[U-Boot] [PATCH] ppc4xx: Optimize PLB4 arbiter and Memory Queue settings for PPC 440SP/SPe and 460EX/GT/SX
Read Pipeline depth should be set to 4 for PPC440SP/SPE, PPC405EX, PPC460EX/GT/SX processors. Optimize Memory Queue settings for PPC440SP/SPE and PPC460EX/GT/SX processors Please apply patch against next branch of Stefan's git tree.
Signed-off-by: Prodyut Hazarika phazarika@amcc.com --- cpu/ppc4xx/44x_spd_ddr2.c | 28 +++++++++++++++++--- cpu/ppc4xx/cpu_init.c | 21 ++++++++++++++- include/asm-ppc/ppc4xx-sdram.h | 48 +++++++++++++++++++++++----------- include/ppc440.h | 47 ---------------------------------- include/ppc4xx.h | 55 ++++++++++++++++++++++++++++++++++++++++ 5 files changed, 131 insertions(+), 68 deletions(-)
diff --git a/cpu/ppc4xx/44x_spd_ddr2.c b/cpu/ppc4xx/44x_spd_ddr2.c index 1c36324..2ba7715 100644 --- a/cpu/ppc4xx/44x_spd_ddr2.c +++ b/cpu/ppc4xx/44x_spd_ddr2.c @@ -2172,6 +2172,11 @@ static void program_memory_queue(unsigned long *dimm_populated, unsigned long i; unsigned long bank_0_populated = 0; phys_size_t total_size = 0; +#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_460SX) + unsigned long val; +#endif
/*------------------------------------------------------------------ * Reset the rank_base_address. @@ -2249,18 +2254,33 @@ static void program_memory_queue(unsigned long *dimm_populated, } }
-#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_460SX) + /* - * Enable high bandwidth access on 460EX/GT. - * This should/could probably be done on other - * PPC's too, like 440SPe. + * Enable high bandwidth access * This is currently not used, but with this setup * it is possible to use it later on in e.g. the Linux * EMAC driver for performance gain. */ mtdcr(SDRAM_PLBADDULL, 0x00000000); /* MQ0_BAUL */ mtdcr(SDRAM_PLBADDUHB, 0x00000008); /* MQ0_BAUH */ + + /* + * Set optimal value for Memory Queue HB/LL Configuration registers + */ + + val = (mfdcr(SDRAM_CONF1HB) | SDRAM_CONF1HB_AAFR | SDRAM_CONF1HB_RPEN | SDRAM_CONF1HB_RFTE); + mtdcr(SDRAM_CONF1HB, val); + + val = (mfdcr(SDRAM_CONF1LL) | SDRAM_CONF1LL_AAFR | SDRAM_CONF1LL_RPEN | SDRAM_CONF1LL_RFTE); + mtdcr(SDRAM_CONF1LL, val); + + val = (mfdcr(SDRAM_CONFPATHB) | SDRAM_CONFPATHB_TPEN); + mtdcr(SDRAM_CONFPATHB, val); #endif + }
/*-----------------------------------------------------------------------------+ diff --git a/cpu/ppc4xx/cpu_init.c b/cpu/ppc4xx/cpu_init.c index e2d0402..033d4f5 100644 --- a/cpu/ppc4xx/cpu_init.c +++ b/cpu/ppc4xx/cpu_init.c @@ -138,7 +138,9 @@ void reconfigure_pll(u32 new_cpu_freq) void cpu_init_f (void) { -#if defined(CONFIG_WATCHDOG) || defined(CONFIG_440GX) || defined(CONFIG_460EX) +#if defined(CONFIG_WATCHDOG) || defined(CONFIG_440GX) || defined(CONFIG_460EX) || \ + defined(CONFIG_440SP) || defined(CONFIG_440SPE) || defined(CONFIG_405EX) || \ + defined (CONFIG_460GT) || defined(CONFIG_460SX) u32 val; #endif
@@ -301,6 +303,23 @@ cpu_init_f (void) val |= 0x400; mtsdr(SDR0_USB2HOST_CFG, val); #endif /* CONFIG_460EX */ + +#if defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_405EX) || defined(CONFIG_460SX) + + /* + * Set PLB4 arbiter (Segment 0 and 1) to 4 deep pipeline read + */ + + val = (mfdcr(plb0_acr) & ~plb0_acr_rdp_mask) | plb0_acr_rdp_4deep; + mtdcr(plb0_acr, val); + + val = (mfdcr(plb1_acr) & ~plb1_acr_rdp_mask) | plb1_acr_rdp_4deep; + mtdcr(plb1_acr, val); + +#endif /* CONFIG_440SP/SPE || CONFIG_460EX/GT || CONFIG_405EX */ + }
/* diff --git a/include/asm-ppc/ppc4xx-sdram.h b/include/asm-ppc/ppc4xx-sdram.h index df787b3..d2e3b42 100644 --- a/include/asm-ppc/ppc4xx-sdram.h +++ b/include/asm-ppc/ppc4xx-sdram.h @@ -259,23 +259,39 @@ /* * Memory queue defines */ -#define SDRAMQ_DCR_BASE 0x040 - -#define SDRAM_R0BAS (SDRAMQ_DCR_BASE+0x0) /* rank 0 base address & size */ -#define SDRAM_R1BAS (SDRAMQ_DCR_BASE+0x1) /* rank 1 base address & size */ -#define SDRAM_R2BAS (SDRAMQ_DCR_BASE+0x2) /* rank 2 base address & size */ -#define SDRAM_R3BAS (SDRAMQ_DCR_BASE+0x3) /* rank 3 base address & size */ -#define SDRAM_CONF1HB (SDRAMQ_DCR_BASE+0x5) /* configuration 1 HB */ -#define SDRAM_ERRSTATHB (SDRAMQ_DCR_BASE+0x7) /* error status HB */ -#define SDRAM_ERRADDUHB (SDRAMQ_DCR_BASE+0x8) /* error address upper 32 HB */ -#define SDRAM_ERRADDLHB (SDRAMQ_DCR_BASE+0x9) /* error address lower 32 HB */ -#define SDRAM_PLBADDULL (SDRAMQ_DCR_BASE+0xA) /* PLB base address upper 32 LL */ -#define SDRAM_CONF1LL (SDRAMQ_DCR_BASE+0xB) /* configuration 1 LL */ -#define SDRAM_ERRSTATLL (SDRAMQ_DCR_BASE+0xC) /* error status LL */ -#define SDRAM_ERRADDULL (SDRAMQ_DCR_BASE+0xD) /* error address upper 32 LL */ -#define SDRAM_ERRADDLLL (SDRAMQ_DCR_BASE+0xE) /* error address lower 32 LL */ -#define SDRAM_CONFPATHB (SDRAMQ_DCR_BASE+0xF) /* configuration between paths */ -#define SDRAM_PLBADDUHB (SDRAMQ_DCR_BASE+0x10) /* PLB base address upper 32 LL */ +#define SDRAMQ_DCR_BASE 0x040 + +#define SDRAM_R0BAS (SDRAMQ_DCR_BASE+0x0) /* rank 0 base address & size */ +#define SDRAM_R1BAS (SDRAMQ_DCR_BASE+0x1) /* rank 1 base address & size */ +#define SDRAM_R2BAS (SDRAMQ_DCR_BASE+0x2) /* rank 2 base address & size */ +#define SDRAM_R3BAS (SDRAMQ_DCR_BASE+0x3) /* rank 3 base address & size */ +#define SDRAM_CONF1HB (SDRAMQ_DCR_BASE+0x5) /* configuration 1 HB */ +#define SDRAM_CONF1HB_AAFR 0x80000000 /* Address Ack on First Request - Bit 0 */ +#define SDRAM_CONF1HB_PRPD 0x00080000 /* PLB Read pipeline Disable - Bit 12 */ +#define SDRAM_CONF1HB_PWPD 0x00040000 /* PLB Write pipeline Disable - Bit 13 */ +#define SDRAM_CONF1HB_PRW 0x00020000 /* PLB Read Wait - Bit 14 */ +#define SDRAM_CONF1HB_RPEN 0x00000800 /* Read Passing Enable - Bit 20 */ +#define SDRAM_CONF1HB_RFTE 0x00000400 /* Read Flow Through Enable - Bit 21 */ + +#define SDRAM_ERRSTATHB (SDRAMQ_DCR_BASE+0x7) /* error status HB */ +#define SDRAM_ERRADDUHB (SDRAMQ_DCR_BASE+0x8) /* error address upper 32 HB */ +#define SDRAM_ERRADDLHB (SDRAMQ_DCR_BASE+0x9) /* error address lower 32 HB */ +#define SDRAM_PLBADDULL (SDRAMQ_DCR_BASE+0xA) /* PLB base address upper 32 LL */ +#define SDRAM_CONF1LL (SDRAMQ_DCR_BASE+0xB) /* configuration 1 LL */ +#define SDRAM_CONF1LL_AAFR 0x80000000 /* Address Ack on First Request - Bit 0 */ +#define SDRAM_CONF1LL_PRPD 0x00080000 /* PLB Read pipeline Disable - Bit 12 */ +#define SDRAM_CONF1LL_PWPD 0x00040000 /* PLB Write pipeline Disable - Bit 13 */ +#define SDRAM_CONF1LL_PRW 0x00020000 /* PLB Read Wait - Bit 14 */ +#define SDRAM_CONF1LL_RPEN 0x00000800 /* Read Passing Enable - Bit 20 */ +#define SDRAM_CONF1LL_RFTE 0x00000400 /* Read Flow Through Enable - Bit 21 */ + +#define SDRAM_ERRSTATLL (SDRAMQ_DCR_BASE+0xC) /* error status LL */ +#define SDRAM_ERRADDULL (SDRAMQ_DCR_BASE+0xD) /* error address upper 32 LL */ +#define SDRAM_ERRADDLLL (SDRAMQ_DCR_BASE+0xE) /* error address lower 32 LL */ +#define SDRAM_CONFPATHB (SDRAMQ_DCR_BASE+0xF) /* configuration between paths */ +#define SDRAM_CONFPATHB_TPEN 0x08000000 /* Transaction Passing Enable - Bit 4 */ + +#define SDRAM_PLBADDUHB (SDRAMQ_DCR_BASE+0x10) /* PLB base address upper 32 LL */
#if !defined(CONFIG_405EX) /* diff --git a/include/ppc440.h b/include/ppc440.h index 92db15f..3584fd2 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -341,53 +341,6 @@
#define PLB4_ACR_WRP (0x80000000 >> 7)
-/* Nebula PLB4 Arbiter - PowerPC440EP */ -#define PLB_ARBITER_BASE 0x80 - -#define plb0_revid (PLB_ARBITER_BASE+ 0x00) -#define plb0_acr (PLB_ARBITER_BASE+ 0x01) -#define plb0_acr_ppm_mask 0xF0000000 -#define plb0_acr_ppm_fixed 0x00000000 -#define plb0_acr_ppm_fair 0xD0000000 -#define plb0_acr_hbu_mask 0x08000000 -#define plb0_acr_hbu_disabled 0x00000000 -#define plb0_acr_hbu_enabled 0x08000000 -#define plb0_acr_rdp_mask 0x06000000 -#define plb0_acr_rdp_disabled 0x00000000 -#define plb0_acr_rdp_2deep 0x02000000 -#define plb0_acr_rdp_3deep 0x04000000 -#define plb0_acr_rdp_4deep 0x06000000 -#define plb0_acr_wrp_mask 0x01000000 -#define plb0_acr_wrp_disabled 0x00000000 -#define plb0_acr_wrp_2deep 0x01000000 - -#define plb0_besrl (PLB_ARBITER_BASE+ 0x02) -#define plb0_besrh (PLB_ARBITER_BASE+ 0x03) -#define plb0_bearl (PLB_ARBITER_BASE+ 0x04) -#define plb0_bearh (PLB_ARBITER_BASE+ 0x05) -#define plb0_ccr (PLB_ARBITER_BASE+ 0x08) - -#define plb1_acr (PLB_ARBITER_BASE+ 0x09) -#define plb1_acr_ppm_mask 0xF0000000 -#define plb1_acr_ppm_fixed 0x00000000 -#define plb1_acr_ppm_fair 0xD0000000 -#define plb1_acr_hbu_mask 0x08000000 -#define plb1_acr_hbu_disabled 0x00000000 -#define plb1_acr_hbu_enabled 0x08000000 -#define plb1_acr_rdp_mask 0x06000000 -#define plb1_acr_rdp_disabled 0x00000000 -#define plb1_acr_rdp_2deep 0x02000000 -#define plb1_acr_rdp_3deep 0x04000000 -#define plb1_acr_rdp_4deep 0x06000000 -#define plb1_acr_wrp_mask 0x01000000 -#define plb1_acr_wrp_disabled 0x00000000 -#define plb1_acr_wrp_2deep 0x01000000 - -#define plb1_besrl (PLB_ARBITER_BASE+ 0x0A) -#define plb1_besrh (PLB_ARBITER_BASE+ 0x0B) -#define plb1_bearl (PLB_ARBITER_BASE+ 0x0C) -#define plb1_bearh (PLB_ARBITER_BASE+ 0x0D) - /* Pin Function Control Register 1 */ #define SDR0_PFC1 0x4101 #define SDR0_PFC1_U1ME_MASK 0x02000000 /* UART1 Mode Enable */ diff --git a/include/ppc4xx.h b/include/ppc4xx.h index c71da60..154956e 100644 --- a/include/ppc4xx.h +++ b/include/ppc4xx.h @@ -46,6 +46,61 @@ #define CONFIG_SDRAM_PPC4xx_IBM_DDR2 /* IBM DDR(2) controller */ #endif
+/* PLB4 CrossBar Arbiter Core supported across PPC4xx families */ +#if defined(CONFIG_440EP) || defined(CONFIG_440EPX) || \ + defined(CONFIG_440GR) || defined(CONFIG_440GRX) || \ + defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_460SX) || defined(CONFIG_405EX) + +#define PLB_ARBITER_BASE 0x80 + +#define plb0_revid (PLB_ARBITER_BASE+ 0x00) +#define plb0_acr (PLB_ARBITER_BASE+ 0x01) +#define plb0_acr_ppm_mask 0xF0000000 +#define plb0_acr_ppm_fixed 0x00000000 +#define plb0_acr_ppm_fair 0xD0000000 +#define plb0_acr_hbu_mask 0x08000000 +#define plb0_acr_hbu_disabled 0x00000000 +#define plb0_acr_hbu_enabled 0x08000000 +#define plb0_acr_rdp_mask 0x06000000 +#define plb0_acr_rdp_disabled 0x00000000 +#define plb0_acr_rdp_2deep 0x02000000 +#define plb0_acr_rdp_3deep 0x04000000 +#define plb0_acr_rdp_4deep 0x06000000 +#define plb0_acr_wrp_mask 0x01000000 +#define plb0_acr_wrp_disabled 0x00000000 +#define plb0_acr_wrp_2deep 0x01000000 + +#define plb0_besrl (PLB_ARBITER_BASE+ 0x02) +#define plb0_besrh (PLB_ARBITER_BASE+ 0x03) +#define plb0_bearl (PLB_ARBITER_BASE+ 0x04) +#define plb0_bearh (PLB_ARBITER_BASE+ 0x05) +#define plb0_ccr (PLB_ARBITER_BASE+ 0x08) + +#define plb1_acr (PLB_ARBITER_BASE+ 0x09) +#define plb1_acr_ppm_mask 0xF0000000 +#define plb1_acr_ppm_fixed 0x00000000 +#define plb1_acr_ppm_fair 0xD0000000 +#define plb1_acr_hbu_mask 0x08000000 +#define plb1_acr_hbu_disabled 0x00000000 +#define plb1_acr_hbu_enabled 0x08000000 +#define plb1_acr_rdp_mask 0x06000000 +#define plb1_acr_rdp_disabled 0x00000000 +#define plb1_acr_rdp_2deep 0x02000000 +#define plb1_acr_rdp_3deep 0x04000000 +#define plb1_acr_rdp_4deep 0x06000000 +#define plb1_acr_wrp_mask 0x01000000 +#define plb1_acr_wrp_disabled 0x00000000 +#define plb1_acr_wrp_2deep 0x01000000 + +#define plb1_besrl (PLB_ARBITER_BASE+ 0x0A) +#define plb1_besrh (PLB_ARBITER_BASE+ 0x0B) +#define plb1_bearl (PLB_ARBITER_BASE+ 0x0C) +#define plb1_bearh (PLB_ARBITER_BASE+ 0x0D) + +#endif /* 440EP/EPX 440GR/GRX 440SP/SPE 460EX/GT/SX 405EX*/ + #if defined(CONFIG_440) /* * Enable long long (%ll ...) printf format on 440 PPC's since most of
Patch is line-wrapped this time. I suggest that you use git-send-email to send your git formatted patches.
Please find some more comments below.
- defined(CONFIG_460EX) || defined(CONFIG_460GT) || \
- defined(CONFIG_460SX)
- unsigned long val;
- This is currently not used, but with this setup
- it is possible to use it later on in e.g. the Linux
- EMAC driver for performance gain.
- val = (mfdcr(SDRAM_CONF1HB) | SDRAM_CONF1HB_AAFR |
- mtdcr(SDRAM_CONF1HB, val);
- val = (mfdcr(SDRAM_CONF1LL) | SDRAM_CONF1LL_AAFR |
- mtdcr(SDRAM_CONF1LL, val);
- val = (mfdcr(SDRAM_CONFPATHB) | SDRAM_CONFPATHB_TPEN);
- mtdcr(SDRAM_CONFPATHB, val);
#endif
Nitpick: Don't add this empty line here.
/*------------------------------------------------------------------------- ----+ diff --git a/cpu/ppc4xx/cpu_init.c b/cpu/ppc4xx/cpu_init.c index e2d0402..033d4f5 100644 --- a/cpu/ppc4xx/cpu_init.c +++ b/cpu/ppc4xx/cpu_init.c @@ -138,7 +138,9 @@ void reconfigure_pll(u32 new_cpu_freq) void cpu_init_f (void) { -#if defined(CONFIG_WATCHDOG) || defined(CONFIG_440GX) || defined(CONFIG_460EX) +#if defined(CONFIG_WATCHDOG) || defined(CONFIG_440GX) || defined(CONFIG_460EX) || \
- defined(CONFIG_440SP) || defined(CONFIG_440SPE) ||
- defined (CONFIG_460GT) || defined(CONFIG_460SX)
No space after "defined" please. -> "defined("
u32 val; #endif
- defined(CONFIG_405EX) || defined(CONFIG_460SX)
Why don't you add 440GP and 440GX here? From my understanding they would benefit from this pipeline change too.
- val = (mfdcr(plb0_acr) & ~plb0_acr_rdp_mask) | plb0_acr_rdp_4deep;
- mtdcr(plb0_acr, val);
- val = (mfdcr(plb1_acr) & ~plb1_acr_rdp_mask) | plb1_acr_rdp_4deep;
- mtdcr(plb1_acr, val);
Again, please don't add this empty line here before the "}".
- Memory queue defines
- defined(CONFIG_440GR) || defined(CONFIG_440GRX) || \
- defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \
- defined(CONFIG_460SX) || defined(CONFIG_405EX)
No upper case defines in this patch. I'm fine with this as long as we update this in a later patch.
And from a quick check of the manuals the 440GP/GX have a slightly different register layout. Is this the reason you didn't include those PPC's in this patch version? What are your plans for those PPC's?
Thanks.
Best regards, Stefan
Thanks Stefan. Please see replies below.
I will use git-send-email next time to avoid these issues
Sorry about that. I will be careful in future.
400GP/GX have a slightly different register layout. I plan to make a separate patch adding the defines and the changes in a separate patch.
I plan to make a cleanup patch soon. Felt it was appropriate to separate them.
That is right. I want to send a separate patch for the same.
Also could you please let me know whether you applied the patch. Sorry for the line wrap issues - I will use git-send-email next time.
Regards, Prodyut Hazarika
======================= Staff S/W Engineer AMCC ======================= --------------------------------------------------------
CONFIDENTIALITY NOTICE: This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and contains information that is confidential and proprietary to Applied Micro Circuits Corporation or its subsidiaries. It is to be used solely for the purpose of furthering the parties' business relationship. All unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message.
Good.
That's what I thought. OK.
Good. Thanks.
OK.
No, I didn't apply it yet. Please fix the nitpicking issues and re-send via git-send-email. I'll apply it then.
Thanks.
Prodyut Hazarika
prodyut hazarika
Stefan Roese
