[U-Boot] [PATCH] part_efi: fix build warning
part_efi.c: In function 'print_part_efi': part_efi.c:133: warning: passing argument 3 of 'is_gpt_valid' from incompatible pointer type part_efi.c:95: note: expected 'struct gpt_header *' but argument is of type 'struct gpt_header **' part_efi.c: In function 'get_partition_info_efi': part_efi.c:172: warning: passing argument 3 of 'is_gpt_valid' from incompatible pointer type part_efi.c:95: note: expected 'struct gpt_header *' but argument is of type 'struct gpt_header **'
Signed-off-by: Lei Wen leiwen@marvell.com --- disk/part_efi.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/disk/part_efi.c b/disk/part_efi.c index e7f2714..ddf80a7 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -130,7 +130,7 @@ void print_part_efi(block_dev_desc_t * dev_desc) } /* This function validates AND fills in the GPT header and PTE */ if (is_gpt_valid(dev_desc, GPT_PRIMARY_PARTITION_TABLE_LBA, - &(gpt_head), &gpt_pte) != 1) { + gpt_head, &gpt_pte) != 1) { printf("%s: *** ERROR: Invalid GPT ***\n", __func__); return; } @@ -169,7 +169,7 @@ int get_partition_info_efi(block_dev_desc_t * dev_desc, int part,
/* This function validates AND fills in the GPT header and PTE */ if (is_gpt_valid(dev_desc, GPT_PRIMARY_PARTITION_TABLE_LBA, - &(gpt_head), &gpt_pte) != 1) { + gpt_head, &gpt_pte) != 1) { printf("%s: *** ERROR: Invalid GPT ***\n", __func__); return -1; }
A patch for this bug already exists: [1].
Thanks anyway, Anatolij
Anatolij Gustschin
Lei Wen
