[PATCH v2 2/2] board: rockchip: add Pine64 QuartzPro64 RK3588 board
QuartzPro64 is a Rockchip RK3588 based SBC by Pine64.
UART and boot over SD/eMMC/RJ45 are tested to work.
Linux commits from next-20231013: 8152d3d070a9 ("arm64: dts: rockchip: Add QuartzPro64 SBC device tree")
Signed-off-by: Tom Fitzhenry tom@tom-fitzhenry.me.uk Cc: Eugen Hristev eugen.hristev@collabora.com Cc: Jonas Karlman jonas@kwiboo.se Cc: Ondrej Jirman megi@xff.cz ---
This patch depends on "rockchip: rk3588: Sync device tree from linux maintainer tree"[0], since the QuartzPro64 upstream DT depends on upstream dtsi changes.
0. https://lore.kernel.org/all/20231010222344.3436526-2-jonas@kwiboo.se --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi | 12 + arch/arm/dts/rk3588-quartzpro64.dts | 1137 +++++++++++++++++ arch/arm/mach-rockchip/rk3588/Kconfig | 8 + board/pine64/quartzpro64-rk3588/Kconfig | 15 + board/pine64/quartzpro64-rk3588/MAINTAINERS | 8 + board/pine64/quartzpro64-rk3588/Makefile | 3 + .../quartzpro64-rk3588/quartzpro64-rk3588.c | 39 + configs/quartzpro64-rk3588_defconfig | 72 ++ doc/board/rockchip/rockchip.rst | 1 + include/configs/quartzpro64-rk3588.h | 14 + 11 files changed, 1310 insertions(+) create mode 100644 arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-quartzpro64.dts create mode 100644 board/pine64/quartzpro64-rk3588/Kconfig create mode 100644 board/pine64/quartzpro64-rk3588/MAINTAINERS create mode 100644 board/pine64/quartzpro64-rk3588/Makefile create mode 100644 board/pine64/quartzpro64-rk3588/quartzpro64-rk3588.c create mode 100644 configs/quartzpro64-rk3588_defconfig create mode 100644 include/configs/quartzpro64-rk3588.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 4569483d5fd..6d1e33d9e2e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -191,6 +191,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3588) += \ rk3588-edgeble-neu6a-io.dtb \ rk3588-edgeble-neu6b-io.dtb \ rk3588-evb1-v10.dtb \ + rk3588-quartzpro64.dtb \ rk3588s-rock-5a.dtb \ rk3588-rock-5b.dtb
diff --git a/arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi b/arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi new file mode 100644 index 00000000000..191ec988c45 --- /dev/null +++ b/arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2023 Google, Inc + */ + +#include "rk3588-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; + }; +}; diff --git a/arch/arm/dts/rk3588-quartzpro64.dts b/arch/arm/dts/rk3588-quartzpro64.dts new file mode 100644 index 00000000000..5c59f9571dc --- /dev/null +++ b/arch/arm/dts/rk3588-quartzpro64.dts @@ -0,0 +1,1137 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Ondřej Jirman megi@xff.cz + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/usb/pd.h> +#include "rk3588.dtsi" + +/ { + model = "PINE64 QuartzPro64"; + compatible = "pine64,quartzpro64", "rockchip,rk3588"; + + aliases { + mmc0 = &sdhci; + mmc1 = &sdmmc; + serial2 = &uart2; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + adc-keys-0 { + compatible = "adc-keys"; + io-channels = <&saradc 0>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + poll-interval = <100>; + + button-maskrom { + label = "Mask Rom"; + linux,code = <KEY_SETUP>; + press-threshold-microvolt = <393>; + }; + }; + + adc-keys-1 { + compatible = "adc-keys"; + io-channels = <&saradc 1>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + poll-interval = <100>; + + button-volume-up { + label = "V+/REC"; + linux,code = <KEY_VOLUMEUP>; + press-threshold-microvolt = <17821>; + }; + + button-volume-down { + label = "V-"; + linux,code = <KEY_VOLUMEDOWN>; + press-threshold-microvolt = <415384>; + }; + + button-menu { + label = "MENU"; + linux,code = <KEY_MENU>; + press-threshold-microvolt = <890909>; + }; + + button-esc { + label = "ESC"; + linux,code = <KEY_ESC>; + press-threshold-microvolt = <1233962>; + }; + }; + + headphone_amp: audio-amplifier-headphone { + compatible = "simple-audio-amplifier"; + enable-gpios = <&gpio1 RK_PD2 GPIO_ACTIVE_HIGH>; + sound-name-prefix = "Headphones Amp"; + }; + + speaker_amp: audio-amplifier-speaker { + compatible = "simple-audio-amplifier"; + enable-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_HIGH>; + sound-name-prefix = "Speaker Amp"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins>; + + led-1 { + color = <LED_COLOR_ID_ORANGE>; + function = LED_FUNCTION_INDICATOR; + gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_HIGH>; + }; + }; + + sound { + compatible = "simple-audio-card"; + pinctrl-names = "default"; + pinctrl-0 = <&hp_detect>; + simple-audio-card,name = "Analog"; + simple-audio-card,aux-devs = <&speaker_amp>, <&headphone_amp>; + simple-audio-card,format = "i2s"; + simple-audio-card,mclk-fs = <256>; + simple-audio-card,hp-det-gpio = <&gpio1 RK_PD5 GPIO_ACTIVE_LOW>; + simple-audio-card,bitclock-master = <&daicpu>; + simple-audio-card,frame-master = <&daicpu>; + /* SARADC_IN3 is used as MIC detection / key input */ + + simple-audio-card,widgets = + "Microphone", "Onboard Microphone", + "Microphone", "Microphone Jack", + "Speaker", "Speaker", + "Headphone", "Headphones"; + + simple-audio-card,routing = + "Headphones", "LOUT1", + "Headphones", "ROUT1", + "Speaker", "LOUT2", + "Speaker", "ROUT2", + + "Headphones", "Headphones Amp OUTL", + "Headphones", "Headphones Amp OUTR", + "Headphones Amp INL", "LOUT1", + "Headphones Amp INR", "ROUT1", + + "Speaker", "Speaker Amp OUTL", + "Speaker", "Speaker Amp OUTR", + "Speaker Amp INL", "LOUT2", + "Speaker Amp INR", "ROUT2", + + /* single ended signal to LINPUT1 */ + "LINPUT1", "Microphone Jack", + "RINPUT1", "Microphone Jack", + /* differential signal */ + "LINPUT2", "Onboard Microphone", + "RINPUT2", "Onboard Microphone"; + + daicpu: simple-audio-card,cpu { + sound-dai = <&i2s0_8ch>; + system-clock-frequency = <12288000>; + }; + + daicodec: simple-audio-card,codec { + sound-dai = <&es8388>; + system-clock-frequency = <12288000>; + }; + }; + + vcc12v_dcin: vcc12v-dcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + vcc3v3_bt: vcc3v3-bt-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio3 RK_PA6 GPIO_ACTIVE_HIGH>; + regulator-name = "vcc3v3_bt"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <50000>; + vin-supply = <&vcc_3v3_s0>; + }; + + vcc3v3_pcie30: vcc3v3-pcie30-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio3 RK_PC3 GPIO_ACTIVE_HIGH>; + regulator-name = "vcc3v3_pcie30"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <5000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc3v3_wf: vcc3v3-wf-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio3 RK_PB1 GPIO_ACTIVE_HIGH>; + regulator-name = "vcc3v3_wf"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <50000>; + vin-supply = <&vcc_3v3_s0>; + }; + + vcc4v0_sys: vcc4v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc4v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <4000000>; + regulator-max-microvolt = <4000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc5v0_host: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PB0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_host_en>; + regulator-name = "vcc5v0_host"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_usb>; + }; + + vcc5v0_usb: vcc5v0-usb-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; +}; + +&combphy0_ps { + status = "okay"; +}; + +&combphy1_ps { + status = "okay"; +}; + +&combphy2_psu { + status = "okay"; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b2 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_b3 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&gmac0 { + clock_in_out = "output"; + phy-handle = <&rgmii_phy>; + phy-mode = "rgmii-rxid"; + pinctrl-names = "default"; + pinctrl-0 = <&gmac0_miim + &gmac0_tx_bus2 + &gmac0_rx_bus2 + &gmac0_rgmii_clk + &gmac0_rgmii_bus>; + rx_delay = <0x00>; + tx_delay = <0x43>; + status = "okay"; +}; + +&i2c2 { + status = "okay"; + + hym8563: rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-output-names = "hym8563"; + interrupt-parent = <&gpio0>; + interrupts = <RK_PD4 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + wakeup-source; + }; +}; + +&i2c7 { + status = "okay"; + + es8388: audio-codec@11 { + compatible = "everest,es8388"; + reg = <0x11>; + assigned-clocks = <&cru I2S0_8CH_MCLKOUT>; + assigned-clock-rates = <12288000>; + clocks = <&cru I2S0_8CH_MCLKOUT>; + clock-names = "mclk"; + AVDD-supply = <&avcc_1v8_codec_s0>; + DVDD-supply = <&avcc_1v8_codec_s0>; + HPVDD-supply = <&vcc_3v3_s0>; + PVDD-supply = <&vcc_3v3_s0>; + #sound-dai-cells = <0>; + }; +}; + +&i2s0_8ch { + pinctrl-names = "default"; + pinctrl-0 = <&i2s0_lrck + &i2s0_mclk + &i2s0_sclk + &i2s0_sdi0 + &i2s0_sdo0>; + status = "okay"; +}; + +&mdio0 { + rgmii_phy: ethernet-phy@1 { + /* RTL8211F */ + compatible = "ethernet-phy-id001c.c916"; + reg = <0x1>; + pinctrl-names = "default"; + pinctrl-0 = <&rtl8211f_rst>; + reset-assert-us = <20000>; + reset-deassert-us = <100000>; + reset-gpios = <&gpio4 RK_PB3 GPIO_ACTIVE_LOW>; + }; +}; + +&pinctrl { + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + leds { + led_pins: led-pins { + rockchip,pins = <3 RK_PB7 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + rtl8111 { + rtl8111_isolate: rtl8111-isolate { + rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + rtl8211f { + rtl8211f_rst: rtl8211f-rst { + rockchip,pins = <4 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + }; + + sound { + hp_detect: hp-detect { + rockchip,pins = <1 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + vcc5v0_host_en: vcc5v0-host-en { + rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +/* WIFI */ +&pcie2x1l0 { + reset-gpios = <&gpio4 RK_PA5 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_wf>; + status = "okay"; +}; + +/* GMAC1 */ +&pcie2x1l1 { + pinctrl-names = "default"; + pinctrl-0 = <&rtl8111_isolate>; + reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&pcie30phy { + status = "okay"; +}; + +&pcie3x4 { + reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie30>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcc_1v8_s0>; + status = "okay"; +}; + +&sata0 { + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + no-sdio; + no-sd; + non-removable; + max-frequency = <150000000>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; + disable-wp; + max-frequency = <150000000>; + no-sdio; + no-mmc; + sd-uhs-sdr104; + vmmc-supply = <&vcc_3v3_s3>; + vqmmc-supply = <&vccio_sd_s0>; + status = "okay"; +}; + +&spi2 { + assigned-clocks = <&cru CLK_SPI2>; + assigned-clock-rates = <200000000>; + num-cs = <2>; + status = "okay"; + + pmic@0 { + compatible = "rockchip,rk806"; + reg = <0x0>; + #gpio-cells = <2>; + gpio-controller; + interrupt-parent = <&gpio0>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, + <&rk806_dvs2_null>, <&rk806_dvs3_null>; + pinctrl-names = "default"; + spi-max-frequency = <1000000>; + + vcc1-supply = <&vcc4v0_sys>; + vcc2-supply = <&vcc4v0_sys>; + vcc3-supply = <&vcc4v0_sys>; + vcc4-supply = <&vcc4v0_sys>; + vcc5-supply = <&vcc4v0_sys>; + vcc6-supply = <&vcc4v0_sys>; + vcc7-supply = <&vcc4v0_sys>; + vcc8-supply = <&vcc4v0_sys>; + vcc9-supply = <&vcc4v0_sys>; + vcc10-supply = <&vcc4v0_sys>; + vcc11-supply = <&vcc_2v0_pldo_s3>; + vcc12-supply = <&vcc4v0_sys>; + vcc13-supply = <&vcc_1v1_nldo_s3>; + vcc14-supply = <&vcc_1v1_nldo_s3>; + vcca-supply = <&vcc4v0_sys>; + + rk806_dvs1_null: dvs1-null-pins { + pins = "gpio_pwrctrl1"; + function = "pin_fun0"; + }; + + rk806_dvs2_null: dvs2-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs3_null: dvs3-null-pins { + pins = "gpio_pwrctrl3"; + function = "pin_fun0"; + }; + + regulators { + vdd_gpu_s0: dcdc-reg1 { + regulator-name = "vdd_gpu_s0"; + regulator-boot-on; + regulator-enable-ramp-delay = <400>; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_npu_s0: dcdc-reg2 { + regulator-name = "vdd_npu_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_log_s0: dcdc-reg3 { + regulator-name = "vdd_log_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <750000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_vdenc_s0: dcdc-reg4 { + regulator-name = "vdd_vdenc_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + + }; + + vdd_gpu_mem_s0: dcdc-reg5 { + regulator-name = "vdd_gpu_mem_s0"; + regulator-boot-on; + regulator-enable-ramp-delay = <400>; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + + }; + + vdd_npu_mem_s0: dcdc-reg6 { + regulator-name = "vdd_npu_mem_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + + }; + + vcc_2v0_pldo_s3: dcdc-reg7 { + regulator-name = "vdd_2v0_pldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2000000>; + }; + }; + + vdd_vdenc_mem_s0: dcdc-reg8 { + regulator-name = "vdd_vdenc_mem_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd2_ddr_s3: dcdc-reg9 { + regulator-name = "vdd2_ddr_s3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v1_nldo_s3: dcdc-reg10 { + regulator-name = "vcc_1v1_nldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1100000>; + }; + }; + + avcc_1v8_s0: pldo-reg1 { + regulator-name = "avcc_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd1_1v8_ddr_s3: pldo-reg2 { + regulator-name = "vdd1_1v8_ddr_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + avcc_1v8_codec_s0: pldo-reg3 { + regulator-name = "avcc_1v8_codec_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3_s3: pldo-reg4 { + regulator-name = "vcc_3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vccio_sd_s0: pldo-reg5 { + regulator-name = "vccio_sd_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s3: pldo-reg6 { + regulator-name = "vcc_1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_0v75_s3: nldo-reg1 { + regulator-name = "vdd_0v75_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + /* reserved for LPDDR5, unused? */ + vdd2l_0v9_ddr_s3: nldo-reg2 { + regulator-name = "vdd2l_0v9_ddr_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vdd_0v75_hdmi_edp_s0: nldo-reg3 { + regulator-name = "vdd_0v75_hdmi_edp_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + avdd_0v75_s0: nldo-reg4 { + regulator-name = "avdd_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v85_s0: nldo-reg5 { + regulator-name = "vdd_0v85_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; + + pmic@1 { + compatible = "rockchip,rk806"; + reg = <0x01>; + #gpio-cells = <2>; + gpio-controller; + interrupt-parent = <&gpio0>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + pinctrl-0 = <&rk806_slave_dvs1_null>, <&rk806_slave_dvs2_null>, + <&rk806_slave_dvs3_null>; + pinctrl-names = "default"; + spi-max-frequency = <1000000>; + + vcc1-supply = <&vcc4v0_sys>; + vcc2-supply = <&vcc4v0_sys>; + vcc3-supply = <&vcc4v0_sys>; + vcc4-supply = <&vcc4v0_sys>; + vcc5-supply = <&vcc4v0_sys>; + vcc6-supply = <&vcc4v0_sys>; + vcc7-supply = <&vcc4v0_sys>; + vcc8-supply = <&vcc4v0_sys>; + vcc9-supply = <&vcc4v0_sys>; + vcc10-supply = <&vcc4v0_sys>; + vcc11-supply = <&vcc_2v0_pldo_s3>; + vcc12-supply = <&vcc4v0_sys>; + vcc13-supply = <&vcc_1v1_nldo_s3>; + vcc14-supply = <&vcc_2v0_pldo_s3>; + vcca-supply = <&vcc4v0_sys>; + + rk806_slave_dvs1_null: dvs1-null-pins { + pins = "gpio_pwrctrl1"; + function = "pin_fun0"; + }; + + rk806_slave_dvs2_null: dvs2-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_slave_dvs3_null: dvs3-null-pins { + pins = "gpio_pwrctrl3"; + function = "pin_fun0"; + }; + + regulators { + vdd_cpu_big1_s0: dcdc-reg1 { + regulator-name = "vdd_cpu_big1_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_big0_s0: dcdc-reg2 { + regulator-name = "vdd_cpu_big0_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_lit_s0: dcdc-reg3 { + regulator-name = "vdd_cpu_lit_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3_s0: dcdc-reg4 { + regulator-name = "vcc_3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_big1_mem_s0: dcdc-reg5 { + regulator-name = "vdd_cpu_big1_mem_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + + vdd_cpu_big0_mem_s0: dcdc-reg6 { + regulator-name = "vdd_cpu_big0_mem_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s0: dcdc-reg7 { + regulator-name = "vcc_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_lit_mem_s0: dcdc-reg8 { + regulator-name = "vdd_cpu_lit_mem_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vddq_ddr_s0: dcdc-reg9 { + regulator-name = "vddq_ddr_s0"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_ddr_s0: dcdc-reg10 { + regulator-name = "vdd_ddr_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <900000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + /* reserved, unused? */ + vcc_1v8_cam_s0: pldo-reg1 { + regulator-name = "vcc_1v8_cam_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + avdd1v8_ddr_pll_s0: pldo-reg2 { + regulator-name = "avdd1v8_ddr_pll_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_1v8_pll_s0: pldo-reg3 { + regulator-name = "vdd_1v8_pll_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + /* reserved, unused? */ + vcc_3v3_sd_s0: pldo-reg4 { + regulator-name = "vcc_3v3_sd_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + /* reserved, unused? */ + vcc_2v8_cam_s0: pldo-reg5 { + regulator-name = "vcc_2v8_cam_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + /* unused */ + pldo6_s3: pldo-reg6 { + regulator-name = "pldo6_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_0v75_pll_s0: nldo-reg1 { + regulator-name = "vdd_0v75_pll_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_ddr_pll_s0: nldo-reg2 { + regulator-name = "vdd_ddr_pll_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + avdd_0v85_s0: nldo-reg3 { + regulator-name = "avdd_0v85_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + /* reserved, unused */ + avdd_1v2_cam_s0: nldo-reg4 { + regulator-name = "avdd_1v2_cam_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + avdd_1v2_s0: nldo-reg5 { + regulator-name = "avdd_1v2_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&tsadc { + status = "okay"; +}; + +&u2phy2 { + status = "okay"; +}; + +&u2phy2_host { + phy-supply = <&vcc5v0_host>; + status = "okay"; +}; + +&u2phy3 { + status = "okay"; +}; + +&u2phy3_host { + phy-supply = <&vcc5v0_host>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2m0_xfer>; + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index 79fcc99b898..a0ebcdb2e84 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -80,6 +80,13 @@ config TARGET_ROCK5B_RK3588 USB PD over USB Type-C Size: 100mm x 72mm (Pico-ITX form factor)
+config TARGET_QUARTZPRO64_RK3588 + bool "Pine64 QuartzPro64 RK3588 board" + select BOARD_LATE_INIT + help + Pine64 QuartzPro64 is a Rockchip RK3588 based SBC (Single Board + Computer) by Pine64. + config ROCKCHIP_BOOT_MODE_REG default 0xfd588080
@@ -93,6 +100,7 @@ config SYS_MALLOC_F_LEN default 0x80000
source board/edgeble/neural-compute-module-6/Kconfig +source board/pine64/quartzpro64-rk3588/Kconfig source board/rockchip/evb_rk3588/Kconfig source board/radxa/rock5a-rk3588s/Kconfig source board/radxa/rock5b-rk3588/Kconfig diff --git a/board/pine64/quartzpro64-rk3588/Kconfig b/board/pine64/quartzpro64-rk3588/Kconfig new file mode 100644 index 00000000000..96aa7921d32 --- /dev/null +++ b/board/pine64/quartzpro64-rk3588/Kconfig @@ -0,0 +1,15 @@ +if TARGET_QUARTZPRO64_RK3588 + +config SYS_BOARD + default "quartzpro64-rk3588" + +config SYS_VENDOR + default "pine64" + +config SYS_CONFIG_NAME + default "quartzpro64-rk3588" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/pine64/quartzpro64-rk3588/MAINTAINERS b/board/pine64/quartzpro64-rk3588/MAINTAINERS new file mode 100644 index 00000000000..a7e944b7478 --- /dev/null +++ b/board/pine64/quartzpro64-rk3588/MAINTAINERS @@ -0,0 +1,8 @@ +QUARTZPRO64-RK3588 +M: Tom Fitzhenry tom@tom-fitzhenry.me.uk +S: Maintained +F: board/pine64/quartzpro64-rk3588 +F: include/configs/quartzpro64-rk3588.h +F: configs/quartzpro64-rk3588_defconfig +F: arch/arm/dts/rk3588-quartzpro64.dts +F: arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi diff --git a/board/pine64/quartzpro64-rk3588/Makefile b/board/pine64/quartzpro64-rk3588/Makefile new file mode 100644 index 00000000000..47819d9be93 --- /dev/null +++ b/board/pine64/quartzpro64-rk3588/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += quartzpro64-rk3588.o diff --git a/board/pine64/quartzpro64-rk3588/quartzpro64-rk3588.c b/board/pine64/quartzpro64-rk3588/quartzpro64-rk3588.c new file mode 100644 index 00000000000..bda804a89e2 --- /dev/null +++ b/board/pine64/quartzpro64-rk3588/quartzpro64-rk3588.c @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2023 Google, Inc + */ + +#include <fdtdec.h> +#include <fdt_support.h> + +#ifdef CONFIG_OF_BOARD_SETUP +int quartzpro64_add_reserved_memory_fdt_nodes(void *new_blob) +{ + struct fdt_memory gap1 = { + .start = 0x3fc000000, + .end = 0x3fc4fffff, + }; + struct fdt_memory gap2 = { + .start = 0x3fff00000, + .end = 0x3ffffffff, + }; + unsigned long flags = FDTDEC_RESERVED_MEMORY_NO_MAP; + unsigned int ret; + + /* + * Inject the reserved-memory nodes into the DTS + */ + ret = fdtdec_add_reserved_memory(new_blob, "gap1", &gap1, NULL, 0, + NULL, flags); + if (ret) + return ret; + + return fdtdec_add_reserved_memory(new_blob, "gap2", &gap2, NULL, 0, + NULL, flags); +} + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + return quartzpro64_add_reserved_memory_fdt_nodes(blob); +} +#endif diff --git a/configs/quartzpro64-rk3588_defconfig b/configs/quartzpro64-rk3588_defconfig new file mode 100644 index 00000000000..d6b35c72647 --- /dev/null +++ b/configs/quartzpro64-rk3588_defconfig @@ -0,0 +1,72 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_DEFAULT_DEVICE_TREE="rk3588-quartzpro64" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_QUARTZPRO64_RK3588=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-quartzpro64.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_RTL8169=y +CONFIG_REGULATOR_PWM=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 8262fc0d32c..6fba0ff1e1d 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -115,6 +115,7 @@ List of mainline supported Rockchip boards: - Rockchip EVB (evb-rk3588) - Edgeble Neural Compute Module 6A SoM - Neu6a (neu6a-io-rk3588) - Edgeble Neural Compute Module 6B SoM - Neu6b (neu6b-io-rk3588) + - Pine64 QuartzPro64 (quartzpro64-rk3588) - Radxa ROCK 5A (rock5a-rk3588s) - Radxa ROCK 5B (rock5b-rk3588)
diff --git a/include/configs/quartzpro64-rk3588.h b/include/configs/quartzpro64-rk3588.h new file mode 100644 index 00000000000..a1faa2aad85 --- /dev/null +++ b/include/configs/quartzpro64-rk3588.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ + * Copyright 2023 Google, Inc + */ + +#ifndef __QUARTZPRO64_RK3588_H +#define __QUARTZPRO64_RK3588_H + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#include <configs/rk3588_common.h> + +#endif /* __QUARTZPRO64_RK3588_H */
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- rk3588-quartzpro64.dtb \ rk3588s-rock-5a.dtb \ rk3588-rock-5b.dtb
- Copyright 2023 Google, Inc
- chosen {
- Copyright (c) 2023 Ondřej Jirman megi@xff.cz
+/dts-v1/;
- model = "PINE64 QuartzPro64";
- compatible = "pine64,quartzpro64", "rockchip,rk3588";
- aliases {
mmc0 = &sdhci;
mmc1 = &sdmmc;
serial2 = &uart2;
- chosen {
- adc-keys-0 {
button-maskrom {
label = "Mask Rom";
- adc-keys-1 {
button-volume-up {
label = "V+/REC";
label = "V-";
button-menu {
label = "MENU";
button-esc {
label = "ESC";
- headphone_amp: audio-amplifier-headphone {
- speaker_amp: audio-amplifier-speaker {
- leds {
led-1 {
- sound {
"Speaker", "LOUT2",
"Speaker", "ROUT2",
- vcc12v_dcin: vcc12v-dcin-regulator {
regulator-boot-on;
- vcc3v3_bt: vcc3v3-bt-regulator {
enable-active-high;
- vcc3v3_pcie30: vcc3v3-pcie30-regulator {
enable-active-high;
- vcc3v3_wf: vcc3v3-wf-regulator {
enable-active-high;
- vcc4v0_sys: vcc4v0-sys-regulator {
regulator-boot-on;
- vcc5v0_host: vcc5v0-host-regulator {
enable-active-high;
regulator-boot-on;
- vcc5v0_usb: vcc5v0-usb-regulator {
regulator-boot-on;
+&combphy0_ps {
- status = "okay";
+&combphy1_ps {
- status = "okay";
+&combphy2_psu {
- status = "okay";
+&cpu_b0 {
- cpu-supply = <&vdd_cpu_big0_s0>;
+&cpu_b1 {
+&cpu_b2 {
- cpu-supply = <&vdd_cpu_big1_s0>;
+&cpu_b3 {
+&cpu_l0 {
- cpu-supply = <&vdd_cpu_lit_s0>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&gmac0 {
- clock_in_out = "output";
- phy-handle = <&rgmii_phy>;
- phy-mode = "rgmii-rxid";
- pinctrl-names = "default";
- pinctrl-0 = <&gmac0_miim
&gmac0_tx_bus2
&gmac0_rx_bus2
&gmac0_rgmii_clk
&gmac0_rgmii_bus>;
- rx_delay = <0x00>;
- tx_delay = <0x43>;
- status = "okay";
+&i2c2 {
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
wakeup-source;
+&i2c7 {
- status = "okay";
- es8388: audio-codec@11 {
reg = <0x11>;
+&i2s0_8ch {
- pinctrl-0 = <&i2s0_lrck
&i2s0_mclk
&i2s0_sclk
&i2s0_sdi0
&i2s0_sdo0>;
- status = "okay";
+&mdio0 {
- rgmii_phy: ethernet-phy@1 {
/* RTL8211F */
reg = <0x1>;
+&pinctrl {
- hym8563 {
- leds {
- rtl8111 {
- rtl8211f {
- sound {
- usb {
- reset-gpios = <&gpio4 RK_PA5 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_wf>;
- status = "okay";
- pinctrl-0 = <&rtl8111_isolate>;
- reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>;
- status = "okay";
+&pcie30phy {
- status = "okay";
+&pcie3x4 {
- reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_pcie30>;
- status = "okay";
+&saradc {
- vref-supply = <&vcc_1v8_s0>;
- status = "okay";
+&sata0 {
- status = "okay";
+&sdhci {
- bus-width = <8>;
- no-sdio;
- no-sd;
- non-removable;
- max-frequency = <150000000>;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>;
- disable-wp;
- no-sdio;
- no-mmc;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc_3v3_s3>;
- vqmmc-supply = <&vccio_sd_s0>;
- status = "okay";
+&spi2 {
- assigned-clocks = <&cru CLK_SPI2>;
- assigned-clock-rates = <200000000>;
- num-cs = <2>;
- status = "okay";
- pmic@0 {
reg = <0x0>;
#gpio-cells = <2>;
gpio-controller;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- pmic@1 {
reg = <0x01>;
#gpio-cells = <2>;
gpio-controller;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
/* unused */
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&tsadc {
- status = "okay";
+&u2phy2 {
- status = "okay";
+&u2phy2_host {
- phy-supply = <&vcc5v0_host>;
- status = "okay";
+&u2phy3 {
- status = "okay";
+&u2phy3_host {
- status = "okay";
+&uart2 {
- pinctrl-0 = <&uart2m0_xfer>;
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
- bool "Pine64 QuartzPro64 RK3588 board"
- select BOARD_LATE_INIT
- help
- config ROCKCHIP_BOOT_MODE_REG default 0xfd588080
+config SYS_BOARD
- default "quartzpro64-rk3588"
+config SYS_VENDOR
- default "pine64"
- def_bool y
- struct fdt_memory gap1 = {
.end = 0x3fc4fffff,
- struct fdt_memory gap2 = {
.end = 0x3ffffffff,
- unsigned long flags = FDTDEC_RESERVED_MEMORY_NO_MAP;
- unsigned int ret;
- ret = fdtdec_add_reserved_memory(new_blob, "gap1", &gap1, NULL, 0,
NULL, flags);
- if (ret)
return ret;
- return fdtdec_add_reserved_memory(new_blob, "gap2", &gap2, NULL, 0,
NULL, flags);
- return quartzpro64_add_reserved_memory_fdt_nodes(blob);
This patch has been update to V2, and your patch are not able to apply any more.
Please help to rebase it.
Thanks,
- Kever
- chosen {
+/dts-v1/;
- aliases {
mmc0 = &sdhci;
mmc1 = &sdmmc;
serial2 = &uart2;
- chosen {
- adc-keys-0 {
button-maskrom {
label = "Mask Rom";
- adc-keys-1 {
button-volume-up {
label = "V+/REC";
label = "V-";
button-menu {
label = "MENU";
button-esc {
label = "ESC";
- leds {
led-1 {
- sound {
"Speaker", "LOUT2",
"Speaker", "ROUT2",
regulator-boot-on;
enable-active-high;
enable-active-high;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
+&combphy0_ps {
- status = "okay";
+&combphy1_ps {
- status = "okay";
+&combphy2_psu {
- status = "okay";
+&cpu_b0 {
+&cpu_b1 {
+&cpu_b2 {
+&cpu_b3 {
+&cpu_l0 {
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&gmac0 {
&gmac0_tx_bus2
&gmac0_rx_bus2
&gmac0_rgmii_clk
&gmac0_rgmii_bus>;
- status = "okay";
+&i2c2 {
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
wakeup-source;
+&i2c7 {
- status = "okay";
reg = <0x11>;
+&i2s0_8ch {
&i2s0_mclk
&i2s0_sclk
&i2s0_sdi0
&i2s0_sdo0>;
- status = "okay";
+&mdio0 {
/* RTL8211F */
reg = <0x1>;
+&pinctrl {
- hym8563 {
- leds {
- rtl8111 {
- rtl8211f {
- sound {
- usb {
- status = "okay";
- status = "okay";
+&pcie30phy {
- status = "okay";
+&pcie3x4 {
- status = "okay";
+&saradc {
- status = "okay";
+&sata0 {
- status = "okay";
+&sdhci {
- bus-width = <8>;
- no-sdio;
- no-sd;
- non-removable;
- mmc-hs400-1_8v;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- no-sdio;
- no-mmc;
- sd-uhs-sdr104;
- status = "okay";
+&spi2 {
- num-cs = <2>;
- status = "okay";
- pmic@0 {
reg = <0x0>;
#gpio-cells = <2>;
gpio-controller;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- pmic@1 {
reg = <0x01>;
#gpio-cells = <2>;
gpio-controller;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
/* unused */
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&tsadc {
- status = "okay";
+&u2phy2 {
- status = "okay";
+&u2phy2_host {
- status = "okay";
+&u2phy3 {
- status = "okay";
+&u2phy3_host {
- status = "okay";
+&uart2 {
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
- help
+config SYS_BOARD
+config SYS_VENDOR
- default "pine64"
- def_bool y
.end = 0x3fc4fffff,
.end = 0x3ffffffff,
- unsigned int ret;
NULL, flags);
- if (ret)
return ret;
NULL, flags);
Kever Yang kever.yang@rock-chips.com writes:
Thank you for your review.
I have sent a v3 patch[0] which is rebased on top of master ( 9a3a58396b78b1f9d0c14580dc03f81d29207dd2 ) and Jonas's v2 patch.
0. https://lore.kernel.org/all/20231023142246.26830-1-tom@tom-fitzhenry.me.uk/ 1. https://lore.kernel.org/all/20231017170216.1627789-2-jonas@kwiboo.se/
Kever Yang
Tom Fitzhenry
