[U-Boot] [PATCH] ARM: rmobile: Fix eMMC signal voltage on Salvator-X/XS
The eMMC is 1V8 device only and the signaling is always 1V8, fix the DT for Salvator-X/XS to describe the hardware correctly.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- arch/arm/dts/salvator-common.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/salvator-common.dtsi b/arch/arm/dts/salvator-common.dtsi index ce06a7cbd5..74bb21e841 100644 --- a/arch/arm/dts/salvator-common.dtsi +++ b/arch/arm/dts/salvator-common.dtsi @@ -438,7 +438,7 @@ sdhi2_pins: sd2 { groups = "sdhi2_data8", "sdhi2_ctrl"; function = "sdhi2"; - power-source = <3300>; + power-source = <1800>; };
sdhi2_pins_uhs: sd2_uhs {
