[U-Boot] [PATCH v2 1/2] ti814x: enable support for parallel NAND flash devices
TI81xx (TI816x, TI814x, TI813x) family of devices include in-built GPMC and ELM hardware controllers which have the capability to support: - x8 and x16 parallel NAND, NOR flash devices. - generation and error detection of Hamming and BCH ECC schemes.
This patch enables support for detection and boot via NAND flash devices for TI814x SoC.
Signed-off-by: Pekon Gupta pekon@ti.com --- arch/arm/cpu/armv7/am33xx/clock_ti814x.c | 5 +++++ arch/arm/include/asm/arch-am33xx/mux_ti814x.h | 5 +++-- 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/am33xx/clock_ti814x.c b/arch/arm/cpu/armv7/am33xx/clock_ti814x.c index ef14f47..341f341 100644 --- a/arch/arm/cpu/armv7/am33xx/clock_ti814x.c +++ b/arch/arm/cpu/armv7/am33xx/clock_ti814x.c @@ -188,6 +188,11 @@ static void enable_per_clocks(void) writel(PRCM_MOD_EN, &cmalwon->rtcclkctrl); while (readl(&cmalwon->rtcclkctrl) != PRCM_MOD_EN) ; + + /* GPMC */ + writel(PRCM_MOD_EN, &cmalwon->gpmcclkctrl); + while (readl(&cmalwon->gpmcclkctrl) != PRCM_MOD_EN) + ; }
/* diff --git a/arch/arm/include/asm/arch-am33xx/mux_ti814x.h b/arch/arm/include/asm/arch-am33xx/mux_ti814x.h index a26e503..6105b27 100644 --- a/arch/arm/include/asm/arch-am33xx/mux_ti814x.h +++ b/arch/arm/include/asm/arch-am33xx/mux_ti814x.h @@ -19,8 +19,9 @@ /* PAD Control Fields */ #define PINCNTL_RSV_MSK (0x3 << 18) /* Reserved bitmask */ #define PULLUP_EN (0x1 << 17) /* Pull UP Selection */ -#define PULLUDEN (0x0 << 16) /* Pull up enabled */ -#define PULLUDDIS (0x1 << 16) /* Pull up disabled */ +#define PULLDOWN_EN (0x1 << 17) /* Pull UP Selection */ +#define PULL_ENABLE (0x0 << 16) /* Pull up enabled */ +#define PULL_DISABLE (0x1 << 16) /* Pull up disabled */ #define MODE(val) val /* used for Readability */
#define MUX_CFG(value, offset) \
ti814x_evm has on-board socket for using Micron (MT29Fxx) family of NAND devices to GPMC interface. This patch - adds NAND related pin-mux configuration for same - adds #defines for NAND partitions to TI814x configs - enables support for NAND in TI814x configs
Signed-off-by: Pekon Gupta pekon@ti.com --- board/ti/ti814x/evm.c | 4 +- board/ti/ti814x/evm.h | 1 + board/ti/ti814x/mux.c | 34 +++++++++++++++++ include/configs/ti814x_evm.h | 91 +++++++++++++++++++++++++++++++++++++++++--- 4 files changed, 124 insertions(+), 6 deletions(-)
diff --git a/board/ti/ti814x/evm.c b/board/ti/ti814x/evm.c index e406326..3bd73a3 100644 --- a/board/ti/ti814x/evm.c +++ b/board/ti/ti814x/evm.c @@ -91,9 +91,10 @@ void set_mux_conf_regs(void) { /* Set MMC pins */ enable_mmc1_pin_mux(); - /* Set Ethernet pins */ enable_enet_pin_mux(); + /* Set NAND pins */ + enable_nand_pin_mux(); }
void sdram_init(void) @@ -113,6 +114,7 @@ void sdram_init(void) int board_init(void) { gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + gpmc_init(); return 0; }
diff --git a/board/ti/ti814x/evm.h b/board/ti/ti814x/evm.h index 6aebec6..113ccc0 100644 --- a/board/ti/ti814x/evm.h +++ b/board/ti/ti814x/evm.h @@ -4,5 +4,6 @@ void enable_uart0_pin_mux(void); void enable_mmc1_pin_mux(void); void enable_enet_pin_mux(void); +void enable_nand_pin_mux(void);
#endif /* _EVM_H */ diff --git a/board/ti/ti814x/mux.c b/board/ti/ti814x/mux.c index fd9f364..63afe04 100644 --- a/board/ti/ti814x/mux.c +++ b/board/ti/ti814x/mux.c @@ -70,6 +70,35 @@ static struct module_pin_mux enet_pin_mux[] = { {OFFSET(pincntl258), MODE(0x01)}, /* EMAC[0]_MTXEN */ };
+#ifdef CONFIG_NAND +static struct module_pin_mux nand_x16_pin_mux[] = { + {OFFSET(pincntl89) , MODE(1) | PULL_DISABLE}, /* GPMC_AD0 */ + {OFFSET(pincntl90) , MODE(1) | PULL_DISABLE}, /* GPMC_AD1 */ + {OFFSET(pincntl91) , MODE(1) | PULL_DISABLE}, /* GPMC_AD2 */ + {OFFSET(pincntl92) , MODE(1) | PULL_DISABLE}, /* GPMC_AD3 */ + {OFFSET(pincntl93) , MODE(1) | PULL_DISABLE}, /* GPMC_AD4 */ + {OFFSET(pincntl94) , MODE(1) | PULL_DISABLE}, /* GPMC_AD5 */ + {OFFSET(pincntl95) , MODE(1) | PULL_DISABLE}, /* GPMC_AD6 */ + {OFFSET(pincntl96) , MODE(1) | PULL_DISABLE}, /* GPMC_AD7 */ + {OFFSET(pincntl97) , MODE(1) | PULL_DISABLE}, /* GPMC_AD8 */ + {OFFSET(pincntl98) , MODE(1) | PULL_DISABLE}, /* GPMC_AD9 */ + {OFFSET(pincntl99) , MODE(1) | PULL_DISABLE}, /* GPMC_AD10 */ + {OFFSET(pincntl100), MODE(1) | PULL_DISABLE}, /* GPMC_AD11 */ + {OFFSET(pincntl101), MODE(1) | PULL_DISABLE}, /* GPMC_AD12 */ + {OFFSET(pincntl102), MODE(1) | PULL_DISABLE}, /* GPMC_AD13 */ + {OFFSET(pincntl103), MODE(1) | PULL_DISABLE}, /* GPMC_AD14 */ + {OFFSET(pincntl104), MODE(1) | PULL_DISABLE}, /* GPMC_AD15 */ + {OFFSET(pincntl122), MODE(1) | PULLUP_EN}, /* GPMC_CS0 */ + {OFFSET(pincntl128), MODE(1) | PULLDOWN_EN}, /* GPMC_ALE_ADV */ + {OFFSET(pincntl129), MODE(1) | PULLUP_EN}, /* GPMC_OE_RE */ + {OFFSET(pincntl130), MODE(1) | PULLUP_EN}, /* GPMC_WEN */ + {OFFSET(pincntl131), MODE(1) | PULLDOWN_EN}, /* GPMC_BE_CLE */ + {OFFSET(pincntl133), MODE(1) | PULLUP_EN}, /* GPMC_WAIT0 */ + /* GPMC_WPN is controlled by Switch SW11(3) on board */ + {-1}, +}; +#endif + void enable_uart0_pin_mux(void) { configure_module_pin_mux(uart0_pin_mux); @@ -84,3 +113,8 @@ void enable_enet_pin_mux(void) { configure_module_pin_mux(enet_pin_mux); } + +void enable_nand_pin_mux(void) +{ + configure_module_pin_mux(nand_x16_pin_mux); +} diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 2fc2c10..2589e50 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -18,8 +18,8 @@
#define CONFIG_TI81XX #define CONFIG_TI814X -#define CONFIG_SYS_NO_FLASH #define CONFIG_OMAP +#define CONFIG_NAND #define CONFIG_OMAP_COMMON
#include <asm/arch/omap.h> @@ -42,10 +42,32 @@
#define CONFIG_CMD_ASKENV #define CONFIG_VERSION_VARIABLE - #define CONFIG_BOOTDELAY 1 /* negative for no autoboot */ #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + +#ifdef CONFIG_NAND +#define NANDARGS \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "nandargs=setenv bootargs console=${console} " \ + "${optargs} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "dfu_alt_info_nand=" DFU_ALT_INFO_NAND "\0" \ + "nandroot=ubi0:rootfs rw ubi.mtd=7,2048\0" \ + "nandrootfstype=ubifs rootwait=1\0" \ + "nandsrcaddr=0x280000\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${loadaddr} ${nandsrcaddr} ${nandimgsize}; " \ + "bootm ${loadaddr}\0" \ + "nandimgsize=0x500000\0" +#else +#define NANDARGS "" +#endif + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x80200000\0" \ "fdtaddr=0x80F80000\0" \ @@ -196,8 +218,6 @@ #define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000 #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds"
-#define CONFIG_SPL_BOARD_INIT - /* * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM * 64 bytes before this address should be set aside for u-boot.img's @@ -207,7 +227,9 @@ #define CONFIG_SYS_TEXT_BASE 0x80800000 #define CONFIG_SYS_SPL_MALLOC_START 0x80208000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 - +/* defines required in SPL for loading U-BOOT image */ +#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_UBOOT_SIZE 0x240000 /* * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. @@ -239,4 +261,63 @@ #define CONFIG_PHY_ET1011C #define CONFIG_PHY_ET1011C_TX_CLK_FIX
+/* NAND support */ +#ifdef CONFIG_NAND +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_DEVICE_WIDTH 16 +#define CONFIG_SYS_NAND_BLOCK_SIZE 131072 +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_NAND_OMAP_ECCSCHEME 6 +/* generic driver configurations */ +#define CONFIG_NAND_OMAP_GPMC /* required for building nand driver */ +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#define CONFIG_SYS_NAND_BASE 0x08000000 /* physical address to */ + /* access nand at CS0 */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max NAND devices allowed */ +#define CONFIG_CMD_NAND +/* SPL specific configurations */ +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_NAND_AM33XX_BCH /* enable ELM support */ +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_ECC +/* falcon mode specific configs */ +#ifdef CONFIG_SPL_OS_BOOT + #define CONFIG_CMD_SPL_NAND_OFS 0x240000 /* env offset */ + #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 /* kernel offset */ + #define CONFIG_CMD_SPL_WRITE_SIZE 0x1000 +#endif +/* framework specific configurations */ +#if !defined(CONFIG_SPI_BOOT) && !defined(CONFIG_NOR_BOOT) + #define CONFIG_MTD_DEVICE /* Required for mtdparts */ + #define CONFIG_CMD_MTDPARTS + #define MTDIDS_DEFAULT "nand0=omap2-nand.0" + #define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:128k(SPL)," \ + "128k(SPL.backup1)," \ + "128k(SPL.backup2)," \ + "128k(SPL.backup3),1792k(u-boot)," \ + "128k(u-boot-spl-os)," \ + "128k(u-boot-env),5m(kernel),-(rootfs)" +#endif +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ +#undef CONFIG_ENV_IS_NOWHERE /* undef this as env is in NAND */ +#endif /* CONFIG_NAND */ + #endif /* ! __CONFIG_TI814X_EVM_H */
Pekon Gupta
