[U-Boot] [PATCH] PXA: FIX: Deep-sleep return address in stored in PSPR
FIX for a typo-bug: The address is stored in PSPR, not PSSR.
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/cpu.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/pxa/cpu.c b/arch/arm/cpu/pxa/cpu.c index 7d49cbb..3bc0525 100644 --- a/arch/arm/cpu/pxa/cpu.c +++ b/arch/arm/cpu/pxa/cpu.c @@ -305,7 +305,7 @@ void pxa_wakeup(void) pxa_dram_init(); icache_disable(); dcache_disable(); - asm volatile("mov pc, %0"::"r"(readl(PSSR))); + asm volatile("mov pc, %0"::"r"(readl(PSPR))); } }
Albert, this is actually a resend of a very old patch. I dunno why it didn't get into mainline, but it really SHOULD be picked up.
Also, can you please just merge it without pull rq?
Thanks!
}asm volatile("mov pc, %0"::"r"(readl(PSPR)));
Hi Marek,
Signed-off-by: Marek Vasutmarek.vasut@gmail.com
You mean apply it to u-boot-arm/master directly ? I can, but if you want it applied ASAP, maybe you should ask that Wolfgang apply it to u-boot/master directly.
Amicalement,
On Wednesday, September 07, 2011 04:23:19 PM Albert ARIBAUD wrote:
Hi Marek,
It's a bugfix that wasn't applied for six months ... AND noone complained. It means 1) PXA is dead and noone cares 2) it's in no hurry.
Wolfgang, if you feel like applying it to master, please do.
Amicalement,
Dear Marek Vasut,
In message 1315401946-17065-1-git-send-email-marek.vasut@gmail.com you wrote:
Applied, thanks.
Albert ARIBAUD
