Re: [U-Boot] [PATCH V8 0/6] add i2c support to pantheon and aramada100
-----Original Message----- From: Prafulla Wadaskar Sent: Wednesday, April 13, 2011 7:57 PM To: 'Lei Wen' Cc: Lei Wen; Heiko Schocher; Wolfgang Denk; u-boot@lists.denx.de; Marek Vasut; Ashish Karkare; Prabhanjan Sarnaik; Yu Tang Subject: RE: [PATCH V8 0/6] add i2c support to pantheon and aramada100
-----Original Message----- From: Lei Wen [mailto:adrian.wenl@gmail.com] Sent: Wednesday, April 13, 2011 7:44 PM To: Prafulla Wadaskar Cc: Lei Wen; Heiko Schocher; Wolfgang Denk; u-boot@lists.denx.de;
Marek
Vasut; Ashish Karkare; Prabhanjan Sarnaik; Yu Tang Subject: Re: [PATCH V8 0/6] add i2c support to pantheon and aramada100
Hi Prafulla,
On Wed, Apr 13, 2011 at 10:01 PM, Prafulla Wadaskar prafulla@marvell.com wrote:
-----Original Message----- From: Lei Wen [mailto:leiwen@marvell.com] Sent: Tuesday, April 05, 2011 1:31 PM To: Heiko Schocher; Prafulla Wadaskar; Wolfgang Denk; u- boot@lists.denx.de; Marek Vasut; Ashish Karkare; Prabhanjan
Sarnaik;
Yu
Tang; adrian.wenl@gmail.com Subject: [PATCH V8 0/6] add i2c support to pantheon and aramada100
V2: rename the previous pxa_i2c to mvi2c, since this driver would be
shared
by many other Marvell platforms.
V3: Clean the code sytle issue
V4: add and* and or* to make set bit operation generic Also make i2c definition included in the ifdef
V5: Fix code style issue of the first patch
V6: Seperate the and* and or* patch out of the patch set Move CONFIG_CMD_I2C define place
V7: Fix comments style Make global change from PXA to MV Move i2c config setting to <arch/config>
V8: Seperate timeout fix patch out
Lei Wen (6): pxa: move i2c driver to the common place mv_i2c: fix timeout value to be consistent with comments mv_i2c: use structure to replace the direclty define I2C: add i2c support for Pantheon platform I2C: mv_i2c: add multi bus support I2C: add i2c support for Armada100 platform
arch/arm/cpu/arm926ejs/armada100/cpu.c | 16 + arch/arm/cpu/arm926ejs/pantheon/cpu.c | 12 + arch/arm/cpu/pxa/Makefile | 1 - arch/arm/cpu/pxa/cpu.c | 10 + arch/arm/cpu/pxa/i2c.c | 469 --------------
arch/arm/include/asm/arch-armada100/config.h | 12 + arch/arm/include/asm/arch-armada100/mfp.h | 40 ++- arch/arm/include/asm/arch-pantheon/config.h | 10 + arch/arm/include/asm/arch-pantheon/cpu.h | 4 +- arch/arm/include/asm/arch-pantheon/mfp.h | 6 +- arch/arm/include/asm/arch-pxa/pxa-regs.h | 56 --- board/Marvell/aspenite/aspenite.c | 5 + board/Marvell/dkb/dkb.c | 4 + board/innokom/innokom.c | 9 +- drivers/i2c/Makefile | 1 + drivers/i2c/mv_i2c.c | 481 ++++++++++++++++++++++++++ drivers/i2c/mv_i2c.h | 83 +++++ include/configs/aspenite.h | 1 + include/configs/dkb.h | 2 + include/configs/innokom.h | 2 + include/configs/xm250.h | 2 + 21 files changed, 671 insertions(+), 555 deletions(-) delete mode 100644 arch/arm/cpu/pxa/i2c.c create mode 100644 drivers/i2c/mv_i2c.c create mode 100644 drivers/i2c/mv_i2c.h
Dear Lei I have trying to apply this patch series to u-boot-marvell.git
master
branch.
Since I have rebased this branch to latest u-boot-arm.git master.
This patch series cannot be cleanly applied.
Can you pls provide new one in sync with latest pull from u-boot-
marvell.git master branch?
I just apply those patch on master branch without any warning. Are you apply the V8 series?
Yes, I am using V8 patches. Have you done git pull before that? What is your latest git log? (before applying patches)
Sorry for the noise Lei. I could apply them cleanly.
Regards.. Prafulla . .
Prafulla Wadaskar
