[U-Boot] [PATCH] net/designware: revert MAC-address setup on init
http://git.denx.de/?p=u-boot.git;a=patch;h=f566c9949fbdce2e09a900c5343ca9986... broke DW GMAC operation if !DM_ETH because eth_write_hwaddr() doesn't exist if !DM_NET.
As for DM_ETH case I'm still not sure if existing implementation will fly.
The point is as it is said in the comment on "soft reset" that is triggered with setting DMAMAC_SRST in "busmode" register HW address gets reset as well. And we inevitably need to set HW address again.
So probably better solution is to move mentioned "soft-reset" from "init" (that is used on start of any network activity) to "initialize" (which is only executed once in "board_r" sequence). But that's a bit of a different story and for now let's just get DW GMAC functional again.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Michal Simek michal.simek@xilinx.com Cc: Tom Rini trini@konsulko.com --- drivers/net/designware.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index ae51cf3..07281a6 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -243,6 +243,10 @@ static int _dw_eth_init(struct dw_eth_dev *priv, u8 *enetaddr) mdelay(100); };
+ /* Soft reset above clears HW address registers. + * So we have to set it here once again */ + _dw_write_hwaddr(priv, enetaddr); + rx_descs_init(priv); tx_descs_init(priv);
Hi Alexey,
On Wed, Jul 1, 2015 at 9:59 PM, Alexey Brodkin Alexey.Brodkin@synopsys.com wrote:
There is already a patch submitted. Please check http://patchwork.ozlabs.org/patch/484214/
Regards, Bin
Hi Tom, Joe,
On Wed, 2015-07-01 at 22:22 +0800, Bin Meng wrote:
Hi Alexey,
http://git.denx.de/?p=u -boot.git;a=patch;h=f566c9949fbdce2e09a900c5343ca9986e5ba360 broke DW GMAC operation if !DM_ETH because eth_write_hwaddr() doesn't exist if !DM_NET.
Any chance for mentioned patch "net: designware: Program MAC address to hardware after soft reset" to be applied?
This really fixes GMAC operation and it would be nice to have this fix in upcoming release.
-Alexey
Hi Alexey,
On Wed, Jul 1, 2015 at 9:25 AM, Alexey Brodkin Alexey.Brodkin@synopsys.com wrote:
Hi Tom, Joe,
Hi Alexey,
I think that sounds appropriate. Tom?
-Joe
On Wed, Jul 01, 2015 at 10:26:21AM -0500, Joe Hershberger wrote:
Hi Alexey,
Hi Tom, Joe,
Hi Alexey,
Yes. Of the handful of recent (in my mind anyhow) net patches, are you going to do a PR for them or should I just grab things?
Hi Joe,
Hi Alexey,
Hi Tom, Joe,
Hi Alexey,
Any chance to see that patch upstream anytime soon?
-Alexey
Hey Tom,
Hi Alexey,
Hi Tom, Joe,
Hi Alexey,
Sorry, was on vacation. I think you can just grab this one. Is there another you are thinking of that is a bug fix for this release?
Thanks, -Joe
Hi Joe,
On Tue, Jul 7, 2015 at 5:55 AM, Joe Hershberger joe.hershberger@gmail.com wrote:
Hey Tom,
Hi Alexey,
Hi Tom, Joe,
Hi Alexey,
I think you want Tom to grab the previous one here http://patchwork.ozlabs.org/patch/484214/
Regards, Bin
Hi Bin,
On Tue, Jul 7, 2015 at 10:46 PM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Joe,
Hey Tom,
Hi Alexey,
Hi Tom, Joe,
Hi Alexey,
On Wed, Jul 1, 2015 at 9:59 PM, Alexey Brodkin Alexey.Brodkin@synopsys.com wrote: > http://git.denx.de/?p=u > -boot.git;a=patch;h=f566c9949fbdce2e09a900c5343ca9986e5ba360 > broke DW GMAC operation if !DM_ETH because eth_write_hwaddr() > doesn't > exist if !DM_NET. > > As for DM_ETH case I'm still not sure if existing implementation > will > fly. > > The point is as it is said in the comment on "soft reset" that is > triggered with setting DMAMAC_SRST in "busmode" register HW address > gets > reset as well. And we inevitably need to set HW address again. > > So probably better solution is to move mentioned "soft-reset" from > "init" (that is used on start of any network activity) to > "initialize" > (which is only executed once in "board_r" sequence). But that's a > bit of > a different story and for now let's just get DW GMAC functional > again. > > Signed-off-by: Alexey Brodkin abrodkin@synopsys.com > Cc: Joe Hershberger joe.hershberger@ni.com > Cc: Michal Simek michal.simek@xilinx.com > Cc: Tom Rini trini@konsulko.com > --- > drivers/net/designware.c | 4 ++++ > 1 file changed, 4 insertions(+) > > diff --git a/drivers/net/designware.c b/drivers/net/designware.c > index ae51cf3..07281a6 100644 > --- a/drivers/net/designware.c > +++ b/drivers/net/designware.c > @@ -243,6 +243,10 @@ static int _dw_eth_init(struct dw_eth_dev > *priv, u8 *enetaddr) > mdelay(100); > }; > > + /* Soft reset above clears HW address registers. > + * So we have to set it here once again */ > + _dw_write_hwaddr(priv, enetaddr); > + > rx_descs_init(priv); > tx_descs_init(priv); > > --
You are correct. I forgot this was a duplicate.
Cheers, -Joe
Alexey Brodkin
Bin Meng
Joe Hershberger
