[U-Boot] [PATCH v2 1/3] mx28: Let imx_get_mac_from_fuse be common for mx28
Let imx_get_mac_from_fuse function be a common function, so that other mx28 boards can reuse it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/arm926ejs/mx28/mx28.c | 35 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx28/sys_proto.h | 2 + board/denx/m28evk/m28evk.c | 35 ---------------------------- 3 files changed, 37 insertions(+), 35 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c index 088c019..785978f 100644 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ b/arch/arm/cpu/arm926ejs/mx28/mx28.c @@ -214,6 +214,41 @@ int cpu_eth_init(bd_t *bis) } #endif
+#ifdef CONFIG_MX28_FEC_MAC_IN_OCOTP + +#define MXS_OCOTP_MAX_TIMEOUT 1000000 +void imx_get_mac_from_fuse(char *mac) +{ + struct mx28_ocotp_regs *ocotp_regs = + (struct mx28_ocotp_regs *)MXS_OCOTP_BASE; + uint32_t data; + + memset(mac, 0, 6); + + writel(OCOTP_CTRL_RD_BANK_OPEN, &ocotp_regs->hw_ocotp_ctrl_set); + + if (mx28_wait_mask_clr(&ocotp_regs->hw_ocotp_ctrl_reg, OCOTP_CTRL_BUSY, + MXS_OCOTP_MAX_TIMEOUT)) { + puts("MXS FEC: Can't get MAC from OCOTP\n"); + return; + } + + data = readl(&ocotp_regs->hw_ocotp_cust0); + + mac[0] = 0x00; + mac[1] = 0x04; + mac[2] = (data >> 24) & 0xff; + mac[3] = (data >> 16) & 0xff; + mac[4] = (data >> 8) & 0xff; + mac[5] = data & 0xff; +} +#else +void imx_get_mac_from_fuse(char *mac) +{ + memset(mac, 0, 6); +} +#endif + U_BOOT_CMD( clocks, CONFIG_SYS_MAXARGS, 1, do_mx28_showclocks, "display clocks", diff --git a/arch/arm/include/asm/arch-mx28/sys_proto.h b/arch/arm/include/asm/arch-mx28/sys_proto.h index be1f7db..cf5ab16 100644 --- a/arch/arm/include/asm/arch-mx28/sys_proto.h +++ b/arch/arm/include/asm/arch-mx28/sys_proto.h @@ -35,4 +35,6 @@ void mx28_common_spl_init(const iomux_cfg_t *iomux_setup, const unsigned int iomux_size); #endif
+void imx_get_mac_from_fuse(char *mac); + #endif /* __MX28_H__ */ diff --git a/board/denx/m28evk/m28evk.c b/board/denx/m28evk/m28evk.c index fcee046..005446a 100644 --- a/board/denx/m28evk/m28evk.c +++ b/board/denx/m28evk/m28evk.c @@ -178,39 +178,4 @@ int board_eth_init(bd_t *bis) return ret; }
-#ifdef CONFIG_M28_FEC_MAC_IN_OCOTP - -#define MXS_OCOTP_MAX_TIMEOUT 1000000 -void imx_get_mac_from_fuse(char *mac) -{ - struct mx28_ocotp_regs *ocotp_regs = - (struct mx28_ocotp_regs *)MXS_OCOTP_BASE; - uint32_t data; - - memset(mac, 0, 6); - - writel(OCOTP_CTRL_RD_BANK_OPEN, &ocotp_regs->hw_ocotp_ctrl_set); - - if (mx28_wait_mask_clr(&ocotp_regs->hw_ocotp_ctrl_reg, OCOTP_CTRL_BUSY, - MXS_OCOTP_MAX_TIMEOUT)) { - printf("MXS FEC: Can't get MAC from OCOTP\n"); - return; - } - - data = readl(&ocotp_regs->hw_ocotp_cust0); - - mac[0] = 0x00; - mac[1] = 0x04; - mac[2] = (data >> 24) & 0xff; - mac[3] = (data >> 16) & 0xff; - mac[4] = (data >> 8) & 0xff; - mac[5] = data & 0xff; -} -#else -void imx_get_mac_from_fuse(char *mac) -{ - memset(mac, 0, 6); -} -#endif - #endif
Let dram_init function be a common function, so that other mx28 boards can reuse it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/arm926ejs/mx28/mx28.c | 21 +++++++++++++++++++++ arch/arm/include/asm/arch-mx28/sys_proto.h | 1 + board/denx/m28evk/m28evk.c | 21 --------------------- 3 files changed, 22 insertions(+), 21 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c index 785978f..ec8eaf9 100644 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ b/arch/arm/cpu/arm926ejs/mx28/mx28.c @@ -249,6 +249,27 @@ void imx_get_mac_from_fuse(char *mac) } #endif
+#define HW_DIGCTRL_SCRATCH0 0x8001c280 +#define HW_DIGCTRL_SCRATCH1 0x8001c290 +int dram_init(void) +{ + uint32_t sz[2]; + + sz[0] = readl(HW_DIGCTRL_SCRATCH0); + sz[1] = readl(HW_DIGCTRL_SCRATCH1); + + if (sz[0] != sz[1]) { + puts("MX28:\n" + "Error, the RAM size in HW_DIGCTRL_SCRATCH0 and\n" + "HW_DIGCTRL_SCRATCH1 is not the same. Please\n" + "verify these two registers contain valid RAM size!\n"); + hang(); + } + + gd->ram_size = sz[0]; + return 0; +} + U_BOOT_CMD( clocks, CONFIG_SYS_MAXARGS, 1, do_mx28_showclocks, "display clocks", diff --git a/arch/arm/include/asm/arch-mx28/sys_proto.h b/arch/arm/include/asm/arch-mx28/sys_proto.h index cf5ab16..745b84d 100644 --- a/arch/arm/include/asm/arch-mx28/sys_proto.h +++ b/arch/arm/include/asm/arch-mx28/sys_proto.h @@ -36,5 +36,6 @@ void mx28_common_spl_init(const iomux_cfg_t *iomux_setup, #endif
void imx_get_mac_from_fuse(char *mac); +int dram_init(void);
#endif /* __MX28_H__ */ diff --git a/board/denx/m28evk/m28evk.c b/board/denx/m28evk/m28evk.c index 005446a..d6a2a50 100644 --- a/board/denx/m28evk/m28evk.c +++ b/board/denx/m28evk/m28evk.c @@ -70,27 +70,6 @@ int board_init(void) return 0; }
-#define HW_DIGCTRL_SCRATCH0 0x8001c280 -#define HW_DIGCTRL_SCRATCH1 0x8001c290 -int dram_init(void) -{ - uint32_t sz[2]; - - sz[0] = readl(HW_DIGCTRL_SCRATCH0); - sz[1] = readl(HW_DIGCTRL_SCRATCH1); - - if (sz[0] != sz[1]) { - printf("MX28:\n" - "Error, the RAM size in HW_DIGCTRL_SCRATCH0 and\n" - "HW_DIGCTRL_SCRATCH1 is not the same. Please\n" - "verify these two registers contain valid RAM size!\n"); - hang(); - } - - gd->ram_size = sz[0]; - return 0; -} - #ifdef CONFIG_CMD_MMC static int m28_mmc_wp(int id) {
- uint32_t sz[2];
puts("MX28:\n"
hang();
Rename it to mx28_dram_init() or something please.
- uint32_t sz[2];
printf("MX28:\n"
hang();
M
Add initial support for Freescale MX28EVK board.
Tested boot via SD card and by loading a kernel via TFTP through the FEC interface.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- - For correct operation of saving environment variables into the SD card, the following patch is needed: http://lists.denx.de/pipermail/u-boot/2011-November/111448.html
Changes since v1: - Read the MAC from fuses - Use tabs instead of space in u-boot.bd - Use puts instead of print - Factor out mac reading function - Factor out ddr size calculation function - Use GENERATED_GBL_DATA_SIZE - Protect CONFIG_ENV_IS_IN_MMC
MAINTAINERS | 1 + arch/arm/cpu/arm926ejs/mx28/mx28.c | 56 +++++++++ arch/arm/include/asm/arch-mx28/sys_proto.h | 3 + board/denx/m28evk/m28evk.c | 56 --------- board/freescale/common/sdhc_boot.c | 2 + board/freescale/mx28evk/Makefile | 49 ++++++++ board/freescale/mx28evk/iomux.c | 138 ++++++++++++++++++++++ board/freescale/mx28evk/mx28evk.c | 164 ++++++++++++++++++++++++++ board/freescale/mx28evk/u-boot.bd | 14 +++ boards.cfg | 1 + include/configs/mx28evk.h | 172 ++++++++++++++++++++++++++++ 11 files changed, 600 insertions(+), 56 deletions(-) create mode 100644 board/freescale/mx28evk/Makefile create mode 100644 board/freescale/mx28evk/iomux.c create mode 100644 board/freescale/mx28evk/mx28evk.c create mode 100644 board/freescale/mx28evk/u-boot.bd create mode 100644 include/configs/mx28evk.h
diff --git a/MAINTAINERS b/MAINTAINERS index a56ca10..72e1089 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -639,6 +639,7 @@ Kristoffer Ericson kristoffer.ericson@gmail.com Fabio Estevam fabio.estevam@freescale.com
mx25pdk i.MX25 + mx28evk i.MX28 mx31pdk i.MX31 mx53ard i.MX53 mx53smd i.MX53 diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c index 088c019..e15b158 100644 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ b/arch/arm/cpu/arm926ejs/mx28/mx28.c @@ -214,6 +214,62 @@ int cpu_eth_init(bd_t *bis) } #endif
+#ifdef CONFIG_MX28_FEC_MAC_IN_OCOTP + +#define MXS_OCOTP_MAX_TIMEOUT 1000000 +void imx_get_mac_from_fuse(char *mac) +{ + struct mx28_ocotp_regs *ocotp_regs = + (struct mx28_ocotp_regs *)MXS_OCOTP_BASE; + uint32_t data; + + memset(mac, 0, 6); + + writel(OCOTP_CTRL_RD_BANK_OPEN, &ocotp_regs->hw_ocotp_ctrl_set); + + if (mx28_wait_mask_clr(&ocotp_regs->hw_ocotp_ctrl_reg, OCOTP_CTRL_BUSY, + MXS_OCOTP_MAX_TIMEOUT)) { + puts("MXS FEC: Can't get MAC from OCOTP\n"); + return; + } + + data = readl(&ocotp_regs->hw_ocotp_cust0); + + mac[0] = 0x00; + mac[1] = 0x04; + mac[2] = (data >> 24) & 0xff; + mac[3] = (data >> 16) & 0xff; + mac[4] = (data >> 8) & 0xff; + mac[5] = data & 0xff; +} +#else +void imx_get_mac_from_fuse(char *mac) +{ + memset(mac, 0, 6); +} +#endif + +#define HW_DIGCTRL_SCRATCH0 0x8001c280 +#define HW_DIGCTRL_SCRATCH1 0x8001c290 +int dram_init(void) +{ + uint32_t sz[2]; + + sz[0] = readl(HW_DIGCTRL_SCRATCH0); + sz[1] = readl(HW_DIGCTRL_SCRATCH1); + + if (sz[0] != sz[1]) { + puts("MX28:\n" + "Error, the RAM size in HW_DIGCTRL_SCRATCH0 and\n" + "HW_DIGCTRL_SCRATCH1 is not the same. Please\n" + "verify these two registers contain valid RAM size!\n"); + hang(); + } + + gd->ram_size = sz[0]; + return 0; +} + U_BOOT_CMD( clocks, CONFIG_SYS_MAXARGS, 1, do_mx28_showclocks, "display clocks", diff --git a/arch/arm/include/asm/arch-mx28/sys_proto.h b/arch/arm/include/asm/arch-mx28/sys_proto.h index be1f7db..745b84d 100644 --- a/arch/arm/include/asm/arch-mx28/sys_proto.h +++ b/arch/arm/include/asm/arch-mx28/sys_proto.h @@ -35,4 +35,7 @@ void mx28_common_spl_init(const iomux_cfg_t *iomux_setup, const unsigned int iomux_size); #endif
+void imx_get_mac_from_fuse(char *mac); +int dram_init(void); + #endif /* __MX28_H__ */ diff --git a/board/denx/m28evk/m28evk.c b/board/denx/m28evk/m28evk.c index fcee046..d6a2a50 100644 --- a/board/denx/m28evk/m28evk.c +++ b/board/denx/m28evk/m28evk.c @@ -70,27 +70,6 @@ int board_init(void) return 0; }
-#define HW_DIGCTRL_SCRATCH0 0x8001c280 -#define HW_DIGCTRL_SCRATCH1 0x8001c290 -int dram_init(void) -{ - uint32_t sz[2]; - - sz[0] = readl(HW_DIGCTRL_SCRATCH0); - sz[1] = readl(HW_DIGCTRL_SCRATCH1); - - if (sz[0] != sz[1]) { - printf("MX28:\n" - "Error, the RAM size in HW_DIGCTRL_SCRATCH0 and\n" - "HW_DIGCTRL_SCRATCH1 is not the same. Please\n" - "verify these two registers contain valid RAM size!\n"); - hang(); - } - - gd->ram_size = sz[0]; - return 0; -} - #ifdef CONFIG_CMD_MMC static int m28_mmc_wp(int id) { @@ -178,39 +157,4 @@ int board_eth_init(bd_t *bis) return ret; }
-#ifdef CONFIG_M28_FEC_MAC_IN_OCOTP - -#define MXS_OCOTP_MAX_TIMEOUT 1000000 -void imx_get_mac_from_fuse(char *mac) -{ - struct mx28_ocotp_regs *ocotp_regs = - (struct mx28_ocotp_regs *)MXS_OCOTP_BASE; - uint32_t data; - - memset(mac, 0, 6); - - writel(OCOTP_CTRL_RD_BANK_OPEN, &ocotp_regs->hw_ocotp_ctrl_set); - - if (mx28_wait_mask_clr(&ocotp_regs->hw_ocotp_ctrl_reg, OCOTP_CTRL_BUSY, - MXS_OCOTP_MAX_TIMEOUT)) { - printf("MXS FEC: Can't get MAC from OCOTP\n"); - return; - } - - data = readl(&ocotp_regs->hw_ocotp_cust0); - - mac[0] = 0x00; - mac[1] = 0x04; - mac[2] = (data >> 24) & 0xff; - mac[3] = (data >> 16) & 0xff; - mac[4] = (data >> 8) & 0xff; - mac[5] = data & 0xff; -} -#else -void imx_get_mac_from_fuse(char *mac) -{ - memset(mac, 0, 6); -} -#endif - #endif diff --git a/board/freescale/common/sdhc_boot.c b/board/freescale/common/sdhc_boot.c index e432318..40b40df 100644 --- a/board/freescale/common/sdhc_boot.c +++ b/board/freescale/common/sdhc_boot.c @@ -32,6 +32,7 @@ #define ESDHC_BOOT_IMAGE_SIZE 0x48 #define ESDHC_BOOT_IMAGE_ADDR 0x50
+#if 0 int mmc_get_env_addr(struct mmc *mmc, u32 *env_addr) { u8 *tmp_buf; @@ -61,3 +62,4 @@ int mmc_get_env_addr(struct mmc *mmc, u32 *env_addr)
return 0; } +#endif diff --git a/board/freescale/mx28evk/Makefile b/board/freescale/mx28evk/Makefile new file mode 100644 index 0000000..7459107 --- /dev/null +++ b/board/freescale/mx28evk/Makefile @@ -0,0 +1,49 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifndef CONFIG_SPL_BUILD +COBJS := mx28evk.o +else +COBJS := iomux.o +endif + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +all: $(ALL) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx28evk/iomux.c b/board/freescale/mx28evk/iomux.c new file mode 100644 index 0000000..904e3f3 --- /dev/null +++ b/board/freescale/mx28evk/iomux.c @@ -0,0 +1,138 @@ +/* + * Freescale MX28EVK IOMUX setup + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> + +#define MUX_CONFIG_SSP0 (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_ENET (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_EMI (MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_NOPULL) + +const iomux_cfg_t iomux_setup[] = { + /* DUART */ + MX28_PAD_PWM0__DUART_RX, + MX28_PAD_PWM1__DUART_TX, + + /* MMC0 */ + MX28_PAD_SSP0_DATA0__SSP0_D0 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA1__SSP0_D1 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA2__SSP0_D2 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA3__SSP0_D3 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA4__SSP0_D4 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA5__SSP0_D5 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA6__SSP0_D6 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA7__SSP0_D7 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_CMD__SSP0_CMD | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT | + (MXS_PAD_8MA | MXS_PAD_3V3 | MXS_PAD_NOPULL), + MX28_PAD_SSP0_SCK__SSP0_SCK | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_NOPULL), + /* write protect */ + MX28_PAD_SSP1_SCK__GPIO_2_12, + /* MMC0 slot power enable */ + MX28_PAD_PWM3__GPIO_3_28 | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_PULLUP), + + /* FEC0 */ + MX28_PAD_ENET0_MDC__ENET0_MDC | MUX_CONFIG_ENET, + MX28_PAD_ENET0_MDIO__ENET0_MDIO | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RX_EN__ENET0_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TX_EN__ENET0_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD0__ENET0_RXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD1__ENET0_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD0__ENET0_TXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD1__ENET0_TXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET_CLK__CLKCTRL_ENET | MUX_CONFIG_ENET, + /* FEC0 Enable */ + MX28_PAD_SSP1_DATA3__GPIO_2_15 | + (MXS_PAD_12MA | MXS_PAD_3V3), + /* FEC0 Reset */ + MX28_PAD_ENET0_RX_CLK__GPIO_4_13 | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_PULLUP), + + /* FEC1 */ + MX28_PAD_ENET0_COL__ENET1_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_CRS__ENET1_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD2__ENET1_RXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD3__ENET1_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD2__ENET1_TXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD3__ENET1_TXD1 | MUX_CONFIG_ENET, + + /* EMI */ + MX28_PAD_EMI_D00__EMI_DATA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D01__EMI_DATA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D02__EMI_DATA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D03__EMI_DATA3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D04__EMI_DATA4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D05__EMI_DATA5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D06__EMI_DATA6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D07__EMI_DATA7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D08__EMI_DATA8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D09__EMI_DATA9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D10__EMI_DATA10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D11__EMI_DATA11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D12__EMI_DATA12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D13__EMI_DATA13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D14__EMI_DATA14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D15__EMI_DATA15 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT0__EMI_ODT0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM0__EMI_DQM0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT1__EMI_ODT1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM1__EMI_DQM1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN_FB__EMI_DDR_OPEN_FEEDBACK | MUX_CONFIG_EMI, + MX28_PAD_EMI_CLK__EMI_CLK | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS0__EMI_DQS0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS1__EMI_DQS1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN__EMI_DDR_OPEN | MUX_CONFIG_EMI, + + MX28_PAD_EMI_A00__EMI_ADDR0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A01__EMI_ADDR1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A02__EMI_ADDR2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A03__EMI_ADDR3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A04__EMI_ADDR4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A05__EMI_ADDR5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A06__EMI_ADDR6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A07__EMI_ADDR7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A08__EMI_ADDR8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A09__EMI_ADDR9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A10__EMI_ADDR10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A11__EMI_ADDR11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A12__EMI_ADDR12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A13__EMI_ADDR13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A14__EMI_ADDR14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA0__EMI_BA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA1__EMI_BA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA2__EMI_BA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_CASN__EMI_CASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_RASN__EMI_RASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_WEN__EMI_WEN | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE0N__EMI_CE0N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE1N__EMI_CE1N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CKE__EMI_CKE | MUX_CONFIG_EMI, +}; + +void board_init_ll(void) +{ + mx28_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup)); +} diff --git a/board/freescale/mx28evk/mx28evk.c b/board/freescale/mx28evk/mx28evk.c new file mode 100644 index 0000000..748180b --- /dev/null +++ b/board/freescale/mx28evk/mx28evk.c @@ -0,0 +1,164 @@ +/* + * Freescale MX28EVK board + * + * (C) Copyright 2011 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * Based on m28evk.c: + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <linux/mii.h> +#include <miiphy.h> +#include <netdev.h> +#include <errno.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Functions + */ +int board_early_init_f(void) +{ + /* IO0 clock at 480MHz */ + mx28_set_ioclk(MXC_IOCLK0, 480000); + /* IO1 clock at 480MHz */ + mx28_set_ioclk(MXC_IOCLK1, 480000); + + /* SSP0 clock at 96MHz */ + mx28_set_sspclk(MXC_SSPCLK0, 96000, 0); + /* SSP2 clock at 96MHz */ + mx28_set_sspclk(MXC_SSPCLK2, 96000, 0); + + return 0; +} + +int board_init(void) +{ + /* Adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + +#ifdef CONFIG_CMD_MMC +static int mx28evk_mmc_wp(int id) +{ + if (id != 0) { + printf("MXS MMC: Invalid card selected (card id = %d)\n", id); + return 1; + } + + return gpio_get_value(MX28_PAD_SSP1_SCK__GPIO_2_12); +} + +int board_mmc_init(bd_t *bis) +{ + /* Configure WP as input */ + gpio_direction_input(MX28_PAD_SSP1_SCK__GPIO_2_12); + + /* Configure MMC0 Power Enable */ + gpio_direction_output(MX28_PAD_PWM3__GPIO_3_28, 0); + + return mxsmmc_initialize(bis, 0, mx28evk_mmc_wp); +} +#endif + +#ifdef CONFIG_CMD_NET + +#define MII_OPMODE_STRAP_OVERRIDE 0x16 +#define MII_PHY_CTRL1 0x1e +#define MII_PHY_CTRL2 0x1f + +int fecmxc_mii_postcall(int phy) +{ + miiphy_write("FEC1", phy, MII_BMCR, 0x9000); + miiphy_write("FEC1", phy, MII_OPMODE_STRAP_OVERRIDE, 0x0202); + if (phy == 3) + miiphy_write("FEC1", 3, MII_PHY_CTRL2, 0x8180); + return 0; +} + +int board_eth_init(bd_t *bis) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + struct eth_device *dev; + int ret; + + ret = cpu_eth_init(bis); + + /* MX28EVK uses ENET_CLK PAD to drive FEC clock */ + writel(CLKCTRL_ENET_TIME_SEL_RMII_CLK | CLKCTRL_ENET_CLK_OUT_EN, + &clkctrl_regs->hw_clkctrl_enet); + + /* Power-on FECs */ + gpio_direction_output(MX28_PAD_SSP1_DATA3__GPIO_2_15, 0); + + /* Reset FEC PHYs */ + gpio_direction_output(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 0); + udelay(200); + gpio_set_value(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 1); + + ret = fecmxc_initialize_multi(bis, 0, 0, MXS_ENET0_BASE); + if (ret) { + puts("FEC MXS: Unable to init FEC0\n"); + return ret; + } + + ret = fecmxc_initialize_multi(bis, 1, 3, MXS_ENET1_BASE); + if (ret) { + puts("FEC MXS: Unable to init FEC1\n"); + return ret; + } + + dev = eth_get_dev_by_name("FEC0"); + if (!dev) { + puts("FEC MXS: Unable to get FEC0 device entry\n"); + return -EINVAL; + } + + ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); + if (ret) { + puts("FEC MXS: Unable to register FEC0 mii postcall\n"); + return ret; + } + + dev = eth_get_dev_by_name("FEC1"); + if (!dev) { + puts("FEC MXS: Unable to get FEC1 device entry\n"); + return -EINVAL; + } + + ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); + if (ret) { + puts("FEC MXS: Unable to register FEC1 mii postcall\n"); + return ret; + } + + return ret; +} + +#endif diff --git a/board/freescale/mx28evk/u-boot.bd b/board/freescale/mx28evk/u-boot.bd new file mode 100644 index 0000000..c60615a --- /dev/null +++ b/board/freescale/mx28evk/u-boot.bd @@ -0,0 +1,14 @@ +sources { + u_boot_spl="spl/u-boot-spl.bin"; + u_boot="u-boot.bin"; +} + +section (0) { + load u_boot_spl > 0x0000; + load ivt (entry = 0x0014) > 0x8000; + hab call 0x8000; + + load u_boot > 0x40000100; + load ivt (entry = 0x40000100) > 0x8000; + hab call 0x8000; +} diff --git a/boards.cfg b/boards.cfg index 1e5b3e0..e859024 100644 --- a/boards.cfg +++ b/boards.cfg @@ -160,6 +160,7 @@ zmx25 arm arm926ejs zmx25 syteco imx27lite arm arm926ejs imx27lite logicpd mx27 magnesium arm arm926ejs imx27lite logicpd mx27 m28evk arm arm926ejs - denx mx28 +mx28evk arm arm926ejs - freescale mx28 nhk8815 arm arm926ejs nhk8815 st nomadik nhk8815_onenand arm arm926ejs nhk8815 st nomadik nhk8815:BOOT_ONENAND omap1610h2 arm arm926ejs omap1610inn ti omap omap1610inn:CS3_BOOT diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h new file mode 100644 index 0000000..40b64bf --- /dev/null +++ b/include/configs/mx28evk.h @@ -0,0 +1,172 @@ +/* + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/regs-base.h> + +/* + * SoC configurations + */ +#define CONFIG_MX28 /* i.MX28 SoC */ +#define CONFIG_MXS_GPIO /* GPIO control */ +#define CONFIG_SYS_HZ 1000 /* Ticks per second */ + +#define CONFIG_MACH_TYPE MACH_TYPE_MX28EVK + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_ARCH_MISC_INIT + +/* + * SPL + */ +#define CONFIG_SPL +#define CONFIG_SPL_NO_CPU_SUPPORT_CODE +#define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mx28" +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT + +/* + * U-Boot Commands + */ +#include <config_cmd_default.h> +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_MII +#define CONFIG_CMD_MMC +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PING + +/* + * Memory configurations + */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0x40000000 /* Base address */ +#define PHYS_SDRAM_1_SIZE 0x40000000 /* Max 1 GB RAM */ +#define CONFIG_STACKSIZE (128 * 1024) /* 128 KB stack */ +#define CONFIG_SYS_MALLOC_LEN 0x00400000 /* 4 MB for malloc */ +#define CONFIG_SYS_MEMTEST_START 0x40000000 /* Memtest start adr */ +#define CONFIG_SYS_MEMTEST_END 0x40400000 /* 4 MB RAM test */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +/* Point initial SP in SRAM so SPL can use it too. */ + +#define CONFIG_SYS_INIT_RAM_ADDR 0x00002000 +#define CONFIG_SYS_INIT_RAM_SIZE (128 * 1024) + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* + * We need to sacrifice first 4 bytes of RAM here to avoid triggering some + * strange BUG in ROM corrupting first 4 bytes of RAM when loading U-Boot + * binary. In case there was more of this mess, 0x100 bytes are skipped. + */ +#define CONFIG_SYS_TEXT_BASE 0x40000100 + +#define CONFIG_ENV_OVERWRITE +/* + * U-Boot general configurations + */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "MX28EVK U-Boot > " +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O buffer size */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + /* Print buffer size */ +#define CONFIG_SYS_MAXARGS 32 /* Max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + /* Boot argument buffer size */ +#define CONFIG_VERSION_VARIABLE /* U-BOOT version */ +#define CONFIG_AUTO_COMPLETE /* Command auto complete */ +#define CONFIG_CMDLINE_EDITING /* Command history etc */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* + * Serial Driver + */ +#define CONFIG_PL011_SERIAL +#define CONFIG_PL011_CLOCK 24000000 +#define CONFIG_PL01x_PORTS { (void *)MXS_UARTDBG_BASE } +#define CONFIG_CONS_INDEX 0 +#define CONFIG_BAUDRATE 115200 /* Default baud rate */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * MMC Driver + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (256 * 1024) +#define CONFIG_ENV_SIZE (16 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_CMD_SAVEENV +#define CONFIG_GENERIC_MMC +#define CONFIG_MXS_MMC +#endif + +/* + * Ethernet on SOC (FEC) + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_NET_MULTI +#define CONFIG_ETHPRIME "FEC0" +#define CONFIG_FEC_MXC +#define CONFIG_FEC_MXC_MULTI +#define CONFIG_MII +#define CONFIG_DISCOVER_PHY +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_MX28_FEC_MAC_IN_OCOTP +#endif + +/* + * Boot Linux + */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_BOOTCOMMAND "run bootcmd_net" +#define CONFIG_LOADADDR 0x42000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* + * Extra Environments + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console_fsl=console=ttyAM0" \ + "console_mainline=console=ttyAMA0" \ + "netargs=setenv bootargs console=${console_mainline}" \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot}\0" \ + "bootcmd_net=echo Booting from net ...; " \ + "run netargs; " \ + "dhcp ${uimage}; bootm\0" \ + +#endif /* __CONFIG_H */
Changes since v1:
mx25pdk i.MX25
- mx28evk i.MX28 mx31pdk i.MX31 mx53ard i.MX53 mx53smd i.MX53
- uint32_t data;
Wait...this patch conflict with your first patch of your patchset, where you have already move this code in a common place. Anything wrong with your patchset ?
Regards, Stefano
Sorry about that. I sent a fixed v3 version.
Thanks,
Fabio Estevam
Please add summaries (what does "v2" "v3" etc. change ...) so we don't have to review this again and again.
M
Hi Fabio,
return;
- mac[0] = 0x00;
- mac[1] = 0x04;
Maybe it is worth to add a comment to explain that the magic numbers 0x00 - 0x04 are the Freescale's vendor prefix.
Best regards, Stefano Babic
Dear Fabio,
Hi Fabio,
return;
- mac[0] = 0x00;
- mac[1] = 0x04;
This is a common file, right? Then what about boards from other vendors?
I think this is not OK as is.
Changes since v2: - Generate the patch again due to error in applying unrelated changes Changes since v1: - Read the MAC from fuses - Use tabs instead of space in u-boot.bd - Use puts instead of print - Factor out mac reading function - Factor out ddr size calculation function - Use GENERATED_GBL_DATA_SIZE - Protect CONFIG_ENV_IS_IN_MMC MAINTAINERS | 1 + board/freescale/mx28evk/Makefile | 49 +++++++++++ board/freescale/mx28evk/iomux.c | 138 +++++++++++++++++++++++++++++ board/freescale/mx28evk/mx28evk.c | 164 +++++++++++++++++++++++++++++++++++ board/freescale/mx28evk/u-boot.bd | 14 +++ boards.cfg | 1 + include/configs/mx28evk.h | 172 +++++++++++++++++++++++++++++++++++++ 7 files changed, 539 insertions(+), 0 deletions(-) create mode 100644 board/freescale/mx28evk/Makefile create mode 100644 board/freescale/mx28evk/iomux.c create mode 100644 board/freescale/mx28evk/mx28evk.c create mode 100644 board/freescale/mx28evk/u-boot.bd create mode 100644 include/configs/mx28evk.h
mx25pdk i.MX25 + mx28evk i.MX28 mx31pdk i.MX31 mx53ard i.MX53 mx53smd i.MX53 diff --git a/board/freescale/mx28evk/Makefile b/board/freescale/mx28evk/Makefile new file mode 100644 index 0000000..7459107 --- /dev/null +++ b/board/freescale/mx28evk/Makefile @@ -0,0 +1,49 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifndef CONFIG_SPL_BUILD +COBJS := mx28evk.o +else +COBJS := iomux.o +endif + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +all: $(ALL) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx28evk/iomux.c b/board/freescale/mx28evk/iomux.c new file mode 100644 index 0000000..904e3f3 --- /dev/null +++ b/board/freescale/mx28evk/iomux.c @@ -0,0 +1,138 @@ +/* + * Freescale MX28EVK IOMUX setup + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> + +#define MUX_CONFIG_SSP0 (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_ENET (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_EMI (MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_NOPULL) + +const iomux_cfg_t iomux_setup[] = { + /* DUART */ + MX28_PAD_PWM0__DUART_RX, + MX28_PAD_PWM1__DUART_TX, + + /* MMC0 */ + MX28_PAD_SSP0_DATA0__SSP0_D0 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA1__SSP0_D1 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA2__SSP0_D2 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA3__SSP0_D3 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA4__SSP0_D4 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA5__SSP0_D5 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA6__SSP0_D6 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA7__SSP0_D7 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_CMD__SSP0_CMD | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT | + (MXS_PAD_8MA | MXS_PAD_3V3 | MXS_PAD_NOPULL), + MX28_PAD_SSP0_SCK__SSP0_SCK | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_NOPULL), + /* write protect */ + MX28_PAD_SSP1_SCK__GPIO_2_12, + /* MMC0 slot power enable */ + MX28_PAD_PWM3__GPIO_3_28 | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_PULLUP), + + /* FEC0 */ + MX28_PAD_ENET0_MDC__ENET0_MDC | MUX_CONFIG_ENET, + MX28_PAD_ENET0_MDIO__ENET0_MDIO | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RX_EN__ENET0_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TX_EN__ENET0_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD0__ENET0_RXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD1__ENET0_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD0__ENET0_TXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD1__ENET0_TXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET_CLK__CLKCTRL_ENET | MUX_CONFIG_ENET, + /* FEC0 Enable */ + MX28_PAD_SSP1_DATA3__GPIO_2_15 | + (MXS_PAD_12MA | MXS_PAD_3V3), + /* FEC0 Reset */ + MX28_PAD_ENET0_RX_CLK__GPIO_4_13 | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_PULLUP), + + /* FEC1 */ + MX28_PAD_ENET0_COL__ENET1_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_CRS__ENET1_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD2__ENET1_RXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD3__ENET1_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD2__ENET1_TXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD3__ENET1_TXD1 | MUX_CONFIG_ENET, + + /* EMI */ + MX28_PAD_EMI_D00__EMI_DATA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D01__EMI_DATA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D02__EMI_DATA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D03__EMI_DATA3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D04__EMI_DATA4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D05__EMI_DATA5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D06__EMI_DATA6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D07__EMI_DATA7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D08__EMI_DATA8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D09__EMI_DATA9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D10__EMI_DATA10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D11__EMI_DATA11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D12__EMI_DATA12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D13__EMI_DATA13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D14__EMI_DATA14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D15__EMI_DATA15 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT0__EMI_ODT0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM0__EMI_DQM0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT1__EMI_ODT1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM1__EMI_DQM1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN_FB__EMI_DDR_OPEN_FEEDBACK | MUX_CONFIG_EMI, + MX28_PAD_EMI_CLK__EMI_CLK | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS0__EMI_DQS0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS1__EMI_DQS1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN__EMI_DDR_OPEN | MUX_CONFIG_EMI, + + MX28_PAD_EMI_A00__EMI_ADDR0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A01__EMI_ADDR1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A02__EMI_ADDR2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A03__EMI_ADDR3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A04__EMI_ADDR4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A05__EMI_ADDR5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A06__EMI_ADDR6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A07__EMI_ADDR7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A08__EMI_ADDR8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A09__EMI_ADDR9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A10__EMI_ADDR10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A11__EMI_ADDR11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A12__EMI_ADDR12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A13__EMI_ADDR13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A14__EMI_ADDR14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA0__EMI_BA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA1__EMI_BA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA2__EMI_BA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_CASN__EMI_CASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_RASN__EMI_RASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_WEN__EMI_WEN | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE0N__EMI_CE0N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE1N__EMI_CE1N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CKE__EMI_CKE | MUX_CONFIG_EMI, +}; + +void board_init_ll(void) +{ + mx28_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup)); +} diff --git a/board/freescale/mx28evk/mx28evk.c b/board/freescale/mx28evk/mx28evk.c new file mode 100644 index 0000000..748180b --- /dev/null +++ b/board/freescale/mx28evk/mx28evk.c @@ -0,0 +1,164 @@ +/* + * Freescale MX28EVK board + * + * (C) Copyright 2011 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * Based on m28evk.c: + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <linux/mii.h> +#include <miiphy.h> +#include <netdev.h> +#include <errno.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Functions + */ +int board_early_init_f(void) +{ + /* IO0 clock at 480MHz */ + mx28_set_ioclk(MXC_IOCLK0, 480000); + /* IO1 clock at 480MHz */ + mx28_set_ioclk(MXC_IOCLK1, 480000); + + /* SSP0 clock at 96MHz */ + mx28_set_sspclk(MXC_SSPCLK0, 96000, 0); + /* SSP2 clock at 96MHz */ + mx28_set_sspclk(MXC_SSPCLK2, 96000, 0); + + return 0; +} + +int board_init(void) +{ + /* Adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + +#ifdef CONFIG_CMD_MMC +static int mx28evk_mmc_wp(int id) +{ + if (id != 0) { + printf("MXS MMC: Invalid card selected (card id = %d)\n", id); + return 1; + } + + return gpio_get_value(MX28_PAD_SSP1_SCK__GPIO_2_12); +} + +int board_mmc_init(bd_t *bis) +{ + /* Configure WP as input */ + gpio_direction_input(MX28_PAD_SSP1_SCK__GPIO_2_12); + + /* Configure MMC0 Power Enable */ + gpio_direction_output(MX28_PAD_PWM3__GPIO_3_28, 0); + + return mxsmmc_initialize(bis, 0, mx28evk_mmc_wp); +} +#endif + +#ifdef CONFIG_CMD_NET + +#define MII_OPMODE_STRAP_OVERRIDE 0x16 +#define MII_PHY_CTRL1 0x1e +#define MII_PHY_CTRL2 0x1f + +int fecmxc_mii_postcall(int phy) +{ + miiphy_write("FEC1", phy, MII_BMCR, 0x9000); + miiphy_write("FEC1", phy, MII_OPMODE_STRAP_OVERRIDE, 0x0202); + if (phy == 3) + miiphy_write("FEC1", 3, MII_PHY_CTRL2, 0x8180); + return 0; +} + +int board_eth_init(bd_t *bis) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + struct eth_device *dev; + int ret; + + ret = cpu_eth_init(bis); + + /* MX28EVK uses ENET_CLK PAD to drive FEC clock */ + writel(CLKCTRL_ENET_TIME_SEL_RMII_CLK | CLKCTRL_ENET_CLK_OUT_EN, + &clkctrl_regs->hw_clkctrl_enet); + + /* Power-on FECs */ + gpio_direction_output(MX28_PAD_SSP1_DATA3__GPIO_2_15, 0); + + /* Reset FEC PHYs */ + gpio_direction_output(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 0); + udelay(200); + gpio_set_value(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 1); + + ret = fecmxc_initialize_multi(bis, 0, 0, MXS_ENET0_BASE); + if (ret) { + puts("FEC MXS: Unable to init FEC0\n"); + return ret; + } + + ret = fecmxc_initialize_multi(bis, 1, 3, MXS_ENET1_BASE); + if (ret) { + puts("FEC MXS: Unable to init FEC1\n"); + return ret; + } + + dev = eth_get_dev_by_name("FEC0"); + if (!dev) { + puts("FEC MXS: Unable to get FEC0 device entry\n"); + return -EINVAL; + } + + ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); + if (ret) { + puts("FEC MXS: Unable to register FEC0 mii postcall\n"); + return ret; + } + + dev = eth_get_dev_by_name("FEC1"); + if (!dev) { + puts("FEC MXS: Unable to get FEC1 device entry\n"); + return -EINVAL; + } + + ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); + if (ret) { + puts("FEC MXS: Unable to register FEC1 mii postcall\n"); + return ret; + } + + return ret; +} + +#endif diff --git a/board/freescale/mx28evk/u-boot.bd b/board/freescale/mx28evk/u-boot.bd new file mode 100644 index 0000000..c60615a --- /dev/null +++ b/board/freescale/mx28evk/u-boot.bd @@ -0,0 +1,14 @@ +sources { + u_boot_spl="spl/u-boot-spl.bin"; + u_boot="u-boot.bin"; +} + +section (0) { + load u_boot_spl > 0x0000; + load ivt (entry = 0x0014) > 0x8000; + hab call 0x8000; + + load u_boot > 0x40000100; + load ivt (entry = 0x40000100) > 0x8000; + hab call 0x8000; +} diff --git a/boards.cfg b/boards.cfg index 1e5b3e0..e859024 100644 --- a/boards.cfg +++ b/boards.cfg @@ -160,6 +160,7 @@ zmx25 arm arm926ejs zmx25 syteco imx27lite arm arm926ejs imx27lite logicpd mx27 magnesium arm arm926ejs imx27lite logicpd mx27 m28evk arm arm926ejs - denx mx28 +mx28evk arm arm926ejs - freescale mx28 nhk8815 arm arm926ejs nhk8815 st nomadik nhk8815_onenand arm arm926ejs nhk8815 st nomadik nhk8815:BOOT_ONENAND omap1610h2 arm arm926ejs omap1610inn ti omap omap1610inn:CS3_BOOT diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h new file mode 100644 index 0000000..40b64bf --- /dev/null +++ b/include/configs/mx28evk.h @@ -0,0 +1,172 @@ +/* + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/regs-base.h> + +/* + * SoC configurations + */ +#define CONFIG_MX28 /* i.MX28 SoC */ +#define CONFIG_MXS_GPIO /* GPIO control */ +#define CONFIG_SYS_HZ 1000 /* Ticks per second */ + +#define CONFIG_MACH_TYPE MACH_TYPE_MX28EVK + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_ARCH_MISC_INIT + +/* + * SPL + */ +#define CONFIG_SPL +#define CONFIG_SPL_NO_CPU_SUPPORT_CODE +#define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mx28" +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT + +/* + * U-Boot Commands + */ +#include <config_cmd_default.h> +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_MII +#define CONFIG_CMD_MMC +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PING + +/* + * Memory configurations + */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0x40000000 /* Base address */ +#define PHYS_SDRAM_1_SIZE 0x40000000 /* Max 1 GB RAM */ +#define CONFIG_STACKSIZE (128 * 1024) /* 128 KB stack */ +#define CONFIG_SYS_MALLOC_LEN 0x00400000 /* 4 MB for malloc */ +#define CONFIG_SYS_MEMTEST_START 0x40000000 /* Memtest start adr */ +#define CONFIG_SYS_MEMTEST_END 0x40400000 /* 4 MB RAM test */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +/* Point initial SP in SRAM so SPL can use it too. */ + +#define CONFIG_SYS_INIT_RAM_ADDR 0x00002000 +#define CONFIG_SYS_INIT_RAM_SIZE (128 * 1024) + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* + * We need to sacrifice first 4 bytes of RAM here to avoid triggering some + * strange BUG in ROM corrupting first 4 bytes of RAM when loading U-Boot + * binary. In case there was more of this mess, 0x100 bytes are skipped. + */ +#define CONFIG_SYS_TEXT_BASE 0x40000100 + +#define CONFIG_ENV_OVERWRITE +/* + * U-Boot general configurations + */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "MX28EVK U-Boot > " +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O buffer size */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + /* Print buffer size */ +#define CONFIG_SYS_MAXARGS 32 /* Max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + /* Boot argument buffer size */ +#define CONFIG_VERSION_VARIABLE /* U-BOOT version */ +#define CONFIG_AUTO_COMPLETE /* Command auto complete */ +#define CONFIG_CMDLINE_EDITING /* Command history etc */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* + * Serial Driver + */ +#define CONFIG_PL011_SERIAL +#define CONFIG_PL011_CLOCK 24000000 +#define CONFIG_PL01x_PORTS { (void *)MXS_UARTDBG_BASE } +#define CONFIG_CONS_INDEX 0 +#define CONFIG_BAUDRATE 115200 /* Default baud rate */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * MMC Driver + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (256 * 1024) +#define CONFIG_ENV_SIZE (16 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_CMD_SAVEENV +#define CONFIG_GENERIC_MMC +#define CONFIG_MXS_MMC +#endif + +/* + * Ethernet on SOC (FEC) + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_NET_MULTI +#define CONFIG_ETHPRIME "FEC0" +#define CONFIG_FEC_MXC +#define CONFIG_FEC_MXC_MULTI +#define CONFIG_MII +#define CONFIG_DISCOVER_PHY +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_MX28_FEC_MAC_IN_OCOTP +#endif + +/* + * Boot Linux + */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_BOOTCOMMAND "run bootcmd_net" +#define CONFIG_LOADADDR 0x42000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* + * Extra Environments + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console_fsl=console=ttyAM0" \ + "console_mainline=console=ttyAMA0" \ + "netargs=setenv bootargs console=${console_mainline}" \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot}\0" \ + "bootcmd_net=echo Booting from net ...; " \ + "run netargs; " \ + "dhcp ${uimage}; bootm\0" \ + +#endif /* __CONFIG_H */
1) Do you use the DRAM init data used by DENX boards ?
- Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com
- on behalf of DENX Software Engineering GmbH
Please recheck these ;-)
- SoC configurations
- SPL
- U-Boot Commands
- Memory configurations
DRAM */
malloc */
adr */
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
- We need to sacrifice first 4 bytes of RAM here to avoid triggering some
- strange BUG in ROM corrupting first 4 bytes of RAM when loading U-Boot
- binary. In case there was more of this mess, 0x100 bytes are skipped.
- U-Boot general configurations
size */
- (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16)
args */
- Serial Driver
115200 }
- MMC Driver
- Ethernet on SOC (FEC)
- Boot Linux
- Extra Environments
- "console_fsl=console=ttyAM0" \
- "console_mainline=console=ttyAMA0" \
- "netargs=setenv bootargs console=${console_mainline}" \
"root=/dev/nfs " \
- "bootcmd_net=echo Booting from net ...; " \
"run netargs; " \
Otherwise it seems OK.
M
On Thu, Dec 15, 2011 at 3:25 PM, Marek Vasut marek.vasut@gmail.com wrote:
- Do you use the DRAM init data used by DENX boards ?
Yes, same DDR settings.
- uint32_t data;
return;
- mac[0] = 0x00;
- mac[1] = 0x04;
Be careful here. 0x00 0x04 prefix might not be correct for all cases!
+} +#endif
- uint32_t data;
return;
- mac[0] = 0x00;
- mac[1] = 0x04;
-} -#endif
#endif
Otherwise, sure, it seems OK.
M
Hi Marek,
return;
- mac[0] = 0x00;
- mac[1] = 0x04;
But to be honest, it seems they are correct for the MX28EVK and not for the M28EVK. The M28EVK and the M28 module are delivered with their own MAC address that does not belong to the Freescale's range.
As far as I can see, the M28EVK starts with a Freescale's MAC, and then the DENX MAC address (Vendor ID C0:E5:4E) is set later to the correct value when Linux boots.
I can understand this feature in the SOC as a way to set the LSBs of the MAC address, but leaving to the customer a way to set its own vendor id, if he bought it.
What about to add a weak function (board_set_mac_vendor, maybe ?) that can be called at this point to set the vendor id ? The default behavior should be to set the Freescale's vendor id.
Hi Marek,
Hi Stefano,
return;
- mac[0] = 0x00;
- mac[1] = 0x04;
It's actually set even in uboot by ethaddr and eth1addr. This is the default behaviour.
ethaddr and eth1addr is insufficient?
M
Hi Marek,
This means ethaddr overwrites the values read from fuses - why do we need the fuses ?
In a standard way, the environment must be adapted for each board to store the MAC address in the ethaddr variable. The reason to get the MAC directly from the hardware is that it is not required a specific initial setup for each board, and that simplifies the production and the delivery of the boards.
If you rely on ethaddr, than we do not need imx_get_mac_from_fuse() at all, and the MAC can be set to zero, because in this case the ethaddr value is used - but we lose the feature.
The reason why imx_get_mac_from_fuse was introduce is to have an automatic mechanism to set up the MAC without any customization.
Hi Marek,
Hi Stefano,
DISCLAIMER: I'm terribly tired today, had early class.
You disable fuses and use ethaddr. Why do we need them? We don't, but the hardware is in the CPU and someone might use it so let's support it.
Sure, but the OCOTP capacity here is limited. But there was approach from Fabio/me how to make the OCOTP good enough for two NICs even.
* The idea is to let user configure the top 2 bytes per-device (which is the most likely case). * Introduce mac_modify(int fec, char *mac) function, which will be called from imx_get_mac_from_fuse() * The function will adjust the MAC, for example by setting top two bytes to preconfigured data, bottom four bytes from OCOTP and the last bit of the MAC from "int fec", which is 0 for FEC0 and 1 for FEC1. This should be sufficient for most people. * The function will be weak so it can be overridden to your hearts content.
Cheers!
M
On 16/12/2011 11:39, Marek Vasut wrote:
Hi Marek,
Hi Stefano,
ok, I understand..;-)
Exactly - see also othe IMX SOCs.
And this is nice.
- The idea is to let user configure the top 2 bytes per-device (which is the
most likely case).
This is exactly what I meant.
- Introduce mac_modify(int fec, char *mac) function, which will be called from
- The function will adjust the MAC, for example by setting top two bytes to
Exactly !
- The function will be weak so it can be overridden to your hearts content.
Right !
Stefano
Hi Marek,
Hi Stefano,
And this is nice.
Exactly !
content.
Right !
Stefano
And it was mostly Fabio's idea I'd say ;-)
M
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Change since v3: - Add a note about the first two MAC addresses being from Freescale vendor.
arch/arm/cpu/arm926ejs/mx28/mx28.c | 41 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx28/sys_proto.h | 2 + board/denx/m28evk/m28evk.c | 35 ----------------------- 3 files changed, 43 insertions(+), 35 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c index 088c019..d82bb01 100644 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ b/arch/arm/cpu/arm926ejs/mx28/mx28.c @@ -214,6 +214,47 @@ int cpu_eth_init(bd_t *bis) } #endif
+#ifdef CONFIG_MX28_FEC_MAC_IN_OCOTP + +#define MXS_OCOTP_MAX_TIMEOUT 1000000 +void imx_get_mac_from_fuse(char *mac) +{ + struct mx28_ocotp_regs *ocotp_regs = + (struct mx28_ocotp_regs *)MXS_OCOTP_BASE; + uint32_t data; + + memset(mac, 0, 6); + + writel(OCOTP_CTRL_RD_BANK_OPEN, &ocotp_regs->hw_ocotp_ctrl_set); + + if (mx28_wait_mask_clr(&ocotp_regs->hw_ocotp_ctrl_reg, OCOTP_CTRL_BUSY, + MXS_OCOTP_MAX_TIMEOUT)) { + puts("MXS FEC: Can't get MAC from OCOTP\n"); + return; + } + + data = readl(&ocotp_regs->hw_ocotp_cust0); + + mac[0] = 0x00; + mac[1] = 0x04; + /* + * Note: + * + * These first two bytes are Freescale's vendor MAC prefix. + * + */ + mac[2] = (data >> 24) & 0xff; + mac[3] = (data >> 16) & 0xff; + mac[4] = (data >> 8) & 0xff; + mac[5] = data & 0xff; +} +#else +void imx_get_mac_from_fuse(char *mac) +{ + memset(mac, 0, 6); +} +#endif + U_BOOT_CMD( clocks, CONFIG_SYS_MAXARGS, 1, do_mx28_showclocks, "display clocks", diff --git a/arch/arm/include/asm/arch-mx28/sys_proto.h b/arch/arm/include/asm/arch-mx28/sys_proto.h index be1f7db..cf5ab16 100644 --- a/arch/arm/include/asm/arch-mx28/sys_proto.h +++ b/arch/arm/include/asm/arch-mx28/sys_proto.h @@ -35,4 +35,6 @@ void mx28_common_spl_init(const iomux_cfg_t *iomux_setup, const unsigned int iomux_size); #endif
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v3: - Rename dram_init to mx28_dram_init
diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c index d82bb01..76b2876 100644 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ b/arch/arm/cpu/arm926ejs/mx28/mx28.c @@ -255,6 +255,27 @@ void imx_get_mac_from_fuse(char *mac) } #endif
+#define HW_DIGCTRL_SCRATCH0 0x8001c280 +#define HW_DIGCTRL_SCRATCH1 0x8001c290 +int mx28_dram_init(void) +{ + uint32_t sz[2]; + + sz[0] = readl(HW_DIGCTRL_SCRATCH0); + sz[1] = readl(HW_DIGCTRL_SCRATCH1); + + if (sz[0] != sz[1]) { + puts("MX28:\n" + "Error, the RAM size in HW_DIGCTRL_SCRATCH0 and\n" + "HW_DIGCTRL_SCRATCH1 is not the same. Please\n" + "verify these two registers contain valid RAM size\n"); + hang(); + } + + gd->ram_size = sz[0]; + return 0; +} + U_BOOT_CMD( clocks, CONFIG_SYS_MAXARGS, 1, do_mx28_showclocks, "display clocks", diff --git a/arch/arm/include/asm/arch-mx28/sys_proto.h b/arch/arm/include/asm/arch-mx28/sys_proto.h index cf5ab16..411173e 100644 --- a/arch/arm/include/asm/arch-mx28/sys_proto.h +++ b/arch/arm/include/asm/arch-mx28/sys_proto.h @@ -36,5 +36,6 @@ void mx28_common_spl_init(const iomux_cfg_t *iomux_setup, #endif
void imx_get_mac_from_fuse(char *mac); +int mx28_dram_init(void);
Changes since v3: - Fix Copyright in mx28evk.h - Call mx28_dram_init from dram_init Changes since v2: - Generate the patch again due to error in applying unrelated changes Changes since v1: - Read the MAC from fuses - Use tabs instead of space in u-boot.bd - Use puts instead of print - Factor out mac reading function - Factor out ddr size calculation function - Use GENERATED_GBL_DATA_SIZE - Protect CONFIG_ENV_IS_IN_MMC MAINTAINERS | 1 + board/freescale/mx28evk/Makefile | 49 ++++++++++ board/freescale/mx28evk/iomux.c | 138 +++++++++++++++++++++++++++++ board/freescale/mx28evk/mx28evk.c | 170 +++++++++++++++++++++++++++++++++++ board/freescale/mx28evk/u-boot.bd | 14 +++ boards.cfg | 1 + include/configs/mx28evk.h | 176 +++++++++++++++++++++++++++++++++++++ 7 files changed, 549 insertions(+), 0 deletions(-) create mode 100644 board/freescale/mx28evk/Makefile create mode 100644 board/freescale/mx28evk/iomux.c create mode 100644 board/freescale/mx28evk/mx28evk.c create mode 100644 board/freescale/mx28evk/u-boot.bd create mode 100644 include/configs/mx28evk.h
mx25pdk i.MX25 + mx28evk i.MX28 mx31pdk i.MX31 mx53ard i.MX53 mx53smd i.MX53 diff --git a/board/freescale/mx28evk/Makefile b/board/freescale/mx28evk/Makefile new file mode 100644 index 0000000..7459107 --- /dev/null +++ b/board/freescale/mx28evk/Makefile @@ -0,0 +1,49 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifndef CONFIG_SPL_BUILD +COBJS := mx28evk.o +else +COBJS := iomux.o +endif + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +all: $(ALL) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx28evk/iomux.c b/board/freescale/mx28evk/iomux.c new file mode 100644 index 0000000..904e3f3 --- /dev/null +++ b/board/freescale/mx28evk/iomux.c @@ -0,0 +1,138 @@ +/* + * Freescale MX28EVK IOMUX setup + * + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> + +#define MUX_CONFIG_SSP0 (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_ENET (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_EMI (MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_NOPULL) + +const iomux_cfg_t iomux_setup[] = { + /* DUART */ + MX28_PAD_PWM0__DUART_RX, + MX28_PAD_PWM1__DUART_TX, + + /* MMC0 */ + MX28_PAD_SSP0_DATA0__SSP0_D0 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA1__SSP0_D1 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA2__SSP0_D2 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA3__SSP0_D3 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA4__SSP0_D4 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA5__SSP0_D5 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA6__SSP0_D6 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DATA7__SSP0_D7 | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_CMD__SSP0_CMD | MUX_CONFIG_SSP0, + MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT | + (MXS_PAD_8MA | MXS_PAD_3V3 | MXS_PAD_NOPULL), + MX28_PAD_SSP0_SCK__SSP0_SCK | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_NOPULL), + /* write protect */ + MX28_PAD_SSP1_SCK__GPIO_2_12, + /* MMC0 slot power enable */ + MX28_PAD_PWM3__GPIO_3_28 | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_PULLUP), + + /* FEC0 */ + MX28_PAD_ENET0_MDC__ENET0_MDC | MUX_CONFIG_ENET, + MX28_PAD_ENET0_MDIO__ENET0_MDIO | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RX_EN__ENET0_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TX_EN__ENET0_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD0__ENET0_RXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD1__ENET0_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD0__ENET0_TXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD1__ENET0_TXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET_CLK__CLKCTRL_ENET | MUX_CONFIG_ENET, + /* FEC0 Enable */ + MX28_PAD_SSP1_DATA3__GPIO_2_15 | + (MXS_PAD_12MA | MXS_PAD_3V3), + /* FEC0 Reset */ + MX28_PAD_ENET0_RX_CLK__GPIO_4_13 | + (MXS_PAD_12MA | MXS_PAD_3V3 | MXS_PAD_PULLUP), + + /* FEC1 */ + MX28_PAD_ENET0_COL__ENET1_TX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_CRS__ENET1_RX_EN | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD2__ENET1_RXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_RXD3__ENET1_RXD1 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD2__ENET1_TXD0 | MUX_CONFIG_ENET, + MX28_PAD_ENET0_TXD3__ENET1_TXD1 | MUX_CONFIG_ENET, + + /* EMI */ + MX28_PAD_EMI_D00__EMI_DATA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D01__EMI_DATA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D02__EMI_DATA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D03__EMI_DATA3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D04__EMI_DATA4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D05__EMI_DATA5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D06__EMI_DATA6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D07__EMI_DATA7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D08__EMI_DATA8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D09__EMI_DATA9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D10__EMI_DATA10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D11__EMI_DATA11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D12__EMI_DATA12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D13__EMI_DATA13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D14__EMI_DATA14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_D15__EMI_DATA15 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT0__EMI_ODT0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM0__EMI_DQM0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_ODT1__EMI_ODT1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQM1__EMI_DQM1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN_FB__EMI_DDR_OPEN_FEEDBACK | MUX_CONFIG_EMI, + MX28_PAD_EMI_CLK__EMI_CLK | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS0__EMI_DQS0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DQS1__EMI_DQS1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_DDR_OPEN__EMI_DDR_OPEN | MUX_CONFIG_EMI, + + MX28_PAD_EMI_A00__EMI_ADDR0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A01__EMI_ADDR1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A02__EMI_ADDR2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A03__EMI_ADDR3 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A04__EMI_ADDR4 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A05__EMI_ADDR5 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A06__EMI_ADDR6 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A07__EMI_ADDR7 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A08__EMI_ADDR8 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A09__EMI_ADDR9 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A10__EMI_ADDR10 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A11__EMI_ADDR11 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A12__EMI_ADDR12 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A13__EMI_ADDR13 | MUX_CONFIG_EMI, + MX28_PAD_EMI_A14__EMI_ADDR14 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA0__EMI_BA0 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA1__EMI_BA1 | MUX_CONFIG_EMI, + MX28_PAD_EMI_BA2__EMI_BA2 | MUX_CONFIG_EMI, + MX28_PAD_EMI_CASN__EMI_CASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_RASN__EMI_RASN | MUX_CONFIG_EMI, + MX28_PAD_EMI_WEN__EMI_WEN | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE0N__EMI_CE0N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CE1N__EMI_CE1N | MUX_CONFIG_EMI, + MX28_PAD_EMI_CKE__EMI_CKE | MUX_CONFIG_EMI, +}; + +void board_init_ll(void) +{ + mx28_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup)); +} diff --git a/board/freescale/mx28evk/mx28evk.c b/board/freescale/mx28evk/mx28evk.c new file mode 100644 index 0000000..542e806 --- /dev/null +++ b/board/freescale/mx28evk/mx28evk.c @@ -0,0 +1,170 @@ +/* + * Freescale MX28EVK board + * + * (C) Copyright 2011 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * Based on m28evk.c: + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <linux/mii.h> +#include <miiphy.h> +#include <netdev.h> +#include <errno.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Functions + */ +int board_early_init_f(void) +{ + /* IO0 clock at 480MHz */ + mx28_set_ioclk(MXC_IOCLK0, 480000); + /* IO1 clock at 480MHz */ + mx28_set_ioclk(MXC_IOCLK1, 480000); + + /* SSP0 clock at 96MHz */ + mx28_set_sspclk(MXC_SSPCLK0, 96000, 0); + /* SSP2 clock at 96MHz */ + mx28_set_sspclk(MXC_SSPCLK2, 96000, 0); + + return 0; +} + +int dram_init(void) +{ + mx28_dram_init(); + return 0; +} + +int board_init(void) +{ + /* Adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + +#ifdef CONFIG_CMD_MMC +static int mx28evk_mmc_wp(int id) +{ + if (id != 0) { + printf("MXS MMC: Invalid card selected (card id = %d)\n", id); + return 1; + } + + return gpio_get_value(MX28_PAD_SSP1_SCK__GPIO_2_12); +} + +int board_mmc_init(bd_t *bis) +{ + /* Configure WP as input */ + gpio_direction_input(MX28_PAD_SSP1_SCK__GPIO_2_12); + + /* Configure MMC0 Power Enable */ + gpio_direction_output(MX28_PAD_PWM3__GPIO_3_28, 0); + + return mxsmmc_initialize(bis, 0, mx28evk_mmc_wp); +} +#endif + +#ifdef CONFIG_CMD_NET + +#define MII_OPMODE_STRAP_OVERRIDE 0x16 +#define MII_PHY_CTRL1 0x1e +#define MII_PHY_CTRL2 0x1f + +int fecmxc_mii_postcall(int phy) +{ + miiphy_write("FEC1", phy, MII_BMCR, 0x9000); + miiphy_write("FEC1", phy, MII_OPMODE_STRAP_OVERRIDE, 0x0202); + if (phy == 3) + miiphy_write("FEC1", 3, MII_PHY_CTRL2, 0x8180); + return 0; +} + +int board_eth_init(bd_t *bis) +{ + struct mx28_clkctrl_regs *clkctrl_regs = + (struct mx28_clkctrl_regs *)MXS_CLKCTRL_BASE; + struct eth_device *dev; + int ret; + + ret = cpu_eth_init(bis); + + /* MX28EVK uses ENET_CLK PAD to drive FEC clock */ + writel(CLKCTRL_ENET_TIME_SEL_RMII_CLK | CLKCTRL_ENET_CLK_OUT_EN, + &clkctrl_regs->hw_clkctrl_enet); + + /* Power-on FECs */ + gpio_direction_output(MX28_PAD_SSP1_DATA3__GPIO_2_15, 0); + + /* Reset FEC PHYs */ + gpio_direction_output(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 0); + udelay(200); + gpio_set_value(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 1); + + ret = fecmxc_initialize_multi(bis, 0, 0, MXS_ENET0_BASE); + if (ret) { + puts("FEC MXS: Unable to init FEC0\n"); + return ret; + } + + ret = fecmxc_initialize_multi(bis, 1, 3, MXS_ENET1_BASE); + if (ret) { + puts("FEC MXS: Unable to init FEC1\n"); + return ret; + } + + dev = eth_get_dev_by_name("FEC0"); + if (!dev) { + puts("FEC MXS: Unable to get FEC0 device entry\n"); + return -EINVAL; + } + + ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); + if (ret) { + puts("FEC MXS: Unable to register FEC0 mii postcall\n"); + return ret; + } + + dev = eth_get_dev_by_name("FEC1"); + if (!dev) { + puts("FEC MXS: Unable to get FEC1 device entry\n"); + return -EINVAL; + } + + ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); + if (ret) { + puts("FEC MXS: Unable to register FEC1 mii postcall\n"); + return ret; + } + + return ret; +} + +#endif diff --git a/board/freescale/mx28evk/u-boot.bd b/board/freescale/mx28evk/u-boot.bd new file mode 100644 index 0000000..c60615a --- /dev/null +++ b/board/freescale/mx28evk/u-boot.bd @@ -0,0 +1,14 @@ +sources { + u_boot_spl="spl/u-boot-spl.bin"; + u_boot="u-boot.bin"; +} + +section (0) { + load u_boot_spl > 0x0000; + load ivt (entry = 0x0014) > 0x8000; + hab call 0x8000; + + load u_boot > 0x40000100; + load ivt (entry = 0x40000100) > 0x8000; + hab call 0x8000; +} diff --git a/boards.cfg b/boards.cfg index 1e5b3e0..e859024 100644 --- a/boards.cfg +++ b/boards.cfg @@ -160,6 +160,7 @@ zmx25 arm arm926ejs zmx25 syteco imx27lite arm arm926ejs imx27lite logicpd mx27 magnesium arm arm926ejs imx27lite logicpd mx27 m28evk arm arm926ejs - denx mx28 +mx28evk arm arm926ejs - freescale mx28 nhk8815 arm arm926ejs nhk8815 st nomadik nhk8815_onenand arm arm926ejs nhk8815 st nomadik nhk8815:BOOT_ONENAND omap1610h2 arm arm926ejs omap1610inn ti omap omap1610inn:CS3_BOOT diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h new file mode 100644 index 0000000..5b8a1bf --- /dev/null +++ b/include/configs/mx28evk.h @@ -0,0 +1,176 @@ +/* + * (C) Copyright 2011 Freescale Semiconductor, Inc. + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * Based on m28evk.h: + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * on behalf of DENX Software Engineering GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/regs-base.h> + +/* + * SoC configurations + */ +#define CONFIG_MX28 /* i.MX28 SoC */ +#define CONFIG_MXS_GPIO /* GPIO control */ +#define CONFIG_SYS_HZ 1000 /* Ticks per second */ + +#define CONFIG_MACH_TYPE MACH_TYPE_MX28EVK + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_ARCH_MISC_INIT + +/* + * SPL + */ +#define CONFIG_SPL +#define CONFIG_SPL_NO_CPU_SUPPORT_CODE +#define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mx28" +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mx28/u-boot-spl.lds" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT + +/* + * U-Boot Commands + */ +#include <config_cmd_default.h> +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_MII +#define CONFIG_CMD_MMC +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PING + +/* + * Memory configurations + */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0x40000000 /* Base address */ +#define PHYS_SDRAM_1_SIZE 0x40000000 /* Max 1 GB RAM */ +#define CONFIG_STACKSIZE (128 * 1024) /* 128 KB stack */ +#define CONFIG_SYS_MALLOC_LEN 0x00400000 /* 4 MB for malloc */ +#define CONFIG_SYS_MEMTEST_START 0x40000000 /* Memtest start adr */ +#define CONFIG_SYS_MEMTEST_END 0x40400000 /* 4 MB RAM test */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +/* Point initial SP in SRAM so SPL can use it too. */ + +#define CONFIG_SYS_INIT_RAM_ADDR 0x00002000 +#define CONFIG_SYS_INIT_RAM_SIZE (128 * 1024) + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* + * We need to sacrifice first 4 bytes of RAM here to avoid triggering some + * strange BUG in ROM corrupting first 4 bytes of RAM when loading U-Boot + * binary. In case there was more of this mess, 0x100 bytes are skipped. + */ +#define CONFIG_SYS_TEXT_BASE 0x40000100 + +#define CONFIG_ENV_OVERWRITE +/* + * U-Boot general configurations + */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "MX28EVK U-Boot > " +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O buffer size */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + /* Print buffer size */ +#define CONFIG_SYS_MAXARGS 32 /* Max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + /* Boot argument buffer size */ +#define CONFIG_VERSION_VARIABLE /* U-BOOT version */ +#define CONFIG_AUTO_COMPLETE /* Command auto complete */ +#define CONFIG_CMDLINE_EDITING /* Command history etc */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* + * Serial Driver + */ +#define CONFIG_PL011_SERIAL +#define CONFIG_PL011_CLOCK 24000000 +#define CONFIG_PL01x_PORTS { (void *)MXS_UARTDBG_BASE } +#define CONFIG_CONS_INDEX 0 +#define CONFIG_BAUDRATE 115200 /* Default baud rate */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * MMC Driver + */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (256 * 1024) +#define CONFIG_ENV_SIZE (16 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_CMD_SAVEENV +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MXS_MMC +#endif + +/* + * Ethernet on SOC (FEC) + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_NET_MULTI +#define CONFIG_ETHPRIME "FEC0" +#define CONFIG_FEC_MXC +#define CONFIG_FEC_MXC_MULTI +#define CONFIG_MII +#define CONFIG_DISCOVER_PHY +#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_MX28_FEC_MAC_IN_OCOTP +#endif + +/* + * Boot Linux + */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_BOOTCOMMAND "run bootcmd_net" +#define CONFIG_LOADADDR 0x42000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* + * Extra Environments + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console_fsl=console=ttyAM0" \ + "console_mainline=console=ttyAMA0" \ + "netargs=setenv bootargs console=${console_mainline}" \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot}\0" \ + "bootcmd_net=echo Booting from net ...; " \ + "run netargs; " \ + "dhcp ${uimage}; bootm\0" \ + +#endif /* __CONFIG_H */
Let imx_get_mac_from_fuse function be a common function, so that other mx28 boards can reuse it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v4: - No changes Change since v3: - Add a note about the first two MAC addresses being from Freescale vendor.
+void imx_get_mac_from_fuse(char *mac); + #endif /* __MX28_H__ */ diff --git a/board/denx/m28evk/m28evk.c b/board/denx/m28evk/m28evk.c index fcee046..005446a 100644 --- a/board/denx/m28evk/m28evk.c +++ b/board/denx/m28evk/m28evk.c @@ -178,39 +178,4 @@ int board_eth_init(bd_t *bis) return ret; }
-#ifdef CONFIG_M28_FEC_MAC_IN_OCOTP - -#define MXS_OCOTP_MAX_TIMEOUT 1000000 -void imx_get_mac_from_fuse(char *mac) -{ - struct mx28_ocotp_regs *ocotp_regs = - (struct mx28_ocotp_regs *)MXS_OCOTP_BASE; - uint32_t data; - - memset(mac, 0, 6); - - writel(OCOTP_CTRL_RD_BANK_OPEN, &ocotp_regs->hw_ocotp_ctrl_set); - - if (mx28_wait_mask_clr(&ocotp_regs->hw_ocotp_ctrl_reg, OCOTP_CTRL_BUSY, - MXS_OCOTP_MAX_TIMEOUT)) { - printf("MXS FEC: Can't get MAC from OCOTP\n"); - return; - } - - data = readl(&ocotp_regs->hw_ocotp_cust0); - - mac[0] = 0x00; - mac[1] = 0x04; - mac[2] = (data >> 24) & 0xff; - mac[3] = (data >> 16) & 0xff; - mac[4] = (data >> 8) & 0xff; - mac[5] = data & 0xff; -} -#else -void imx_get_mac_from_fuse(char *mac) -{ - memset(mac, 0, 6); -} -#endif - #endif
Changes since v4:
- No changes
Change since v3:
What changes are in V5? Also, mark resubmissions with "RESEND" or "V3 RESEND" or something ... like "[PATCH V3 RESEND]" ... though you don't need to resend stuff here.
- uint32_t data;
return;
/* Freescale MAC vendor prefix: 00:04:xx:xx:xx:xx */ ... or something
It's shorter and it should be above the code.
- mac[0] = 0x00;
- mac[1] = 0x04;
* Note:
+} +#endif
- uint32_t data;
return;
- mac[0] = 0x00;
- mac[1] = 0x04;
-} -#endif
#endif
M
Let dram_init function be a common function, so that other mx28 boards can reuse it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v4: - Call mx28_dram_init from m28evk.c Changes since v3: - Rename dram_init to mx28_dram_init arch/arm/cpu/arm926ejs/mx28/mx28.c | 21 +++++++++++++++++++++ arch/arm/include/asm/arch-mx28/sys_proto.h | 1 + board/denx/m28evk/m28evk.c | 25 +++++-------------------- 3 files changed, 27 insertions(+), 20 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx28/mx28.c b/arch/arm/cpu/arm926ejs/mx28/mx28.c index 40ffe4c..ade3df5 100644 --- a/arch/arm/cpu/arm926ejs/mx28/mx28.c +++ b/arch/arm/cpu/arm926ejs/mx28/mx28.c @@ -255,6 +255,27 @@ void imx_get_mac_from_fuse(char *mac) } #endif
#endif /* __MX28_H__ */ diff --git a/board/denx/m28evk/m28evk.c b/board/denx/m28evk/m28evk.c index 005446a..3225543 100644 --- a/board/denx/m28evk/m28evk.c +++ b/board/denx/m28evk/m28evk.c @@ -62,32 +62,17 @@ int board_early_init_f(void) return 0; }
-int board_init(void) +int dram_init(void) { - /* Adress of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; - + mx28_dram_init(); return 0; }
-#define HW_DIGCTRL_SCRATCH0 0x8001c280 -#define HW_DIGCTRL_SCRATCH1 0x8001c290 -int dram_init(void) +int board_init(void) { - uint32_t sz[2]; - - sz[0] = readl(HW_DIGCTRL_SCRATCH0); - sz[1] = readl(HW_DIGCTRL_SCRATCH1); - - if (sz[0] != sz[1]) { - printf("MX28:\n" - "Error, the RAM size in HW_DIGCTRL_SCRATCH0 and\n" - "HW_DIGCTRL_SCRATCH1 is not the same. Please\n" - "verify these two registers contain valid RAM size!\n"); - hang(); - } + /* Adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
- gd->ram_size = sz[0]; return 0; }
- mx28_dram_init(); return 0;
Why not simply return mx28_dram_init() ?
We do not drop the return code if mx28_dram_init will be changed.
Add initial support for Freescale MX28EVK board.
Tested boot via SD card and by loading a kernel via TFTP through the FEC interface.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- - For correct operation of saving environment variables into the SD card, the following patch is needed: http://lists.denx.de/pipermail/u-boot/2011-November/111448.html
Changes since v4: - No changes Changes since v3: - Fix Copyright in mx28evk.h - Call mx28_dram_init from dram_init Changes since v2: - Generate the patch again due to error in applying unrelated changes Changes since v1: - Read the MAC from fuses - Use tabs instead of space in u-boot.bd - Use puts instead of print - Factor out mac reading function - Factor out ddr size calculation function - Use GENERATED_GBL_DATA_SIZE - Protect CONFIG_ENV_IS_IN_MMC MAINTAINERS | 1 + board/freescale/mx28evk/Makefile | 49 ++++++++++ board/freescale/mx28evk/iomux.c | 138 +++++++++++++++++++++++++++++ board/freescale/mx28evk/mx28evk.c | 170 +++++++++++++++++++++++++++++++++++ board/freescale/mx28evk/u-boot.bd | 14 +++ boards.cfg | 1 + include/configs/mx28evk.h | 176 +++++++++++++++++++++++++++++++++++++ 7 files changed, 549 insertions(+), 0 deletions(-) create mode 100644 board/freescale/mx28evk/Makefile create mode 100644 board/freescale/mx28evk/iomux.c create mode 100644 board/freescale/mx28evk/mx28evk.c create mode 100644 board/freescale/mx28evk/u-boot.bd create mode 100644 include/configs/mx28evk.h
diff --git a/MAINTAINERS b/MAINTAINERS index a56ca10..72e1089 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -639,6 +639,7 @@ Kristoffer Ericson kristoffer.ericson@gmail.com Fabio Estevam fabio.estevam@freescale.com
Hi Fabio,
- mx28_dram_init();
return mx28_dram_init();
Changes since v4:
- No changes
Changes since v3:
Changes since v2:
Changes since v1:
mx25pdk i.MX25
- $(call cmd_link_o_target, $(OBJS))
+all: $(ALL)
- Freescale MX28EVK IOMUX setup
- project.
- /* DUART */
- MX28_PAD_PWM0__DUART_RX,
- MX28_PAD_PWM1__DUART_TX,
- /* MMC0 */
- MX28_PAD_SSP0_DATA0__SSP0_D0 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA1__SSP0_D1 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA2__SSP0_D2 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA3__SSP0_D3 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA4__SSP0_D4 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA5__SSP0_D5 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA6__SSP0_D6 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DATA7__SSP0_D7 | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_CMD__SSP0_CMD | MUX_CONFIG_SSP0,
- MX28_PAD_SSP0_DETECT__SSP0_CARD_DETECT |
- MX28_PAD_SSP0_SCK__SSP0_SCK |
- /* write protect */
- MX28_PAD_SSP1_SCK__GPIO_2_12,
- /* MMC0 slot power enable */
- MX28_PAD_PWM3__GPIO_3_28 |
- /* FEC0 */
- MX28_PAD_ENET0_MDC__ENET0_MDC | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_MDIO__ENET0_MDIO | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_RX_EN__ENET0_RX_EN | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_TX_EN__ENET0_TX_EN | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_RXD0__ENET0_RXD0 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_RXD1__ENET0_RXD1 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_TXD0__ENET0_TXD0 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_TXD1__ENET0_TXD1 | MUX_CONFIG_ENET,
- MX28_PAD_ENET_CLK__CLKCTRL_ENET | MUX_CONFIG_ENET,
- /* FEC0 Enable */
- MX28_PAD_SSP1_DATA3__GPIO_2_15 |
- /* FEC0 Reset */
- MX28_PAD_ENET0_RX_CLK__GPIO_4_13 |
- /* FEC1 */
- MX28_PAD_ENET0_COL__ENET1_TX_EN | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_CRS__ENET1_RX_EN | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_RXD2__ENET1_RXD0 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_RXD3__ENET1_RXD1 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_TXD2__ENET1_TXD0 | MUX_CONFIG_ENET,
- MX28_PAD_ENET0_TXD3__ENET1_TXD1 | MUX_CONFIG_ENET,
- /* EMI */
- MX28_PAD_EMI_D00__EMI_DATA0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D01__EMI_DATA1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D02__EMI_DATA2 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D03__EMI_DATA3 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D04__EMI_DATA4 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D05__EMI_DATA5 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D06__EMI_DATA6 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D07__EMI_DATA7 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D08__EMI_DATA8 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D09__EMI_DATA9 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D10__EMI_DATA10 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D11__EMI_DATA11 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D12__EMI_DATA12 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D13__EMI_DATA13 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D14__EMI_DATA14 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_D15__EMI_DATA15 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_ODT0__EMI_ODT0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DQM0__EMI_DQM0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_ODT1__EMI_ODT1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DQM1__EMI_DQM1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DDR_OPEN_FB__EMI_DDR_OPEN_FEEDBACK | MUX_CONFIG_EMI,
- MX28_PAD_EMI_CLK__EMI_CLK | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DQS0__EMI_DQS0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DQS1__EMI_DQS1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_DDR_OPEN__EMI_DDR_OPEN | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A00__EMI_ADDR0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A01__EMI_ADDR1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A02__EMI_ADDR2 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A03__EMI_ADDR3 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A04__EMI_ADDR4 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A05__EMI_ADDR5 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A06__EMI_ADDR6 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A07__EMI_ADDR7 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A08__EMI_ADDR8 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A09__EMI_ADDR9 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A10__EMI_ADDR10 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A11__EMI_ADDR11 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A12__EMI_ADDR12 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A13__EMI_ADDR13 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_A14__EMI_ADDR14 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_BA0__EMI_BA0 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_BA1__EMI_BA1 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_BA2__EMI_BA2 | MUX_CONFIG_EMI,
- MX28_PAD_EMI_CASN__EMI_CASN | MUX_CONFIG_EMI,
- MX28_PAD_EMI_RASN__EMI_RASN | MUX_CONFIG_EMI,
- MX28_PAD_EMI_WEN__EMI_WEN | MUX_CONFIG_EMI,
- MX28_PAD_EMI_CE0N__EMI_CE0N | MUX_CONFIG_EMI,
- MX28_PAD_EMI_CE1N__EMI_CE1N | MUX_CONFIG_EMI,
- MX28_PAD_EMI_CKE__EMI_CKE | MUX_CONFIG_EMI,
- mx28_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup));
- Freescale MX28EVK board
- (C) Copyright 2011 Freescale Semiconductor, Inc.
- Author: Fabio Estevam fabio.estevam@freescale.com
- Based on m28evk.c:
- project.
- Functions
- /* IO0 clock at 480MHz */
- mx28_set_ioclk(MXC_IOCLK0, 480000);
- /* IO1 clock at 480MHz */
- mx28_set_ioclk(MXC_IOCLK1, 480000);
- /* SSP0 clock at 96MHz */
- mx28_set_sspclk(MXC_SSPCLK0, 96000, 0);
- /* SSP2 clock at 96MHz */
- mx28_set_sspclk(MXC_SSPCLK2, 96000, 0);
- mx28_dram_init();
- if (id != 0) {
return 1;
- return gpio_get_value(MX28_PAD_SSP1_SCK__GPIO_2_12);
- /* Configure WP as input */
- gpio_direction_input(MX28_PAD_SSP1_SCK__GPIO_2_12);
- /* Configure MMC0 Power Enable */
- gpio_direction_output(MX28_PAD_PWM3__GPIO_3_28, 0);
- return mxsmmc_initialize(bis, 0, mx28evk_mmc_wp);
+} +#endif
- miiphy_write("FEC1", phy, MII_BMCR, 0x9000);
- miiphy_write("FEC1", phy, MII_OPMODE_STRAP_OVERRIDE, 0x0202);
- if (phy == 3)
- struct mx28_clkctrl_regs *clkctrl_regs =
- struct eth_device *dev;
- int ret;
- ret = cpu_eth_init(bis);
- /* MX28EVK uses ENET_CLK PAD to drive FEC clock */
- writel(CLKCTRL_ENET_TIME_SEL_RMII_CLK | CLKCTRL_ENET_CLK_OUT_EN,
- /* Power-on FECs */
- gpio_direction_output(MX28_PAD_SSP1_DATA3__GPIO_2_15, 0);
- /* Reset FEC PHYs */
- gpio_direction_output(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 0);
- udelay(200);
- gpio_set_value(MX28_PAD_ENET0_RX_CLK__GPIO_4_13, 1);
- ret = fecmxc_initialize_multi(bis, 0, 0, MXS_ENET0_BASE);
- if (ret) {
return ret;
- ret = fecmxc_initialize_multi(bis, 1, 3, MXS_ENET1_BASE);
- if (ret) {
return ret;
- dev = eth_get_dev_by_name("FEC0");
- if (!dev) {
return -EINVAL;
- ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall);
- if (ret) {
return ret;
- dev = eth_get_dev_by_name("FEC1");
- if (!dev) {
return -EINVAL;
- if (ret) {
return ret;
- return ret;
- u_boot_spl="spl/u-boot-spl.bin";
- u_boot="u-boot.bin";
+section (0) {
- load u_boot_spl > 0x0000;
- load ivt (entry = 0x0014) > 0x8000;
- hab call 0x8000;
- load u_boot > 0x40000100;
- load ivt (entry = 0x40000100) > 0x8000;
- hab call 0x8000;
diff --git
- Based on m28evk.h:
- SPL
- U-Boot Commands
DRAM */
malloc */
adr */
size */
args */
- Serial Driver
115200 }
- MMC Driver
Tabs vs. spaces, please fix globally.
M
Hi Fabio,
Have you any idea why this works from SD card but not by USB recovery using exactly same sb file?
By quick look it seems that control is not passed back to the ROM properly after SPL or ROM is unable to load/run U-Boot after SPL.
-- Veli-Pekka Peltola
On Fri, Dec 16, 2011 at 12:55 PM, Veli-Pekka Peltola veli-pekka.peltola@bluegiga.com wrote:
Sorry, never tested this 'USB recovery' mode.
I can look at it after I finish the mx28evk patches.
Reagards,
Fabio Estevam
Hi Fabio,
What do you mean? The SPL only inits the hardware and then lets the bootrom do whatever it wants again with the next file in u-boot.bd.
Dear Marek Vasut,
On 12/17/2011 05:17 AM, Marek Vasut wrote:
Hi Fabio,
U-Boot doesn't start up after SPL, that is what I see.
I don't have tools or knowledge to investigate this further but here are steps to replicate the issue: 1) make mx28evk_config 2) make u-boot.sb 3) set dip switches to usb0 bootmode 4) connect micro-USB cable 5) try to load u-boot.sb using mfgtool (Windows) or imx_hid_recovery (Linux) [1]
I tested USB powered mode and 5V wall adapter without difference.
[1] http://git.pengutronix.de/?p=mxs-utils.git;a=commit;h=87692449099ae85922842f...
participants (6)
Fabio Estevam
Fabio Estevam
Stefano Babic
Veli-Pekka Peltola
