[U-Boot] [PATCH] mmc: sdhci: use the SDHCI_QUIRK_USE_WIDE8 for samsung SoC
Samsung SoC is supported the WIDE8, even if Controller version is v2.0. So add the SDHCI_QUIRK_USE_WIDE8 for Samsung-SoC.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- drivers/mmc/s5p_sdhci.c | 4 +++- drivers/mmc/sdhci.c | 13 +++++++------ include/sdhci.h | 3 +++ 3 files changed, 13 insertions(+), 7 deletions(-)
diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index e50ff92..97e153e 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -84,7 +84,7 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width)
host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR | - SDHCI_QUIRK_WAIT_SEND_CMD; + SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_USE_WIDE8; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; host->version = sdhci_readw(host, SDHCI_HOST_VERSION);
@@ -93,6 +93,8 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width) host->index = index;
host->host_caps = MMC_MODE_HC; + if (bus_width == 8) + host->host_caps |= MMC_MODE_8BIT;
return add_sdhci(host, 52000000, 400000); } diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index c5631bf..9bf3052 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -270,7 +270,7 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) if (clock == 0) return 0;
- if ((host->version & SDHCI_SPEC_VER_MASK) >= SDHCI_SPEC_300) { + if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) { /* Version 3.00 divisors must be a multiple of 2. */ if (mmc->f_max <= clock) div = 1; @@ -363,10 +363,11 @@ void sdhci_set_ios(struct mmc *mmc) ctrl = sdhci_readb(host, SDHCI_HOST_CONTROL); if (mmc->bus_width == 8) { ctrl &= ~SDHCI_CTRL_4BITBUS; - if ((host->version & SDHCI_SPEC_VER_MASK) >= SDHCI_SPEC_300) + if ((SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) || + (host->quirks & SDHCI_QUIRK_USE_WIDE8)) ctrl |= SDHCI_CTRL_8BITBUS; } else { - if ((host->version & SDHCI_SPEC_VER_MASK) >= SDHCI_SPEC_300) + if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) ctrl &= ~SDHCI_CTRL_8BITBUS; if (mmc->bus_width == 4) ctrl |= SDHCI_CTRL_4BITBUS; @@ -453,7 +454,7 @@ int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) if (max_clk) mmc->f_max = max_clk; else { - if ((host->version & SDHCI_SPEC_VER_MASK) >= SDHCI_SPEC_300) + if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) mmc->f_max = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT; else @@ -468,7 +469,7 @@ int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) if (min_clk) mmc->f_min = min_clk; else { - if ((host->version & SDHCI_SPEC_VER_MASK) >= SDHCI_SPEC_300) + if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) mmc->f_min = mmc->f_max / SDHCI_MAX_DIV_SPEC_300; else mmc->f_min = mmc->f_max / SDHCI_MAX_DIV_SPEC_200; @@ -486,7 +487,7 @@ int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) mmc->voltages |= host->voltages;
mmc->host_caps = MMC_MODE_HS | MMC_MODE_HS_52MHz | MMC_MODE_4BIT; - if ((host->version & SDHCI_SPEC_VER_MASK) >= SDHCI_SPEC_300) { + if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) { if (caps & SDHCI_CAN_DO_8BIT) mmc->host_caps |= MMC_MODE_8BIT; } diff --git a/include/sdhci.h b/include/sdhci.h index cffbe53..f3f8219 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -208,6 +208,8 @@ #define SDHCI_SPEC_200 1 #define SDHCI_SPEC_300 2
+#define SDHCI_GET_VERSION(x) (x->version & SDHCI_SPEC_VER_MASK) + /* * End of controller registers. */ @@ -226,6 +228,7 @@ #define SDHCI_QUIRK_NO_CD (1 << 5) #define SDHCI_QUIRK_WAIT_SEND_CMD (1 << 6) #define SDHCI_QUIRK_NO_SIMULT_VDD_AND_POWER (1 << 7) +#define SDHCI_QUIRK_USE_WIDE8 (1 << 8)
/* to make gcc happy */ struct sdhci_host;
Dear Pantelis,
Welcome to take care of u-boot-mmc.
Could you merge this patch?
Best Regards, Jaehoon Chung
host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; host->version = sdhci_readw(host, SDHCI_HOST_VERSION);SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_USE_WIDE8;
if (bus_width == 8)
- if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) { /* Version 3.00 divisors must be a multiple of 2. */ if (mmc->f_max <= clock) div = 1;
} else {(host->quirks & SDHCI_QUIRK_USE_WIDE8)) ctrl |= SDHCI_CTRL_8BITBUS;
if (mmc->bus_width == 4) ctrl |= SDHCI_CTRL_4BITBUS;if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) ctrl &= ~SDHCI_CTRL_8BITBUS;
elseif (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) mmc->f_max = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT;
else mmc->f_min = mmc->f_max / SDHCI_MAX_DIV_SPEC_200;if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) mmc->f_min = mmc->f_max / SDHCI_MAX_DIV_SPEC_300;
- if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) { if (caps & SDHCI_CAN_DO_8BIT) mmc->host_caps |= MMC_MODE_8BIT; }
- End of controller registers.
Hi Jaehoon,
On Aug 13, 2013, at 11:52 AM, Jaehoon Chung wrote:
Dear Pantelis,
Thanks
Please hold on a bit; we're still in the process of passing over the (mmc) torch.
That patch looks good.
Regards
-- Pantelis
if (bus_width == 8)
On 08/13/2013 06:01 PM, Pantelis Antoniou wrote:
Hi Jaehoon,
Dear Pantelis,
Thanks
Sure..Thank you.:)
Regards
-- Pantelis
if (bus_width == 8)
Acked-by: Pantelis Antoniou panto@antoniou-consulting.com
Thanks
Jaehoon Chung
Pantelis Antoniou
Pantelis Antoniou
