[PATCH 1/1] block: ide: use definitions from include/libata.h
Currently ATA commands are defined both in include/libata.h and include/ata.h. libata.h is included in ata.h. So this duplication does not make much sense.
Use the command definitions from include/libata.h where applicable.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/block/ide.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/block/ide.c b/drivers/block/ide.c index 4b8a4eac17..67cc4fbc02 100644 --- a/drivers/block/ide.c +++ b/drivers/block/ide.c @@ -231,7 +231,7 @@ unsigned char atapi_issue(int device, unsigned char *ccb, int ccblen, (unsigned char) ((buflen >> 8) & 0xFF)); ide_outb(device, ATA_DEV_HD, ATA_LBA | ATA_DEVICE(device));
- ide_outb(device, ATA_COMMAND, ATAPI_CMD_PACKET); + ide_outb(device, ATA_COMMAND, ATA_CMD_PACKET); udelay(50);
mask = ATA_STAT_DRQ | ATA_STAT_BUSY | ATA_STAT_ERR; @@ -570,7 +570,7 @@ static void ide_ident(struct blk_desc *dev_desc) /* * Start Ident Command */ - ide_outb(device, ATA_COMMAND, ATAPI_CMD_IDENT); + ide_outb(device, ATA_COMMAND, ATA_CMD_ID_ATAPI); /* * Wait for completion - ATAPI devices need more time * to become ready @@ -582,7 +582,7 @@ static void ide_ident(struct blk_desc *dev_desc) /* * Start Ident Command */ - ide_outb(device, ATA_COMMAND, ATA_CMD_IDENT); + ide_outb(device, ATA_COMMAND, ATA_CMD_ID_ATA);
/* * Wait for completion @@ -966,7 +966,7 @@ ulong ide_read(struct blk_desc *block_dev, lbaint_t blknr, lbaint_t blkcnt,
/* first check if the drive is in Powersaving mode, if yes, * increase the timeout value */ - ide_outb(device, ATA_COMMAND, ATA_CMD_CHK_PWR); + ide_outb(device, ATA_COMMAND, ATA_CMD_CHK_POWER); udelay(50);
c = ide_wait(device, IDE_TIME_OUT); /* can't take over 500 ms */ -- 2.25.0
