[U-Boot] [PATCH] AT91: Use AT91_CPU_CLOCK in displays
Introduce AT91_CPU_CLOCK and use it for displaying the CPU speed in the LCD driver.
Also make AT91_MAIN_CLOCK and AT91_MASTER_CLOCK reflect the corresponding board clocks.
Signed-off-by: Stelian Pop stelian@popies.net --- common/lcd.c | 2 +- include/configs/at91cap9adk.h | 5 +++-- include/configs/at91sam9260ek.h | 6 ++++-- include/configs/at91sam9261ek.h | 5 +++-- include/configs/at91sam9263ek.h | 5 +++-- include/configs/at91sam9rlek.h | 5 +++-- 6 files changed, 17 insertions(+), 11 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index 25f8664..c6ced91 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -837,7 +837,7 @@ static void *lcd_logo (void)
sprintf (info, "%s CPU at %s MHz", AT91_CPU_NAME, - strmhz(temp, AT91_MAIN_CLOCK)); + strmhz(temp, AT91_CPU_CLOCK)); lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 3, (uchar *)info, strlen(info));
diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index fd06245..1dbd3a4 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -29,8 +29,9 @@
/* ARM asynchronous clock */ #define AT91_CPU_NAME "AT91CAP9" -#define AT91_MAIN_CLOCK 200000000 /* from 12 MHz crystal */ -#define AT91_MASTER_CLOCK 100000000 /* peripheral = main / 2 */ +#define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define AT91_MASTER_CLOCK 100000000 /* peripheral */ +#define AT91_CPU_CLOCK 200000000 /* cpu */ #define CFG_HZ 1000000 /* 1us resolution */
#define AT91_SLOW_CLOCK 32768 /* slow clock */ diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 41d1da3..cb8857a 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -28,8 +28,10 @@ #define __CONFIG_H
/* ARM asynchronous clock */ -#define AT91_MAIN_CLOCK 198656000 /* from 18.432 MHz crystal */ -#define AT91_MASTER_CLOCK 99328000 /* peripheral = main / 2 */ +#define AT91_CPU_NAME "AT91SAM9260" +#define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ +#define AT91_MASTER_CLOCK 100000000 /* peripheral */ +#define AT91_CPU_CLOCK 200000000 /* cpu */ #define CFG_HZ 1000000 /* 1us resolution */
#define AT91_SLOW_CLOCK 32768 /* slow clock */ diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 80c3b03..92e134d 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -29,8 +29,9 @@
/* ARM asynchronous clock */ #define AT91_CPU_NAME "AT91SAM9261" -#define AT91_MAIN_CLOCK 198656000 /* from 18.432 MHz crystal */ -#define AT91_MASTER_CLOCK 99328000 /* peripheral = main / 2 */ +#define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ +#define AT91_MASTER_CLOCK 100000000 /* peripheral */ +#define AT91_CPU_CLOCK 200000000 /* cpu */ #define CFG_HZ 1000000 /* 1us resolution */
#define AT91_SLOW_CLOCK 32768 /* slow clock */ diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index b4368ef..c914571 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -29,8 +29,9 @@
/* ARM asynchronous clock */ #define AT91_CPU_NAME "AT91SAM9263" -#define AT91_MAIN_CLOCK 199919000 /* from 16.367 MHz crystal */ -#define AT91_MASTER_CLOCK 99959500 /* peripheral = main / 2 */ +#define AT91_MAIN_CLOCK 16367660 /* 16.367 MHz crystal */ +#define AT91_MASTER_CLOCK 100000000 /* peripheral */ +#define AT91_CPU_CLOCK 200000000 /* cpu */ #define CFG_HZ 1000000 /* 1us resolution */
#define AT91_SLOW_CLOCK 32768 /* slow clock */ diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 32168dc..9bcd2db 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -29,8 +29,9 @@
/* ARM asynchronous clock */ #define AT91_CPU_NAME "AT91SAM9RL" -#define AT91_MAIN_CLOCK 200000000 /* from 12.000 MHz crystal */ -#define AT91_MASTER_CLOCK 100000000 /* peripheral = main / 2 */ +#define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define AT91_MASTER_CLOCK 100000000 /* peripheral */ +#define AT91_CPU_CLOCK 200000000 /* cpu */ #define CFG_HZ 1000000 /* 1us resolution */
failed to apply
could you rebase it against u-boot-at91?
Best Regards, J.
Le jeudi 06 novembre 2008 à 20:29 +0100, Jean-Christophe PLAGNIOL-VILLARD a écrit :
failed to apply
Here it is.
Thanks,
Stelian.
From 5a769ae742ca62d451e412a77dbf31e691b755bf Mon Sep 17 00:00:00 2001
From: Stelian Pop stelian@popies.net Date: Thu, 6 Nov 2008 22:47:15 +0100 Subject: [PATCH] AT91: Use AT91_CPU_CLOCK in displays
Signed-off-by: Stelian Pop stelian@popies.net --- board/atmel/at91cap9adk/at91cap9adk.c | 2 +- board/atmel/at91sam9261ek/at91sam9261ek.c | 2 +- board/atmel/at91sam9263ek/at91sam9263ek.c | 2 +- board/atmel/at91sam9rlek/at91sam9rlek.c | 2 +- include/configs/at91cap9adk.h | 7 ++++--- include/configs/at91sam9260ek.h | 8 +++++--- include/configs/at91sam9261ek.h | 7 ++++--- include/configs/at91sam9263ek.h | 7 ++++--- include/configs/at91sam9rlek.h | 7 ++++--- 9 files changed, 25 insertions(+), 19 deletions(-)
diff --git a/board/atmel/at91cap9adk/at91cap9adk.c b/board/atmel/at91cap9adk/at91cap9adk.c index af145cc..f7d68b7 100644 --- a/board/atmel/at91cap9adk/at91cap9adk.c +++ b/board/atmel/at91cap9adk/at91cap9adk.c @@ -342,7 +342,7 @@ void lcd_show_board_info(void) lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", AT91_CPU_NAME, - strmhz(temp, AT91_MAIN_CLOCK)); + strmhz(temp, AT91_CPU_CLOCK));
dram_size = 0; for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index 185d6e1..14f236d 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -225,7 +225,7 @@ void lcd_show_board_info(void) lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", AT91_CPU_NAME, - strmhz(temp, AT91_MAIN_CLOCK)); + strmhz(temp, AT91_CPU_CLOCK));
dram_size = 0; for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index 4feed9a..ebd4649 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -276,7 +276,7 @@ void lcd_show_board_info(void) lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", AT91_CPU_NAME, - strmhz(temp, AT91_MAIN_CLOCK)); + strmhz(temp, AT91_CPU_CLOCK));
dram_size = 0; for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index 992dd4c..b6fef9d 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -197,7 +197,7 @@ void lcd_show_board_info(void) lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", AT91_CPU_NAME, - strmhz(temp, AT91_MAIN_CLOCK)); + strmhz(temp, AT91_CPU_CLOCK));
dram_size = 0; for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index 30a7cb4..667e049 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -29,9 +29,10 @@
/* ARM asynchronous clock */ #define AT91_CPU_NAME "AT91CAP9" -#define AT91_MAIN_CLOCK 200000000 /* from 12 MHz crystal */ -#define AT91_MASTER_CLOCK 100000000 /* peripheral = main / 2 */ -#define CONFIG_SYS_HZ 1000000 /* 1us resolution */ +#define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define AT91_MASTER_CLOCK 100000000 /* peripheral */ +#define AT91_CPU_CLOCK 200000000 /* cpu */ +#define CONFIG_SYS_HZ 1000000 /* 1us resolution */
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index be9a8eb..81c8d39 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -28,9 +28,11 @@ #define __CONFIG_H
/* ARM asynchronous clock */ -#define AT91_MAIN_CLOCK 198656000 /* from 18.432 MHz crystal */ -#define AT91_MASTER_CLOCK 99328000 /* peripheral = main / 2 */ -#define CONFIG_SYS_HZ 1000000 /* 1us resolution */ +#define AT91_CPU_NAME "AT91SAM9260" +#define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ +#define AT91_MASTER_CLOCK 100000000 /* peripheral */ +#define AT91_CPU_CLOCK 200000000 /* cpu */ +#define CONFIG_SYS_HZ 1000000 /* 1us resolution */
diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index add31c9..efe35a4 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -29,9 +29,10 @@
/* ARM asynchronous clock */ #define AT91_CPU_NAME "AT91SAM9261" -#define AT91_MAIN_CLOCK 198656000 /* from 18.432 MHz crystal */ -#define AT91_MASTER_CLOCK 99328000 /* peripheral = main / 2 */ -#define CONFIG_SYS_HZ 1000000 /* 1us resolution */ +#define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ +#define AT91_MASTER_CLOCK 100000000 /* peripheral */ +#define AT91_CPU_CLOCK 200000000 /* cpu */ +#define CONFIG_SYS_HZ 1000000 /* 1us resolution */
diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 555cb7f..ef5b666 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -29,9 +29,10 @@
/* ARM asynchronous clock */ #define AT91_CPU_NAME "AT91SAM9263" -#define AT91_MAIN_CLOCK 199919000 /* from 16.367 MHz crystal */ -#define AT91_MASTER_CLOCK 99959500 /* peripheral = main / 2 */ -#define CONFIG_SYS_HZ 1000000 /* 1us resolution */ +#define AT91_MAIN_CLOCK 16367660 /* 16.367 MHz crystal */ +#define AT91_MASTER_CLOCK 100000000 /* peripheral */ +#define AT91_CPU_CLOCK 200000000 /* cpu */ +#define CONFIG_SYS_HZ 1000000 /* 1us resolution */
diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 648d60e..35dac47 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -29,9 +29,10 @@
/* ARM asynchronous clock */ #define AT91_CPU_NAME "AT91SAM9RL" -#define AT91_MAIN_CLOCK 200000000 /* from 12.000 MHz crystal */ -#define AT91_MASTER_CLOCK 100000000 /* peripheral = main / 2 */ -#define CONFIG_SYS_HZ 1000000 /* 1us resolution */ +#define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define AT91_MASTER_CLOCK 100000000 /* peripheral */ +#define AT91_CPU_CLOCK 200000000 /* cpu */ +#define CONFIG_SYS_HZ 1000000 /* 1us resolution */
failed to apply
Here it is.
Thanks,
Stelian.
Applied to u-boot-at91
Best Regards, J.
Stelian Pop
