[U-Boot-Users] Re: FCC2 issue on PQ2FADS
Kumar,
Which MAC address is being sent as source by ping echo request? Some time ago I found out some problem sending packets from one interface with the MAC address from the other interface, which resulted in the PHY doesn't capturing the reply packet
Alex
-----Original Message----- Cc: "u-boot-users list" u-boot-users@lists.sourceforge.net From: Kumar Gala kumar.gala@freescale.com Subject: Re: [U-Boot-Users] FCC2 issue on PQ2FADS Date: Fri, 7 Jan 2005 17:28:27 -0600 To: "Yuli Barcohen" yuli@arabellasw.com
On Jan 7, 2005, at 10:49 AM, Yuli Barcohen wrote:
> Kumar Gala writes:
=A0=A0=A0 Kumar> I've got a new PQ2FADS board and am having issues =
with FCC2.
=A0=A0=A0 Kumar> I'm using the 1.1.2 release, we seem to be able to =
transmit
=A0=A0=A0 Kumar> but not receive packets.
=A0=A0=A0 Kumar> Any ideas?
Is the board connected to the LAN using hub? If yes, try switch. There can be problems with half-duplex link.
I've tried both a hub & switch. One odd thing was that the hub was=20 reporting half duplex, but the board was report full. I tried=20 modifying the fcc_psmr to match, but that only made things worse.
I need to try using the other ethernet port and see what happens.
- kumar
Bastos Fernandez Alexandre
