[U-Boot] [PATCH 1/2] fdt: Rename fdt_resize() to fdt_shrink_to_minimum()
Since libfdt now has an fdt_resize() function, we need to rename the U-Boot one.
common/cmd_fdt.c | 2 +- common/fdt_support.c | 2 +- common/image-fdt.c | 2 +- include/fdt_support.h | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/common/cmd_fdt.c b/common/cmd_fdt.c index e86d992..5640ded 100644 --- a/common/cmd_fdt.c +++ b/common/cmd_fdt.c @@ -621,7 +621,7 @@ static int do_fdt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } /* resize the fdt */ else if (strncmp(argv[1], "re", 2) == 0) { - fdt_resize(working_fdt); + fdt_shrink_to_minimum(working_fdt); } else { /* Unrecognized command */ diff --git a/common/fdt_support.c b/common/fdt_support.c index 7927a83..784a570 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -508,7 +508,7 @@ void fdt_fixup_ethernet(void *fdt) }
/* Resize the fdt to its actual size + a bit of padding */ -int fdt_resize(void *blob) +int fdt_shrink_to_minimum(void *blob) { int i; uint64_t addr, size; diff --git a/common/image-fdt.c b/common/image-fdt.c index 9fc7481..0ea676b 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -476,7 +476,7 @@ int image_setup_libfdt(bootm_headers_t *images, void *blob, lmb_free(lmb, (phys_addr_t)(u32)(uintptr_t)blob, (phys_size_t)fdt_totalsize(blob));
- ret = fdt_resize(blob); + ret = fdt_shrink_to_minimum(blob); if (ret < 0) return ret; of_size = ret; diff --git a/include/fdt_support.h b/include/fdt_support.h index fd44d7e..1bda686 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -76,7 +76,7 @@ void ft_cpu_setup(void *blob, bd_t *bd); void ft_pci_setup(void *blob, bd_t *bd);
void set_working_fdt_addr(void *addr); -int fdt_resize(void *blob); +int fdt_shrink_to_minimum(void *blob); int fdt_increase_size(void *fdt, int add_len);
int fdt_fixup_nor_flash_size(void *blob);
This brings in changes up to commit f9e91a48 in the libfdt repo. Mostly this is whitespace/minor changes. But there are a few new features:
- fdt_size_cells() and fdt_address_cells() - fdt_resize()
include/libfdt.h | 73 +++++++++++++++++++++++++++++++++++++++++--- lib/libfdt/Makefile | 3 +- lib/libfdt/fdt_addresses.c | 55 +++++++++++++++++++++++++++++++++ lib/libfdt/fdt_rw.c | 6 ++-- lib/libfdt/fdt_sw.c | 32 +++++++++++++++++++ lib/libfdt/libfdt_internal.h | 6 ++-- 6 files changed, 163 insertions(+), 12 deletions(-) create mode 100644 lib/libfdt/fdt_addresses.c
diff --git a/include/libfdt.h b/include/libfdt.h index 9eefaaf..a1ef1e1 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -116,7 +116,12 @@ * Should never be returned, if it is, it indicates a bug in * libfdt itself. */
-#define FDT_ERR_MAX 13 +/* Errors in device tree content */ +#define FDT_ERR_BADNCELLS 14 + /* FDT_ERR_BADNCELLS: Device tree has a #address-cells, #size-cells + * or similar property with a bad format or value */ + +#define FDT_ERR_MAX 14
/**********************************************************************/ /* Low-level functions (you probably don't need these) */ @@ -596,9 +601,9 @@ const char *fdt_get_alias_namelen(const void *fdt, const char *name, int namelen);
/** - * fdt_get_alias - retrieve the path referenced by a given alias + * fdt_get_alias - retreive the path referenced by a given alias * @fdt: pointer to the device tree blob - * @name: name of the alias to look up + * @name: name of the alias th look up * * fdt_get_alias() retrieves the value of a given alias. That is, the * value of the property named 'name' in the node /aliases. @@ -731,7 +736,7 @@ int fdt_parent_offset(const void *fdt, int nodeoffset); * offset = fdt_node_offset_by_prop_value(fdt, -1, propname, * propval, proplen); * while (offset != -FDT_ERR_NOTFOUND) { - * ... other code here ... + * // other code here * offset = fdt_node_offset_by_prop_value(fdt, offset, propname, * propval, proplen); * } @@ -816,7 +821,7 @@ int fdt_node_check_compatible(const void *fdt, int nodeoffset, * idiom can be used: * offset = fdt_node_offset_by_compatible(fdt, -1, compatible); * while (offset != -FDT_ERR_NOTFOUND) { - * ... other code here ... + * // other code here * offset = fdt_node_offset_by_compatible(fdt, offset, compatible); * } * @@ -853,6 +858,63 @@ int fdt_node_offset_by_compatible(const void *fdt, int startoffset, int fdt_stringlist_contains(const char *strlist, int listlen, const char *str);
/**********************************************************************/ +/* Read-only functions (addressing related) */ +/**********************************************************************/ + +/** + * FDT_MAX_NCELLS - maximum value for #address-cells and #size-cells + * + * This is the maximum value for #address-cells, #size-cells and + * similar properties that will be processed by libfdt. IEE1275 + * requires that OF implementations handle values up to 4. + * Implementations may support larger values, but in practice higher + * values aren't used. + */ +#define FDT_MAX_NCELLS 4 + +/** + * fdt_address_cells - retrieve address size for a bus represented in the tree + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node to find the address size for + * + * When the node has a valid #address-cells property, returns its value. + * + * returns: + * 0 <= n < FDT_MAX_NCELLS, on success + * 2, if the node has no #address-cells property + * -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid + * #address-cells property + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_address_cells(const void *fdt, int nodeoffset); + +/** + * fdt_size_cells - retrieve address range size for a bus represented in the + * tree + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node to find the address range size for + * + * When the node has a valid #size-cells property, returns its value. + * + * returns: + * 0 <= n < FDT_MAX_NCELLS, on success + * 2, if the node has no #address-cells property + * -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid + * #size-cells property + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_size_cells(const void *fdt, int nodeoffset); + + +/**********************************************************************/ /* Write-in-place functions */ /**********************************************************************/
@@ -1023,6 +1085,7 @@ int fdt_nop_node(void *fdt, int nodeoffset); /**********************************************************************/
int fdt_create(void *buf, int bufsize); +int fdt_resize(void *fdt, void *buf, int bufsize); int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size); int fdt_finish_reservemap(void *fdt); int fdt_begin_node(void *fdt, const char *name); diff --git a/lib/libfdt/Makefile b/lib/libfdt/Makefile index a02c9b0..6fe79e0 100644 --- a/lib/libfdt/Makefile +++ b/lib/libfdt/Makefile @@ -5,7 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS-libfdt += fdt.o fdt_ro.o fdt_rw.o fdt_strerror.o fdt_sw.o fdt_wip.o fdt_empty_tree.o +COBJS-libfdt += fdt.o fdt_ro.o fdt_rw.o fdt_strerror.o fdt_sw.o fdt_wip.o \ + fdt_empty_tree.o fdt_addresses.o
obj-$(CONFIG_OF_LIBFDT) += $(COBJS-libfdt) obj-$(CONFIG_FIT) += $(COBJS-libfdt) diff --git a/lib/libfdt/fdt_addresses.c b/lib/libfdt/fdt_addresses.c new file mode 100644 index 0000000..76054d9 --- /dev/null +++ b/lib/libfdt/fdt_addresses.c @@ -0,0 +1,55 @@ +/* + * libfdt - Flat Device Tree manipulation + * Copyright (C) 2014 David Gibson david@gibson.dropbear.id.au + * SPDX-License-Identifier: GPL-2.0+ BSD-2-Clause + */ +#include "libfdt_env.h" + +#ifndef USE_HOSTCC +#include <fdt.h> +#include <libfdt.h> +#else +#include "fdt_host.h" +#endif + +#include "libfdt_internal.h" + +int fdt_address_cells(const void *fdt, int nodeoffset) +{ + const fdt32_t *ac; + int val; + int len; + + ac = fdt_getprop(fdt, nodeoffset, "#address-cells", &len); + if (!ac) + return 2; + + if (len != sizeof(*ac)) + return -FDT_ERR_BADNCELLS; + + val = fdt32_to_cpu(*ac); + if ((val <= 0) || (val > FDT_MAX_NCELLS)) + return -FDT_ERR_BADNCELLS; + + return val; +} + +int fdt_size_cells(const void *fdt, int nodeoffset) +{ + const fdt32_t *sc; + int val; + int len; + + sc = fdt_getprop(fdt, nodeoffset, "#size-cells", &len); + if (!sc) + return 2; + + if (len != sizeof(*sc)) + return -FDT_ERR_BADNCELLS; + + val = fdt32_to_cpu(*sc); + if ((val < 0) || (val > FDT_MAX_NCELLS)) + return -FDT_ERR_BADNCELLS; + + return val; +} diff --git a/lib/libfdt/fdt_rw.c b/lib/libfdt/fdt_rw.c index 6fa4f13..bec8b8a 100644 --- a/lib/libfdt/fdt_rw.c +++ b/lib/libfdt/fdt_rw.c @@ -43,9 +43,9 @@ static int _fdt_rw_check_header(void *fdt)
#define FDT_RW_CHECK_HEADER(fdt) \ { \ - int err; \ - if ((err = _fdt_rw_check_header(fdt)) != 0) \ - return err; \ + int __err; \ + if ((__err = _fdt_rw_check_header(fdt)) != 0) \ + return __err; \ }
static inline int _fdt_data_size(void *fdt) diff --git a/lib/libfdt/fdt_sw.c b/lib/libfdt/fdt_sw.c index 580b570..320a914 100644 --- a/lib/libfdt/fdt_sw.c +++ b/lib/libfdt/fdt_sw.c @@ -62,6 +62,38 @@ int fdt_create(void *buf, int bufsize) return 0; }
+int fdt_resize(void *fdt, void *buf, int bufsize) +{ + size_t headsize, tailsize; + char *oldtail, *newtail; + + FDT_SW_CHECK_HEADER(fdt); + + headsize = fdt_off_dt_struct(fdt); + tailsize = fdt_size_dt_strings(fdt); + + if ((headsize + tailsize) > bufsize) + return -FDT_ERR_NOSPACE; + + oldtail = (char *)fdt + fdt_totalsize(fdt) - tailsize; + newtail = (char *)buf + bufsize - tailsize; + + /* Two cases to avoid clobbering data if the old and new + * buffers partially overlap */ + if (buf <= fdt) { + memmove(buf, fdt, headsize); + memmove(newtail, oldtail, tailsize); + } else { + memmove(newtail, oldtail, tailsize); + memmove(buf, fdt, headsize); + } + + fdt_set_off_dt_strings(buf, bufsize); + fdt_set_totalsize(buf, bufsize); + + return 0; +} + int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size) { struct fdt_reserve_entry *re; diff --git a/lib/libfdt/libfdt_internal.h b/lib/libfdt/libfdt_internal.h index 13cbc9a..9a79fe8 100644 --- a/lib/libfdt/libfdt_internal.h +++ b/lib/libfdt/libfdt_internal.h @@ -12,9 +12,9 @@
#define FDT_CHECK_HEADER(fdt) \ { \ - int err; \ - if ((err = fdt_check_header(fdt)) != 0) \ - return err; \ + int __err; \ + if ((__err = fdt_check_header(fdt)) != 0) \ + return __err; \ }
int _fdt_check_node_offset(const void *fdt, int offset);
- fdt_resize()
