[U-Boot] [PATCH v2 1/6] sf: eon|spansion|ramtron: Fix code cleanup
- line over 80 characters - insert the expression in same line
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- drivers/mtd/spi/eon.c | 3 +-- drivers/mtd/spi/ramtron.c | 6 ++++-- drivers/mtd/spi/spansion.c | 3 ++- 3 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/spi/eon.c b/drivers/mtd/spi/eon.c index b16e7ab..25cfc12 100644 --- a/drivers/mtd/spi/eon.c +++ b/drivers/mtd/spi/eon.c @@ -54,8 +54,7 @@ struct spi_flash *spi_flash_probe_eon(struct spi_slave *spi, u8 *idcode)
flash->page_size = 256; flash->sector_size = 256 * 16 * 16; - flash->size = 256 * 16 - * params->nr_sectors; + flash->size = 256 * 16 * params->nr_sectors;
return flash; } diff --git a/drivers/mtd/spi/ramtron.c b/drivers/mtd/spi/ramtron.c index f67ddd6..27e6411 100644 --- a/drivers/mtd/spi/ramtron.c +++ b/drivers/mtd/spi/ramtron.c @@ -230,7 +230,8 @@ struct spi_flash *spi_fram_probe_ramtron(struct spi_slave *spi, u8 *idcode) /* JEDEC conformant RAMTRON id */ for (i = 0; i < ARRAY_SIZE(ramtron_spi_fram_table); i++) { params = &ramtron_spi_fram_table[i]; - if (idcode[1] == params->id1 && idcode[2] == params->id2) + if (idcode[1] == params->id1 && + idcode[2] == params->id2) goto found; } break; @@ -251,7 +252,8 @@ struct spi_flash *spi_fram_probe_ramtron(struct spi_slave *spi, u8 *idcode) /* now find the device */ for (i = 0; i < ARRAY_SIZE(ramtron_spi_fram_table); i++) { params = &ramtron_spi_fram_table[i]; - if (!strcmp(params->name, CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC)) + if (!strcmp(params->name, + CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC)) goto found; } debug("SF: Unsupported non-JEDEC RAMTRON device " diff --git a/drivers/mtd/spi/spansion.c b/drivers/mtd/spi/spansion.c index 47a4897..b9a36c2 100644 --- a/drivers/mtd/spi/spansion.c +++ b/drivers/mtd/spi/spansion.c @@ -122,7 +122,8 @@ struct spi_flash *spi_flash_probe_spansion(struct spi_slave *spi, u8 *idcode) }
if (i == ARRAY_SIZE(spansion_spi_flash_table)) { - debug("SF: Unsupported SPANSION ID %04x %04x\n", jedec, ext_jedec); + debug("SF: Unsupported SPANSION ID %04x %04x\n", + jedec, ext_jedec); return NULL; }
