[U-Boot] [v2 PATCH 0/2] omap3-overo: Code cleanup and reduce the size of MLO binary.
This is the v2 of the two-patch series. v1 can be found here: http://lists.denx.de/pipermail/u-boot/2015-April/211651.html
The only change in this version is that the earlier version missed printing the board revision, so fixed that.
Arun Bharadwaj (2): This separates the SPL-specific code from the u-boot-specific code for the Overo board following the discussion at http://lists.denx.de/pipermail/u-boot/2015-April/211622.html u-boot breaks for the Overo boards since the following commit: a6b541b09022acb6f7c2754100ae26bd44eed1d9
board/overo/Makefile | 6 +- board/overo/common.c | 341 +++++++++++++++++++++++++++++++++++++++++++++++++++ board/overo/overo.c | 117 +----------------- board/overo/overo.h | 266 +--------------------------------------- board/overo/spl.c | 60 +++++++++ 5 files changed, 411 insertions(+), 379 deletions(-) create mode 100644 board/overo/common.c create mode 100644 board/overo/spl.c
The code is split up into spl.c, overo.c and common.c (which has the code common to both)
Signed-off-by: Arun Bharadwaj arun@gumstix.com --- board/overo/Makefile | 6 +- board/overo/common.c | 355 +++++++++++++++++++++++++++++++++++++++++++++++++++ board/overo/overo.c | 117 +---------------- board/overo/overo.h | 266 +------------------------------------- board/overo/spl.c | 60 +++++++++ 5 files changed, 425 insertions(+), 379 deletions(-) create mode 100644 board/overo/common.c create mode 100644 board/overo/spl.c
diff --git a/board/overo/Makefile b/board/overo/Makefile index 9109484..2189071 100644 --- a/board/overo/Makefile +++ b/board/overo/Makefile @@ -5,4 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y := overo.o +ifdef CONFIG_SPL_BUILD +obj-y := spl.o common.o +else +obj-y := overo.o common.o +endif diff --git a/board/overo/common.c b/board/overo/common.c new file mode 100644 index 0000000..bdfa5ca --- /dev/null +++ b/board/overo/common.c @@ -0,0 +1,355 @@ +/* + * Maintainer : Steve Sakoman steve@sakoman.com + * + * Derived from Beagle Board, 3430 SDP, and OMAP3EVM code by + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim khasim@ti.com + * Sunil Kumar sunilsaini05@gmail.com + * Shashi Ranjan shashiranjanmca05@gmail.com + * + * (C) Copyright 2004-2008 + * Texas Instruments, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <twl4030.h> +#include <common.h> +#include <asm/io.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define TWL4030_I2C_BUS 0 + +/* + * Routine: board_init + * Description: Early hardware init. + */ +int board_init(void) +{ + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + /* board id for Linux */ + gd->bd->bi_arch_number = MACH_TYPE_OVERO; + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + return 0; +} + +#define MUX_OVERO() \ + /*SDRC*/\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) /*SDRC_D0*/\ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) /*SDRC_D1*/\ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) /*SDRC_D2*/\ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) /*SDRC_D3*/\ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) /*SDRC_D4*/\ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) /*SDRC_D5*/\ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) /*SDRC_D6*/\ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) /*SDRC_D7*/\ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) /*SDRC_D8*/\ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) /*SDRC_D9*/\ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) /*SDRC_D10*/\ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) /*SDRC_D11*/\ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) /*SDRC_D12*/\ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) /*SDRC_D13*/\ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) /*SDRC_D14*/\ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) /*SDRC_D15*/\ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) /*SDRC_D16*/\ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) /*SDRC_D17*/\ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) /*SDRC_D18*/\ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) /*SDRC_D19*/\ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) /*SDRC_D20*/\ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) /*SDRC_D21*/\ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) /*SDRC_D22*/\ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) /*SDRC_D23*/\ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) /*SDRC_D24*/\ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) /*SDRC_D25*/\ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) /*SDRC_D26*/\ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) /*SDRC_D27*/\ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) /*SDRC_D28*/\ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) /*SDRC_D29*/\ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) /*SDRC_D30*/\ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) /*SDRC_D31*/\ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) /*SDRC_CLK*/\ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) /*SDRC_DQS0*/\ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) /*SDRC_DQS1*/\ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) /*SDRC_DQS2*/\ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) /*SDRC_DQS3*/\ + /*GPMC*/\ + MUX_VAL(CP(GPMC_A1), (IDIS | PTU | EN | M0)) /*GPMC_A1*/\ + MUX_VAL(CP(GPMC_A2), (IDIS | PTU | EN | M0)) /*GPMC_A2*/\ + MUX_VAL(CP(GPMC_A3), (IDIS | PTU | EN | M0)) /*GPMC_A3*/\ + MUX_VAL(CP(GPMC_A4), (IDIS | PTU | EN | M0)) /*GPMC_A4*/\ + MUX_VAL(CP(GPMC_A5), (IDIS | PTU | EN | M0)) /*GPMC_A5*/\ + MUX_VAL(CP(GPMC_A6), (IDIS | PTU | EN | M0)) /*GPMC_A6*/\ + MUX_VAL(CP(GPMC_A7), (IDIS | PTU | EN | M0)) /*GPMC_A7*/\ + MUX_VAL(CP(GPMC_A8), (IDIS | PTU | EN | M0)) /*GPMC_A8*/\ + MUX_VAL(CP(GPMC_A9), (IDIS | PTU | EN | M0)) /*GPMC_A9*/\ + MUX_VAL(CP(GPMC_A10), (IDIS | PTU | EN | M0)) /*GPMC_A10*/\ + MUX_VAL(CP(GPMC_D0), (IEN | PTU | EN | M0)) /*GPMC_D0*/\ + MUX_VAL(CP(GPMC_D1), (IEN | PTU | EN | M0)) /*GPMC_D1*/\ + MUX_VAL(CP(GPMC_D2), (IEN | PTU | EN | M0)) /*GPMC_D2*/\ + MUX_VAL(CP(GPMC_D3), (IEN | PTU | EN | M0)) /*GPMC_D3*/\ + MUX_VAL(CP(GPMC_D4), (IEN | PTU | EN | M0)) /*GPMC_D4*/\ + MUX_VAL(CP(GPMC_D5), (IEN | PTU | EN | M0)) /*GPMC_D5*/\ + MUX_VAL(CP(GPMC_D6), (IEN | PTU | EN | M0)) /*GPMC_D6*/\ + MUX_VAL(CP(GPMC_D7), (IEN | PTU | EN | M0)) /*GPMC_D7*/\ + MUX_VAL(CP(GPMC_D8), (IEN | PTU | EN | M0)) /*GPMC_D8*/\ + MUX_VAL(CP(GPMC_D9), (IEN | PTU | EN | M0)) /*GPMC_D9*/\ + MUX_VAL(CP(GPMC_D10), (IEN | PTU | EN | M0)) /*GPMC_D10*/\ + MUX_VAL(CP(GPMC_D11), (IEN | PTU | EN | M0)) /*GPMC_D11*/\ + MUX_VAL(CP(GPMC_D12), (IEN | PTU | EN | M0)) /*GPMC_D12*/\ + MUX_VAL(CP(GPMC_D13), (IEN | PTU | EN | M0)) /*GPMC_D13*/\ + MUX_VAL(CP(GPMC_D14), (IEN | PTU | EN | M0)) /*GPMC_D14*/\ + MUX_VAL(CP(GPMC_D15), (IEN | PTU | EN | M0)) /*GPMC_D15*/\ + MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) /*GPMC_nCS0*/\ + MUX_VAL(CP(GPMC_NCS2), (IDIS | PTU | EN | M0)) /*GPMC_nCS2*/\ + MUX_VAL(CP(GPMC_NCS3), (IEN | PTU | EN | M4)) /*GPIO_54*/\ + /* - MMC1_WP*/\ + MUX_VAL(CP(GPMC_NCS7), (IEN | PTU | EN | M0)) /*GPMC_nCS7*/\ + MUX_VAL(CP(GPMC_NBE1), (IEN | PTD | DIS | M0)) /*GPMC_nCS3*/\ + MUX_VAL(CP(GPMC_CLK), (IEN | PTU | EN | M0)) /*GPMC_CLK*/\ + MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) /*GPMC_nADV_ALE*/\ + MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) /*GPMC_nOE*/\ + MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) /*GPMC_nWE*/\ + MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTD | DIS | M0)) /*GPMC_nBE0_CLE*/\ + MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) /*GPMC_nWP*/\ + MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) /*GPMC_WAIT0*/\ + /*CAMERA*/\ + MUX_VAL(CP(CAM_HS), (IEN | PTU | DIS | M0)) /*CAM_HS */\ + MUX_VAL(CP(CAM_VS), (IEN | PTU | DIS | M0)) /*CAM_VS */\ + MUX_VAL(CP(CAM_XCLKA), (IDIS | PTD | DIS | M0)) /*CAM_XCLKA*/\ + MUX_VAL(CP(CAM_PCLK), (IEN | PTU | DIS | M0)) /*CAM_PCLK*/\ + MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M0)) /*CAM_D0*/\ + MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M0)) /*CAM_D1*/\ + MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M0)) /*CAM_D2*/\ + MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M0)) /*CAM_D3*/\ + MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M0)) /*CAM_D4*/\ + MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M0)) /*CAM_D5*/\ + MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M0)) /*CAM_D6*/\ + MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M0)) /*CAM_D7*/\ + MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M0)) /*CAM_D8*/\ + MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M0)) /*CAM_D9*/\ + MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M0)) /*CAM_D10*/\ + MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M0)) /*CAM_D11*/\ + MUX_VAL(CP(CSI2_DX0), (IEN | PTD | EN | M4)) /*GPIO_112*/\ + MUX_VAL(CP(CSI2_DY0), (IEN | PTD | EN | M4)) /*GPIO_113*/\ + MUX_VAL(CP(CSI2_DY1), (IEN | PTD | EN | M4)) /*GPIO_115*/\ + /*Audio Interface */\ + MUX_VAL(CP(MCBSP2_FSX), (IEN | PTD | DIS | M0)) /*McBSP2_FSX*/\ + MUX_VAL(CP(MCBSP2_CLKX), (IEN | PTD | DIS | M0)) /*McBSP2_CLKX*/\ + MUX_VAL(CP(MCBSP2_DR), (IEN | PTD | DIS | M0)) /*McBSP2_DR*/\ + MUX_VAL(CP(MCBSP2_DX), (IDIS | PTD | DIS | M0)) /*McBSP2_DX*/\ + /*Expansion card */\ + MUX_VAL(CP(MMC1_CLK), (IEN | PTU | EN | M0)) /*MMC1_CLK*/\ + MUX_VAL(CP(MMC1_CMD), (IEN | PTU | EN | M0)) /*MMC1_CMD*/\ + MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | EN | M0)) /*MMC1_DAT0*/\ + MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | EN | M0)) /*MMC1_DAT1*/\ + MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | EN | M0)) /*MMC1_DAT2*/\ + MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | EN | M0)) /*MMC1_DAT3*/\ + MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M0)) /*MMC1_DAT4*/\ + MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M0)) /*MMC1_DAT5*/\ + MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M0)) /*MMC1_DAT6*/\ + MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M0)) /*MMC1_DAT7*/\ + /*Wireless LAN */\ + MUX_VAL(CP(MMC2_CLK), (IEN | PTU | EN | M4)) /*GPIO_130*/\ + MUX_VAL(CP(MMC2_CMD), (IEN | PTU | EN | M0)) /*MMC2_CMD*/\ + MUX_VAL(CP(MMC2_DAT0), (IEN | PTU | EN | M0)) /*MMC2_DAT0*/\ + MUX_VAL(CP(MMC2_DAT1), (IEN | PTU | EN | M0)) /*MMC2_DAT1*/\ + MUX_VAL(CP(MMC2_DAT2), (IEN | PTU | EN | M0)) /*MMC2_DAT2*/\ + MUX_VAL(CP(MMC2_DAT3), (IEN | PTU | EN | M0)) /*MMC2_DAT3*/\ + MUX_VAL(CP(MMC2_DAT4), (IEN | PTU | EN | M1)) /*MMC2_DIR_DAT0*/\ + MUX_VAL(CP(MMC2_DAT5), (IEN | PTU | EN | M1)) /*MMC2_DIR_DAT1*/\ + MUX_VAL(CP(MMC2_DAT6), (IEN | PTU | EN | M1)) /*MMC2_DIR_CMD*/\ + MUX_VAL(CP(MMC2_DAT7), (IEN | PTU | EN | M4)) /*GPIO_139*/\ + /*Bluetooth*/\ + MUX_VAL(CP(MCBSP3_DX), (IEN | PTD | DIS | M1)) /*UART2_CTS*/\ + MUX_VAL(CP(MCBSP3_DR), (IDIS | PTD | DIS | M1)) /*UART2_RTS*/\ + MUX_VAL(CP(MCBSP3_CLKX), (IDIS | PTD | DIS | M1)) /*UART2_TX*/\ + MUX_VAL(CP(MCBSP3_FSX), (IEN | PTD | DIS | M1)) /*UART2_RX*/\ + MUX_VAL(CP(UART1_RTS), (IEN | PTU | DIS | M4)) /*GPIO_149*/ \ + MUX_VAL(CP(MCBSP4_CLKX), (IEN | PTD | DIS | M0)) /*McBSP4_CLKX*/\ + MUX_VAL(CP(MCBSP4_DR), (IEN | PTD | DIS | M0)) /*McBSP4_DR*/\ + MUX_VAL(CP(MCBSP4_DX), (IEN | PTD | DIS | M0)) /*McBSP4_DX*/\ + MUX_VAL(CP(MCBSP4_FSX), (IEN | PTD | DIS | M0)) /*McBSP4_FSX*/\ + MUX_VAL(CP(MCBSP1_CLKR), (IEN | PTD | DIS | M0)) /*McBSP1_CLKR*/\ + MUX_VAL(CP(MCBSP1_FSR), (IEN | PTD | DIS | M0)) /*McBSP1_FSR*/\ + MUX_VAL(CP(MCBSP1_DX), (IEN | PTD | DIS | M0)) /*McBSP1_DX*/\ + MUX_VAL(CP(MCBSP1_DR), (IEN | PTD | DIS | M0)) /*McBSP1_DR*/\ + MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) /*McBSP_CLKS*/\ + MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | DIS | M0)) /*McBSP1_FSX*/\ + MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTD | DIS | M0)) /*McBSP1_CLKX*/\ + /*Serial Interface*/\ + MUX_VAL(CP(UART3_RTS_SD), (IEN | PTU | EN | M4)) /*GPIO_164 W2W_*/\ + /* BT_NRESET*/\ + MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTU | EN | M0)) /*UART3_RX_IRRX*/\ + MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) /*UART3_TX_IRTX*/\ + MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) /*HSUSB0_CLK*/\ + MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) /*HSUSB0_STP*/\ + MUX_VAL(CP(HSUSB0_DIR), (IEN | PTD | DIS | M0)) /*HSUSB0_DIR*/\ + MUX_VAL(CP(HSUSB0_NXT), (IEN | PTD | DIS | M0)) /*HSUSB0_NXT*/\ + MUX_VAL(CP(HSUSB0_DATA0), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA0*/\ + MUX_VAL(CP(HSUSB0_DATA1), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA1*/\ + MUX_VAL(CP(HSUSB0_DATA2), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA2*/\ + MUX_VAL(CP(HSUSB0_DATA3), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA3*/\ + MUX_VAL(CP(HSUSB0_DATA4), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA4*/\ + MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA5*/\ + MUX_VAL(CP(HSUSB0_DATA6), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA6*/\ + MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA7*/\ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) /*I2C1_SCL*/\ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) /*I2C1_SDA*/\ + MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M4)) /*GPIO_168*/\ + /* - USBH_CPEN*/\ + MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M4)) /*GPIO_183*/\ + /* - USBH_RESET*/\ + MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0)) /*I2C3_SCL*/\ + MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0)) /*I2C3_SDA*/\ + MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) /*I2C4_SCL*/\ + MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0)) /*I2C4_SDA*/\ + MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA2*/\ + MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA7*/\ + MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA4*/\ + MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA5*/\ + MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA6*/\ + MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA3*/\ + /*Control and debug */\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) /*SYS_32K*/\ + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) /*SYS_CLKREQ*/\ + MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) /*SYS_nIRQ*/\ + MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /*GPIO_2*/\ + MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /*GPIO_3 */\ + MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /*GPIO_4 - MMC1_WP*/\ + MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4)) /*GPIO_5*/\ + MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4)) /*GPIO_6*/\ + MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /*GPIO_7*/\ + MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4)) /*GPIO_8*/\ + MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) /*SYS_OFF_MODE*/\ + MUX_VAL(CP(ETK_D1_ES2), (IEN | PTD | EN | M4)) /*GPIO_15 - X_GATE*/\ + MUX_VAL(CP(ETK_D2_ES2), (IEN | PTU | EN | M4)) /*GPIO_16*/\ + /* - W2W_NRESET*/\ + MUX_VAL(CP(ETK_D10_ES2), (IDIS | PTD | DIS | M3)) /*HSUSB2_CLK*/\ + MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTD | DIS | M3)) /*HSUSB2_STP*/\ + MUX_VAL(CP(ETK_D12_ES2), (IEN | PTD | DIS | M3)) /*HSUSB2_DIR*/\ + MUX_VAL(CP(ETK_D13_ES2), (IEN | PTD | DIS | M3)) /*HSUSB2_NXT*/\ + MUX_VAL(CP(ETK_D14_ES2), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA0*/\ + MUX_VAL(CP(ETK_D15_ES2), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA1*/\ + /* die to die */\ + MUX_VAL(CP(D2D_MCAD1), (IEN | PTD | EN | M0)) /*d2d_mcad1*/\ + MUX_VAL(CP(D2D_MCAD2), (IEN | PTD | EN | M0)) /*d2d_mcad2*/\ + MUX_VAL(CP(D2D_MCAD3), (IEN | PTD | EN | M0)) /*d2d_mcad3*/\ + MUX_VAL(CP(D2D_MCAD4), (IEN | PTD | EN | M0)) /*d2d_mcad4*/\ + MUX_VAL(CP(D2D_MCAD5), (IEN | PTD | EN | M0)) /*d2d_mcad5*/\ + MUX_VAL(CP(D2D_MCAD6), (IEN | PTD | EN | M0)) /*d2d_mcad6*/\ + MUX_VAL(CP(D2D_MCAD7), (IEN | PTD | EN | M0)) /*d2d_mcad7*/\ + MUX_VAL(CP(D2D_MCAD8), (IEN | PTD | EN | M0)) /*d2d_mcad8*/\ + MUX_VAL(CP(D2D_MCAD9), (IEN | PTD | EN | M0)) /*d2d_mcad9*/\ + MUX_VAL(CP(D2D_MCAD10), (IEN | PTD | EN | M0)) /*d2d_mcad10*/\ + MUX_VAL(CP(D2D_MCAD11), (IEN | PTD | EN | M0)) /*d2d_mcad11*/\ + MUX_VAL(CP(D2D_MCAD12), (IEN | PTD | EN | M0)) /*d2d_mcad12*/\ + MUX_VAL(CP(D2D_MCAD13), (IEN | PTD | EN | M0)) /*d2d_mcad13*/\ + MUX_VAL(CP(D2D_MCAD14), (IEN | PTD | EN | M0)) /*d2d_mcad14*/\ + MUX_VAL(CP(D2D_MCAD15), (IEN | PTD | EN | M0)) /*d2d_mcad15*/\ + MUX_VAL(CP(D2D_MCAD16), (IEN | PTD | EN | M0)) /*d2d_mcad16*/\ + MUX_VAL(CP(D2D_MCAD17), (IEN | PTD | EN | M0)) /*d2d_mcad17*/\ + MUX_VAL(CP(D2D_MCAD18), (IEN | PTD | EN | M0)) /*d2d_mcad18*/\ + MUX_VAL(CP(D2D_MCAD19), (IEN | PTD | EN | M0)) /*d2d_mcad19*/\ + MUX_VAL(CP(D2D_MCAD20), (IEN | PTD | EN | M0)) /*d2d_mcad20*/\ + MUX_VAL(CP(D2D_MCAD21), (IEN | PTD | EN | M0)) /*d2d_mcad21*/\ + MUX_VAL(CP(D2D_MCAD22), (IEN | PTD | EN | M0)) /*d2d_mcad22*/\ + MUX_VAL(CP(D2D_MCAD23), (IEN | PTD | EN | M0)) /*d2d_mcad23*/\ + MUX_VAL(CP(D2D_MCAD24), (IEN | PTD | EN | M0)) /*d2d_mcad24*/\ + MUX_VAL(CP(D2D_MCAD25), (IEN | PTD | EN | M0)) /*d2d_mcad25*/\ + MUX_VAL(CP(D2D_MCAD26), (IEN | PTD | EN | M0)) /*d2d_mcad26*/\ + MUX_VAL(CP(D2D_MCAD27), (IEN | PTD | EN | M0)) /*d2d_mcad27*/\ + MUX_VAL(CP(D2D_MCAD28), (IEN | PTD | EN | M0)) /*d2d_mcad28*/\ + MUX_VAL(CP(D2D_MCAD29), (IEN | PTD | EN | M0)) /*d2d_mcad29*/\ + MUX_VAL(CP(D2D_MCAD30), (IEN | PTD | EN | M0)) /*d2d_mcad30*/\ + MUX_VAL(CP(D2D_MCAD31), (IEN | PTD | EN | M0)) /*d2d_mcad31*/\ + MUX_VAL(CP(D2D_MCAD32), (IEN | PTD | EN | M0)) /*d2d_mcad32*/\ + MUX_VAL(CP(D2D_MCAD33), (IEN | PTD | EN | M0)) /*d2d_mcad33*/\ + MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0)) /*d2d_mcad34*/\ + MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0)) /*d2d_mcad35*/\ + MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0)) /*d2d_mcad36*/\ + MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0)) /*d2d_clk26mi*/\ + MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0)) /*d2d_nrespwron*/\ + MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0)) /*d2d_nreswarm */\ + MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0)) /*d2d_arm9nirq */\ + MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0)) /*d2d_uma2p6fiq*/\ + MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0)) /*d2d_spint*/\ + MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0)) /*d2d_frint*/\ + MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0)) /*d2d_dmareq0*/\ + MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0)) /*d2d_dmareq1*/\ + MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0)) /*d2d_dmareq2*/\ + MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0)) /*d2d_dmareq3*/\ + MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0)) /*d2d_n3gtrst*/\ + MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0)) /*d2d_n3gtdi*/\ + MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0)) /*d2d_n3gtdo*/\ + MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0)) /*d2d_n3gtms*/\ + MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0)) /*d2d_n3gtck*/\ + MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0)) /*d2d_n3grtck*/\ + MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0)) /*d2d_mstdby*/\ + MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0)) /*d2d_swakeup*/\ + MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0)) /*d2d_idlereq*/\ + MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0)) /*d2d_idleack*/\ + MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0)) /*d2d_mwrite*/\ + MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0)) /*d2d_swrite*/\ + MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0)) /*d2d_mread*/\ + MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0)) /*d2d_sread*/\ + MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0)) /*d2d_mbusflag*/\ + MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0)) /*d2d_sbusflag*/\ + MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) /*sdrc_cke0*/\ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | EN | M0)) /*sdrc_cke1*/ + +/* + * Routine: get_board_revision + * Description: Returns the board revision + */ +int get_board_revision(void) +{ + int revision; + +#ifdef CONFIG_SYS_I2C_OMAP34XX + unsigned char data; + + /* board revisions <= R2410 connect 4030 irq_1 to gpio112 */ + /* these boards should return a revision number of 0 */ + /* the code below forces a 4030 RTC irq to ensure that gpio112 is low */ + i2c_set_bus_num(TWL4030_I2C_BUS); + data = 0x01; + i2c_write(0x4B, 0x29, 1, &data, 1); + data = 0x0c; + i2c_write(0x4B, 0x2b, 1, &data, 1); + i2c_read(0x4B, 0x2a, 1, &data, 1); +#endif + + if (!gpio_request(112, "") && + !gpio_request(113, "") && + !gpio_request(115, "")) { + + gpio_direction_input(112); + gpio_direction_input(113); + gpio_direction_input(115); + + revision = gpio_get_value(115) << 2 | + gpio_get_value(113) << 1 | + gpio_get_value(112); + } else { + puts("Error: unable to acquire board revision GPIOs\n"); + revision = -1; + } + + return revision; +} + +/* + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers specific to the + * hardware. Many pins need to be moved from protect to primary + * mode. + */ +void set_muxconf_regs(void) +{ + MUX_OVERO(); +} diff --git a/board/overo/overo.c b/board/overo/overo.c index b7f85e7..95658be 100644 --- a/board/overo/overo.c +++ b/board/overo/overo.c @@ -79,106 +79,6 @@ U_BOOT_DEVICE(overo_uart) = { };
/* - * Routine: board_init - * Description: Early hardware init. - */ -int board_init(void) -{ - gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ - /* board id for Linux */ - gd->bd->bi_arch_number = MACH_TYPE_OVERO; - /* boot param addr */ - gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); - - return 0; -} - -/* - * Routine: get_board_revision - * Description: Returns the board revision - */ -int get_board_revision(void) -{ - int revision; - -#ifdef CONFIG_SYS_I2C_OMAP34XX - unsigned char data; - - /* board revisions <= R2410 connect 4030 irq_1 to gpio112 */ - /* these boards should return a revision number of 0 */ - /* the code below forces a 4030 RTC irq to ensure that gpio112 is low */ - i2c_set_bus_num(TWL4030_I2C_BUS); - data = 0x01; - i2c_write(0x4B, 0x29, 1, &data, 1); - data = 0x0c; - i2c_write(0x4B, 0x2b, 1, &data, 1); - i2c_read(0x4B, 0x2a, 1, &data, 1); -#endif - - if (!gpio_request(112, "") && - !gpio_request(113, "") && - !gpio_request(115, "")) { - - gpio_direction_input(112); - gpio_direction_input(113); - gpio_direction_input(115); - - revision = gpio_get_value(115) << 2 | - gpio_get_value(113) << 1 | - gpio_get_value(112); - } else { - puts("Error: unable to acquire board revision GPIOs\n"); - revision = -1; - } - - return revision; -} - -#ifdef CONFIG_SPL_BUILD -/* - * Routine: get_board_mem_timings - * Description: If we use SPL then there is no x-loader nor config header - * so we have to setup the DDR timings ourself on both banks. - */ -void get_board_mem_timings(struct board_sdrc_timings *timings) -{ - timings->mr = MICRON_V_MR_165; - switch (get_board_revision()) { - case REVISION_0: /* Micron 1286MB/256MB, 1/2 banks of 128MB */ - timings->mcfg = MICRON_V_MCFG_165(128 << 20); - timings->ctrla = MICRON_V_ACTIMA_165; - timings->ctrlb = MICRON_V_ACTIMB_165; - timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; - break; - case REVISION_1: /* Micron 256MB/512MB, 1/2 banks of 256MB */ - case REVISION_4: - timings->mcfg = MICRON_V_MCFG_200(256 << 20); - timings->ctrla = MICRON_V_ACTIMA_200; - timings->ctrlb = MICRON_V_ACTIMB_200; - timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; - break; - case REVISION_2: /* Hynix 256MB/512MB, 1/2 banks of 256MB */ - timings->mcfg = HYNIX_V_MCFG_200(256 << 20); - timings->ctrla = HYNIX_V_ACTIMA_200; - timings->ctrlb = HYNIX_V_ACTIMB_200; - timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; - break; - case REVISION_3: /* Micron 512MB/1024MB, 1/2 banks of 512MB */ - timings->mcfg = MCFG(512 << 20, 15); - timings->ctrla = MICRON_V_ACTIMA_200; - timings->ctrlb = MICRON_V_ACTIMB_200; - timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; - break; - default: - timings->mcfg = MICRON_V_MCFG_165(128 << 20); - timings->ctrla = MICRON_V_ACTIMA_165; - timings->ctrlb = MICRON_V_ACTIMB_165; - timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; - } -} -#endif - -/* * Routine: get_sdio2_config * Description: Return information about the wifi module connection * Returns 0 if the module connects though a level translator @@ -392,18 +292,7 @@ int misc_init_r(void) return 0; }
-/* - * Routine: set_muxconf_regs - * Description: Setting up the configuration Mux registers specific to the - * hardware. Many pins need to be moved from protect to primary - * mode. - */ -void set_muxconf_regs(void) -{ - MUX_OVERO(); -} - -#if defined(CONFIG_CMD_NET) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_CMD_NET) /* GPMC definitions for LAN9221 chips on Tobi expansion boards */ static const u32 gpmc_lan_config[] = { NET_LAN9221_GPMC_CONFIG1, @@ -486,7 +375,7 @@ int board_eth_init(bd_t *bis) } #endif
-#if defined(CONFIG_GENERIC_MMC) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_GENERIC_MMC) int board_mmc_init(bd_t *bis) { return omap_mmc_init(0, 0, 0, -1, -1); @@ -500,7 +389,7 @@ void board_mmc_power_init(void) } #endif
-#if defined(CONFIG_USB_EHCI) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_USB_EHCI) static struct omap_usbhs_board_data usbhs_bdata = { .port_mode[0] = OMAP_USBHS_PORT_MODE_UNUSED, .port_mode[1] = OMAP_EHCI_PORT_MODE_PHY, diff --git a/board/overo/overo.h b/board/overo/overo.h index d0edf86..bbe16d5 100644 --- a/board/overo/overo.h +++ b/board/overo/overo.h @@ -17,6 +17,8 @@ const omap3_sysinfo sysinfo = { #endif };
+int get_board_revision(void); + /* overo revisions */ #define REVISION_0 0x0 #define REVISION_1 0x1 @@ -34,270 +36,6 @@ const omap3_sysinfo sysinfo = { * M0 - Mode 0 * The commented string gives the final mux configuration for that pin */ -#define MUX_OVERO() \ - /*SDRC*/\ - MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) /*SDRC_D0*/\ - MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) /*SDRC_D1*/\ - MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) /*SDRC_D2*/\ - MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) /*SDRC_D3*/\ - MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) /*SDRC_D4*/\ - MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) /*SDRC_D5*/\ - MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) /*SDRC_D6*/\ - MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) /*SDRC_D7*/\ - MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) /*SDRC_D8*/\ - MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) /*SDRC_D9*/\ - MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) /*SDRC_D10*/\ - MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) /*SDRC_D11*/\ - MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) /*SDRC_D12*/\ - MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) /*SDRC_D13*/\ - MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) /*SDRC_D14*/\ - MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) /*SDRC_D15*/\ - MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) /*SDRC_D16*/\ - MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) /*SDRC_D17*/\ - MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) /*SDRC_D18*/\ - MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) /*SDRC_D19*/\ - MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) /*SDRC_D20*/\ - MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) /*SDRC_D21*/\ - MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) /*SDRC_D22*/\ - MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) /*SDRC_D23*/\ - MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) /*SDRC_D24*/\ - MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) /*SDRC_D25*/\ - MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) /*SDRC_D26*/\ - MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) /*SDRC_D27*/\ - MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) /*SDRC_D28*/\ - MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) /*SDRC_D29*/\ - MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) /*SDRC_D30*/\ - MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) /*SDRC_D31*/\ - MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) /*SDRC_CLK*/\ - MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) /*SDRC_DQS0*/\ - MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) /*SDRC_DQS1*/\ - MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) /*SDRC_DQS2*/\ - MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) /*SDRC_DQS3*/\ - /*GPMC*/\ - MUX_VAL(CP(GPMC_A1), (IDIS | PTU | EN | M0)) /*GPMC_A1*/\ - MUX_VAL(CP(GPMC_A2), (IDIS | PTU | EN | M0)) /*GPMC_A2*/\ - MUX_VAL(CP(GPMC_A3), (IDIS | PTU | EN | M0)) /*GPMC_A3*/\ - MUX_VAL(CP(GPMC_A4), (IDIS | PTU | EN | M0)) /*GPMC_A4*/\ - MUX_VAL(CP(GPMC_A5), (IDIS | PTU | EN | M0)) /*GPMC_A5*/\ - MUX_VAL(CP(GPMC_A6), (IDIS | PTU | EN | M0)) /*GPMC_A6*/\ - MUX_VAL(CP(GPMC_A7), (IDIS | PTU | EN | M0)) /*GPMC_A7*/\ - MUX_VAL(CP(GPMC_A8), (IDIS | PTU | EN | M0)) /*GPMC_A8*/\ - MUX_VAL(CP(GPMC_A9), (IDIS | PTU | EN | M0)) /*GPMC_A9*/\ - MUX_VAL(CP(GPMC_A10), (IDIS | PTU | EN | M0)) /*GPMC_A10*/\ - MUX_VAL(CP(GPMC_D0), (IEN | PTU | EN | M0)) /*GPMC_D0*/\ - MUX_VAL(CP(GPMC_D1), (IEN | PTU | EN | M0)) /*GPMC_D1*/\ - MUX_VAL(CP(GPMC_D2), (IEN | PTU | EN | M0)) /*GPMC_D2*/\ - MUX_VAL(CP(GPMC_D3), (IEN | PTU | EN | M0)) /*GPMC_D3*/\ - MUX_VAL(CP(GPMC_D4), (IEN | PTU | EN | M0)) /*GPMC_D4*/\ - MUX_VAL(CP(GPMC_D5), (IEN | PTU | EN | M0)) /*GPMC_D5*/\ - MUX_VAL(CP(GPMC_D6), (IEN | PTU | EN | M0)) /*GPMC_D6*/\ - MUX_VAL(CP(GPMC_D7), (IEN | PTU | EN | M0)) /*GPMC_D7*/\ - MUX_VAL(CP(GPMC_D8), (IEN | PTU | EN | M0)) /*GPMC_D8*/\ - MUX_VAL(CP(GPMC_D9), (IEN | PTU | EN | M0)) /*GPMC_D9*/\ - MUX_VAL(CP(GPMC_D10), (IEN | PTU | EN | M0)) /*GPMC_D10*/\ - MUX_VAL(CP(GPMC_D11), (IEN | PTU | EN | M0)) /*GPMC_D11*/\ - MUX_VAL(CP(GPMC_D12), (IEN | PTU | EN | M0)) /*GPMC_D12*/\ - MUX_VAL(CP(GPMC_D13), (IEN | PTU | EN | M0)) /*GPMC_D13*/\ - MUX_VAL(CP(GPMC_D14), (IEN | PTU | EN | M0)) /*GPMC_D14*/\ - MUX_VAL(CP(GPMC_D15), (IEN | PTU | EN | M0)) /*GPMC_D15*/\ - MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) /*GPMC_nCS0*/\ - MUX_VAL(CP(GPMC_NCS2), (IDIS | PTU | EN | M0)) /*GPMC_nCS2*/\ - MUX_VAL(CP(GPMC_NCS3), (IEN | PTU | EN | M4)) /*GPIO_54*/\ - /* - MMC1_WP*/\ - MUX_VAL(CP(GPMC_NCS7), (IEN | PTU | EN | M0)) /*GPMC_nCS7*/\ - MUX_VAL(CP(GPMC_NBE1), (IEN | PTD | DIS | M0)) /*GPMC_nCS3*/\ - MUX_VAL(CP(GPMC_CLK), (IEN | PTU | EN | M0)) /*GPMC_CLK*/\ - MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) /*GPMC_nADV_ALE*/\ - MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) /*GPMC_nOE*/\ - MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) /*GPMC_nWE*/\ - MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTD | DIS | M0)) /*GPMC_nBE0_CLE*/\ - MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) /*GPMC_nWP*/\ - MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) /*GPMC_WAIT0*/\ - /*CAMERA*/\ - MUX_VAL(CP(CAM_HS), (IEN | PTU | DIS | M0)) /*CAM_HS */\ - MUX_VAL(CP(CAM_VS), (IEN | PTU | DIS | M0)) /*CAM_VS */\ - MUX_VAL(CP(CAM_XCLKA), (IDIS | PTD | DIS | M0)) /*CAM_XCLKA*/\ - MUX_VAL(CP(CAM_PCLK), (IEN | PTU | DIS | M0)) /*CAM_PCLK*/\ - MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M0)) /*CAM_D0*/\ - MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M0)) /*CAM_D1*/\ - MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M0)) /*CAM_D2*/\ - MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M0)) /*CAM_D3*/\ - MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M0)) /*CAM_D4*/\ - MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M0)) /*CAM_D5*/\ - MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M0)) /*CAM_D6*/\ - MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M0)) /*CAM_D7*/\ - MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M0)) /*CAM_D8*/\ - MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M0)) /*CAM_D9*/\ - MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M0)) /*CAM_D10*/\ - MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M0)) /*CAM_D11*/\ - MUX_VAL(CP(CSI2_DX0), (IEN | PTD | EN | M4)) /*GPIO_112*/\ - MUX_VAL(CP(CSI2_DY0), (IEN | PTD | EN | M4)) /*GPIO_113*/\ - MUX_VAL(CP(CSI2_DY1), (IEN | PTD | EN | M4)) /*GPIO_115*/\ - /*Audio Interface */\ - MUX_VAL(CP(MCBSP2_FSX), (IEN | PTD | DIS | M0)) /*McBSP2_FSX*/\ - MUX_VAL(CP(MCBSP2_CLKX), (IEN | PTD | DIS | M0)) /*McBSP2_CLKX*/\ - MUX_VAL(CP(MCBSP2_DR), (IEN | PTD | DIS | M0)) /*McBSP2_DR*/\ - MUX_VAL(CP(MCBSP2_DX), (IDIS | PTD | DIS | M0)) /*McBSP2_DX*/\ - /*Expansion card */\ - MUX_VAL(CP(MMC1_CLK), (IEN | PTU | EN | M0)) /*MMC1_CLK*/\ - MUX_VAL(CP(MMC1_CMD), (IEN | PTU | EN | M0)) /*MMC1_CMD*/\ - MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | EN | M0)) /*MMC1_DAT0*/\ - MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | EN | M0)) /*MMC1_DAT1*/\ - MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | EN | M0)) /*MMC1_DAT2*/\ - MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | EN | M0)) /*MMC1_DAT3*/\ - MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M0)) /*MMC1_DAT4*/\ - MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M0)) /*MMC1_DAT5*/\ - MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M0)) /*MMC1_DAT6*/\ - MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M0)) /*MMC1_DAT7*/\ - /*Wireless LAN */\ - MUX_VAL(CP(MMC2_CLK), (IEN | PTU | EN | M4)) /*GPIO_130*/\ - MUX_VAL(CP(MMC2_CMD), (IEN | PTU | EN | M0)) /*MMC2_CMD*/\ - MUX_VAL(CP(MMC2_DAT0), (IEN | PTU | EN | M0)) /*MMC2_DAT0*/\ - MUX_VAL(CP(MMC2_DAT1), (IEN | PTU | EN | M0)) /*MMC2_DAT1*/\ - MUX_VAL(CP(MMC2_DAT2), (IEN | PTU | EN | M0)) /*MMC2_DAT2*/\ - MUX_VAL(CP(MMC2_DAT3), (IEN | PTU | EN | M0)) /*MMC2_DAT3*/\ - MUX_VAL(CP(MMC2_DAT4), (IEN | PTU | EN | M1)) /*MMC2_DIR_DAT0*/\ - MUX_VAL(CP(MMC2_DAT5), (IEN | PTU | EN | M1)) /*MMC2_DIR_DAT1*/\ - MUX_VAL(CP(MMC2_DAT6), (IEN | PTU | EN | M1)) /*MMC2_DIR_CMD*/\ - MUX_VAL(CP(MMC2_DAT7), (IEN | PTU | EN | M4)) /*GPIO_139*/\ - /*Bluetooth*/\ - MUX_VAL(CP(MCBSP3_DX), (IEN | PTD | DIS | M1)) /*UART2_CTS*/\ - MUX_VAL(CP(MCBSP3_DR), (IDIS | PTD | DIS | M1)) /*UART2_RTS*/\ - MUX_VAL(CP(MCBSP3_CLKX), (IDIS | PTD | DIS | M1)) /*UART2_TX*/\ - MUX_VAL(CP(MCBSP3_FSX), (IEN | PTD | DIS | M1)) /*UART2_RX*/\ - MUX_VAL(CP(UART1_RTS), (IEN | PTU | DIS | M4)) /*GPIO_149*/ \ - MUX_VAL(CP(MCBSP4_CLKX), (IEN | PTD | DIS | M0)) /*McBSP4_CLKX*/\ - MUX_VAL(CP(MCBSP4_DR), (IEN | PTD | DIS | M0)) /*McBSP4_DR*/\ - MUX_VAL(CP(MCBSP4_DX), (IEN | PTD | DIS | M0)) /*McBSP4_DX*/\ - MUX_VAL(CP(MCBSP4_FSX), (IEN | PTD | DIS | M0)) /*McBSP4_FSX*/\ - MUX_VAL(CP(MCBSP1_CLKR), (IEN | PTD | DIS | M0)) /*McBSP1_CLKR*/\ - MUX_VAL(CP(MCBSP1_FSR), (IEN | PTD | DIS | M0)) /*McBSP1_FSR*/\ - MUX_VAL(CP(MCBSP1_DX), (IEN | PTD | DIS | M0)) /*McBSP1_DX*/\ - MUX_VAL(CP(MCBSP1_DR), (IEN | PTD | DIS | M0)) /*McBSP1_DR*/\ - MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) /*McBSP_CLKS*/\ - MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | DIS | M0)) /*McBSP1_FSX*/\ - MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTD | DIS | M0)) /*McBSP1_CLKX*/\ - /*Serial Interface*/\ - MUX_VAL(CP(UART3_RTS_SD), (IEN | PTU | EN | M4)) /*GPIO_164 W2W_*/\ - /* BT_NRESET*/\ - MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTU | EN | M0)) /*UART3_RX_IRRX*/\ - MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) /*UART3_TX_IRTX*/\ - MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) /*HSUSB0_CLK*/\ - MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) /*HSUSB0_STP*/\ - MUX_VAL(CP(HSUSB0_DIR), (IEN | PTD | DIS | M0)) /*HSUSB0_DIR*/\ - MUX_VAL(CP(HSUSB0_NXT), (IEN | PTD | DIS | M0)) /*HSUSB0_NXT*/\ - MUX_VAL(CP(HSUSB0_DATA0), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA0*/\ - MUX_VAL(CP(HSUSB0_DATA1), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA1*/\ - MUX_VAL(CP(HSUSB0_DATA2), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA2*/\ - MUX_VAL(CP(HSUSB0_DATA3), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA3*/\ - MUX_VAL(CP(HSUSB0_DATA4), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA4*/\ - MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA5*/\ - MUX_VAL(CP(HSUSB0_DATA6), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA6*/\ - MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA7*/\ - MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) /*I2C1_SCL*/\ - MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) /*I2C1_SDA*/\ - MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M4)) /*GPIO_168*/\ - /* - USBH_CPEN*/\ - MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M4)) /*GPIO_183*/\ - /* - USBH_RESET*/\ - MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0)) /*I2C3_SCL*/\ - MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0)) /*I2C3_SDA*/\ - MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) /*I2C4_SCL*/\ - MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0)) /*I2C4_SDA*/\ - MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA2*/\ - MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA7*/\ - MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA4*/\ - MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA5*/\ - MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA6*/\ - MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA3*/\ - /*Control and debug */\ - MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) /*SYS_32K*/\ - MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) /*SYS_CLKREQ*/\ - MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) /*SYS_nIRQ*/\ - MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /*GPIO_2*/\ - MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /*GPIO_3 */\ - MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /*GPIO_4 - MMC1_WP*/\ - MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4)) /*GPIO_5*/\ - MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4)) /*GPIO_6*/\ - MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /*GPIO_7*/\ - MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4)) /*GPIO_8*/\ - MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) /*SYS_OFF_MODE*/\ - MUX_VAL(CP(ETK_D1_ES2), (IEN | PTD | EN | M4)) /*GPIO_15 - X_GATE*/\ - MUX_VAL(CP(ETK_D2_ES2), (IEN | PTU | EN | M4)) /*GPIO_16*/\ - /* - W2W_NRESET*/\ - MUX_VAL(CP(ETK_D10_ES2), (IDIS | PTD | DIS | M3)) /*HSUSB2_CLK*/\ - MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTD | DIS | M3)) /*HSUSB2_STP*/\ - MUX_VAL(CP(ETK_D12_ES2), (IEN | PTD | DIS | M3)) /*HSUSB2_DIR*/\ - MUX_VAL(CP(ETK_D13_ES2), (IEN | PTD | DIS | M3)) /*HSUSB2_NXT*/\ - MUX_VAL(CP(ETK_D14_ES2), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA0*/\ - MUX_VAL(CP(ETK_D15_ES2), (IEN | PTD | DIS | M3)) /*HSUSB2_DATA1*/\ - /* die to die */\ - MUX_VAL(CP(D2D_MCAD1), (IEN | PTD | EN | M0)) /*d2d_mcad1*/\ - MUX_VAL(CP(D2D_MCAD2), (IEN | PTD | EN | M0)) /*d2d_mcad2*/\ - MUX_VAL(CP(D2D_MCAD3), (IEN | PTD | EN | M0)) /*d2d_mcad3*/\ - MUX_VAL(CP(D2D_MCAD4), (IEN | PTD | EN | M0)) /*d2d_mcad4*/\ - MUX_VAL(CP(D2D_MCAD5), (IEN | PTD | EN | M0)) /*d2d_mcad5*/\ - MUX_VAL(CP(D2D_MCAD6), (IEN | PTD | EN | M0)) /*d2d_mcad6*/\ - MUX_VAL(CP(D2D_MCAD7), (IEN | PTD | EN | M0)) /*d2d_mcad7*/\ - MUX_VAL(CP(D2D_MCAD8), (IEN | PTD | EN | M0)) /*d2d_mcad8*/\ - MUX_VAL(CP(D2D_MCAD9), (IEN | PTD | EN | M0)) /*d2d_mcad9*/\ - MUX_VAL(CP(D2D_MCAD10), (IEN | PTD | EN | M0)) /*d2d_mcad10*/\ - MUX_VAL(CP(D2D_MCAD11), (IEN | PTD | EN | M0)) /*d2d_mcad11*/\ - MUX_VAL(CP(D2D_MCAD12), (IEN | PTD | EN | M0)) /*d2d_mcad12*/\ - MUX_VAL(CP(D2D_MCAD13), (IEN | PTD | EN | M0)) /*d2d_mcad13*/\ - MUX_VAL(CP(D2D_MCAD14), (IEN | PTD | EN | M0)) /*d2d_mcad14*/\ - MUX_VAL(CP(D2D_MCAD15), (IEN | PTD | EN | M0)) /*d2d_mcad15*/\ - MUX_VAL(CP(D2D_MCAD16), (IEN | PTD | EN | M0)) /*d2d_mcad16*/\ - MUX_VAL(CP(D2D_MCAD17), (IEN | PTD | EN | M0)) /*d2d_mcad17*/\ - MUX_VAL(CP(D2D_MCAD18), (IEN | PTD | EN | M0)) /*d2d_mcad18*/\ - MUX_VAL(CP(D2D_MCAD19), (IEN | PTD | EN | M0)) /*d2d_mcad19*/\ - MUX_VAL(CP(D2D_MCAD20), (IEN | PTD | EN | M0)) /*d2d_mcad20*/\ - MUX_VAL(CP(D2D_MCAD21), (IEN | PTD | EN | M0)) /*d2d_mcad21*/\ - MUX_VAL(CP(D2D_MCAD22), (IEN | PTD | EN | M0)) /*d2d_mcad22*/\ - MUX_VAL(CP(D2D_MCAD23), (IEN | PTD | EN | M0)) /*d2d_mcad23*/\ - MUX_VAL(CP(D2D_MCAD24), (IEN | PTD | EN | M0)) /*d2d_mcad24*/\ - MUX_VAL(CP(D2D_MCAD25), (IEN | PTD | EN | M0)) /*d2d_mcad25*/\ - MUX_VAL(CP(D2D_MCAD26), (IEN | PTD | EN | M0)) /*d2d_mcad26*/\ - MUX_VAL(CP(D2D_MCAD27), (IEN | PTD | EN | M0)) /*d2d_mcad27*/\ - MUX_VAL(CP(D2D_MCAD28), (IEN | PTD | EN | M0)) /*d2d_mcad28*/\ - MUX_VAL(CP(D2D_MCAD29), (IEN | PTD | EN | M0)) /*d2d_mcad29*/\ - MUX_VAL(CP(D2D_MCAD30), (IEN | PTD | EN | M0)) /*d2d_mcad30*/\ - MUX_VAL(CP(D2D_MCAD31), (IEN | PTD | EN | M0)) /*d2d_mcad31*/\ - MUX_VAL(CP(D2D_MCAD32), (IEN | PTD | EN | M0)) /*d2d_mcad32*/\ - MUX_VAL(CP(D2D_MCAD33), (IEN | PTD | EN | M0)) /*d2d_mcad33*/\ - MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0)) /*d2d_mcad34*/\ - MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0)) /*d2d_mcad35*/\ - MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0)) /*d2d_mcad36*/\ - MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0)) /*d2d_clk26mi*/\ - MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0)) /*d2d_nrespwron*/\ - MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0)) /*d2d_nreswarm */\ - MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0)) /*d2d_arm9nirq */\ - MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0)) /*d2d_uma2p6fiq*/\ - MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0)) /*d2d_spint*/\ - MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0)) /*d2d_frint*/\ - MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0)) /*d2d_dmareq0*/\ - MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0)) /*d2d_dmareq1*/\ - MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0)) /*d2d_dmareq2*/\ - MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0)) /*d2d_dmareq3*/\ - MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0)) /*d2d_n3gtrst*/\ - MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0)) /*d2d_n3gtdi*/\ - MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0)) /*d2d_n3gtdo*/\ - MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0)) /*d2d_n3gtms*/\ - MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0)) /*d2d_n3gtck*/\ - MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0)) /*d2d_n3grtck*/\ - MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0)) /*d2d_mstdby*/\ - MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0)) /*d2d_swakeup*/\ - MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0)) /*d2d_idlereq*/\ - MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0)) /*d2d_idleack*/\ - MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0)) /*d2d_mwrite*/\ - MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0)) /*d2d_swrite*/\ - MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0)) /*d2d_mread*/\ - MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0)) /*d2d_sread*/\ - MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0)) /*d2d_mbusflag*/\ - MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0)) /*d2d_sbusflag*/\ - MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) /*sdrc_cke0*/\ - MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | EN | M0)) /*sdrc_cke1*/ - #define MUX_GUMSTIX() \ /*GPMC*/\ MUX_VAL(CP(GPMC_NCS1), (IDIS | PTU | EN | M0)) /*GPMC_nCS1*/\ diff --git a/board/overo/spl.c b/board/overo/spl.c new file mode 100644 index 0000000..5af780e --- /dev/null +++ b/board/overo/spl.c @@ -0,0 +1,60 @@ +/* + * Maintainer : Steve Sakoman steve@sakoman.com + * + * Derived from Beagle Board, 3430 SDP, and OMAP3EVM code by + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim khasim@ti.com + * Sunil Kumar sunilsaini05@gmail.com + * Shashi Ranjan shashiranjanmca05@gmail.com + * + * (C) Copyright 2004-2008 + * Texas Instruments, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <asm/io.h> +#include <asm/arch/mem.h> +#include <asm/arch/sys_proto.h> +#include "overo.h" + +/* + * Routine: get_board_mem_timings + * Description: If we use SPL then there is no x-loader nor config header + * so we have to setup the DDR timings ourself on both banks. + */ +void get_board_mem_timings(struct board_sdrc_timings *timings) +{ + timings->mr = MICRON_V_MR_165; + switch (get_board_revision()) { + case REVISION_0: /* Micron 1286MB/256MB, 1/2 banks of 128MB */ + timings->mcfg = MICRON_V_MCFG_165(256 << 20); + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + break; + case REVISION_1: /* Micron 256MB/512MB, 1/2 banks of 256MB */ + case REVISION_4: + timings->mcfg = MICRON_V_MCFG_200(256 << 20); + timings->ctrla = MICRON_V_ACTIMA_200; + timings->ctrlb = MICRON_V_ACTIMB_200; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; + break; + case REVISION_2: /* Hynix 256MB/512MB, 1/2 banks of 256MB */ + timings->mcfg = HYNIX_V_MCFG_200(256 << 20); + timings->ctrla = HYNIX_V_ACTIMA_200; + timings->ctrlb = HYNIX_V_ACTIMB_200; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; + break; + case REVISION_3: /* Micron 512MB/1024MB, 1/2 banks of 512MB */ + timings->mcfg = MCFG(512 << 20, 15); + timings->ctrla = MICRON_V_ACTIMA_200; + timings->ctrlb = MICRON_V_ACTIMB_200; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; + break; + default: + timings->mcfg = MICRON_V_MCFG_165(128 << 20); + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + } +}
This is because the gd pointer is not set early enough anymore, such that the i2c_set_bus_num in get_board_revision can safely execute. This results in a console hang at SPL and the boot does not proceed.
This piece of code is anyway necessary only for really old Overo boards with revision numbers <= 2410 and not required for the newer boards. For these older boards, u-boot v2014.10 still works fine.
Signed-off-by: Arun Bharadwaj arun@gumstix.com --- board/overo/common.c | 14 -------------- 1 file changed, 14 deletions(-)
diff --git a/board/overo/common.c b/board/overo/common.c index bdfa5ca..f6f6792 100644 --- a/board/overo/common.c +++ b/board/overo/common.c @@ -310,20 +310,6 @@ int get_board_revision(void) { int revision;
-#ifdef CONFIG_SYS_I2C_OMAP34XX - unsigned char data; - - /* board revisions <= R2410 connect 4030 irq_1 to gpio112 */ - /* these boards should return a revision number of 0 */ - /* the code below forces a 4030 RTC irq to ensure that gpio112 is low */ - i2c_set_bus_num(TWL4030_I2C_BUS); - data = 0x01; - i2c_write(0x4B, 0x29, 1, &data, 1); - data = 0x0c; - i2c_write(0x4B, 0x2b, 1, &data, 1); - i2c_read(0x4B, 0x2a, 1, &data, 1); -#endif - if (!gpio_request(112, "") && !gpio_request(113, "") && !gpio_request(115, "")) {
Arun Bharadwaj
