[PATCH 00/11] AM68 SK: Add initial support for AM68 Starter Kit
AM68 Starter Kit (SK) is a low cost, small form factor board designed for TI’s J721S2/AM68 SoC. TI’s J721S2/AM68 SoC comprises of dual core A72, high performance vision accelerators, hardware accelerators, latest C71x DSP, high bandwidth real-time IPs for capture and display. The SoC is power optimized to provide best in class performance for industrial and automotive applications.
Refer below link to J721S2/AM68 Technical Reference Manual for further details: http://www.ti.com/lit/pdf/spruj28
AM68 SK supports the following interfaces: * 16 GB LPDDR4 RAM * x1 Gigabit Ethernet interface * x1 USB 3.1 Type-C port * x2 USB 3.1 Type-A ports * x1 PCIe M.2 M Key * 512 Mbit OSPI flash * x2 CSI2 Camera interface (RPi and TI Camera connector) * 40-pin Raspberry Pi GPIO header
This series of patch add initial support for AM68 starter kit. Design files can be referrred from https://www.ti.com/lit/zip/SPRR463
Sinthu Raja (11): configs: j721s2_evm_r5: Enable support for building multiple dtbs into FIT configs: j721s2_evm_a72: Enable support for building multiple dtbs into FIT configs: j721s2_evm: Enable configs to store env in MMC FAT partition board: ti: j721s2: Add support to update board_name for am68-sk board: ti: j721s2: Enable support for reading EEPROM at next alternate address board: ti: j721s2: Add support for detecting multiple device trees arm: j721s2: Add support for selecting DT based on EEPROM arm: dts: Add initial support for AM68 Starter Kit System on Module arm: dts: Add support for A72 specific AM68 Starter Kit Base Board arm: dts: k3-am68-sk: Add r5 specific dt support include: configs: Update env for selecting right dtb
arch/arm/dts/Makefile | 4 +- .../arm/dts/k3-am68-sk-base-board-u-boot.dtsi | 216 ++++++++++ arch/arm/dts/k3-am68-sk-base-board.dts | 395 ++++++++++++++++++ arch/arm/dts/k3-am68-sk-r5-base-board.dts | 226 ++++++++++ arch/arm/dts/k3-am68-sk-som.dtsi | 167 ++++++++ arch/arm/mach-k3/j721s2_init.c | 59 +++ board/ti/j721s2/evm.c | 32 +- configs/j721s2_evm_a72_defconfig | 5 +- configs/j721s2_evm_r5_defconfig | 4 + include/configs/j721s2_evm.h | 4 + 10 files changed, 1105 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am68-sk-base-board.dts create mode 100644 arch/arm/dts/k3-am68-sk-r5-base-board.dts create mode 100644 arch/arm/dts/k3-am68-sk-som.dtsi
Enable configs for building multiple dtbs into a single fit image and load the right dtb for next stage. This will help to use same defconfig for both EVM and SK.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- configs/j721s2_evm_r5_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 98d69a18b9..b72ed1dbd5 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -84,6 +84,9 @@ CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_OF_LIST="k3-j721s2-r5-common-proc-board k3-am68-sk-r5-base-board" +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y
Enable configs for building multiple dtbs into a single fit image and load the right dtb for next stage. Add k3-am68-sk-base-board dtb along with evm dtb inside DTB FIT image. This helps to use same defconfig for both EVM and SK
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- configs/j721s2_evm_a72_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index a06312f4f5..2084ed020e 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -89,6 +89,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_OF_LIST="k3-j721s2-common-proc-board k3-am68-sk-base-board" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y
J721S2 EVM used to store env on eMMC, since EVM and SK uses same defconfig and there is no eMMC on SK, we need to keep env in an interface which available on both EVM and SK. So, save env in FAT partition of MMC SD Card.
Enable defconfigs relevant for storing env on FAT partition of MMC.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- configs/j721s2_evm_a72_defconfig | 4 +++- configs/j721s2_evm_r5_defconfig | 1 + 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 2084ed020e..cf23a73222 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -92,7 +92,9 @@ CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_OF_LIST="k3-j721s2-common-proc-board k3-am68-sk-base-board" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index b72ed1dbd5..6e694c8d55 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -88,6 +88,7 @@ CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_OF_LIST="k3-j721s2-r5-common-proc-board k3-am68-sk-r5-base-board" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_OVERWRITE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y
Update setup_board_eeprom_env() to choose the right board name for am68-sk.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- board/ti/j721s2/evm.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index e09adc8ad3..e3c75b35b6 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -28,6 +28,8 @@
#define board_is_j721s2_som() board_ti_k3_is("J721S2X-PM1-SOM")
+#define board_is_am68_sk_som() board_ti_k3_is("AM68-SK-SOM") + DECLARE_GLOBAL_DATA_PTR;
int board_init(void) @@ -136,6 +138,8 @@ static void setup_board_eeprom_env(void)
if (board_is_j721s2_som()) name = "j721s2"; + else if (board_is_am68_sk_som()) + name = "am68-sk"; else printf("Unidentified board claims %s in eeprom header\n", board_ti_get_name());
- else if (board_is_am68_sk_som())
else printf("Unidentified board claims %s in eeprom header\n", board_ti_get_name());name = "am68-sk";
What I'd like to see is moving the board_is_XXX defines moved down to by do_board_detect() and then a comment inside the start of that block to explain that all of this functionality is specific to the EVM family designs. This will hopefully make it clearer that when making a custom board that doesn't have this EEPROM all of this can be omitted and we don't loose the "mini" U-Boot concept for this SoC.
J721S2 EVM has EEPROM populated at 0x50. AM68 SK has EEPROM populated at next address 0x51 in order to be compatible with RPi. So start looking for TI specific EEPROM at 0x50, if not found look for EEPROM at 0x51.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- board/ti/j721s2/evm.c | 12 +++++++++--- 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index e3c75b35b6..8ada924e3f 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -109,9 +109,15 @@ int do_board_detect(void)
ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS); - if (ret) - pr_err("Reading on-board EEPROM at 0x%02x failed %d\n", - CONFIG_EEPROM_CHIP_ADDRESS, ret); + if (ret) { + printf("EEPROM not available at 0x%02x, trying to read at 0x%02x\n", + CONFIG_EEPROM_CHIP_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS + 1); + ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, + CONFIG_EEPROM_CHIP_ADDRESS + 1); + if (ret) + pr_err("Reading on-board EEPROM at 0x%02x failed %d\n", + CONFIG_EEPROM_CHIP_ADDRESS + 1, ret); + }
return ret; }
Update the board_fit_config_name_match() to choose the right dtb based on the board name read from EEPROM.
Also restrict multpile EEPROM reads by verifying if EEPROM is already read
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- board/ti/j721s2/evm.c | 16 ++++++++++++++-- 1 file changed, 14 insertions(+), 2 deletions(-)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index 8ada924e3f..25667900ce 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -79,8 +79,17 @@ int dram_init_banksize(void) #ifdef CONFIG_SPL_LOAD_FIT int board_fit_config_name_match(const char *name) { - if (!strcmp(name, "k3-j721s2-common-proc-board")) - return 0; + bool eeprom_read = board_ti_was_eeprom_read(); + + if (!eeprom_read || board_is_j721s2_som()) { + if (!strcmp(name, "k3-j721s2-common-proc-board") || + !strcmp(name, "k3-j721s2-r5-common-proc-board")) + return 0; + } else if (!eeprom_read || board_is_am68_sk_som()) { + if (!strcmp(name, "k3-am68-sk-base-board") || + !strcmp(name, "k3-am68-sk-r5-base-board")) + return 0; + }
return -1; } @@ -107,6 +116,9 @@ int do_board_detect(void) { int ret;
+ if (board_ti_was_eeprom_read()) + return 0; + ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS); if (ret) {
return -1;
Do we actually need a different DTB to be used in SPL, in order to get the right DTB for full U-Boot? It's an intentional design decision here that we go board-specific as late as possible, so that it's clearer for custom designs what they do and do not need to modify.
Enable support for selecting DTB from FIT within SPL based on the board name read from EEPROM. This will help to use single defconfig for both EVM and SK.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- arch/arm/mach-k3/j721s2_init.c | 59 ++++++++++++++++++++++++++++++++++ 1 file changed, 59 insertions(+)
diff --git a/arch/arm/mach-k3/j721s2_init.c b/arch/arm/mach-k3/j721s2_init.c index 12da8136f9..fc5eee03b6 100644 --- a/arch/arm/mach-k3/j721s2_init.c +++ b/arch/arm/mach-k3/j721s2_init.c @@ -19,8 +19,10 @@ #include <dm.h> #include <dm/uclass-internal.h> #include <dm/pinctrl.h> +#include <fdt_support.h> #include <mmc.h> #include <remoteproc.h> +#include <dm/root.h>
static void ctrl_mmr_unlock(void) { @@ -93,6 +95,59 @@ static void store_boot_info_from_rom(void) sizeof(struct rom_extended_boot_data)); }
+#ifdef CONFIG_SPL_OF_LIST +void do_dt_magic(void) +{ + int ret, rescan, mmc_dev = -1; + static struct mmc *mmc; + + if (IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) + do_board_detect(); + + /* + * Board detection has been done. + * Let us see if another dtb wouldn't be a better match + * for our board + */ + if (IS_ENABLED(CONFIG_CPU_V7R)) { + ret = fdtdec_resetup(&rescan); + if (!ret && rescan) { + dm_uninit(); + dm_init_and_scan(true); + } + } + + /* + * Because of multi DTB configuration, the MMC device has + * to be re-initialized after reconfiguring FDT inorder to + * boot from MMC. Do this when boot mode is MMC and ROM has + * not loaded SYSFW. + */ + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC1: + mmc_dev = 0; + break; + case BOOT_DEVICE_MMC2: + case BOOT_DEVICE_MMC2_2: + mmc_dev = 1; + break; + } + + if (mmc_dev > 0 && !is_rom_loaded_sysfw(&bootdata)) { + ret = mmc_init_device(mmc_dev); + if (!ret) { + mmc = find_mmc_device(mmc_dev); + if (mmc) { + ret = mmc_init(mmc); + if (ret) { + printf("mmc init failed with error: %d\n", ret); + } + } + } + } +} +#endif + void board_init_f(ulong dummy) { struct udevice *dev; @@ -139,6 +194,10 @@ void board_init_f(ulong dummy) k3_sysfw_loader(is_rom_loaded_sysfw(&bootdata), k3_mmc_stop_clock, k3_mmc_restart_clock);
+#ifdef CONFIG_SPL_OF_LIST + do_dt_magic(); +#endif + if (IS_ENABLED(CONFIG_SPL_CLK_K3)) { /* * Force probe of clk_k3 driver here to ensure basic default clock
- int ret, rescan, mmc_dev = -1;
- static struct mmc *mmc;
- if (IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT))
do_board_detect();
We need to try and avoid putting the CONFIG_TI_I2C_BOARD_DETECT calls and checks in the generic mach-k3 code as it's not required nor likely used on non-reference platforms. And again, if we do not need to move to a board-specific DTB in SPL, we do not want to, we want to push that off to full U-Boot.
AM68 Starter Kit (SK) is a low cost, small form factor board designed for TI’s AM68 SoC. TI’s AM68 SoC comprises of dual core A72, high performance vision accelerators, hardware accelerators, latest C71x DSP, high bandwidth real-time IPs for capture and display. The SoC is power optimized to provide best in class performance for industrial applications.
SK's System on Module (SoM) contains the SoC, PMIC, DDR and OSPI flash. Therefore, add support for the components present on the SoM.
Schematics: https://www.ti.com/lit/zip/SPRR463 TRM: http://www.ti.com/lit/pdf/spruj28
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- arch/arm/dts/k3-am68-sk-som.dtsi | 167 +++++++++++++++++++++++++++++++ 1 file changed, 167 insertions(+) create mode 100644 arch/arm/dts/k3-am68-sk-som.dtsi
diff --git a/arch/arm/dts/k3-am68-sk-som.dtsi b/arch/arm/dts/k3-am68-sk-som.dtsi new file mode 100644 index 0000000000..b8bec1f335 --- /dev/null +++ b/arch/arm/dts/k3-am68-sk-som.dtsi @@ -0,0 +1,167 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/dts-v1/; + +#include "k3-j721s2.dtsi" +#include <dt-bindings/gpio/gpio.h> + +/ { + memory@80000000 { + device_type = "memory"; + /* 16 GB RAM */ + reg = <0x00 0x80000000 0x00 0x80000000>, + <0x08 0x80000000 0x03 0x80000000>; + }; + + /* Reserving memory regions still pending */ + reserved_memory: reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; + alignment = <0x1000>; + no-map; + }; + }; +}; + +&wkup_pmx0 { + mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-pins-default { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x000, PIN_OUTPUT, 0) /* (D19) MCU_OSPI0_CLK */ + J721S2_WKUP_IOPAD(0x02c, PIN_OUTPUT, 0) /* (F15) MCU_OSPI0_CSn0 */ + J721S2_WKUP_IOPAD(0x03c, PIN_OUTPUT, 0) /* (F17) MCU_OSPI0_CSn3 */ + J721S2_WKUP_IOPAD(0x00c, PIN_INPUT, 0) /* (C19) MCU_OSPI0_D0 */ + J721S2_WKUP_IOPAD(0x010, PIN_INPUT, 0) /* (F16) MCU_OSPI0_D1 */ + J721S2_WKUP_IOPAD(0x014, PIN_INPUT, 0) /* (G15) MCU_OSPI0_D2 */ + J721S2_WKUP_IOPAD(0x018, PIN_INPUT, 0) /* (F18) MCU_OSPI0_D3 */ + J721S2_WKUP_IOPAD(0x01c, PIN_INPUT, 0) /* (E19) MCU_OSPI0_D4 */ + J721S2_WKUP_IOPAD(0x020, PIN_INPUT, 0) /* (G19) MCU_OSPI0_D5 */ + J721S2_WKUP_IOPAD(0x024, PIN_INPUT, 0) /* (F19) MCU_OSPI0_D6 */ + J721S2_WKUP_IOPAD(0x028, PIN_INPUT, 0) /* (F20) MCU_OSPI0_D7 */ + J721S2_WKUP_IOPAD(0x008, PIN_INPUT, 0) /* (E18) MCU_OSPI0_DQS */ + J721S2_WKUP_IOPAD(0x004, PIN_INPUT, 0) /* (E20) MCU_OSPI0_LBCLKO */ + >; + }; +}; + +&ospi0 { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_fss0_ospi0_pins_default>; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-tx-bus-width = <8>; + spi-rx-bus-width = <8>; + spi-max-frequency = <25000000>; + cdns,tshsl-ns = <60>; + cdns,tsd2d-ns = <60>; + cdns,tchsh-ns = <60>; + cdns,tslch-ns = <60>; + cdns,read-delay = <4>; + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +&mailbox0_cluster0 { + status = "disabled"; +}; + +&mailbox0_cluster1 { + status = "disabled"; +}; + +&mailbox0_cluster2 { + status = "disabled"; +}; + +&mailbox0_cluster3 { + status = "disabled"; +}; + +&mailbox0_cluster4 { + status = "disabled"; +}; + +&mailbox0_cluster5 { + status = "disabled"; +}; + +&mailbox0_cluster6 { + status = "disabled"; +}; + +&mailbox0_cluster7 { + status = "disabled"; +}; + +&mailbox0_cluster8 { + status = "disabled"; +}; + +&mailbox0_cluster9 { + status = "disabled"; +}; + +&mailbox0_cluster10 { + status = "disabled"; +}; + +&mailbox0_cluster11 { + status = "disabled"; +}; + +&mailbox1_cluster0 { + status = "disabled"; +}; + +&mailbox1_cluster1 { + status = "disabled"; +}; + +&mailbox1_cluster2 { + status = "disabled"; +}; + +&mailbox1_cluster3 { + status = "disabled"; +}; + +&mailbox1_cluster4 { + status = "disabled"; +}; + +&mailbox1_cluster5 { + status = "disabled"; +}; + +&mailbox1_cluster6 { + status = "disabled"; +}; + +&mailbox1_cluster7 { + status = "disabled"; +}; + +&mailbox1_cluster8 { + status = "disabled"; +}; + +&mailbox1_cluster9 { + status = "disabled"; +}; + +&mailbox1_cluster10 { + status = "disabled"; +}; + +&mailbox1_cluster11 { + status = "disabled"; +};
What is the status of this dtsi file (and the ones in subsequent patches) with upstream Linux? Please mention the tag they're synced from in the commit message to make future updates easier.
The SK architecture comprises of baseboard and a SOM board. The AM68 Starter Kit's baseboard contains most of the actual connectors, power supply etc. The System on Module (SoM) is plugged on to the base board. Therefore, add support for peripherals brought out in the base board.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- arch/arm/dts/Makefile | 3 +- .../arm/dts/k3-am68-sk-base-board-u-boot.dtsi | 216 ++++++++++ arch/arm/dts/k3-am68-sk-base-board.dts | 395 ++++++++++++++++++ 3 files changed, 613 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am68-sk-base-board.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9b00b64509..b1fcd20f39 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1221,7 +1221,8 @@ dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb \ k3-j7200-r5-common-proc-board.dtb \ k3-j721e-sk.dtb \ k3-j721e-r5-sk.dtb -dtb-$(CONFIG_SOC_K3_J721S2) += k3-j721s2-common-proc-board.dtb\ +dtb-$(CONFIG_SOC_K3_J721S2) += k3-am68-sk-base-board.dtb\ + k3-j721s2-common-proc-board.dtb\ k3-j721s2-r5-common-proc-board.dtb dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-evm.dtb \ k3-am642-r5-evm.dtb \ diff --git a/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi b/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi new file mode 100644 index 0000000000..01e00862df --- /dev/null +++ b/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi @@ -0,0 +1,216 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/ { + chosen { + stdout-path = "serial2:115200n8"; + tick-timer = &timer1; + }; + + aliases { + serial0 = &wkup_uart0; + serial1 = &mcu_uart0; + serial2 = &main_uart8; + i2c0 = &wkup_i2c0; + i2c1 = &mcu_i2c0; + i2c2 = &mcu_i2c1; + i2c3 = &main_i2c0; + ethernet0 = &cpsw_port1; + spi0 = &ospi0; + mmc1 = &main_sdhci1; + }; +}; + +&wkup_i2c0 { + u-boot,dm-spl; +}; + +&cbass_main { + u-boot,dm-spl; +}; + +&main_navss { + u-boot,dm-spl; +}; + +&main_r5fss0 { + ti,cluster-mode = <0>; +}; + +&main_r5fss1 { + ti,cluster-mode = <0>; +}; + +&cbass_mcu_wakeup { + u-boot,dm-spl; + + timer1: timer@40400000 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x40400000 0x0 0x80>; + ti,timer-alwon; + clock-frequency = <250000000>; + u-boot,dm-spl; + }; + + chipid@43000014 { + u-boot,dm-spl; + }; +}; + +&mcu_navss { + u-boot,dm-spl; +}; + +&mcu_ringacc { + reg = <0x0 0x2b800000 0x0 0x400000>, + <0x0 0x2b000000 0x0 0x400000>, + <0x0 0x28590000 0x0 0x100>, + <0x0 0x2a500000 0x0 0x40000>, + <0x0 0x28440000 0x0 0x40000>; + reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg"; + u-boot,dm-spl; +}; + +&mcu_udmap { + reg = <0x0 0x285c0000 0x0 0x100>, + <0x0 0x284c0000 0x0 0x4000>, + <0x0 0x2a800000 0x0 0x40000>, + <0x0 0x284a0000 0x0 0x4000>, + <0x0 0x2aa00000 0x0 0x40000>, + <0x0 0x28400000 0x0 0x2000>; + reg-names = "gcfg", "rchan", "rchanrt", "tchan", + "tchanrt", "rflow"; + u-boot,dm-spl; +}; + +&secure_proxy_main { + u-boot,dm-spl; +}; + +&sms { + u-boot,dm-spl; + k3_sysreset: sysreset-controller { + compatible = "ti,sci-sysreset"; + u-boot,dm-spl; + }; +}; + +&main_pmx0 { + u-boot,dm-spl; +}; + +&main_uart8_pins_default { + u-boot,dm-spl; +}; + +&main_mmc1_pins_default { + u-boot,dm-spl; +}; + +&main_usbss0_pins_default { + u-boot,dm-spl; +}; + +&wkup_pmx0 { + u-boot,dm-spl; +}; + +&k3_pds { + u-boot,dm-spl; +}; + +&k3_clks { + u-boot,dm-spl; +}; + +&k3_reset { + u-boot,dm-spl; +}; + +&main_uart8 { + u-boot,dm-spl; +}; + +&mcu_uart0 { + u-boot,dm-spl; +}; + +&wkup_uart0 { + u-boot,dm-spl; +}; + +&fss { + u-boot,dm-spl; +}; + +&usbss0 { + u-boot,dm-spl; +}; + +&usb0 { + dr_mode = "peripheral"; + u-boot,dm-spl; +}; + +&mcu_cpsw { + reg = <0x0 0x46000000 0x0 0x200000>, + <0x0 0x40f00200 0x0 0x8>; + reg-names = "cpsw_nuss", "mac_efuse"; + /delete-property/ ranges; + + cpsw-phy-sel@40f04040 { + compatible = "ti,am654-cpsw-phy-sel"; + reg= <0x0 0x40f04040 0x0 0x4>; + reg-names = "gmii-sel"; + }; +}; + +&mcu_fss0_ospi0_pins_default { + u-boot,dm-spl; +}; + +&wiz0_pll1_refclk { + assigned-clocks = <&wiz0_pll1_refclk>, <&wiz0_pll0_refclk>; + assigned-clock-parents = <&k3_clks 365 3>, <&k3_clks 365 0>; +}; + +&serdes_ln_ctrl { + u-boot,mux-autoprobe; +}; + +&usb_serdes_mux { + u-boot,mux-autoprobe; +}; + +&ospi0 { + u-boot,dm-spl; + + flash@0 { + cdns,phy-mode; + u-boot,dm-spl; + + partition@3fc0000 { + label = "ospi.phypattern"; + reg = <0x3fc0000 0x40000>; + u-boot,dm-spl; + }; + }; +}; + +&ospi1 { + u-boot,dm-spl; + + flash@0 { + u-boot,dm-spl; + }; +}; + +&main_sdhci0 { + status = "disabled"; +}; + +&main_sdhci1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/k3-am68-sk-base-board.dts b/arch/arm/dts/k3-am68-sk-base-board.dts new file mode 100644 index 0000000000..4a9bfed621 --- /dev/null +++ b/arch/arm/dts/k3-am68-sk-base-board.dts @@ -0,0 +1,395 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + * + * Base Board: **Yet to Add** + */ + +/dts-v1/; + +#include "k3-am68-sk-som.dtsi" +#include <dt-bindings/net/ti-dp83867.h> +#include <dt-bindings/phy/phy-cadence.h> +#include <dt-bindings/phy/phy.h> + +/ { + compatible = "ti,am68-sk", "ti,j721s2"; + model = "Texas Instruments AM68 SK"; + + chosen { + stdout-path = "serial2:115200n8"; + bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x2880000"; + }; + + aliases { + serial2 = &main_uart8; + mmc1 = &main_sdhci1; + }; + + vusb_main: fixedregulator-vusb-main5v0 { + /* USB MAIN INPUT 5V DC */ + compatible = "regulator-fixed"; + regulator-name = "vusb-main5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_3v3: fixedregulator-vsys3v3 { + /* Output of LM5141 */ + compatible = "regulator-fixed"; + regulator-name = "vsys_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vusb_main>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_mmc1: fixedregulator-sd { + /* Output of TPS22918 */ + compatible = "regulator-fixed"; + regulator-name = "vdd_mmc1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + enable-active-high; + vin-supply = <&vsys_3v3>; + gpio = <&exp1 10 GPIO_ACTIVE_HIGH>; + }; + + vdd_sd_dv: gpio-regulator-TLV71033 { + /* Output of TLV71033 */ + compatible = "regulator-gpio"; + regulator-name = "tlv71033"; + pinctrl-names = "default"; + pinctrl-0 = <&vdd_sd_dv_pins_default>; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + vin-supply = <&vsys_3v3>; + gpios = <&main_gpio0 49 GPIO_ACTIVE_HIGH>; + states = <1800000 0x0>, + <3300000 0x1>; + }; +}; + +&main_pmx0 { + main_uart8_pins_default: main-uart8-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x040, PIN_INPUT, 14) /* (AC28) MCASP0_AXR0.UART8_CTSn */ + J721S2_IOPAD(0x044, PIN_OUTPUT, 14) /* (Y26) MCASP0_AXR1.UART8_RTSn */ + J721S2_IOPAD(0x0d0, PIN_INPUT, 11) /* (AF26) SPI0_CS1.UART8_RXD */ + J721S2_IOPAD(0x0d4, PIN_OUTPUT, 11) /* (AH27) SPI0_CLK.UART8_TXD */ + >; + }; + + main_i2c0_pins_default: i2c0-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x0e0, PIN_INPUT_PULLUP, 0) /* (AH25) I2C0_SCL */ + J721S2_IOPAD(0x0e4, PIN_INPUT_PULLUP, 0) /* (AE24) I2C0_SDA */ + >; + }; + + main_mmc1_pins_default: main-mmc1-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x104, PIN_INPUT, 0) /* (P23) MMC1_CLK */ + J721S2_IOPAD(0x108, PIN_INPUT, 0) /* (N24) MMC1_CMD */ + J721S2_IOPAD(0x100, PIN_INPUT, 0) /* (###) MMC1_CLKLB */ + J721S2_IOPAD(0x0fc, PIN_INPUT, 0) /* (M23) MMC1_DAT0 */ + J721S2_IOPAD(0x0f8, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */ + J721S2_IOPAD(0x0f4, PIN_INPUT, 0) /* (R24) MMC1_DAT2 */ + J721S2_IOPAD(0x0f0, PIN_INPUT, 0) /* (R22) MMC1_DAT3 */ + J721S2_IOPAD(0x0e8, PIN_INPUT, 8) /* (AE25) TIMER_IO0.MMC1_SDCD */ + >; + }; + + vdd_sd_dv_pins_default: vdd-sd-dv-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x0c4, PIN_INPUT, 7) /* (AB26) ECAP0_IN_APWM_OUT.GPIO0_49 */ + >; + }; + + main_usbss0_pins_default: main-usbss0-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x0ec, PIN_OUTPUT, 6) /* (AG25) TIMER_IO1.USB0_DRVVBUS */ + >; + }; +}; + +&wkup_pmx0 { + mcu_cpsw_pins_default: mcu-cpsw-pins-default { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x094, PIN_INPUT, 0) /* (B22) MCU_RGMII1_RD0 */ + J721S2_WKUP_IOPAD(0x090, PIN_INPUT, 0) /* (B21) MCU_RGMII1_RD1 */ + J721S2_WKUP_IOPAD(0x08c, PIN_INPUT, 0) /* (C22) MCU_RGMII1_RD2 */ + J721S2_WKUP_IOPAD(0x088, PIN_INPUT, 0) /* (D23) MCU_RGMII1_RD3 */ + J721S2_WKUP_IOPAD(0x084, PIN_INPUT, 0) /* (D22) MCU_RGMII1_RXC */ + J721S2_WKUP_IOPAD(0x06c, PIN_INPUT, 0) /* (E23) MCU_RGMII1_RX_CTL */ + J721S2_WKUP_IOPAD(0x07c, PIN_OUTPUT, 0) /* (F23) MCU_RGMII1_TD0 */ + J721S2_WKUP_IOPAD(0x078, PIN_OUTPUT, 0) /* (G22) MCU_RGMII1_TD1 */ + J721S2_WKUP_IOPAD(0x074, PIN_OUTPUT, 0) /* (E21) MCU_RGMII1_TD2 */ + J721S2_WKUP_IOPAD(0x070, PIN_OUTPUT, 0) /* (E22) MCU_RGMII1_TD3 */ + J721S2_WKUP_IOPAD(0x080, PIN_OUTPUT, 0) /* (F21) MCU_RGMII1_TXC */ + J721S2_WKUP_IOPAD(0x068, PIN_OUTPUT, 0) /* (F22) MCU_RGMII1_TX_CTL */ + >; + }; + + mcu_mdio_pins_default: mcu-mdio-pins-default { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x09c, PIN_OUTPUT, 0) /* (A21) MCU_MDIO0_MDC */ + J721S2_WKUP_IOPAD(0x098, PIN_INPUT, 0) /* (A22) MCU_MDIO0_MDIO */ + >; + }; +}; + +&main_gpio2 { + status = "disabled"; +}; + +&main_gpio4 { + status = "disabled"; +}; + +&main_gpio6 { + status = "disabled"; +}; + +&wkup_gpio1 { + status = "disabled"; +}; + +&wkup_uart0 { + status = "reserved"; +}; + +&main_uart0 { + status = "disabled"; +}; + +&main_uart1 { + status = "disabled"; +}; + +&main_uart2 { + status = "disabled"; +}; + +&main_uart3 { + status = "disabled"; +}; + +&main_uart4 { + status = "disabled"; +}; + +&main_uart5 { + status = "disabled"; +}; + +&main_uart6 { + status = "disabled"; +}; + +&main_uart7 { + status = "disabled"; +}; + +&main_uart8 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart8_pins_default>; + /* Shared with TFA on this platform */ + power-domains = <&k3_pds 357 TI_SCI_PD_SHARED>; +}; + +&main_uart9 { + status = "disabled"; +}; + +&main_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c0_pins_default>; + clock-frequency = <400000>; + + exp1: gpio@21 { + compatible = "ti,tca6416"; + reg = <0x21>; + gpio-controller; + #gpio-cells = <2>; + gpio-line-names = "CSI_VIO_SEL", "CSI_SEL_FPC_EXPN", "HDMI_PDN", + "HDMI_LS_OE", "DP0_3V3_EN", "BOARDID_EEPROM_WP", + "CAN_STB", "","GPIO_uSD_PWR_EN", "EDP_ENABLE", + "IO_EXP_PCIE1_M2_RSTZ", "IO_EXP_MCU_RGMII_RSTZ", + "IO_EXP_CSI1_EXP_RSTZ", "","CSI0_B_GPIO1", + "CSI1_B_GPIO1"; + }; +}; + +&main_i2c1 { + status = "disabled"; +}; + +&main_i2c2 { + status = "disabled"; +}; + +&main_i2c3 { + status = "disabled"; +}; + +&main_i2c4 { + status = "disabled"; +}; + +&main_i2c5 { + status = "disabled"; +}; + +&main_i2c6 { + status = "disabled"; +}; + +&main_sdhci0 { + status = "disabled"; +}; + +&main_sdhci1 { + /* SD card */ + pinctrl-0 = <&main_mmc1_pins_default>; + pinctrl-names = "default"; + disable-wp; + vmmc-supply = <&vdd_mmc1>; + vqmmc-supply = <&vdd_sd_dv>; +}; + +&mcu_cpsw { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>; +}; + +&davinci_mdio { + phy0: ethernet-phy@0 { + reg = <0>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + ti,min-output-impedance; + }; +}; + +&cpsw_port1 { + phy-mode = "rgmii-rxid"; + phy-handle = <&phy0>; +}; + +&serdes_ln_ctrl { + idle-states = <J721S2_SERDES0_LANE0_PCIE1_LANE0>, <J721S2_SERDES0_LANE1_USB>, + <J721S2_SERDES0_LANE3_USB>, <J721S2_SERDES0_LANE2_IP4_UNUSED>; +}; + +&serdes_refclk { + clock-frequency = <100000000>; +}; + +&usb_serdes_mux { + idle-states = <1>; /* USB0 to SERDES lane 1 */ +}; + +&serdes0 { + serdes0_usb_link: link@0 { + reg = <0>; + cdns,num-lanes = <1>; + #phy-cells = <0>; + cdns,phy-type = <PHY_TYPE_USB3>; + resets = <&serdes_wiz0 1>; + }; +}; + +&usbss0 { + pinctrl-0 = <&main_usbss0_pins_default>; + pinctrl-names = "default"; + ti,vbus-divider; +}; + +&usb0 { + dr_mode = "otg"; + maximum-speed = "super-speed"; + phys = <&serdes0_usb_link>; + phy-names = "cdns3,usb3-phy"; +}; + +&mcu_mcan0 { + status = "disabled"; +}; + +&mcu_mcan1 { + status = "disabled"; +}; + +&main_mcan0 { + status = "disabled"; +}; + +&main_mcan1 { + status = "disabled"; +}; + +&main_mcan2 { + status = "disabled"; +}; + +&main_mcan3 { + status = "disabled"; +}; + +&main_mcan4 { + status = "disabled"; +}; + +&main_mcan5 { + status = "disabled"; +}; + +&main_mcan6 { + status = "disabled"; +}; + +&main_mcan7 { + status = "disabled"; +}; + +&main_mcan8 { + status = "disabled"; +}; + +&main_mcan9 { + status = "disabled"; +}; + +&main_mcan10 { + status = "disabled"; +}; + +&main_mcan11 { + status = "disabled"; +}; + +&main_mcan12 { + status = "disabled"; +}; + +&main_mcan13 { + status = "disabled"; +}; + +&main_mcan14 { + status = "disabled"; +}; + +&main_mcan15 { + status = "disabled"; +}; + +&main_mcan17 { + status = "disabled"; +};
Add initial support for AM68 SK device tree that runs on R5.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/k3-am68-sk-r5-base-board.dts | 226 ++++++++++++++++++++++ 2 files changed, 227 insertions(+) create mode 100644 arch/arm/dts/k3-am68-sk-r5-base-board.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b1fcd20f39..6e9e4310d8 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1222,6 +1222,7 @@ dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb \ k3-j721e-sk.dtb \ k3-j721e-r5-sk.dtb dtb-$(CONFIG_SOC_K3_J721S2) += k3-am68-sk-base-board.dtb\ + k3-am68-sk-r5-base-board.dtb\ k3-j721s2-common-proc-board.dtb\ k3-j721s2-r5-common-proc-board.dtb dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-evm.dtb \ diff --git a/arch/arm/dts/k3-am68-sk-r5-base-board.dts b/arch/arm/dts/k3-am68-sk-r5-base-board.dts new file mode 100644 index 0000000000..7d70d8ce81 --- /dev/null +++ b/arch/arm/dts/k3-am68-sk-r5-base-board.dts @@ -0,0 +1,226 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/dts-v1/; + +#include "k3-am68-sk-som.dtsi" +#include "k3-j721s2-ddr-evm-lp4-4266.dtsi" +#include "k3-j721s2-ddr.dtsi" + +/ { + chosen { + firmware-loader = &fs_loader0; + stdout-path = &main_uart8; + tick-timer = &timer1; + }; + + aliases { + remoteproc0 = &sysctrler; + remoteproc1 = &a72_0; + }; + + fs_loader0: fs_loader@0 { + compatible = "u-boot,fs-loader"; + u-boot,dm-pre-reloc; + }; + + a72_0: a72@0 { + compatible = "ti,am654-rproc"; + reg = <0x0 0x00a90000 0x0 0x10>; + power-domains = <&k3_pds 61 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 202 TI_SCI_PD_EXCLUSIVE>; + resets = <&k3_reset 202 0>; + clocks = <&k3_clks 61 1>; + assigned-clocks = <&k3_clks 61 1>, <&k3_clks 202 0>; + assigned-clock-parents = <&k3_clks 61 2>; + assigned-clock-rates = <200000000>, <2000000000>; + ti,sci = <&sms>; + ti,sci-proc-id = <32>; + ti,sci-host-id = <10>; + u-boot,dm-spl; + }; + + clk_200mhz: dummy_clock_200mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <200000000>; + u-boot,dm-spl; + }; + + clk_19_2mhz: dummy_clock_19_2mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <19200000>; + u-boot,dm-spl; + }; +}; + +&cbass_mcu_wakeup { + sa3_secproxy: secproxy@44880000 { + u-boot,dm-spl; + compatible = "ti,am654-secure-proxy"; + reg = <0x0 0x44880000 0x0 0x20000>, + <0x0 0x44860000 0x0 0x20000>, + <0x0 0x43600000 0x0 0x10000>; + reg-names = "rt", "scfg", "target_data"; + #mbox-cells = <1>; + }; + + mcu_secproxy: secproxy@2a380000 { + compatible = "ti,am654-secure-proxy"; + reg = <0x0 0x2a380000 0x0 0x80000>, + <0x0 0x2a400000 0x0 0x80000>, + <0x0 0x2a480000 0x0 0x80000>; + reg-names = "rt", "scfg", "target_data"; + #mbox-cells = <1>; + u-boot,dm-spl; + }; + + sysctrler: sysctrler { + compatible = "ti,am654-system-controller"; + mboxes= <&mcu_secproxy 4>, <&mcu_secproxy 5>, <&sa3_secproxy 5>; + mbox-names = "tx", "rx", "boot_notify"; + u-boot,dm-spl; + }; + + dm_tifs: dm-tifs { + compatible = "ti,j721e-dm-sci"; + ti,host-id = <3>; + ti,secure-host; + mbox-names = "rx", "tx"; + mboxes= <&mcu_secproxy 21>, + <&mcu_secproxy 23>; + u-boot,dm-spl; + }; +}; + +&main_pmx0 { + main_uart8_pins_default: main-uart8-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x0d0, PIN_INPUT, 11) /* (AF26) SPI0_CS1.UART8_RXD */ + J721S2_IOPAD(0x0d4, PIN_OUTPUT, 11) /* (AH27) SPI0_CLK.UART8_TXD */ + >; + }; + + main_mmc1_pins_default: main-mmc1-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x104, PIN_INPUT, 0) /* (P23) MMC1_CLK */ + J721S2_IOPAD(0x108, PIN_INPUT, 0) /* (N24) MMC1_CMD */ + J721S2_IOPAD(0x100, PIN_INPUT, 0) /* (###) MMC1_CLKLB */ + J721S2_IOPAD(0x0fc, PIN_INPUT, 0) /* (M23) MMC1_DAT0 */ + J721S2_IOPAD(0x0f8, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */ + J721S2_IOPAD(0x0f4, PIN_INPUT, 0) /* (R24) MMC1_DAT2 */ + J721S2_IOPAD(0x0f0, PIN_INPUT, 0) /* (R22) MMC1_DAT3 */ + J721S2_IOPAD(0x0e8, PIN_INPUT, 8) /* (AE25) TIMER_IO0.MMC1_SDCD */ + >; + }; + + main_usbss0_pins_default: main-usbss0-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x0ec, PIN_OUTPUT, 6) /* (AG25) TIMER_IO1.USB0_DRVVBUS */ + >; + }; +}; + +&wkup_pmx0 { + mcu_uart0_pins_default: mcu-uart0-pins-default { + u-boot,dm-spl; + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x0f4, PIN_INPUT, 0) /*(C24) WKUP_GPIO0_13.MCU_UART0_RXD*/ + J721S2_WKUP_IOPAD(0x0f0, PIN_OUTPUT, 0) /*(C25) WKUP_GPIO0_12.MCU_UART0_TXD*/ + >; + }; + + wkup_uart0_pins_default: wkup-uart0-pins-default { + u-boot,dm-spl; + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x0d8, PIN_INPUT, 0) /*(E25) WKUP_GPIO0_6.WKUP_UART0_CTSn*/ + J721S2_WKUP_IOPAD(0x0dc, PIN_OUTPUT, 0) /*(F28) WKUP_GPIO0_7.WKUP_UART0_RTSn*/ + J721S2_WKUP_IOPAD(0x0b0, PIN_INPUT, 0) /* (D28) WKUP_UART0_RXD */ + J721S2_WKUP_IOPAD(0x0b4, PIN_OUTPUT, 0) /* (D27) WKUP_UART0_TXD */ + >; + }; + +}; + +&sms { + mboxes= <&mcu_secproxy 8>, <&mcu_secproxy 6>, <&mcu_secproxy 5>; + mbox-names = "tx", "rx", "notify"; + ti,host-id = <4>; + ti,secure-host; + u-boot,dm-spl; +}; + +&wkup_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; +}; + +&mcu_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_uart0_pins_default>; +}; + +&main_uart8 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart8_pins_default>; +}; + +&main_sdhci0 { + status = "disabled"; +}; + +&main_sdhci1 { + /delete-property/ power-domains; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + pinctrl-0 = <&main_mmc1_pins_default>; + pinctrl-names = "default"; + clock-names = "clk_xin"; + clocks = <&clk_200mhz>; + ti,driver-strength-ohm = <50>; +}; + +&usbss0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_usbss0_pins_default>; + ti,vbus-divider; + ti,usb2-only; +}; + +&usb0 { + dr_mode = "otg"; + maximum-speed = "high-speed"; +}; + +&mcu_ringacc { + ti,sci = <&dm_tifs>; +}; + +&mcu_udmap { + ti,sci = <&dm_tifs>; +}; + +&ospi0 { + reg = <0x0 0x47040000 0x0 0x100>, + <0x0 0x50000000 0x0 0x8000000>; + + flash@0{ + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-tx-bus-width = <8>; + spi-rx-bus-width = <8>; + spi-max-frequency = <25000000>; + cdns,tshsl-ns = <60>; + cdns,tsd2d-ns = <60>; + cdns,tchsh-ns = <60>; + cdns,tslch-ns = <60>; + cdns,read-delay = <4>; + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +#include "k3-am68-sk-base-board-u-boot.dtsi"
Now that single defconfig shall be used for booting J721S2 EVM and AM68 SK, the default device tree will not work for selecting dtb for kernel. Update the findfdt env to select right dtb based on board_name env variable.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- include/configs/j721s2_evm.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/j721s2_evm.h b/include/configs/j721s2_evm.h index 932d7d3c8c..715f03048a 100644 --- a/include/configs/j721s2_evm.h +++ b/include/configs/j721s2_evm.h @@ -32,6 +32,10 @@ "default_device_tree=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "findfdt=" \ "setenv name_fdt ${default_device_tree};" \ + "if test $board_name = j721s2; then " \ + "setenv name_fdt k3-j721s2-common-proc-board.dtb; fi;" \ + "if test $board_name = am68-sk; then " \ + "setenv name_fdt k3-am68-sk-base-board.dtb; fi;"\ "setenv fdtfile ${name_fdt}\0" \ "name_kern=Image\0" \ "console=ttyS2,115200n8\0" \
Sinthu Raja
