Re: [BUG] sandbox error handling broken on origin/next
Hi Heinrich,
On Tue, 23 Mar 2021 at 07:12, Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hello Simon,
using sandbox_defconfig on origin/master:
Hit any key to stop autoboot: 0 => exception sigsegv
Segmentation violation pc = 0x55d3566d04f9, pc_reloc = 0x554f9
Here the SIGSEGV is correctly handled by the sandbox.
On origin/next:
Segmentation violation pc = 0x5567966da96b, pc_reloc = 0x5567866da96b
Writing sandbox state Segmentation fault $
The same problem is visible when executing the poweroff command.
=> poweroff poweroff ... Segmentation fault $
Bisecting points to your commit
b308d9fd18fa sandbox: Avoid using malloc() for system state
The segmentation fault occurs when os_exit() calls dm_uninit(). The value of gd is invalid at this point.
Can you please check this patch?
http://patchwork.ozlabs.org/project/uboot/patch/20210315051124.1940496-10-sj...
Also, is there no test covering the above?
On 3/22/21 7:16 PM, Simon Glass wrote:
Hi Heinrich,
Hello Simon,
On origin/next:
Hello Simon,
We have a poweroff test but there is no detection for the 'Segmentation fault' string.
For CONFIG_SANDBOX_CRASH_RESET=n the patch helps.
For CONFIG_SANDBOX_CRASH_RESET=y you still get a segmentation fault when executing 'exception sigsegv'.
Unfortunately you decided to disable CONFIG_SANDBOX_CRASH_RESET in sandbox_defconfig. Otherwise you would have detected the problem as "FAILED test/py/tests/test_sandbox_exit.py::test_exception_reset".
Please, adjust sandbox_reset().
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
Hello Simon,
On origin/next:
Hello Simon,
OK, is that caused by the same commit? The problem is that the commit is actually fixing a bug. I'll need to think about how to fix the fix.
Well we don't generally want to reset when we get a crash, right?
What would you like it to do?
Am 23. März 2021 01:57:00 MEZ schrieb Simon Glass sjg@chromium.org:
Hi Heinrich,
Hi Heinrich,
Hello Simon,
On origin/next:
Hello Simon,
'Segmentation
fault' string.
when
Yes
Resetting after a crash is what all other boards do.
I personally don't have a need for the sandbox to behave differently.
Executing the 'reset' command fails with a crash.
The crash occurs when dm_uninit() is invoked.
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
Hello Simon,
On origin/next:
Hello Simon,
'Segmentation
fault' string.
when
Yes
I see sandbox as a normal program. If you run grimp and it crashes, it doesn't reset. The only reason we have a reset feature in sandbox is for testing purposes.
This is definitely a tricky area. Since devices are allocated in the 'emulated' RAM we really can't close down sandbox before uniniting devices, and vice versa. Some separation is needed.
I will take a look at this at some point, but it needs a fair bit of thought.
