Dear u-boot team,
Occasionally, I get corrupted rootfs if the system power goes away while u-boot is attaching the root file system in order to fetch the kernel.
I am using imx6 Solo and u-boot 2013-10.
Is there any way to stop uboot messing up the file system while making attachment of UBI? Does the latest u-boot provides a better way to protect the ubi file system during attachment.
Any advice or guidance will be very much appreciated.
Andy
Hello Andy,
Am 01.02.2016 um 09:58 schrieb Andy Ng:
Dear u-boot team,
In principle U-Boot has the same code as Linux. Current U-Boot uses Linux code from:
linux v4.2 commit 64291f7db5bd8150a74ad2036f1037e6a0428df2
see U-Boot commit: 0195a7bb36a0abc71145da419001377bf56662fd
2013-10 uses an older Source Base, so update to current U-Boot is recommended... yes.
Do you see this issue also with Linux?
Do you use UBI FASTMAP?
bye, Heiko
Thank you for your reply.
by going to update u-boot, does it guaranty corruption free UBI if the power goes away during the phase where u-boot fetches uImage from the ubifs?
best regards, Andy
On Mon, Feb 1, 2016 at 9:34 AM, Heiko Schocher hs@denx.de wrote:
Hello Andy,
Dear u-boot team,
bye, Heiko -- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
Hello Andy,
Am 01.02.2016 um 14:42 schrieb Andy Ng:
I cannot guarantee this. The problem can be also in the underlying nand driver. Try current code, also enable UBI debug messages, may this shows the problem...
bye, Heiko
best regards, Andy
Hello Andy,
Dear u-boot team,
Andy Ng
Heiko Schocher
