[PATCH] net: ravb: Remove writeext function call
The micrel phy driver is already configuring this values from device tree. So remove the redundant phy configuration call from this driver.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- Tested on RCar M3N board, the final configuration value is same. rxc-skew-ps 19 ksz90x1_of_config_group Final:1f9 --- drivers/net/ravb.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/drivers/net/ravb.c b/drivers/net/ravb.c index 886f53ee82..98883cd15b 100644 --- a/drivers/net/ravb.c +++ b/drivers/net/ravb.c @@ -438,8 +438,6 @@ static int ravb_config(struct udevice *dev)
writel(mask, eth->iobase + RAVB_REG_ECMR);
- phy->drv->writeext(phy, -1, 0x02, 0x08, (0x0f << 5) | 0x19); - return 0; }
Biju Das
