[PATCH v2] arm: xilinx: Add missing dual parallel flash description
Describe flash memories based on the latest DT binding.
Signed-off-by: Michal Simek michal.simek@amd.com ---
Changes in v2: - Add missing description for zc706
arch/arm/dts/zynq-zc706.dts | 5 +++-- arch/arm/dts/zynq-zc770-xm013.dts | 5 +++-- arch/arm/dts/zynqmp-m-a2197-01-revA.dts | 4 +++- arch/arm/dts/zynqmp-m-a2197-02-revA.dts | 4 +++- arch/arm/dts/zynqmp-m-a2197-03-revA.dts | 4 +++- 5 files changed, 15 insertions(+), 7 deletions(-)
diff --git a/arch/arm/dts/zynq-zc706.dts b/arch/arm/dts/zynq-zc706.dts index 03eb016ed687..18963a395156 100644 --- a/arch/arm/dts/zynq-zc706.dts +++ b/arch/arm/dts/zynq-zc706.dts @@ -309,10 +309,11 @@ &qspi { bootph-all; status = "okay"; - num-cs = <1>; + num-cs = <2>; flash@0 { compatible = "n25q128a11", "jedec,spi-nor"; - reg = <0x0>; + reg = <0>, <1>; + parallel-memories = /bits/ 64 <0x1000000 0x1000000>; /* 16MB */ spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; spi-max-frequency = <50000000>; diff --git a/arch/arm/dts/zynq-zc770-xm013.dts b/arch/arm/dts/zynq-zc770-xm013.dts index 21902fbb0cc1..582aa1f1b873 100644 --- a/arch/arm/dts/zynq-zc770-xm013.dts +++ b/arch/arm/dts/zynq-zc770-xm013.dts @@ -61,10 +61,11 @@
&qspi { status = "okay"; - num-cs = <1>; + num-cs = <2>; flash@0 { compatible = "n25q128a11", "jedec,spi-nor"; - reg = <0x0>; + reg = <0>, <1>; + parallel-memories = /bits/ 64 <0x1000000 0x1000000>; /* 16MB */ spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; spi-max-frequency = <50000000>; diff --git a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts index 25ef646c8466..83b8a98d80ca 100644 --- a/arch/arm/dts/zynqmp-m-a2197-01-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-01-revA.dts @@ -71,11 +71,13 @@
&qspi { status = "okay"; + num-cs = <2>; flash@0 { compatible = "m25p80", "jedec,spi-nor"; /* 32MB */ + reg = <0>, <1>; + parallel-memories = /bits/ 64 <0x4000000 0x4000000>; /* 64MB */ #address-cells = <1>; #size-cells = <1>; - reg = <0x0>; spi-tx-bus-width = <4>; spi-rx-bus-width = <4>; spi-max-frequency = <108000000>; diff --git a/arch/arm/dts/zynqmp-m-a2197-02-revA.dts b/arch/arm/dts/zynqmp-m-a2197-02-revA.dts index ece9e6914541..dd37b726d3dc 100644 --- a/arch/arm/dts/zynqmp-m-a2197-02-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-02-revA.dts @@ -67,11 +67,13 @@
&qspi { status = "okay"; + num-cs = <2>; flash@0 { compatible = "m25p80", "jedec,spi-nor"; /* 32MB */ + reg = <0>, <1>; + parallel-memories = /bits/ 64 <0x4000000 0x4000000>; /* 64MB */ #address-cells = <1>; #size-cells = <1>; - reg = <0x0>; spi-tx-bus-width = <4>; spi-rx-bus-width = <4>; spi-max-frequency = <108000000>; diff --git a/arch/arm/dts/zynqmp-m-a2197-03-revA.dts b/arch/arm/dts/zynqmp-m-a2197-03-revA.dts index 7372968e5734..811cebafe9e6 100644 --- a/arch/arm/dts/zynqmp-m-a2197-03-revA.dts +++ b/arch/arm/dts/zynqmp-m-a2197-03-revA.dts @@ -67,11 +67,13 @@
Changes in v2:
- num-cs = <1>;
- num-cs = <2>; flash@0 { compatible = "n25q128a11", "jedec,spi-nor";
reg = <0x0>;
reg = <0>, <1>;
spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; spi-max-frequency = <50000000>;parallel-memories = /bits/ 64 <0x1000000 0x1000000>; /* 16MB */
- num-cs = <1>;
reg = <0x0>;
reg = <0>, <1>;
- num-cs = <2>; flash@0 { compatible = "m25p80", "jedec,spi-nor"; /* 32MB */
reg = <0>, <1>;
#address-cells = <1>; #size-cells = <1>;parallel-memories = /bits/ 64 <0x4000000 0x4000000>; /* 64MB */
spi-tx-bus-width = <4>; spi-rx-bus-width = <4>; spi-max-frequency = <108000000>;reg = <0x0>;
reg = <0>, <1>;
reg = <0>, <1>;
Applied. M
Michal Simek
