[U-Boot] [UBOOT PATCH v2 0/2] eeprom: Moved eeprom u-boot headers to the Kconfig
This series of patch added Kconfig support for eeprom u-boot headers and enabled in respective defconfig.
These are the configs: -CONFIG_ZYNQ_EEPROM_BUS -CONFIG_ZYNQ_GEM_EEPROM_ADDR
-Changes in v2: - Removed CONFIG_ZYNQ_EEPROM for zynqmp - Enabled configs defined under CONFIG_ZYNQ_EEPROM for zynq - in defconfig and removed CONFIG_ZYNQ_EEPROM. - Added depends on ARCH_ZYNQ - Branch: u-boot-microblaze/kconfig
Vipul Kumar (2): eeprom: Enabled eeprom u-boot headers in defconfig eeprom: Added Kconfig support for eeprom u-boot headers
configs/syzygy_hub_defconfig | 1 + configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 2 ++ configs/xilinx_zynqmp_zcu102_revA_defconfig | 2 ++ configs/xilinx_zynqmp_zcu102_revB_defconfig | 2 ++ configs/zynq_zc702_defconfig | 6 ++++++ configs/zynq_zc706_defconfig | 6 ++++++ configs/zynq_zybo_defconfig | 1 + drivers/misc/Kconfig | 14 ++++++++++++++ include/configs/syzygy_hub.h | 1 - include/configs/xilinx_zynqmp_ep.h | 1 - include/configs/xilinx_zynqmp_zcu102.h | 2 -- include/configs/zynq-common.h | 9 --------- include/configs/zynq_zc70x.h | 2 -- include/configs/zynq_zybo.h | 1 - 14 files changed, 34 insertions(+), 16 deletions(-)
-- 2.7.4
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
This patch enabled eeprom related u-boot headers in the respective defconfig and removed CONFIG_ZYNQ_EEPROM.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- - Changes in v2: - Removed CONFIG_ZYNQ_EEPROM for zynqmp. - Enabled configs defined under CONFIG_ZYNQ_EEPROM for zynq in defconfig and removed CONFIG_ZYNQ_EEPROM. - Branch: u-boot-microblaze/kconfig --- configs/zynq_zc702_defconfig | 6 ++++++ configs/zynq_zc706_defconfig | 6 ++++++ include/configs/xilinx_zynqmp_ep.h | 1 - include/configs/zynq-common.h | 9 --------- include/configs/zynq_zc70x.h | 2 -- 5 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 8e8b800..2970ef8 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -43,6 +43,12 @@ CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x54 +CONFIG_SYS_EEPROM_SIZE=1024 +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=4 +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=5 CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 8f83d17..b51567c 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -43,6 +43,12 @@ CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x54 +CONFIG_SYS_EEPROM_SIZE=1024 +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=4 +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=5 CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y diff --git a/include/configs/xilinx_zynqmp_ep.h b/include/configs/xilinx_zynqmp_ep.h index 3a572b7..6c48e15 100644 --- a/include/configs/xilinx_zynqmp_ep.h +++ b/include/configs/xilinx_zynqmp_ep.h @@ -15,7 +15,6 @@
#define CONFIG_ZYNQ_SDHCI_MAX_FREQ 52000000 #define CONFIG_ZYNQ_SDHCI_MIN_FREQ (CONFIG_ZYNQ_SDHCI_MAX_FREQ >> 9) -#define CONFIG_ZYNQ_EEPROM #define CONFIG_ZYNQMP_XHCI_LIST {ZYNQMP_USB0_XHCI_BASEADDR, \ ZYNQMP_USB1_XHCI_BASEADDR}
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 0ebb66b..4622d39 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -122,15 +122,6 @@ # define CONFIG_SYS_I2C #endif
-/* EEPROM */ -#ifdef CONFIG_ZYNQ_EEPROM -# define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -# define CONFIG_SYS_I2C_EEPROM_ADDR 0x54 -# define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 -# define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 -# define CONFIG_SYS_EEPROM_SIZE 1024 /* Bytes */ -#endif - /* Total Size of Environment Sector */ #define CONFIG_ENV_SIZE (128 << 10)
diff --git a/include/configs/zynq_zc70x.h b/include/configs/zynq_zc70x.h index 720f953..715ea80 100644 --- a/include/configs/zynq_zc70x.h +++ b/include/configs/zynq_zc70x.h @@ -10,8 +10,6 @@ #ifndef __CONFIG_ZYNQ_ZC70X_H #define __CONFIG_ZYNQ_ZC70X_H
-#define CONFIG_ZYNQ_EEPROM - #include <configs/zynq-common.h>
#endif /* __CONFIG_ZYNQ_ZC70X_H */ -- 2.7.4
- Changes in v2:
Please take a look at this again. I can compile it on zc706. This will require to switch to DM based driver which is not done here too. It means this patch is not complete.
Thanks, Michal
- Changes in v2:
This should be I can't compile it.
Thanks, Michal
This patch added Kconfig support for CONFIG_ZYNQ_EEPROM_BUS and CONFIG_ZYNQ_GEM_EEPROM_ADDR and enabled it in respective defconfig.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- - Changes in V2: - Added depends on ARCH_ZYNQ - Branch: u-boot-microblaze/kconfig --- configs/syzygy_hub_defconfig | 1 + configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 2 ++ configs/xilinx_zynqmp_zcu102_revA_defconfig | 2 ++ configs/xilinx_zynqmp_zcu102_revB_defconfig | 2 ++ configs/zynq_zybo_defconfig | 1 + drivers/misc/Kconfig | 14 ++++++++++++++ include/configs/syzygy_hub.h | 1 - include/configs/xilinx_zynqmp_zcu102.h | 2 -- include/configs/zynq_zybo.h | 1 - 9 files changed, 22 insertions(+), 4 deletions(-)
diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index 67d1f54..eda5a60 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -37,6 +37,7 @@ CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C1=y +CONFIG_ZYNQ_GEM_EEPROM_ADDR=0x57 CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0xFA CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index 1df5b0b..fe6b6c3 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -57,6 +57,8 @@ CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y CONFIG_ZYNQ_I2C1=y CONFIG_MISC=y +CONFIG_ZYNQ_EEPROM_BUS=5 +CONFIG_ZYNQ_GEM_EEPROM_ADDR=0x54 CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index c8a8362..3ee241d 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -57,6 +57,8 @@ CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y CONFIG_ZYNQ_I2C1=y CONFIG_MISC=y +CONFIG_ZYNQ_EEPROM_BUS=5 +CONFIG_ZYNQ_GEM_EEPROM_ADDR=0x54 CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 8f85b5f..75ca1f0 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -57,6 +57,8 @@ CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y CONFIG_ZYNQ_I2C1=y CONFIG_MISC=y +CONFIG_ZYNQ_EEPROM_BUS=5 +CONFIG_ZYNQ_GEM_EEPROM_ADDR=0x54 CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 92f3e1e..4cb46b8 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -43,6 +43,7 @@ CONFIG_DM_GPIO=y CONFIG_SYS_I2C_ZYNQ=y CONFIG_ZYNQ_I2C0=y CONFIG_ZYNQ_I2C1=y +CONFIG_ZYNQ_GEM_EEPROM_ADDR=0x50 CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0xFA CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index d774569..aa1089a 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -214,6 +214,20 @@ config SPL_I2C_EEPROM This option is an SPL-variant of the I2C_EEPROM option. See the help of I2C_EEPROM for details.
+config ZYNQ_EEPROM_BUS + int "Define the EEPROM bus number" + depends on ARCH_ZYNQMP || ARCH_ZYNQ + default -1 + help + Define the EEPROM bus number. + +config ZYNQ_GEM_EEPROM_ADDR + hex "Define GEM EEPROM address" + depends on ARCH_ZYNQMP || ARCH_ZYNQ + default 0x0 + help + Define the EEPROM address for GEM. + config ZYNQ_GEM_I2C_MAC_OFFSET hex "Set the I2C MAC offset" default 0x0 diff --git a/include/configs/syzygy_hub.h b/include/configs/syzygy_hub.h index 73c9189..362a6c9 100644 --- a/include/configs/syzygy_hub.h +++ b/include/configs/syzygy_hub.h @@ -12,7 +12,6 @@ #define __CONFIG_SYZYGY_HUB_H
#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_ZYNQ_GEM_EEPROM_ADDR 0x57
#define CONFIG_EXTRA_ENV_SETTINGS \ "fit_image=fit.itb\0" \ diff --git a/include/configs/xilinx_zynqmp_zcu102.h b/include/configs/xilinx_zynqmp_zcu102.h index 27d9d6a..1166343 100644 --- a/include/configs/xilinx_zynqmp_zcu102.h +++ b/include/configs/xilinx_zynqmp_zcu102.h @@ -39,8 +39,6 @@ #define CONFIG_ZYNQMP_XHCI_LIST {ZYNQMP_USB0_XHCI_BASEADDR}
#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_ZYNQ_EEPROM_BUS 5 -#define CONFIG_ZYNQ_GEM_EEPROM_ADDR 0x54
#include <configs/xilinx_zynqmp.h>
diff --git a/include/configs/zynq_zybo.h b/include/configs/zynq_zybo.h index 8f4e088..aca867c 100644 --- a/include/configs/zynq_zybo.h +++ b/include/configs/zynq_zybo.h @@ -12,7 +12,6 @@ #define __CONFIG_ZYNQ_ZYBO_H
#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_ZYNQ_GEM_EEPROM_ADDR 0x50 #define CONFIG_DISPLAY #define CONFIG_I2C_EDID
-- 2.7.4
Michal Simek
Vipul Kumar
