[PATCH v5 0/5] efi: Start to chip away at the EFI workaround
At present there is a function, efi_set_bootdev(), which is used in various places to tell the EFI loader which device a file came from.
With bootstd, this information is available in the bootflow.
This little series provides a way for bootstd to provide the bootflow to the EFI loader, so that it is able to select the correct paths.
For now only the EFI bootmeth is updated.
Changes in v5: - Rename the parameters - Drop the image->image_ptr rename - Rename _efi_binary_run() to efi_binary_run_dp() - Rebase on earlier changes - Rebase on earlier change
Changes in v3: - Rename efi_binary_run_() to _efi_binary_run() - Add new patch to support PXE booting - Rebase on Tom's tree (i.e. without the pointers/addresses series) https://patchwork.ozlabs.org/project/uboot/list/?series=436241
Changes in v2: - Adjust argument ordering for efi_run_image() - Use efi_loader tag instead of efi - Drop unnecessary path removal - Fix 'require' typo - Move calculation of dev-name into a separate function
Simon Glass (5): efi_loader: Update efi_run_image() to accept image and device path efi_loader: Add a version of efi_binary_run() with more parameters efi_loader: Move the fallback code from efi_run_image() efi_loader: Pass in the required parameters from EFI bootmeth bootmeth_efi: Support PXE booting
boot/bootmeth_efi.c | 64 +----------- include/efi_loader.h | 10 ++ lib/efi_loader/efi_bootbin.c | 189 +++++++++++++++++++++++++++-------- 3 files changed, 160 insertions(+), 103 deletions(-)
Provide these globals as parameters to this function, on the way to making it possible to start an image without relying on the globals.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org ---
lib/efi_loader/efi_bootbin.c | 16 ++++++++++------ 1 file changed, 10 insertions(+), 6 deletions(-)
diff --git a/lib/efi_loader/efi_bootbin.c b/lib/efi_loader/efi_bootbin.c index 428991df88f..71591dd54b9 100644 --- a/lib/efi_loader/efi_bootbin.c +++ b/lib/efi_loader/efi_bootbin.c @@ -157,9 +157,13 @@ void efi_set_bootdev(const char *dev, const char *devnr, const char *path, * * @source_buffer: memory address of the UEFI image * @source_size: size of the UEFI image + * @dp_dev: EFI device-path + * @dp_img: EFI image-path * Return: status code */ -static efi_status_t efi_run_image(void *source_buffer, efi_uintn_t source_size) +static efi_status_t efi_run_image(void *source_buffer, efi_uintn_t source_size, + struct efi_device_path *dp_dev, + struct efi_device_path *dp_img) { efi_handle_t mem_handle = NULL, handle; struct efi_device_path *file_path = NULL; @@ -167,7 +171,7 @@ static efi_status_t efi_run_image(void *source_buffer, efi_uintn_t source_size) efi_status_t ret; u16 *load_options;
- if (!bootefi_device_path || !bootefi_image_path) { + if (!dp_img || !dp_img) { log_debug("Not loaded from disk\n"); /* * Special case for efi payload not loaded from disk, @@ -188,9 +192,8 @@ static efi_status_t efi_run_image(void *source_buffer, efi_uintn_t source_size) goto out; msg_path = file_path; } else { - file_path = efi_dp_concat(bootefi_device_path, - bootefi_image_path, 0); - msg_path = bootefi_image_path; + file_path = efi_dp_concat(dp_img, dp_img, 0); + msg_path = dp_img; log_debug("Loaded from disk\n"); }
@@ -252,5 +255,6 @@ efi_status_t efi_binary_run(void *image, size_t size, void *fdt) if (ret != EFI_SUCCESS) return ret;
- return efi_run_image(image, size); + return efi_run_image(image, size, bootefi_device_path, + bootefi_image_path); }
This uses a few global variables at present. With the bootflow we have the required parameters, so add a function which accepts these. Update the existing function to call the new one with the globals.
Changes in v5: - Rename _efi_binary_run() to efi_binary_run_dp()
lib/efi_loader/efi_bootbin.c | 29 +++++++++++++++++++++++++---- 1 file changed, 25 insertions(+), 4 deletions(-)
diff --git a/lib/efi_loader/efi_bootbin.c b/lib/efi_loader/efi_bootbin.c index 71591dd54b9..789da8bcda0 100644 --- a/lib/efi_loader/efi_bootbin.c +++ b/lib/efi_loader/efi_bootbin.c @@ -228,18 +228,22 @@ out: }
/** - * efi_binary_run() - run loaded UEFI image + * efi_binary_run_dp() - run loaded UEFI image * * @image: memory address of the UEFI image * @size: size of the UEFI image * @fdt: device-tree + * @dp_dev: EFI device-path + * @dp_img: EFI image-path * * Execute an EFI binary image loaded at @image. * @size may be zero if the binary is loaded with U-Boot load command. * * Return: status code */ -efi_status_t efi_binary_run(void *image, size_t size, void *fdt) +efi_status_t efi_binary_run_dp(void *image, size_t size, void *fdt, + struct efi_device_path *dp_dev, + struct efi_device_path *dp_img) { efi_status_t ret;
@@ -255,6 +259,23 @@ efi_status_t efi_binary_run(void *image, size_t size, void *fdt) if (ret != EFI_SUCCESS) return ret;
- return efi_run_image(image, size, bootefi_device_path, - bootefi_image_path); + return efi_run_image(image, size, dp_dev, dp_img); +} + +/** + * efi_binary_run() - run loaded UEFI image + * + * @image: memory address of the UEFI image + * @size: size of the UEFI image + * @fdt: device-tree + * + * Execute an EFI binary image loaded at @image. + * @size may be zero if the binary is loaded with U-Boot load command. + * + * Return: status code + */ +efi_status_t efi_binary_run(void *image, size_t size, void *fdt) +{ + return efi_binary_run_dp(image, size, fdt, bootefi_device_path, + bootefi_image_path); }
This code is only needed if an invalid image/device path is passed in. Move the code out to a caller where this can be dealt with. The normal flow will provide these parameters.
Changes in v5: - Rebase on earlier changes
lib/efi_loader/efi_bootbin.c | 90 +++++++++++++++++++----------------- 1 file changed, 48 insertions(+), 42 deletions(-)
diff --git a/lib/efi_loader/efi_bootbin.c b/lib/efi_loader/efi_bootbin.c index 789da8bcda0..fdb4c6e4b51 100644 --- a/lib/efi_loader/efi_bootbin.c +++ b/lib/efi_loader/efi_bootbin.c @@ -165,37 +165,13 @@ static efi_status_t efi_run_image(void *source_buffer, efi_uintn_t source_size, struct efi_device_path *dp_dev, struct efi_device_path *dp_img) { - efi_handle_t mem_handle = NULL, handle; - struct efi_device_path *file_path = NULL; - struct efi_device_path *msg_path; + efi_handle_t handle; + struct efi_device_path *msg_path, *file_path; efi_status_t ret; u16 *load_options;
- if (!dp_img || !dp_img) { - log_debug("Not loaded from disk\n"); - /* - * Special case for efi payload not loaded from disk, - * such as 'bootefi hello' or for example payload - * loaded directly into memory via JTAG, etc: - */ - file_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, - (uintptr_t)source_buffer, - source_size); - /* - * Make sure that device for device_path exist - * in load_image(). Otherwise, shell and grub will fail. - */ - ret = efi_install_multiple_protocol_interfaces(&mem_handle, - &efi_guid_device_path, - file_path, NULL); - if (ret != EFI_SUCCESS) - goto out; - msg_path = file_path; - } else { - file_path = efi_dp_concat(dp_img, dp_img, 0); - msg_path = dp_img; - log_debug("Loaded from disk\n"); - } + file_path = efi_dp_concat(dp_dev, dp_img, 0); + msg_path = dp_img;
log_info("Booting %pD\n", msg_path);
@@ -214,15 +190,6 @@ static efi_status_t efi_run_image(void *source_buffer, efi_uintn_t source_size, ret = do_bootefi_exec(handle, load_options);
out: - if (mem_handle) { - efi_status_t r; - - r = efi_uninstall_multiple_protocol_interfaces( - mem_handle, &efi_guid_device_path, file_path, NULL); - if (r != EFI_SUCCESS) - log_err("Uninstalling protocol interfaces failed\n"); - } - efi_free_pool(file_path);
return ret; } @@ -241,9 +208,9 @@ out: * * Return: status code */ -efi_status_t efi_binary_run_dp(void *image, size_t size, void *fdt, - struct efi_device_path *dp_dev, - struct efi_device_path *dp_img) +static efi_status_t efi_binary_run_dp(void *image, size_t size, void *fdt, + struct efi_device_path *dp_dev, + struct efi_device_path *dp_img) { efi_status_t ret;
@@ -276,6 +243,45 @@ efi_status_t efi_binary_run_dp(void *image, size_t size, void *fdt, */ efi_status_t efi_binary_run(void *image, size_t size, void *fdt) { - return efi_binary_run_dp(image, size, fdt, bootefi_device_path, - bootefi_image_path); + efi_handle_t mem_handle = NULL; + struct efi_device_path *file_path = NULL; + efi_status_t ret; + + if (!bootefi_device_path || !bootefi_image_path) { + log_debug("Not loaded from disk\n"); + /* + * Special case for efi payload not loaded from disk, + * such as 'bootefi hello' or for example payload + * loaded directly into memory via JTAG, etc: + */ + file_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, + (uintptr_t)image, size); + /* + * Make sure that device for device_path exist + * in load_image(). Otherwise, shell and grub will fail. + */ + ret = efi_install_multiple_protocol_interfaces(&mem_handle, + &efi_guid_device_path, + file_path, NULL); + if (ret != EFI_SUCCESS) + goto out; + } else { + log_debug("Loaded from disk\n"); + } + + ret = efi_binary_run_dp(image, size, fdt, bootefi_device_path, + bootefi_image_path); +out: + if (mem_handle) { + efi_status_t r; + + r = efi_uninstall_multiple_protocol_interfaces(mem_handle, + &efi_guid_device_path, file_path, NULL); + if (r != EFI_SUCCESS) + log_err("Uninstalling protocol interfaces failed\n"); + } + efi_free_pool(file_path); + + return ret; } +
Rather than setting up the global variables and then making the call, pass them into function directly. This cleans up the code and makes it all a bit easier to understand.
Changes in v2: - Use efi_loader tag instead of efi - Drop unnecessary path removal - Fix 'require' typo - Move calculation of dev-name into a separate function
boot/bootmeth_efi.c | 49 +------------------------ include/efi_loader.h | 10 +++++ lib/efi_loader/efi_bootbin.c | 71 ++++++++++++++++++++++++++++++++++++ 3 files changed, 83 insertions(+), 47 deletions(-)
diff --git a/boot/bootmeth_efi.c b/boot/bootmeth_efi.c index a2998452666..b745ba8bd4b 100644 --- a/boot/bootmeth_efi.c +++ b/boot/bootmeth_efi.c @@ -52,40 +52,6 @@ static bool bootmeth_uses_network(struct bootflow *bflow) device_get_uclass_id(media) == UCLASS_ETH; }
-static void set_efi_bootdev(struct blk_desc *desc, struct bootflow *bflow) -{ - const struct udevice *media_dev; - int size = bflow->size; - const char *dev_name; - char devnum_str[9]; - char dirname[200]; - char *last_slash; - - /* - * This is a horrible hack to tell EFI about this boot device. Once we - * unify EFI with the rest of U-Boot we can clean this up. The same hack - * exists in multiple places, e.g. in the fs, tftp and load commands. - * - * Once we can clean up the EFI code to make proper use of driver model, - * this can go away. - */ - media_dev = dev_get_parent(bflow->dev); - snprintf(devnum_str, sizeof(devnum_str), "%x:%x", - desc ? desc->devnum : dev_seq(media_dev), - bflow->part); - - strlcpy(dirname, bflow->fname, sizeof(dirname)); - last_slash = strrchr(dirname, '/'); - if (last_slash) - *last_slash = '\0'; - - dev_name = device_get_uclass_id(media_dev) == UCLASS_MASS_STORAGE ? - "usb" : blk_get_uclass_name(device_get_uclass_id(media_dev)); - log_debug("setting bootdev %s, %s, %s, %p, %x\n", - dev_name, devnum_str, bflow->fname, bflow->buf, size); - efi_set_bootdev(dev_name, devnum_str, bflow->fname, bflow->buf, size); -} - static int efiload_read_file(struct bootflow *bflow, ulong addr) { struct blk_desc *desc = NULL; @@ -102,8 +68,6 @@ static int efiload_read_file(struct bootflow *bflow, ulong addr) return log_msg_ret("rdf", ret); bflow->buf = map_sysmem(addr, bflow->size);
- set_efi_bootdev(desc, bflow); - return 0; }
@@ -344,17 +308,8 @@ static int distro_efi_boot(struct udevice *dev, struct bootflow *bflow) fdt = env_get_hex("fdt_addr_r", 0); }
- if (bflow->flags & BOOTFLOWF_USE_BUILTIN_FDT) { - log_debug("Booting with built-in fdt\n"); - if (efi_binary_run(map_sysmem(kernel, 0), bflow->size, - EFI_FDT_USE_INTERNAL)) - return log_msg_ret("run", -EINVAL); - } else { - log_debug("Booting with external fdt\n"); - if (efi_binary_run(map_sysmem(kernel, 0), bflow->size, - map_sysmem(fdt, 0))) - return log_msg_ret("run", -EINVAL); - } + if (efi_bootflow_run(bflow)) + return log_msg_ret("run", -EINVAL);
return 0; } diff --git a/include/efi_loader.h b/include/efi_loader.h index 0d858c1e12e..2243e3a179c 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -20,6 +20,7 @@ #include <linux/oid_registry.h>
struct blk_desc; +struct bootflow; struct jmp_buf_data;
#if CONFIG_IS_ENABLED(EFI_LOADER) @@ -578,6 +579,15 @@ efi_status_t efi_install_fdt(void *fdt); efi_status_t do_bootefi_exec(efi_handle_t handle, void *load_options); /* Run loaded UEFI image with given fdt */ efi_status_t efi_binary_run(void *image, size_t size, void *fdt); + +/** + * efi_bootflow_run() - Run a bootflow containing an EFI application + * + * @bootflow: Bootflow to run + * Return: Status code, something went wrong + */ +efi_status_t efi_bootflow_run(struct bootflow *bootflow); + /* Initialize variable services */ efi_status_t efi_init_variables(void); /* Notify ExitBootServices() is called */ diff --git a/lib/efi_loader/efi_bootbin.c b/lib/efi_loader/efi_bootbin.c index fdb4c6e4b51..efc2ca36c0f 100644 --- a/lib/efi_loader/efi_bootbin.c +++ b/lib/efi_loader/efi_bootbin.c @@ -6,13 +6,16 @@
#define LOG_CATEGORY LOGC_EFI
+#include <bootflow.h> #include <charset.h> +#include <dm.h> #include <efi.h> #include <efi_loader.h> #include <env.h> #include <image.h> #include <log.h> #include <malloc.h> +#include <mapmem.h>
static struct efi_device_path *bootefi_image_path; static struct efi_device_path *bootefi_device_path; @@ -285,3 +288,71 @@ out: return ret; }
+/** + * calc_dev_name() - Calculate the device name to give to EFI + * + * If not supported, this shows an error. + * + * Return name, or NULL if not supported + */ +static const char *calc_dev_name(struct bootflow *bflow) +{ + const struct udevice *media_dev; + + media_dev = dev_get_parent(bflow->dev); + + if (!bflow->blk) { + log_err("Cannot boot EFI app on media '%s'\n", + dev_get_uclass_name(media_dev)); + + return NULL; + } + + if (device_get_uclass_id(media_dev) == UCLASS_MASS_STORAGE) + return "usb"; + + return blk_get_uclass_name(device_get_uclass_id(media_dev)); +} + +efi_status_t efi_bootflow_run(struct bootflow *bflow) +{ + struct efi_device_path *device, *image; + const struct udevice *media_dev; + struct blk_desc *desc = NULL; + const char *dev_name; + char devnum_str[9]; + efi_status_t ret; + void *fdt; + + media_dev = dev_get_parent(bflow->dev); + if (bflow->blk) { + desc = dev_get_uclass_plat(bflow->blk); + + snprintf(devnum_str, sizeof(devnum_str), "%x:%x", + desc ? desc->devnum : dev_seq(media_dev), bflow->part); + } else { + *devnum_str = '\0'; + } + + dev_name = calc_dev_name(bflow); + log_debug("dev_name '%s' devnum_str '%s' fname '%s' media_dev '%s'\n", + dev_name, devnum_str, bflow->fname, media_dev->name); + if (!dev_name) + return EFI_UNSUPPORTED; + ret = calculate_paths(dev_name, devnum_str, bflow->fname, &device, + &image); + if (ret) + return ret; + + if (bflow->flags & BOOTFLOWF_USE_BUILTIN_FDT) { + log_debug("Booting with built-in fdt\n"); + fdt = EFI_FDT_USE_INTERNAL; + } else { + log_debug("Booting with external fdt\n"); + fdt = map_sysmem(bflow->fdt_addr, 0); + } + ret = efi_binary_run_dp(bflow->buf, bflow->size, fdt, device, image); + + return ret; +} +
Finish off the implementation so it is possible to boot an EFI app over a network.
(no changes since v3)
Changes in v3: - Add new patch to support PXE booting - Rebase on Tom's tree (i.e. without the pointers/addresses series) https://patchwork.ozlabs.org/project/uboot/list/?series=436241
boot/bootmeth_efi.c | 15 +-------------- lib/efi_loader/efi_bootbin.c | 5 ++++- 2 files changed, 5 insertions(+), 15 deletions(-)
diff --git a/boot/bootmeth_efi.c b/boot/bootmeth_efi.c index b745ba8bd4b..0c9b4c3d59d 100644 --- a/boot/bootmeth_efi.c +++ b/boot/bootmeth_efi.c @@ -210,6 +210,7 @@ static int distro_efi_read_bootflow_net(struct bootflow *bflow) if (size <= 0) return log_msg_ret("sz", -EINVAL); bflow->size = size; + bflow->buf = map_sysmem(addr, size);
/* bootfile should be setup by dhcp */ bootfile_name = env_get("bootfile"); @@ -219,10 +220,6 @@ static int distro_efi_read_bootflow_net(struct bootflow *bflow) if (!bflow->fname) return log_msg_ret("fi0", -ENOMEM);
- /* do the hideous EFI hack */ - efi_set_bootdev("Net", "", bflow->fname, map_sysmem(addr, 0), - bflow->size); - /* read the DT file also */ fdt_addr_str = env_get("fdt_addr_r"); if (!fdt_addr_str) @@ -296,16 +293,6 @@ static int distro_efi_boot(struct udevice *dev, struct bootflow *bflow) if (bflow->flags & ~BOOTFLOWF_USE_BUILTIN_FDT) fdt = bflow->fdt_addr;
- } else { - /* - * This doesn't actually work for network devices: - * - * do_bootefi_image() No UEFI binary known at 0x02080000 - * - * But this is the same behaviour for distro boot, so it can be - * fixed here. - */ - fdt = env_get_hex("fdt_addr_r", 0); }
if (efi_bootflow_run(bflow)) diff --git a/lib/efi_loader/efi_bootbin.c b/lib/efi_loader/efi_bootbin.c index efc2ca36c0f..f015d7946b4 100644 --- a/lib/efi_loader/efi_bootbin.c +++ b/lib/efi_loader/efi_bootbin.c @@ -302,6 +302,9 @@ static const char *calc_dev_name(struct bootflow *bflow) media_dev = dev_get_parent(bflow->dev);
if (!bflow->blk) { + if (device_get_uclass_id(media_dev) == UCLASS_ETH) + return "Net"; + log_err("Cannot boot EFI app on media '%s'\n", dev_get_uclass_name(media_dev));
@@ -342,7 +345,7 @@ efi_status_t efi_bootflow_run(struct bootflow *bflow) ret = calculate_paths(dev_name, devnum_str, bflow->fname, &device, &image); if (ret) - return ret; + return EFI_UNSUPPORTED;
if (bflow->flags & BOOTFLOWF_USE_BUILTIN_FDT) { log_debug("Booting with built-in fdt\n");
