[U-Boot] [PATCH 0/2] rtc, rv3029: add support for trickle charger
This patchseries adds trickle charger support for the RTC RV3029 and add it to the existing digsy_mtc board (rev5 boards only).
checkpatch says:
total: 0 errors, 0 warnings, 117 lines checked
20110328/0001-rtc-rv3029-add-trickle-charger-support.patch has no obvious style problems and is ready for submission. total: 0 errors, 0 warnings, 7 lines checked
20110328/0002-mpc52xx-digsy_mtc-add-trickle-charger-support-for-re.patch has no obvious style problems and is ready for submission.
Heiko Schocher (2): rtc, rv3029: add trickle charger support. mpc52xx, digsy_mtc: add trickle charger support for rev5 boards.
README | 2 + drivers/rtc/rv3029.c | 87 +++++++++++++++++++++++++++++++++++++++++++ include/configs/digsy_mtc.h | 1 + 3 files changed, 90 insertions(+), 0 deletions(-)
Signed-off-by: Heiko Schocher hs@denx.de --- README | 2 + drivers/rtc/rv3029.c | 87 ++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 89 insertions(+), 0 deletions(-)
diff --git a/README b/README index 21cd71b..45b32e7 100644 --- a/README +++ b/README @@ -743,6 +743,8 @@ The following options need to be configured: CONFIG_RTC_ISL1208 - use Intersil ISL1208 RTC CONFIG_RTC_MAX6900 - use Maxim, Inc. MAX6900 RTC CONFIG_SYS_RTC_DS1337_NOOSC - Turn off the OSC output for DS1337 + CONFIG_SYS_RV3029_TCR - enable trickle charger on + RV3029 RTC.
Note that if the RTC uses I2C, then the I2C interface must also be configured. See I2C Support, below. diff --git a/drivers/rtc/rv3029.c b/drivers/rtc/rv3029.c index 3ebc768..e012168 100644 --- a/drivers/rtc/rv3029.c +++ b/drivers/rtc/rv3029.c @@ -25,6 +25,12 @@ #include <i2c.h> #include <rtc.h>
+#define RTC_RV3029_CTRL1 0x00 +#define RTC_RV3029_CTRL1_EERE (1 << 3) + +#define RTC_RV3029_CTRL_STATUS 0x03 +#define RTC_RV3029_CTRLS_EEBUSY (1 << 7) + #define RTC_RV3029_CTRL_RESET 0x04 #define RTC_RV3029_CTRL_SYS_R (1 << 4)
@@ -42,6 +48,12 @@ #define RV3029C2_REG_HR_12_24 (1 << 6) /* 24h/12h mode */ #define RV3029C2_REG_HR_PM (1 << 5) /* PM/AM bit in 12h mode */
+#define RTC_RV3029_EEPROM_CTRL 0x30 +#define RTC_RV3029_TRICKLE_1K (1 << 4) +#define RTC_RV3029_TRICKLE_5K (1 << 5) +#define RTC_RV3029_TRICKLE_20K (1 << 6) +#define RTC_RV3029_TRICKLE_80K (1 << 7) + int rtc_get( struct rtc_time *tmp ) { int ret; @@ -113,6 +125,41 @@ int rtc_set( struct rtc_time *tmp ) return 0; }
+/* sets EERE-Bit (automatic EEPROM refresh) */ +static void set_eere_bit(int state) +{ + int ret; + unsigned char reg_ctrl1; + + ret = i2c_read(CONFIG_SYS_I2C_RTC_ADDR, RTC_RV3029_CTRL1, 1, + ®_ctrl1, 1); + + if (state) + reg_ctrl1 |= RTC_RV3029_CTRL1_EERE; + else + reg_ctrl1 &= (~RTC_RV3029_CTRL1_EERE); + + ret = i2c_write(CONFIG_SYS_I2C_RTC_ADDR, RTC_RV3029_CTRL1, 1, + ®_ctrl1, 1); +} + +/* waits until EEPROM page is no longer busy (times out after 10ms*loops) */ +static int wait_eebusy(int loops) +{ + int i, ret; + unsigned char ctrl_status; + + for (i = 0; i < loops; i++) { + ret = i2c_read(CONFIG_SYS_I2C_RTC_ADDR, RTC_RV3029_CTRL_STATUS, + 1, &ctrl_status, 1); + + if ((ctrl_status & RTC_RV3029_CTRLS_EEBUSY) == 0) + break; + udelay(10000); + } + return i; +} + void rtc_reset (void) { int ret; @@ -121,4 +168,44 @@ void rtc_reset (void) buf[0] = RTC_RV3029_CTRL_SYS_R; ret = i2c_write(CONFIG_SYS_I2C_RTC_ADDR, RTC_RV3029_CTRL_RESET, 1, buf, 1); + +#if defined(CONFIG_SYS_RV3029_TCR) + /* + * because EEPROM_CTRL register is in EEPROM page it is necessary to + * disable automatic EEPROM refresh and check if EEPROM is busy + * before EEPORM_CTRL register may be accessed + */ + set_eere_bit(0); + wait_eebusy(100); + /* read current trickle charger setting */ + ret = i2c_read(CONFIG_SYS_I2C_RTC_ADDR, RTC_RV3029_EEPROM_CTRL, + 1, buf, 1); + /* enable automatic EEPROM refresh again */ + set_eere_bit(1); + + /* + * to minimize EEPROM access write trickle charger setting only if it + * differs from current value + */ + if ((buf[0] & 0xF0) != CONFIG_SYS_RV3029_TCR) { + buf[0] = (buf[0] & 0x0F) | CONFIG_SYS_RV3029_TCR; + /* + * write trickle charger setting (disable autom. EEPROM + * refresh and wait until EEPROM is idle) + */ + set_eere_bit(0); + wait_eebusy(100); + ret = i2c_write(CONFIG_SYS_I2C_RTC_ADDR, + RTC_RV3029_EEPROM_CTRL, 1, buf, 1); + /* + * it is necessary to wait 10ms before EEBUSY-Bit may be read + * (this is not documented in the data sheet yet, but the + * manufacturer recommends it) + */ + udelay(10000); + /* wait until EEPROM write access is finished */ + wait_eebusy(100); + set_eere_bit(1); + } +#endif }
Signed-off-by: Heiko Schocher hs@denx.de --- include/configs/digsy_mtc.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index e7fd0f7..7e50a86 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -252,6 +252,7 @@ #if defined(CONFIG_DIGSY_REV5) #define CONFIG_SYS_I2C_RTC_ADDR 0x56 #define CONFIG_RTC_RV3029 +#define CONFIG_SYS_RV3029_TCR #else #define CONFIG_RTC_DS1337 #define CONFIG_SYS_I2C_RTC_ADDR 0x68
changes for v2: - set CONFIG_SYS_RV3029_TCR to 5k Ohm
checkpatch says:
20110328_2/0001-rtc-rv3029-add-trickle-charger-support.patch has no obvious style problems and is ready for submission. total: 0 errors, 0 warnings, 8 lines checked
20110328_2/0002-mpc52xx-digsy_mtc-add-trickle-charger-support-for-re.patch has no obvious style problems and is ready for submission.
README | 2 + drivers/rtc/rv3029.c | 87 +++++++++++++++++++++++++++++++++++++++++++ include/configs/digsy_mtc.h | 2 + 3 files changed, 91 insertions(+), 0 deletions(-)
Dear Heiko Schocher,
Applied,t hanks.
--- changes for v2: - set CONFIG_SYS_RV3029_TCR to 5k Ohm
include/configs/digsy_mtc.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index e7fd0f7..f1613c7 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -252,6 +252,8 @@ #if defined(CONFIG_DIGSY_REV5) #define CONFIG_SYS_I2C_RTC_ADDR 0x56 #define CONFIG_RTC_RV3029 +/* Enable 5k Ohm trickle charge resistor */ +#define CONFIG_SYS_RV3029_TCR 0x20 #else #define CONFIG_RTC_DS1337 #define CONFIG_SYS_I2C_RTC_ADDR 0x68
changes for v2:
Applied, thanks.
Hallo Heiko,
changes for v2:
checkpatch says:
Looks good, so
Acked-by: Detlev Zundel dzu@denx.de
Cheers Detlev
Detlev Zundel
Heiko Schocher
