[U-Boot] FIT: workarounding wrong configuration name
In our project we read device ID from EEPROM and then select an appropriate configuration "bootm ${loadaddr}#conf${board_name}". If for some reason wrong ID was written into EEPROM, then it is still important, that device can still be booted with default configuration.
One can still put a big warning, saying, that provided configuration is missing and that the system is using default one.
What do you think about this?
Regards, Yegor
Signed-off-by: Yegor Yefremov yegorslists@googlemail.com --- common/image-fit.c | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index c61be65..b892d06 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1547,6 +1547,10 @@ int fit_image_load(bootm_headers_t *images, ulong addr, } else { cfg_noffset = fit_conf_get_node(fit, fit_uname_config); + + if (cfg_noffset < 0) { + cfg_noffset = fit_conf_get_node(fit, NULL); + } } if (cfg_noffset < 0) { puts("Could not find configuration node\n");
Hi Yegor,
It seems if you ask for a specific configuration that is not available, you should get an error.
You can accomplish similar behavior you are implementing here by using the shell to try the default if the specified one returns an error.
Cheers, -Joe
Hi Joe,
On Mon, May 4, 2015 at 8:16 PM, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Yegor,
Thanks. It is working:
bootm ${loadaddr}#conf${board_name}; if test $? -ne 0; then echo "Using default FIT configuration"; bootm ${loadaddr}; fi;
Now I have another question, how can I split long line in uEnv.txt? Is it possible at all?
Yegor
Hi Yegor,
On Tue, May 12, 2015 at 1:43 AM, Yegor Yefremov yegorslists@googlemail.com wrote:
Hi Joe,
Hi Yegor,
Great!
I assume you are loading it and eventually calling env import on the memory?
Have you tried passing the -t switch to the env import command?
Or are you talking about a single variable value that is a long line?
-Joe
Hi Joe,
On Tue, May 12, 2015 at 10:18 PM, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Yegor,
Hi Joe,
Hi Yegor,
Great!
Yes, I'm talking about a single variable with very long value.
Yegor
Hi Yegor,
On Tue, May 12, 2015 at 3:41 PM, Yegor Yefremov yegorslists@googlemail.com wrote:
Hi Joe,
Hi Yegor,
Hi Joe,
Hi Yegor,
Great!
I think we would need to patch the env import to handle escaping newlines to do something like this. Then you could end a line with \ and it would still be part of the value of the previous variable.
I'm not sure of a way as it works now.
-Joe
Joe Hershberger
Yegor Yefremov
