[U-Boot] About mtest on boot
Hello,
I want to stop autoboot and use mtest to check if my ram is alright, but 0x07FD2C00 forward freezes, and 0x00000902 also freezes, mtest, when using it. My ramsize is 0x08000000.
Does u-boot uses any parts of ram by itself, I mean, is there any known spots where I can't test because it would crash my system?
Thanks
Érico V. Porto
On Fri, 20 Jan 2012 08:07:41 -0200 Érico Porto ericoporto2008@gmail.com wrote:
Hello,
U-Boot relocates itself into RAM. You can check the address using 'bdinfo' command (look at 'relocaddr' in the output). There are also some data structures in RAM (global data, board info, stack, malloc area) and also exception vectors. Where it is located in RAM depends on your architecture and board configuration options. You can try to define DEBUG in the arch board.c file to get more info. Board config file should define CONFIG_SYS_MEMTEST_START and CONFIG_SYS_MEMTEST_END to prevent crashing when mtest is invoked.
HTH, Anatolij
Now I understood, LTIB is giving me an older u-boot version - 1.1.6 and not 2011.12. Will try to update it...
Érico V. Porto
Hello,
using
HTH, Anatolij
Okay, got 2011.12 working here.
Same problem, my system stalls when I try using mtest on low position of the memory, but now I have the relocaddr var to tell me what is the superior memory limit.
( I can't paste any output here because the list gives me a BASE ENCODE64 not allowed error... )
And if the system freezes during mtest, I can't ctrl+c out of it.
Is there any know workaround?
My system is much a like MPC8323ERDB. Other than that, seems I can run linux fine on it after bootload, I just can't use mtest...
Érico V. Porto
Érico V. Porto
Hello,
using
HTH, Anatolij
I've partially solved the ctrl+c situatin inserting more check for it into the code. But this isn't really what I was hoping...
Any known alternatives? Thanks.
Érico V. Porto
Érico V. Porto
Érico V. Porto
Hello,
but
using
HTH, Anatolij
Anatolij Gustschin
Érico Porto
