[U-Boot] [PATCH 1/1] board/ls2080aqds, SD-boot: Update env offset
As per new memory layout, Update env offset from 0x200000 to 0x300000
Signed-off-by: Santan Kumar santan.kumar@nxp.com --- include/configs/ls2080aqds.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 8a8ee9d..c32c184 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -238,7 +238,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NAND_U_BOOT_OFFS (256 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 * 1024) #elif defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_OFFSET 0x200000 +#define CONFIG_ENV_OFFSET 0x300000 #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x20000
LS2080ARDB/LS2088ARDB updated RevF boards do not have smart voltage translator, so no need to program GPIO for LS2088ARDB boards The GPIO programming is required only for LS2081ARDB.
Signed-off-by: Santan Kumar santan.kumar@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- board/freescale/ls2080ardb/ls2080ardb.c | 18 ++---------------- 1 file changed, 2 insertions(+), 16 deletions(-)
diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index df2d768..210142c 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -257,31 +257,17 @@ int board_early_init_f(void)
int misc_init_r(void) { -#ifdef CONFIG_FSL_QIXIS - /* - * LS2081ARDB has smart voltage translator which needs - * to be programmed as below - */ -#ifndef CONFIG_TARGET_LS2081ARDB - u8 sw; - - sw = QIXIS_READ(arch); /* - * LS2080ARDB/LS2088ARDB RevF board has smart voltage translator + * LS2081ARDB RevF board has smart voltage translator * which needs to be programmed to enable high speed SD interface * by setting GPIO4_10 output to zero */ - if ((sw & 0xf) == 0x5) { -#endif +#ifdef CONFIG_TARGET_LS2081ARDB out_le32(GPIO4_GPDIR_ADDR, (1 << 21 | in_le32(GPIO4_GPDIR_ADDR))); out_le32(GPIO4_GPDAT_ADDR, (~(1 << 21) & in_le32(GPIO4_GPDAT_ADDR))); -#ifndef CONFIG_TARGET_LS2081ARDB - } -#endif #endif - if (hwconfig("sdhc")) config_board_mux(MUX_TYPE_SDHC);
- u8 sw;
- which needs to be programmed to enable high speed SD interface
- by setting GPIO4_10 output to zero
-#endif #endif
This change is not backward-compatible, is it?
York
-----Original Message----- From: York Sun Sent: Wednesday, June 14, 2017 2:16 AM To: Santan Kumar santan.kumar@nxp.com; u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com Subject: Re: [PATCH 1/1] board/ls2080ardb: Disable SD-related GPIO programming
- u8 sw;
#ifndef
-#endif #endif
York
Yes, It is backward compatible. As per updated board designs and the manufactured boards, GPIO programming is required only for LS2081ARDB boards.
Priyanka
- u8 sw;
#ifndef
-#endif #endif
York
Priyanka,
I looked at this patch again. Before this change, LS2080ARDB rev F and LS2081ARDB both have the smart voltage translator enabled. After this change, rev F no longer enables this voltage translator. You still consider it backward-compatible?
York
-----Original Message----- From: York Sun Sent: Tuesday, August 08, 2017 2:20 AM To: Priyanka Jain priyanka.jain@nxp.com; Santan Kumar santan.kumar@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH 1/1] board/ls2080ardb: Disable SD-related GPIO programming
- u8 sw;
#ifndef
-#endif #endif
York
Priyanka,
I looked at this patch again. Before this change, LS2080ARDB rev F and LS2081ARDB both have the smart voltage translator enabled. After this change, rev F no longer enables this voltage translator. You still consider it backward- compatible?
York
Both LS2080ARDB rev F and LS2081ARDB were initially designed to have smart voltage translator to support SD-boot and UHS mode At a later stage, due to some issues on LS2088ARDB RevF board to support SD-boot, translator was removed from RevF boards.
I confirmed with board team that all LS2088ARDB RevF board will not have the smart voltage translator and all LS2081ARDB boards will have smart voltage translator.
Priyanka
On 08/07/2017 10:18 PM, Priyanka Jain wrote: <snip>
York
Priyanka,
York
OK. Thanks.
York
Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Patch makes below changes: -As per updated board design, different QSPI flash is connected on boards, hence change QSPI flash type from n25q512a to s25fs512ss -Remove deprecated config : CONFIG_DISPLAY_BOARDINFO_LATE -Increase env size from 64kb to 256kb for qspi boot -Update checkboard() to detect boot source and display message
Signed-off-by: Santan Kumar santan.kumar@nxp.com Signed-off-by: Yogesh Gaur yogeshnarayan.gaur@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- arch/arm/dts/fsl-ls2081a-rdb.dts | 4 ++-- board/freescale/ls2080ardb/ls2080ardb.c | 15 +++------------ include/configs/ls2080a_common.h | 2 +- include/configs/ls2080ardb.h | 7 +------ 4 files changed, 7 insertions(+), 21 deletions(-)
diff --git a/arch/arm/dts/fsl-ls2081a-rdb.dts b/arch/arm/dts/fsl-ls2081a-rdb.dts index 6489362..aa4aa68 100644 --- a/arch/arm/dts/fsl-ls2081a-rdb.dts +++ b/arch/arm/dts/fsl-ls2081a-rdb.dts @@ -41,7 +41,7 @@ bus-num = <0>; status = "okay";
- qflash0: n25q512a@0 { + qflash0: s25fs512s@0 { #address-cells = <1>; #size-cells = <1>; compatible = "spi-flash"; @@ -49,7 +49,7 @@ reg = <0>; };
- qflash1: n25q512a@1 { + qflash1: s25fs512s@1 { #address-cells = <1>; #size-cells = <1>; compatible = "spi-flash"; diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index 210142c..9d21d1e 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -71,36 +71,27 @@ int checkboard(void) #ifdef CONFIG_TARGET_LS2081ARDB #ifdef CONFIG_FSL_QIXIS sw = QIXIS_READ(arch); - printf("Board Arch: V%d, ", sw >> 4); printf("Board version: %c, ", (sw & 0xf) + 'A');
sw = QIXIS_READ(brdcfg[0]); - sw = (sw & QIXIS_QMAP_MASK) >> QIXIS_QMAP_SHIFT; + sw = sw >> QIXIS_QMAP_SHIFT; switch (sw) { case 0: + case 4: puts("boot from QSPI DEV#0\n"); - puts("QSPI_CSA_1 mapped to QSPI DEV#1\n"); break; case 1: puts("boot from QSPI DEV#1\n"); - puts("QSPI_CSA_1 mapped to QSPI DEV#0\n"); break; case 2: - puts("boot from QSPI EMU\n"); - puts("QSPI_CSA_1 mapped to QSPI DEV#0\n"); - break; case 3: puts("boot from QSPI EMU\n"); - puts("QSPI_CSA_1 mapped to QSPI DEV#1\n"); - break; - case 4: - puts("boot from QSPI DEV#0\n"); - puts("QSPI_CSA_1 mapped to QSPI EMU\n"); break; default: printf("invalid setting of SW%u\n", sw); break; } + printf("FPGA: v%d.%d\n", QIXIS_READ(scver), QIXIS_READ(tagdata)); #endif puts("SERDES1 Reference : "); printf("Clock1 = 100MHz "); diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index e311d0b..68191f2 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -34,7 +34,7 @@ #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 +#define CONFIG_ENV_SECT_SIZE 0x40000 #endif
#define CONFIG_SUPPORT_RAW_INITRD diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 2dab065..a5f7eea 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -18,7 +18,6 @@ #define CONFIG_QIXIS_I2C_ACCESS #endif #define CONFIG_SYS_I2C_EARLY_INIT -#define CONFIG_DISPLAY_BOARDINFO_LATE #endif
#define I2C_MUX_CH_VOL_MONITOR 0xa @@ -293,19 +292,15 @@ unsigned long get_board_sys_clk(void); /* SPI */ #if defined(CONFIG_FSL_QSPI) || defined(CONFIG_FSL_DSPI) #define CONFIG_SPI_FLASH -#ifdef CONFIG_FSL_QSPI +#ifdef CONFIG_FSL_DSPI #define CONFIG_SPI_FLASH_STMICRO #endif #ifdef CONFIG_FSL_QSPI -#ifdef CONFIG_TARGET_LS2081ARDB -#define CONFIG_SPI_FLASH_STMICRO -#else #define CONFIG_SPI_FLASH_SPANSION #endif #define FSL_QSPI_FLASH_SIZE SZ_64M /* 64MB */ #define FSL_QSPI_FLASH_NUM 2 #endif -#endif
/* * RTC configuration
Please separate common change from board specific change.
- qflash0: s25fs512s@0 {
Is there any version of LS2081ARDB with n25q512a?
- qflash1: s25fs512s@1 { #address-cells = <1>; #size-cells = <1>; compatible = "spi-flash";
What's the reason to drop "Board Arch"?
- sw = sw >> QIXIS_QMAP_SHIFT; switch (sw) { case 0:
- case 4: puts("boot from QSPI DEV#0\n");
break; case 1: puts("boot from QSPI DEV#1\n");puts("QSPI_CSA_1 mapped to QSPI DEV#1\n");
break; case 2:puts("QSPI_CSA_1 mapped to QSPI DEV#0\n");
case 3: puts("boot from QSPI EMU\n");break;
break;
- case 4:
break; default: printf("invalid setting of SW%u\n", sw); break; }puts("QSPI_CSA_1 mapped to QSPI EMU\n");
- printf("FPGA: v%d.%d\n", QIXIS_READ(scver), QIXIS_READ(tagdata));
What are you changing in this function?
York
-----Original Message----- From: York Sun Sent: Wednesday, June 14, 2017 2:23 AM To: Santan Kumar santan.kumar@nxp.com; u-boot@lists.denx.de Cc: Yogesh Narayan Gaur yogeshnarayan.gaur@nxp.com; Priyanka Jain priyanka.jain@nxp.com Subject: Re: [PATCH 1/1] board/ls2081ardb: Update qspi flash type and checkboard
rdb.dts
No, All ls2081ardb boards will have s25fs512s device
Based on feedback from board team, this is not required for RDB boards Arch contains Qixis architecture version to use common Qixis image across multipl platforms. This field is relevant for QDS boards. For RDB boards it is always constant as '1'
break;
- case 4:
York
Sw value is updated to sw = sw >> QIXIS_QMP_SHIFT Instead of sw = (sw & QIXIS_QMAP_MASK) >> QIXIS_QMAP_SHIFT Also With earlier version of prints, u-boot boot messages were confusing. So, tried to make the bootlogs similar to Nor boot bootlogs to make them more user friendly.
Priyanka
Signed-off-by: Santan Kumar santan.kumar@nxp.com --- drivers/usb/common/fsl-errata.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/usb/common/fsl-errata.c b/drivers/usb/common/fsl-errata.c index 338ac08..383a433 100644 --- a/drivers/usb/common/fsl-errata.c +++ b/drivers/usb/common/fsl-errata.c @@ -198,6 +198,10 @@ bool has_erratum_a010151(void) #ifdef CONFIG_ARM64 case SVR_LS2080A: case SVR_LS2085A: + /* fallthrough */ + case SVR_LS2088A: + /* fallthrough */ + case SVR_LS2081A: case SVR_LS1046A: case SVR_LS1012A: return IS_SVR_REV(svr, 1, 0);
Applied to fsl-qoriq master. Thanks.
York
Update SVR as per the SOC document. -LS2081A: 0x870919 -> 0x870918 -LS2041A: 0x870915 -> 0x870914
Signed-off-by: Santan Kumar santan.kumar@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/soc.h | 4 ++-- drivers/pci/pcie_layerscape.h | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index cc3b079..fae5730 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -55,8 +55,8 @@ struct cpu_type { #define SVR_LS2084A 0x870910 #define SVR_LS2048A 0x870920 #define SVR_LS2044A 0x870930 -#define SVR_LS2081A 0x870919 -#define SVR_LS2041A 0x870915 +#define SVR_LS2081A 0x870918 +#define SVR_LS2041A 0x870914
#define SVR_DEV_LS2080A 0x8701
diff --git a/drivers/pci/pcie_layerscape.h b/drivers/pci/pcie_layerscape.h index 308b073..782e3ab 100644 --- a/drivers/pci/pcie_layerscape.h +++ b/drivers/pci/pcie_layerscape.h @@ -118,8 +118,8 @@ #define SVR_LS2084A 0x870910 #define SVR_LS2048A 0x870920 #define SVR_LS2044A 0x870930 -#define SVR_LS2081A 0x870919 -#define SVR_LS2041A 0x870915 +#define SVR_LS2081A 0x870918 +#define SVR_LS2041A 0x870914
/* LS1021a PCIE space */ #define LS1021_PCIE_SPACE_OFFSET 0x4000000000ULL
York
York
Priyanka Jain
Santan Kumar
York Sun
