS }
#define XILINX_XC2S50E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S50E_SIZE, fn_table, cookie, &spartan2_op } +{ xilinx_spartan2, iface, XILINX_XC2S50E_SIZE, fn_table, cookie, \ + FPGA_SPARTAN2_OPS }
#define XILINX_XC2S100E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S100E_SIZE, fn_table, cookie, &spartan2_op } +{ xilinx_spartan2, iface, XILINX_XC2S100E_SIZE, fn_table, cookie, \ + FPGA_SPARTAN2_OPS }
#define XILINX_XC2S150E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S150E_SIZE, fn_table, cookie, &spartan2_op } +{ xilinx_spartan2, iface, XILINX_XC2S150E_SIZE, fn_table, cookie, \ + FPGA_SPARTAN2_OPS }
#define XILINX_XC2S200E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S200E_SIZE, fn_table, cookie, &spartan2_op } +{ xilinx_spartan2, iface, XILINX_XC2S200E_SIZE, fn_table, cookie, \ + FPGA_SPARTAN2_OPS }
#define XILINX_XC2S300E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan2, iface, XILINX_XC2S300E_SIZE, fn_table, cookie, &spartan2_op } +{ xilinx_spartan2, iface, XILINX_XC2S300E_SIZE, fn_table, cookie, \ + FPGA_SPARTAN2_OPS }
#endif /* _SPARTAN2_H_ */ -- 1.8.2.3
include/spartan3.h | 45 +++++++++++++++++++++++++++++++-------------- 1 file changed, 31 insertions(+), 14 deletions(-)
diff --git a/include/spartan3.h b/include/spartan3.h index d6d67a6e560c..fcb27b01e4a7 100644 --- a/include/spartan3.h +++ b/include/spartan3.h @@ -40,7 +40,12 @@ typedef struct { xilinx_abort_fn abort; } xilinx_spartan3_slave_serial_fns;
+#if defined(CONFIG_FPGA_SPARTAN3) extern struct xilinx_fpga_op spartan3_op; +# define FPGA_SPARTAN3_OPS &spartan3_op +#else +# define FPGA_SPARTAN3_OPS NULL +#endif
/* Device Image Sizes *********************************************************************/ @@ -71,48 +76,60 @@ extern struct xilinx_fpga_op spartan3_op; *********************************************************************/ /* Spartan-III devices */ #define XILINX_XC3S50_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S50_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINX_XC3S50_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
#define XILINX_XC3S200_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S200_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINX_XC3S200_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
#define XILINX_XC3S400_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S400_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINX_XC3S400_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
#define XILINX_XC3S1000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S1000_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINX_XC3S1000_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
#define XILINX_XC3S1500_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S1500_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINX_XC3S1500_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
#define XILINX_XC3S2000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S2000_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINX_XC3S2000_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
#define XILINX_XC3S4000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S4000_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINX_XC3S4000_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
#define XILINX_XC3S5000_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S5000_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINX_XC3S5000_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
/* Spartan-3E devices */ #define XILINX_XC3S100E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S100E_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINX_XC3S100E_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
#define XILINX_XC3S250E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S250E_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINX_XC3S250E_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
#define XILINX_XC3S500E_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINX_XC3S500E_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINX_XC3S500E_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
#define XILINX_XC3S1200E_DESC(iface, fn_table, cookie) \ { xilinx_spartan3, iface, XILINX_XC3S1200E_SIZE, fn_table, cookie, \ - &spartan3_op } + FPGA_SPARTAN3_OPS }
#define XILINX_XC3S1600E_DESC(iface, fn_table, cookie) \ { xilinx_spartan3, iface, XILINX_XC3S1600E_SIZE, fn_table, cookie, \ - &spartan3_op } + FPGA_SPARTAN3_OPS }
#define XILINX_XC6SLX4_DESC(iface, fn_table, cookie) \ -{ xilinx_spartan3, iface, XILINK_XC6SLX4_SIZE, fn_table, cookie, &spartan3_op } +{ xilinx_spartan3, iface, XILINK_XC6SLX4_SIZE, fn_table, cookie, \ + FPGA_SPARTAN3_OPS }
#endif /* _SPARTAN3_H_ */ -- 1.8.2.3
include/virtex2.h | 45 +++++++++++++++++++++++++++++++-------------- 1 file changed, 31 insertions(+), 14 deletions(-)
diff --git a/include/virtex2.h b/include/virtex2.h index 7b7825f513e3..5944bbcb61b8 100644 --- a/include/virtex2.h +++ b/include/virtex2.h @@ -11,8 +11,6 @@
#include <xilinx.h>
-extern struct xilinx_fpga_op virtex2_op; - /* * Slave SelectMap Implementation function table. */ @@ -40,6 +38,13 @@ typedef struct { xilinx_wdata_fn wdata; } xilinx_virtex2_slave_serial_fns;
+#if defined(CONFIG_FPGA_VIRTEX2) +extern struct xilinx_fpga_op virtex2_op; +# define FPGA_VIRTEX2_OPS &virtex2_op +#else +# define FPGA_VIRTEX2_OPS NULL +#endif + /* Device Image Sizes (in bytes) *********************************************************************/ #define XILINX_XC2V40_SIZE (338208 / 8) @@ -58,39 +63,51 @@ typedef struct { /* Descriptor Macros *********************************************************************/ #define XILINX_XC2V40_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V40_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V40_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#define XILINX_XC2V80_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V80_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V80_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#define XILINX_XC2V250_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V250_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V250_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#define XILINX_XC2V500_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V500_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V500_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#define XILINX_XC2V1000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V1000_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V1000_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#define XILINX_XC2V1500_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V1500_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V1500_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#define XILINX_XC2V2000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V2000_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V2000_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#define XILINX_XC2V3000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V3000_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V3000_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#define XILINX_XC2V4000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V4000_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V4000_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#define XILINX_XC2V6000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V6000_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V6000_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#define XILINX_XC2V8000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V8000_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V8000_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#define XILINX_XC2V10000_DESC(iface, fn_table, cookie) \ -{ xilinx_virtex2, iface, XILINX_XC2V10000_SIZE, fn_table, cookie, &virtex2_op } +{ xilinx_virtex2, iface, XILINX_XC2V10000_SIZE, fn_table, cookie, \ + FPGA_VIRTEX2_OPS }
#endif /* _VIRTEX2_H_ */ -- 1.8.2.3
No functional changes.
include/virtex2.h | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/virtex2.h b/include/virtex2.h index 5944bbcb61b8..503df9abaeaa 100644 --- a/include/virtex2.h +++ b/include/virtex2.h @@ -47,10 +47,10 @@ extern struct xilinx_fpga_op virtex2_op;
/* Device Image Sizes (in bytes) *********************************************************************/ -#define XILINX_XC2V40_SIZE (338208 / 8) -#define XILINX_XC2V80_SIZE (597408 / 8) -#define XILINX_XC2V250_SIZE (1591584 / 8) -#define XILINX_XC2V500_SIZE (2557857 / 8) +#define XILINX_XC2V40_SIZE (338208 / 8) +#define XILINX_XC2V80_SIZE (597408 / 8) +#define XILINX_XC2V250_SIZE (1591584 / 8) +#define XILINX_XC2V500_SIZE (2557857 / 8) #define XILINX_XC2V1000_SIZE (3749408 / 8) #define XILINX_XC2V1500_SIZE (5166240 / 8) #define XILINX_XC2V2000_SIZE (6808352 / 8) -- 1.8.2.3
include/zynqpl.h | 23 +++++++++++++++++------ 1 file changed, 17 insertions(+), 6 deletions(-)
diff --git a/include/zynqpl.h b/include/zynqpl.h index 8a9ec3297fbe..d0ff0d9a8bda 100644 --- a/include/zynqpl.h +++ b/include/zynqpl.h @@ -12,7 +12,12 @@
#include <xilinx.h>
+#if defined(CONFIG_FPGA_ZYNQPL) extern struct xilinx_fpga_op zynq_op; +# define FPGA_ZYNQPL_OPS &zynq_op +#else +# define FPGA_ZYNQPL_OPS NULL +#endif
#define XILINX_ZYNQ_7010 0x2 #define XILINX_ZYNQ_7015 0x1b @@ -31,21 +36,27 @@ extern struct xilinx_fpga_op zynq_op;
/* Descriptor Macros */ #define XILINX_XC7Z010_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z010_SIZE, NULL, cookie, &zynq_op, "7z010" } +{ xilinx_zynq, devcfg, XILINX_XC7Z010_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ + "7z010" }
#define XILINX_XC7Z015_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z015_SIZE, NULL, cookie, &zynq_op, "7z015" } +{ xilinx_zynq, devcfg, XILINX_XC7Z015_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ + "7z015" }
#define XILINX_XC7Z020_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z020_SIZE, NULL, cookie, &zynq_op, "7z020" } +{ xilinx_zynq, devcfg, XILINX_XC7Z020_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ + "7z020" }
#define XILINX_XC7Z030_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z030_SIZE, NULL, cookie, &zynq_op, "7z030" } +{ xilinx_zynq, devcfg, XILINX_XC7Z030_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ + "7z030" }
#define XILINX_XC7Z045_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z045_SIZE, NULL, cookie, &zynq_op, "7z045" } +{ xilinx_zynq, devcfg, XILINX_XC7Z045_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ + "7z045" }
#define XILINX_XC7Z100_DESC(cookie) \ -{ xilinx_zynq, devcfg, XILINX_XC7Z100_SIZE, NULL, cookie, &zynq_op, "7z100" } +{ xilinx_zynq, devcfg, XILINX_XC7Z100_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ + "7z100" }
#endif /* _ZYNQPL_H_ */ -- 1.8.2.3
Ensure that operations are correctly setup.
drivers/fpga/xilinx.c | 17 +++++++++++++++-- 1 file changed, 15 insertions(+), 2 deletions(-)
diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index adb4b8cd25fd..9c95148b25c1 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -139,6 +139,11 @@ int xilinx_load(xilinx_desc *desc, const void *buf, size_t bsize, return FPGA_FAIL; }
+ if (!desc->operations || !desc->operations->load) { + printf("%s: Missing load operation\n", __func__); + return FPGA_FAIL; + } + return desc->operations->load(desc, buf, bsize, bstype); }
@@ -151,8 +156,10 @@ int xilinx_loadfs(xilinx_desc *desc, const void *buf, size_t bsize, return FPGA_FAIL; }
- if (!desc->operations->loadfs) + if (!desc->operations || !desc->operations->loadfs) { + printf("%s: Missing loadfs operation\n", __func__); return FPGA_FAIL; + }
return desc->operations->loadfs(desc, buf, bsize, fpga_fsinfo); } @@ -165,6 +172,11 @@ int xilinx_dump(xilinx_desc *desc, const void *buf, size_t bsize) return FPGA_FAIL; }
+ if (!desc->operations || !desc->operations->dump) { + printf("%s: Missing dump operation\n", __func__); + return FPGA_FAIL; + } + return desc->operations->dump(desc, buf, bsize); }
@@ -228,7 +240,8 @@ int xilinx_info(xilinx_desc *desc)
if (desc->iface_fns) { printf ("Device Function Table @ 0x%p\n", desc->iface_fns); - desc->operations->info(desc); + if (desc->operations && desc->operations->info) + desc->operations->info(desc); } else printf ("No Device Function Table.\n");
-- 1.8.2.3
(comment below)
return FPGA_FAIL;
I wonder if these error codes should be dropped in favour of the standard ones? Perhaps in a separate patch. E.g. here we could use -ENOSYS.
} return desc->operations->loadfs(desc, buf, bsize, fpga_fsinfo);
return FPGA_FAIL;
-- 1.8.2.3
(comment below)
return FPGA_FAIL;
Definitely. They are bogus.
Thanks, Michal
Show fpga_op->info even if desc->iface_fns is not defined.
drivers/fpga/xilinx.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/drivers/fpga/xilinx.c b/drivers/fpga/xilinx.c index 9c95148b25c1..c765a74a25e0 100644 --- a/drivers/fpga/xilinx.c +++ b/drivers/fpga/xilinx.c @@ -238,13 +238,14 @@ int xilinx_info(xilinx_desc *desc) if (desc->name) printf("Device name: \t%s\n", desc->name);
- if (desc->iface_fns) { + if (desc->iface_fns) printf ("Device Function Table @ 0x%p\n", desc->iface_fns); - if (desc->operations && desc->operations->info) - desc->operations->info(desc); - } else + else printf ("No Device Function Table.\n");
+ if (desc->operations && desc->operations->info) + desc->operations->info(desc); + ret_val = FPGA_SUCCESS; } else { printf ("%s: Invalid device descriptor\n", __FUNCTION__); -- 1.8.2.3
} else
-- 1.8.2.3
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Added support for zc7035
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
board/xilinx/zynq/board.c | 4 ++++ include/zynqpl.h | 6 ++++++ 2 files changed, 10 insertions(+)
diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 258632e52b0b..3a2198f8e830 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -24,6 +24,7 @@ static xilinx_desc fpga010 = XILINX_XC7Z010_DESC(0x10); static xilinx_desc fpga015 = XILINX_XC7Z015_DESC(0x15); static xilinx_desc fpga020 = XILINX_XC7Z020_DESC(0x20); static xilinx_desc fpga030 = XILINX_XC7Z030_DESC(0x30); +static xilinx_desc fpga035 = XILINX_XC7Z035_DESC(0x35); static xilinx_desc fpga045 = XILINX_XC7Z045_DESC(0x45); static xilinx_desc fpga100 = XILINX_XC7Z100_DESC(0x100); #endif @@ -49,6 +50,9 @@ int board_init(void) case XILINX_ZYNQ_7030: fpga = fpga030; break; + case XILINX_ZYNQ_7035: + fpga = fpga035; + break; case XILINX_ZYNQ_7045: fpga = fpga045; break; diff --git a/include/zynqpl.h b/include/zynqpl.h index d0ff0d9a8bda..1d37a51a04ef 100644 --- a/include/zynqpl.h +++ b/include/zynqpl.h @@ -23,6 +23,7 @@ extern struct xilinx_fpga_op zynq_op; #define XILINX_ZYNQ_7015 0x1b #define XILINX_ZYNQ_7020 0x7 #define XILINX_ZYNQ_7030 0xc +#define XILINX_ZYNQ_7035 0x12 #define XILINX_ZYNQ_7045 0x11 #define XILINX_ZYNQ_7100 0x16
@@ -31,6 +32,7 @@ extern struct xilinx_fpga_op zynq_op; #define XILINX_XC7Z015_SIZE 28085344/8 #define XILINX_XC7Z020_SIZE 32364512/8 #define XILINX_XC7Z030_SIZE 47839328/8 +#define XILINX_XC7Z035_SIZE 106571232/8 #define XILINX_XC7Z045_SIZE 106571232/8 #define XILINX_XC7Z100_SIZE 139330784/8
@@ -51,6 +53,10 @@ extern struct xilinx_fpga_op zynq_op; { xilinx_zynq, devcfg, XILINX_XC7Z030_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ "7z030" }
+#define XILINX_XC7Z035_DESC(cookie) \ +{ xilinx_zynq, devcfg, XILINX_XC7Z035_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ + "7z035" } + #define XILINX_XC7Z045_DESC(cookie) \ { xilinx_zynq, devcfg, XILINX_XC7Z045_SIZE, NULL, cookie, FPGA_ZYNQPL_OPS, \ "7z045" } -- 1.8.2.3
Michal Simek
Michal Simek
