[U-Boot] [u-boot 1/2] drivers/fsl-mc: Create Kconfig file to manage driver specific configs better
Create drivers/net/fsl-mc/Kconfig and move fsl-mc specific configs from arch/arm/cpu/armv8/fsl-layerscape/Kconfig to this new Kconfig
Signed-off-by: Florinel Iordache florinel.iordache@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 17 ----------------- drivers/net/Kconfig | 1 + drivers/net/fsl-mc/Kconfig | 25 +++++++++++++++++++++++++ 3 files changed, 26 insertions(+), 17 deletions(-) create mode 100644 drivers/net/fsl-mc/Kconfig
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index f48481f..87f84f7 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -226,14 +226,6 @@ config FSL_LSCH3 config NXP_LSCH3_2 bool
-config FSL_MC_ENET - bool "Management Complex network" - depends on ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A - default y - select RESV_RAM - help - Enable Management Complex (MC) network - menu "Layerscape architecture" depends on FSL_LSCH2 || FSL_LSCH3
@@ -567,15 +559,6 @@ config SYS_FSL_HAS_RGMII bool depends on SYS_FSL_EC1 || SYS_FSL_EC2
- -config SYS_MC_RSV_MEM_ALIGN - hex "Management Complex reserved memory alignment" - depends on RESV_RAM - default 0x20000000 if ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A - help - Reserved memory needs to be aligned for MC to use. Default value - is 512MB. - config SPL_LDSCRIPT default "arch/arm/cpu/armv8/u-boot-spl.lds" if ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 77d0b3a..3627456 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -1,5 +1,6 @@ source "drivers/net/phy/Kconfig" source "drivers/net/pfe_eth/Kconfig" +source "drivers/net/fsl-mc/Kconfig"
config DM_ETH bool "Enable Driver Model for Ethernet drivers" diff --git a/drivers/net/fsl-mc/Kconfig b/drivers/net/fsl-mc/Kconfig new file mode 100644 index 0000000..25a2cb8 --- /dev/null +++ b/drivers/net/fsl-mc/Kconfig @@ -0,0 +1,25 @@ +# +# NXP Management Complex +# + +menuconfig FSL_MC_ENET + bool "NXP Management Complex" + depends on ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A + default y + select RESV_RAM + help + Enable Management Complex (MC) network + This is NXP Management Complex menuconfig + that contains all MC related config options + +if FSL_MC_ENET + +config SYS_MC_RSV_MEM_ALIGN + hex "Management Complex reserved memory alignment" + depends on RESV_RAM + default 0x20000000 if ARCH_LS2080A || ARCH_LS1088A || ARCH_LX2160A + help + Reserved memory needs to be aligned for MC to use. Default value + is 512MB. + +endif # FSL_MC_ENET
On Wed, May 15, 2019 at 4:09 AM Florinel Iordache florinel.iordache@nxp.com wrote:
Hi Florinel,
https://patchwork.ozlabs.org/patch/1099898/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Florinel Iordache
Joe Hershberger
Joe Hershberger
