[U-Boot] [PATCH] Remove entirely superfluous preprocessor tests from cmd_*.c files.
A small number of common/cmd_*.c files contain preprocessor tests that are apparently superfluous since those same tests are used in the Makefile to control the compilation of those files. Those tests are clearly redundant as long as they surround the entirety of the source in those files.
Signed-off-by: Robert P. J. Day rpjday@crashcourse.ca
based on simple visual inspection, i can't see how those tests could make any difference so they might as well be tossed.
diff --git a/common/cmd_cache.c b/common/cmd_cache.c index 0dfa336..1202258 100644 --- a/common/cmd_cache.c +++ b/common/cmd_cache.c @@ -27,8 +27,6 @@ #include <common.h> #include <command.h>
-#if defined(CONFIG_CMD_CACHE) - static int on_off (const char *);
int do_icache ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -108,5 +106,3 @@ U_BOOT_CMD( "[on, off]\n" " - enable or disable data (writethrough) cache" ); - -#endif diff --git a/common/cmd_license.c b/common/cmd_license.c index 141215b..c6f272a 100644 --- a/common/cmd_license.c +++ b/common/cmd_license.c @@ -23,8 +23,6 @@
#include <common.h>
-#if defined(CONFIG_CMD_LICENSE) - /* COPYING is currently 15951 bytes in size */ #define LICENSE_MAX 20480
@@ -56,5 +54,3 @@ U_BOOT_CMD(license, 1, 1, do_license, "print GPL license text", "" ); - -#endif /* CONFIG_CMD_LICENSE */ diff --git a/common/cmd_mgdisk.c b/common/cmd_mgdisk.c index aadc335..3ba62f6 100644 --- a/common/cmd_mgdisk.c +++ b/common/cmd_mgdisk.c @@ -24,8 +24,6 @@ #include <common.h> #include <command.h>
-#if defined (CONFIG_CMD_MG_DISK) - #include <mg_disk.h>
int do_mg_disk_cmd (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -72,5 +70,3 @@ U_BOOT_CMD( " - sector read : mgd readsec [sector] [to] [counts]\n" " - sector write : mgd writesec [from] [sector] [counts]" ); - -#endif
======================================================================== Robert P. J. Day Waterloo, Ontario, CANADA
Linux Consulting, Training and Kernel Pedantry.
Web page: http://crashcourse.ca Twitter: http://twitter.com/rpjday ========================================================================
Hi Robert, Thanks for the cleanup. The above change was recently submitted, but hasn't been applied yet. Search for "cmd_license: Remove unneeded #ifdef CONFIG_CMD_LICENSE". Could you remove the above chunk from your patch and resubmit so as to prevent a conflict when Wolfgang applies both patches?
Best, Peter
okey dokey, coming right up.
rday --
Peter Tyser
Robert P. J. Day
