[PATCH 0/2] reset: fix reset_get_by_index_nodev index handling
A regression weas detected on Amlogic G12A/G12B SoCs, where HDMI output was disable even when Linux was booting.
Bisect reports 139e4a1cbe ("drivers: reset: Add a managed API to get reset controllers from the DT") as the offending commit.
But the error is in ea9dc35aab ("reset: Get the RESET by index without device") where a spurius "> 0" was added to the index handling.
But the dm_test_reset_base() test did not catch it.
The first commit extends the test to catch the regression, and the second patch fixes the regression.
Neil Armstrong (2): test: reset: Extend base reset test to catch error reset: fix reset_get_by_index_nodev index handling
arch/sandbox/dts/test.dts | 4 ++-- drivers/reset/reset-uclass.c | 2 +- test/dm/reset.c | 39 +++++++++++++++++++++++++++++++----- 3 files changed, 37 insertions(+), 8 deletions(-)
With this extended test, we get the following failure :
=> ut dm reset_base Test: dm_test_reset_base: reset.c test/dm/reset.c:52, dm_test_reset_base(): reset_method3.id == reset_method3_1.id: Expected 0x14 (20), got 0x2 (2) Test: dm_test_reset_base: reset.c (flat tree) test/dm/reset.c:52, dm_test_reset_base(): reset_method3.id == reset_method3_1.id: Expected 0x14 (20), got 0x2 (2) Failures: 2
A fix is needed in reset_get_by_index_nodev() when introduced in [1].
[1] ea9dc35aab ("reset: Get the RESET by index without device")
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/sandbox/dts/test.dts | 4 ++-- test/dm/reset.c | 39 ++++++++++++++++++++++++++++++++++----- 2 files changed, 36 insertions(+), 7 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 48240aa26f..4fde923e9a 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -997,8 +997,8 @@
reset-ctl-test { compatible = "sandbox,reset-ctl-test"; - resets = <&resetc 100>, <&resetc 2>; - reset-names = "other", "test"; + resets = <&resetc 100>, <&resetc 2>, <&resetc 20>, <&resetc 40>; + reset-names = "other", "test", "test2", "test3"; };
rng { diff --git a/test/dm/reset.c b/test/dm/reset.c index fc8e9250b0..9c00452336 100644 --- a/test/dm/reset.c +++ b/test/dm/reset.c @@ -24,18 +24,47 @@ static int dm_test_reset_base(struct unit_test_state *uts) { struct udevice *dev; - struct reset_ctl reset_method1; - struct reset_ctl reset_method2; + struct reset_ctl reset_method1, reset_method1_1; + struct reset_ctl reset_method2, reset_method2_1; + struct reset_ctl reset_method3, reset_method3_1; + struct reset_ctl reset_method4, reset_method4_1;
/* Get the device using the reset device */ ut_assertok(uclass_get_device_by_name(UCLASS_MISC, "reset-ctl-test", &dev));
/* Get the same reset port in 2 different ways and compare */ - ut_assertok(reset_get_by_index(dev, 1, &reset_method1)); + ut_assertok(reset_get_by_index(dev, 0, &reset_method1)); + ut_assertok(reset_get_by_index_nodev(dev_ofnode(dev), 0, + &reset_method1_1)); + ut_assertok(reset_get_by_index(dev, 1, &reset_method2)); ut_assertok(reset_get_by_index_nodev(dev_ofnode(dev), 1, - &reset_method2)); - ut_asserteq(reset_method1.id, reset_method2.id); + &reset_method2_1)); + ut_assertok(reset_get_by_index(dev, 2, &reset_method3)); + ut_assertok(reset_get_by_index_nodev(dev_ofnode(dev), 2, + &reset_method3_1)); + ut_assertok(reset_get_by_index(dev, 3, &reset_method4)); + ut_assertok(reset_get_by_index_nodev(dev_ofnode(dev), 3, + &reset_method4_1)); + + ut_asserteq(reset_method1.id, reset_method1_1.id); + ut_asserteq(reset_method2.id, reset_method2_1.id); + ut_asserteq(reset_method3.id, reset_method3_1.id); + ut_asserteq(reset_method4.id, reset_method4_1.id); + + ut_asserteq(true, reset_method1.id != reset_method2.id); + ut_asserteq(true, reset_method1.id != reset_method3.id); + ut_asserteq(true, reset_method1.id != reset_method4.id); + ut_asserteq(true, reset_method2.id != reset_method3.id); + ut_asserteq(true, reset_method2.id != reset_method4.id); + ut_asserteq(true, reset_method3.id != reset_method4.id); + + ut_asserteq(true, reset_method1_1.id != reset_method2_1.id); + ut_asserteq(true, reset_method1_1.id != reset_method3_1.id); + ut_asserteq(true, reset_method1_1.id != reset_method4_1.id); + ut_asserteq(true, reset_method2_1.id != reset_method3_1.id); + ut_asserteq(true, reset_method2_1.id != reset_method4_1.id); + ut_asserteq(true, reset_method3_1.id != reset_method4_1.id);
return 0; }
This fixes an issue getting resets index 1 and 3+, the spurius "> 0" made it return the index 0 or 1, whatever index was passed.
The dm_test_reset_base() did not catch it, but the dm_test_reset_base() extension catches it and this fixes the regression.
This also fixes a reggression on Amlogic G12A/G12B SoCs, where HDMI output was disable even when Linux was booting.
Fixes: ea9dc35aab ("reset: Get the RESET by index without device") Reported-by: B1oHazard ty3uk@mail.ua Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/reset/reset-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/reset/reset-uclass.c b/drivers/reset/reset-uclass.c index 071c389ca0..ac89eaf098 100644 --- a/drivers/reset/reset-uclass.c +++ b/drivers/reset/reset-uclass.c @@ -95,7 +95,7 @@ int reset_get_by_index_nodev(ofnode node, int index, int ret;
ret = ofnode_parse_phandle_with_args(node, "resets", "#reset-cells", 0, - index > 0, &args); + index, &args);
return reset_get_by_index_tail(ret, node, &args, "resets", index > 0, reset_ctl);
Hi Tom, Simon,
So you have any comment on the patch order here ? Should I push the fixed test after the fix ?
Neil
On Tue, Apr 27, 2021 at 09:37:11AM +0200, Neil Armstrong wrote:
Hi Tom, Simon,
I'll grab these shortly, thanks for the reminder.
Neil Armstrong
